cgma
00001 #ifndef SUB_ENTITY_SET_HPP 00002 #define SUB_ENTITY_SET_HPP 00003 00004 #include "TBOwnerSet.hpp" 00005 00006 class PartitionEntity; 00007 class TopologyBridge; 00008 class CubitSimpleAttrib; 00009 class CubitVector; 00010 class PartitionBody; 00011 00012 class SubEntitySet : public TBOwnerSet 00013 { 00014 00015 public: 00016 00017 SubEntitySet( TopologyBridge* real_entity, 00018 PartitionEntity* first_partition ); 00019 virtual ~SubEntitySet(); 00020 00021 TopologyBridge* get_entity() const 00022 { return myEntity; } 00023 00024 void add_partition( PartitionEntity* partition, 00025 PartitionEntity* insert_after = 0 ); 00026 00027 void add_lower_order( PartitionEntity* partition ); 00028 void add_lower_order( PartitionEntity* entity, 00029 const CubitSimpleAttrib& attrib, 00030 int dimension, 00031 DLIList<CubitVector*>& points_from_attrib, 00032 DLIList<int>& facets_from_attrib, 00033 DLIList<int>& children_from_attrib, 00034 DLIList<int>& facet_point_owners_from_attrib ); 00035 00036 void remove( PartitionEntity* partition ); 00037 00038 00039 bool has_lower_order() const 00040 { return lowerOrderHead != 0; } 00041 00042 bool has_multiple_sub_entities() const; 00043 00044 PartitionBody* body() const 00045 { return bodyPtr; } 00046 00047 void get_owners( DLIList<TopologyBridge*>& owner_list ) const; 00048 00049 CubitStatus remove_bridge( TopologyBridge* bridge ); 00050 CubitStatus swap_bridge( TopologyBridge* remove, 00051 TopologyBridge* add, 00052 bool reversed ); 00053 void notify_reversed( TopologyBridge* bridge ); 00054 CubitStatus bridge_destroyed( TopologyBridge* bridge ); 00055 00056 void print_debug_info( const char* prefix = 0 ) const; 00057 00058 void add_attribute( PartitionEntity* entity, const CubitSimpleAttrib& csa ); 00059 void rem_attribute( PartitionEntity* entity, const CubitSimpleAttrib& csa ); 00060 void get_attributes( PartitionEntity* entity, 00061 DLIList<CubitSimpleAttrib>& list ); 00062 void get_attributes( PartitionEntity* entity, const char* name, 00063 DLIList<CubitSimpleAttrib>& list ); 00064 void rem_all_attrib( PartitionEntity* entity ); 00065 void unwrap_attributes(); 00066 00067 void get_sub_entities( DLIList<PartitionEntity*>& result_set ) const; 00068 void get_lower_order( DLIList<PartitionEntity*>& result_set ) const; 00069 00070 int get_id( PartitionEntity* entity ) const; 00071 PartitionEntity* entity_from_id( int id ) const; 00072 00073 // The following two methods are used by PartitionEngine 00074 // when restoring geometry. Calling them at the wrong 00075 // time will result in the loss of attribute data. 00076 void set_id( PartitionEntity* entity, int id ); 00077 void renumerate( int lowest_value, bool only_higher_ids ); 00078 // renumerate sets new SubEntitySet ids on owned entities. 00079 // The lowest id of any updated entity will be the passed value. 00080 // If only_higher_ids is true, only entities with IDs equal to 00081 // or higher than the passed value are updated. 00082 00083 int get_owner_layer() const { return layerNumber; } 00084 00085 00086 CubitStatus save_geometry(); 00087 00088 int get_unique_id(); 00089 void reset_unique_id() { uniqueId = 0; } 00090 00091 CubitStatus save_geometry( int id, int dimension, 00092 DLIList<CubitVector*>* point_list, 00093 DLIList<int>* point_connectivity, 00094 DLIList<int>* topo_connectivity, 00095 DLIList<int>* point_owners, 00096 CubitSimpleAttrib& attrib ); 00097 00098 static CubitStatus read_geometry( int& id, int& dimension, 00099 DLIList<CubitVector*>& point_list, 00100 DLIList<int>& point_connectivity, 00101 DLIList<int>& topo_connectivity, 00102 DLIList<int>& point_owners, 00103 const CubitSimpleAttrib& attrib ); 00104 00105 static int get_geom_dimension( const CubitSimpleAttrib& attrib ); 00106 // return the dimension of the geometry stored in the attrib 00107 00108 static int get_geom_id( const CubitSimpleAttrib& attrib ); 00109 00110 static int get_segment_count( const CubitSimpleAttrib& attrib ); 00111 00112 static void remove_non_geom_attribs( DLIList<CubitSimpleAttrib>& list ); 00113 // given a list of all the geometry attributes on an entity, 00114 // remove and destroy any that are not partition geometry. 00115 00116 static void strip_attributes( TopologyBridge* bridge ); 00117 // remove any attributes related to partition geometry 00118 // from the passed bridge. 00119 00120 void strip_attributes(); 00121 // remove all attributes on paritioned entities, 00122 // sub entities and lower-order entities 00123 00124 inline SubEntitySet* next_in_body() const 00125 { return bodyNext; } 00126 00127 private: 00128 00129 friend class PartitionBody; 00130 SubEntitySet* bodyNext; 00131 PartitionBody* bodyPtr; 00132 00133 // don't allow assignment (make assignment private) 00134 SubEntitySet& operator=( const SubEntitySet& ) { return *this;} 00135 bool operator==( const SubEntitySet& c ) const { return &c == this; } 00136 00137 CubitStatus wrap_attribute( CubitSimpleAttrib& csa, int id ) const; 00138 int unwrap_attribute( CubitSimpleAttrib& csa ) const; 00139 bool is_attribute( const CubitSimpleAttrib& csa, int id = 0 ) const; 00140 00141 TopologyBridge* myEntity; 00142 00143 PartitionEntity* subEntityHead; 00144 PartitionEntity* lowerOrderHead; 00145 00146 int lastId; 00147 00148 int layerNumber; 00149 00150 int uniqueId; 00151 }; 00152 00153 #endif
