cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CompositeCurve.cpp 00003 // 00004 // Purpose : Geometry defined as the joining of a chain of curves. 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 12/19/01 00011 //------------------------------------------------------------------------- 00012 00013 #include <math.h> 00014 00015 #include "CompositeCurve.hpp" 00016 #include "CompositeCoEdge.hpp" 00017 #include "CompositeLoop.hpp" 00018 #include "CompositePoint.hpp" 00019 #include "VirtualQueryEngine.hpp" 00020 #include "CompositeEngine.hpp" 00021 00022 //#include "GfxDebug.hpp" 00023 #include "GMem.hpp" 00024 00025 //------------------------------------------------------------------------- 00026 // Purpose : Constructor 00027 // 00028 // Special Notes : 00029 // 00030 // Creator : Jason Kraftcheck 00031 // 00032 // Creation Date : 12/19/01 00033 //------------------------------------------------------------------------- 00034 CompositeCurve::CompositeCurve( Curve* curve ) 00035 : HadBridgeRemoved(0), 00036 hiddenSet(0), 00037 firstCoEdge(0), 00038 startPoint(0), 00039 endPoint(0), 00040 startNext(0), 00041 endNext(0), 00042 stitchNext(0) 00043 { 00044 compGeom = new CompositeGeom(1); 00045 compGeom->append( curve, CUBIT_FORWARD ); 00046 if( curve->owner() ) 00047 curve->owner()->swap_bridge( curve, this, false ); 00048 curve->owner(this); 00049 } 00050 00051 CompositeCurve::CompositeCurve( CompositeGeom* geometry ) 00052 : HadBridgeRemoved(0), 00053 compGeom( geometry ), 00054 hiddenSet( 0 ), 00055 firstCoEdge( 0 ), 00056 startPoint( 0 ), 00057 endPoint( 0 ), 00058 startNext( 0 ), 00059 endNext( 0 ), 00060 stitchNext(0) 00061 { 00062 for( int i = 0; i < compGeom->num_entities(); i++ ) 00063 { 00064 GeometryEntity* entity = compGeom->entity(i); 00065 assert( !entity->owner() ); 00066 entity->owner(this); 00067 } 00068 } 00069 00070 //------------------------------------------------------------------------- 00071 // Purpose : Point-curve constructor 00072 // 00073 // Special Notes : 00074 // 00075 // Creator : Jason Kraftcheck 00076 // 00077 // Creation Date : 02/27/04 00078 //------------------------------------------------------------------------- 00079 CompositeCurve::CompositeCurve( CompositePoint* point ) 00080 : HadBridgeRemoved(0), 00081 hiddenSet(0), 00082 firstCoEdge(0), 00083 startPoint(0), 00084 endPoint(0), 00085 startNext(0), 00086 endNext(0), 00087 stitchNext(0) 00088 { 00089 compGeom = new CompositeGeom(1); 00090 //compGeom->append( point, CUBIT_FORWARD ); 00091 start_point(point); 00092 end_point(point); 00093 } 00094 00095 00096 CompositeCurve::~CompositeCurve() 00097 { 00098 while( firstCoEdge ) 00099 remove( firstCoEdge ); 00100 00101 for( int i = 0; i < num_curves(); i++ ) 00102 if( get_curve(i)->owner() == this ) 00103 get_curve(i)->owner(0); 00104 00105 start_point(0); 00106 end_point(0); 00107 00108 unstitch_all(); 00109 00110 delete hiddenSet; 00111 delete compGeom; 00112 hiddenSet = (HiddenEntitySet*)0xbdbdbdbd; 00113 compGeom = (CompositeGeom*)0xbdbdbdbd; 00114 assert(!startNext); 00115 assert(!endNext); 00116 } 00117 00118 00119 CompositeCurve* CompositeCurve::next( const CompositePoint* around ) 00120 { 00121 return around == startPoint ? startNext : 00122 around == endPoint ? endNext : 0; 00123 } 00124 00125 CubitStatus CompositeCurve::start_point( CompositePoint* pt ) 00126 { 00127 return set_point( true, pt ); 00128 } 00129 00130 CubitStatus CompositeCurve::end_point( CompositePoint* pt ) 00131 { 00132 return set_point( false, pt ); 00133 } 00134 00135 CubitStatus CompositeCurve::set_point( bool start, CompositePoint* pt ) 00136 { 00137 CompositePoint*& my_point = start ? startPoint : endPoint; 00138 CompositeCurve*& next_crv = start ? startNext : endNext; 00139 00140 if( pt == my_point ) 00141 return CUBIT_SUCCESS; 00142 00143 if( my_point && startPoint != endPoint ) 00144 { 00145 CompositeCurve* prev = my_point->firstCurve; 00146 assert( prev != NULL ); 00147 00148 if( prev == this ) 00149 { 00150 my_point->firstCurve = next_crv; 00151 } 00152 else 00153 { 00154 CompositeCurve* curve = prev->next(my_point); 00155 while( curve != this ) 00156 { 00157 prev = curve; 00158 curve = prev->next(my_point); 00159 } 00160 00161 if( prev->startPoint == my_point ) 00162 { 00163 assert(prev->startNext == this); 00164 prev->startNext = next_crv; 00165 } 00166 00167 if( prev->endPoint == my_point ) 00168 { 00169 assert(prev->endNext == this); 00170 prev->endNext = next_crv; 00171 } 00172 } 00173 } 00174 00175 my_point = pt; 00176 if (!pt) 00177 { 00178 next_crv = 0; 00179 } 00180 else if (startPoint == endPoint) 00181 { 00182 next_crv = start ? endNext : startNext; 00183 } 00184 else 00185 { 00186 next_crv = pt->firstCurve; 00187 pt->firstCurve = this; 00188 } 00189 00190 return CUBIT_SUCCESS; 00191 } 00192 00193 00194 CompositePoint* CompositeCurve::other_point( CompositePoint* pt ) 00195 { 00196 CompositePoint* sp = start_point(); 00197 CompositePoint* ep = end_point(); 00198 return (pt == sp) ? ep : (pt == ep) ? sp : 0; 00199 } 00200 00201 CompositeCurve* CompositeCurve::split( Curve* curve ) 00202 { 00203 int index = index_of( curve ); 00204 if( (index < 0) || (index == (num_curves()-1)) ) 00205 return 0; 00206 00207 CompositeGeom* new_geom = compGeom->split( index ); 00208 if( !new_geom ) 00209 return 0; 00210 00211 for( int i = 0; i < new_geom->num_entities(); i++ ) 00212 new_geom->entity(i)->owner( 0 ); 00213 00214 return new CompositeCurve( new_geom ); 00215 } 00216 00217 00218 CubitStatus CompositeCurve::combine( CompositeCurve* curve, bool prepend ) 00219 { 00220 int start, stop; 00221 if ( prepend ) { 00222 start = 0; 00223 stop = curve->compGeom->num_entities(); 00224 } else { 00225 start = compGeom->num_entities(); 00226 stop = start + curve->compGeom->num_entities(); 00227 } 00228 00229 compGeom->merge( *(curve->compGeom), prepend ); 00230 if( curve->hiddenSet ) 00231 hidden_entities().merge( curve->hiddenSet ); 00232 00233 for( int i = start; i < stop; i++ ) 00234 { 00235 TopologyBridge* bridge = compGeom->entity(i); 00236 assert( bridge->owner() == curve ); 00237 bridge->owner(this); 00238 } 00239 00240 return CUBIT_SUCCESS; 00241 } 00242 00243 bool CompositeCurve::has_parent_composite_surface() const 00244 { 00245 CompositeCoEdge* coedge; 00246 for( coedge = first_coedge(); coedge; coedge = next_coedge(coedge) ) 00247 if( coedge->get_loop() ) 00248 return true; 00249 return false; 00250 } 00251 00252 void CompositeCurve::reverse() 00253 { 00254 compGeom->reverse(); 00255 } 00256 00257 CompositePoint* CompositeCurve::common_point( CompositeCurve* curve ) 00258 { 00259 CompositePoint* result = 0; 00260 CompositePoint* this_sp = start_point(); 00261 CompositePoint* this_ep = end_point(); 00262 CompositePoint* othr_sp = curve->start_point(); 00263 CompositePoint* othr_ep = curve->end_point(); 00264 00265 if( this_sp == othr_sp || this_sp == othr_ep ) 00266 result = this_sp; 00267 else if( this_ep == othr_sp || this_ep == othr_ep ) 00268 result = this_ep; 00269 00270 return result; 00271 } 00272 /* 00273 CompositeCoEdge* CompositeCurve::find_coedge( CompositeSurface* surface ) 00274 { 00275 CoEdge* coedge = 0; 00276 while( coedge = next_coedge( coedge ) ) 00277 if( coedge->get_loop() && coedge->get_loop()->get_surface() == surface ) 00278 break; 00279 return coedge; 00280 } 00281 */ 00282 CubitStatus CompositeCurve::add( CompositeCoEdge* coedge ) 00283 { 00284 if( coedge->myCurve ) 00285 { 00286 assert(0); 00287 return CUBIT_FAILURE; 00288 } 00289 00290 coedge->myCurve = this; 00291 coedge->nextOnCurve = firstCoEdge; 00292 firstCoEdge = coedge; 00293 00294 return CUBIT_SUCCESS; 00295 } 00296 00297 CubitStatus CompositeCurve::remove( CompositeCoEdge* coedge ) 00298 { 00299 if( coedge->myCurve != this ) 00300 return CUBIT_FAILURE; 00301 00302 if( coedge == firstCoEdge ) 00303 { 00304 firstCoEdge = coedge->nextOnCurve; 00305 } 00306 else 00307 { 00308 CompositeCoEdge *prev = firstCoEdge, 00309 *next = firstCoEdge->nextOnCurve; 00310 while( next != coedge ) 00311 { 00312 assert(next != NULL); 00313 prev = next; 00314 next = next->nextOnCurve; 00315 } 00316 00317 prev->nextOnCurve = next->nextOnCurve; 00318 } 00319 00320 coedge->nextOnCurve = 0; 00321 coedge->myCurve = 0; 00322 return CUBIT_SUCCESS; 00323 } 00324 00325 00326 CubitBox CompositeCurve::bounding_box() const 00327 { return compGeom->bounding_box(); } 00328 00329 double CompositeCurve::measure() 00330 { return compGeom->measure(); } 00331 00332 GeometryType CompositeCurve::geometry_type() 00333 { 00334 switch (num_curves()) { 00335 case 0 : return POINT_CURVE_TYPE; 00336 case 1 : return get_curve(0)->geometry_type(); 00337 default : return UNDEFINED_CURVE_TYPE; 00338 } 00339 } 00340 00341 GeometryQueryEngine* CompositeCurve::get_geometry_query_engine() const 00342 { return VirtualQueryEngine::instance(); } 00343 00344 00345 double CompositeCurve::start_param() 00346 { return 0; } 00347 00348 double CompositeCurve::end_param() 00349 { return measure(); } 00350 00351 CubitBoolean CompositeCurve::get_param_range( double& lower, double& upper ) 00352 { 00353 lower = 0; 00354 upper = measure(); 00355 return CUBIT_TRUE; 00356 } 00357 00358 CubitBoolean CompositeCurve::is_periodic( double& period ) 00359 { 00360 if (geometry_type() == POINT_CURVE_TYPE) 00361 return CUBIT_FALSE; 00362 00363 if( startPoint == endPoint && num_curves() > 0 ) 00364 { 00365 period = measure(); 00366 return CUBIT_TRUE; 00367 } 00368 else 00369 { 00370 period = 0; 00371 return CUBIT_FALSE; 00372 } 00373 } 00374 00375 CubitStatus CompositeCurve::position_from_u( double u, CubitVector& position ) 00376 { 00377 int index; 00378 double ui; 00379 00380 if (num_curves() == 0) // point curve 00381 return CUBIT_FAILURE; 00382 00383 if( ! curve_param( u, ui, index ) || index < 0 ) 00384 return CUBIT_FAILURE; 00385 00386 Curve* curve_ptr = get_curve( index ); 00387 return curve_ptr ? curve_ptr->position_from_u( ui, position ) : CUBIT_FAILURE; 00388 } 00389 00390 double CompositeCurve::u_from_position( const CubitVector& position ) 00391 { 00392 if (num_curves() == 0) // point curve 00393 return 0.0; 00394 00395 int index = closest_curve(position ); 00396 double param = get_curve( index )->u_from_position( position ); 00397 return composite_param( index, param ); 00398 } 00399 00400 double CompositeCurve::u_from_arc_length( double param, double length ) 00401 { return param + length; } 00402 double CompositeCurve::length_from_u( double u1, double u2 ) 00403 { return u2 - u1; } 00404 00405 CubitStatus CompositeCurve::closest_point( const CubitVector& location, 00406 CubitVector& closest, 00407 CubitVector* tangent_ptr, 00408 CubitVector* curvature_ptr, 00409 double* param ) 00410 { 00411 if (num_curves() == 0) // point curve 00412 { 00413 if (!startPoint) 00414 return CUBIT_FAILURE; 00415 00416 closest = startPoint->coordinates(); 00417 if (tangent_ptr) 00418 tangent_ptr->set(0.0,0.0,0.0); 00419 if (curvature_ptr) 00420 curvature_ptr->set(0.0,0.0,0.0); 00421 if (param) 00422 *param = 0.0; 00423 } 00424 00425 if( compGeom->num_entities() == 1 ) 00426 { 00427 CubitStatus result = get_curve(0) 00428 ->closest_point( location, closest, tangent_ptr, curvature_ptr, param ); 00429 00430 if( tangent_ptr && compGeom->sense(0) == CUBIT_REVERSED ) 00431 *tangent_ptr *= -1.0; 00432 00433 if( param ) 00434 *param = composite_param( 0, *param ); 00435 00436 return result; 00437 } 00438 00439 int index = closest_curve( location, &closest ); 00440 Curve* curve = get_curve( index ); 00441 if( tangent_ptr || curvature_ptr || param ) 00442 { 00443 curve->closest_point( location, closest, tangent_ptr, 00444 curvature_ptr, param ); 00445 if( param ) 00446 *param = composite_param( index, *param ); 00447 if( tangent_ptr && compGeom->sense(index) == CUBIT_REVERSED ) 00448 *tangent_ptr *= -1.0; 00449 } 00450 00451 return CUBIT_SUCCESS; 00452 } 00453 00454 00455 CubitStatus CompositeCurve::closest_point_trimmed( 00456 const CubitVector& position, 00457 CubitVector& closest ) 00458 { 00459 if (num_curves() == 0) 00460 return closest_point( position, closest ); 00461 00462 if( compGeom->num_entities() == 1 ) 00463 return get_curve(0)->closest_point_trimmed( position, closest ); 00464 00465 closest_curve( position, &closest ); 00466 return CUBIT_SUCCESS; 00467 } 00468 00469 CubitBoolean CompositeCurve::is_position_on( const CubitVector& position ) 00470 { 00471 // point curve 00472 if (num_curves() == 0) 00473 { 00474 CompositePoint* point = start_point(); 00475 double lensqr = (position - point->coordinates()).length_squared(); 00476 return lensqr <= (GEOMETRY_RESABS*GEOMETRY_RESABS); 00477 } 00478 00479 if( compGeom->num_entities() == 1 ) 00480 return get_curve(0)->is_position_on( position ); 00481 00482 int index = closest_curve( position ); 00483 return get_curve(index)->is_position_on( position ); 00484 } 00485 00486 CubitPointContainment CompositeCurve::point_containment( const CubitVector& point ) 00487 { 00488 int index; 00489 00490 if (num_curves() == 0) 00491 return is_position_on(point) ? CUBIT_PNT_ON : CUBIT_PNT_OFF; 00492 00493 for( index = 0; index < compGeom->num_entities(); index++ ) 00494 { 00495 if( get_curve(index)->point_containment( point ) == CUBIT_PNT_ON ) 00496 return CUBIT_PNT_ON; 00497 } 00498 00499 return CUBIT_PNT_OFF; //not on any Curve 00500 } 00501 00502 CubitStatus CompositeCurve::get_point_direction( CubitVector& origin, 00503 CubitVector& direction ) 00504 { 00505 if (num_curves() == 0) // point curve 00506 return CUBIT_FAILURE; 00507 00508 if( compGeom->num_entities() == 1 ) 00509 return get_curve(0)->get_point_direction( origin, direction ); 00510 00511 int count = compGeom->num_entities(); 00512 CubitVector* vect_list = new CubitVector[count]; 00513 double RESABS_SQUARED = CUBIT_RESABS * CUBIT_RESABS; 00514 direction.set(0,0,0); 00515 for( int i = 0; i < count; i++ ) 00516 { 00517 if( ! get_curve(i)->get_point_direction(origin,vect_list[i]) || 00518 (vect_list[i].length_squared() < RESABS_SQUARED) ) 00519 { 00520 delete [] vect_list; 00521 return CUBIT_FAILURE; 00522 } 00523 if( get_sense(i) == CUBIT_REVERSED ) 00524 vect_list[i] *= -1; 00525 direction += vect_list[i]; 00526 } 00527 //If we reach this point, then all of the underlying curves are linear. 00528 //Next check if they are colinear. 00529 if( direction.length_squared() < RESABS_SQUARED ) 00530 { 00531 delete [] vect_list; 00532 return CUBIT_FAILURE; 00533 } 00534 CubitVector mean = ~direction; 00535 for( int j = 0; j < count; j++ ) 00536 { 00537 if( fabs( 1 - (mean % ~vect_list[j]) ) > CUBIT_RESABS ) 00538 { 00539 delete [] vect_list; 00540 return CUBIT_FAILURE; 00541 } 00542 } 00543 00544 delete [] vect_list; 00545 get_curve(0)->get_point_direction(origin,direction); 00546 direction = mean; 00547 return CUBIT_SUCCESS; 00548 } 00549 00550 CubitStatus CompositeCurve::get_interior_extrema( 00551 DLIList<CubitVector*>& interior_points, 00552 CubitSense& return_sense ) 00553 { 00554 return_sense = CUBIT_FORWARD; 00555 if (num_curves() == 0) // point curve 00556 return CUBIT_SUCCESS; 00557 00558 // Go through each curve in the composite 00559 DLIList<CubitVector*> curve_point_list; 00560 for (int i = compGeom->num_entities() - 1; i >= 0; i--) 00561 { 00562 // Get the next curve's extrema 00563 Curve* cur_curve = get_curve(i); 00564 cur_curve->get_interior_extrema(curve_point_list,return_sense); 00565 // See which order to put them into the return list 00566 if (return_sense == get_sense(i)) 00567 { 00568 interior_points += curve_point_list; 00569 } 00570 else 00571 { 00572 curve_point_list.last(); 00573 for (int j = curve_point_list.size(); j--; ) 00574 interior_points.append(curve_point_list.get_and_back()); 00575 } 00576 // Unless this is the last curve, put in the point 00577 // between this and the next curve 00578 if (i != 0) 00579 { 00580 CubitVector* endpoint = new CubitVector(0,0,0); 00581 if (get_sense(i) == CUBIT_FORWARD) 00582 cur_curve->position_from_u(cur_curve->end_param(), *endpoint); 00583 else 00584 cur_curve->position_from_u(cur_curve->end_param(), *endpoint); 00585 interior_points.append(endpoint); 00586 } 00587 // clean out the list for the next curve 00588 curve_point_list.clean_out(); 00589 } 00590 00591 return CUBIT_SUCCESS; 00592 } 00593 00594 CubitStatus CompositeCurve::get_center_radius( CubitVector& c, double& r ) 00595 { 00596 if (num_curves() == 0) // point curve 00597 return CUBIT_FAILURE; 00598 00599 if (!get_curve(0)->get_center_radius(c,r) ) 00600 return CUBIT_FAILURE; 00601 00602 for (int i = compGeom->num_entities() - 1; i > 0; i-- ) 00603 { 00604 CubitVector c2; 00605 double r2; 00606 if (!get_curve(i)->get_center_radius(c2,r2) || 00607 fabs(r - r2) > GEOMETRY_RESABS || 00608 (c2 - c).length_squared() > GEOMETRY_RESABS*GEOMETRY_RESABS) 00609 { 00610 return CUBIT_FAILURE; 00611 } 00612 } 00613 return CUBIT_SUCCESS; 00614 } 00615 00616 CubitBoolean CompositeCurve::G1_discontinuous( double param, 00617 CubitVector* minus_tangent, CubitVector* plus_tangent ) 00618 { 00619 if (num_curves() == 0) // point curve 00620 return CUBIT_FALSE; 00621 00622 const double half_resabs = CUBIT_RESABS / 2.0; 00623 double curve_param; 00624 int curve_index; 00625 CubitStatus s = this->curve_param( param, curve_param, curve_index ); 00626 if( ! s ) 00627 { 00628 PRINT_ERROR("Parameter %f out of range [%f,%f] in " 00629 "CompositeCurve::G1_discontinous(..)\n",param,start_param(),end_param()); 00630 return CUBIT_FALSE; 00631 } 00632 00633 CubitVector tan1, tan2, location, cp; 00634 CubitBoolean result = CUBIT_FALSE; 00635 if( (curve_index > 0) && 00636 (fabs(compGeom->measure(curve_index-1) - param) < half_resabs) ) 00637 { 00638 get_curve( curve_index )->position_from_u( curve_param, location ); 00639 get_curve( curve_index-1 )->closest_point( location, cp, &tan1 ); 00640 if( get_sense( curve_index-1 ) == CUBIT_REVERSED ) tan1 *= -1.0; 00641 get_curve( curve_index )->closest_point( location, cp, &tan2 ); 00642 if( get_sense( curve_index ) == CUBIT_REVERSED ) tan2 *= -1.0; 00643 double cross = (tan1 * tan2).length_squared(); 00644 double sum = (tan1 + tan2).length_squared(); 00645 double diff = (tan1 - tan2).length_squared(); 00646 if( (cross > CUBIT_RESABS) || (sum < diff) ) 00647 { 00648 if( minus_tangent ) *minus_tangent = tan1; 00649 if( plus_tangent ) *plus_tangent = tan2; 00650 result = CUBIT_TRUE; 00651 } 00652 else 00653 result = CUBIT_FALSE; 00654 00655 } 00656 else if( (curve_index < (compGeom->num_entities()-1)) && 00657 (fabs(compGeom->measure(curve_index) - param) < half_resabs) ) 00658 { 00659 get_curve( curve_index )->position_from_u( curve_param, location ); 00660 get_curve( curve_index )->closest_point( location, cp, &tan1 ); 00661 if( get_sense( curve_index ) == CUBIT_REVERSED ) tan1 *= -1.0; 00662 get_curve( curve_index+1 )->closest_point( location, cp, &tan2 ); 00663 if( get_sense( curve_index+1 ) == CUBIT_REVERSED ) tan2 *= -1.0; 00664 double cross = (tan1 * tan2).length_squared(); 00665 double sum = (tan1 + tan2).length_squared(); 00666 double diff = (tan1 - tan2).length_squared(); 00667 if( (cross > CUBIT_RESABS) || (sum < diff) ) 00668 { 00669 if( minus_tangent ) *minus_tangent = tan1; 00670 if( plus_tangent ) *plus_tangent = tan2; 00671 result = CUBIT_TRUE; 00672 } 00673 else 00674 result = CUBIT_FALSE; 00675 } 00676 else if( get_sense(curve_index) == CUBIT_FORWARD ) 00677 { 00678 result = get_curve( curve_index ) 00679 ->G1_discontinuous( curve_param, minus_tangent, plus_tangent ); 00680 } 00681 else 00682 { 00683 result = get_curve( curve_index ) 00684 ->G1_discontinuous( curve_param, plus_tangent, minus_tangent ); 00685 if( result ) 00686 { 00687 if( plus_tangent ) *plus_tangent *= -1.0; 00688 if( minus_tangent) *minus_tangent *= -1.0; 00689 } 00690 } 00691 return result; 00692 } 00693 00694 00695 int CompositeCurve::closest_curve( const CubitVector& location, 00696 CubitVector *point ) 00697 { 00698 double shortest_distance_sqr, current_distance_sqr; 00699 CubitVector closest_point, current_point; 00700 int closest_curve, current_curve; 00701 00702 closest_curve = compGeom->closest_box( location ); 00703 00704 get_curve( closest_curve )->closest_point_trimmed( location, closest_point ); 00705 shortest_distance_sqr = (location - closest_point).length_squared(); 00706 00707 while( ( current_curve = compGeom->next_box_within_dist( shortest_distance_sqr ) ) >= 0 ) 00708 { 00709 get_curve( current_curve )->closest_point_trimmed( location, current_point ); 00710 current_distance_sqr = (location - current_point).length_squared(); 00711 if( current_distance_sqr < shortest_distance_sqr ) 00712 { 00713 closest_curve = current_curve; 00714 shortest_distance_sqr = current_distance_sqr; 00715 closest_point = current_point; 00716 } 00717 } 00718 00719 if( point ) *point = closest_point; 00720 return closest_curve; 00721 } 00722 00723 00724 00725 //------------------------------------------------------------------------- 00726 // Purpose : Parameter Conversion 00727 // 00728 // Special Notes : 00729 // 00730 // Creator : Jason Kraftcheck 00731 // 00732 // Creation Date : 06/08/98 00733 //------------------------------------------------------------------------- 00734 double CompositeCurve::composite_param( int index, double u ) const 00735 { 00736 if( (index < 0) || (index >= compGeom->num_entities()) ) return -1.0; 00737 Curve* curve_ptr = get_curve( index ); 00738 double sum = lengthUntilI( index ); 00739 00740 double u_min, u_max; 00741 curve_ptr->get_param_range( u_min, u_max ); 00742 00743 CubitSense sense = this->get_sense(index); 00744 double root_param = (sense == CUBIT_FORWARD) ? u_min : u_max; 00745 double lfu = (root_param < u) ? 00746 curve_ptr->length_from_u( root_param, u ) : 00747 curve_ptr->length_from_u( u, root_param ); 00748 return sum + fabs( lfu ); 00749 } 00750 00751 00752 CubitStatus CompositeCurve::curve_param( double uc, double& ui, int& index ) const 00753 { 00754 double sum = 0.0, period; 00755 if( const_cast<CompositeCurve*>(this)->is_periodic(period) ) 00756 fixup_periodic_param( uc ); 00757 00758 int max = compGeom->num_entities(); 00759 int min = 0; 00760 index = max / 2; 00761 sum = lengthUntilI( max - 1); 00762 if( uc >= sum ) index = max - 1; 00763 else while( min != max ) 00764 { 00765 sum = lengthUntilI(index); 00766 if( sum > uc ) 00767 max = index; 00768 else if( lengthUntilI(index+1) > uc ) 00769 break; 00770 else 00771 min = index; 00772 00773 index = (min + max) / 2; 00774 } 00775 00776 if( index >= compGeom->num_entities() ) return CUBIT_FAILURE; 00777 00778 double start_param, end_param; 00779 get_curve(index)->get_param_range( start_param, end_param ); 00780 00781 double arc_len = uc - sum; 00782 if( get_sense(index) == CUBIT_REVERSED ) 00783 arc_len = get_curve(index)->measure() - arc_len; 00784 00785 ui = get_curve(index)->u_from_arc_length( start_param, arc_len ); 00786 return CUBIT_SUCCESS; 00787 } 00788 00789 00790 00791 00792 //------------------------------------------------------------------------- 00793 // Purpose : Calculate the sum of the lengths of curves 0 to i-1. 00794 // 00795 // Special Notes : 00796 // 00797 // Creator : Jason Kraftcheck 00798 // 00799 // Creation Date : 06/09/98 00800 //------------------------------------------------------------------------- 00801 double CompositeCurve::lengthUntilI( int i ) const 00802 { 00803 assert( i >= 0 && i < compGeom->num_entities() ); 00804 return ( i == 0 ) ? 0.0 : compGeom->measure(i - 1); 00805 } 00806 00807 //------------------------------------------------------------------------- 00808 // Purpose : TopologyBridge queries 00809 // 00810 // Special Notes : 00811 // 00812 // Creator : Jason Kraftcheck 00813 // 00814 // Creation Date : 03/04/02 00815 //------------------------------------------------------------------------- 00816 void CompositeCurve::get_parents_virt( DLIList<TopologyBridge*>& list ) 00817 { 00818 for( CompositeCoEdge* coedge = firstCoEdge; 00819 coedge != 0; 00820 coedge = coedge->nextOnCurve ) 00821 if (!dynamic_cast<HiddenEntitySet*>(coedge->owner())) 00822 list.append( coedge ); 00823 00824 if (stitchNext) 00825 stitchNext->get_parents_virt(list); 00826 } 00827 void CompositeCurve::get_children_virt( DLIList<TopologyBridge*>& list ) 00828 { 00829 CompositePoint* sp = start_point(); 00830 CompositePoint* ep = end_point(); 00831 00832 if( sp ) 00833 list.append( sp ); 00834 if( ep && ep != sp ) 00835 list.append( ep ); 00836 } 00837 00838 //------------------------------------------------------------------------- 00839 // Purpose : TBOwner methods 00840 // 00841 // Special Notes : 00842 // 00843 // Creator : Jason Kraftcheck 00844 // 00845 // Creation Date : 03/04/02 00846 //------------------------------------------------------------------------- 00847 CubitStatus CompositeCurve::remove_bridge( TopologyBridge* bridge ) 00848 { 00849 int i = compGeom->index_of(bridge); 00850 if ( i >= 0 ) 00851 { 00852 bridge->owner(0); 00853 if ( !compGeom->remove(i,true) ) 00854 return CUBIT_FAILURE; 00855 00856 if (compGeom->num_entities() == 0) 00857 CompositeEngine::instance().notify_deactivated(this); 00858 HadBridgeRemoved = 1; 00859 return CUBIT_SUCCESS; 00860 } 00861 else 00862 { 00863 for (CompositeCurve* ptr = this; ptr->stitchNext; ptr = ptr->stitchNext) 00864 { 00865 if (ptr->stitchNext == bridge) 00866 { 00867 ptr->stitchNext = ((CompositeCurve*)bridge)->stitchNext; 00868 HadBridgeRemoved = 1; 00869 return CUBIT_SUCCESS; 00870 } 00871 } 00872 } 00873 00874 return CUBIT_FAILURE; 00875 } 00876 00877 Curve* CompositeCurve::remove_curve( int index ) 00878 { 00879 Curve* curve = get_curve(index); 00880 if (!curve || !compGeom->remove(index,false) ) 00881 return 0; 00882 curve->owner(0); 00883 return curve; 00884 } 00885 00886 00887 00888 CubitStatus CompositeCurve::swap_bridge( TopologyBridge* o, 00889 TopologyBridge* n, 00890 bool reversed ) 00891 { 00892 int i = compGeom->index_of(o); 00893 GeometryEntity* ge = dynamic_cast<GeometryEntity*>(n); 00894 if( i >= 0 && ge != 0 ) 00895 { 00896 o->owner(0); 00897 n->owner(this); 00898 if ( ! compGeom->swap( i, ge ) ) 00899 return CUBIT_FAILURE; 00900 00901 if (reversed) 00902 compGeom->reverse_sense(i); 00903 return CUBIT_SUCCESS; 00904 } 00905 else 00906 return CUBIT_FAILURE; 00907 } 00908 CubitBoolean CompositeCurve::contains_bridge( TopologyBridge* bridge ) const 00909 { 00910 if (!compGeom) 00911 return CUBIT_FALSE; 00912 00913 return (CubitBoolean)(compGeom->index_of(bridge) >= 0); 00914 } 00915 00916 00917 //------------------------------------------------------------------------- 00918 // Purpose : Attach a CubitSimpleAttribute 00919 // 00920 // Special Notes : 00921 // 00922 // Creator : Jason Kraftcheck 00923 // 00924 // Creation Date : 03/10/98 00925 //------------------------------------------------------------------------- 00926 void CompositeCurve::append_simple_attribute_virt( 00927 const CubitSimpleAttrib& simple_attrib_ptr ) 00928 { 00929 if(compGeom) 00930 compGeom->add_attribute( simple_attrib_ptr ); 00931 } 00932 00933 //------------------------------------------------------------------------- 00934 // Purpose : Remove an attached CubitSimpleAttrib 00935 // 00936 // Special Notes : 00937 // 00938 // Creator : Jason Kraftcheck 00939 // 00940 // Creation Date : 03/10/98 00941 //------------------------------------------------------------------------- 00942 void CompositeCurve::remove_simple_attribute_virt( 00943 const CubitSimpleAttrib& simple_attrib_ptr ) 00944 { 00945 if(compGeom) 00946 compGeom->rem_attribute( simple_attrib_ptr ); 00947 } 00948 00949 00950 //------------------------------------------------------------------------- 00951 // Purpose : Remove an all attached CubitSimpleAttrib 00952 // 00953 // Special Notes : 00954 // 00955 // Creator : Greg Nielson 00956 // 00957 // Creation Date : 07/10/98 00958 //------------------------------------------------------------------------- 00959 void CompositeCurve::remove_all_simple_attribute_virt() 00960 { 00961 if(compGeom) 00962 compGeom->rem_all_attributes( ); 00963 } 00964 00965 00966 //------------------------------------------------------------------------- 00967 // Purpose : Return the attached CubitSimpleAttribs. 00968 // 00969 // Special Notes : 00970 // 00971 // Creator : Jason Kraftcheck 00972 // 00973 // Creation Date : 03/10/98 00974 //------------------------------------------------------------------------- 00975 CubitStatus CompositeCurve::get_simple_attribute( 00976 DLIList<CubitSimpleAttrib>& attrib_list ) 00977 { 00978 if(!compGeom) 00979 return CUBIT_FAILURE; 00980 compGeom->get_attributes( attrib_list ); 00981 return CUBIT_SUCCESS; 00982 } 00983 00984 00985 00986 //------------------------------------------------------------------------- 00987 // Purpose : Get attribs by name 00988 // 00989 // Special Notes : 00990 // 00991 // Creator : Jason Kraftcheck 00992 // 00993 // Creation Date : 03/03/03 00994 //------------------------------------------------------------------------- 00995 CubitStatus CompositeCurve::get_simple_attribute( 00996 const CubitString& name, DLIList<CubitSimpleAttrib>& attrib_list ) 00997 { 00998 if(!compGeom) 00999 return CUBIT_FAILURE; 01000 compGeom->get_attributes( name.c_str(), attrib_list ); 01001 return CUBIT_SUCCESS; 01002 } 01003 01004 void CompositeCurve::fixup_periodic_param( double& param ) const 01005 { 01006 if(!compGeom) 01007 return; 01008 double period = compGeom->measure(); 01009 if( param < 0.0 ) 01010 param = period - param; 01011 if( param >= period ) 01012 param = fmod( param, period ); 01013 } 01014 01015 //------------------------------------------------------------------------- 01016 // Purpose : Write attributes to underlying geometry entity 01017 // 01018 // Special Notes : Special case for point-curves 01019 // 01020 // Creator : Jason Kraftcheck 01021 // 01022 // Creation Date : 02/28/04 01023 //------------------------------------------------------------------------- 01024 void CompositeCurve::write_attributes() 01025 { 01026 if (num_curves()) // not a point-curve 01027 { 01028 compGeom->write_attributes(); 01029 } 01030 else 01031 { 01032 CompositePoint* point = start_point(); 01033 assert(point == end_point()); 01034 compGeom->write_attributes(point); 01035 } 01036 } 01037 01038 //------------------------------------------------------------------------- 01039 // Purpose : Read attributes from underlying geometry 01040 // 01041 // Special Notes : 01042 // 01043 // Creator : Jason Kraftcheck 01044 // 01045 // Creation Date : 02/28/04 01046 //------------------------------------------------------------------------- 01047 void CompositeCurve::read_attributes() 01048 { 01049 if (num_curves()) // not a point-curve 01050 { 01051 compGeom->read_attributes(); 01052 } 01053 else 01054 { 01055 CompositePoint* point = start_point(); 01056 assert(point == end_point()); 01057 compGeom->read_attributes(point); 01058 } 01059 } 01060 01061 01062 void CompositeCurve::get_hidden_points( DLIList<TBPoint*>& points ) 01063 { 01064 if( hiddenSet ) 01065 { 01066 hiddenSet->hidden_points( points ); 01067 } 01068 } 01069 01070 01071 01072 void CompositeCurve::print_debug_info( const char* prefix, 01073 bool brief ) const 01074 { 01075 if( prefix == 0 ) prefix = ""; 01076 01077 if ( brief ) 01078 { 01079 #ifdef TOPOLOGY_BRIDGE_IDS 01080 PRINT_INFO("%sCompositeCurve %d : points (%d,%d) ", prefix, get_id(), 01081 startPoint ? startPoint->get_id() : -1, endPoint ? endPoint->get_id() : -1 ); 01082 if ( num_curves() == 1 ) 01083 PRINT_INFO(": %s %d\n", fix_type_name(typeid(*get_curve(0)).name()), get_curve(0)->get_id()); 01084 else 01085 PRINT_INFO(": %d curves.\n", num_curves() ); 01086 #else 01087 PRINT_INFO("%sCompositeCurve %p : points (%p,%p) ", prefix, (void*)this, 01088 (void*)startPoint, (void*)endPoint ); 01089 if ( num_curves() == 1 ) 01090 PRINT_INFO(": %s %p\n", fix_type_name(typeid(*get_curve(0)).name()), (void*)get_curve(0)); 01091 else 01092 PRINT_INFO(": %d curves.\n", num_curves() ); 01093 #endif 01094 return; 01095 } 01096 01097 char* new_prefix = new char[strlen(prefix)+3]; 01098 strcpy( new_prefix, prefix ); 01099 strcat( new_prefix, " "); 01100 01101 #ifdef TOPOLOGY_BRIDGE_IDS 01102 PRINT_INFO("%sCompositeCurve %d\n", prefix, get_id() ); 01103 #else 01104 PRINT_INFO("%sCompositeCurve %p\n", prefix, (void*)this ); 01105 #endif 01106 compGeom->print_debug_info( new_prefix ); 01107 if( hiddenSet ) hiddenSet->print_debug_info( new_prefix ); 01108 else PRINT_INFO("%s No Hidden Entities.\n", prefix ); 01109 01110 CompositeCoEdge* coedge = first_coedge(); 01111 DLIList<TopologyBridge*> loops(1), surface_list(1); 01112 01113 while( coedge ) 01114 { 01115 TopologyBridge* surf_ptr = 0; 01116 loops.clean_out(); 01117 surface_list.clean_out(); 01118 coedge->get_parents_virt(loops); 01119 if ( loops.size() == 1 ) 01120 { 01121 loops.get()->get_parents_virt(surface_list); 01122 if( surface_list.size() == 1 ) 01123 surf_ptr = surface_list.get(); 01124 } 01125 01126 #ifdef TOPOLOGY_BRIDGE_IDS 01127 PRINT_INFO("%s %s on Surface %d\n", prefix, 01128 coedge->sense() == CUBIT_FORWARD ? "FORWARD" : 01129 coedge->sense() == CUBIT_REVERSED ? "REVERSE" : "UNKNOWN", 01130 surf_ptr->get_id() ); 01131 #else 01132 PRINT_INFO("%s %s on Surface %p\n", prefix, 01133 coedge->sense() == CUBIT_FORWARD ? "FORWARD" : 01134 coedge->sense() == CUBIT_REVERSED ? "REVERSE" : "UNKNOWN", 01135 (void*)surf_ptr ); 01136 #endif 01137 01138 if (!coedge->get_loop()) 01139 coedge->print_debug_info( new_prefix, true ); 01140 coedge = next_coedge(coedge); 01141 } 01142 01143 if ( !start_point() ) 01144 PRINT_INFO("%s NULL START POINT\n", prefix ); 01145 else 01146 start_point()->print_debug_info( new_prefix, true ); 01147 01148 if ( !end_point() ) 01149 PRINT_INFO("%s NULL END POINT\n", prefix ); 01150 else if ( end_point() == start_point() ) 01151 PRINT_INFO("%s end point SAME as start point\n", prefix ); 01152 else 01153 end_point()->print_debug_info( new_prefix, true ); 01154 01155 delete [] new_prefix; 01156 } 01157 01158 01159 //------------------------------------------------------------------------- 01160 // Purpose : Update composite for change in sense of underlying curve 01161 // 01162 // Special Notes : 01163 // 01164 // Creator : Jason Kraftcheck 01165 // 01166 // Creation Date : 01167 //------------------------------------------------------------------------- 01168 void CompositeCurve::notify_reversed( TopologyBridge* bridge ) 01169 { 01170 int index = compGeom->index_of(bridge); 01171 if( index >= 0 ) 01172 compGeom->reverse_sense(index); 01173 } 01174 01175 //------------------------------------------------------------------------- 01176 // Purpose : Merge 01177 // 01178 // Special Notes : 01179 // 01180 // Creator : Jason Kraftcheck 01181 // 01182 // Creation Date : 12/02/02 01183 //------------------------------------------------------------------------- 01184 CubitStatus CompositeCurve::stitch( CompositeCurve* dead ) 01185 { 01186 // check to make sure end points are already stitched. 01187 bool reversed; 01188 01189 if( dead->start_point() == this->start_point() ) 01190 reversed = false; 01191 else if( dead->end_point() == this->start_point() ) 01192 reversed = true; 01193 else 01194 return CUBIT_FAILURE; 01195 01196 if( ( reversed && (dead->start_point() != this->end_point())) || 01197 (!reversed && (dead->end_point() != this->end_point())) ) 01198 return CUBIT_FAILURE; 01199 01200 // shouldn't be merging hidden curves 01201 if( dynamic_cast<CompositeCurve*>(this->owner()) || 01202 dynamic_cast<CompositeCurve*>(dead->owner()) ) 01203 { 01204 assert(0); 01205 return CUBIT_FAILURE; 01206 } 01207 01208 // DAG / next level up should already be merged 01209 if( dead->owner() != this->owner() ) 01210 { 01211 assert(0); 01212 return CUBIT_FAILURE; 01213 } 01214 01215 // update owner 01216 if( dead->owner() ) 01217 dead->owner()->notify_merged( dead, this ); 01218 assert( !dead->owner() ); 01219 dead->owner( this ); 01220 01221 // merge lists 01222 CompositeCurve* end = dead; 01223 while (end->stitchNext) 01224 { 01225 end->stitchNext->owner( this ); 01226 end = end->stitchNext; 01227 } 01228 end->stitchNext = stitchNext; 01229 stitchNext = end; 01230 01231 return CUBIT_SUCCESS; 01232 } 01233 01234 //------------------------------------------------------------------------- 01235 // Purpose : Get the visible curve of a set of stitched curves 01236 // 01237 // Special Notes : 01238 // 01239 // Creator : Jason Kraftcheck 01240 // 01241 // Creation Date : 12/02/02 01242 //------------------------------------------------------------------------- 01243 CompositeCurve* CompositeCurve::primary_stitched_curve() 01244 { 01245 CompositeCurve* result = dynamic_cast<CompositeCurve*>(owner()); 01246 return result ? result : this; 01247 } 01248 01249 //------------------------------------------------------------------------- 01250 // Purpose : Is this curve stitched with any others 01251 // 01252 // Special Notes : 01253 // 01254 // Creator : Jason Kraftcheck 01255 // 01256 // Creation Date : 12/02/02 01257 //------------------------------------------------------------------------- 01258 bool CompositeCurve::is_stitched() 01259 { 01260 return stitchNext || dynamic_cast<CompositeCurve*>(owner()); 01261 } 01262 01263 //------------------------------------------------------------------------- 01264 // Purpose : Get list of stitched curves 01265 // 01266 // Special Notes : 01267 // 01268 // Creator : Jason Kraftcheck 01269 // 01270 // Creation Date : 12/16/02 01271 //------------------------------------------------------------------------- 01272 void CompositeCurve::get_stitched( DLIList<CompositeCurve*>& list ) 01273 { 01274 for (CompositeCurve* curve = primary_stitched_curve(); 01275 curve; curve = curve->stitchNext) 01276 list.append( curve ); 01277 } 01278 01279 //------------------------------------------------------------------------- 01280 // Purpose : Remove all stitched curves 01281 // 01282 // Special Notes : 01283 // 01284 // Creator : Jason Kraftcheck 01285 // 01286 // Creation Date : 12/02/02 01287 //------------------------------------------------------------------------- 01288 void CompositeCurve::unstitch_all() 01289 { 01290 // should only call on visible curve 01291 assert (this == primary_stitched_curve()); 01292 01293 while (stitchNext) 01294 { 01295 stitchNext->owner(0); 01296 if (owner()) 01297 owner()->notify_copied( stitchNext, this ); 01298 stitchNext = stitchNext->stitchNext; 01299 } 01300 } 01301 01302 01303 //------------------------------------------------------------------------- 01304 // Purpose : Update for split in underlying curve 01305 // 01306 // Special Notes : 01307 // 01308 // Creator : Jason Kraftcheck 01309 // 01310 // Creation Date : 12/19/02 01311 //------------------------------------------------------------------------- 01312 void CompositeCurve::notify_split( TopologyBridge* new_bridge, 01313 TopologyBridge* old_bridge ) 01314 { 01315 Curve* old_curve = dynamic_cast<Curve*>(old_bridge); 01316 Curve* new_curve = dynamic_cast<Curve*>(new_bridge); 01317 assert( old_curve && new_curve && index_of(old_curve) >= 0 ); 01318 01319 // get start and end points 01320 DLIList<TopologyBridge*> bridges; 01321 old_curve->get_children(bridges,true,old_curve->layer()); 01322 bridges.reset(); 01323 TBPoint* old_start = dynamic_cast<TBPoint*>(bridges.get()); 01324 TBPoint* old_end = dynamic_cast<TBPoint*>(bridges.next()); 01325 bridges.clean_out(); 01326 new_curve->get_children(bridges,true,new_curve->layer()); 01327 TBPoint* new_start = dynamic_cast<TBPoint*>(bridges.get()); 01328 TBPoint* new_end = dynamic_cast<TBPoint*>(bridges.next()); 01329 bridges.clean_out(); 01330 01331 01332 // find new point 01333 bool sp = (new_start == old_start || new_start == old_end); 01334 #ifndef NDEBUG 01335 bool ep = (new_end == old_start || new_end == old_end); 01336 assert( ep != sp ); // one must be true and one must be false 01337 #endif 01338 TBPoint* new_pt = sp ? new_start : new_end; 01339 01340 // find relative sense of curves 01341 int old_index = index_of(old_curve); 01342 bool is_start = (old_start == new_pt); 01343 bool is_forward = (get_sense(old_index) == CUBIT_FORWARD); 01344 bool prepend = (is_start == is_forward); 01345 is_start = (new_start == new_pt); 01346 assert( is_start || new_pt == new_end ); 01347 bool reversed = (is_start == prepend); 01348 01349 CompositePoint* new_cpt = new CompositePoint(new_pt); 01350 01351 hidden_entities().hide(new_cpt); 01352 01353 CubitSense new_sense = reversed ? CUBIT_REVERSED : CUBIT_FORWARD; 01354 int insert_index = old_index; 01355 if( !prepend ) insert_index++; 01356 if( ! compGeom->insert( insert_index, new_curve, new_sense ) ) 01357 { 01358 assert(0); 01359 delete new_cpt; 01360 return; 01361 } 01362 new_curve->owner(this); 01363 01364 DLIList<CoEdgeSM*> new_coedges, old_coedges; 01365 bridges.clean_out(); 01366 new_curve->get_parents_virt( bridges ); 01367 CAST_LIST( bridges, new_coedges, CoEdgeSM ); 01368 assert(bridges.size() == new_coedges.size()); 01369 bridges.clean_out(); 01370 old_curve->get_parents_virt( bridges ); 01371 CAST_LIST( bridges, old_coedges, CoEdgeSM ); 01372 assert(bridges.size() == old_coedges.size()); 01373 01374 for( CompositeCoEdge* coedge = first_coedge(); 01375 coedge; 01376 coedge = next_coedge(coedge) ) 01377 { 01378 // for each coedge of the old curve 01379 int i; 01380 CoEdgeSM* old_coedge = 0; 01381 for( i = 0; i < coedge->num_coedges(); i++ ) 01382 { 01383 old_coedge = coedge->get_coedge(i); 01384 if( old_coedges.is_in_list(old_coedge) ) 01385 break; 01386 } 01387 assert(i < coedge->num_coedges() && old_coedge); 01388 01389 bridges.clean_out(); 01390 old_coedge->get_parents_virt(bridges); 01391 assert(bridges.size() == 1); 01392 LoopSM* loopsm = dynamic_cast<LoopSM*>(bridges.get()); 01393 assert(0 != loopsm); 01394 01395 bridges.clean_out(); 01396 loopsm->get_children(bridges, true, old_curve->layer()); 01397 bridges.move_to(old_coedge); 01398 assert(bridges.get() == old_coedge); 01399 01400 // Determine if new_coedge (the one we are looking for) 01401 // should occur before or after old_coedge in the loop. 01402 // If new_curve is after old_curve (old_end == new_pt), 01403 // then the we want the coedge after old_coedge iff the 01404 // sense of old_coedge is forward, otherwise the one before. 01405 // Invert that if new_curve is before old_curve (old_start 01406 // == new_pt). 01407 bool coe_reversed = (old_coedge->sense() == CUBIT_REVERSED); 01408 bool curve_prepend = (old_start == new_pt); 01409 bool previous = coe_reversed != curve_prepend; 01410 CoEdgeSM* new_coedge = 01411 dynamic_cast<CoEdgeSM*>(previous ? bridges.prev() : bridges.next()); 01412 assert(new_coedges.is_in_list(new_coedge)); 01413 01414 CubitStatus s = coedge->insert_coedge(insert_index, new_coedge); 01415 assert(s); 01416 if (CUBIT_SUCCESS != s) { 01417 PRINT_ERROR("Failed to insert a new coedge.\n"); 01418 return; 01419 } 01420 } 01421 } 01422 01423 CubitStatus CompositeCurve::get_spline_params 01424 ( 01425 bool &rational, // return true/false 01426 int °ree, // the degree of this spline 01427 DLIList<CubitVector> &cntrl_pts, // xyz position of controlpoints 01428 DLIList<double> &cntrl_pt_weights, // if rational, a weight for each cntrl point. 01429 DLIList<double> &knots, // There should be order+cntrl_pts.size()-2 knots 01430 bool &spline_is_reversed 01431 ) const 01432 { 01433 PRINT_ERROR("Currently, Cubit is unable to determine spline parameters for CompositeCurves.\n"); 01434 return CUBIT_FAILURE; 01435 } 01436 01437 CubitStatus CompositeCurve::get_ellipse_params 01438 ( 01439 CubitVector ¢er_vec, 01440 CubitVector &normal, 01441 CubitVector &major_axis, 01442 double &radius_ratio 01443 ) const 01444 { 01445 PRINT_ERROR("Currently, Cubit is unable to determine ellipse parameters for CompositeCurves.\n"); 01446 return CUBIT_FAILURE; 01447 } 01448 01449 /* 01450 void CompositeCurve::draw( int color ) 01451 { 01452 int num_pts; 01453 GMem gmem; 01454 01455 if (!VirtualQueryEngine::instance()->get_graphics(this, num_pts, &gmem)) 01456 return; 01457 01458 GfxDebug::draw_polyline( gmem.point_list(), 01459 gmem.pointListCount, 01460 color ); 01461 GfxDebug::flush(); 01462 } 01463 */
