cgma
00001 //- Class: ChollaSurface 00002 //- Description: Temporary class for constructing the facet-based geometry 00003 //- 00004 //- Owner: Steven J. Owen 00005 //- Checked by: 00006 //- Version: 00007 #include "ChollaSurface.hpp" 00008 #include "ChollaCurve.hpp" 00009 #include "ChollaPoint.hpp" 00010 #include "TDGeomFacet.hpp" 00011 #include "CastTo.hpp" 00012 #include "CubitPoint.hpp" 00013 #include "CubitFacet.hpp" 00014 #include "CubitFacetData.hpp" 00015 #include "CubitFacetEdge.hpp" 00016 #include "CubitPointData.hpp" 00017 #include "CubitFacetEdgeData.hpp" 00018 #include "ChollaDebug.hpp" 00019 #include "TDFacetBoundaryPoint.hpp" 00020 #include "TDFacetBoundaryEdge.hpp" 00021 #include "GfxDebug.hpp" 00022 #include "FacetEvalTool.hpp" 00023 #include "FacetDataUtil.hpp" 00024 00025 //=============================================================================== 00026 //Function: ChollaSurface (PUBLIC) (constructor) 00027 //=============================================================================== 00028 ChollaSurface::ChollaSurface(int block_id) 00029 { 00030 static int count = 100; 00031 id = count++; 00032 myFlag = CUBIT_FALSE; 00033 mySurface = NULL; 00034 myEvalTool = NULL; 00035 blockId = block_id; 00036 myMergePartner = NULL; 00037 } 00038 //=============================================================================== 00039 //Function: ~ChollaSurface (PUBLIC) (destructor) 00040 //=============================================================================== 00041 ChollaSurface::~ChollaSurface() 00042 { 00043 } 00044 00045 //=========================================================================== 00046 //Function Name: check_faceting 00047 // 00048 //Member Type: PRIVATE 00049 //Descriptoin: check the edge/face orientations 00050 //=========================================================================== 00051 void ChollaSurface::check_faceting() 00052 { 00053 00054 } 00055 00056 00057 //============================================================================= 00058 //Function: split_surface (PUBLIC) 00059 //Description: split this surface into multiple ChollaSurface where there are 00060 // discontinuous faces. 00061 //Author: sjowen 00062 //Date: 12/22/00 00063 //============================================================================= 00064 CubitStatus ChollaSurface::split_surface( 00065 DLIList<ChollaSurface*> &facet_surface_list 00066 ) 00067 { 00068 DLIList<ChollaSurface*> new_surface_list; 00069 CubitStatus stat = CUBIT_SUCCESS; 00070 00071 // Go through the surfaceElemList and pull faces off one by one as we 00072 // determine which surface it belongs to. Continue until we have depleted 00073 // the list 00074 00075 int jj; 00076 int mydebug = 0; 00077 int num_surfs_created = 0; 00078 while( surfaceElemList.size() > 0) 00079 { 00080 00081 // start with the first face and create a list of all elements 00082 // attached to the face 00083 00084 DLIList<FacetEntity*> face_list; 00085 FacetEntity *start_face_ptr = surfaceElemList.get_and_step(); 00086 stat = get_adj_facets( start_face_ptr, face_list, mydebug ); 00087 if (stat != CUBIT_SUCCESS) 00088 return stat; 00089 00090 // if we have the same number of faces on the face_list as we do 00091 // on the surfaceElemList, then we are done. This surface is 00092 // not multiply connected. Oherwise continue... 00093 00094 if (face_list.size() == surfaceElemList.size()) 00095 { 00096 00097 // if this surface had a curve already defined (its a 2D topology 00098 // defined in skin2D) then its no longer valid if the surface was split 00099 // (for 3D the curves aren't defined until later) 00100 00101 if (num_surfs_created > 0 && curveList.size() > 0) 00102 { 00103 ChollaCurve *fcm_ptr = curveList.get(); // there should only be 1 00104 curveList.remove(); 00105 fcm_ptr->remove_td_associativity( this ); 00106 delete fcm_ptr; 00107 } 00108 return CUBIT_SUCCESS; 00109 } 00110 00111 // create a new surface to hold the face info 00112 00113 num_surfs_created++; 00114 ChollaSurface *fsm_ptr = new ChollaSurface( blockId ); 00115 facet_surface_list.append( fsm_ptr ); 00116 00117 // update the geometric curve pointer 00118 00119 fsm_ptr->assign_geometric_surface( NULL ); 00120 00121 // add the faces to this surface and update the surface 00122 // pointers in the face tool data 00123 00124 // surfaceElemList: nullify the items then compress the list 00125 // afterwards, instead of removing the items one by one, for 00126 // speed. 00127 for (jj=face_list.size(); jj > 0; jj--) 00128 { 00129 FacetEntity *face_ptr = face_list.get_and_step(); 00130 TDGeomFacet *td_gm_face = TDGeomFacet::get_geom_facet(face_ptr); 00131 td_gm_face->remove_cholla_surf( this ); 00132 td_gm_face->add_cholla_surf( fsm_ptr ); 00133 surfaceElemList.move_to_nearby( face_ptr ); 00134 surfaceElemList.extract(); 00135 fsm_ptr->add_facet( face_ptr ); 00136 } 00137 } 00138 00139 return CUBIT_SUCCESS; 00140 } 00141 00142 00143 #if 0 00144 //============================================================================= 00145 //Function: get_adj_facets (PRIVATE) 00146 //Description: recursive funstion that creates a list of all faces connected 00147 // the passed in face 00148 //Author: sjowen 00149 //Date: 12/22/00 00150 //============================================================================= 00151 CubitStatus ChollaSurface::get_adj_facets( 00152 FacetEntity *start_face_ptr, 00153 DLIList<FacetEntity*> &face_list, 00154 int mydebug) 00155 { 00156 CubitStatus stat = CUBIT_SUCCESS; 00157 00158 // add this face to the list 00159 00160 if (mydebug) 00161 { 00162 //start_face_ptr->draw( CUBIT_RED_INDEX ); 00163 //CDrawingTool::instance()->flush(); 00164 } 00165 face_list.append( start_face_ptr ); 00166 TDGeomFacet *td_gm_face = TDGeomFacet::get_geom_facet(start_face_ptr); 00167 td_gm_face->set_hit_flag( 0 ); 00168 00169 // loop through its edges 00170 00171 CubitFacetEdge *edge_ptr; 00172 FacetEntity *face_ptr; 00173 DLIList<CubitFacetEdge*> edge_list; 00174 start_face_ptr->edges( edge_list ); 00175 int ii; 00176 for (ii=0; ii<edge_list.size(); ii++) 00177 { 00178 edge_ptr = edge_list.get_and_step(); 00179 00180 // edges that already have a tool data defined are the result 00181 // of a feature angle. Don't traverse past a feature angle edge 00182 00183 TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00184 if (td_gm_edge == NULL) 00185 { 00186 DLIList<FacetEntity*> adj_face_list; 00187 edge_ptr->get_parents( adj_face_list ); 00188 00189 // keep traversing only if there are two adjacent faces to this edge, 00190 // otherwise, this is a boundary 00191 00192 if (adj_face_list.size() == 2) 00193 { 00194 face_ptr = adj_face_list.get_and_step(); 00195 if (face_ptr == start_face_ptr) 00196 face_ptr = adj_face_list.get(); 00197 00198 // go to its neighbor if it is part of the surface 00199 00200 td_gm_face = TDGeomFacet::get_geom_facet(face_ptr); 00201 if (td_gm_face->get_hit_flag() == id) 00202 { 00203 stat = get_adj_facets( face_ptr, face_list, mydebug ); 00204 if (stat != CUBIT_SUCCESS) 00205 return stat; 00206 } 00207 } 00208 } 00209 } 00210 return stat; 00211 } 00212 #endif 00213 00214 //============================================================================= 00215 //Function: get_adj_facets (PRIVATE) 00216 //Description: non recursive function that creates a list of all facets connected 00217 // to the passed in facet 00218 //Author: sjowen 00219 //Date: 12/22/00 00220 //============================================================================= 00221 CubitStatus ChollaSurface::get_adj_facets( 00222 FacetEntity *start_face_ptr, 00223 DLIList<FacetEntity*> &face_list, 00224 int mydebug, 00225 bool bound_check, 00226 bool feature_edge_check) 00227 { 00228 //int found = 0; 00229 int ii; 00230 CubitStatus stat = CUBIT_SUCCESS; 00231 DLIList<FacetEntity*> temp_list; 00232 FacetEntity *face_ptr = NULL; 00233 FacetEntity *adj_face_ptr = NULL; 00234 DLIList<CubitFacetEdge *>edge_list; 00235 CubitFacetEdge *edge_ptr = NULL; 00236 DLIList<FacetEntity *>adj_face_list; 00237 00238 if (mydebug) 00239 { 00240 for(ii=0; ii<surfaceElemList.size(); ii++) 00241 { 00242 face_ptr = surfaceElemList.get_and_step(); 00243 TDGeomFacet *td_gm_face = TDGeomFacet::get_geom_facet(face_ptr); 00244 PRINT_INFO("%d ", td_gm_face->get_hit_flag()); 00245 if (ii%10 == 0) 00246 { 00247 PRINT_INFO("\n"); 00248 } 00249 } 00250 } 00251 00252 // add this face to the list 00253 00254 temp_list.append( start_face_ptr ); 00255 TDGeomFacet *td_gm_face = TDGeomFacet::get_geom_facet(start_face_ptr); 00256 td_gm_face->set_hit_flag( 0 ); 00257 00258 while (temp_list.size()) 00259 { 00260 face_ptr = temp_list.pop(); 00261 td_gm_face = TDGeomFacet::get_geom_facet(face_ptr); 00262 if (td_gm_face->get_hit_flag() == 0) 00263 { 00264 face_list.append( face_ptr ); 00265 if (mydebug) 00266 { 00267 face_ptr->debug_draw( CUBIT_RED_INDEX ); 00268 GfxDebug::flush(); 00269 } 00270 edge_list.clean_out(); 00271 face_ptr->edges( edge_list ); 00272 for (ii=0; ii<edge_list.size(); ii++) 00273 { 00274 edge_ptr = edge_list.get_and_step(); 00275 00276 // edges that already have a tool data defined are the result 00277 // of a feature angle. Don't traverse past a feature angle edge 00278 00279 TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00280 if (td_gm_edge == NULL || !feature_edge_check ) 00281 { 00282 adj_face_list.clean_out(); 00283 edge_ptr->get_parents( adj_face_list ); 00284 00285 // keep traversing only if there are two adjacent faces to this edge, 00286 // otherwise, this is a boundary 00287 00288 if (adj_face_list.size() != 2) 00289 { 00290 continue; 00291 } 00292 00293 if( bound_check ) 00294 { 00295 TDFacetBoundaryEdge *td_facet_bnd_edge = TDFacetBoundaryEdge::get_facet_boundary_edge( edge_ptr ); 00296 if( td_facet_bnd_edge ) 00297 continue; 00298 } 00299 00300 adj_face_ptr = adj_face_list.get_and_step(); 00301 if (adj_face_ptr == face_ptr) 00302 adj_face_ptr = adj_face_list.get(); 00303 00304 // go to its neighbor if it is part of the surface 00305 00306 td_gm_face = TDGeomFacet::get_geom_facet(adj_face_ptr); 00307 if (td_gm_face->get_hit_flag() == id) 00308 { 00309 temp_list.append( adj_face_ptr ); 00310 td_gm_face->set_hit_flag( 0 ); 00311 } 00312 00313 } 00314 } 00315 } 00316 } 00317 return stat; 00318 } 00319 00320 00321 00322 //============================================================================= 00323 //Function: feature_angle (PRIVATE) 00324 //Description: mark all edges that exceed the specified feature angle 00325 // min_dot is the minimum dot product between adjacent face normals 00326 //Author: sjowen 00327 //Date: 12/22/00 00328 //============================================================================= 00329 CubitStatus ChollaSurface::feature_angle( 00330 double min_dot, 00331 DLIList<CubitFacetEdge *> &feature_edge_list) 00332 { 00333 //CubitStatus stat = CUBIT_SUCCESS; 00334 int ii, jj; 00335 00336 // compute face normals 00337 int mydebug = 0; 00338 double dot; 00339 CubitVector face_normal, adj_face_normal; 00340 FacetEntity *face_ptr, *adj_face_ptr; 00341 TDGeomFacet *td_gm_face; 00342 CubitFacet *tri_ptr; 00343 for (ii=0; ii<surfaceElemList.size(); ii++) 00344 { 00345 face_ptr = surfaceElemList.get_and_step(); 00346 td_gm_face = TDGeomFacet::get_geom_facet(face_ptr); 00347 tri_ptr = CAST_TO( face_ptr, CubitFacet ); 00348 face_normal = tri_ptr->normal( ); 00349 face_normal.normalize(); 00350 td_gm_face->set_normal( face_normal ); 00351 } 00352 00353 // check adjacencies and compute the dot product between them 00354 // where dot product is less than the min_dot, create a tool data 00355 // on the edge 00356 00357 if(mydebug) 00358 GfxDebug::clear(); 00359 for (ii=0; ii<surfaceElemList.size(); ii++) 00360 { 00361 face_ptr = surfaceElemList.get_and_step(); 00362 CubitFacet* curr_facet = CAST_TO(face_ptr, CubitFacet); 00363 CubitFacet* temp_facet = NULL; 00364 double curr_area=curr_facet->area(); 00365 td_gm_face = TDGeomFacet::get_geom_facet(face_ptr); 00366 face_normal = td_gm_face->get_normal(); 00367 DLIList<CubitFacetEdge*> edge_list; 00368 face_ptr->edges( edge_list ); 00369 for (jj=0; jj<edge_list.size(); jj++) 00370 { 00371 CubitFacetEdge *edge_ptr = edge_list.get_and_step(); 00372 TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00373 if (!td_gm_edge) 00374 { 00375 DLIList<FacetEntity*> adj_face_list; 00376 edge_ptr->get_parents( adj_face_list ); 00377 00378 // it has to be an internal edge - ignore boundaries 00379 if (adj_face_list.size() == 2) 00380 { 00381 adj_face_ptr = adj_face_list.get_and_step(); 00382 00383 if (adj_face_ptr == face_ptr) 00384 adj_face_ptr = adj_face_list.get(); 00385 td_gm_face = TDGeomFacet::get_geom_facet(adj_face_ptr); 00386 00387 // make sure the adj face is on the same surface 00388 00389 if (td_gm_face->get_hit_flag() == id) 00390 { 00391 00392 // test the dot product between normals 00393 00394 adj_face_normal = td_gm_face->get_normal(); 00395 temp_facet = CAST_TO(adj_face_ptr, CubitFacet); 00396 double adj_area=temp_facet->area(); 00397 //mbrewer:: ensure no NULL 00398 dot = adj_face_normal % face_normal; 00399 bool add_an_edge = true; 00400 if(mydebug){ 00401 PRINT_INFO("This area %f, other %f\n",curr_area,adj_area); 00402 } 00403 if(curr_area<(1.e-10*adj_area)){ 00404 DLIList<CubitFacetEdge*> edge_list_tmp; 00405 CubitFacetEdge* edge_ptr_tmp=NULL; 00406 curr_facet->edges(edge_list_tmp); 00407 double edge_length = edge_ptr->length(); 00408 int k = 0; 00409 if(edge_list_tmp.size()>0) 00410 add_an_edge=false; 00411 for(k=edge_list_tmp.size();k>0;k--){ 00412 edge_ptr_tmp=edge_list_tmp.get_and_step(); 00413 if(edge_ptr_tmp != edge_ptr && 00414 edge_ptr_tmp->length() > edge_length){ 00415 add_an_edge=true; 00416 } 00417 } 00418 } 00419 if(adj_area<(1.e-10*curr_area)) 00420 { 00421 DLIList<CubitFacetEdge*> edge_list_tmp; 00422 CubitFacetEdge* edge_ptr_tmp=NULL; 00423 temp_facet->edges(edge_list_tmp); 00424 double edge_length = edge_ptr->length(); 00425 int k = 0; 00426 if(edge_list_tmp.size()>0) 00427 add_an_edge=false; 00428 for(k=edge_list_tmp.size();k>0;k--){ 00429 edge_ptr_tmp=edge_list_tmp.get_and_step(); 00430 if(edge_ptr_tmp != edge_ptr && 00431 edge_ptr_tmp->length() > edge_length){ 00432 add_an_edge=true; 00433 } 00434 } 00435 } 00436 if (dot <= min_dot && add_an_edge ) 00437 { 00438 if(mydebug){ 00439 edge_ptr->debug_draw(CUBIT_MAGENTA_INDEX); 00440 } 00441 TDGeomFacet::add_geom_facet(edge_ptr, -1); 00442 td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00443 edge_ptr->set_as_feature(); 00444 feature_edge_list.append( edge_ptr ); 00445 } 00446 } 00447 } 00448 00449 // non-manifold edges (edges with more than 2 adj facets) 00450 // must be features 00451 00452 else if (adj_face_list.size() > 2) 00453 { 00454 TDGeomFacet::add_geom_facet(edge_ptr, -1); 00455 td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00456 edge_ptr->set_as_feature(); 00457 feature_edge_list.append( edge_ptr ); 00458 } 00459 } 00460 } 00461 } 00462 if(mydebug){ 00463 GfxDebug::mouse_xforms(); 00464 } 00465 return CUBIT_SUCCESS; 00466 } 00467 00468 //============================================================================= 00469 //Function: add_preexisting_feature_edges (PRIVATE) 00470 //Description: edges that were marked previously in function ChollaEngine::mark_features 00471 // are added to the feature edge list 00472 //Author: sjowen 00473 //Date: 01/08 00474 //============================================================================= 00475 CubitStatus ChollaSurface::add_preexisting_feature_edges( 00476 DLIList<CubitFacetEdge *> &feature_edge_list) 00477 { 00478 DLIList<CubitFacetEdge *> edge_list; 00479 DLIList<CubitFacet *> facet_list; 00480 CAST_LIST( surfaceElemList, facet_list, CubitFacet ); 00481 FacetDataUtil::get_edges( facet_list, edge_list ); 00482 int iedge; 00483 CubitFacetEdge *edge; 00484 for (iedge=0; iedge < edge_list.size(); iedge++) 00485 { 00486 edge = edge_list.get_and_step(); 00487 if (edge->is_feature()) 00488 feature_edge_list.append(edge); 00489 } 00490 return CUBIT_SUCCESS; 00491 } 00492 00493 00494 //============================================================================= 00495 //Function: non_manifold_edges (PRIVATE) 00496 //Description: mark all edges that are non-manifold (have more than 2 adj 00497 // facets) 00498 //Author: sjowen 00499 //Date: 5/01 00500 //============================================================================= 00501 CubitStatus ChollaSurface::non_manifold_edges( 00502 DLIList<CubitFacetEdge *> &feature_edge_list) 00503 { 00504 //CubitStatus stat = CUBIT_SUCCESS; 00505 int ii, jj; 00506 DLIList<CubitFacetEdge*> edge_list; 00507 FacetEntity *face_ptr; 00508 for (ii=0; ii<surfaceElemList.size(); ii++) 00509 { 00510 face_ptr = surfaceElemList.get_and_step(); 00511 edge_list.clean_out(); 00512 face_ptr->edges( edge_list ); 00513 for (jj=0; jj<edge_list.size(); jj++) 00514 { 00515 CubitFacetEdge *edge_ptr = edge_list.get_and_step(); 00516 TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00517 if (!td_gm_edge) 00518 { 00519 DLIList<FacetEntity*> adj_face_list; 00520 edge_ptr->get_parents( adj_face_list ); 00521 00522 // non-manifold edges (edges with more than 2 adj facets) 00523 // must be features 00524 00525 if (adj_face_list.size() > 2 || edge_ptr->is_feature()) 00526 { 00527 TDGeomFacet::add_geom_facet(edge_ptr, -1); 00528 td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00529 edge_ptr->set_as_feature(); 00530 feature_edge_list.append( edge_ptr ); 00531 } 00532 } 00533 } 00534 } 00535 return CUBIT_SUCCESS; 00536 } 00537 00538 00539 00540 //============================================================================= 00541 //Function: clean_features (PRIVATE) 00542 //Description: clean up edges that do not form complete loops as a result 00543 // of feature angle 00544 //Author: sjowen 00545 //Date: 12/22/00 00546 //============================================================================= 00547 CubitStatus ChollaSurface::clean_features( ) 00548 { 00549 int ii, jj; 00550 for (ii=0; ii<surfaceElemList.size(); ii++) 00551 { 00552 FacetEntity *face_ptr = surfaceElemList.get_and_step(); 00553 DLIList<CubitFacetEdge*> edge_list; 00554 face_ptr->edges( edge_list ); 00555 for (jj=0; jj<edge_list.size(); jj++) 00556 { 00557 CubitFacetEdge *edge_ptr = edge_list.get_and_step(); 00558 TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr); 00559 if (td_gm_edge != NULL) 00560 { 00561 00562 // make sure this edge actually forms the boundary between two surfaces 00563 00564 DLIList<FacetEntity*> adj_face_list; 00565 edge_ptr->get_parents( adj_face_list ); 00566 00567 // it has to be an internal edge - ignore boundaries 00568 00569 if (adj_face_list.size() == 2) 00570 { 00571 FacetEntity *adj_face_ptr = adj_face_list.get_and_step(); 00572 if (adj_face_ptr == face_ptr) 00573 adj_face_ptr = adj_face_list.get(); 00574 TDGeomFacet *td_gm_adjface = TDGeomFacet::get_geom_facet(adj_face_ptr); 00575 if (td_gm_adjface != NULL) 00576 { 00577 DLIList<ChollaSurface*> surf_list; 00578 td_gm_adjface->get_cholla_surfs( surf_list ); 00579 ChollaSurface *adj_surf = surf_list.get(); // must be only 1 surf 00580 if (adj_surf == this) 00581 { 00582 00583 // the same surface is on both sides of this edge - Therefore it 00584 // does not form a complete loop. Delete the tool data from 00585 // this edge to indicate that it is not at a boundary. 00586 00587 edge_ptr->delete_TD( &TDGeomFacet::is_geom_facet ); 00588 } 00589 } 00590 } 00591 } 00592 } 00593 } 00594 return CUBIT_SUCCESS; 00595 } 00596 00597 //============================================================================= 00598 //Function: init_hit_flags (PUBLIC) 00599 //Description: initialize the hit flags to the block surface id - used for 00600 // traversing the faces 00601 //Author: sjowen 00602 //Date: 01/22/01 00603 //============================================================================= 00604 void ChollaSurface::init_hit_flags() 00605 { 00606 int ii; 00607 for (ii=0; ii<surfaceElemList.size(); ii++) 00608 { 00609 FacetEntity *face_ptr = surfaceElemList.get_and_step(); 00610 TDGeomFacet *td_gm = TDGeomFacet::get_geom_facet(face_ptr); 00611 td_gm->set_hit_flag( id ); 00612 } 00613 } 00614 00615 //============================================================================= 00616 //Function: get_points (PUBLIC) 00617 //Description: compile a list of points on the surface 00618 //Author: sjowen 00619 //Date: 4/01 00620 //============================================================================= 00621 void ChollaSurface::get_points( DLIList<CubitPoint *> &point_list ) 00622 { 00623 int ii; 00624 CubitPoint *point[3]; 00625 CubitFacet *facet; 00626 FacetEntity *facet_entity; 00627 for (ii=0; ii<surfaceElemList.size(); ii++) 00628 { 00629 facet_entity = surfaceElemList.get_and_step(); 00630 facet = CAST_TO( facet_entity, CubitFacet ); 00631 facet->points( point[0], point[1], point[2] ); 00632 point[0]->marked(0); 00633 point[1]->marked(0); 00634 point[2]->marked(0); 00635 } 00636 00637 int jj; 00638 for (ii=0; ii<surfaceElemList.size(); ii++) 00639 { 00640 facet_entity = surfaceElemList.get_and_step(); 00641 facet = CAST_TO( facet_entity, CubitFacet ); 00642 facet->points( point[0], point[1], point[2] ); 00643 for (jj=0; jj<3; jj++) 00644 { 00645 if (point[jj]->marked() == 0) 00646 { 00647 point[jj]->marked(1); 00648 point_list.append(point[jj]); 00649 } 00650 } 00651 } 00652 } 00653 00654 //============================================================================= 00655 //Function: update_boundary_tool_data (PUBLIC) 00656 //Description: update the surface IDs on the boundary facet tooldatas 00657 //Author: sjowen 00658 //Date: 5/01 00659 //============================================================================= 00660 CubitStatus ChollaSurface::update_boundary_tool_data() 00661 { 00662 int ii, jj; 00663 CubitPoint *point_ptr; 00664 CubitFacetEdge *edge_ptr; 00665 CubitFacet *facet_ptr; 00666 FacetEntity *facet_entity; 00667 00668 TDFacetBoundaryPoint *td_fbp; 00669 TDFacetBoundaryEdge *td_fbe; 00670 for (ii=0; ii<surfaceElemList.size(); ii++) 00671 { 00672 facet_entity = surfaceElemList.get_and_step(); 00673 facet_ptr = CAST_TO( facet_entity, CubitFacet ); 00674 for (jj=0; jj<3; jj++) 00675 { 00676 point_ptr = facet_ptr->point(jj); 00677 td_fbp = TDFacetBoundaryPoint::get_facet_boundary_point( point_ptr ); 00678 if (td_fbp != NULL) 00679 { 00680 td_fbp->set_surf_id( facet_ptr, id ); 00681 } 00682 00683 edge_ptr = facet_ptr->edge(jj); 00684 td_fbe = TDFacetBoundaryEdge::get_facet_boundary_edge( edge_ptr ); 00685 if (td_fbe != NULL) 00686 { 00687 td_fbe->set_surf_id( facet_ptr, id ); 00688 } 00689 } 00690 } 00691 00692 return CUBIT_SUCCESS; 00693 } 00694 00695 //============================================================================= 00696 //Function: reset_facet_flags (PUBLIC) 00697 //Description: 00698 //Author: sjowen 00699 //Date: 6/01 00700 //============================================================================= 00701 void ChollaSurface::reset_facet_flags() 00702 { 00703 CubitFacet *facet_ptr; 00704 FacetEntity *fe_ptr; 00705 int ii; 00706 for (ii=0; ii<surfaceElemList.size(); ii++) 00707 { 00708 fe_ptr = surfaceElemList.get_and_step(); 00709 facet_ptr = CAST_TO( fe_ptr, CubitFacet ); 00710 facet_ptr->marked( 0 ); 00711 } 00712 } 00713 00714 //============================================================================= 00715 //Function: is_adjacent (PUBLIC) 00716 //Description: determine if this surface is adjacent to the given surface 00717 //Author: sjowen 00718 //Date: 02/11/2004 00719 //============================================================================= 00720 CubitBoolean ChollaSurface::is_adjacent( ChollaSurface *other_surf ) 00721 { 00722 DLIList<ChollaSurface *> *adjsurf_list_ptr; 00723 ChollaCurve *curv; 00724 ChollaSurface *surf; 00725 int icurv, ii; 00726 for(icurv=0; icurv< curveList.size(); icurv++) 00727 { 00728 curv = curveList.get_and_step(); 00729 adjsurf_list_ptr = curv->get_surface_list_ptr(); 00730 for(ii=0; ii<adjsurf_list_ptr->size(); ii++) 00731 { 00732 surf = adjsurf_list_ptr->get_and_step(); 00733 if (surf != this && surf == other_surf) 00734 { 00735 return CUBIT_TRUE; 00736 } 00737 } 00738 } 00739 return CUBIT_FALSE; 00740 } 00741 00742 //============================================================================= 00743 //Function: get_loop_edges (PUBLIC) 00744 //Description: return the ordered list of edges on the boundary of this surface 00745 //Author: sjowen 00746 //Date: 02/23/2004 00747 //============================================================================= 00748 DLIList<DLIList<CubitFacetEdge *>*> *ChollaSurface::get_loop_edges( ) 00749 { 00750 assert(myEvalTool != NULL); 00751 return myEvalTool->loops(); 00752 } 00753 00754 00755 static int icolor = 0; 00756 void ChollaSurface::debug_draw() 00757 { 00758 icolor++; 00759 icolor = (icolor%15)+1; 00760 dcolor(icolor); 00761 dldraw(surfaceElemList); 00762 } 00763 00764 //============================================================================= 00765 //Function: flip_facets (PUBLIC) 00766 //Description: invert all facets on this surface 00767 //Author: sjowen 00768 //Date: 09/10/09 00769 //============================================================================= 00770 void ChollaSurface::flip_facets() 00771 { 00772 FacetEntity *facet_entity; 00773 CubitFacet *facet_ptr; 00774 for (int ii=0; ii<surfaceElemList.size(); ii++) 00775 { 00776 facet_entity = surfaceElemList.get_and_step(); 00777 facet_ptr = dynamic_cast<CubitFacet *> (facet_entity); 00778 assert( facet_ptr != NULL ); 00779 facet_ptr->flip(); 00780 } 00781 } 00782 00783 //============================================================================= 00784 //Function: is_in_volume (PUBLIC) 00785 //Description: return whether this surface is in a particular volume 00786 //Author: sjowen 00787 //Date: 09/11/09 00788 //============================================================================= 00789 CubitBoolean ChollaSurface::is_in_volume( ChollaVolume *chvol_ptr ) 00790 { 00791 ChollaVolume *mychvol_ptr; 00792 for (int ii=0; ii<volList.size(); ii++) 00793 { 00794 mychvol_ptr = volList.get_and_step(); 00795 if (mychvol_ptr == chvol_ptr) 00796 return CUBIT_TRUE; 00797 } 00798 return CUBIT_FALSE; 00799 } 00800 00801 //============================================================================= 00802 //Function: get_vertices (PUBLIC) 00803 //Description: get the list of ChollaPoints on this surface 00804 //Author: sjowen 00805 //Date: 09/11/09 00806 //============================================================================= 00807 void ChollaSurface::get_vertices( DLIList<ChollaPoint *> &chpt_list ) 00808 { 00809 chpt_list.clean_out(); 00810 ChollaCurve *chcurv_ptr; 00811 for (int ii=0; ii<curveList.size(); ii++) 00812 { 00813 chcurv_ptr = curveList.get_and_step(); 00814 DLIList<ChollaPoint *> chc_pts = chcurv_ptr->get_points(); 00815 chpt_list += chc_pts; 00816 } 00817 chpt_list.uniquify_unordered(); 00818 } 00819 00820 bool ChollaSurface::is_contain( FacetEntity *facet ) 00821 { 00822 if( surfaceElemList.is_in_list( facet ) ) 00823 return true; 00824 else 00825 return false; 00826 } 00827 00828 //EOF 00829
