cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : OffsetSplitTool.cpp 00003 // 00004 // Purpose : 00005 // 00006 // Split Surface <id_list> Offset Curve <id_list> 00007 // Distance <val> [Segment <val>] [Partition] [Blunt] [Preview [Create]] 00008 // 00009 // Special Notes : 00010 // 00011 // Creator : Sam Showman 00012 // 00013 // Creation Date : 05/10/2005 00014 //------------------------------------------------------------------------- 00015 #include "OffsetSplitTool.hpp" 00016 #include "AnalyticGeometryTool.hpp" 00017 #include "RefFace.hpp" 00018 #include "Point.hpp" 00019 #include "Curve.hpp" 00020 #include "CubitMessage.hpp" 00021 #include "GeometryModifyTool.hpp" 00022 #include "GeometryModifyEngine.hpp" 00023 #include "GeometryQueryTool.hpp" 00024 #include "CubitUtil.hpp" 00025 #include "DLIList.hpp" 00026 #include "GfxPreview.hpp" 00027 #include "GMem.hpp" 00028 #include "Curve.hpp" 00029 #include "BodySM.hpp" 00030 #include "TopologyBridge.hpp" 00031 #include "Surface.hpp" 00032 #include "CubitBox.hpp" 00033 00034 // #define OFFSET_SPLIT_DEBUG 00035 00036 double OffsetSplitTool::tolerance = .001; 00037 00038 OffsetSplitTool::OffsetSplitTool() 00039 { 00040 } 00041 00042 CubitStatus OffsetSplitTool::split_surfaces_offset(DLIList<RefFace*> &ref_face_list, 00043 DLIList<RefEdge*> &edge_list, 00044 int num_segs, 00045 double distance_in, 00046 CubitBoolean divide_flg, 00047 CubitBoolean blunt_flg, 00048 CubitBoolean preview_flg, 00049 CubitBoolean create_ref_edges_flg) 00050 { 00051 ref_face_list.uniquify_unordered(); 00052 edge_list.uniquify_unordered(); 00053 00054 // Check for valid number of segments 00055 if( num_segs < 1 ) 00056 { 00057 PRINT_ERROR( "Number of specified segments must be >= 1\n" ); 00058 return CUBIT_FAILURE; 00059 } 00060 00061 if(ref_face_list.size() < 1) 00062 { 00063 PRINT_ERROR( "No surfaces specified for splitting\n" ); 00064 return CUBIT_FAILURE; 00065 } 00066 00067 if(edge_list.size() < 1) 00068 { 00069 PRINT_ERROR( "No curves specified for splitting\n" ); 00070 return CUBIT_FAILURE; 00071 } 00072 00073 // clear the preview graphics 00074 GfxPreview::clear(); 00075 00076 DLIList<Curve*> offset_curves; 00077 DLIList<DLIList<Curve*>*> imprint_list; 00078 for(int seg = 1;seg<num_segs+1;seg++) 00079 { 00080 // set the current distance 00081 double distance = (distance_in/(double)num_segs)*(seg); 00082 00083 // generate a swept body at each curve 00084 DLIList<BodySM*> body_list; 00085 DLIList<TBPoint*> points; 00086 GeometryModifyEngine* gme = 0; 00087 GeometryQueryEngine* gqe = 0; 00088 edge_list.reset(); 00089 int i = 0; 00090 for(i =edge_list.size();i--;) 00091 { 00092 RefEdge* ref_edge = edge_list.get_and_step(); 00093 Curve* cur_curve = ref_edge->get_curve_ptr(); 00094 00095 // add the curve to the class list of source curves 00096 // will use this latter for dividing surfaces 00097 sourceCurves.append(cur_curve); 00098 00099 gqe = cur_curve->get_geometry_query_engine(); 00100 gme = GeometryModifyTool::instance()->get_engine(cur_curve); 00101 tolerance = gqe->get_sme_resabs_tolerance(); 00102 00103 if(!gme) 00104 { 00105 PRINT_ERROR( "No ModifyEngine found!\n" ); 00106 return CUBIT_FAILURE; 00107 } 00108 00109 cur_curve->points(points); 00110 Curve* swept_curve = create_sweep_curve(cur_curve,distance,tolerance,CUBIT_TRUE); 00111 if(!swept_curve) 00112 { 00113 PRINT_WARNING("Failed to create offset geometry for curve %d.\n",ref_edge->id()); 00114 continue; 00115 } 00116 00117 CubitVector swpt_loc, source_loc; 00118 cur_curve->position_from_fraction(0.0,source_loc); 00119 swept_curve->position_from_fraction(0.0,swpt_loc); 00120 00121 CubitVector up_vector = swpt_loc-source_loc; 00122 00123 Surface* section = create_sweep_section(cur_curve,distance,up_vector); 00124 if(!section) 00125 { 00126 PRINT_WARNING("Failed to create offset geometry for curve %d.\n",ref_edge->id()); 00127 // delete the Curve path 00128 gqe->delete_solid_model_entities(swept_curve); 00129 continue; 00130 } 00131 00132 BodySM* swept_body = create_sweep_body(section,swept_curve); 00133 00134 // delete the Curve path and Surface section 00135 gqe->delete_solid_model_entities(swept_curve); 00136 if(!swept_body) 00137 { 00138 PRINT_WARNING("Failed to create offset geometry for curve %d.\n",ref_edge->id()); 00139 continue; 00140 } 00141 00142 body_list.append(swept_body); 00143 } 00144 00145 if(body_list.size() == 0) 00146 { 00147 PRINT_ERROR("Failed to offset any curve.\n"); 00148 return CUBIT_FAILURE; 00149 } 00150 00151 DLIList<TBPoint*> blunt_points; 00152 if(blunt_flg == CUBIT_TRUE) 00153 { 00154 for(i = 0; i < points.size(); i++) 00155 { 00156 bool remove_point = true; 00157 CubitVector pnt_loc_0 = points[i]->coordinates(); 00158 int j = 0; 00159 for(j = 0;j < points.size(); j++) 00160 { 00161 if(i==j) 00162 continue; 00163 00164 if(points[j] == points[i]) 00165 { 00166 remove_point = false; 00167 break; 00168 } 00169 00170 CubitVector pnt_loc_1 = points[j]->coordinates(); 00171 00172 if(pnt_loc_1.within_tolerance(pnt_loc_0,tolerance)) 00173 { 00174 remove_point = false; 00175 break; 00176 } 00177 } 00178 if(remove_point) 00179 blunt_points.append(points[i]); 00180 } 00181 } 00182 points.uniquify_ordered(); 00183 points -= blunt_points; 00184 00185 for(i = points.size(); i--;) 00186 { 00187 BodySM* shpere_body = gme->sphere(distance); 00188 CubitVector trans_dist = points.get_and_step()->coordinates(); 00189 gqe->translate(shpere_body,trans_dist); 00190 body_list.append(shpere_body); 00191 } 00192 00193 // create the offset geometry for debuging 00194 #ifdef OFFSET_SPLIT_DEBUG 00195 for(i=body_list.size();i--;) 00196 { 00197 GeometryQueryTool::instance()->make_Body( 00198 gme->copy_body(body_list.get_and_step())); 00199 } 00200 #endif 00201 00202 DLIList<BodySM*> united_body_list; 00203 if(body_list.size() == 1) 00204 united_body_list = body_list; 00205 else 00206 { 00207 if(!gme->unite(body_list,united_body_list))//united_body_list)) 00208 { 00209 if(body_list.size() == 1) 00210 PRINT_ERROR( "Offset split failed at the unite step.\n" ); 00211 else 00212 PRINT_ERROR( "Offset split failed at the unite step. Try reducing the curve count\n" ); 00213 00214 // delete the solid bodies 00215 for(i = body_list.size(); i--;) 00216 gqe->delete_solid_model_entities(body_list.get_and_step()); 00217 00218 return CUBIT_FAILURE; 00219 } 00220 } 00221 00222 // get the surfaces contained in the body 00223 DLIList<Surface*> surface_united_list; 00224 for(i = united_body_list.size(); i--;) 00225 { 00226 BodySM* cur_body = united_body_list.get_and_step(); 00227 cur_body->surfaces(surface_united_list); 00228 } 00229 00230 ref_face_list.reset(); 00231 imprint_list.reset(); 00232 for(i = ref_face_list.size(); i--;) 00233 { 00234 Surface* surf_1 = ref_face_list.get_and_step()->get_surface_ptr(); 00235 DLIList<Curve*> cur_curves; 00236 for(int j = surface_united_list.size(); j--;) 00237 { 00238 DLIList<Curve*> intersection_curves; 00239 Surface* surf_2 = surface_united_list.get_and_step(); 00240 gme->surface_intersection(surf_1,surf_2,intersection_curves,0.0); 00241 00242 // remove any very small curves from the intersection graph 00243 // for some reason seems to return zero length curves 00244 for(int k = intersection_curves.size();k--;) 00245 { 00246 Curve* cur_curve = intersection_curves[k]; 00247 double len = cur_curve-> 00248 length_from_u(cur_curve->start_param(),cur_curve->end_param()); 00249 00250 if(fabs(len) < tolerance) 00251 { 00252 intersection_curves.remove(cur_curve); 00253 gqe->delete_solid_model_entities(cur_curve); 00254 } 00255 } 00256 00257 // do the division if the user asks for it 00258 if(divide_flg && 00259 num_segs == seg && 00260 // skip the curves created by sphere surfaces 00261 surf_2->geometry_type() != SPHERE_SURFACE_TYPE && 00262 surf_2->geometry_type() != PLANE_SURFACE_TYPE) 00263 { 00264 intersection_curves += 00265 this->create_divide_curves(intersection_curves,surf_1,distance); 00266 } 00267 00268 cur_curves += intersection_curves; 00269 } 00270 DLIList<Curve*>* surf_inter_list = 0; 00271 00272 if(ref_face_list.size() > imprint_list.size()) 00273 { 00274 surf_inter_list = new DLIList<Curve*>; 00275 imprint_list.append(surf_inter_list); 00276 } 00277 else 00278 surf_inter_list = imprint_list.get_and_step(); 00279 00280 (*surf_inter_list) += cur_curves; 00281 offset_curves += cur_curves; 00282 00283 // draw the preview as the offset curves are being calculated 00284 if(preview_flg && !create_ref_edges_flg) 00285 draw_preview(cur_curves); 00286 } 00287 00288 // delete the solid bodies 00289 for(i = united_body_list.size(); i--;) 00290 gqe->delete_solid_model_entities(united_body_list.get_and_step()); 00291 } 00292 00293 // ok, now do the imprint or preview 00294 if(preview_flg) 00295 { 00296 if(!create_ref_edges_flg) 00297 { 00298 //Delete the Curve entities 00299 for(int i=0;i<offset_curves.size();i++) 00300 { 00301 Curve* cur_curve = offset_curves.get_and_step(); 00302 cur_curve->get_geometry_query_engine()-> 00303 delete_solid_model_entities(cur_curve); 00304 } 00305 } 00306 else 00307 { 00308 create_ref_edges(offset_curves); 00309 } 00310 00311 // delete the list that contained the curves that would have been imprinted 00312 for(int i= imprint_list.size();i--;) 00313 delete imprint_list.get_and_step(); 00314 } 00315 // Imprint 00316 else 00317 { 00318 int i = 0; 00319 ref_face_list.reset(); 00320 DLIList<Surface*> surface_list; 00321 for( i = ref_face_list.size(); i--;) 00322 surface_list.append(ref_face_list.get_and_step()->get_surface_ptr()); 00323 00324 Body *new_body_ptr; 00325 if( GeometryModifyTool::instance()->imprint( surface_list, 00326 imprint_list, new_body_ptr, false, false ) == CUBIT_FAILURE ) 00327 { 00328 //Delete the Curve entities 00329 for(i= offset_curves.size();i--;) 00330 { 00331 Curve* cur_curve = offset_curves.get_and_step(); 00332 cur_curve->get_geometry_query_engine()-> 00333 delete_solid_model_entities(cur_curve); 00334 } 00335 00336 // delete the curves that would have been imprinted 00337 for( i= imprint_list.size();i--;) 00338 delete imprint_list.get_and_step(); 00339 00340 return CUBIT_FAILURE; 00341 } 00342 00343 //Delete the Curve entities 00344 for( i= offset_curves.size();i--;) 00345 { 00346 Curve* cur_curve = offset_curves.get_and_step(); 00347 cur_curve->get_geometry_query_engine()-> 00348 delete_solid_model_entities(cur_curve); 00349 } 00350 00351 // delete the curves that were used for imprinted 00352 for( i= imprint_list.size();i--;) 00353 delete imprint_list.get_and_step(); 00354 } 00355 00356 return CUBIT_SUCCESS; 00357 } 00358 00359 //- Begin Private Functions 00360 CubitStatus OffsetSplitTool::draw_preview( 00361 DLIList<Curve*> &curve_list, 00362 int color ) 00363 { 00364 int i; 00365 Curve *curve_ptr; 00366 curve_list.reset(); 00367 for( i=curve_list.size(); i--; ) 00368 { 00369 curve_ptr = curve_list.get_and_step(); 00370 draw_preview( curve_ptr, CUBIT_FALSE, color ); 00371 } 00372 00373 GfxPreview::flush(); 00374 00375 return CUBIT_SUCCESS; 00376 } 00377 00378 CubitStatus OffsetSplitTool::draw_preview( 00379 Curve *curve_ptr, 00380 CubitBoolean flush, 00381 int color ) 00382 { 00383 CubitStatus result; 00384 GMem g_mem; 00385 00386 // get the graphics 00387 result = curve_ptr->get_geometry_query_engine()-> 00388 get_graphics( curve_ptr, &g_mem ); 00389 00390 if (result==CUBIT_FAILURE || g_mem.pointListCount == 0) 00391 { 00392 PRINT_WARNING("Unable to preview a curve\n" );; 00393 double len = curve_ptr-> 00394 length_from_u(curve_ptr->start_param(),curve_ptr->end_param()); 00395 00396 PRINT_WARNING("Curve len: %f\n",len); 00397 } 00398 00399 // Draw the polyline 00400 GfxPreview::draw_polyline( g_mem.point_list(), g_mem.pointListCount, color ); 00401 if( flush ) 00402 GfxPreview::flush(); 00403 00404 return CUBIT_SUCCESS; 00405 } 00406 00407 00408 Curve *OffsetSplitTool::create_sweep_curve( 00409 Curve *curve_in, 00410 double distance, 00411 double chord_tol, 00412 CubitBoolean iterate) 00413 { 00414 GeometryModifyEngine* gme = 00415 GeometryModifyTool::instance()->get_engine( curve_in ); 00416 GeometryQueryEngine* gqe = curve_in->get_geometry_query_engine(); 00417 00418 CubitVector start_pos; 00419 CubitVector end_pos; 00420 CubitVector dummy_pos; 00421 CubitVector x_axis; 00422 CubitVector y_axis; 00423 CubitVector z_axis; 00424 CubitVector curvature; 00425 00426 if(!curve_in->position_from_fraction(0.0,start_pos)) 00427 return 0; 00428 00429 if(!curve_in->position_from_fraction(1.0,end_pos)) 00430 return 0; 00431 00432 curve_in->closest_point(start_pos,dummy_pos,&z_axis,&curvature); 00433 00434 // check to see if the curve is planar 00435 CubitBoolean is_planar = CUBIT_FALSE; 00436 DLIList<Surface*> attached_surfs; 00437 curve_in->surfaces(attached_surfs); 00438 int i = 0; 00439 for(i = 0;i < attached_surfs.size();i++) 00440 { 00441 Surface* cur_surf = attached_surfs.get_and_step(); 00442 if(cur_surf && 00443 cur_surf->geometry_type() == PLANE_SURFACE_TYPE) 00444 { 00445 CubitVector center_vec; 00446 cur_surf->get_point_normal(center_vec,x_axis); 00447 is_planar = CUBIT_TRUE; 00448 break; 00449 } 00450 } 00451 00452 if(is_planar) 00453 { 00454 y_axis = z_axis*x_axis; 00455 } 00456 // If curvature is significant, use it to create the sweep coordinate system 00457 else if(curvature.length() < CUBIT_DBL_MIN) 00458 { 00459 z_axis.orthogonal_vectors(x_axis,y_axis); 00460 } 00461 else 00462 { 00463 y_axis = curvature; 00464 x_axis = z_axis*y_axis; 00465 } 00466 00467 x_axis.normalize(); 00468 y_axis.normalize(); 00469 z_axis.normalize(); 00470 x_axis *=distance; 00471 00472 GeometryType geom_type = curve_in->geometry_type(); 00473 if(geom_type == STRAIGHT_CURVE_TYPE) // if the curve is a line just offset it 00474 { 00475 // has problems calculating the intersection curves of surface edges and surfaces 00476 // so rotate the coordinate system to some angle that is less likely to be used 00477 x_axis.normalize(); 00478 y_axis.normalize(); 00479 CubitVector move_vec = y_axis - x_axis; 00480 y_axis = y_axis+(move_vec*.744561789854); 00481 x_axis = z_axis*y_axis; 00482 00483 x_axis.normalize(); 00484 y_axis.normalize(); 00485 z_axis.normalize(); 00486 x_axis *=distance; 00487 00488 // just offset the curve 00489 Curve* offset_curve = gme->make_Curve(curve_in); 00490 gqe->translate(offset_curve,x_axis); 00491 return offset_curve; 00492 } 00493 else if(geom_type == ARC_CURVE_TYPE || 00494 geom_type == ELLIPSE_CURVE_TYPE || 00495 is_planar) // if the curve is a arc just offset it 00496 { 00497 // just offset the curve 00498 Curve* offset_curve = gme->make_Curve(curve_in); 00499 gqe->translate(offset_curve,x_axis); 00500 return offset_curve; 00501 } 00502 00503 DLIList<CubitVector*> pnt_list; 00504 CubitVector* loc_0 = new CubitVector(start_pos); 00505 CubitVector* loc_1 = new CubitVector(end_pos); 00506 pnt_list.append(loc_0); 00507 pnt_list.append(loc_1); 00508 DLIList<double> frac_list; 00509 frac_list.append(0.0); 00510 frac_list.append(1.0); 00511 frac_list.reset(); 00512 00513 // create the curve points with a maximum deviation of 'chord_tol' 00514 while(1) 00515 { 00516 double frac_0 = frac_list.get_and_step(); 00517 double frac_1 = frac_list.get(); 00518 pnt_list.step(); 00519 00520 if(frac_0>frac_1) 00521 break; 00522 00523 CubitVector tmp_pos_0; 00524 curve_in->position_from_fraction(frac_0,tmp_pos_0); 00525 CubitVector tmp_pos_1; 00526 curve_in->position_from_fraction(frac_1,tmp_pos_1); 00527 CubitVector tmp_pos_2 = (tmp_pos_0+tmp_pos_1)/2.0; 00528 CubitVector tmp_pos_3; 00529 double mid_frac = (frac_0+frac_1)/2.0; 00530 curve_in->position_from_fraction(mid_frac,tmp_pos_3); 00531 00532 if(tmp_pos_3.distance_between(tmp_pos_2) > chord_tol) 00533 { 00534 CubitVector* loc = new CubitVector(tmp_pos_3); 00535 pnt_list.back(); 00536 frac_list.back(); 00537 pnt_list.insert(loc); 00538 frac_list.insert(mid_frac); 00539 pnt_list.back(); 00540 frac_list.back(); 00541 } 00542 } 00543 00544 // generate the offset curve points 00545 CubitVector last_vec = x_axis; 00546 pnt_list.reset(); 00547 for(i = 0;i < pnt_list.size();i++) 00548 { 00549 CubitVector curv,tangent,dummy; 00550 CubitVector *cur_pnt = pnt_list.get_and_step(); 00551 curve_in->closest_point(*cur_pnt,dummy,&tangent,&curv); 00552 00553 // if the radius of curvature is smaller than the distance of the 00554 // sweep offset then return a NULL curve 00555 if(curvature.length()> CUBIT_DBL_MIN && 00556 1.0/(curv.length()) <= distance) 00557 { 00558 // clean out the points 00559 for(int i =pnt_list.size();i--;) 00560 delete pnt_list.get_and_step(); 00561 00562 PRINT_WARNING("Radius of curvature is smaller than or equal to %f.\n" 00563 "Cannot offset curve.\n",distance); 00564 return 0; 00565 } 00566 00567 CubitVector up_vec = tangent*last_vec; 00568 CubitVector offset_vec = up_vec*tangent; 00569 offset_vec.normalize(); 00570 offset_vec *= distance; 00571 cur_pnt->set(*cur_pnt + offset_vec); 00572 last_vec = offset_vec; 00573 } 00574 00575 // create a spline sweep path 00576 pnt_list.reset(); 00577 TBPoint* start_point = gme->make_Point(*(pnt_list.get_and_back())); 00578 TBPoint* end_point = gme->make_Point(*(pnt_list.get_and_step())); 00579 00580 // Create the curve 00581 00582 Curve* curve_out = 00583 gme->make_Curve( 00584 SPLINE_CURVE_TYPE, 00585 start_point,end_point,pnt_list); 00586 00587 pnt_list.reset(); 00588 for(i =pnt_list.size();i--;) 00589 delete pnt_list.get_and_step(); 00590 00591 pnt_list.clean_out(); 00592 return curve_out; 00593 } 00594 00595 00596 Surface* OffsetSplitTool::create_sweep_section( 00597 Curve* path, 00598 double distance, 00599 CubitVector up_vector, 00600 double fraction) 00601 { 00602 up_vector.normalize(); 00603 GeometryModifyEngine* gme = 00604 GeometryModifyTool::instance()->get_engine( path ); 00605 00606 CubitVector start_pos; 00607 CubitVector dummy_pos; 00608 CubitVector x_axis; 00609 CubitVector y_axis; 00610 CubitVector z_axis; 00611 if(!path->position_from_fraction(fraction,start_pos)) 00612 return 0; 00613 00614 path->closest_point(start_pos,dummy_pos,&z_axis); 00615 y_axis = z_axis*up_vector; 00616 x_axis = up_vector; 00617 00618 x_axis.normalize(); 00619 y_axis.normalize(); 00620 z_axis.normalize(); 00621 00622 TBPoint* start_point = gme->make_Point(start_pos+x_axis); 00623 TBPoint* end_point = gme->make_Point(start_pos-x_axis); 00624 TBPoint* center_point = gme->make_Point(start_pos); 00625 00626 Curve* arc_curve_0 = 00627 gme->create_arc_center_edge(center_point,start_point,end_point,z_axis,distance); 00628 00629 start_point = gme->make_Point(start_pos+x_axis); 00630 end_point = gme->make_Point(start_pos-x_axis); 00631 center_point = gme->make_Point(start_pos); 00632 00633 Curve* arc_curve_1 = 00634 gme->create_arc_center_edge(center_point,start_point,end_point,-z_axis,distance); 00635 00636 DLIList<Curve*> curve_list; 00637 curve_list.append(arc_curve_0); 00638 curve_list.append(arc_curve_1); 00639 00640 Surface* surf_out = 00641 gme->make_Surface(PLANE_SURFACE_TYPE,curve_list,0,false); 00642 00643 return surf_out; 00644 } 00645 00646 BodySM* OffsetSplitTool::create_sweep_body( 00647 Surface* section, 00648 Curve* path) 00649 { 00650 GeometryModifyEngine* gme = 00651 GeometryModifyTool::instance()->get_engine( section ); 00652 00653 DLIList<GeometryEntity*> ent_list; 00654 ent_list.append(section); 00655 DLIList<BodySM*> body_list; 00656 DLIList<Curve*> path_list; 00657 path_list.append(path); 00658 00659 gme->sweep_along_curve(ent_list,body_list,path_list, 0.0, 0, 00660 CUBIT_FALSE, CUBIT_FALSE, CUBIT_FALSE); 00661 00662 if(body_list.size()) 00663 return body_list.get(); 00664 00665 return 0; 00666 } 00667 00668 CubitStatus OffsetSplitTool::create_ref_edges( 00669 DLIList<Curve*> &curve_list ) 00670 { 00671 int i; 00672 Curve *curve_ptr; 00673 curve_list.reset(); 00674 for( i=curve_list.size(); i--; ) 00675 { 00676 curve_ptr = curve_list.get_and_step(); 00677 GeometryQueryTool::instance()->make_free_RefEdge(curve_ptr); 00678 } 00679 return CUBIT_SUCCESS; 00680 } 00681 00682 DLIList<Curve*> OffsetSplitTool::create_divide_curves( 00683 DLIList<Curve*> &curve_list, 00684 Surface* target_surface, 00685 double distance) 00686 { 00687 DLIList<Curve*> return_list; 00688 curve_list.reset(); 00689 int curve_list_size = curve_list.size(); 00690 for(int i = curve_list_size; i--;) 00691 { 00692 Curve* cur_curve = curve_list.get_and_step(); 00693 GeometryModifyEngine* gme = 00694 GeometryModifyTool::instance()->get_engine( cur_curve ); 00695 GeometryQueryEngine* gqe = 00696 cur_curve->get_geometry_query_engine(); 00697 00698 // Find the matching source curve. 00699 // there are better ways to do this such as using the surface 00700 // arc intersection but that only seems to work for one engine or another 00701 // not both 00702 for(int j = sourceCurves.size(); j--;) 00703 { 00704 Curve* source_curve = sourceCurves.get_and_step(); 00705 CubitVector coord1; 00706 CubitVector coord2; 00707 double distance_out = 0.0; 00708 if(!gqe->entity_entity_distance( source_curve, cur_curve, 00709 coord1, coord2, distance_out )) 00710 continue; 00711 00712 if(fabs(distance_out-distance) < tolerance) 00713 { 00714 // check three points 00715 CubitVector pnt_0; 00716 CubitVector pnt_1; 00717 CubitVector pnt_2; 00718 CubitVector pnt_3; 00719 CubitVector pnt_4; 00720 CubitVector pnt_5; 00721 cur_curve->position_from_fraction(0.0,pnt_0); 00722 source_curve->closest_point(pnt_0,pnt_1); 00723 cur_curve->position_from_fraction(0.5,pnt_2); 00724 source_curve->closest_point(pnt_2,pnt_3); 00725 cur_curve->position_from_fraction(1.0,pnt_4); 00726 source_curve->closest_point(pnt_4,pnt_5); 00727 00728 if(fabs(pnt_0.distance_between(pnt_1) - distance) < tolerance && 00729 fabs(pnt_2.distance_between(pnt_3) - distance) < tolerance && 00730 fabs(pnt_4.distance_between(pnt_5) - distance) < tolerance) 00731 { 00732 // ok now just create curves between each end of the surface intersection curves 00733 // and the projection to the source curves 00734 00735 // first curve 00736 TBPoint* start_point_0 = gme->make_Point(pnt_0); 00737 TBPoint* end_point_0 = gme->make_Point(pnt_1); 00738 CubitVector vert3_coord_0 = start_point_0->coordinates(); 00739 00740 Curve* new_curve_0 = 00741 gme->make_Curve(STRAIGHT_CURVE_TYPE, 00742 start_point_0,end_point_0,&vert3_coord_0 ); 00743 00744 // second curve 00745 TBPoint* start_point_1 = gme->make_Point(pnt_4); 00746 TBPoint* end_point_1 = gme->make_Point(pnt_5); 00747 CubitVector vert3_coord_1 = start_point_1->coordinates(); 00748 00749 Curve* new_curve_1 = 00750 gme->make_Curve(STRAIGHT_CURVE_TYPE, 00751 start_point_1,end_point_1,&vert3_coord_1 ); 00752 00753 // if the target surface is not a plane then do a projection 00754 if(target_surface->geometry_type() != PLANE_SURFACE_TYPE) 00755 { 00756 DLIList<Curve*> curves_in; 00757 00758 if(new_curve_0) 00759 curves_in.append(new_curve_0); 00760 00761 if(new_curve_1) 00762 curves_in.append(new_curve_1); 00763 00764 DLIList<Curve*> curves_out; 00765 DLIList<Surface*> surface_in; 00766 surface_in.append(target_surface); 00767 if(gme->project_edges(surface_in,curves_in,curves_out)) 00768 return_list += curves_out; // add the curves to the return list 00769 } 00770 else // add the curves to the return list 00771 { 00772 if(new_curve_0) 00773 return_list.append(new_curve_0); 00774 00775 if(new_curve_1) 00776 return_list.append(new_curve_1); 00777 } 00778 } 00779 } 00780 } 00781 } 00782 return return_list; 00783 }
