cgma
00001 //- Class: LoopParamTool 00002 //------------------------------------------------------------------------- 00003 // Filename : LoopParamTool.cpp 00004 // 00005 // Purpose : Surface Parameterization for mesh by triangulation flattening 00006 // 00007 // Creator : Shiraj Khan 00008 // 00009 // Creation Date : 1/21/2003 00010 // 00011 // Owner : Shiraj Khan 00012 //------------------------------------------------------------------------- 00013 00014 #include "LoopParamTool.hpp" 00015 #include "CastTo.hpp" 00016 #include "CubitPointData.hpp" 00017 #include "GeometryDefines.h" 00018 #include "GeometryDefines.h" 00019 #include "CubitMessage.hpp" 00020 #include "math.h" 00021 #define EPSILON_LOWER -0.00000001 00022 #define EPSILON_UPPER 0.00000001 00023 #define SWAP(a,b) { temp = a; a = b; b = temp; } 00024 00025 00026 00027 00028 //------------------------------------------------------------------------- 00029 // Function: LoopParamTool 00030 // Description: constructor 00031 // Author: Shiraj Khan 00032 // Date: 1/21/2003 00033 //------------------------------------------------------------------------- 00034 LoopParamTool::LoopParamTool() 00035 { 00036 00037 } 00038 00039 //------------------------------------------------------------------------- 00040 // Function: LoopParamTool 00041 // Description: deconstructor 00042 // Author: Shiraj Khan 00043 // Date: 1/21/2003 00044 //------------------------------------------------------------------------- 00045 LoopParamTool::~LoopParamTool() {} 00046 00047 //=================================================================================== 00048 // Function: set_up_space (Public) 00049 // Description: sets up space of flattening 00050 // Author: Shiraj Khan 00051 // Date: 1/21/2003 00052 //=================================================================================== 00053 CubitStatus LoopParamTool::set_up_space() 00054 { 00055 return CUBIT_SUCCESS; 00056 } 00057 00058 //=================================================================================== 00059 // Function: new_space_LoopParam (Public) 00060 // Description: sets up space of flattening 00061 // Author: Shiraj Khan 00062 // Date: 1/21/2003 00063 //=================================================================================== 00064 CubitStatus LoopParamTool::new_space_LoopParam( DLIList<DLIList<CubitPoint *>*> &loops_cubit_points, 00065 CubitVector* normal) 00066 { 00067 00068 int ii; 00069 int jj; 00070 double sumx = 0.0, sumy = 0.0, sumz = 0.0; 00071 double sumxx = 0.0, sumxy = 0.0, sumxz = 0.0; 00072 double sumyy = 0.0, sumyz = 0, sumzz = 0.0; 00073 double aa[4][4]; 00074 double Xc = 0.0, Yc = 0.0, Zc = 0.0; 00075 int n = 0; 00076 00077 CubitPoint *point, *point1, *point2; 00078 CubitVector point_coordinates, point_coordinates1, point_coordinates2; 00079 CubitVector cm_plane; // center of mass of a plane 00080 CubitVector vec1, vec2, plane_normal; 00081 DLIList<CubitPoint *> *sub_loops_cubit_points; 00082 00083 00084 for ( ii = 0; ii < loops_cubit_points.size(); ii++ ) 00085 { 00086 sub_loops_cubit_points = loops_cubit_points.get_and_step(); 00087 for ( jj = 0; jj < sub_loops_cubit_points->size(); jj++ ) 00088 { 00089 point = sub_loops_cubit_points->get_and_step(); 00090 point_coordinates = point->coordinates(); 00091 sumx = sumx + point_coordinates.x(); 00092 sumy = sumy + point_coordinates.y(); 00093 sumz = sumz + point_coordinates.z(); 00094 sumxx = sumxx + ( point_coordinates.x() * point_coordinates.x() ); 00095 sumxy = sumxy + ( point_coordinates.x() * point_coordinates.y() ); 00096 sumxz = sumxz + ( point_coordinates.x() * point_coordinates.z() ); 00097 sumyy = sumyy + ( point_coordinates.y() * point_coordinates.y() ); 00098 sumyz = sumyz + ( point_coordinates.y() * point_coordinates.z() ); 00099 sumzz = sumzz + ( point_coordinates.z() * point_coordinates.z() ); 00100 n++; 00101 } 00102 } 00103 Xc = sumx / n; 00104 Yc = sumy / n; 00105 Zc = sumz / n; 00106 cm_plane.set(Xc,Yc,Zc); 00107 if ( Xc < EPSILON_UPPER && Xc > EPSILON_LOWER ) Xc = 0.0; 00108 if ( Yc < EPSILON_UPPER && Yc > EPSILON_LOWER ) Yc = 0.0; 00109 if ( Zc < EPSILON_UPPER && Zc > EPSILON_LOWER ) Zc = 0.0; 00110 aa[1][1] = sumxx - Xc * sumx; 00111 aa[1][2] = sumxy - Yc * sumx; 00112 aa[1][3] = sumxz - Zc * sumx; 00113 aa[2][1] = sumxy - Xc * sumy; 00114 aa[2][2] = sumyy - Yc * sumy; 00115 aa[2][3] = sumyz - Zc * sumy; 00116 aa[3][1] = sumxz - Xc * sumz; 00117 aa[3][2] = sumyz - Yc * sumz; 00118 aa[3][3] = sumzz - Zc * sumz; 00119 00120 for ( ii = 1; ii <=3; ii++ ) 00121 { 00122 for ( jj = 1; jj <=3; jj++ ) 00123 if ( aa[ii][jj] < EPSILON_UPPER && aa[ii][jj] > EPSILON_LOWER ) 00124 aa[ii][jj] = 0.0; 00125 } 00126 double determinant_aa = aa[1][1] * ( aa[2][2]*aa[3][3] - aa[3][2]*aa[2][3] ) - aa[1][2] * ( aa[2][1]*aa[3][3] - aa[3][1]*aa[2][3] ) 00127 + aa[1][3] * ( aa[2][1]*aa[3][2] - aa[3][1]*aa[2][2] ); 00128 00129 if ( determinant_aa < EPSILON_UPPER && determinant_aa > EPSILON_LOWER ) 00130 determinant_aa = 0.0; 00131 loops_cubit_points.reset(); 00132 00133 // if determinant is 0.0 ( all the points are lying on the plane), the equation of a plane: 00134 //(vec1) crossproduct (vec2) 00135 // where vec1 and vec2 are the vectors originating from a common point( center of mass of a plane) and 00136 // lying on the plane. 00137 if(normal){ 00138 a = normal->x(); 00139 b = normal->y(); 00140 c = normal->z(); 00141 d = -(a*Xc + b*Yc + c*Zc ); 00142 } 00143 else if ( determinant_aa == 0.0 ) 00144 { 00145 sub_loops_cubit_points = loops_cubit_points.get_and_step(); 00146 point1 = sub_loops_cubit_points->get_and_step(); 00147 point2 = sub_loops_cubit_points->get_and_step(); 00148 point_coordinates1 = point1->coordinates(); 00149 point_coordinates2 = point2->coordinates(); 00150 vec1 = cm_plane - point_coordinates1; 00151 vec2 = cm_plane - point_coordinates2; 00152 plane_normal = vec1 * vec2; 00153 a = plane_normal.x(); 00154 b = plane_normal.y(); 00155 c = plane_normal.z(); 00156 d = -( a*Xc + b*Yc + c*Zc ); 00157 } 00158 else // to calculate eigen vector corresponding to the smallest eigen value 00159 { 00160 // to calculate the inverse of a matrix 00161 int i, j, k; 00162 int icol = -1, irow = -1, l, ll; 00163 double big, z, pivinv, temp; 00164 int indxc[4]; 00165 int indxr[4]; 00166 int ipiv[4]; 00167 for ( j = 1; j <= 3; j++) 00168 { 00169 indxc[j] = 0; 00170 indxr[j] = 0; 00171 ipiv[j] = 0; 00172 } 00173 for ( i = 1; i <= 3;i++) 00174 { 00175 big = 0.0; 00176 for ( j = 1; j <= 3; j++) 00177 { 00178 if ( ipiv[j] != 1 ) 00179 { 00180 for ( k = 1; k <= 3; k++) 00181 { 00182 if (ipiv[k] == 0 ) 00183 { 00184 if (fabs(aa[j][k]) >= big ) 00185 { 00186 big = fabs(aa[j][k]); 00187 irow = j; 00188 icol = k; 00189 } 00190 } 00191 else if(ipiv[k]>1) PRINT_ERROR("Matrix is singular1\n"); 00192 } 00193 } 00194 } 00195 ipiv[icol]+=1; 00196 if ( irow != icol ) 00197 { 00198 for (l=1; l <= 3;l++) 00199 SWAP( aa[irow][l],aa[icol][l] ); 00200 00201 } 00202 indxr[i] = irow; 00203 indxc[i] = icol; 00204 if(aa[icol][icol] == 0.0 ) PRINT_ERROR("Matrix is singular2\n"); 00205 pivinv = 1.0/aa[icol][icol]; 00206 aa[icol][icol] = 1.0; 00207 for( l = 1; l <= 3; l++) 00208 aa[icol][l] *= pivinv; 00209 for ( ll = 1; ll <= 3; ll++) 00210 { 00211 if ( ll != icol ) 00212 { 00213 z = aa[ll][icol]; 00214 aa[ll][icol] = 0.0; 00215 for ( l = 1;l <= 3; l++) 00216 aa[ll][l] -= aa[icol][l] * z; 00217 00218 } 00219 } 00220 00221 for ( l = 3; l >= 1; l-- ) 00222 { 00223 if ( indxr[l] != indxc[l] ) 00224 for ( k = 1; k <= 3; k++ ) 00225 SWAP( aa[k][indxr[l]], aa[k][indxc[l]] ) 00226 } 00227 } 00228 00229 00230 // Power Method to get the Eigen Vector corresponding to the smallest Eigen value 00231 double x[4] = {0.0, 1.0, 1.1, 1.2}; 00232 double dd[4]; 00233 double zz[4]; 00234 int t = 0; 00235 double diff1 = 0.0, diff2 = 0.0; 00236 int flag; 00237 double largest_dd; 00238 while ( t <= 100 ) 00239 { 00240 flag = 1; 00241 for ( i = 1; i <= 3; i++ ) 00242 { 00243 dd[i] = 0.0; 00244 for ( j = 1; j <= 3; j++ ) 00245 { 00246 dd[i] = dd[i] + aa[i][j] * x[j]; 00247 00248 if (dd[i] > EPSILON_LOWER && dd[i] < EPSILON_UPPER) dd[i] = 0.0; 00249 } 00250 } 00251 t = t+1; 00252 largest_dd = dd[1] > dd[2] ? ( dd[1] > dd[3] ? dd[1] : dd[3] ) : ( dd[2] > dd[3] ? dd[2] : dd[3] ); 00253 for ( i = 1; i <= 3; i++ ) 00254 { 00255 zz[i] = dd[i]/largest_dd; 00256 if (zz[i] > EPSILON_LOWER && zz[i] < EPSILON_UPPER) zz[i] = 0.0; 00257 } 00258 for ( i = 1; i <= 3; i++ ) 00259 { 00260 diff1 = fabs(x[i] - zz[i]); 00261 diff2 = fabs(diff1) - EPSILON_UPPER*fabs(zz[i]); 00262 if ( diff2 <= 0.0 ) 00263 continue; 00264 else 00265 { 00266 flag = 0; 00267 break; 00268 } 00269 } 00270 if ( flag == 1 ) 00271 break; 00272 if (flag == 0 ) 00273 { 00274 for ( i = 1; i <= 3; i++ ) 00275 x[i] = zz[i]; 00276 } 00277 00278 00279 } 00280 for ( i = 1; i <= 3; i++ ) 00281 { 00282 x[i] = zz[i]; 00283 if ( (x[i] < EPSILON_UPPER) && (x[i] > EPSILON_LOWER) ) 00284 x[i] = 0.0; 00285 } 00286 a = x[1]; 00287 b = x[2]; 00288 c = x[3]; 00289 d = -(a*Xc+b*Yc+c*Zc); 00290 00291 } 00292 00293 //printf("\n\nEquation of Plane is %fx+%fy+%fz+%f = 0\n",a,b,c,d); 00294 loops_cubit_points.reset(); 00295 sub_loops_cubit_points = loops_cubit_points.get_and_step(); 00296 CubitPoint *p1 = sub_loops_cubit_points->get_and_step(); 00297 CubitVector p1_coordinates = p1->coordinates(); 00298 double p1x = p1_coordinates.x() - (p1_coordinates.x()*a + p1_coordinates.y()*b + p1_coordinates.z()*c + d)* 00299 (a)/(pow(a,2)+pow(b,2)+pow(c,2)); 00300 double p1y = p1_coordinates.y() - (p1_coordinates.x()*a + p1_coordinates.y()*b + p1_coordinates.z()*c + d)* 00301 (b)/(pow(a,2)+pow(b,2)+pow(c,2)); 00302 double p1z = p1_coordinates.z() - (p1_coordinates.x()*a + p1_coordinates.y()*b + p1_coordinates.z()*c + d)* 00303 (c)/(pow(a,2)+pow(b,2)+pow(c,2)); 00304 00305 p1_coordinates.set(p1x, p1y, p1z); 00306 CubitVector surf_normal; 00307 surf_normal.x(a); surf_normal.y(b); surf_normal.z(-1.0); 00308 surf_normal.normalize(); 00309 00310 // use the first two points on the boundary to define gradient vectors 00311 // and orient our uv space. 00312 CubitPoint *p2; 00313 CubitVector p2_coordinates; 00314 double p2x, p2y, p2z; 00315 double cos = 1.0; 00316 // 00317 while (cos == 1.0) 00318 { 00319 p2 = sub_loops_cubit_points->get_and_step(); 00320 p2_coordinates = p2->coordinates(); 00321 p2x = p2_coordinates.x() - (p2_coordinates.x()*a + p2_coordinates.y()*b + p2_coordinates.z()*c + d)* 00322 (a)/(pow(a,2)+pow(b,2)+pow(c,2)); 00323 p2y = p2_coordinates.y() - (p2_coordinates.x()*a + p2_coordinates.y()*b + p2_coordinates.z()*c + d)* 00324 (b)/(pow(a,2)+pow(b,2)+pow(c,2)); 00325 p2z = p2_coordinates.z() - (p2_coordinates.x()*a + p2_coordinates.y()*b + p2_coordinates.z()*c + d)* 00326 (c)/(pow(a,2)+pow(b,2)+pow(c,2)); 00327 p2_coordinates.set(p2x, p2y, p2z); 00328 00329 00330 if ( p1_coordinates == p2_coordinates ) 00331 cos = 1.0; 00332 else cos = 0.0; 00333 } 00334 Du = p2_coordinates - p1_coordinates; 00335 Du.normalize(); 00336 Dv = surf_normal * Du; 00337 Dv.normalize(); 00338 uvCenter = p1_coordinates; 00339 sub_loops_cubit_points->reset(); 00340 00341 return CUBIT_SUCCESS; 00342 } 00343 00344 //=================================================================================== 00345 // Function: transform_to_bestfit_plane (Public) 00346 // Description: same as title 00347 // Author: Shiraj Khan 00348 // Date: 1/21/2003 00349 //=================================================================================== 00350 CubitStatus LoopParamTool::transform_to_bestfit_plane(DLIList<DLIList<CubitPoint *>*> &loop_cubit_points) 00351 { 00352 int ii, jj; 00353 DLIList<CubitPoint *> *sub_loop_cubit_points = NULL; 00354 CubitPoint *point_ptr = NULL; 00355 00356 CubitVector point_coordinates; 00357 double x, y, z; 00358 00359 for ( ii = 0; ii < loop_cubit_points.size(); ii++ ) 00360 { 00361 sub_loop_cubit_points = loop_cubit_points.get_and_step(); 00362 00363 for ( jj = 0; jj < sub_loop_cubit_points->size(); jj++ ) 00364 { 00365 point_ptr = sub_loop_cubit_points->get_and_step(); 00366 ToolData* td = point_ptr->get_TD( &TDVector::is_td_vector ); 00367 TDVector* td_pos = NULL; 00368 if( NULL == td ) 00369 td_pos = new TDVector(point_ptr->coordinates()); 00370 else 00371 td_pos = static_cast<TDVector*>( td ); 00372 point_ptr->add_TD(td_pos); 00373 point_coordinates = point_ptr->coordinates(); 00374 00375 x = point_coordinates.x() - (point_coordinates.x()*a + point_coordinates.y()*b + point_coordinates.z()*c + d)* 00376 (a)/(pow(a,2)+pow(b,2)+pow(c,2)); 00377 y = point_coordinates.y() - (point_coordinates.x()*a + point_coordinates.y()*b + point_coordinates.z()*c + d)* 00378 (b)/(pow(a,2)+pow(b,2)+pow(c,2)); 00379 z = point_coordinates.z() - (point_coordinates.x()*a + point_coordinates.y()*b + point_coordinates.z()*c + d)* 00380 (c)/(pow(a,2)+pow(b,2)+pow(c,2)); 00381 point_coordinates.set(x, y, z); 00382 point_ptr->set(point_coordinates); 00383 00384 00385 } 00386 00387 } 00388 00389 return CUBIT_SUCCESS; 00390 } 00391 //=================================================================================== 00392 // Function: transform_to_uv (Public) 00393 // Description: Does nothing for this tool. 00394 // Author: Shiraj Khan 00395 // Date: 1/21/2003 00396 //=================================================================================== 00397 CubitStatus LoopParamTool::transform_to_uv(const CubitVector &, CubitVector &) 00398 { 00399 PRINT_ERROR("This function is not appropriate for the the LoopParamTool.\n"); 00400 assert(0); 00401 return CUBIT_FAILURE; 00402 } 00403 00404 00405 //=================================================================================== 00406 // Function: transform_to_uv_local (Private) 00407 // Description: It transforms points from the Best Fit plane plane to UV space 00408 // Author: Shiraj Khan 00409 // Date: 1/21/2003 00410 //=================================================================================== 00411 CubitStatus LoopParamTool::transform_to_uv_local(CubitVector &xyz_location, CubitVector &uv_location) 00412 { 00413 // Translate to local origin at center 00414 00415 CubitVector vect = xyz_location - uvCenter; 00416 00417 // Multiply by transpose (inverse) of transformation vector 00418 00419 uv_location.x( vect % Du ); 00420 uv_location.y( vect % Dv ); 00421 uv_location.z( 1.0 ); 00422 00423 return CUBIT_SUCCESS; 00424 } 00425 //=================================================================================== 00426 // Function: transform_to_xyz (Private) 00427 // Description: Does nothing, just fills in virtual function. 00428 // Author: Shiraj Khan 00429 // Date: 1/21/2003 00430 //=================================================================================== 00431 CubitStatus LoopParamTool::transform_to_xyz(CubitVector &, const CubitVector &) 00432 { 00433 PRINT_ERROR("This function is not appropriate for the the LoopParamTool.\n"); 00434 assert(0); 00435 return CUBIT_FAILURE; 00436 } 00437 00438 //=================================================================================== 00439 // Function: transform_to_xyz_local (Priavate) 00440 // Description: same as title 00441 // Author: Shiraj Khan 00442 // Date: 1/21/2003 00443 //=================================================================================== 00444 CubitStatus LoopParamTool::transform_to_xyz_local(CubitVector &xyz_location, CubitVector &uv_location) 00445 { 00446 // Multiply by transformation matrix 00447 00448 CubitVector vect; 00449 vect.x( uv_location.x() * Du.x() + 00450 uv_location.y() * Dv.x() ); 00451 vect.y( uv_location.x() * Du.y() + 00452 uv_location.y() * Dv.y() ); 00453 vect.z( uv_location.x() * Du.z() + 00454 uv_location.y() * Dv.z() ); 00455 00456 // Translate from origin 00457 00458 xyz_location = vect + uvCenter; 00459 00460 return CUBIT_SUCCESS; 00461 } 00462 00463 00464 //------------------------------------------------------------------------- 00465 // Function: transform_loopspoints_to_uv 00466 // Description: transform all the boundary points to the UV space. Use 00467 // the x-y coordinates in the points and set the z coordinate 00468 // to one 00469 // Author: Shiraj Khan 00470 // Date: 1/22/2003 00471 //------------------------------------------------------------------------- 00472 00473 CubitStatus LoopParamTool::transform_loopspoints_to_uv( DLIList<DLIList<CubitPoint *>*> &loops_point_list) 00474 00475 { 00476 int ii, jj; 00477 CubitStatus ret_value = CUBIT_SUCCESS; 00478 DLIList<CubitPoint *> *sub_loops_point_list; 00479 CubitPoint *point_ptr; 00480 CubitVector xyz_location, uv_location, point_coordinates; 00481 00482 // transform the points on the best fit plane 00483 ret_value = transform_to_bestfit_plane( loops_point_list); 00484 00485 /*printf("\n after transform to best fit plane\n"); 00486 for( ii = 0; ii < loops_point_list.size(); ii++) 00487 { 00488 sub_loops_point_list = loops_point_list.get_and_step(); 00489 for ( jj = 0; jj < sub_loops_point_list->size(); jj++) 00490 { 00491 point_ptr = sub_loops_point_list->get_and_step(); 00492 point_coordinates = point_ptr->coordinates(); 00493 printf(" %f %f %f \n",point_coordinates.x(),point_coordinates.y(),point_coordinates.z()); 00494 } 00495 }*/ 00496 00497 //transform to u-v 00498 for ( ii = 0; ii < loops_point_list.size(); ii++) 00499 { 00500 sub_loops_point_list = loops_point_list.get_and_step(); 00501 00502 for ( jj = 0; jj < sub_loops_point_list->size(); jj++ ) 00503 { 00504 point_ptr = sub_loops_point_list->get_and_step(); 00505 xyz_location = point_ptr->coordinates(); 00506 ret_value = transform_to_uv_local( xyz_location, uv_location ); 00507 point_ptr->set(uv_location); 00508 00509 } 00510 } 00511 00512 if ( check_selfintersecting_coincident_edges(loops_point_list) != CUBIT_SUCCESS ) 00513 { 00514 //PRINT_ERROR("Self interesections in parameter space found.\n"); 00515 ret_value = CUBIT_FAILURE; 00516 } 00517 else 00518 ret_value = CUBIT_SUCCESS; 00519 00520 00521 // if the self-intersecting and coincident edges are not there then return CUBIT_SUCCESS 00522 // else restore the points to their original positions and return CUBIT_FAILURE 00523 return ret_value; 00524 //don't do the rest for now... 00525 if ( ret_value == CUBIT_SUCCESS ) 00526 return CUBIT_SUCCESS; 00527 else 00528 { 00529 ToolData *td; 00530 for ( ii = 0; ii < loops_point_list.size(); ii++ ) 00531 { 00532 sub_loops_point_list = loops_point_list.next(ii); 00533 for ( jj = 0; jj < sub_loops_point_list->size(); jj++) 00534 { 00535 point_ptr = sub_loops_point_list->next(jj); 00536 td = point_ptr->get_TD(&TDVector::is_td_vector); 00537 TDVector *td_pos = CAST_TO(td, TDVector); 00538 CubitVector orig_xyz_location = td_pos->get_vector(); 00539 point_ptr->set(orig_xyz_location); 00540 point_coordinates = point_ptr->coordinates(); 00541 } 00542 } 00543 return CUBIT_FAILURE; 00544 } 00545 } 00546 //------------------------------------------------------------------------- 00547 // Function: check for self-intersecting and coincident edges 00548 // Description: check for self-intersecting and coincident edges. If the condition is true, 00549 // it generates an error " Can't mesh due to self intersecting/coincident edges 00550 // Author: Shiraj Khan 00551 // Date: 02/22/2003 00552 //------------------------------------------------------------------------- 00553 00554 CubitStatus LoopParamTool::check_selfintersecting_coincident_edges(DLIList<DLIList<CubitPoint *>*> 00555 &loops_bounding_points) 00556 { 00557 //This function checks each line segment against every other line segment 00558 //to see if they intersect or overlap. Each line will be described 00559 //by the following equations: 00560 // 00561 // Pa = P1 + ua( P2 - P1 ) 00562 // Pb = P3 + ub( P4 - P3 ) 00563 // 00564 //Setting the Pa equal to Pb and solving for ua and ub you will get two 00565 //equation. Both will have the common denominator: 00566 // 00567 // denom = ( (uv4.y() - uv3.y()) * (uv2.x() - uv1.x() ) - 00568 // (uv4.x() - uv3.x()) * (uv2.y() - uv1.y() ) ) 00569 // 00570 //And the numerators will be: 00571 // 00572 // numer_a = ( (uv4.x() - uv3.x()) * (uv1.y() - uv3.y() ) - 00573 // (uv4.y() - uv3.y()) * (uv1.x() - uv3.x() ) ) 00574 // 00575 // numer_b = ( (uv2.x() - uv1.x()) * (uv1.y() - uv3.y() ) - 00576 // (uv2.y() - uv1.y()) * (uv1.x() - uv3.x() ) ) 00577 // 00578 //ua and ub then become: 00579 // 00580 // ua = numer_a / denom 00581 // ub = numer_b / denom 00582 // 00583 //If the lines are parallel then denom will be zero. If they are 00584 //also coincedent then the numerators will also be zero. For the 00585 //segments to intersect ua and ub need to both be between 0 00586 //and 1. 00587 00588 int ii, jj, kk, ll; 00589 00590 for ( ii = 0; ii < loops_bounding_points.size(); ii++ ) 00591 { 00592 DLIList<CubitPoint*>* sub_loops_bounding_points1 = loops_bounding_points.next(ii); 00593 for( jj = 0; jj < sub_loops_bounding_points1->size(); jj++ ) 00594 { 00595 CubitPoint* start_point1 = sub_loops_bounding_points1->next(jj); 00596 CubitPoint* end_point1 = NULL; 00597 if ( jj == sub_loops_bounding_points1->size()-1 ) 00598 end_point1 = sub_loops_bounding_points1->next(0); 00599 else 00600 end_point1 = sub_loops_bounding_points1->next(jj+1); 00601 CubitVector uv1 = start_point1->coordinates(); 00602 CubitVector uv2 = end_point1->coordinates(); 00603 00604 //Start with the current loop in the list. The previous 00605 //lists have already been checked against this list. 00606 for ( kk = ii; kk < loops_bounding_points.size(); kk++ ) 00607 { 00608 DLIList<CubitPoint*>* sub_loops_bounding_points2 = loops_bounding_points.next(kk); 00609 for ( ll = 0; ll < sub_loops_bounding_points2->size(); ll++ ) 00610 { 00611 CubitPoint* start_point2 = sub_loops_bounding_points2->next(ll); 00612 CubitPoint* end_point2 = NULL; 00613 if ( ll == sub_loops_bounding_points2->size()-1 ) 00614 end_point2 = sub_loops_bounding_points2->next(0); 00615 else 00616 end_point2 = sub_loops_bounding_points2->next(ll+1); 00617 CubitVector uv3 = start_point2->coordinates(); 00618 CubitVector uv4 = end_point2->coordinates(); 00619 00620 if ( start_point1 == end_point2 || start_point1== start_point2 || 00621 end_point1 == start_point2 || end_point1 == end_point2 ) 00622 continue; 00623 00624 if ( (uv1 == uv3) && (uv2 == uv4) ) 00625 continue; 00626 00627 double denom = ( (uv4.y() - uv3.y()) * (uv2.x() - uv1.x() ) - 00628 (uv4.x() - uv3.x()) * (uv2.y() - uv1.y() ) ); 00629 00630 double numer_a = ( (uv4.x() - uv3.x()) * (uv1.y() - uv3.y() ) - 00631 (uv4.y() - uv3.y()) * (uv1.x() - uv3.x() ) ); 00632 00633 double numer_b = ( (uv2.x() - uv1.x()) * (uv1.y() - uv3.y() ) - 00634 (uv2.y() - uv1.y()) * (uv1.x() - uv3.x() ) ); 00635 00636 if( denom < CUBIT_RESABS && denom > -CUBIT_RESABS ) 00637 { 00638 //The lines are parallel. Check the numerators to 00639 //see if they are coincident. 00640 if( numer_a < CUBIT_RESABS && numer_a > -CUBIT_RESABS && 00641 numer_b < CUBIT_RESABS && numer_b > -CUBIT_RESABS ) 00642 { 00643 //The lines are coincident. Now see if the segments 00644 //over lap. 00645 double ua; 00646 double ub; 00647 if( (uv2.x() - uv1.x()) < CUBIT_RESABS && 00648 (uv2.x() - uv1.x()) > -CUBIT_RESABS ) 00649 { 00650 if( (uv2.y() - uv1.y() < CUBIT_RESABS && 00651 uv2.y() - uv1.y() > -CUBIT_RESABS)){ 00652 PRINT_ERROR("Can't mesh due to zero-length edge.\n"); 00653 return CUBIT_FAILURE; 00654 } 00655 ua = (uv3.y() - uv1.y() ) / ( uv2.y() - uv1.y() ); 00656 ub = (uv4.y() - uv1.y() ) / ( uv2.y() - uv1.y() ); 00657 } 00658 else 00659 { 00660 ua = (uv3.x() - uv1.x() ) / ( uv2.x() - uv1.x() ); 00661 ub = (uv4.x() - uv1.x() ) / ( uv2.x() - uv1.x() ); 00662 } 00663 00664 if ((ua > CUBIT_RESABS && ua < (1.0 - CUBIT_RESABS)) || 00665 (ub > CUBIT_RESABS && ub < (1.0 - CUBIT_RESABS))) 00666 { 00667 //The segments overlap. 00668 PRINT_ERROR("Can't mesh due to coincident edges \n\n\n"); 00669 return CUBIT_FAILURE; 00670 } 00671 } 00672 } 00673 else 00674 { 00675 double ua = numer_a / denom; 00676 double ub = numer_b / denom; 00677 00678 if( ( (ua > CUBIT_RESABS && ua < (1.0-CUBIT_RESABS)) && 00679 (ub > CUBIT_RESABS && ub < (1.0-CUBIT_RESABS))) ) 00680 { 00681 PRINT_ERROR("Can't mesh due to self intersecting edges \n\n\n"); 00682 return CUBIT_FAILURE; 00683 } 00684 } 00685 }//end of for ( ll ) 00686 }// end of for ( kk ) 00687 }//end of for ( jj ) 00688 }// end of for ( ii ) 00689 00690 return CUBIT_SUCCESS; 00691 } 00692 00693 bool LoopParamTool::double_equal(double val, double equal_to) 00694 { 00695 if ( (val < (equal_to + CUBIT_RESABS)) && (val > (equal_to - CUBIT_RESABS)) ) 00696 return true; 00697 else 00698 return false; 00699 } 00700 00701 //EOF
