cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : PartitionCurve-new.hpp 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 04/10/02 00011 //------------------------------------------------------------------------- 00012 #ifndef PARTITION_CURVE_HPP 00013 #define PARTITION_CURVE_HPP 00014 00015 #include "Curve.hpp" 00016 #include "PartitionPoint.hpp" 00017 #include "PartitionCoEdge.hpp" 00018 00019 class PartitionPoint; 00020 class PartitionSurface; 00021 class GMem; 00022 class CubitFacetEdgeData; 00023 00024 class PartitionCurve : public Curve, public PartitionEntity 00025 { 00026 00027 public: 00028 00029 virtual PartitionCurve* split( double param ) = 0; 00030 00031 virtual CubitStatus combine( PartitionCurve* dead_curve ) = 0; 00032 00033 virtual ~PartitionCurve(); 00034 00035 PartitionPoint* start_point() const 00036 { return startPoint; } 00037 00038 PartitionPoint* end_point() const 00039 { return endPoint; } 00040 00041 PartitionPoint* other_point( const PartitionPoint* pt ) const 00042 { return pt == startPoint ? endPoint : pt == endPoint ? startPoint : 0; } 00043 00044 int num_coedges() const; 00045 00046 PartitionCoEdge* next_coedge( const PartitionCoEdge* prev = 0 ) const 00047 { return !prev ? firstCoEdge : prev->myCurve == this ? prev->curveNext : 0; } 00048 00049 CubitStatus add( PartitionCoEdge* coedge ); 00050 CubitStatus remove( PartitionCoEdge* coedge ); 00051 void remove_all_coedges(); 00052 00053 CubitStatus start_point( PartitionPoint* point ); 00054 CubitStatus end_point ( PartitionPoint* point ); 00055 00056 virtual CubitStatus get_graphics( GMem& result, 00057 double angle_tolerance=0, 00058 double distance_tolerance=0, 00059 double max_edge_length=0) = 0; 00060 00061 PartitionCurve* next_curve( const PartitionPoint* about_this ) const 00062 { return about_this == startPoint ? startNext : 00063 about_this == endPoint ? endNext : 0; } 00064 00065 bool is_nonmanifold( const PartitionSurface* in_this_surf ) const; 00066 bool is_in_surface( const PartitionSurface* surf, 00067 bool manifold_only = false ) const; 00068 00069 CubitStatus move_to_geometry( CubitVector& position ); 00070 CubitStatus move_to_geometry( CubitPoint* facetPoint ); 00071 00072 void append_simple_attribute_virt( const CubitSimpleAttrib& ); 00073 void remove_simple_attribute_virt( const CubitSimpleAttrib& ); 00074 void remove_all_simple_attribute_virt(); 00075 CubitStatus get_simple_attribute( DLIList<CubitSimpleAttrib>& ); 00076 CubitStatus get_simple_attribute( const CubitString& name, 00077 DLIList<CubitSimpleAttrib>& ); 00078 00079 void get_parents_virt( DLIList<TopologyBridge*>& ); 00080 void get_children_virt( DLIList<TopologyBridge*>& ); 00081 int layer() const { return sub_entity_set().get_owner_layer(); } 00082 GeometryQueryEngine* get_geometry_query_engine() const; 00083 00084 00085 virtual void print_debug_info( const char* prefix = 0, 00086 bool print_subentity_set = true ) const; 00087 00088 00089 void get_facet_data( DLIList<CubitFacetEdgeData*>& result_list ) const; 00090 void set_facet_data( const DLIList<CubitFacetEdgeData*>& new_list ); 00091 bool has_facet_data() const { return facetEdges.size() > 0; } 00092 void remove_facet_data(); 00093 void replace_facet(CubitFacetEdgeData* dead_facet, 00094 DLIList<CubitFacetEdgeData*> &new_facets); 00095 virtual void notify_split( FacetEntity* old_entity, FacetEntity* new_entity ); 00096 CubitStatus fix_facet_data( PartitionCurve* new_curve ); 00097 void remove_dead_facet( CubitFacetEdgeData* edge ); 00098 //- update facet data for curve partition operation 00099 //- must be called after end points have been updated. 00100 00101 void do_facet_cleanup(); 00102 //- remove small edges, etc. 00103 00104 void draw_facets(int color); 00105 00106 virtual void transform( const CubitTransformMatrix& ); 00107 00108 protected: 00109 00110 PartitionCurve( ); 00111 00112 CubitStatus get_save_topology( DLIList<int>& points ); 00113 00114 void reverse_point_order(); 00115 00116 private: 00117 00118 DLIList<CubitFacetEdgeData*> facetEdges; 00119 00120 CubitStatus remove_start_point(); 00121 CubitStatus remove_end_point(); 00122 CubitStatus remove_from_point( PartitionPoint* point, PartitionCurve* next ); 00123 00124 PartitionCoEdge* firstCoEdge; 00125 00126 PartitionPoint *startPoint, *endPoint; 00127 PartitionCurve *startNext, *endNext; 00128 }; 00129 00130 #endif 00131 00132 00133
