cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : SenseEntity.hpp 00003 // 00004 // Purpose : This class is the base class of all sense entities such, 00005 // as CoVolume, CoFace, CoEdge, and CoVertex. 00006 // 00007 // Special Notes : This is a pure virtual class. 00008 // 00009 // Creator : Xuechen Liu 00010 // 00011 // Creation Date : 07/11/96 00012 // 00013 // Owner : Malcolm J. Panthaki 00014 //------------------------------------------------------------------------- 00015 00016 #ifndef SENSE_ENTITY_HPP 00017 #define SENSE_ENTITY_HPP 00018 00019 // ********** BEGIN STANDARD INCLUDES ********** 00020 // ********** END STANDARD INCLUDES ********** 00021 00022 // ********** BEGIN CUBIT INCLUDES ********** 00023 #include "CubitDefines.h" 00024 #include "TopologyEntity.hpp" 00025 #include "CubitObservable.hpp" 00026 00027 // ********** END CUBIT INCLUDES ********** 00028 00029 // ********** BEGIN MACROS DEFINITIONS ********** 00030 // ********** END MACROS DEFINITIONS ********** 00031 00032 // ********** BEGIN FORWARD DECLARATIONS ********** 00033 class BasicTopologyEntity ; 00034 class GroupingEntity; 00035 template <class X> class DLIList ; 00036 // ********** END FORWARD DECLARATIONS ********** 00037 00038 class CUBIT_GEOM_EXPORT SenseEntity : public TopologyEntity, 00039 public CubitObservable 00040 { 00041 public : 00042 00043 inline SenseEntity(); 00044 00045 virtual ~SenseEntity(); 00046 00047 inline BasicTopologyEntity* get_basic_topology_entity_ptr() ; 00048 //R BasicTopologyEntity* 00049 //R- A pointer to the BasicTopologyEntity which the current sense 00050 //R- entity is associated with. 00051 //- This function returns a pointer to the BasicTopologyEntity which 00052 //- the current sense entity is associated with. 00053 00054 inline GroupingEntity* get_grouping_entity_ptr(); 00055 //R GroupingEntity* 00056 //R- A pointer to the parent GroupingEntity. 00057 00058 BasicTopologyEntity* get_parent_basic_topology_entity_ptr(); 00059 00060 CubitStatus attach_basic_topology_entity(BasicTopologyEntity* basicTopologyEntityPtr) ; 00061 //R CubitStatus 00062 //R- CUBIT_SUCCESS/FAILURE 00063 //I basicTopologyEntityPtr 00064 //I- The pointer to a BasicTopologyEntity which will be attached as 00065 //I- a BasicTopologyEntity of this SenseEntity. 00066 //- This function is used to attach a BasicTopologyEntity to this 00067 //- SenseEntity. The operation can fail if the BTE is not the 00068 //- appropriate type. In that case the function returns 00069 //- CUBIT_FAILURE. If the attachment is done successfully, the function 00070 //- returns CUBIT_SUCCESS. 00071 00072 CubitStatus switch_basic_topology_entity(BasicTopologyEntity* new_bte ); 00073 //- Change the BasicTopologyEntity attached to this SenseEntity 00074 //- to the passed BTE. This is used by unmerge. 00075 00076 inline void set_sense(CubitSense sense) ; 00077 //R void 00078 //I sense 00079 //I- The sense to be set. 00080 //- This function sets the sense of the SenseEntity. 00081 00082 void reverse_sense(); 00083 //- Reverse the sense of this SenseEntity. 00084 00085 inline CubitSense get_sense() const ; 00086 //R CubitSense 00087 //R- The sense of the sense entity - CUBIT_FORWARD/REVERSED. 00088 //- This function returns the sense of the SenseEntity. 00089 00090 inline SenseEntity* next(); 00091 //R SenseEntity* 00092 //R- A SenseEntity pointer 00093 //- This function returns a pointer to the SenseEntity that is 00094 //- a child of this one in the DAG. If it is the end of the line, 00095 //- then a NULL pointer is returned. 00096 00097 inline SenseEntity* previous(); 00098 //R SenseEntity* 00099 //R- A SenseEntity pointer 00100 //- This function returns a pointer to the SenseEntity that is 00101 //- a "parent" of this one in the DAG. If this SenseEntity is 00102 //- already at the beginning of the list, then a NULL pointer is 00103 //- returned. 00104 00105 inline SenseEntity* next_on_bte(); 00106 //R SenseEntity* 00107 //R- The next sense entity in the linked of list of 00108 //R- sense entities associated with the child bte. 00109 00110 virtual int get_parents( DLIList<TopologyEntity*>* list = 0 ) const; 00111 virtual int get_children( DLIList<TopologyEntity*>* list = 0 ) const; 00112 00113 00114 protected : 00115 00116 virtual CubitBoolean query_append_parents( DLIList<TopologyEntity*>& list ); 00117 virtual CubitBoolean query_append_children(DLIList<TopologyEntity*>& list ); 00118 00119 virtual CubitStatus remove_child_link( TopologyEntity* ); 00120 00121 CubitStatus disconnect_all_children( DLIList<TopologyEntity*>* children = 0 ); 00122 CubitStatus disconnect_all_parents( DLIList<TopologyEntity*>* parents = 0 ); 00123 00124 private : 00125 00126 // functions for use by GroupingEntity only 00127 friend class GroupingEntity; 00128 inline CubitStatus gpe_insert_after (SenseEntity* prev_ptr); 00129 inline CubitStatus gpe_insert_before(SenseEntity* next_ptr); 00130 inline CubitStatus gpe_remove(); 00131 inline CubitStatus set_grouping_entity_ptr(GroupingEntity* gpe_ptr); 00132 inline void swap_gpe_list_ptrs(); 00133 00134 // functions for use by BasicTopologyEntity only 00135 friend class BasicTopologyEntity; 00136 inline SenseEntity* set_bte_next(SenseEntity* next_ptr); 00137 inline CubitStatus set_basic_topology_entity_ptr(BasicTopologyEntity* bte_ptr); 00138 00139 CubitSense mySense; 00140 00141 GroupingEntity* myParent; 00142 SenseEntity* nextInParent; 00143 SenseEntity* prevInParent; 00144 00145 BasicTopologyEntity* myChild; 00146 SenseEntity* nextInChild; 00147 00148 SenseEntity( const SenseEntity& ); 00149 void operator=( const SenseEntity& ); 00150 }; 00151 00152 00153 SenseEntity::SenseEntity() 00154 : mySense(CUBIT_FORWARD), 00155 myParent(0), 00156 nextInParent(0), 00157 prevInParent(0), 00158 myChild(0), 00159 nextInChild(0) 00160 {} 00161 00162 BasicTopologyEntity* SenseEntity::get_basic_topology_entity_ptr() 00163 { return myChild; } 00164 00165 GroupingEntity* SenseEntity::get_grouping_entity_ptr() 00166 { return myParent; } 00167 00168 void SenseEntity::set_sense(CubitSense sense) 00169 { mySense = sense; } 00170 00171 CubitSense SenseEntity::get_sense() const 00172 { return mySense; } 00173 00174 SenseEntity* SenseEntity::next() 00175 { return nextInParent; } 00176 00177 SenseEntity* SenseEntity::previous() 00178 { return prevInParent; } 00179 00180 SenseEntity* SenseEntity::next_on_bte() 00181 { return nextInChild; } 00182 00183 CubitStatus SenseEntity::gpe_insert_after(SenseEntity* prev_ptr) 00184 { 00185 nextInParent = prev_ptr->nextInParent; 00186 if (nextInParent) 00187 nextInParent->prevInParent = this; 00188 prevInParent = prev_ptr; 00189 prev_ptr->nextInParent = this; 00190 return CUBIT_SUCCESS; 00191 } 00192 00193 CubitStatus SenseEntity::gpe_insert_before(SenseEntity* next_ptr) 00194 { 00195 prevInParent = next_ptr->prevInParent; 00196 if (prevInParent) 00197 prevInParent->nextInParent = this; 00198 nextInParent = next_ptr; 00199 next_ptr->prevInParent = this; 00200 return CUBIT_SUCCESS; 00201 } 00202 00203 CubitStatus SenseEntity::gpe_remove() 00204 { 00205 if (nextInParent) 00206 nextInParent->prevInParent = prevInParent; 00207 if (prevInParent) 00208 prevInParent->nextInParent = nextInParent; 00209 prevInParent = nextInParent = 0; 00210 return CUBIT_SUCCESS; 00211 } 00212 00213 void SenseEntity::swap_gpe_list_ptrs() 00214 { 00215 SenseEntity* tmp = nextInParent; 00216 nextInParent = prevInParent; 00217 prevInParent = tmp; 00218 } 00219 00220 CubitStatus SenseEntity::set_grouping_entity_ptr(GroupingEntity* gpe_ptr) 00221 { 00222 myParent = gpe_ptr; 00223 return CUBIT_SUCCESS; 00224 } 00225 00226 SenseEntity* SenseEntity::set_bte_next(SenseEntity* next_ptr) 00227 { 00228 SenseEntity* old_val = nextInChild; 00229 nextInChild = next_ptr; 00230 return old_val; 00231 } 00232 00233 CubitStatus SenseEntity::set_basic_topology_entity_ptr( 00234 BasicTopologyEntity* bte_ptr) 00235 { 00236 if (myChild && bte_ptr) 00237 { assert(0); return CUBIT_FAILURE; } 00238 00239 myChild = bte_ptr; 00240 return CUBIT_SUCCESS; 00241 } 00242 00243 00244 // ********** BEGIN HELPER CLASSES ********** 00245 // ********** END HELPER CLASSES ********** 00246 00247 // ********** BEGIN INLINE FUNCTIONS ********** 00248 // ********** END INLINE FUNCTIONS ********** 00249 00250 // ********** BEGIN FRIEND FUNCTIONS ********** 00251 // ********** END FRIEND FUNCTIONS ********** 00252 00253 // ********** BEGIN EXTERN FUNCTIONS ********** 00254 // ********** END EXTERN FUNCTIONS ********** 00255 00256 00257 #endif 00258 00259
