cgma
00001 #include "VGDefines.h" 00002 #include "SubEntitySet.hpp" 00003 #include "PartitionEntity.hpp" 00004 #include "CoEdgeSM.hpp" 00005 #include "DLIList.hpp" 00006 #include "CubitSimpleAttrib.hpp" 00007 #include "TDUniqueId.hpp" 00008 #include "CubitVector.hpp" 00009 #include "PartitionEngine.hpp" 00010 #include "GeometryEntity.hpp" 00011 #include "PartitionBody.hpp" 00012 #include "PartitionSurface.hpp" 00013 #include "CubitMessage.hpp" 00014 #include <typeinfo> 00015 00016 00017 const char* const PARTITION_DATA_ATTRIB_NAME = "PARTITION_ATTRIB"; 00018 const char* const PARTITION_GEOM_ATTRIB_NAME = "PARTITION_GEOM"; 00019 const char* const PARTITION_UID_ATTRIB_NAME = "PARTITION_UID"; 00020 00021 void SubEntitySet::strip_attributes( TopologyBridge* bridge ) 00022 { 00023 DLIList<CubitSimpleAttrib> list; 00024 00025 bridge->get_simple_attribute( PARTITION_DATA_ATTRIB_NAME, list ); 00026 while ( list.size() ) 00027 { 00028 CubitSimpleAttrib csa = list.pop(); 00029 bridge->remove_simple_attribute_virt( csa ); 00030 } 00031 00032 bridge->get_simple_attribute( PARTITION_GEOM_ATTRIB_NAME, list ); 00033 while ( list.size() ) 00034 { 00035 CubitSimpleAttrib csa = list.pop(); 00036 bridge->remove_simple_attribute_virt( csa ); 00037 } 00038 00039 bridge->get_simple_attribute( PARTITION_UID_ATTRIB_NAME, list ); 00040 while ( list.size() ) 00041 { 00042 CubitSimpleAttrib csa = list.pop(); 00043 bridge->remove_simple_attribute_virt( csa ); 00044 } 00045 } 00046 00047 00048 SubEntitySet::SubEntitySet( TopologyBridge* real_entity, 00049 PartitionEntity* first_part ) 00050 : bodyNext(0), bodyPtr(0), subEntityHead(0), lowerOrderHead(0), lastId(0), 00051 layerNumber(SUBCOMP_PARTITION_LAYER), uniqueId(0) 00052 { 00053 // if( real_entity->owner() ) 00054 // real_entity->owner()->swap_bridge( real_entity, 00055 // dynamic_cast<TopologyBridge*>(first_part) ); 00056 00057 // real_entity->owner( this ); 00058 myEntity = real_entity; 00059 assert(!!myEntity); 00060 00061 // Scan for existing partition geometry stored 00062 // in attributes on the real entity. We need 00063 // to start new Ids after any existing ones 00064 // to avoid conflicts as the stored entities 00065 // are restored. 00066 DLIList<CubitSimpleAttrib> csa_list; 00067 00068 real_entity->get_simple_attribute( PARTITION_GEOM_ATTRIB_NAME, csa_list ); 00069 while( csa_list.size() ) 00070 { 00071 CubitSimpleAttrib csa = csa_list.pop(); 00072 if( csa.character_type() == PARTITION_GEOM_ATTRIB_NAME ) 00073 { 00074 int id = csa.int_data_list()[0]; 00075 if( id > lastId ) 00076 lastId = id; 00077 } 00078 } 00079 00080 real_entity->get_simple_attribute( PARTITION_UID_ATTRIB_NAME, csa_list ); 00081 if ( csa_list.size() ) 00082 { 00083 assert(csa_list.size() == 1); 00084 CubitSimpleAttrib csa = csa_list.pop(); 00085 //real_entity->remove_simple_attribute_virt(csa); 00086 assert(csa.int_data_list().size() == 1); 00087 uniqueId = csa.int_data_list()[0]; 00088 PartitionEngine::instance().add_to_id_map( this, uniqueId ); 00089 } 00090 00091 // add first partition into the SubEntitySet's linked list 00092 add_partition( first_part, 0 ); 00093 00094 csa_list.clean_out(); 00095 real_entity->get_simple_attribute( PARTITION_DATA_ATTRIB_NAME, csa_list ); 00096 while ( csa_list.size() ) 00097 { 00098 CubitSimpleAttrib csa = csa_list.pop(); 00099 real_entity->remove_simple_attribute_virt(csa); 00100 wrap_attribute(csa, first_part->entitySetId ); 00101 real_entity->append_simple_attribute_virt(csa); 00102 } 00103 } 00104 00105 void SubEntitySet::unwrap_attributes() 00106 { 00107 DLIList<CubitSimpleAttrib> csa_list; 00108 if ( myEntity) 00109 myEntity->get_simple_attribute( PARTITION_DATA_ATTRIB_NAME, csa_list ); 00110 while( csa_list.size() ) 00111 { 00112 CubitSimpleAttrib csa = csa_list.pop(); 00113 myEntity->remove_simple_attribute_virt(csa); 00114 unwrap_attribute(csa); 00115 myEntity->append_simple_attribute_virt(csa); 00116 } 00117 } 00118 00119 00120 int SubEntitySet::get_unique_id() 00121 { 00122 if( uniqueId == 0 ) 00123 { 00124 uniqueId = TDUniqueId::generate_unique_id(); 00125 CubitSimpleAttrib attrib( PARTITION_UID_ATTRIB_NAME, 0, 0, &uniqueId ); 00126 myEntity->append_simple_attribute_virt( attrib ); 00127 PartitionEngine::instance().add_to_id_map( this, uniqueId ); 00128 } 00129 return uniqueId; 00130 } 00131 00132 SubEntitySet::~SubEntitySet() 00133 { 00134 if( uniqueId ) 00135 PartitionEngine::instance().remove_from_id_map(this,uniqueId); 00136 assert( subEntityHead == 0 && lowerOrderHead == 0 ); 00137 if( myEntity ) { 00138 strip_attributes(myEntity); 00139 if( myEntity->owner() == this ) 00140 myEntity->owner(0); 00141 } 00142 00143 if( bodyPtr ) 00144 { 00145 // keep copy because calling bodyPtr->remove 00146 // means that bodyPtr will become NULL 00147 PartitionBody* body = bodyPtr; 00148 body->remove(*this); 00149 00150 assert(body->entitySet != this); 00151 if( !body->has_children() ) 00152 { 00153 BodySM* real_body = body->real_body(); 00154 body->sub_entity_set().remove_bridge(real_body); 00155 if( body->owner() ) 00156 body->owner()->swap_bridge( body, real_body, false ); 00157 delete body; 00158 } 00159 } 00160 } 00161 00162 void SubEntitySet::add_lower_order( PartitionEntity* partition ) 00163 { 00164 assert( partition->entitySet == 0 && 00165 partition->entitySetNext == 0 ); 00166 partition->entitySet = this; 00167 partition->entitySetNext = lowerOrderHead; 00168 lowerOrderHead = partition; 00169 partition->entitySetId = ++lastId; 00170 } 00171 00172 void SubEntitySet::add_lower_order( PartitionEntity* partition, 00173 const CubitSimpleAttrib& attrib, 00174 int dimension, 00175 DLIList<CubitVector*>& points, 00176 DLIList<int>& facets, 00177 DLIList<int>& children, 00178 DLIList<int>& point_owners ) 00179 { 00180 assert( partition->entitySet == 0 && 00181 partition->entitySetNext == 0 ); 00182 00183 int id, dim; 00184 CubitStatus result = read_geometry( id, dim, points, facets, children, 00185 point_owners, attrib ); 00186 assert( result && dimension == dim ); 00187 if (CUBIT_SUCCESS != result || dimension != dim) { 00188 PRINT_ERROR("SubEntitySet::read_geometry failed or returned a mismatched dimension.\n"); 00189 return; 00190 } 00191 00192 partition->entitySet = this; 00193 partition->entitySetNext = lowerOrderHead; 00194 lowerOrderHead = partition; 00195 00196 partition->entitySetId = id; 00197 } 00198 /* 00199 void SubEntitySet::fix_duplicate_id( int id ) 00200 { 00201 for( int i = 0; i < 2; i++ ) 00202 { 00203 PartitionEntit* list = i ? subEntityHead : lowerOrderHead; 00204 for( ; list; list = list->entitySetNext ) 00205 { 00206 if( list->entitySetId == id ) 00207 list->entitySetId = ++lastId; 00208 } 00209 } 00210 } 00211 */ 00212 void SubEntitySet::add_partition( PartitionEntity* partition, 00213 PartitionEntity* after ) 00214 { 00215 assert( partition->entitySet == 0 && partition->entitySetNext == 0 ); 00216 partition->entitySet = this; 00217 00218 if( after ) 00219 { 00220 assert( after->entitySet == this ); 00221 partition->entitySetNext = after->entitySetNext; 00222 after->entitySetNext = partition; 00223 } 00224 else 00225 { 00226 partition->entitySetNext = subEntityHead; 00227 subEntityHead = partition; 00228 } 00229 partition->entitySetId = ++lastId; 00230 } 00231 00232 00233 void SubEntitySet::remove( PartitionEntity* partition ) 00234 { 00235 assert( partition->entitySet == this ); 00236 partition->entitySet = 0; 00237 00238 if( lowerOrderHead == partition ) 00239 { 00240 lowerOrderHead = partition->entitySetNext; 00241 } 00242 else if( subEntityHead == partition ) 00243 { 00244 subEntityHead = partition->entitySetNext; 00245 } 00246 else 00247 { 00248 PartitionEntity* curr = subEntityHead; 00249 while( curr && curr->entitySetNext != partition ) 00250 curr = curr->entitySetNext; 00251 if( curr == 0 ) 00252 { 00253 curr = lowerOrderHead; 00254 while( curr && curr->entitySetNext != partition ) 00255 curr = curr->entitySetNext; 00256 } 00257 00258 assert( curr && curr->entitySetNext == partition ); 00259 curr->entitySetNext = partition->entitySetNext; 00260 } 00261 00262 partition->entitySetNext = 0; 00263 00264 if( !subEntityHead && !lowerOrderHead ) 00265 { 00266 delete this; 00267 } 00268 00269 partition->entitySetId = 0; 00270 } 00271 00272 CubitStatus SubEntitySet::bridge_destroyed( TopologyBridge* bridge ) 00273 { 00274 if( myEntity && myEntity == bridge ) 00275 { 00276 if( myEntity->owner() == this ) 00277 myEntity->owner(0); 00278 myEntity = 0; 00279 return CUBIT_SUCCESS; 00280 } 00281 return CUBIT_FAILURE; 00282 } 00283 00284 CubitStatus SubEntitySet::remove_bridge( TopologyBridge* bridge ) 00285 { 00286 if (myEntity && myEntity == bridge) 00287 { 00288 strip_attributes(myEntity); 00289 return bridge_destroyed(myEntity); 00290 } 00291 return CUBIT_FAILURE; 00292 } 00293 00294 CubitStatus SubEntitySet::swap_bridge( TopologyBridge* remove, 00295 TopologyBridge* add, 00296 bool reversed ) 00297 { 00298 if( remove_bridge( remove ) ) 00299 { 00300 if( add->owner() ) 00301 { 00302 add->owner()->remove_bridge( add ); 00303 } 00304 add->owner(this); 00305 myEntity = add; 00306 if (reversed) 00307 notify_reversed(add); 00308 return CUBIT_SUCCESS; 00309 } 00310 return CUBIT_FAILURE; 00311 } 00312 00313 void SubEntitySet::get_owners( DLIList<TopologyBridge*>& owner_list ) const 00314 { 00315 for( PartitionEntity* ent = subEntityHead; ent; ent = ent->entitySetNext ) 00316 owner_list.append( dynamic_cast<TopologyBridge*>(ent) ); 00317 00318 CoEdgeSM* coedge = dynamic_cast<CoEdgeSM*>(get_entity()); 00319 if( coedge && coedge->sense() == CUBIT_REVERSED ) 00320 owner_list.reverse(); 00321 } 00322 00323 00324 bool SubEntitySet::has_multiple_sub_entities() const 00325 { return subEntityHead && subEntityHead->entitySetNext; } 00326 00327 void SubEntitySet::print_debug_info( const char* prefix ) const 00328 { 00329 if( !prefix ) prefix = ""; 00330 00331 PRINT_INFO("%sSubEntitySet for %s %p\n", prefix, 00332 myEntity ? fix_type_name(typeid(*myEntity).name()) : "TopologyBridge", 00333 (void*)myEntity ); 00334 00335 PRINT_INFO("%s SubEntities:\n", prefix ); 00336 PartitionEntity* ent = subEntityHead; 00337 00338 while( ent ) 00339 { 00340 PartitionSurface *partition_surf = dynamic_cast<PartitionSurface*>(ent); 00341 if( partition_surf ) 00342 PRINT_INFO("%p is a partition surface\n", (void*)partition_surf); 00343 00344 PRINT_INFO("%s %s %d (%p)\n", prefix, 00345 fix_type_name(typeid(*ent).name()), ent->entitySetId, (void*)ent); 00346 ent = ent->entitySetNext; 00347 } 00348 00349 PRINT_INFO("%s Lower-order entities:\n", prefix ); 00350 ent = lowerOrderHead; 00351 while( ent ) 00352 { 00353 PRINT_INFO("%s %s %d (%p)\n", prefix, 00354 fix_type_name(typeid(*ent).name()), ent->entitySetId, (void*)ent); 00355 ent = ent->entitySetNext; 00356 } 00357 00358 PRINT_INFO("%s Body: %p\n", prefix, (void*)bodyPtr); 00359 } 00360 00361 bool SubEntitySet::is_attribute( const CubitSimpleAttrib& csa, int id ) const 00362 { 00363 if( csa.string_data_list().size() < 1 ) 00364 return false; 00365 00366 if( csa.character_type() != PARTITION_DATA_ATTRIB_NAME ) 00367 return false; 00368 00369 assert( csa.int_data_list().size() ); 00370 if( id && csa.int_data_list()[0] != id ) 00371 return false; 00372 00373 return true; 00374 } 00375 00376 CubitStatus SubEntitySet::wrap_attribute( CubitSimpleAttrib& csa, int id ) const 00377 { 00378 if( is_attribute( csa ) ) 00379 return CUBIT_FAILURE; 00380 00381 csa.string_data_list().insert(csa.string_data_list().begin(), CubitString(PARTITION_DATA_ATTRIB_NAME) ); 00382 csa.int_data_list().insert(csa.int_data_list().begin(), id ); 00383 return CUBIT_SUCCESS; 00384 } 00385 00386 int SubEntitySet::unwrap_attribute( CubitSimpleAttrib& csa ) const 00387 { 00388 if( ! is_attribute( csa ) ) 00389 return 0; 00390 00391 csa.string_data_list().erase(csa.string_data_list().begin()); 00392 int id = csa.int_data_list()[0]; 00393 csa.int_data_list().erase(csa.int_data_list().begin()); 00394 00395 return id; 00396 } 00397 00398 void SubEntitySet::add_attribute( PartitionEntity* entity, const CubitSimpleAttrib& csa ) 00399 { 00400 assert( entity->entitySet == this ); 00401 00402 if( !myEntity ) 00403 return; 00404 00405 CubitSimpleAttrib copy = csa; 00406 if( wrap_attribute( copy, entity->entitySetId ) ) 00407 { 00408 myEntity->append_simple_attribute_virt( copy ); 00409 } 00410 } 00411 00412 void SubEntitySet::rem_attribute( PartitionEntity* entity, const CubitSimpleAttrib& csa ) 00413 { 00414 assert( entity->entitySet == this ); 00415 00416 if( !myEntity ) 00417 return; 00418 00419 CubitSimpleAttrib copy = csa; 00420 if( wrap_attribute( copy, entity->entitySetId ) ) 00421 { 00422 myEntity->remove_simple_attribute_virt( copy ); 00423 } 00424 } 00425 00426 void SubEntitySet::get_attributes( PartitionEntity* entity, 00427 DLIList<CubitSimpleAttrib>& list ) 00428 { 00429 assert( entity->entitySet == this ); 00430 assert( !list.size() ); 00431 list.clean_out(); 00432 00433 if( !myEntity ) 00434 return; 00435 00436 DLIList<CubitSimpleAttrib> tmp; 00437 myEntity->get_simple_attribute( PARTITION_DATA_ATTRIB_NAME, tmp ); 00438 for(int i=0; i<tmp.size(); i++) 00439 { 00440 CubitSimpleAttrib& csa = tmp[i]; 00441 if( is_attribute( csa, entity->entitySetId ) ) 00442 { 00443 unwrap_attribute( csa ); 00444 list.append(csa); 00445 } 00446 } 00447 } 00448 void SubEntitySet::get_attributes( PartitionEntity* entity, const char* name, 00449 DLIList<CubitSimpleAttrib>& list ) 00450 { 00451 list.clean_out(); 00452 00453 DLIList<CubitSimpleAttrib> tmp; 00454 get_attributes(entity,tmp); 00455 00456 for ( int i=0; i<tmp.size(); i++) 00457 { 00458 if(tmp[i].character_type() == name) 00459 { 00460 list.append(tmp[i]); 00461 } 00462 } 00463 } 00464 00465 void SubEntitySet::rem_all_attrib( PartitionEntity* entity ) 00466 { 00467 assert( entity->entitySet == this ); 00468 00469 if( !myEntity ) 00470 return; 00471 00472 DLIList<CubitSimpleAttrib> dead_list; 00473 myEntity->get_simple_attribute( PARTITION_DATA_ATTRIB_NAME, dead_list ); 00474 for( int i = dead_list.size(); i--; ) 00475 { 00476 const CubitSimpleAttrib& csa = dead_list.get_and_step(); 00477 if( is_attribute( csa, entity->entitySetId ) ) 00478 myEntity->remove_simple_attribute_virt( csa ); 00479 } 00480 } 00481 00482 int SubEntitySet::get_id( PartitionEntity* entity ) const 00483 { 00484 if( entity->entitySet != this ) 00485 return 0; 00486 return entity->entitySetId; 00487 } 00488 00489 PartitionEntity* SubEntitySet::entity_from_id( int id ) const 00490 { 00491 PartitionEntity* ent; 00492 for( ent = subEntityHead; ent; ent = ent->entitySetNext ) 00493 if( ent->entitySetId == id ) 00494 return ent; 00495 for( ent = lowerOrderHead; ent; ent = ent->entitySetNext ) 00496 if( ent->entitySetId == id ) 00497 return ent; 00498 return 0; 00499 } 00500 00501 void SubEntitySet::get_sub_entities( DLIList<PartitionEntity*>& list ) const 00502 { 00503 for( PartitionEntity* ent = subEntityHead; ent; ent = ent->entitySetNext ) 00504 list.append(ent); 00505 } 00506 00507 00508 void SubEntitySet::get_lower_order( DLIList<PartitionEntity*>& list ) const 00509 { 00510 for( PartitionEntity* ent = lowerOrderHead; ent; ent = ent->entitySetNext ) 00511 list.append(ent); 00512 } 00513 00514 void SubEntitySet::set_id( PartitionEntity* entity, int id ) 00515 { 00516 if( entity->entitySet != this ) 00517 assert(0); 00518 else 00519 { 00520 entity->entitySetId = id; 00521 if( id > lastId ) 00522 lastId = id; 00523 } 00524 } 00525 00526 void SubEntitySet::renumerate( int lowest_value, bool higher_only ) 00527 { 00528 lastId = lowest_value - 1; 00529 00530 PartitionEntity* ent; 00531 for( ent = subEntityHead; ent; ent = ent->entitySetNext ) 00532 if( !higher_only || ent->entitySetId >= lowest_value ) 00533 ent->entitySetId = ++lastId; 00534 for( ent = lowerOrderHead; ent; ent = ent->entitySetNext ) 00535 if( !higher_only || ent->entitySetId >= lowest_value ) 00536 ent->entitySetId = ++lastId; 00537 } 00538 00539 void SubEntitySet::notify_reversed( TopologyBridge* bridge ) 00540 { 00541 assert( !bridge || bridge == myEntity ); 00542 00543 // reverse list order (only really necessary for curves) 00544 PartitionEntity* entity = subEntityHead; 00545 subEntityHead = 0; 00546 while( entity ) 00547 { 00548 PartitionEntity* next = entity->entitySetNext; 00549 entity->entitySetNext = subEntityHead; 00550 subEntityHead = entity; 00551 entity = next; 00552 } 00553 00554 // reverse the sense of all subentities 00555 for( entity = subEntityHead; entity; entity = entity->entitySetNext ) 00556 entity->reverse_sense(); 00557 } 00558 00559 00560 CubitStatus SubEntitySet::save_geometry( int id, int dimension, 00561 DLIList<CubitVector*>* point_list, 00562 DLIList<int>* point_connectivity, 00563 DLIList<int>* topo_connectivity, 00564 DLIList<int>* point_owners, 00565 CubitSimpleAttrib& attrib ) 00566 { 00567 int i; 00568 00569 attrib.int_data_list().clear(); 00570 attrib.double_data_list().clear(); 00571 00572 attrib.int_data_list().push_back( id); 00573 attrib.int_data_list().push_back( dimension); 00574 int point_list_size = point_list ? point_list->size() : 0; 00575 attrib.int_data_list().push_back( point_list_size); 00576 int point_conn_size = point_connectivity ? point_connectivity->size() : 0; 00577 attrib.int_data_list().push_back( point_conn_size); 00578 int topo_conn_size = topo_connectivity ? topo_connectivity->size() : 0; 00579 attrib.int_data_list().push_back( topo_conn_size); 00580 00581 if( point_list ) 00582 { 00583 point_list->reset(); 00584 for( i = point_list->size(); i--; ) 00585 { 00586 CubitVector* p = point_list->get_and_step(); 00587 attrib.double_data_list().push_back(p->x()); 00588 attrib.double_data_list().push_back(p->y()); 00589 attrib.double_data_list().push_back(p->z()); 00590 delete p; 00591 } 00592 point_list->clean_out(); 00593 } 00594 00595 if( point_connectivity ) 00596 { 00597 point_connectivity->reset(); 00598 for( i = point_connectivity->size(); i--; ) 00599 attrib.int_data_list().push_back(point_connectivity->get_and_step()); 00600 } 00601 00602 if( topo_connectivity ) 00603 { 00604 topo_connectivity->reset(); 00605 for( i = topo_connectivity->size(); i--; ) 00606 attrib.int_data_list().push_back(topo_connectivity->get_and_step()); 00607 } 00608 00609 if ( point_owners ) 00610 { 00611 point_owners->reset(); 00612 for ( i = point_owners->size(); i--; ) 00613 attrib.int_data_list().push_back(point_owners->get_and_step()); 00614 } 00615 00616 myEntity->append_simple_attribute_virt( attrib ); 00617 00618 return CUBIT_SUCCESS; 00619 } 00620 00621 00622 CubitStatus SubEntitySet::read_geometry( int& id, int& dimension, 00623 DLIList<CubitVector*>& point_list, 00624 DLIList<int>& point_connectivity, 00625 DLIList<int>& topo_connectivity, 00626 DLIList<int>& point_owners, 00627 const CubitSimpleAttrib& attrib ) 00628 { 00629 int i; 00630 00631 // read metadata 00632 int ioffset = 0; 00633 int doffset = 0; 00634 id = attrib.int_data_list()[ioffset++]; 00635 dimension = attrib.int_data_list()[ioffset++]; 00636 int point_count = attrib.int_data_list()[ioffset++]; 00637 int conn_count = attrib.int_data_list()[ioffset++]; 00638 int topo_count = attrib.int_data_list()[ioffset++]; 00639 int owner_count = conn_count ? 2 * point_count : 0; 00640 00641 // consistancy checks 00642 if( id < 0 || dimension < 0 || dimension > 3 || 00643 point_count < 0 || conn_count < 0 || topo_count < 0 ) 00644 { 00645 PRINT_ERROR("Invalid %s attribute read. Corrupted file?\n" 00646 "\tId = %d\n\tDimension = %d\n\tPoint Count = %d\n" 00647 "\tPoint Connectivity Count = %d\n" 00648 "\tTopology Connectivity Count = %d\n", 00649 attrib.string_data_list()[0].c_str(), 00650 id, dimension, point_count, conn_count, topo_count ); 00651 return CUBIT_FAILURE; 00652 } 00653 00654 if( (size_t)(conn_count + topo_count + owner_count + 5) != attrib.int_data_list().size() || 00655 attrib.int_data_list().size() < 5 ) 00656 { 00657 PRINT_ERROR("Invalid %s attribute read. Corrupted file?\n" 00658 "\tInsufficient/Excess integer data:\n" 00659 "\tAvailable integer data: %d\n" 00660 "\tMetadata : 5\n" 00661 "\tPoint Connectivity : %d\n" 00662 "\tTopology Connectivity : %d\n" 00663 "\tFacet Point Assoc. : %d\n" 00664 "\tTotal Expected Ints : %d\n", 00665 attrib.string_data_list()[0].c_str(), 00666 (int) attrib.int_data_list().size(), 00667 conn_count, topo_count, owner_count, 00668 conn_count + topo_count + owner_count + 5 ); 00669 return CUBIT_FAILURE; 00670 } 00671 00672 if( (size_t)(point_count * 3) != attrib.double_data_list().size() ) 00673 { 00674 PRINT_ERROR("Invalid %s attribute read. Corrupted file?\n" 00675 "\tInsufficient/Excess real data: %d for %d points.\n", 00676 attrib.string_data_list()[0].c_str(), 00677 (int) attrib.double_data_list().size(), point_count ); 00678 return CUBIT_FAILURE; 00679 } 00680 00681 // read point coordinates 00682 for( i = 0; i < point_count; i++ ) 00683 { 00684 double x = attrib.double_data_list()[doffset++]; 00685 double y = attrib.double_data_list()[doffset++]; 00686 double z = attrib.double_data_list()[doffset++]; 00687 point_list.append( new CubitVector(x,y,z) ); 00688 } 00689 00690 // read point connectivity (facets) 00691 for( i = 0; i < conn_count; i++ ) 00692 point_connectivity.append( attrib.int_data_list()[ioffset++] ); 00693 00694 // read topology connectivity (children) 00695 for( i = 0; i < topo_count; i++ ) 00696 topo_connectivity.append( attrib.int_data_list()[ioffset++] ); 00697 00698 // read facet point owners 00699 for( i = 0; i < owner_count; i++ ) 00700 point_owners.append( attrib.int_data_list()[ioffset++] ); 00701 00702 return CUBIT_SUCCESS; 00703 } 00704 00705 00706 int SubEntitySet::get_geom_dimension( const CubitSimpleAttrib& attrib ) 00707 { 00708 assert(attrib.int_data_list().size() > 1); 00709 return attrib.int_data_list()[1]; 00710 } 00711 00712 int SubEntitySet::get_geom_id( const CubitSimpleAttrib& attrib ) 00713 { 00714 assert(attrib.int_data_list().size() > 1); 00715 return attrib.int_data_list()[0]; 00716 } 00717 00718 int SubEntitySet::get_segment_count( const CubitSimpleAttrib& attrib ) 00719 { 00720 assert(attrib.int_data_list().size() > 2); 00721 00722 int point_count = attrib.int_data_list()[2]; 00723 if ( point_count == 0 ) 00724 return 0; 00725 00726 assert( point_count > 1 ); 00727 return point_count - 1; 00728 } 00729 00730 CubitStatus SubEntitySet::save_geometry() 00731 { 00732 if( !lowerOrderHead ) 00733 return CUBIT_SUCCESS; 00734 00735 DLIList<CubitSimpleAttrib> old_list; 00736 myEntity->get_simple_attribute(PARTITION_GEOM_ATTRIB_NAME, old_list); 00737 while (old_list.size()) 00738 { 00739 CubitSimpleAttrib old_attrib = old_list.pop(); 00740 myEntity->remove_simple_attribute_virt(old_attrib); 00741 } 00742 00743 CubitSimpleAttrib attrib(PARTITION_GEOM_ATTRIB_NAME); 00744 00745 CubitStatus result = CUBIT_SUCCESS; 00746 for( int i = 0; i < 2; i++ ) 00747 { 00748 PartitionEntity* list_node = i ? subEntityHead : lowerOrderHead; 00749 for( ; list_node; list_node = list_node->entitySetNext ) 00750 if(dynamic_cast<GeometryEntity*>(list_node) && !list_node->save(attrib)) 00751 result = CUBIT_FAILURE; 00752 } 00753 00754 return result; 00755 } 00756 00757 00758 void SubEntitySet::strip_attributes() 00759 { 00760 strip_attributes( myEntity ); 00761 } 00762 00763
