cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : TopologyEntity.cpp 00003 // 00004 // Purpose : Implementation of the TopologyEntity class. 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Xuechen Liu 00009 // 00010 // Creation Date : 07/31/96 00011 // 00012 // Owner : Malcolm J. Panthaki 00013 //------------------------------------------------------------------------- 00014 00015 // ********** BEGIN STANDARD INCLUDES ********** 00016 #include <assert.h> 00017 // ********** END STANDARD INCLUDES ********** 00018 00019 // ********** BEGIN CUBIT INCLUDES ********** 00020 #include "CubitDefines.h" 00021 #include "CubitMessage.hpp" 00022 00023 #include "CastTo.hpp" 00024 #include "TopologyEntity.hpp" 00025 #include "TopologyBridge.hpp" 00026 00027 #include "ModelQueryEngine.hpp" 00028 #include "GeometryQueryTool.hpp" 00029 00030 #include "Body.hpp" 00031 #include "DLIList.hpp" 00032 #include "Shell.hpp" 00033 #include "Loop.hpp" 00034 #include "Chain.hpp" 00035 #include "RefVolume.hpp" 00036 #include "RefFace.hpp" 00037 #include "RefEdge.hpp" 00038 #include "RefVertex.hpp" 00039 #include "CoVolume.hpp" 00040 #include "CoFace.hpp" 00041 #include "CoEdge.hpp" 00042 #include "CoVertex.hpp" 00043 #include "AppUtil.hpp" 00044 #include "CubitEvent.hpp" 00045 00046 // ********** END CUBIT INCLUDES ********** 00047 00048 // ********** BEGIN STATIC DECLARATIONS ********** 00049 // ********** END STATIC DECLARATIONS ********** 00050 00051 // ********** BEGIN PUBLIC FUNCTIONS ********** 00052 00053 //------------------------------------------------------------------------- 00054 // Purpose : Casting query functions 00055 // 00056 // Special Notes : 00057 // 00058 // Creator : Jason Kraftcheck 00059 // 00060 // Creation Date : 07/29/03 00061 //------------------------------------------------------------------------- 00062 #define DECLARE_TOPO_ENT_QUERY_FUNC( TYPE, NAME, QUERYTYPE ) \ 00063 CubitStatus TopologyEntity::NAME(DLIList<TYPE*>& list) \ 00064 { \ 00065 DLIList<TopologyEntity*> temp_list ; \ 00066 CubitStatus result; \ 00067 ModelQueryEngine *const mqe = ModelQueryEngine::instance(); \ 00068 \ 00069 result = mqe->query_model( *this, DagType::QUERYTYPE(), temp_list ); \ 00070 if (result == CUBIT_FAILURE) \ 00071 { \ 00072 PRINT_ERROR("In TopologyEntity::" #NAME "\n"); \ 00073 PRINT_ERROR(" Query failed for unknown reason.\n"); \ 00074 return CUBIT_FAILURE; \ 00075 } \ 00076 \ 00077 temp_list.reset(); \ 00078 for (int i = temp_list.size(); i--; ) \ 00079 { \ 00080 TYPE* ptr = static_cast<TYPE*>(temp_list.get_and_step()); \ 00081 assert(!!ptr); \ 00082 list.append(ptr); \ 00083 } \ 00084 \ 00085 return CUBIT_SUCCESS; \ 00086 } 00087 00088 00089 00090 //------------------------------------------------------------------------- 00091 // Purpose : Default constructor. 00092 // 00093 // Special Notes : 00094 // 00095 // Creator : Xuechen Liu 00096 // 00097 // Creation Date : 07/31/96 00098 //------------------------------------------------------------------------- 00099 00100 TopologyEntity::TopologyEntity() 00101 : deactivatedStatus_(CUBIT_FALSE), 00102 encountered_(CUBIT_FALSE), 00103 bridgeMan() 00104 { 00105 bridgeMan.set_entity(this); 00106 } 00107 00108 //------------------------------------------------------------------------- 00109 // Purpose : Destructor. 00110 // 00111 // Special Notes : 00112 // 00113 // Creator : Raikanta Sahu 00114 // 00115 // Creation Date : 09/10/96 00116 //------------------------------------------------------------------------- 00117 00118 TopologyEntity::~TopologyEntity() 00119 { 00120 // Make sure that the TopologyEntity class does not have a pointer to this 00121 // TopologyEntity in its list. If it does, then remove the instances 00122 // of the pointer 00123 DAG::instance()->remove(this); 00124 } 00125 00126 00127 GeometryQueryEngine* 00128 TopologyEntity::get_geometry_query_engine() const 00129 { 00130 TopologyBridge* bridge = 00131 const_cast<TopologyEntity*>(this)->bridgeMan.topology_bridge(); 00132 if (bridge) 00133 return bridge->get_geometry_query_engine(); 00134 else 00135 return NULL; 00136 } 00137 00138 00139 DECLARE_TOPO_ENT_QUERY_FUNC( Body, bodies, body_type ) 00140 DECLARE_TOPO_ENT_QUERY_FUNC( CoVolume, co_volumes, co_volume_type ) 00141 DECLARE_TOPO_ENT_QUERY_FUNC( RefVolume, ref_volumes, ref_volume_type ) 00142 DECLARE_TOPO_ENT_QUERY_FUNC( Shell, shells, shell_type ) 00143 DECLARE_TOPO_ENT_QUERY_FUNC( CoFace, co_faces, co_face_type ) 00144 DECLARE_TOPO_ENT_QUERY_FUNC( RefFace, ref_faces, ref_face_type ) 00145 DECLARE_TOPO_ENT_QUERY_FUNC( Loop, loops, loop_type ) 00146 DECLARE_TOPO_ENT_QUERY_FUNC( CoEdge, co_edges, co_edge_type ) 00147 DECLARE_TOPO_ENT_QUERY_FUNC( RefEdge, ref_edges, ref_edge_type ) 00148 DECLARE_TOPO_ENT_QUERY_FUNC( Chain, chains, chain_type ) 00149 DECLARE_TOPO_ENT_QUERY_FUNC( CoVertex, co_vertices, co_vertex_type ) 00150 DECLARE_TOPO_ENT_QUERY_FUNC( RefVertex, ref_vertices, ref_vertex_type ) 00151 00152 00153 RefVertex *TopologyEntity::ref_vertex() 00154 { 00155 DLIList<RefVertex*> verts; 00156 ref_vertices(verts); 00157 if (verts.size() > 0) return verts.get(); 00158 else return NULL; 00159 } 00160 00161 RefEdge *TopologyEntity::ref_edge() 00162 { 00163 DLIList<RefEdge*> edges; 00164 ref_edges(edges); 00165 if (edges.size() > 0) return edges.get(); 00166 else return NULL; 00167 } 00168 00169 RefFace *TopologyEntity::ref_face() 00170 { 00171 DLIList<RefFace*> faces; 00172 ref_faces(faces); 00173 if (faces.size() > 0) return faces.get(); 00174 else return NULL; 00175 } 00176 00177 RefVolume *TopologyEntity::ref_volume() 00178 { 00179 DLIList<RefVolume*> volumes; 00180 ref_volumes(volumes); 00181 if (volumes.size() > 0) return volumes.get(); 00182 else return NULL; 00183 } 00184 00185 Body *TopologyEntity::body() 00186 { 00187 DLIList<Body*> these_bodies; 00188 this->bodies(these_bodies); 00189 if (these_bodies.size() > 0) return these_bodies.get(); 00190 else return NULL; 00191 } 00192 00193 00194 CoEdge *TopologyEntity::co_edge() 00195 { 00196 DLIList<CoEdge*> these_co_edges; 00197 co_edges(these_co_edges); 00198 if (these_co_edges.size() > 0) return these_co_edges.get(); 00199 else return NULL; 00200 } 00201 00202 int TopologyEntity::num_loops() 00203 { 00204 DLIList<Loop*> these_loops; 00205 loops(these_loops); 00206 return these_loops.size(); 00207 } 00208 00209 00210 int TopologyEntity::num_ref_volumes() 00211 { 00212 DLIList<RefVolume*> these_ref_volumes; 00213 ref_volumes(these_ref_volumes); 00214 return these_ref_volumes.size(); 00215 } 00216 00217 int TopologyEntity::num_ref_faces() 00218 { 00219 DLIList<RefFace*> these_ref_faces; 00220 ref_faces(these_ref_faces); 00221 return these_ref_faces.size(); 00222 } 00223 00224 int TopologyEntity::num_ref_edges() 00225 { 00226 DLIList<RefEdge*> these_ref_edges; 00227 ref_edges(these_ref_edges); 00228 return these_ref_edges.size(); 00229 } 00230 00231 int TopologyEntity::num_ref_vertices() 00232 { 00233 DLIList<RefVertex*> these_ref_vertices; 00234 ref_vertices(these_ref_vertices); 00235 return these_ref_vertices.size(); 00236 } 00237 00238 00239 //- return the number of connected entities of the given type 00240 00241 CubitBoolean TopologyEntity::is_directly_related( TopologyEntity* entity ) 00242 { 00243 // NULL? 00244 if ( !entity ) 00245 return CUBIT_FALSE; 00246 00247 // self? 00248 if (entity == this) 00249 return CUBIT_TRUE; 00250 00251 // same type but not self? 00252 if ( dag_type() == entity->dag_type() ) 00253 return CUBIT_FALSE; 00254 00255 // Get the entities of the right type. 00256 DLIList<TopologyEntity*> kin_folk; 00257 CubitStatus result = ModelQueryEngine::instance()-> 00258 query_model( *this, entity->dag_type(), kin_folk ); 00259 //only fails if types are the same, caught above. 00260 assert(result != CUBIT_FAILURE); 00261 if (CUBIT_FAILURE == result) { 00262 PRINT_ERROR("ModelQueryEngine::query_model failed.\n"); 00263 return CUBIT_FALSE; 00264 } 00265 00266 // Search entities for passed in entity. 00267 TopologyEntity* model_entity = CAST_TO(entity, TopologyEntity) ; 00268 return kin_folk.is_in_list( model_entity ); 00269 } 00270 00271 CubitStatus TopologyEntity::set_topology_bridge(TopologyBridge* TB_ptr) 00272 { 00273 assert (TB_ptr != NULL); 00274 CubitStatus rv = CUBIT_SUCCESS; 00275 00276 BridgeManager* bridges = bridge_manager(); 00277 bridges->remove_all_bridges(); 00278 bridges->add_bridge(TB_ptr); 00279 00280 return rv; 00281 } 00282 00283 CubitStatus TopologyEntity::remove_from_DAG(CubitBoolean recurse_flag) 00284 { 00285 // This counter will be used in the recursion to test whether 00286 // the call is from outside or from the function itself. When 00287 // the call comes from outside, the counter should always be 00288 // zero. 00289 00290 CubitBoolean this_recurse = recurse_flag; 00291 if (recurse_flag == CUBIT_FALSE) recurse_flag = CUBIT_TRUE; 00292 00293 DLIList<TopologyEntity*> childModEntList; 00294 00295 // Check to see if there are no parents of this object. 00296 if ( get_parents() == 0 ) 00297 { 00298 if (this_recurse == CUBIT_FALSE) 00299 { 00300 // Since we are not recursing, this is a top-level entity. 00301 // Notify the static observers that a top-level entity is being 00302 // destructed. This must be done before children are disconnected. 00303 CubitObservable *top_level = CAST_TO(this, CubitObservable); 00304 AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOP_LEVEL_ENTITY_DESTRUCTED, dynamic_cast<RefEntity*>(top_level))); 00305 } 00306 00307 // Go through all the children and remove their link to 00308 // the current object. 00309 00310 TopologyEntity* tempModEntPtr = NULL ; 00311 TopologyEntity* childModEntPtr = NULL ; 00312 00313 childModEntList.clean_out(); 00314 disconnect_all_children(&childModEntList); 00315 00316 // The following while conditional may not work...it depends on 00317 // what is_at_end does when you step over the end...CHECK THIS 00318 int i; 00319 for( i = 0 ; i < childModEntList.size() ; i++ ) 00320 { 00321 // Get the next ModelEnti in the child list and make sure its 00322 // pointer to its parent is removed. 00323 tempModEntPtr = childModEntList.get_and_step(); 00324 00325 // Try remove() on the child ModEnt. If it comes back with 00326 // a success, then delete it. 00327 childModEntPtr = tempModEntPtr; 00328 00329 if ( childModEntPtr->remove_from_DAG(recurse_flag) == CUBIT_SUCCESS ) 00330 { 00331 // Now deactivate the child ModEnt 00332 childModEntPtr->deactivated(CUBIT_TRUE) ; 00333 00334 // remove it from observables, just before we go to delete it 00335 CubitObservable *observable = CAST_TO(childModEntPtr, CubitObservable); 00336 if (observable) 00337 { 00338 AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_ENTITY_DESTRUCTED, dynamic_cast<RefEntity*>(observable))); 00339 } 00340 } 00341 } 00342 00343 00344 // If this is the top of the recursion, then clean out all the deactivated 00345 // entities. 00346 if (this_recurse == CUBIT_FALSE) 00347 { 00348 this->deactivated(CUBIT_TRUE) ; 00349 00350 // remove it from observables, just before we go to delete it 00351 CubitObservable *observable = CAST_TO(childModEntPtr, CubitObservable); 00352 if (observable) 00353 { 00354 AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_ENTITY_DESTRUCTED, dynamic_cast<RefEntity*>(observable))); 00355 } 00356 GeometryQueryTool::instance()->cleanout_deactivated_geometry() ; 00357 } 00358 00359 return CUBIT_SUCCESS ; 00360 } 00361 else 00362 { 00363 return CUBIT_FAILURE ; 00364 } 00365 } 00366 00367 void TopologyEntity::disconnect_from_DAG() 00368 { 00369 // disconnects this entity from any others 00370 // to which it is connected in the DAG; does not delete the DAGNode 00371 00372 disconnect_all_children(); 00373 disconnect_all_parents(); 00374 } 00375 00376 //------------------------------------------------------------------------- 00377 // Purpose : Get and set functions for the deactivated flag. 00378 // 00379 // Special Notes : 00380 // 00381 // Creator : Raikanta Sahu 00382 // 00383 // Creation Date : 12/02/96 00384 //------------------------------------------------------------------------- 00385 00386 void TopologyEntity::deactivated(CubitBoolean flag) 00387 { 00388 if (deactivatedStatus_ != flag) 00389 { 00390 deactivatedStatus_ = flag ; 00391 if (flag == CUBIT_TRUE) 00392 { 00393 DAG::instance()->add_deactivated_DAG_node(this) ; 00394 } 00395 else 00396 { 00397 DAG::instance()->remove_deactivated_DAG_node(this) ; 00398 } 00399 } 00400 } 00401 00402 CubitBoolean TopologyEntity::deactivated() const 00403 { 00404 return (CubitBoolean)deactivatedStatus_ ; 00405 } 00406 00407 00408 00409 00410 // ********** END PUBLIC FUNCTIONS ********** 00411 00412 // ********** BEGIN PROTECTED FUNCTIONS ********** 00413 // ********** END PROTECTED FUNCTIONS ********** 00414 00415 // ********** BEGIN PRIVATE FUNCTIONS ********** 00416 // ********** END PRIVATE FUNCTIONS ********** 00417 00418 // ********** BEGIN HELPER CLASSES ********** 00419 // ********** END HELPER CLASSES ********** 00420 00421 // ********** BEGIN EXTERN FUNCTIONS ********** 00422 // ********** END EXTERN FUNCTIONS ********** 00423 00424 // ********** BEGIN STATIC FUNCTIONS ********** 00425 // ********** END STATIC FUNCTIONS ********** 00426
