cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CompositeCoEdge.cpp 00003 // 00004 // Purpose : Combined set of CoEdgeSMs 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 01/11/02 00011 //------------------------------------------------------------------------- 00012 00013 #include "CompositeCoEdge.hpp" 00014 #include "CompositeCurve.hpp" 00015 #include "CompositeLoop.hpp" 00016 #include "CompositeEngine.hpp" 00017 #include "VirtualQueryEngine.hpp" 00018 00019 // for printing debug info 00020 #include "RefEdge.hpp" 00021 00022 //------------------------------------------------------------------------- 00023 // Purpose : Constructor 00024 // 00025 // Special Notes : 00026 // 00027 // Creator : Jason Kraftcheck 00028 // 00029 // Creation Date : 01/11/02 00030 //------------------------------------------------------------------------- 00031 CompositeCoEdge::CompositeCoEdge( CoEdgeSM* coedge ) 00032 : myLoop(0), 00033 nextCoedge(0), 00034 prevCoedge(0), 00035 myCurve(0), 00036 nextOnCurve(0) 00037 { 00038 mySense = coedge->sense(); 00039 coedgeSet.push( coedge ); 00040 if( coedge->owner() ) 00041 coedge->owner()->swap_bridge( coedge, this, false ); 00042 coedge->owner(this); 00043 } 00044 00045 CompositeCoEdge::CompositeCoEdge( CompositeCurve* point_curve ) 00046 : mySense(CUBIT_FORWARD), 00047 myLoop(0), 00048 nextCoedge(0), 00049 prevCoedge(0), 00050 myCurve(0), 00051 nextOnCurve(0) 00052 { 00053 assert(point_curve->num_curves() == 0); 00054 CubitStatus stat = point_curve->add(this); 00055 assert(stat); 00056 if (CUBIT_SUCCESS != stat) { 00057 PRINT_ERROR("Failed to add a coedge to point curve.\n"); 00058 } 00059 } 00060 00061 CompositeCoEdge::CompositeCoEdge() 00062 : mySense(CUBIT_UNKNOWN), 00063 myLoop(0), 00064 nextCoedge( 0 ), 00065 prevCoedge( 0 ), 00066 myCurve(0), 00067 nextOnCurve(0) 00068 {} 00069 00070 //------------------------------------------------------------------------- 00071 // Purpose : Destructor 00072 // 00073 // Special Notes : 00074 // 00075 // Creator : Jason Kraftcheck 00076 // 00077 // Creation Date : 01/11/02 00078 //------------------------------------------------------------------------- 00079 CompositeCoEdge::~CompositeCoEdge() 00080 { 00081 if( myLoop ) 00082 myLoop->remove(this); 00083 if( myCurve ) 00084 myCurve->remove(this); 00085 00086 assert( !prevCoedge && !nextCoedge && !nextOnCurve ); 00087 00088 for( int i = 0; i < coedgeSet.size(); i++ ) 00089 if( coedgeSet[i]->owner() == this ) 00090 coedgeSet[i]->owner(0); 00091 } 00092 /* 00093 //------------------------------------------------------------------------- 00094 // Purpose : Add an underlying coedge 00095 // 00096 // Special Notes : 00097 // 00098 // Creator : Jason Kraftcheck 00099 // 00100 // Creation Date : 01/11/02 00101 //------------------------------------------------------------------------- 00102 CubitStatus CompositeCoEdge::append( CoEdgeSM* coedge_ptr ) 00103 { 00104 if( index_of( coedge_ptr ) >= 0 || coedge_ptr->owner() ) 00105 return CUBIT_FAILURE; 00106 00107 coedge_ptr->owner( this ); 00108 coedgeSet.push( coedge_ptr ); 00109 00110 return CUBIT_SUCCESS; 00111 } 00112 */ 00113 00114 //------------------------------------------------------------------------- 00115 // Purpose : find the index of the coedge that owns the passed curve 00116 // 00117 // Special Notes : returns -1 if not found 00118 // 00119 // Creator : Jason Kraftcheck 00120 // 00121 // Creation Date : 01/11/02 00122 //------------------------------------------------------------------------- 00123 int CompositeCoEdge::index_of( Curve* ptr ) const 00124 { 00125 int i; 00126 DLIList<TopologyBridge*> curve_list; 00127 TopologyBridge* curve = ptr; 00128 for( i = coedgeSet.size() - 1; i > 0; i-- ) 00129 { 00130 curve_list.clean_out(); 00131 coedgeSet[i]->get_children( curve_list ); 00132 if( curve_list.is_in_list( curve ) ) 00133 break; 00134 } 00135 return i; 00136 } 00137 00138 //------------------------------------------------------------------------- 00139 // Purpose : Split this CompositeCoEdge into two at the specified index 00140 // 00141 // Special Notes : new/other gets CoEdge at the passed index 00142 // 00143 // Creator : Jason Kraftcheck 00144 // 00145 // Creation Date : 01/11/02 00146 //------------------------------------------------------------------------- 00147 CompositeCoEdge* CompositeCoEdge::split( int index ) 00148 { 00149 if( index < 0 || index >= coedgeSet.size() ) 00150 return 0; 00151 00152 ++index; 00153 CompositeCoEdge* new_cce = new CompositeCoEdge(); 00154 new_cce->mySense = mySense; 00155 00156 int new_cce_count = coedgeSet.size() - index; 00157 new_cce->coedgeSet.size( new_cce_count ); 00158 00159 for( int i = 0; i < new_cce_count; i++ ) 00160 { 00161 new_cce->coedgeSet[i] = coedgeSet[i+index]; 00162 new_cce->coedgeSet[i]->owner( new_cce ); 00163 } 00164 coedgeSet.size( index ); 00165 00166 if( myLoop ) 00167 { 00168 CubitStatus s; 00169 if( mySense == CUBIT_FORWARD ) 00170 s = myLoop->insert_after( new_cce, this ); 00171 else 00172 s = myLoop->insert_before( new_cce, this ); 00173 assert( s ); 00174 if (CUBIT_SUCCESS != s) { 00175 PRINT_ERROR("Failed to insert a child coedge.\n"); 00176 return NULL; 00177 } 00178 } 00179 00180 new_cce->mySense = mySense; 00181 00182 return new_cce; 00183 } 00184 00185 CubitStatus CompositeCoEdge::combine( CompositeCoEdge* dead, bool prepend ) 00186 { 00187 int insert; 00188 if ( prepend ) 00189 { 00190 insert = 0; 00191 coedgeSet.size_end( coedgeSet.size() + dead->coedgeSet.size() ); 00192 } 00193 else 00194 { 00195 insert = coedgeSet.size(); 00196 coedgeSet.size( coedgeSet.size() + dead->coedgeSet.size() ); 00197 } 00198 00199 for( int i = 0; i < dead->coedgeSet.size(); i++ ) 00200 { 00201 CoEdgeSM* coedge = dead->coedgeSet[i]; 00202 assert( coedge->owner() == dead ); 00203 coedge->owner(this); 00204 coedgeSet[insert++] = coedge; 00205 } 00206 dead->coedgeSet.size(0); 00207 return CUBIT_SUCCESS; 00208 } 00209 00210 /* 00211 //------------------------------------------------------------------------- 00212 // Purpose : dequeue underlying coedge 00213 // 00214 // Special Notes : 00215 // 00216 // Creator : Jason Kraftcheck 00217 // 00218 // Creation Date : 01/11/02 00219 //------------------------------------------------------------------------- 00220 CoEdgeSM* CompositeCoEdge::remove_first() 00221 { 00222 CoEdgeSM* result = 0; 00223 if( coedgeSet.size() > 0 ) 00224 { 00225 result = coedgeSet[0]; 00226 coedgeSet.remove(0); 00227 } 00228 return result; 00229 } 00230 00231 //------------------------------------------------------------------------- 00232 // Purpose : pop underlying coedge 00233 // 00234 // Special Notes : 00235 // 00236 // Creator : Jason Kraftcheck 00237 // 00238 // Creation Date : 01/11/02 00239 //------------------------------------------------------------------------- 00240 CoEdgeSM* CompositeCoEdge::remove_last() 00241 { 00242 CoEdgeSM* result = 0; 00243 if( coedgeSet.size() > 0 ) 00244 { 00245 result = coedgeSet.pop() 00246 result->owner(0); 00247 } 00248 return result; 00249 } 00250 */ 00251 //------------------------------------------------------------------------- 00252 // Purpose : get parents (pure virtual in TopologyBridge) 00253 // 00254 // Special Notes : 00255 // 00256 // Creator : Jason Kraftcheck 00257 // 00258 // Creation Date : 01/11/02 00259 //------------------------------------------------------------------------- 00260 void CompositeCoEdge::get_parents_virt( DLIList<TopologyBridge*>& parents ) 00261 { 00262 LoopSM* result = get_parent_loop(); 00263 if( result ) 00264 { 00265 parents.append( result ); 00266 } 00267 } 00268 00269 //------------------------------------------------------------------------- 00270 // Purpose : get children (pure virtual in TopologyBridge) 00271 // 00272 // Special Notes : 00273 // 00274 // Creator : Jason Kraftcheck 00275 // 00276 // Creation Date : 01/11/02 00277 //------------------------------------------------------------------------- 00278 void CompositeCoEdge::get_children_virt( DLIList<TopologyBridge*>& children ) 00279 { 00280 if( myCurve ) 00281 { 00282 children.append( myCurve->primary_stitched_curve() ); 00283 } 00284 /* 00285 else if( num_coedges() ) 00286 { 00287 DLIList<TopologyBridge*> coedge_children; 00288 coedge(0)->get_children( coedge_children ); 00289 assert( coedge_children.size() == 1 ); 00290 children.append( coedge_children.get() ); 00291 } 00292 */ 00293 } 00294 00295 /* 00296 //------------------------------------------------------------------------- 00297 // Purpose : Set child curve 00298 // 00299 // Special Notes : If curve is composite, update curve link to this 00300 // 00301 // Creator : Jason Kraftcheck 00302 // 00303 // Creation Date : 01/11/02 00304 //------------------------------------------------------------------------- 00305 void CompositeCoEdge::curve( CompositeCurve* curve_ptr ) 00306 { 00307 if( myCurve ) 00308 { 00309 myCurve->remove(this); 00310 assert( !myCurve ); 00311 } 00312 00313 if( curve_ptr ) 00314 { 00315 curve_ptr->add(this); 00316 assert( myCurve == curve_ptr ); 00317 } 00318 } 00319 00320 //------------------------------------------------------------------------- 00321 // Purpose : set loop pointer 00322 // 00323 // Special Notes : if loop is composite, add this to loop instead 00324 // 00325 // Creator : Jason Kraftcheck 00326 // 00327 // Creation Date : 01/11/02 00328 //------------------------------------------------------------------------- 00329 void CompositeCoEdge::loop( CompositeLoop* loop_ptr ) 00330 { 00331 if( myLoop ) 00332 myLoop->remove( this ); 00333 00334 if( loop_ptr ) 00335 loop_ptr->insert_before( loop_ptr->first_coedge(), this ); 00336 00337 myLoop = loop_ptr; 00338 } 00339 */ 00340 //------------------------------------------------------------------------- 00341 // Purpose : Get parent loop no higher than composite level 00342 // 00343 // Special Notes : 00344 // 00345 // Creator : Jason Kraftcheck 00346 // 00347 // Creation Date : 03/05/02 00348 //------------------------------------------------------------------------- 00349 LoopSM* CompositeCoEdge::get_parent_loop() 00350 { 00351 LoopSM* result = get_loop(); 00352 00353 if( !result && num_coedges() ) 00354 { 00355 DLIList<TopologyBridge*> parents(1); 00356 get_coedge(0)->get_parents_virt( parents ); 00357 assert( parents.size() == 1 ); 00358 result = dynamic_cast<LoopSM*>(parents.get()); 00359 } 00360 00361 return result; 00362 } 00363 00364 //------------------------------------------------------------------------- 00365 // Purpose : remove an underlying bridge 00366 // 00367 // Special Notes : pure virtual in TBOwner 00368 // 00369 // Creator : Jason Kraftcheck 00370 // 00371 // Creation Date : 01/11/02 00372 //------------------------------------------------------------------------- 00373 CubitStatus CompositeCoEdge::remove_bridge( TopologyBridge* bridge ) 00374 { 00375 int index; 00376 for( index = coedgeSet.size() - 1; index >= 0; index-- ) 00377 if( coedgeSet[index] == bridge ) 00378 break; 00379 if( index < 0 ) 00380 return CUBIT_FAILURE; 00381 00382 coedgeSet.remove( index ); 00383 bridge->owner(0); 00384 /* 00385 if ( coedgeSet.size() > 0 ) 00386 return CUBIT_SUCCESS; 00387 00388 if ( get_curve() ) 00389 get_curve()->remove(this); 00390 00391 if ( get_loop() ) 00392 { 00393 CompositeLoop* loop = get_loop(); 00394 loop->remove(this); 00395 if ( loop->first_coedge() == 0 ) 00396 delete loop; 00397 } 00398 00399 delete this; 00400 */ 00401 return CUBIT_SUCCESS; 00402 } 00403 00404 //------------------------------------------------------------------------- 00405 // Purpose : exchange one underlying coedge for another 00406 // 00407 // Special Notes : pure virtual in TBOwner 00408 // 00409 // Creator : Jason Kraftcheck 00410 // 00411 // Creation Date : 01/11/02 00412 //------------------------------------------------------------------------- 00413 CubitStatus CompositeCoEdge::swap_bridge( TopologyBridge* old_tb, 00414 TopologyBridge* new_tb, 00415 bool ) 00416 { 00417 CoEdgeSM* old_coedge = dynamic_cast<CoEdgeSM*>(old_tb); 00418 CoEdgeSM* new_coedge = dynamic_cast<CoEdgeSM*>(new_tb); 00419 00420 int index = index_of( old_coedge ); 00421 if( index < 0 || !new_coedge || index_of(new_coedge) >= 0 ) 00422 return CUBIT_FAILURE; 00423 00424 coedgeSet[index] = new_coedge; 00425 00426 old_tb->owner(0); 00427 if( new_tb->owner() ) 00428 new_tb->owner()->remove_bridge( new_tb ); 00429 new_tb->owner(this); 00430 00431 return CUBIT_SUCCESS; 00432 } 00433 00434 //------------------------------------------------------------------------- 00435 // Purpose : see if we are the owner of the passed TB 00436 // 00437 // Special Notes : pure virtual in TBOwner 00438 // 00439 // Creator : Jason Kraftcheck 00440 // 00441 // Creation Date : 01/11/02 00442 //------------------------------------------------------------------------- 00443 CubitBoolean CompositeCoEdge::contains_bridge( TopologyBridge* bridge ) const 00444 { 00445 CompositeCoEdge* coedge = dynamic_cast<CompositeCoEdge*>(bridge); 00446 return (index_of(coedge) < 0) ? CUBIT_FALSE : CUBIT_TRUE; 00447 } 00448 00449 void CompositeCoEdge::notify_reversed( TopologyBridge* ) 00450 {} 00451 00452 00453 //------------------------------------------------------------------------- 00454 // Purpose : Get CompositeEngine 00455 // 00456 // Special Notes : 00457 // 00458 // Creator : Jason Kraftcheck 00459 // 00460 // Creation Date : 01/11/02 00461 //------------------------------------------------------------------------- 00462 GeometryQueryEngine* CompositeCoEdge::get_geometry_query_engine() const 00463 { return VirtualQueryEngine::instance(); } 00464 00465 //------------------------------------------------------------------------- 00466 // Purpose : Attribute functions 00467 // 00468 // Special Notes : 00469 // 00470 // Creator : Jason Kraftcheck 00471 // 00472 // Creation Date : 01/11/02 00473 //------------------------------------------------------------------------- 00474 void CompositeCoEdge::append_simple_attribute_virt( const CubitSimpleAttrib& ) 00475 { } 00476 void CompositeCoEdge::remove_simple_attribute_virt( const CubitSimpleAttrib& ) 00477 { } 00478 void CompositeCoEdge::remove_all_simple_attribute_virt() 00479 { } 00480 CubitStatus CompositeCoEdge::get_simple_attribute( DLIList<CubitSimpleAttrib>& ) 00481 { return CUBIT_FAILURE; } 00482 CubitStatus CompositeCoEdge::get_simple_attribute( const CubitString& , 00483 DLIList<CubitSimpleAttrib>& ) 00484 { return CUBIT_FAILURE; } 00485 00486 00487 00488 00489 void CompositeCoEdge::reverse() 00490 { 00491 switch( mySense ) { 00492 case CUBIT_FORWARD: 00493 mySense = CUBIT_REVERSED; 00494 break; 00495 case CUBIT_REVERSED: 00496 mySense = CUBIT_FORWARD; 00497 break; 00498 default: 00499 mySense = CUBIT_UNKNOWN; 00500 } 00501 00502 int half = coedgeSet.size() / 2; 00503 for( int i = 0; i < half; i++ ) 00504 { 00505 int j = coedgeSet.size() - i - 1; 00506 CoEdgeSM* tmp = coedgeSet[i]; 00507 coedgeSet[i] = coedgeSet[j]; 00508 coedgeSet[j] = tmp; 00509 } 00510 00511 } 00512 00513 //------------------------------------------------------------------------- 00514 // Purpose : Get start and end points reversed if sense is reversed 00515 // 00516 // Special Notes : 00517 // 00518 // Creator : Jason Kraftcheck 00519 // 00520 // Creation Date : 03/17/02 00521 //------------------------------------------------------------------------- 00522 CompositePoint* CompositeCoEdge::start_point() 00523 { 00524 return mySense == CUBIT_FORWARD 00525 ? myCurve->start_point() 00526 : myCurve->end_point(); 00527 } 00528 CompositePoint* CompositeCoEdge::end_point() 00529 { 00530 return mySense == CUBIT_FORWARD 00531 ? myCurve->end_point() 00532 : myCurve->start_point(); 00533 } 00534 00535 00536 CubitStatus CompositeCoEdge::remove_coedge( int index ) 00537 { 00538 if( index < 0 || index >= coedgeSet.size() ) 00539 return CUBIT_FAILURE; 00540 00541 coedgeSet[index]->owner(0); 00542 coedgeSet.remove( index ); 00543 00544 return CUBIT_SUCCESS; 00545 } 00546 00547 00548 CubitStatus CompositeCoEdge::insert_coedge( int index, CoEdgeSM* coedge ) 00549 { 00550 if( index < 0 || index > coedgeSet.size() ) 00551 return CUBIT_FAILURE; 00552 00553 coedgeSet.insert(coedge, index); 00554 coedge->owner(this); 00555 return CUBIT_SUCCESS; 00556 } 00557 00558 void CompositeCoEdge::print_debug_info( const char* prefix, bool brief ) 00559 { 00560 if( prefix == 0 ) prefix = ""; 00561 00562 const char* sense = mySense == CUBIT_FORWARD ? "Forward" : 00563 mySense == CUBIT_REVERSED ? "Reverse" : "UNKNOWN"; 00564 00565 PRINT_INFO("%sCompCoEdge %p %s ", prefix, (void*)this, sense ); 00566 if ( num_coedges() == 1 ) 00567 PRINT_INFO("%s %p ", fix_type_name(typeid(*get_coedge(0)).name()), 00568 (void*)get_coedge(0)); 00569 else 00570 PRINT_INFO("%d coedges ", num_coedges() ); 00571 00572 if( !myCurve ) 00573 PRINT_INFO("NULL CURVE\n"); 00574 else if( brief ) 00575 #ifdef TOPOLOGY_BRIDGE_IDS 00576 PRINT_INFO("curve %d\n", myCurve->get_id() ); 00577 #else 00578 PRINT_INFO("curve %p\n", (void*)myCurve ); 00579 #endif 00580 else 00581 { PRINT_INFO("\n "); myCurve->print_debug_info(prefix, true); } 00582 00583 /* 00584 if( coedgeSet.size() == 0 ) 00585 PRINT_INFO(" No CoEdgeSMs!\n"); 00586 else if( coedgeSet.size() == 1 ) 00587 PRINT_INFO(" CoEdgeSM=%p\n", coedgeSet[0] ); 00588 else 00589 { 00590 PRINT_INFO("\n"); 00591 for( int i = 0; i < coedgeSet.size(); i++ ) 00592 PRINT_INFO("%s CoEdgeSM[%d] = %p\n", prefix, i, coedgeSet[i] ); 00593 } 00594 */ 00595 }
