cgma
00001 #include "MergeTool.hpp" 00002 #include "InitCGMA.hpp" 00003 #include "GeometryModifyTool.hpp" 00004 #include "GeometryQueryTool.hpp" 00005 #include "Body.hpp" 00006 #include "CGMApp.hpp" 00007 #include "CubitAttribManager.hpp" 00008 #include "CubitCompat.hpp" 00009 00010 #include <stdio.h> 00011 #include <stdlib.h> 00012 00013 #if defined (TEST_OCC) 00014 # define ENGINE "OCC" 00015 # define FORMAT "OCC" 00016 #elif defined (TEST_FACET) 00017 # define ENGINE "FACET" 00018 # define FORMAT "FACET" 00019 #else 00020 # error "Which engine to test?" 00021 #endif 00022 #define FILE_NAME "merge_test." FORMAT 00023 00024 #define ASSERT(A) if (!(A)) failed(#A,__FILE__,__LINE__) 00025 void failed( const char* A, const char* FILE, int LINE ) 00026 { 00027 printf( "Condition failed at %s:%d : %s\n", FILE, LINE, A ); 00028 abort(); 00029 } 00030 00031 RefFace* shared_face( Body* bod1, Body* bod2 ); 00032 00033 int main() 00034 { 00035 CubitStatus s = InitCGMA::initialize_cgma( ENGINE ); 00036 ASSERT(s); 00037 CGMApp::instance()->attrib_manager()->auto_flag( CUBIT_TRUE ); 00038 00039 Body *brick1, *brick2; 00040 brick1 = GeometryModifyTool::instance()->brick( 1, 1, 1 ); 00041 brick2 = GeometryModifyTool::instance()->brick( 1, 1, 1 ); 00042 ASSERT(brick1 && brick2); 00043 00044 DLIList<Body*> bods; 00045 bods.append(brick2); 00046 s = GeometryQueryTool::instance()->translate( bods, CubitVector(1,0,0) ); 00047 ASSERT(s); 00048 00049 DLIList<Body*> merge_list; 00050 merge_list.append( brick1 ); 00051 merge_list.append( brick2 ); 00052 s = MergeTool::instance()->merge_bodies( merge_list ); 00053 ASSERT(s); 00054 00055 ASSERT( shared_face( brick1, brick2 ) ); 00056 00057 int junk; 00058 DLIList<RefEntity*> export_list; 00059 export_list.append( brick1 ); 00060 export_list.append( brick2 ); 00061 s = CubitCompat_export_solid_model( export_list, 00062 FILE_NAME, 00063 FORMAT, 00064 junk, 00065 CubitString(__FILE__) ); 00066 ASSERT(s); 00067 00068 00069 DLIList<RefEntity*> import_list; 00070 s = CubitCompat_import_solid_model( FILE_NAME, 00071 FORMAT, 00072 NULL, 00073 CUBIT_FALSE, 00074 CUBIT_TRUE, 00075 CUBIT_TRUE, 00076 CUBIT_TRUE, 00077 CUBIT_TRUE, 00078 CUBIT_TRUE, 00079 &import_list ); 00080 ASSERT(s); 00081 remove( FILE_NAME ); 00082 00083 DLIList<Body*> import_bodies; 00084 CAST_LIST( import_list, import_bodies, Body ); 00085 ASSERT( 2 == import_bodies.size() ); 00086 00087 Body* new_bod1 = import_bodies.get_and_step(); 00088 Body* new_bod2 = import_bodies.get_and_step(); 00089 ASSERT( brick1 != new_bod1 && brick1 != new_bod2 ); 00090 ASSERT( brick2 != new_bod1 && brick2 != new_bod2 ); 00091 ASSERT( shared_face( new_bod1, new_bod2 ) ); 00092 00093 return 0; 00094 } 00095 00096 RefFace* shared_face( Body* b1, Body* b2 ) 00097 { 00098 DLIList<RefFace*> faces1, faces2; 00099 b1->ref_faces( faces1 ); 00100 b2->ref_faces( faces2 ); 00101 faces1.intersect( faces2 ); 00102 if (faces1.size() == 1) 00103 return faces1.get(); 00104 else 00105 return 0; 00106 } 00107
