cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : GroupingEntity.hpp 00003 // 00004 // Purpose : This file contains the declarations of the class 00005 // GroupingEntity. 00006 // This class is the base class of all the grouping entities 00007 // Body, Shell, Loop, Chain. 00008 // 00009 // Special Notes : Each GroupingEntity is associated with a set of 00010 // SenseEntity's (SE's). These SE's are ordered in a 00011 // list. Hence the GroupingEntity interface 00012 // not only provides the ability to get the entire list 00013 // of SE's, but also allows you to ask for the "first" 00014 // associated SE. The SE interface thus provides a 00015 // function to ask for the "next" SE. The linked 00016 // list of SE's ends when the next function returns a 00017 // NULL pointer. 00018 // 00019 // The same is true of GroupingEntities themselves. They 00020 // are an ordered list in the DAG, implying that a next() 00021 // function needs to be provided. 00022 // 00023 // This is a pure virtual class. 00024 // 00025 // Creator : Xuechen Liu 00026 // 00027 // Creation Date : 07/11/96 00028 // 00029 // Owner : Malcolm J. Panthaki 00030 //------------------------------------------------------------------------- 00031 00032 #ifndef GROUPING_ENTITY_HPP 00033 #define GROUPING_ENTITY_HPP 00034 00035 // ********** BEGIN STANDARD INCLUDES ********** 00036 // ********** END STANDARD INCLUDES ********** 00037 00038 // ********** BEGIN CUBIT INCLUDES ********** 00039 #include "CubitDefines.h" 00040 #include "TopologyEntity.hpp" 00041 // ********** END CUBIT INCLUDES ********** 00042 00043 // ********** BEGIN MACROS DEFINITIONS ********** 00044 // ********** END MACROS DEFINITIONS ********** 00045 00046 // ********** BEGIN FORWARD DECLARATIONS ********** 00047 class SenseEntity; 00048 class BasicTopologyEntity; 00049 00050 // ********** END FORWARD DECLARATIONS ********** 00051 00052 class CUBIT_GEOM_EXPORT GroupingEntity : public TopologyEntity 00053 { 00054 public : 00055 00056 inline GroupingEntity() ; 00057 //- The default constructor 00058 00059 virtual ~GroupingEntity(); 00060 00061 inline SenseEntity* get_first_sense_entity_ptr(); 00062 inline SenseEntity* get_last_sense_entity_ptr(); 00063 //R SenseEntity* 00064 //R- A pointer to the first of the list of SenseEntitys pointed 00065 //R- to by this object. 00066 //- This function returns a pointer to the first of the list of 00067 //- SenseEntity's pointed to by this GroupingEntity. 00068 00069 CubitStatus get_sense_entity_list(DLIList<SenseEntity*>& list); 00070 //R CubitStatus 00071 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00072 //O list 00073 //O- A list of SenseEntity pointers. 00074 //- This function returns a list of SenseEntity pointers 00075 //- associated with this GroupingEntity. If there are none, then 00076 //- CUBIT_FAILURE is returned. 00077 00078 CubitStatus set_sense_entity_list(DLIList<SenseEntity*>& list, 00079 DLIList<SenseEntity*>& removed); 00080 //R CubitStatus 00081 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00082 //I list 00083 //I- New set of child SenseEntitys for this GroupingEntity. 00084 //O removed 00085 //O- List of child SenseEntitys removed from this GroupingEntity 00086 //- Change/reorder child list. 00087 //- It is an error for any input SenseEntity to have a parent 00088 //- GroupingEntity unless that parent GroupingEntity is this. 00089 00090 00091 inline GroupingEntity* next(); 00092 //R GroupingEntity* 00093 //R- A GroupingEntity pointer 00094 //- This function returns a pointer to the GroupingEntity that is 00095 //- a child of this one in the DAG. If it is the end of the line, 00096 //- then a NULL pointer is returned. 00097 00098 inline GroupingEntity* previous(); 00099 //R GroupingEntity* 00100 //R- A GroupingEntity pointer 00101 //- This function returns a pointer to the GroupingEntity that is 00102 //- a child of this one in the DAG. If it is the end of the line, 00103 //- then a NULL pointer is returned. 00104 00105 inline BasicTopologyEntity* get_basic_topology_entity_ptr(); 00106 //R BasicTopologyEntity* 00107 //R- A pointer to the BasicTopologyEntity which the current grouping 00108 //R- entity is associated with. 00109 //- This function returns a pointer to the BasicTopologyEntity which 00110 //- the current sense entity is associated with. 00111 00112 CubitStatus add_sense_entity(SenseEntity *sense_entity_ptr, 00113 SenseEntity *after_this = 0) ; 00114 //R CubitStatus 00115 //I senseEntityPtr 00116 //I- The pointer to a SenseEntity which will be added to the 00117 //I- list of sense entities of the grouping entity. 00118 //- This function is used to add a SenseEntity to the list of 00119 //- sense entities of a grouping entity. If the input sense entity 00120 //- is not the appropriate type, nothing is done and the function 00121 //- returns CUBIT_FAILURE. If the sense entity is added successfully, 00122 //- the function returns CUBIT_SUCCESS. 00123 00124 CubitStatus remove_sense_entity(SenseEntity* sense_entity_ptr); 00125 00126 void reverse_direction(); 00127 // reverse order and sense of child sense entities 00128 00129 virtual int get_parents( DLIList<TopologyEntity*>* list = 0 ) const; 00130 virtual int get_children(DLIList<TopologyEntity*>* list = 0 ) const; 00131 00132 protected : 00133 00134 virtual CubitBoolean query_append_parents( DLIList<TopologyEntity*>& list ); 00135 virtual CubitBoolean query_append_children(DLIList<TopologyEntity*>& list ); 00136 00137 virtual CubitStatus remove_child_link( TopologyEntity* child_ptr ); 00138 00139 CubitStatus disconnect_all_children( DLIList<TopologyEntity*>* children = 0 ); 00140 CubitStatus disconnect_all_parents( DLIList<TopologyEntity*>* parents = 0 ); 00141 00142 private : 00143 00144 // for use by BasicTopologyEntity only 00145 friend class BasicTopologyEntity; 00146 inline CubitStatus remove_from_list(); 00147 inline void set_basic_topology_entity_ptr( BasicTopologyEntity* ); 00148 inline CubitStatus insert_after(GroupingEntity* next); 00149 inline CubitStatus insert_before(GroupingEntity* prev); 00150 00151 BasicTopologyEntity* myParent; 00152 GroupingEntity* nextInParent; 00153 GroupingEntity* prevInParent; 00154 SenseEntity* firstSenseEntity; 00155 SenseEntity* lastSenseEntity; 00156 00157 GroupingEntity( const GroupingEntity& ); 00158 void operator=( const GroupingEntity& ); 00159 }; 00160 00161 // ********** BEGIN HELPER CLASSES ********** 00162 // ********** END HELPER CLASSES ********** 00163 00164 // ********** BEGIN INLINE FUNCTIONS ********** 00165 00166 inline GroupingEntity::GroupingEntity() 00167 : myParent(0), 00168 nextInParent(0), 00169 prevInParent(0), 00170 firstSenseEntity(0), 00171 lastSenseEntity(0) 00172 {} 00173 00174 inline SenseEntity* GroupingEntity::get_first_sense_entity_ptr() 00175 { return firstSenseEntity; } 00176 00177 inline SenseEntity* GroupingEntity::get_last_sense_entity_ptr() 00178 { return lastSenseEntity; } 00179 00180 inline GroupingEntity* GroupingEntity::next() 00181 { return nextInParent; } 00182 00183 inline GroupingEntity* GroupingEntity::previous() 00184 { return prevInParent; } 00185 00186 inline BasicTopologyEntity* GroupingEntity::get_basic_topology_entity_ptr() 00187 { return myParent; } 00188 00189 inline CubitStatus GroupingEntity::remove_from_list() 00190 { 00191 if (nextInParent) 00192 nextInParent->prevInParent = prevInParent; 00193 if (prevInParent) 00194 prevInParent->nextInParent = nextInParent; 00195 prevInParent = nextInParent = 0; 00196 return CUBIT_SUCCESS; 00197 } 00198 00199 inline CubitStatus GroupingEntity::insert_after( GroupingEntity* next_ptr ) 00200 { 00201 prevInParent = next_ptr; 00202 nextInParent = next_ptr->nextInParent; 00203 if (nextInParent) 00204 nextInParent->prevInParent = this; 00205 next_ptr->nextInParent = this; 00206 return CUBIT_SUCCESS; 00207 } 00208 00209 inline CubitStatus GroupingEntity::insert_before( GroupingEntity* prev_ptr ) 00210 { 00211 nextInParent = prev_ptr; 00212 prevInParent = prev_ptr->prevInParent; 00213 if (prevInParent) 00214 prevInParent->nextInParent = this; 00215 prev_ptr->prevInParent = this; 00216 return CUBIT_SUCCESS; 00217 } 00218 00219 inline void GroupingEntity::set_basic_topology_entity_ptr( BasicTopologyEntity* bte_ptr ) 00220 { 00221 assert(!myParent || !bte_ptr); 00222 myParent = bte_ptr; 00223 } 00224 00225 00226 // ********** END INLINE FUNCTIONS ********** 00227 00228 // ********** BEGIN FRIEND FUNCTIONS ********** 00229 // ********** END FRIEND FUNCTIONS ********** 00230 00231 // ********** BEGIN EXTERN FUNCTIONS ********** 00232 // ********** END EXTERN FUNCTIONS ********** 00233 00234 #endif 00235
