cgma
00001 00010 #undef NDEBUG 00011 #include <cassert> 00012 00013 #include "GeometryModifyEngine.hpp" 00014 #include "GeometryModifyTool.hpp" 00015 #include "GeometryQueryTool.hpp" 00016 #include "CubitMessage.hpp" 00017 #include "Body.hpp" 00018 #include "RefVolume.hpp" 00019 #include "RefFace.hpp" 00020 #include "RefEdge.hpp" 00021 #include "RefVertex.hpp" 00022 #include "InitCGMA.hpp" 00023 #include "OCCBody.hpp" 00024 #include "OCCSurface.hpp" 00025 #include "OCCCurve.hpp" 00026 #include "OCCDrawTool.hpp" 00027 #include "CubitCompat.hpp" 00028 00029 #ifndef SRCDIR 00030 # define SRCDIR . 00031 #endif 00032 00033 #define STRINGIFY_(X) #X 00034 #define STRINGIFY(X) STRINGIFY_(X) 00035 #define SRCPATH STRINGIFY(SRCDIR) "/" 00036 00037 // forward declare some functions used and defined later 00038 CubitStatus read_geometry(int, const char **, bool local = false); 00039 CubitStatus make_Point(); 00040 // macro for printing a separator line 00041 #define PRINT_SEPARATOR PRINT_INFO("=======================================\n"); 00042 00043 00044 // main program - initialize, then send to proper function 00045 int main (int argc, char **argv) 00046 { 00047 CubitStatus status = InitCGMA::initialize_cgma("OCC"); 00048 if (CUBIT_SUCCESS != status) return 1; 00049 00050 //Do make point. 00051 status = make_Point(); 00052 if (status == CUBIT_FAILURE) 00053 PRINT_INFO("Operation Failed"); 00054 00055 int ret_val = ( CubitMessage::instance()->error_count() ); 00056 if ( ret_val > 2 ) 00057 { 00058 PRINT_ERROR("Errors found during Mergechk session.\n"); 00059 } 00060 return ret_val-2; 00061 00062 } 00063 00068 CubitStatus read_geometry(int num_files, const char **argv, bool local) 00069 { 00070 CubitStatus status = CUBIT_SUCCESS; 00071 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00072 assert(gti); 00073 int i; 00074 00075 PRINT_SEPARATOR; 00076 00077 for (i = 0; i < num_files; i++) { 00078 std::string filename( local ? "./" : SRCPATH ); 00079 filename += argv[i]; 00080 status = CubitCompat_import_solid_model(filename.c_str(), "OCC"); 00081 if (status != CUBIT_SUCCESS) { 00082 PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str()); 00083 } 00084 } 00085 PRINT_SEPARATOR; 00086 00087 return CUBIT_SUCCESS; 00088 } 00089 00090 CubitStatus make_Point() 00091 { 00092 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00093 GeometryModifyTool *gmti = GeometryModifyTool::instance(); 00094 00095 //test for creating prisms 00096 Body* prism1 = gmti->prism(10, 7, 5, 2); 00097 Body* prism2 = gmti->prism(10, 7, 5, 5); 00098 Body* prism3 = gmti->prism(10, 8, 5, 2); 00099 Body* prism4 = gmti->prism(10, 8, 5, 5); 00100 CubitStatus rsl = CUBIT_SUCCESS; 00101 DLIList<RefEntity*> ref_entity_list; 00102 int num_ents_exported=0; 00103 const CubitString cubit_version="10.2"; 00104 const char * filename = "prism.occ"; 00105 const char * filetype = "OCC"; 00106 00107 rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00108 num_ents_exported, cubit_version); 00109 00110 remove(filename); 00111 00112 CubitBox box1 = prism1->bounding_box(); 00113 CubitVector min(-5.0, -1.949, -5.0); 00114 CubitVector max(4.504, 1.949, 5.0); 00115 CubitBox test_box(min, max); 00116 assert(box1 >= test_box); 00117 test_box *= 1.02; 00118 assert( box1 <= test_box ); 00119 00120 box1 = prism2->bounding_box(); 00121 min.set(-5.0, -4.874, -5.0); 00122 max.set(4.504, 4.874, 5.0); 00123 test_box.reset(min, max); 00124 assert(box1 >= test_box); 00125 test_box *= 1.02; 00126 assert( box1 <= test_box ); 00127 00128 box1 = prism3->bounding_box(); 00129 min.set(-4.619, -1.847, -5.0); 00130 max.set(4.619, 1.847, 5.0); 00131 test_box.reset(min, max); 00132 assert(box1 >= test_box); 00133 test_box *= 1.02; 00134 assert( box1 <= test_box ); 00135 00136 box1 = prism4->bounding_box(); 00137 min.set(-4.619, -4.619, -5.0); 00138 max.set(4.619, 4.619, 5.0); 00139 test_box.reset(min, max); 00140 assert(box1 >= test_box); 00141 test_box *= 1.02; 00142 assert( box1 <= test_box ); 00143 00144 DLIList<Body*> bodies; 00145 gti->bodies(bodies); 00146 gti->delete_Body(bodies); 00147 00148 //test for creating pyramids 00149 Body* pyramid1 = gmti->pyramid(10, 7, 5, 2, 2); 00150 Body* pyramid2 = gmti->pyramid(10, 7, 5, 5, 2); 00151 Body* pyramid3 = gmti->pyramid(10, 8, 5, 2, 2); 00152 Body* pyramid4 = gmti->pyramid(10, 8, 5, 5, 2); 00153 Body* pyramid5 = gmti->pyramid(10, 4, 5, 2, 0); 00154 Body* pyramid6 = gmti->pyramid(10, 4, 5, 5, 0); 00155 ref_entity_list.clean_out(); 00156 num_ents_exported=0; 00157 filename = "pyramid.occ"; 00158 00159 rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00160 num_ents_exported, cubit_version); 00161 00162 remove(filename); 00163 box1 = pyramid1->bounding_box(); 00164 min.set(-5.0, -1.949, -5.0); 00165 max.set(4.504, 1.949, 5.0); 00166 test_box.reset(min, max); 00167 assert(box1 >= test_box); 00168 test_box *= 1.02; 00169 assert( box1 <= test_box ); 00170 00171 box1 = pyramid2->bounding_box(); 00172 min.set(-5.0, -4.874, -5.0); 00173 max.set(4.504, 4.874, 5.0); 00174 test_box.reset(min, max); 00175 assert(box1 >= test_box); 00176 test_box *= 1.02; 00177 assert( box1 <= test_box ); 00178 00179 box1 = pyramid3->bounding_box(); 00180 min.set(-4.619, -1.847, -5.0); 00181 max.set(4.619, 1.847, 5.0); 00182 test_box.reset(min, max); 00183 assert(box1 >= test_box); 00184 test_box *= 1.02; 00185 assert( box1 <= test_box ); 00186 00187 box1 = pyramid4->bounding_box(); 00188 min.set(-4.619, -4.619, -5.0); 00189 max.set(4.619, 4.619, 5.0); 00190 test_box.reset(min, max); 00191 assert(box1 >= test_box); 00192 test_box *= 1.02; 00193 assert( box1 <= test_box ); 00194 00195 box1 = pyramid5->bounding_box(); 00196 min.set(-3.535, -1.414, -5.0); 00197 max.set(3.535, 1.414, 5.0); 00198 test_box.reset(min, max); 00199 assert(box1 >= test_box); 00200 test_box *= 1.02; 00201 assert( box1 <= test_box ); 00202 00203 box1 = pyramid6->bounding_box(); 00204 min.set(-3.535, -3.535, -5.0); 00205 max.set(3.535, 3.535, 5.0); 00206 test_box.reset(min, max); 00207 assert(box1 >= test_box); 00208 test_box *= 1.02; 00209 assert( box1 <= test_box ); 00210 00211 bodies.clean_out(); 00212 gti->bodies(bodies); 00213 gti->delete_Body(bodies); 00214 00215 //Create sphere 00216 RefEntity* sphereEnt= GeometryModifyTool::instance()->sphere(1.5); 00217 sphereEnt->entity_name("sphere"); 00218 00219 box1 = sphereEnt->bounding_box(); 00220 min.set(-1.5,-1.5,-1.5); 00221 max.set(1.5,1.5,1.5); 00222 test_box.reset(min, max); 00223 assert(box1 >= test_box); 00224 test_box *= 1.02; 00225 assert( box1 <= test_box ); 00226 00227 //TopoDS_Compound* objOCC; 00228 Body* tmpBd = GeometryQueryTool::instance()->get_first_body(); 00229 DLIList<RefVertex*> vertices; 00230 tmpBd->ref_vertices(vertices); 00231 DLIList<RefEdge*> ref_edges; 00232 tmpBd->ref_edges(ref_edges); 00233 DLIList<RefFace*> sphere_faces; 00234 tmpBd->ref_faces(sphere_faces); 00235 for(int i = 0; i < ref_edges.size(); i++) 00236 { 00237 vertices.clean_out(); 00238 ref_edges.get()->ref_vertices(vertices); 00239 ref_edges.get_and_step()->measure(); 00240 } 00241 //BodySM* tmpBdSM = tmpBd->get_body_sm_ptr(); 00242 //objOCC = ( (OCCBody*) tmpBdSM )->get_TopoDS_Shape(); //Opencascade Object 00243 //OCCDrawTool::instance()->draw_TopoDS_Shape(objOCC, 200); 00244 00245 bodies.clean_out(); 00246 gti->bodies(bodies); 00247 DLIList<RefEntity*> free_entities; 00248 gti->get_free_ref_entities(free_entities); 00249 gti->delete_Body(bodies); 00250 00251 for (int j = free_entities.size(); j--;) 00252 { 00253 gti->delete_RefEntity( free_entities.get_and_step()); 00254 } 00255 // Read in the geometry from files specified on the command line 00256 const char *argv = "66_shaver3.brep"; 00257 CubitStatus status = read_geometry(1, &argv); 00258 if (status == CUBIT_FAILURE) exit(1); 00259 00260 const char *argv2 = "62_shaver1.brep"; 00261 status = read_geometry(1, &argv2); 00262 if (status == CUBIT_FAILURE) exit(1); 00263 00264 const char *argv3 = "72_shaver6.brep"; 00265 status = read_geometry(1, &argv3); 00266 if (status == CUBIT_FAILURE) exit(1); 00267 00268 DLIList<Body*> test_bodies; 00269 gti->bodies(test_bodies); 00270 CubitVector vi, vii; 00271 vi = test_bodies.get()->center_point(); 00272 00273 CubitVector axis(10,0,0); 00274 00275 DLIList<Body*> bods; 00276 bods.append(test_bodies.get()); 00277 gti->translate(bods,axis); 00278 vii = test_bodies.get()->center_point(); 00279 assert(vii - vi == axis); 00280 // After parellel move, center point moved by x (10) 00281 00282 CubitVector vector1(10,10,10); 00283 CubitVector vector2(-10,-10,10); 00284 CubitVector vector3(10, -10, 10); 00285 free_entities.clean_out(); 00286 00287 // Make two vertices. 00288 gmti->make_RefVertex(vector1,5); 00289 gmti->make_RefVertex(vector2,5); 00290 gmti->make_RefVertex(vector3,5); 00291 gti->get_free_ref_entities(free_entities); 00292 00293 ref_entity_list.clean_out(); 00294 num_ents_exported=0; 00295 filename = "point.occ"; 00296 filetype = "OCC"; 00297 00298 rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00299 num_ents_exported, cubit_version); 00300 00301 remove(filename); 00302 //check for vertex 00303 bodies.clean_out(); 00304 gti->bodies(bodies); 00305 free_entities.clean_out();// get_free_ref_entities directly append 00306 //without checking for duplicates, so clean_out first. 00307 gti->get_free_ref_entities(free_entities); 00308 00309 RefVertex* vertex1 = CAST_TO(free_entities.step_and_get(),RefVertex); 00310 RefVertex* vertex2 = CAST_TO(free_entities.step_and_get(),RefVertex); 00311 RefVertex* vertex3 = CAST_TO(free_entities.step_and_get(),RefVertex); 00312 CubitBoolean is_equal = gti-> 00313 about_spatially_equal(vertex1,vertex2); 00314 assert(is_equal == CUBIT_FAILURE); 00315 00316 double d; 00317 gti->entity_entity_distance(vertex1,vertex2,vi, vii,d); 00318 assert(d > 28.284 && d < 28.2843); 00319 // distance (d) between vertex1,vertex2. 00320 00321 //check for body 00322 d = bodies.get()->measure(); 00323 assert( d > 2237.75 && d < 2237.752); 00324 // first body's volume. 00325 00326 vi = bodies.get()->center_point(); 00327 //first body's bounding box's center point. 00328 min.set(6.67, 0, 14.58); 00329 assert(vi.distance_between(min) < 0.01 ); 00330 00331 CubitBox box = bodies.get()->bounding_box(); 00332 min.set(-11.5894,-11.58944, 7.79849); 00333 max.set(24.9303,11.58944,21.3615); 00334 test_box.reset(min,max); 00335 assert(box >= test_box); 00336 test_box *= 1.01; 00337 assert(box <= test_box); 00338 //first body's bounding box. 00339 00340 gti->entity_entity_distance(gti->get_first_ref_volume(), vertex2,vi, vii,d); 00341 //first body and vertex2 's minimum distance(d) and locations for the minimum. 00342 assert(d <3.64214 && d > 3.64213); 00343 00344 // test create a Compound body. 00345 test_bodies.clean_out(); 00346 gti->bodies(test_bodies); 00347 00348 bodies.clean_out(); 00349 gmti->unite(test_bodies, bodies ); 00350 assert(bodies.size() == 1); 00351 00352 Body* CompBody = bodies.get(); 00353 BodySM* body = CompBody->get_body_sm_ptr(); 00354 OCCBody* occ_body = CAST_TO(body, OCCBody); 00355 occ_body->mass_properties(vi, d); 00356 00357 bodies.last(); 00358 vi = bodies.get()->center_point(); 00359 CubitVector ref_point(0,0,0); 00360 gti->reflect(bodies, ref_point, axis); 00361 vii = bodies.pop()->center_point(); 00362 assert(vi.x() == -vii.x() && vi.y() == vii.y() && vi.z() == vii.z()); 00363 // After reflection, only x value should change. 00364 00365 vi = CompBody->center_point(); 00366 double volume1 = CompBody->measure(); 00367 gti->scale(CompBody,vi, 2); 00368 vii = CompBody->center_point(); 00369 double volume2 = CompBody->measure(); 00370 assert(fabs(volume2 - 8 * volume1) < 0.0000001); 00371 assert(vii.distance_between(vi) < 0.0000001); 00372 // After scale, center point not moved and volume increased by 8 times 00373 00374 vi = CompBody->center_point(); 00375 bods.clean_out(); 00376 bods.append(CompBody); 00377 gti->translate(bods,axis); 00378 vii =CompBody->center_point(); 00379 assert(axis.about_equal(vii - vi) ); 00380 // After parellel move, center point moved by x (10) 00381 00382 vi = CompBody->center_point(); 00383 gti->rotate(bods, axis, 3.14/6); 00384 vii = CompBody->center_point(); 00385 assert(vi.x() == vii.x() && vi.y() != vii.y() && vi.z() != vii.z()); 00386 // After rotation, center point changed in y and z value. 00387 00388 double d_; 00389 occ_body->mass_properties(vii, d_); 00390 assert(fabs(d_ - 8*d) < 0.0001); 00391 //true center and volume, volume should be 8 times of the original one. 00392 00393 vi = occ_body->get_bounding_box().center(); 00394 // bounding box center. 00395 assert(vi != vii); 00396 00397 //check for surface 00398 DLIList<OCCSurface*> surfaces; 00399 occ_body->get_all_surfaces(surfaces); 00400 assert(surfaces.size() == 981); 00401 OCCSurface* surface = NULL; 00402 GeometryType type; 00403 00404 DLIList<RefFace*> ref_faces; 00405 gti->ref_faces(ref_faces); 00406 for(int i = 0; i < ref_faces.size(); i++) 00407 { 00408 surface = CAST_TO(ref_faces.step_and_get()->get_surface_ptr(), OCCSurface); 00409 type = surface->geometry_type(); 00410 if (type == CONE_SURFACE_TYPE) 00411 break; 00412 } 00413 RefFace* ref_face = ref_faces.get(); 00414 box = surface->bounding_box(); 00415 // bounding box 00416 00417 //make a new refface out of existing refface. 00418 RefFace* new_face = gmti->make_RefFace(ref_face); 00419 00420 ref_entity_list.clean_out(); 00421 ref_entity_list.append(new_face); 00422 filename = "surface.brep"; 00423 rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00424 num_ents_exported, cubit_version); 00425 remove(filename); 00426 00427 DLIList<DLIList<RefEdge*> > ref_edge_loops; 00428 new_face->ref_edge_loops(ref_edge_loops); 00429 00430 DLIList<RefEdge*> ref_edge_list; 00431 ref_edge_list = ref_edge_loops.get(); 00432 00433 //RefVertex* start = NULL; 00434 //RefVertex* end = NULL; 00435 for (int i = 0; i < ref_edge_list.size(); i++) 00436 { 00437 RefEdge * edge = ref_edge_list.get_and_step(); 00438 if (edge) { 00439 //double d = edge->measure(); 00440 //start = edge->start_vertex(); 00441 //end = edge->end_vertex(); 00442 } 00443 } 00444 00445 RefFace* new_face2 = gmti->make_RefFace(CONE_SURFACE_TYPE, 00446 ref_edge_list, CUBIT_TRUE, new_face, CUBIT_TRUE); 00447 assert(new_face2 == NULL); 00448 //2 Errors here for failing making a surface. negtive test here. 00449 00450 bodies.clean_out(); 00451 gti->bodies(bodies); 00452 //translate the new face by (20,20,20) 00453 for(int i = 1; i <= bodies.size(); i++) 00454 { 00455 bodies.step(); 00456 if( i != 2) 00457 continue; 00458 Body * entity = bodies.get(); 00459 vi = entity->center_point(); 00460 bods.clean_out(); 00461 bods.append(entity); 00462 gti->translate(bods, i*vector1); 00463 vii = entity->center_point(); 00464 } 00465 00466 //center point should moved by (20,20,20) compared with the original one below 00467 assert(fabs(vi.distance_between(vii)-vector1.length()*2) < 0.0001); 00468 00469 double area = ref_face->measure(); 00470 assert(fabs(area - 45.57587) < 0.0001); 00471 00472 double lower, upper; 00473 ref_face->get_param_range_U(lower, upper); 00474 assert(fabs(lower) < 0.0001 && fabs(upper - 1.57079) < 0.0001); 00475 00476 ref_face->get_param_range_V(lower, upper); 00477 assert(fabs(lower - 1.81177) < 0.01 && fabs(upper - 6.64752) < 0.01 ); 00478 // get surface V direction boundaries. here it's (24,24.5) 00479 00480 double u = 1; 00481 double v = 3; 00482 vi = ref_face->position_from_u_v(u,v); 00483 vii.set(27.88436, 37.66955, 127.69491); 00484 assert(fabs(vi.distance_between(vii)) < 0.0001); 00485 // get location on surface for it's u,v 00486 00487 ref_face->u_v_from_position(vi, u, v); 00488 assert(fabs(u - 1) < 0.0001 && fabs(v - 3) < 0.00001); 00489 // get (u,v) from this vi. 00490 00491 CubitBoolean periodic = ref_face->is_periodic(); 00492 assert(periodic == CUBIT_TRUE); 00493 // found if surface is periodic. 00494 00495 double p = 0; //period 00496 periodic = ref_face->is_periodic_in_U(p); 00497 assert(periodic == CUBIT_TRUE ); 00498 assert(fabs(p - 6.28318) < 0.0001); 00499 // found if surface is periodic in U and its period. 00500 00501 periodic = ref_face->is_periodic_in_V(p); 00502 assert(periodic == CUBIT_FALSE ); 00503 00504 //All OCC entities are parametric. 00505 00506 CubitBoolean closed = ref_face->is_closed_in_U(); 00507 assert(closed == CUBIT_FALSE); 00508 00509 closed = ref_face->is_closed_in_V(); 00510 assert(closed == CUBIT_FALSE); 00511 00512 CubitPointContainment pc = ref_face->point_containment(7,25); 00513 assert(pc == CUBIT_PNT_OUTSIDE); 00514 00515 CubitPointContainment pc2 = ref_face->point_containment(1,3); 00516 assert(pc2 == CUBIT_PNT_INSIDE); 00517 00518 ref_edge_loops.clean_out(); 00519 //int num_loops = ref_face->ref_edge_loops(ref_edge_loops); 00520 DLIList<RefEdge*> ref_edges1; 00521 ref_edges1 = ref_edge_loops.get(); 00522 RefEdge* edge1 = ref_edges1.pop(); 00523 RefEdge* edge2 = ref_edges1.pop(); 00524 double angle = edge2->angle_between(edge1, ref_face); 00525 assert(fabs(angle - 4.71238) < 0.001); 00526 00527 //test for curve 00528 CubitVector c_point, tangent, center; 00529 00530 //make all kinds of curves. 00531 CubitVector center_pnt(0,0,10); 00532 DLIList<CubitVector*> list; 00533 CubitVector center_pnt1(5,8,10); 00534 CubitVector center_pnt2(1,2,10); 00535 CubitVector center_pnt3(-2,-3.5,10); 00536 CubitVector start_pt = vertex1->coordinates(); 00537 CubitVector end_pt = vertex2->coordinates(); 00538 list.append(&start_pt); 00539 list.append(¢er_pnt1); 00540 list.append(¢er_pnt2); 00541 list.append(¢er_pnt); 00542 list.append(¢er_pnt3); 00543 list.append(&end_pt); 00544 RefEdge* new_edge_1 = gmti->make_RefEdge(SPLINE_CURVE_TYPE, vertex1, 00545 vertex2, list); 00546 d = new_edge_1->measure(); 00547 assert(fabs(d - 29.55)<0.01); 00548 CubitVector closest_location; 00549 new_edge_1->closest_point_trimmed(center_pnt1, closest_location); 00550 assert(center_pnt1.distance_between(closest_location) < 1.E-6); 00551 new_edge_1->closest_point_trimmed(center_pnt2,closest_location); 00552 assert(center_pnt2.distance_between(closest_location) < 1.E-6); 00553 00554 //Spline with points and tangents 00555 DLIList<CubitVector*> tangents; 00556 for (int i = 0; i< 6; i++) 00557 tangents.append(NULL); 00558 00559 GeometryModifyEngine* gme = gmti->get_engine(new_edge_1); 00560 Curve* new_curve = gme->make_Curve(list, tangents); 00561 RefEdge * new_edge_11 = gti->make_free_RefEdge(new_curve); 00562 d = new_edge_11->measure(); 00563 assert(fabs(d - 29.5517) <0.001); 00564 00565 CubitVector v11(-1,-1,0); 00566 CubitVector v12(3,1,0); 00567 tangents.clean_out(); 00568 tangents.append(&v11); 00569 for (int i = 0; i< 4; i++) 00570 tangents.append(NULL); 00571 tangents.append(&v12); 00572 00573 new_curve = gme->make_Curve(list, tangents); 00574 RefEdge * new_edge_12 = gti->make_free_RefEdge(new_curve); 00575 d = new_edge_12->measure(); 00576 assert(fabs(d - 34.33967) < 0.0001); 00577 00578 num_ents_exported=0; 00579 filename = "BsplineCurve.occ"; 00580 ref_entity_list.clean_out(); 00581 ref_entity_list.append(new_edge_11); 00582 ref_entity_list.append(new_edge_12); 00583 rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00584 num_ents_exported, cubit_version); 00585 remove(filename); 00586 00587 //straight line 00588 RefEdge* new_edge_2 = gmti->make_RefEdge(STRAIGHT_CURVE_TYPE, vertex1, 00589 vertex2, ¢er_pnt); 00590 d = new_edge_2->measure(); 00591 assert(fabs(d - 28.284) <0.001); 00592 00593 vi.set(-9.374537, 7.2082, 51.8845); 00594 new_edge_2->closest_point_trimmed(vi, c_point); 00595 vii.set(-1.083148, -1.083148, 10); 00596 assert(vii.distance_between( c_point ) < 0.0001); 00597 00598 //arc curve 00599 RefEdge* new_edge_3 = gmti->make_RefEdge(ARC_CURVE_TYPE, vertex1, 00600 vertex3, ¢er_pnt); 00601 d = new_edge_3->measure(); 00602 assert(fabs(d - 31.4159) < 0.0001); 00603 new_edge_3->closest_point_trimmed(vi, c_point); 00604 vii.set(0.62764, 3.486959, 10); 00605 assert(vii.distance_between( c_point ) < 0.0001); 00606 00607 //ellipse curve 00608 CubitVector ellps_cnt(0.4, 2.8, 10); 00609 RefEdge* new_edge_4 = gmti->make_RefEdge(ELLIPSE_CURVE_TYPE, vertex1, 00610 vertex3, &ellps_cnt); 00611 d = new_edge_4->measure(); 00612 assert(fabs(d - 66.31) < 0.01); 00613 new_edge_4->closest_point_trimmed(vi, c_point); 00614 vii.set(-13.163, 7.367 , 10); 00615 assert(vii.distance_between( c_point ) < 0.001); 00616 00617 RefEdge* new_edge_5 = gmti->make_RefEdge(ELLIPSE_CURVE_TYPE, vertex3, 00618 vertex1, &ellps_cnt); 00619 d = new_edge_5->measure(); 00620 assert(fabs(d-22.103) < 0.001); 00621 00622 00623 filename = "ellipses.occ"; 00624 ref_entity_list.clean_out(); 00625 ref_entity_list.append(new_edge_5); 00626 ref_entity_list.append(new_edge_4); 00627 00628 rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00629 num_ents_exported, cubit_version); 00630 remove(filename); 00631 00632 new_edge_5->closest_point_trimmed(vi, c_point); 00633 vii.set(10, -10, 10); 00634 assert(vii.distance_between( c_point ) < 0.0001); 00635 00636 //PARABOLA_CURVE_TYPE 00637 RefEdge* new_edge_6 = gmti->make_RefEdge(PARABOLA_CURVE_TYPE, vertex1, 00638 vertex3, ¢er_pnt); 00639 d = new_edge_6->measure(); 00640 assert(fabs(d-29.56546) < 0.0001); 00641 new_edge_6->closest_point_trimmed(vi, c_point); 00642 vii.set(0.58077, 2.41, 10); 00643 assert(vii.distance_between( c_point ) < 0.0001); 00644 00645 //HYPERBOLA_CURVE_TYPE 00646 RefEdge* new_edge_7 = gmti->make_RefEdge(HYPERBOLA_CURVE_TYPE, vertex1, 00647 vertex3, ¢er_pnt); 00648 d = new_edge_7->measure(); 00649 assert(fabs(d-21.6815) < 0.0001); 00650 00651 new_edge_7->closest_point_trimmed(vi, c_point); 00652 vii.set( 6.5835, 2.8855, 10); 00653 assert(vii.distance_between( c_point ) < 0.0001); 00654 00655 //delete all free vertices and edges 00656 for (int j = free_entities.size(); j--;) 00657 { 00658 gti->delete_RefEntity( free_entities.get_and_step()); 00659 } 00660 00661 ref_edges.clean_out(); 00662 gti->ref_edges(ref_edges); 00663 00664 //make a new refedge out of existing refedge. 00665 RefEdge* ref_edge = ref_edges.step_and_get(); 00666 00667 //RefEdge* new_edge = gmti->make_RefEdge(ref_edge); 00668 00669 free_entities.clean_out(); 00670 gti->get_free_ref_entities(free_entities); 00671 00672 //translate the new curve by (10,10,10) 00673 RefEntity * entity = free_entities.get(); 00674 box = entity->bounding_box(); 00675 DLIList<BasicTopologyEntity*> btes; 00676 btes.append((BasicTopologyEntity*)entity); 00677 gti->translate(btes, vector1); 00678 test_box = entity->bounding_box(); 00679 assert(fabs(test_box.minimum().distance_between( box.minimum()) -vector1.length())<0.001 && 00680 fabs(test_box.maximum().distance_between( box.maximum()) -vector1.length())< 0.001); 00681 //general query 00682 DLIList<OCCCurve*> curves; 00683 CAST_TO(body, OCCBody)->get_all_curves(curves); 00684 00685 OCCCurve *curve = NULL; 00686 for(int i = 0; i < curves.size(); i ++) 00687 { 00688 curve = curves.step_and_get(); 00689 type = curve->geometry_type(); 00690 if(type == ARC_CURVE_TYPE) 00691 break; 00692 } 00693 00694 box = curve-> bounding_box(); 00695 min.set(26.4388, 41.2872, 124.4865); 00696 max.set(32.9331, 41.3465, 130.9806); 00697 assert(min.distance_between(box.minimum()) < 0.001 && 00698 max.distance_between(box.maximum()) < 0.001); 00699 // bounding box 00700 00701 d = ref_edge->measure(); 00702 assert(fabs(d - 21.6815) < 0.001); 00703 00704 ref_edge->get_param_range(lower,upper); 00705 assert(lower + 1.06127 <= 0.0001 && fabs(upper-1.06127) < 0.001); 00706 // paremeter range. 00707 00708 d = ref_edge->length_from_u(lower,upper); 00709 assert(fabs(d - 21.6815) < 0.001); 00710 00711 d = ref_edge->length_from_u(lower/2+upper/2, upper); 00712 assert(fabs(d-10.8407) < 0.0001); 00713 // half curve length. 00714 00715 periodic = ref_edge->is_periodic(p); 00716 assert(periodic == CUBIT_FALSE); 00717 // if curve is periodic and its period (p). here it's not. 00718 00719 ref_edge->position_from_u(lower/2+upper/2, vi); 00720 // middle point. 00721 00722 u = ref_edge->u_from_position(vi); 00723 assert(fabs(u ) < 0.001); 00724 // middle point's u value. 00725 00726 //double radius; 00727 CubitVector curvature1_ptr; 00728 ref_edge->closest_point(vi, c_point, &tangent, & curvature1_ptr); 00729 vii.set(0, -1, 0); 00730 assert(tangent.distance_between(vii) < 0.001); 00731 // Closed point on middle point. 00732 00733 ref_edge->tangent(vi, tangent); 00734 assert(tangent.distance_between(vii) < 0.001); 00735 // tangent at middle point. 00736 00737 ref_edge->get_point_direction(c_point, tangent); 00738 assert(tangent.distance_between(vii) < 0.001); 00739 // double check tangent 00740 00741 pc = ref_edge->point_containment(c_point); 00742 assert(pc == CUBIT_PNT_INSIDE); 00743 // middle point should be on the curve. 00744 00745 //delete all entities 00746 gti->delete_Body(bodies); 00747 00748 for (int j = free_entities.size(); j--;) 00749 { 00750 gti->delete_RefEntity( free_entities.get_and_step()); 00751 } 00752 00753 return rsl; 00754 }
