cgma
00001 //------------------------------------------------------------------ 00002 //Class: VirtualImprintTool 00003 //Description: Provides functionality and interface to imprinting 00004 // topology through virtual geometry and faceted booleans. 00005 //Author: David R. White 00006 //Date: 2/15/2002 00007 //------------------------------------------------------------------ 00008 00009 #include "VirtualImprintTool.hpp" 00010 #include "RefFace.hpp" 00011 #include "RefVolume.hpp" 00012 #include "CubitMessage.hpp" 00013 #include "CubitBox.hpp" 00014 #include "RTree.hpp" 00015 #include "ImprintBoundaryTool.hpp" 00016 #include "AppUtil.hpp" 00017 00018 CubitBoolean VirtualImprintTool::useRealIntersection = CUBIT_FALSE; 00019 00020 //------------------------------------------------------------------- 00021 // Constructor 00022 //------------------------------------------------------------------- 00023 VirtualImprintTool::VirtualImprintTool() 00024 { 00025 } 00026 //------------------------------------------------------------------- 00027 // Destructor 00028 //------------------------------------------------------------------- 00029 VirtualImprintTool::~VirtualImprintTool() 00030 {} 00031 00032 //-------------------------------------------------------------------- 00033 // virtual_imprint 00034 // Does the imprinting between two surfaces... 00035 //-------------------------------------------------------------------- 00036 CubitStatus VirtualImprintTool::virtual_imprint(RefFace *ref_face1, 00037 RefFace *ref_face2, 00038 DLIList <RefFace*> &results, 00039 double feature_size, 00040 CubitBoolean &curves_modified) 00041 { 00042 if ( useRealIntersection ) 00043 { 00044 /* SurfaceImprintTool imp_tool(feature_size); 00045 CubitStatus stat = imp_tool.imprint_surface(ref_face1, ref_face2, results); 00046 if (stat != CUBIT_SUCCESS ) 00047 return stat; 00048 curves_modified = imp_tool.curves_modified(); 00049 return CUBIT_SUCCESS; 00050 */ 00051 return CUBIT_FAILURE; 00052 } 00053 else 00054 { 00055 ImprintBoundaryTool ib_tool(ref_face1, ref_face2, feature_size); 00056 CubitStatus stat=ib_tool.imprint(results, CUBIT_FALSE); 00057 if (stat != CUBIT_SUCCESS ) 00058 return stat; 00059 if ( ib_tool.modified_bound_1() || ib_tool.modified_bound_2() ) 00060 curves_modified = CUBIT_TRUE; 00061 return CUBIT_SUCCESS; 00062 } 00063 } 00064 //-------------------------------------------------------------------- 00065 // virtual_imprint 00066 // Does the imprinting between multiple surfaces 00067 //-------------------------------------------------------------------- 00068 CubitStatus VirtualImprintTool::virtual_imprint(DLIList <RefFace*> &input_faces, 00069 DLIList <RefFace*> &surf_results, 00070 double feature_size, 00071 CubitBoolean &curves_modified) 00072 { 00073 int ii, jj; 00074 //Do the n^2 thing, imprint every volume against every other volume... 00075 DLIList <RefFace*> faces_stack = input_faces, ref_faces_close, tmp_results; 00076 RefFace *curr_face, *canidate_face; 00077 while ( faces_stack.size() > 0 ) 00078 { 00079 curr_face = faces_stack.pop(); 00080 curr_face->marked(1); 00081 ref_faces_close.clean_out(); 00082 CubitBox curr_box = curr_face->bounding_box(); 00083 for ( jj = input_faces.size(); jj > 0; jj-- ) 00084 { 00085 canidate_face = input_faces.get_and_step(); 00086 if ( canidate_face == curr_face || canidate_face->marked() ) 00087 continue; 00088 CubitBox canidate_box = canidate_face->bounding_box(); 00089 if ( curr_box.overlap(feature_size, canidate_box) ) 00090 ref_faces_close.append(canidate_face); 00091 } 00092 for ( jj = ref_faces_close.size(); jj > 0; jj-- ) 00093 { 00094 //check for interrupt. 00095 if ( AppUtil::instance()->interrupt() ) 00096 { 00097 break; 00098 } 00099 00100 tmp_results.clean_out(); 00101 canidate_face = ref_faces_close.get_and_step(); 00102 PRINT_INFO("Imprint Surfaces: %d %d\n", curr_face->id(), canidate_face->id() ); 00103 CubitStatus stat = virtual_imprint(curr_face, canidate_face, 00104 tmp_results, feature_size, 00105 curves_modified); 00106 if ( stat != CUBIT_SUCCESS ) 00107 { 00108 PRINT_ERROR("Problems imprinting Surface %d and %d\n", 00109 curr_face->id(), canidate_face->id()); 00110 return stat; 00111 } 00112 if ( tmp_results.size() ) 00113 { 00114 faces_stack.remove(canidate_face); 00115 input_faces.remove(curr_face); 00116 input_faces.remove(canidate_face); 00117 int ll; 00118 for ( ll = tmp_results.size(); ll > 0; ll-- ) 00119 { 00120 canidate_face = tmp_results.get_and_step(); 00121 canidate_face->marked(0); 00122 faces_stack.append(canidate_face); 00123 input_faces.append(canidate_face); 00124 } 00125 surf_results += tmp_results; 00126 break; 00127 } 00128 } 00129 //check for interrupt. 00130 if ( AppUtil::instance()->interrupt() ) 00131 { 00132 //just break out and still clean up marks and stuff... 00133 break; 00134 } 00135 } 00136 for ( ii = 0; ii < surf_results.size(); ii++ ) 00137 surf_results.get_and_step()->marked(0); 00138 DLIList <RefFace*> tmp_list; 00139 for ( ii = 0; ii < surf_results.size(); ii++ ) 00140 { 00141 curr_face = surf_results.get_and_step(); 00142 if ( curr_face->marked() ) 00143 continue; 00144 else 00145 { 00146 tmp_list.append(curr_face); 00147 curr_face->marked(1); 00148 } 00149 } 00150 surf_results.clean_out(); 00151 for ( ii = 0; ii < tmp_list.size(); ii++ ) 00152 { 00153 curr_face = tmp_list.get_and_step(); 00154 curr_face->marked(0); 00155 surf_results.append(curr_face); 00156 } 00157 return CUBIT_SUCCESS; 00158 } 00159 00160 00161 CubitStatus VirtualImprintTool::virtual_imprint(RefVolume *ref_volume1, 00162 RefVolume *ref_volume2, 00163 DLIList <RefVolume*> &vol_results, 00164 double feature_size, 00165 CubitBoolean &curves_modified) 00166 { 00167 CubitBoolean ref_1_mod=CUBIT_FALSE, ref_2_mod = CUBIT_FALSE; 00168 curves_modified = CUBIT_FALSE; 00169 //First make sure the bounding boxes are close... 00170 CubitBox ref_vol1_box = ref_volume1->bounding_box(); 00171 CubitBox ref_vol2_box = ref_volume2->bounding_box(); 00172 if ( !ref_vol1_box.overlap(feature_size, ref_vol2_box) ) 00173 return CUBIT_SUCCESS; 00174 00175 //Now get the list of surfaces for imprinting. 00176 DLIList <RefFace*> ref_faces1, ref_faces2, ref_faces_close; 00177 DLIList <RefFace*> faces1_stack, tmp_faces1,tmp_faces2, tmp_output; 00178 DLIList <RefVolume*> tmp_vols; 00179 RefFace *curr_ref_face, *canidate_ref_face; 00180 ref_volume1->ref_faces(ref_faces1); 00181 ref_volume2->ref_faces(ref_faces2); 00182 int ii, jj; 00183 CubitStatus stat; 00184 //loop over the the ref_faces from the first list. 00185 //Get all the reffaces that are within tolerance of its 00186 //bounding box. 00187 for ( ii = ref_faces1.size(); ii > 0; ii-- ) 00188 { 00189 curr_ref_face = ref_faces1.get_and_step(); 00190 CubitBox curr_box = curr_ref_face->bounding_box(); 00191 ref_faces_close.clean_out(); 00192 //do this everytime to get the most up-to-date ones... 00193 ref_faces2.clean_out(); 00194 ref_volume2->ref_faces(ref_faces2); 00195 for ( jj = ref_faces2.size(); jj > 0; jj-- ) 00196 { 00197 canidate_ref_face = ref_faces2.get_and_step(); 00198 CubitBox canidate_box = canidate_ref_face->bounding_box(); 00199 if ( curr_box.overlap(feature_size, canidate_box) ) 00200 ref_faces_close.append(canidate_ref_face); 00201 } 00202 //Now imprint the faces that are close with the curr_ref_face. 00203 faces1_stack.clean_out(); 00204 faces1_stack.append( curr_ref_face); 00205 while( faces1_stack.size() && (curr_ref_face = faces1_stack.pop()) != NULL && 00206 ref_faces_close.size() > 0 ) 00207 { 00208 if ( AppUtil::instance()->interrupt() ) 00209 { 00210 //just break out and still clean up marks and stuff... 00211 break; 00212 } 00213 while (ref_faces_close.size() && (canidate_ref_face = ref_faces_close.pop()) != NULL ) 00214 { 00215 tmp_output.clean_out(); 00216 stat = virtual_imprint(curr_ref_face,canidate_ref_face, 00217 tmp_output, feature_size, curves_modified ); 00218 if ( stat != CUBIT_SUCCESS ) 00219 return stat; 00220 //check for interrupt. 00221 if ( AppUtil::instance()->interrupt() ) 00222 { 00223 //just break out and still clean up marks and stuff... 00224 break; 00225 } 00226 //Now sort the faces in tmp_output into two lists associated 00227 //with the owning volumes... 00228 for ( jj = tmp_output.size(); jj > 0;jj-- ) 00229 { 00230 RefFace *ref_face = tmp_output.get_and_step(); 00231 tmp_vols.clean_out(); 00232 ref_face->ref_volumes(tmp_vols); 00233 if ( tmp_vols.move_to(ref_volume1) ) 00234 { 00235 ref_1_mod = CUBIT_TRUE; 00236 tmp_faces1.append(ref_face); 00237 } 00238 else 00239 { 00240 ref_2_mod = CUBIT_TRUE; 00241 tmp_faces2.append(ref_face); 00242 } 00243 } 00244 if ( tmp_faces1.size() > 0 ) 00245 break; 00246 } 00247 faces1_stack += tmp_faces1; 00248 ref_faces_close += tmp_faces2; 00249 tmp_faces1.clean_out(); 00250 tmp_faces2.clean_out(); 00251 } 00252 if ( AppUtil::instance()->interrupt() ) 00253 { 00254 //just break out and still clean up marks and stuff... 00255 break; 00256 } 00257 } 00258 if ( ref_1_mod ) 00259 vol_results.append(ref_volume1); 00260 if ( ref_2_mod ) 00261 vol_results.append(ref_volume2); 00262 00263 return CUBIT_SUCCESS; 00264 } 00265 CubitStatus VirtualImprintTool::virtual_imprint(DLIList <RefVolume*> &input_vols, 00266 DLIList <RefVolume*> &vol_results, 00267 double feature_size, 00268 CubitBoolean &curves_modified) 00269 { 00270 int ii, jj; 00271 //Do the n^2 thing, imprint every volume against every other volume... 00272 DLIList <RefVolume*> marked_vols; 00273 DLIList <RefVolume*> vols_stack = input_vols, ref_vols_close; 00274 RefVolume *curr_volume, *canidate_volume; 00275 while ( vols_stack.size() > 0 ) 00276 { 00277 if ( AppUtil::instance()->interrupt() ) 00278 { 00279 //just break out and still clean up marks and stuff... 00280 break; 00281 } 00282 curr_volume = vols_stack.pop(); 00283 curr_volume->marked(1); 00284 marked_vols.append(curr_volume); 00285 ref_vols_close.clean_out(); 00286 CubitBox curr_box = curr_volume->bounding_box(); 00287 for ( jj = input_vols.size(); jj > 0; jj-- ) 00288 { 00289 canidate_volume = input_vols.get_and_step(); 00290 if ( canidate_volume == curr_volume || canidate_volume->marked() ) 00291 continue; 00292 CubitBox canidate_box = canidate_volume->bounding_box(); 00293 if ( curr_box.overlap(feature_size, canidate_box) ) 00294 ref_vols_close.append(canidate_volume); 00295 } 00296 for ( jj = ref_vols_close.size(); jj > 0; jj-- ) 00297 { 00298 if ( AppUtil::instance()->interrupt() ) 00299 { 00300 //just break out and still clean up marks and stuff... 00301 break; 00302 } 00303 canidate_volume = ref_vols_close.get_and_step(); 00304 PRINT_INFO("Imprint Volumes: %d %d\n", curr_volume->id(), canidate_volume->id() ); 00305 CubitStatus stat = virtual_imprint(curr_volume, canidate_volume, 00306 vol_results, feature_size, 00307 curves_modified); 00308 if ( stat != CUBIT_SUCCESS ) 00309 { 00310 PRINT_ERROR("Problems imprinting volume %d and %d\n", 00311 curr_volume->id(), canidate_volume->id()); 00312 return stat; 00313 } 00314 } 00315 } 00316 DLIList <RefVolume*> tmp_list; 00317 for ( ii = 0; ii < vol_results.size(); ii++ ) 00318 { 00319 curr_volume = vol_results.get_and_step(); 00320 if ( curr_volume->marked() ) 00321 continue; 00322 else 00323 { 00324 tmp_list.append(curr_volume); 00325 curr_volume->marked(1); 00326 marked_vols.append(curr_volume); 00327 } 00328 } 00329 vol_results.clean_out(); 00330 for ( ii = 0; ii < tmp_list.size(); ii++ ) 00331 { 00332 curr_volume = tmp_list.get_and_step(); 00333 vol_results.append(curr_volume); 00334 } 00335 for ( ii = 0; ii < marked_vols.size(); ii++ ) 00336 marked_vols.get_and_step()->marked(0); 00337 return CUBIT_SUCCESS; 00338 } 00339 00340 00341 00342 00343 00344
