cgma
00001 #include "MergeTool.hpp" 00002 #include "InitCGMA.hpp" 00003 #include "GeometryModifyTool.hpp" 00004 #include "GeometryQueryTool.hpp" 00005 #include "Body.hpp" 00006 #include "CGMApp.hpp" 00007 #include "CubitAttribManager.hpp" 00008 #include "CubitCompat.hpp" 00009 00010 #include <stdio.h> 00011 #include <stdlib.h> 00012 #include <iostream> 00013 #include <vector> 00014 00015 #ifndef ENGINE 00016 # define ENGINE 0 00017 #endif 00018 00019 #define gti GeometryQueryTool::instance() 00020 #define gmti GeometryModifyTool::instance() 00021 00022 #define ASSERT(A) if (!(A)) failed(#A,__FILE__,__LINE__) 00023 void failed( const char* A, const char* FILE, int LINE ) 00024 { 00025 printf( "Condition failed at %s:%d : %s\n", FILE, LINE, A ); 00026 abort(); 00027 } 00028 00029 00030 static void print_usage( const char* name, std::ostream& stream ) 00031 { 00032 std::cout << "Usage: " << name << " <input geometry file name> #x-parts #y-parts #z-parts <output geometry file name>" << std::endl; 00033 } 00034 00035 00036 std::string type_from_file_name( const std::string& filename ) 00037 { 00038 size_t dot_pos = filename.find_last_of( '.' ); 00039 if (dot_pos == std::string::npos) 00040 return std::string(); 00041 00042 std::string extension = filename.substr( dot_pos + 1 ); 00043 std::transform( extension.begin(), extension.end(), extension.begin(), ::tolower ); 00044 if (extension == "occ" || extension == "brep") 00045 return "OCC"; 00046 else if (extension == "step" || extension == "stp") 00047 return "STEP"; 00048 else if (extension == "iges" || extension == "igs") 00049 return "IGES"; 00050 else if (extension == "sat") 00051 return "ACIS_SAT"; 00052 else 00053 return std::string(); 00054 } 00055 00056 00057 int main(int argc, char* argv[]) 00058 { 00059 if (argc !=6){ 00060 print_usage(argv[0], std::cerr); 00061 exit(0); 00062 } 00063 // parse command line options for partitioning geometry for parallel mesh generation 00064 CubitStatus rsl = CUBIT_SUCCESS; 00065 00066 rsl = InitCGMA::initialize_cgma( ENGINE ); 00067 ASSERT(rsl); 00068 00069 CGMApp::instance()->attrib_manager()->auto_flag( CUBIT_TRUE ); 00070 00071 std::string type = type_from_file_name( argv[1] ); 00072 if (type.empty()) // just guess OCC 00073 type = "OCC"; 00074 rsl = CubitCompat_import_solid_model(argv[1], type.c_str()); 00075 if (rsl != CUBIT_SUCCESS) { 00076 PRINT_ERROR("Problems reading geometry file %s.\n", argv[1]); 00077 abort(); 00078 } 00079 00080 int npartsx = atoi(argv[2]), npartsy = atoi(argv[3]), npartsz = atoi(argv[4]); 00081 00082 // Get the bounding box for this geometry 00083 DLIList<Body*> old_bodies, new_bodies, junk; 00084 gti->bodies(old_bodies); 00085 old_bodies.reset(); 00086 00087 std::vector<CubitBox> box; 00088 box.resize(old_bodies.size()); 00089 CubitBox box1; 00090 00091 for(int i=0; i< old_bodies.size (); i++){ 00092 box[i] =old_bodies[i]->bounding_box(); 00093 if (i>0) 00094 box1 = box[i-1].operator |= (box[i]); 00095 else 00096 box1 = box[i]; 00097 } 00098 00099 double bxmax =box1.max_x (); 00100 double bymax =box1.max_y (); 00101 double bzmax =box1.max_z (); 00102 00103 double bxmin =box1.min_x (); 00104 double bymin =box1.min_y (); 00105 double bzmin =box1.min_z (); 00106 std::cout << "Bounding box of the geometry file:" << std::endl; 00107 std::cout << bxmin << " < X < " << bxmax << std::endl; 00108 std::cout << bymin << " < X < " << bymax << std::endl; 00109 std::cout << bzmin << " < X < " << bzmax << std::endl; 00110 double dx = box1.x_range (); 00111 double dy = box1.y_range (); 00112 double dz = box1.z_range (); 00113 00114 for (int i=0; i< npartsx-1; i++){ 00115 double xcenter = bxmin + (i+1)*dx/npartsx; 00116 00117 CubitVector center(xcenter,0.0, 0.0); 00118 CubitVector axes[2]; 00119 axes[0].set(0.,0.,1.); 00120 axes[1].set(0.,1.,0.); 00121 00122 new_bodies.clean_out (); 00123 rsl = gmti->webcut_with_planar_sheet(old_bodies,center,axes,2*dy,2*dz,new_bodies,junk); 00124 if (rsl== CUBIT_FAILURE) 00125 return rsl; 00126 old_bodies.clean_out (); 00127 old_bodies.copy_from (&new_bodies[0],new_bodies.size ()); 00128 } 00129 00130 old_bodies.clean_out (); 00131 gti->bodies(old_bodies); 00132 old_bodies.reset(); 00133 for (int j=0; j< npartsy-1; j++){ 00134 00135 double ycenter = bymin + (j+1)*dy/npartsy; 00136 00137 CubitVector center(0.0,ycenter, 0.0); 00138 CubitVector axes[2]; 00139 axes[0].set(0.,0.,1.); 00140 axes[1].set(1.,0.,0.); 00141 00142 new_bodies.clean_out (); 00143 rsl = gmti->webcut_with_planar_sheet(old_bodies,center,axes,2*dz,2*dx,new_bodies,junk); 00144 if (rsl== CUBIT_FAILURE) 00145 return rsl; 00146 old_bodies.clean_out (); 00147 old_bodies.copy_from (&new_bodies[0],new_bodies.size ()); 00148 } 00149 00150 old_bodies.clean_out (); 00151 gti->bodies(old_bodies); 00152 old_bodies.reset(); 00153 for (int k=0; k< npartsz-1; k++){ 00154 00155 double zcenter = bzmin + (k+1)*dz/npartsz; 00156 00157 CubitVector center(0.0,0.0, zcenter); 00158 CubitVector axes[2]; 00159 axes[0].set(0.,1.,0.); 00160 axes[1].set(1.,0.,0.); 00161 00162 new_bodies.clean_out (); 00163 rsl = gmti->webcut_with_planar_sheet(old_bodies,center,axes,2*dx,2*dy,new_bodies,junk); 00164 if (rsl== CUBIT_FAILURE) 00165 return rsl; 00166 old_bodies.clean_out (); 00167 old_bodies.copy_from (&new_bodies[0],new_bodies.size ()); 00168 } 00169 00170 // merge entities 00171 rsl = MergeTool::instance()->merge_bodies( new_bodies ); 00172 ASSERT(rsl); 00173 00174 int num_ents_exported=0; 00175 DLIList<RefEntity*> ref_entities; 00176 const CubitString cubit_version="10.2"; 00177 const char * filename = argv[5]; 00178 00179 ref_entities.clean_out(); 00180 rsl = CubitCompat_export_solid_model(ref_entities, filename, type.c_str(), 00181 num_ents_exported, cubit_version); 00182 if (rsl== CUBIT_FAILURE) 00183 return rsl; 00184 00185 return 0; 00186 } 00187 00188
