cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : SplitSurfaceTool.hpp 00003 // 00004 // Purpose : Split a single or chain of surfaces (e.g., split a fillet 00005 // down the middle so that a mesh sweep can occur, or split 00006 // across a surface). Used by the "split surface" commands. 00007 // 00008 // Special Notes : 00009 // 00010 // Creator : Steve Storm 00011 // 00012 // Creation Date : 10/06/2002 00013 //------------------------------------------------------------------------- 00014 00015 #ifndef SPLITSURFACETOOL_HPP 00016 #define SPLITSURFACETOOL_HPP 00017 00018 #include "CubitDefines.h" 00019 #include "RefEdge.hpp" 00020 #include "RefVertex.hpp" 00021 #include "CoEdge.hpp" 00022 class Cubit2DPoint; 00023 class RefVertex; 00024 class RefEdge; 00025 class RefFace; 00026 class TDSplitSurface; 00027 //class Curve; 00028 class GeometryModifyEngine; 00029 00030 template <class X> class DLIList; 00031 00033 class CUBIT_GEOM_EXPORT SplitSurfaceTool 00034 { 00035 00036 public: 00037 00038 SplitSurfaceTool(); 00039 ~SplitSurfaceTool(){} 00040 00048 CubitStatus preview( RefFace *ref_face_ptr, 00049 DLIList<CubitVector*> &locations, 00050 DLIList<DLIList<CubitVector*>*> &vec_lists, 00051 CubitBoolean create_ref_edges_flg, 00052 CubitBoolean clear_previous_previews = CUBIT_TRUE ); 00053 00055 CubitStatus preview( DLIList<RefFace*> &ref_face_list, 00056 DLIList<CubitVector*> &locations, 00057 DLIList<DLIList<DLIList<CubitVector*>*>*> &list_of_vec_lists, 00058 CubitBoolean create_ref_edges_flg, 00059 CubitBoolean clear_previous_previews = CUBIT_TRUE ); 00060 00062 00063 00064 00065 00066 CubitStatus calculate_split_curves( RefFace *ref_face_ptr, 00067 DLIList<DLIList<CubitVector*>*> &vec_lists, 00068 DLIList<Curve*> &curve_list ); 00069 CubitStatus calculate_split_curves( Surface *surf_ptr, 00070 DLIList<DLIList<CubitVector*>*> &vec_lists, 00071 DLIList<Curve*> &curve_list ); 00073 00109 CubitStatus calculate_split_curves( DLIList<RefFace*> &ref_face_list, 00110 int num_segs, double fraction, 00111 double distance, RefEdge *from_curve_ptr, 00112 DLIList<RefVertex*> &corner_vertex_list, 00113 DLIList<RefVertex*> &through_vertex_list, 00114 RefEdge *curve_dir_ptr, 00115 CubitBoolean preview_flg, 00116 CubitBoolean create_ref_edges_flg, 00117 CubitBoolean just_curves_flg, 00118 DLIList<DLIList<Curve*>*> &curve_lists_list ); 00119 00125 CubitStatus split_surface( RefFace *ref_face_ptr, 00126 DLIList<DLIList<CubitVector*>*> &vec_lists ); 00127 00129 CubitStatus split_surface( DLIList<RefFace*> &ref_face_list, 00130 DLIList<DLIList<DLIList<CubitVector*>*>*> &list_of_vec_lists ); 00131 00133 CubitStatus split_surface( RefFace *ref_face_ptr, DLIList<Curve*> &curve_list); 00134 00170 CubitStatus split_surfaces( DLIList<RefFace*> &ref_face_list, 00171 int num_segs, 00172 double fraction, 00173 double distance, 00174 RefEdge *from_curve_ptr, 00175 DLIList<RefVertex*> &corner_vertex_list, 00176 DLIList<RefVertex*> &through_vertex_list, 00177 RefEdge *curve_dir_ptr = NULL, 00178 CubitBoolean preview_flg = CUBIT_FALSE, 00179 CubitBoolean create_ref_edges_flg = CUBIT_FALSE ); 00180 00187 CubitStatus split_surfaces( DLIList<RefFace*> &ref_face_list, 00188 int num_segs, 00189 double fraction, 00190 double distance, 00191 RefEdge *from_curve_ptr, 00192 DLIList<RefVertex*> &corner_vertex_list, 00193 DLIList<RefVertex*> &through_vertex_list, 00194 RefEdge *curve_dir_ptr, 00195 DLIList<DLIList<Curve*>*> &curve_lists_list ); 00196 00198 CubitStatus split_surfaces( DLIList<RefFace*> &ref_face_list, 00199 int num_segs, 00200 double fraction, 00201 double distance, 00202 RefEdge *from_curve_ptr, 00203 DLIList<RefVertex*> &corner_vertex_list, 00204 DLIList<RefVertex*> &through_vertex_list, 00205 RefEdge *curve_dir_ptr, 00206 DLIList<Curve*> &curve_list ); 00207 00230 CubitStatus split_surfaces_extend( DLIList<RefFace*> &ref_face_list, 00231 DLIList<RefVertex*> &ref_vertex_list, 00232 CubitBoolean preview_flg = CUBIT_FALSE, 00233 CubitBoolean create_ref_edges_flg = CUBIT_FALSE ); 00234 00238 void free_curves_lists( DLIList<DLIList<Curve*>*> &curve_lists_list, 00239 CubitBoolean free_curves_flg = CUBIT_TRUE ); 00240 00242 static void set_tolerance( double tol ); 00243 00254 static double get_tolerance(); 00255 00257 static void set_auto_detect_triangles_flg( CubitBoolean auto_detect_flg ); 00258 00260 static CubitBoolean get_auto_detect_triangles_flg(); 00261 00263 static void set_side_angle_threshold( double angle ); 00264 00268 static double get_side_angle_threshold(); 00269 00271 static void set_point_angle_threshold( double tol ); 00272 00276 static double get_point_angle_threshold(); 00277 00279 static void set_parametric_flg( CubitBoolean parametric_flg ); 00280 00290 static CubitBoolean get_parametric_flg(); 00291 00293 static void set_extend_gap_threshold( double threshold = CUBIT_DBL_MAX ); 00294 00296 static double get_extend_gap_threshold(); 00297 00301 static void set_extend_tolerance( double tol ); 00302 00304 static double get_extend_tolerance(); 00305 00309 static void set_extend_normal_flg( CubitBoolean extend_normal_flg ); 00310 00312 static CubitBoolean get_extend_normal_flg(); 00313 00315 static void initialize_settings(); 00316 00318 CubitStatus draw_preview( DLIList<Curve*> &curve_list, int color=CUBIT_BLUE_INDEX ); 00319 00320 Curve *create_curve( DLIList<CubitVector*> &vec_list, 00321 Surface *surf_ptr, 00322 double tolerance = GEOMETRY_RESABS, 00323 CubitBoolean iterate = CUBIT_FALSE, 00324 CubitBoolean draw_pnts = CUBIT_FALSE, 00325 CubitBoolean project_curve = CUBIT_TRUE ); 00326 //- Creates a curve given the input points. The function will attempt 00327 //- to use a straight line or arc, if possible. In order to create 00328 //- a straight line or arc, all of the input points must lie within 00329 //- 0.5*tolerance of a line or arc (0.5 to minimize the total deviation, 00330 //- exception - if tolerance==GEOMETRY_RESABS do not take 0.5), and the 00331 //- line or arc must lie within resabs of the surface (so that imprinting 00332 //- can occur). If iterate is TRUE, if a line or arc cannot be created, 00333 //- the function will iterate until a spline is created that lies within 00334 //- tolerance of the line segments input in vec_list (i.e., the resultant 00335 //- spline approximates a series of line segments). If draw_pnts is TRUE, 00336 //- the function will draw the resultant spline points. If project_curve 00337 //- is CUBIT_TRUE, project the curve to the surface (this option was 00338 //- added to speed up previewing - for that we skip the project). 00339 00340 private: 00341 00342 CubitStatus split_surfaces( DLIList<RefFace*> &ref_face_list, 00343 int num_segs, 00344 double fraction, 00345 double distance, 00346 RefEdge *from_curve_ptr, 00347 DLIList<RefVertex*> &corner_vertex_list, 00348 DLIList<RefVertex*> &through_vertex_list, 00349 RefEdge *curve_dir_ptr, 00350 CubitBoolean preview_flg, 00351 CubitBoolean create_ref_edges_flg, 00352 CubitBoolean just_curves_flg, 00353 DLIList<DLIList<Curve*>*> &curve_lists_list ); 00354 //- Main workhorse function for automatic splitting. See above for 00355 //- description of inputs. Note if just_curves_flg==CUBIT_TRUE, the 00356 //- preview_flg and create_ref_edges_flg are ignored. See above for 00357 //- description of the inputs. 00358 00359 CubitStatus check_valid_faces(); 00360 //- Check each face for multiple loops, hardlines and against looping on 00361 //- themselves (if more than one face). 00362 00363 CubitStatus order_face_list(); 00364 //- Order the refFaceChain from one end of surface chain to the other. 00365 //- This function also detects the isLoop condition (a continuous loop 00366 //- of surfaces). 00367 00368 CubitStatus get_neighbors( RefFace *seed_ref_face, 00369 DLIList<RefFace*> &input_ref_faces, 00370 DLIList<RefFace*> &neighbor_ref_faces ); 00371 //- Get all the neighbors of the input seed RefFace. Note second 00372 //- list is intended to be copied in. 00373 00374 CubitStatus get_outer_loops(); 00375 //- Get all of the outer loops - outerCurveLoop, outerCoEdgeLoop, 00376 //- outerVertexList. Make sure they start at the start surface 00377 //- in the chain. 00378 00379 CubitStatus get_outer_coedge_loop(); 00380 //- Given the ordered refFaceChain, finds the outerCoEdgeLoop. 00381 00382 CubitStatus find_loop_start( CoEdge *&start_co_edge_ptr ); 00383 //- Finds the start of the loop when constructing the outerCoEdgeLoop 00384 00385 CubitStatus get_outer_vertices( DLIList<RefVertex*> &ref_vertex_list ); 00386 //- Fill the given vertex list using the outerCoEdgeLoop. This is 00387 //- simply an ordered list of the vertices in the loop. 00388 00389 CubitStatus get_outer_curves( DLIList<RefEdge*> &ref_edge_list ); 00390 //- Fill the given refedge list using the outerCoEdgeLoop. This is 00391 //- simply an ordered list of refedges in the loop. 00392 00393 CubitStatus pick_4_corners(); 00394 //- For a chain of surfaces. Uses angle angle criteria to pick the 00395 //- corner vertices so that a mapping algorithm can be used to find 00396 //- the split locations on the surfaces. Two vertices must be on 00397 //- the start surface, and two on the end. 00398 00399 CubitStatus pick_expanded_corners( RefFace *ref_face_ptr, 00400 DLIList<CoEdge*> &co_edge_list, 00401 int &offset, double epsilon, 00402 int &A_i, int &B_i ); 00403 //- Used by pick_4_corners. Finds the two best corners on the given 00404 //- RefFace (which will be either the start or the end surface of the 00405 //- chain). If there are multiple vertices with the same angle, it 00406 //- will find the pair that are the farthest from the center. 00407 00408 CubitStatus pick_4_corners_simple(); 00409 //- For a single surface. Just finds the 4 corners closest to PI/2. 00410 00411 CubitStatus update_corners_for_triangle(); 00412 //- Determines whether any corners are close to 180 degrees (above 00413 //- angleTolerance). On a single surface, the corner that is 00414 //- closest to 180 and above angleTolerance is removed. The next 00415 //- angle farthest from PI/2 is chosen as the corner of the triangle. 00416 //- For a chain, both ends of the chain are checked. 00417 00418 CubitStatus remove_corner( int corner_to_remove, int collapsed_corner, 00419 CubitBoolean set_collapsed_first ); 00420 //- Removes a corner making a triangle. If set_collapsed_first is 00421 //- CUBIT_TRUE, then the collapsed side is set to the first corner, 00422 //- meaning the split will originate there. 00423 00424 CubitStatus fill_corners( int best_corner_1, int best_corner_2, 00425 int best_corner_3, int best_corner_4 ); 00426 //- Fill the cornerCoEdge array given the position of the corners 00427 00428 CubitStatus fill_side_intervals( int best_corner_1, int best_corner_2, 00429 int best_corner_3, int best_corner_4 ); 00430 //- Fill sideInterval array given teh position of the corners 00431 00432 CubitStatus order_selected_corners( DLIList<RefVertex*> &outer_vertex_list ); 00433 //- If the user specified corners, this function will reorient the lists 00434 //- so that the desired split direction will occur. It also does error 00435 //- checking on the users selected corners. 00436 00437 int number_in_list( DLIList<RefVertex*> &corner_vertex_list, 00438 RefVertex *ref_vertex_ptr ); 00439 //- Count the number of times the given RefVertex exists in the list 00440 00441 CubitBoolean is_in_outer_loop( RefVertex *ref_vertex_ptr ); 00442 //- Determines whether the given vertex exists in the outer loop 00443 00444 CubitStatus compute_angles( double *&angles, double &turn_angle_sum ); 00445 //- This finds an array of angles around the outer loop for finding 00446 //- corners. Note the angles array is allocated - the calling function 00447 //- must free it. turn_angle_sum is currently not used. 00448 00449 void order_corners( int &corner_1, int &corner_2, 00450 int &corner_3, int &corner_4 ); 00451 void order_corners( int &corner_1, int &corner_2, 00452 int &corner_3 ); 00453 //- Given the best corners in any order, these functions just sort them 00454 //- from lowest to highest. 00455 00456 CubitStatus adjust_for_split_direction( RefEdge *curve_dir_ptr, 00457 RefEdge *from_curve_ptr, 00458 DLIList<RefVertex*> &corner_vertex_list ); 00459 //- Adjust the lists so that the split direction is proper. See function 00460 //- for logic details (i.e., always split along chains of surfaces, attempt 00461 //- to split along highest aspect ratio for single surfaces, etc.). 00462 00463 double get_side_length( int side ); 00464 //- Determines the length of a given side of the logical rectangle. 00465 00466 double compute_next_angle( DLIList<CoEdge*> &co_edge_list ); 00467 //- Finds the next angle when walking around outerCoEdgeLoop finding 00468 //- angles for corner picking. It steps the list. 00469 00470 CubitStatus reorient_loop( int start_offset ); 00471 //- Reorients the global loop (outerCoEdgeLoop) so that it starts at the beginning. 00472 00473 CubitStatus shuffle_corners_forward(); 00474 //- This shuffles the outer loop, side interval and corner array forward 00475 //- by sideInterval[0] (ie., useful when changing the split direction for 00476 //- a single surface). 00477 00478 CubitStatus shuffle_zero_side_forward(); 00479 //- This shuffles the zero interval side (present on triangles) forward. 00480 //- Side interval and corner array affected. This function is necessary 00481 //- if user specifies a 'direction' or 'from' curve when splitting a triangle. 00482 00483 CubitStatus populate_curve_loops(); 00484 //- Populates the CoEdge lists in the surface tooldatas. The CoEdge lists 00485 //- are organized by side of the logical rectangle on each surface in 00486 //- refFaceChain. 00487 00488 CubitBoolean is_edge_in_list( RefEdge *ref_edge_ptr, DLIList<CoEdge*> &co_edge_list ); 00489 //- Determines if the given RefEdge is the child of any of the CoEdges in co_edge_list 00490 00491 CubitStatus check_face_loop( RefFace *ref_face_ptr, CubitBoolean &is_loop ); 00492 //- Checks a single surface to see if it is a loop. 00493 00494 CubitStatus check_for_loop( RefFace *ref_face_ptr1, RefFace *ref_face_ptr2, 00495 CubitBoolean &is_loop, 00496 CoEdge *&start_co_edge_ptr ); 00497 //- Checks a two-surface chain to see if it is a loop. If it is a loop, it can 00498 //- return the starting coedge as well (warning - if not a loop, the starting 00499 //- coedge is not set). 00500 00501 CubitStatus ordered_co_edges( RefFace *ref_face_ptr, DLIList<CoEdge*> &co_edge_list ); 00502 //- Get an ordered list of coedges from the RefFace. The RefFace must only 00503 //- contain one loop. 00504 00505 CoEdge *get_next_co_edge( CoEdge *prev_co_edge_ptr, DLIList<CoEdge*> &co_edge_list ); 00506 //- Given the previous CoEdge, get the next CoEdge using the CoEdges in 00507 //- the given list. 00508 00509 RefVertex *start_vertex( CoEdge *co_edge_ptr ); 00510 //- Get the starting vertex of the given CoEdge. 00511 00512 RefVertex *end_vertex( CoEdge *co_edge_ptr ); 00513 //- Get the ending vertex of the given CoEdge. 00514 00515 CoEdge *get_complimentary_co_edge( CoEdge *co_edge_ptr, 00516 DLIList<CoEdge*> co_edge_list ); 00517 //- Find the CoEdge from co_edge_list that shares a common RefEdge with 00518 //- the input co_edge_ptr. Returns NULL if no complimentary CoEdge is 00519 //- found. Note the input co_edge_list is copied so that it's list 00520 //- position is not changed. 00521 00522 CubitStatus get_attached_coedges_start( CoEdge *co_edge_ptr, 00523 DLIList<CoEdge*> &co_edge_list, 00524 DLIList<CoEdge*> &attached_co_edge_list ); 00525 //- Get coedges from co_edge_list whose start vertices are attached to the start 00526 //- vertex of co_edge_ptr 00527 00528 CubitStatus remove_other_corner_coedges( CoEdge *co_edge_1, CoEdge *co_edge_2, 00529 DLIList<CoEdge*> &all_co_edge_list, 00530 DLIList<CoEdge*> &att_co_edge_list ); 00531 //- For isLoop situation, removes CoEdges from the "attached_co_edge_list" 00532 //- that are connected to the other shared corner. The inputs are the 00533 //- previous and next CoEdges surrounding this (not the other) corner. 00534 00535 CubitStatus add_tooldata( DLIList<CoEdge*> &co_edge_list, int vertex_type ); 00536 //- Add a tooldata to each of the CoEdges in co_edge_list containing the 00537 //- vertex_type at the start of the CoEdge. 00538 00539 CubitBoolean is_vertex_on_side( RefVertex *ref_vertex_ptr, int side ); 00540 //- Determines if the given vertex lies on the given side. Note the 00541 //- vertex is checked spatially, not literally as if in the vertices 00542 //- in the outer loop. 00543 00544 CubitBoolean is_vertex_in_surface( RefVertex *ref_vertex_ptr, RefFace *ref_face ); 00545 //- Determines if the given vertex is in the given RefFace. 00546 00547 CubitBoolean is_curve_in_outer_loop( RefEdge *ref_edge_ptr ); 00548 //- Determines if the given curve lies in the outer loop of curves. 00549 00550 CubitBoolean is_curve_on_side( RefEdge *ref_edge_ptr, int side ); 00551 //- Determines if the given curve lies on the given side. 00552 00553 CubitBoolean is_chain_two_triangles(); 00554 //- Determines wheither the chain of surfaces is actually two connected 00555 //- triangles (see diagram in function). 00556 00557 CubitBoolean is_triangle(); 00558 //- Determines if a single surface chain is a triangle 00559 00560 CubitStatus check_through_vertices( const char *type ); 00561 //- Determines if the through vertices are on valid sides of the surface. 00562 //- Call this function after adjusting for a Curve direction. 00563 //- This function only checks - it gives an error if through vertices are 00564 //- on invalid sides. Type is either "direction" or "from", for the error 00565 //- message ("direction" if the direction exists and was checked previously, 00566 //- "from" if only a from curve was given). 00567 00568 CoEdge* prev_co_edge( CoEdge *co_edge_ptr ); 00569 //- From the outerCoEdgeLoop, get the CoEdge previous to the one given. 00570 00571 CubitStatus position_co_edge_list( int i, DLIList<CoEdge*> &co_edge_list ); 00572 //- Position the co_edge_list to the start of the loop 00573 00574 CubitStatus get_a_coedges( DLIList<CoEdge*> &co_edge_list, 00575 DLIList<CoEdge*> &a_coedges ); 00576 CubitStatus get_b_coedges( DLIList<CoEdge*> &co_edge_list, 00577 DLIList<CoEdge*> &b_coedges ); 00578 CubitStatus get_c_coedges( DLIList<CoEdge*> &co_edge_list, 00579 DLIList<CoEdge*> &c_coedges ); 00580 CubitStatus get_d_coedges( DLIList<CoEdge*> &co_edge_list, 00581 int num_so_far, DLIList<CoEdge*> &d_coedges ); 00582 //- These functions find the coedges on each side of the logical rectangle, 00583 //- using the vertex classifications 00584 00585 CubitStatus find_spline_curves( RefFace *ref_face_ptr, int num_segs, 00586 double distance, 00587 DLIList<Curve*> *curve_list_ptr, 00588 double tolerance, 00589 CubitBoolean parametric_flg = CUBIT_FALSE, 00590 CubitBoolean preview_flg = CUBIT_FALSE, 00591 CubitBoolean create_ref_edges_flg = CUBIT_FALSE ); 00592 //- Uses a mapping algorithm to calculate the interior points to pass 00593 //- spline(s) through and creates the Curve(s) for the surface. By default, 00594 //- it will do the mapping in the 3D space of the surface. It can be 00595 //- overridden to use the parametric space if a surface parametric space 00596 //- exists. If preview_flg is TRUE, then the interior spline points are 00597 //- drawn for the user to query. This setting, along with the create_ref_edges_flg 00598 //- also helps to determine whether to project the curves to the surface. 00599 //- In OCC, projecting is very slow, so we skip it when previewing; however 00600 //- we use it if the user is ultimately creating RefEdges (note the RefEdges 00601 //- will not be created within this function). 00602 00603 CubitStatus fill_boundary_coords( TDSplitSurface *tdss, int nr, int nc, 00604 CubitVector ***coords ); 00605 //- Fills the boundary array for the mapping algorithm in 3D 00606 00607 CubitStatus draw_boundary_coords( TDSplitSurface *tdss ); 00608 //- Debug function - just draws the coords for each side, if debug 100 is on 00609 00610 CubitStatus smooth_interior_coords( RefFace *ref_face_ptr, 00611 TDSplitSurface *tdss, 00612 double tolerance, 00613 int nr, int nc, double distance, 00614 CubitVector ***coords ); 00615 //- Smooths the interior coords in 3D so that the split location is correct. 00616 //- Respect distance if not -1.0. 00617 00618 CubitStatus fill_interior_coords( TDSplitSurface *tdss, int nr, int nc, 00619 CubitVector ***coords ); 00620 //- Fills the interior coordinates using a mapping algorithm in 3D 00621 00622 CubitVector *make_interior_coord( CubitVector ***coords, int nr, int nc, 00623 double ada, double tse, int j, int i ); 00624 //- Calculates an interior coordinate using the mapping algorithm in 3D 00625 00626 CubitStatus fill_boundary_coords( TDSplitSurface *tdss, int nr, int nc, 00627 Cubit2DPoint ***coords ); 00628 //- Fills the boundary array for the mapping algorithm in 2D 00629 00630 Cubit2DPoint *get_uv_point( RefFace *ref_face_ptr, CubitVector *vec_ptr ); 00631 //- Given an input 3D point gets a UV point on the given surface 00632 00633 CubitStatus fill_interior_coords( TDSplitSurface *tdss, int nr, int nc, 00634 Cubit2DPoint ***coords ); 00635 //- Fills the interior coordinates using a mapping algorithm in 2D 00636 00637 CubitStatus get_tse_array( TDSplitSurface *tdss, int tse_ints, 00638 DLIList<double> &tse_array ); 00639 //- For the mapping algorithm, finds an array of tse which are the 00640 //- average fractional distances across the AC direction of the surface 00641 00642 Cubit2DPoint *make_interior_coord( Cubit2DPoint ***coords, int nr, int nc, 00643 double ada, double tse, int j, int i ); 00644 //- Calculates an interior coordinate using the mapping algorithm in 2D 00645 00646 CubitStatus draw_points( DLIList<CubitVector*> &pnt_list, int color, 00647 int flush = CUBIT_TRUE ); 00648 CubitStatus draw_point( CubitVector &pnt, int color, int flush = CUBIT_FALSE ); 00649 //- Draw points 00650 00651 CubitStatus draw_preview( Curve *curve_ptr, CubitBoolean flush=CUBIT_TRUE, 00652 int color=CUBIT_BLUE_INDEX ); 00653 //- Draw the curves 00654 00655 CubitStatus create_ref_edges( DLIList<Curve*> &curve_list, 00656 DLIList<RefEdge*> &ref_edge_list ); 00657 //- Create RefEdges from the given Curves. Appends to the output list. 00658 00659 int number_coedges( RefEdge *ref_edge_ptr, RefFace *ref_face_ptr ); 00660 //- Finds the number of coedges for the given edge on the given surface 00661 00662 void delete_surf_tooldatas( DLIList<RefFace*> &ref_face_list ); 00663 //- Deletes tooldatas from the given ref_face_list 00664 00665 void delete_coedge_tooldatas( DLIList<CoEdge*> &co_edge_list ); 00666 //- Deletes tooldatas from the given co_edge_list 00667 00668 void delete_vertex_tooldatas( DLIList<RefVertex*> &ref_vertex_list ); 00669 //- Deletes tooldatas from the given ref_vertex_list 00670 00671 void list_sides_debug(); 00672 //- Lists the sides for debugging purposes 00673 00674 CubitBoolean check_points_straight( Surface *surf_ptr, 00675 DLIList<CubitVector*> &point_list, 00676 double tolerance ); 00677 //- Check to see if the points approximate a straight line, within 00678 //- tolerance. Also, if surface is not a plane, all points are projected 00679 //- to the resultant line and checked to make sure they lie within resabs 00680 //- (GEOMETRY_RESABS or a user specified tolerance) to the surf_ptr so 00681 //- that an imprint will be successful. If only two points are input, 00682 //- additional locations along the line are checked. 00683 00684 Curve* check_points_arc( Surface *surf_ptr, 00685 GeometryModifyEngine *gme, 00686 DLIList<CubitVector*> &point_list, 00687 double resabs, 00688 double tolerance ); 00689 //- Check to see if the input points approximate an arc. If there are 00690 //- only two input points, try to create an arc if the surface is a 00691 //- cone, sphere or torus. 00692 00693 Curve* check_if_arc( GeometryModifyEngine *gme, 00694 Surface *surf_ptr, 00695 DLIList<CubitVector*> &point_list, 00696 CubitVector &start_pnt, 00697 CubitVector &mid_pnt, 00698 CubitVector &end_pnt, 00699 double resabs, 00700 double tolerance, 00701 double &deviation ); 00702 //- Supplemental function for check_points_arc. This function can be 00703 //- called multiple times from check_points_arc as we try to iterate 00704 //- to a solution. 00705 00706 CubitStatus get_arc_mid_pnt( Surface *surf_ptr, 00707 CubitVector &start_pnt, 00708 CubitVector &end_pnt, 00709 CubitVector &mid_pnt, 00710 double tolerance ); 00711 //- Given the start and end points, and the surface, this function finds 00712 //- a third point on the arc. 00713 00714 Curve* create_arc_two( GeometryModifyEngine *gme, 00715 Surface *surf_ptr, 00716 CubitVector &start_pnt, 00717 CubitVector &end_pnt, 00718 double resabs, 00719 double tolerance ); 00720 //- Given the surface and two points, attempt to find an arc that lies 00721 //- on the surface. 00722 00723 Curve* create_arc_three( GeometryModifyEngine *gme, 00724 Surface *surf_ptr, 00725 CubitVector &start_pnt, 00726 CubitVector &mid_pnt, 00727 CubitVector &end_pnt, 00728 double resabs ); 00729 //- Given the surface and three points, attempt to find an arc that lies 00730 //- on the surface. 00731 00732 CubitStatus reflect_arc_pnt( CubitVector &vec1, 00733 CubitVector &vec2, 00734 CubitVector &vec3, 00735 CubitVector &pnt_to_reflect, 00736 CubitVector &out_pnt ); 00737 //- Given three points and another input point, create an arc and 00738 //- reflect the input point about the arc center. 00739 00740 CubitBoolean is_point_on_surface( Surface *surf_ptr, CubitVector &pnt, 00741 double resabs ); 00742 //- Determine if the input point is within the given resabs of the surface. 00743 00744 int count_surfaces_in_owning_body( RefFace *ref_face_ptr, Body *&body_ptr ); 00745 //- Returns: Number of surfaces in the owning body of the RefFace 00746 //- -1 - RefFace is free (no owning body) 00747 //- -2 - RefFace is owned by more than one body 00748 //- Also returns the owning body via argument list 00749 00750 int count_surfaces_in_body( Body *body_ptr ); 00751 //- Return number of surfaces in the body 00752 00753 int count_curves_in_body( Body *body_ptr ); 00754 //- Return number of curves in the body 00755 00756 void cleanup_for_extend_op( DLIList<RefVertex*> &ref_vertex_list, 00757 DLIList<DLIList<Surface*>*> &body_surf_list_list, 00758 DLIList<DLIList<DLIList<Curve*>*>*> &curve_lists_lists_list, 00759 CubitBoolean free_curves_flg = CUBIT_TRUE ); 00760 //- This function cleans up after the split extend operation. It removes 00761 //- the tooldatas from the vertices and frees the lists memory. If 00762 //- free_curves_flg is CUBIT_TRUE, free the Curves as well (however, the 00763 //- function checks if a RefEdge is attached to the Curve - if a RefEdge 00764 //- is attached the Curve is not freed). 00765 00766 void find_nearest_curve_for_normal_projection( 00767 RefEdge* hit_edge_ptr, CubitVector& start_loc, RefFace* face, 00768 CubitVector& ray_dir, RefEdge*& new_edge_ptr, CubitVector& new_end_loc); 00769 //- This function is used when the split extend command is used with normal = TRUE and 00770 //- the hardline does not intersect the curve found by fire_ray at a 90 degree angle. 00771 //- This function traverses the curve's neighbors to find a curve that can be split normal. 00772 00773 static CubitBoolean parametricFlg; // Split parametrically or not (3D) 00774 static double splitTolerance; // Length tolerance for tessellations, etc. 00775 static CubitBoolean autoDetectTriangles; // Detect triangles automatically? 00776 static double sideAngleThreshold; // Closest corner within this threshold 00777 // to 180 is removed (if pointAngleThreshold 00778 // criteria also met) 00779 static double pointAngleThreshold; // Corner with angle below this becomes 00780 // the triangle point (if sideAngleThreshold 00781 // criteria also met) 00782 00783 static double extendGapThreshold; // Only gaps below this value are split 00784 static CubitBoolean extendNormalFlg; // If true, extend normal to curve 00785 // instead of in curve direction if 00786 // distance is less 00787 static double extendTolerance; // If split end is equal or closer than this 00788 // to a vertex along a curve snap to the 00789 // vertex. 00790 00791 DLIList<RefFace*> refFaceChain; 00792 DLIList<RefVertex*> throughVertexList; 00793 DLIList<CoEdge*> outerCoEdgeLoop; 00794 CoEdge *cornerCoEdge[4]; // Corner at start of given CoEdge 00795 CubitBoolean isLoop; // A continuous loop of surfaces? 00796 int sideInterval[4]; 00797 }; 00798 00799 inline void 00800 SplitSurfaceTool::set_tolerance( double tol ) 00801 { splitTolerance = tol; } 00802 00803 inline double 00804 SplitSurfaceTool::get_tolerance() 00805 { return splitTolerance; } 00806 00807 inline void 00808 SplitSurfaceTool::set_auto_detect_triangles_flg( CubitBoolean flg ) 00809 { autoDetectTriangles = flg; } 00810 00811 inline CubitBoolean 00812 SplitSurfaceTool::get_auto_detect_triangles_flg() 00813 { return autoDetectTriangles; } 00814 00815 inline void 00816 SplitSurfaceTool::set_side_angle_threshold( double tol ) 00817 { sideAngleThreshold = tol; } 00818 00819 inline double 00820 SplitSurfaceTool::get_side_angle_threshold() 00821 { return sideAngleThreshold; } 00822 00823 inline void 00824 SplitSurfaceTool::set_point_angle_threshold( double tol ) 00825 { pointAngleThreshold = tol; } 00826 00827 inline double 00828 SplitSurfaceTool::get_point_angle_threshold() 00829 { return pointAngleThreshold; } 00830 00831 inline void 00832 SplitSurfaceTool::set_parametric_flg( CubitBoolean parametric_flg ) 00833 { parametricFlg = parametric_flg; } 00834 00835 inline CubitBoolean 00836 SplitSurfaceTool::get_parametric_flg() 00837 { return parametricFlg; } 00838 00839 inline void 00840 SplitSurfaceTool::set_extend_gap_threshold( double gap ) 00841 { extendGapThreshold = gap; } 00842 00843 inline double 00844 SplitSurfaceTool::get_extend_gap_threshold() 00845 { return extendGapThreshold; } 00846 00847 inline void 00848 SplitSurfaceTool::set_extend_tolerance( double tol ) 00849 { extendTolerance = tol; } 00850 00851 inline double 00852 SplitSurfaceTool::get_extend_tolerance() 00853 { return extendTolerance; } 00854 00855 inline void 00856 SplitSurfaceTool::set_extend_normal_flg( CubitBoolean extend_normal_flg ) 00857 { extendNormalFlg = extend_normal_flg; } 00858 00859 inline CubitBoolean 00860 SplitSurfaceTool::get_extend_normal_flg() 00861 { return extendNormalFlg; } 00862 00863 #endif 00864
