cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : Faceter.cpp 00003 // 00004 // Purpose : Implementation of Faceter 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : David White 00009 // 00010 // Creation Date : 03/01/02 00011 //------------------------------------------------------------------------- 00012 00013 #include "Faceter.hpp" 00014 #include "CubitPoint.hpp" 00015 #include "CubitFacet.hpp" 00016 #include "FaceterPointData.hpp" 00017 #include "FaceterFacetData.hpp" 00018 #include "CubitVector.hpp" 00019 00020 #include "DLIList.hpp" 00021 00022 #include "GeometryDefines.h" 00023 #include "CubitDefines.h" 00024 #include "GfxDebug.hpp" 00025 #include "GeometryQueryEngine.hpp" 00026 #include "GMem.hpp" 00027 00028 #include "RefFace.hpp" 00029 #include "RefEdge.hpp" 00030 #include "CoEdge.hpp" 00031 #include "RefVertex.hpp" 00032 #include "CubitPlane.hpp" 00033 #include "Curve.hpp" 00034 #include "PointGridSearch.hpp" 00035 00036 //------------------------------------------------------------------------- 00037 // Purpose : Constructor 00038 // 00039 // Special Notes : 00040 // 00041 // Creator : David White 00042 // 00043 // Creation Date : 03/01/02 00044 //------------------------------------------------------------------------- 00045 Faceter::Faceter( RefFace *face ) 00046 : thisRefFacePtr(face), gridCellScale(2.5) 00047 { 00048 globalPointList = new DLIList <CubitPoint*>; 00049 gridSearchPtr = NULL; 00050 avoidedOverlap = CUBIT_FALSE; 00051 } 00052 //------------------------------------------------------------------------- 00053 // Purpose : Destructor 00054 // 00055 // Special Notes : 00056 // 00057 // Creator : David White 00058 // 00059 // Creation Date : 03/01/02 00060 //------------------------------------------------------------------------- 00061 Faceter::~Faceter() 00062 { 00063 if (gridSearchPtr) 00064 delete gridSearchPtr; 00065 if ( globalPointList ) 00066 delete globalPointList; 00067 } 00068 //------------------------------------------------------------------------- 00069 // Purpose : facet_surface: facets the surface. 00070 // 00071 // Special Notes : 00072 // 00073 // Creator : David White 00074 // 00075 // Creation Date : 03/01/02 00076 //------------------------------------------------------------------------- 00077 CubitStatus Faceter::facet_surface(DLIList <CubitFacet*> &results, 00078 DLIList <CubitPoint*> &point_list) 00079 { 00080 if ( DEBUG_FLAG(129) ) 00081 { 00082 GfxDebug::clear(); 00083 GfxDebug::draw_ref_face_edges(thisRefFacePtr); 00084 GfxDebug::flush(); 00085 int debug = 0; 00086 if ( debug ) 00087 { 00088 GfxDebug::mouse_xforms(); 00089 GfxDebug::flush(); 00090 } 00091 } 00092 if ( thisRefFacePtr->number_of_Loops() > 1 ) 00093 return CUBIT_FAILURE; 00094 //Get the ordered boundary loops. 00095 int ii, jj; 00096 DLIList <DLIList<CubitPoint*>*> boundary_point_loops; 00097 DLIList <CubitPoint*> *tmp_list_ptr; 00098 CubitStatus stat = get_boundary_points( boundary_point_loops ); 00099 if ( stat != CUBIT_SUCCESS ) 00100 { 00101 //clean up the data... 00102 for ( ii = boundary_point_loops.size(); ii > 0; ii-- ) 00103 { 00104 tmp_list_ptr = boundary_point_loops.pop(); 00105 for ( jj = tmp_list_ptr->size(); jj > 0; jj-- ) 00106 delete tmp_list_ptr->pop(); 00107 delete tmp_list_ptr; 00108 } 00109 return stat; 00110 } 00111 //Set up the gridsearch. 00112 double ratio = gridCellScale, cell_size = 0.0; 00113 max_min_edge_ratio(boundary_point_loops, ratio, cell_size); 00114 if (ratio <= gridCellScale) { 00115 ratio = gridCellScale; 00116 } 00117 //Get all of the points into a single list. 00118 for ( ii = boundary_point_loops.size(); ii > 0; ii-- ) 00119 { 00120 tmp_list_ptr = boundary_point_loops.get_and_step(); 00121 for ( jj = tmp_list_ptr->size(); jj > 0; jj-- ) 00122 { 00123 globalPointList->append(tmp_list_ptr->get_and_step()); 00124 } 00125 } 00126 gridSearchPtr = new PointGridSearch(*globalPointList, 00127 cell_size, 00128 ratio); 00129 //fill in the grid... 00130 for ( ii = globalPointList->size(); ii > 0; ii-- ) 00131 gridSearchPtr->add_point(globalPointList->get_and_step()); 00132 00133 //Now start faceting. 00134 stat = facet_loop( boundary_point_loops.get(), results ); 00135 //clean up the data... 00136 for ( ii = boundary_point_loops.size(); ii > 0; ii-- ) 00137 delete boundary_point_loops.pop(); 00138 if ( stat != CUBIT_SUCCESS ) 00139 { 00140 //clean the data and return.. 00141 for ( ii = results.size(); ii > 0; ii-- ) 00142 delete results.pop(); 00143 for ( ii = globalPointList->size(); ii > 0; ii-- ) 00144 delete globalPointList->pop(); 00145 return stat; 00146 } 00147 //Didn't add any points... 00148 point_list += *globalPointList; 00149 return CUBIT_SUCCESS; 00150 } 00151 00152 00153 CubitStatus Faceter::facet_loop(DLIList <CubitPoint*> *loop_ptr, 00154 DLIList <CubitFacet*> &results) 00155 { 00156 //Assume there is just this loop and facet it as if there was nothing 00157 //in the middle. This is about the most stupid, simplistic method 00158 //of faceting I could think of. I'm sure anyone reading this could 00159 //think of something more sophisticated and better. 00160 00161 //First get the inteior angle for all of the points. 00162 DLIList <FaceterPointData*> ordered_point_list; 00163 int ii; 00164 double angle; 00165 CubitStatus stat; 00166 CubitPoint *curr_point; 00167 FaceterPointData *curr_faceter_data, *prev, *next; 00168 loop_ptr->reset(); 00169 int debug = 0; 00170 for ( ii = 0; ii < loop_ptr->size(); ii++ ) 00171 { 00172 stat = interior_angle(loop_ptr, angle); 00173 if ( stat == CUBIT_FAILURE ) 00174 return CUBIT_FAILURE; 00175 curr_point = loop_ptr->get_and_step(); 00176 if ( debug ) 00177 { 00178 PRINT_INFO("%d\n",curr_point->id()); 00179 GfxDebug::draw_point( curr_point->coordinates(), CUBIT_ORANGE_INDEX); 00180 } 00181 curr_faceter_data = (FaceterPointData*) curr_point; 00182 prev = (FaceterPointData*) loop_ptr->prev(2); 00183 next = (FaceterPointData*) loop_ptr->get(); 00184 00185 if ( angle < CUBIT_RESABS || angle > DEGREES_TO_RADIANS( 359.95 )) 00186 { 00187 00188 PRINT_ERROR("Zero degree angle in loop\n"); 00189 RefEdge *owner_e = (RefEdge*) curr_faceter_data->owner(); 00190 RefEdge *prev_e = (RefEdge*) prev->owner(); 00191 RefEdge *next_e = (RefEdge*) next->owner(); 00192 PRINT_ERROR("On edge %d, with next %d and prev %d\n", owner_e->id(), 00193 next_e->id(), prev_e->id()); 00194 return CUBIT_FAILURE; 00195 } 00196 curr_faceter_data->set_interior_angle(angle); 00197 curr_faceter_data->set_prev(prev); 00198 curr_faceter_data->set_next(next); 00199 ordered_point_list.append(curr_faceter_data); 00200 } 00201 ordered_point_list.sort(FaceterPointData::sort_by_angle); 00202 00203 //Now go through and just cut off the smallest triangles... 00204 //The list should be ordered largest angle to smallest. 00205 //so go from the end to the front. 00206 CubitFacet *new_facet = NULL; 00207 int safe_size = 4* ordered_point_list.size(); 00208 int safe_count = 0; 00209 int redo_count = ordered_point_list.size(); 00210 while (ordered_point_list.size() >= 3 && 00211 safe_count < safe_size ) 00212 { 00213 curr_faceter_data = ordered_point_list.pop(); 00214 new_facet = NULL; 00215 stat = facet_factory(curr_faceter_data, new_facet, ordered_point_list); 00216 if ( new_facet != NULL ) 00217 results.append(new_facet); 00218 if ( stat != CUBIT_SUCCESS ) 00219 return stat; 00220 if ( safe_count == redo_count ) 00221 { 00222 if ( avoidedOverlap ) 00223 { 00224 CubitBoolean reorder = CUBIT_FALSE; 00225 for ( ii = ordered_point_list.size(); ii > 0; ii-- ) 00226 { 00227 curr_faceter_data = ordered_point_list.get_and_step(); 00228 angle = curr_faceter_data->get_interior_angle(); 00229 if ( angle > 2*CUBIT_PI ) 00230 { 00231 angle = angle - 2*CUBIT_PI; 00232 curr_faceter_data->set_interior_angle(angle); 00233 reorder = CUBIT_TRUE; 00234 } 00235 } 00236 if ( reorder ) 00237 ordered_point_list.sort(FaceterPointData::sort_by_angle); 00238 //set the next redo to be later. 00239 avoidedOverlap = CUBIT_FALSE; 00240 } 00241 redo_count += redo_count; 00242 } 00243 safe_count++; 00244 } 00245 if ( ordered_point_list.size() < 3 ) 00246 return CUBIT_SUCCESS; 00247 else 00248 return CUBIT_FAILURE; 00249 } 00250 CubitStatus Faceter::facet_factory(FaceterPointData *curr_faceter_data, 00251 CubitFacet *&new_facet, 00252 DLIList <FaceterPointData*> &order_list) 00253 { 00254 double angle; 00255 DLIList<CubitPoint*> loop_list; 00256 new_facet = NULL; 00257 if ( avoid_facet(curr_faceter_data, order_list) ) 00258 return CUBIT_SUCCESS; 00259 FaceterPointData *prev = curr_faceter_data->get_prev(); 00260 FaceterPointData *next = curr_faceter_data->get_next(); 00261 //create the new facet. 00262 //create a triangle from these three points. 00263 new_facet = (CubitFacet*) new FaceterFacetData((CubitPoint*)prev, 00264 (CubitPoint*)curr_faceter_data, 00265 (CubitPoint*)next); 00266 CubitVector facet_normal = new_facet->normal(); 00267 CubitVector surface_normal = thisRefFacePtr->normal_at(curr_faceter_data->coordinates()); 00268 double dot = facet_normal%surface_normal; 00269 if ( dot < 0 ) 00270 { 00271 //new need to try and do this in a different way... 00272 delete new_facet; 00273 new_facet = NULL; 00274 if ( order_list.size() < 3 ) 00275 { 00276 PRINT_DEBUG_129("Last triangle is inverted. (surface %d)\n", 00277 thisRefFacePtr->id()); 00278 return CUBIT_FAILURE; 00279 } 00280 //Try and create facets on either side of this facet. 00281 return CUBIT_FAILURE; 00282 } 00283 00284 int debug = 1; 00285 if ( debug ) 00286 GfxDebug::draw_facet(new_facet, CUBIT_RED_INDEX); 00287 //Now fix up the ordered_list. 00288 //First update the angles. 00289 prev->set_next(next); 00290 next->set_prev(prev); 00291 loop_list.clean_out(); 00292 loop_list.append(prev->get_prev()); 00293 loop_list.append(prev); 00294 loop_list.append(next); 00295 loop_list.step(); 00296 interior_angle(&loop_list, angle); 00297 prev->set_interior_angle(angle); 00298 loop_list.clean_out(); 00299 loop_list.append(prev); 00300 loop_list.append(next); 00301 loop_list.append(next->get_next()); 00302 loop_list.step(); 00303 interior_angle(&loop_list, angle); 00304 next->set_interior_angle(angle); 00305 //Now do basically a sort again. There is probably 00306 //a faster way to do this but there are also much slower 00307 //ways in worst case too. At least this has guaranteed O(nlogn). 00308 order_list.sort(FaceterPointData::sort_by_angle); 00309 CubitPoint *tmp_point = (CubitPoint*) curr_faceter_data; 00310 gridSearchPtr->remove_point(tmp_point); 00311 return CUBIT_SUCCESS; 00312 } 00313 CubitBoolean Faceter::avoid_facet(FaceterPointData *curr_faceter_data, 00314 DLIList<FaceterPointData*> &order_list) 00315 { 00316 00317 int ii; 00318 CubitPoint *tmp_point; 00319 FaceterPointData *prev = curr_faceter_data->get_prev(); 00320 FaceterPointData *next = curr_faceter_data->get_next(); 00321 //get the closest edges to this point. 00322 CubitVector curr_v = curr_faceter_data->coordinates(); 00323 CubitVector prev_v = prev->coordinates(); 00324 CubitVector next_v = next->coordinates(); 00325 double r1 = (curr_v - prev_v).length(); 00326 double r2 = (curr_v - next_v).length(); 00327 double radius; 00328 double angle; 00329 if ( r1 > r2 ) 00330 radius = r1; 00331 else 00332 radius = r2; 00333 gridSearchPtr->set_neighborhood_bounds(curr_v, radius); 00334 DLIList<CubitPoint*> neighborhood_points; 00335 DLIList<CubitPoint*> close_points, loop_list; 00336 gridSearchPtr->get_neighborhood_points(neighborhood_points); 00337 //Loop through and see if there are nodes in here closer 00338 //than the r1 or r2. 00339 FaceterPointData *tmp_faceter; 00340 CubitVector tmp_v; 00341 radius *= radius; 00342 double angle1, angle2; 00343 for (ii = neighborhood_points.size(); ii > 0; ii-- ) 00344 { 00345 tmp_point = neighborhood_points.get_and_step(); 00346 tmp_faceter = (FaceterPointData*) tmp_point; 00347 if ( tmp_faceter == curr_faceter_data || 00348 tmp_faceter == prev || 00349 tmp_faceter == next || 00350 tmp_faceter == next->get_next() || 00351 tmp_faceter == prev->get_prev() ) 00352 continue; 00353 tmp_v = tmp_faceter->coordinates(); 00354 if ( (curr_v-tmp_v).length_squared() < radius ) 00355 close_points.append(tmp_point); 00356 } 00357 //Now of these close points if any of them make 00358 //good trinagles for the other nodes then don't do 00359 //this triangle... 00360 CubitBoolean abort_facet = CUBIT_FALSE; 00361 for ( ii = close_points.size(); ii > 0; ii-- ) 00362 { 00363 tmp_point = close_points.get_and_step(); 00364 loop_list.clean_out(); 00365 loop_list.append(tmp_point); 00366 loop_list.append((CubitPoint*)prev); 00367 loop_list.append((CubitPoint*)curr_faceter_data); 00368 loop_list.step(); 00369 interior_angle(&loop_list, angle1); 00370 loop_list.clean_out(); 00371 loop_list.append((CubitPoint*)curr_faceter_data); 00372 loop_list.append((CubitPoint*)next); 00373 loop_list.append(tmp_point); 00374 loop_list.step(); 00375 interior_angle(&loop_list, angle2); 00376 if ( angle1 < DEGREES_TO_RADIANS(160) && 00377 angle2 < DEGREES_TO_RADIANS(160)) 00378 { 00379 int tmp_debug = 1; 00380 if ( tmp_debug ) 00381 { 00382 GfxDebug::draw_point(prev->coordinates(), CUBIT_GREEN_INDEX); 00383 GfxDebug::draw_point(curr_faceter_data->coordinates(), CUBIT_RED_INDEX); 00384 GfxDebug::draw_point(tmp_point->coordinates(), CUBIT_BLUE_INDEX); 00385 GfxDebug::draw_point(next->coordinates(), CUBIT_MAGENTA_INDEX); 00386 loop_list.clean_out(); 00387 loop_list.append(tmp_point); 00388 loop_list.append((CubitPoint*)prev); 00389 loop_list.append((CubitPoint*)curr_faceter_data); 00390 loop_list.step(); 00391 interior_angle(&loop_list, angle1); 00392 } 00393 abort_facet = CUBIT_TRUE; 00394 break; 00395 } 00396 } 00397 if ( abort_facet ) 00398 { 00399 //We need to add curr_facerter_data back to the list. 00400 order_list.insert(curr_faceter_data); 00401 //Set the angle above 360... 00402 angle = curr_faceter_data->get_interior_angle(); 00403 curr_faceter_data->set_interior_angle(angle + 2*CUBIT_PI); 00404 avoidedOverlap = CUBIT_TRUE; 00405 return CUBIT_TRUE; 00406 } 00407 return CUBIT_FALSE; 00408 } 00409 00410 CubitStatus Faceter::interior_angle(DLIList <CubitPoint*> *loop_ptr, 00411 double &my_angle) 00412 { 00413 CubitVector point = loop_ptr->get()->coordinates(); 00414 CubitVector to_prev = loop_ptr->prev()->coordinates(); 00415 to_prev -= point; 00416 CubitVector to_next = loop_ptr->next()->coordinates(); 00417 to_next -= point; 00418 CubitVector surf_norm = thisRefFacePtr->normal_at ( point ); 00419 if ( surf_norm.length_squared() < CUBIT_RESABS ) 00420 { 00421 //Try getting it at one of the other nodes... 00422 surf_norm = thisRefFacePtr->normal_at(loop_ptr->next()->coordinates() ); 00423 if (surf_norm.length_squared() < CUBIT_RESABS ) 00424 { 00425 //Try getting it at one of the other nodes... 00426 surf_norm = thisRefFacePtr->normal_at(loop_ptr->prev()->coordinates() ); 00427 if (surf_norm.length_squared() < CUBIT_RESABS ) 00428 { 00429 PRINT_ERROR("Trying to get normal at point %d on surf %d.\n" 00430 " Normal length being returned equals zero.\n", 00431 loop_ptr->get()->id(), thisRefFacePtr->id() ); 00432 return CUBIT_FAILURE; 00433 } 00434 } 00435 } 00436 double angle = surf_norm.vector_angle ( to_next, to_prev ); 00437 00438 //Now if the angle is very small (zero) we don't know if this 00439 //should be 0 or 2PI, so do some tests. 00440 const double NEAR_ZERO = DEGREES_TO_RADIANS( 0.15 ); 00441 const double NEAR_360 = DEGREES_TO_RADIANS( 359.95 ); 00442 if( NEAR_ZERO < angle && angle < NEAR_360 ) 00443 { 00444 my_angle = angle; 00445 return CUBIT_SUCCESS; 00446 } 00447 //If we are close to zero or 2PI then take some other loop nodes 00448 //into consideration to see if we can get a better approximation 00449 //as to we are zero or 2 PI. 00450 CubitPoint *prev_node = loop_ptr->prev(); 00451 CubitPoint *next_node = loop_ptr->next(); 00452 int stop_it = loop_ptr->size(); 00453 int count = 0; 00454 while (( angle < NEAR_ZERO || angle > NEAR_360 ) && ( count < stop_it ) ) 00455 { 00456 prev_node = loop_ptr->prev( count + 2 ); 00457 next_node = loop_ptr->next( count + 2 ); 00458 to_prev = prev_node->coordinates() - point; 00459 to_next = next_node->coordinates() - point; 00460 angle = surf_norm.vector_angle ( to_next, to_prev ); 00461 count++; 00462 } 00463 const double TWO_PI = 2.0 * CUBIT_PI; 00464 if ( angle < NEAR_ZERO ) 00465 my_angle = TWO_PI; 00466 else if( angle < CUBIT_PI ) 00467 my_angle = 0.0; 00468 else 00469 my_angle = TWO_PI; 00470 return CUBIT_SUCCESS; 00471 } 00472 void Faceter::max_min_edge_ratio( DLIList <DLIList <CubitPoint*>*> &boundary_point_loops, 00473 double &ratio, 00474 double &cell_size) 00475 { 00476 double max_edge_length = CUBIT_DBL_MIN; 00477 double min_edge_length = CUBIT_DBL_MAX; 00478 double sum = 0.0; 00479 int total_count = 0; 00480 DLIList<CubitPoint*> *loopPtr; 00481 CubitPoint *node1, *node2; 00482 CubitVector edge; 00483 for (int i = boundary_point_loops.size(); i > 0; i--) { 00484 loopPtr = boundary_point_loops.get_and_step(); 00485 node2 = loopPtr->prev(); 00486 for (int j = loopPtr->size(); j > 0; j--) { 00487 node1 = node2; 00488 node2 = loopPtr->get_and_step(); 00489 CubitVector p1 = node1->coordinates(); 00490 CubitVector p2 = node2->coordinates(); 00491 edge = p2-p1; 00492 double edge_length = edge.length_squared(); 00493 if (edge_length > max_edge_length) max_edge_length = edge_length; 00494 if (edge_length < min_edge_length) min_edge_length = edge_length; 00495 total_count++; 00496 sum += edge_length; 00497 } 00498 } 00499 00500 if (min_edge_length > CUBIT_RESABS) { 00501 ratio = sqrt(max_edge_length/min_edge_length); 00502 } 00503 else { 00504 ratio = sqrt(max_edge_length); 00505 } 00506 if ( total_count > 0 && sum > 0 ) 00507 cell_size = sqrt(sum/total_count); 00508 else 00509 cell_size = 0.0; 00510 } 00511 00512 00513 CubitStatus Faceter::get_boundary_points( DLIList <DLIList<CubitPoint*>*> &boundary_point_loops ) const 00514 { 00515 DLIList<DLIList<CoEdge*> > co_edge_loops; 00516 thisRefFacePtr->co_edge_loops(co_edge_loops); 00517 int ii, jj; 00518 DLIList <CubitPoint*> *new_point_loop_ptr, tmp_point_list; 00519 RefEdge *ref_edge_ptr; 00520 CoEdge *co_edge_ptr; 00521 CubitStatus stat; 00522 CubitSense sense; 00523 00524 for ( ii = co_edge_loops.size(); ii > 0; ii-- ) 00525 { 00526 DLIList <CoEdge*> &co_edge_list_ptr = co_edge_loops.get_and_step(); 00527 new_point_loop_ptr = new DLIList <CubitPoint*>; 00528 for ( jj = co_edge_list_ptr.size(); jj > 0; jj-- ) 00529 { 00530 co_edge_ptr = co_edge_list_ptr.get_and_step(); 00531 ref_edge_ptr = co_edge_ptr->get_ref_edge_ptr(); 00532 tmp_point_list.clean_out(); 00533 stat = get_curve_facets( ref_edge_ptr, tmp_point_list ); 00534 PRINT_DEBUG_129("curve %d has %d points\n", 00535 ref_edge_ptr->id(), 00536 tmp_point_list.size()); 00537 if ( !stat ) 00538 return CUBIT_FAILURE; 00539 tmp_point_list.reset(); 00540 //the points are in order from start vertex to end vertex. 00541 //append them now according to the loop. 00542 sense = co_edge_ptr->get_sense(); 00543 if ( CUBIT_FORWARD != sense ) 00544 tmp_point_list.reverse(); 00545 //Now take off the last point as it is a duplicate with the 00546 //other list... 00547 tmp_point_list.reset(); 00548 delete tmp_point_list.pop(); 00549 (*new_point_loop_ptr) += tmp_point_list; 00550 } 00551 CubitVector curr, prev; 00552 for ( jj = new_point_loop_ptr->size(); jj > 0; jj-- ) 00553 { 00554 prev = new_point_loop_ptr->prev()->coordinates(); 00555 curr = new_point_loop_ptr->get_and_step()->coordinates(); 00556 if ( prev.about_equal(curr) ) 00557 { 00558 PRINT_DEBUG_129("Points within tolerance in boundaryloop.\n"); 00559 new_point_loop_ptr->back(); 00560 delete new_point_loop_ptr->remove(); 00561 } 00562 } 00563 boundary_point_loops.append(new_point_loop_ptr); 00564 } 00565 00566 return CUBIT_SUCCESS; 00567 } 00568 00569 CubitStatus Faceter::get_curve_facets( RefEdge* curve, DLIList<CubitPoint*>& segments ) const 00570 { 00571 //const double COS_ANGLE_TOL = 0.965925826289068312213715; // cos(15) 00572 const double COS_ANGLE_TOL = 0.984807753012208020315654; // cos(10) 00573 //const double COS_ANGLE_TOL = 0.996194698091745545198705; // cos(5) 00574 GMem curve_graphics; 00575 const double dist_tol = GEOMETRY_RESABS; 00576 const double dist_tol_sqr = dist_tol*dist_tol; 00577 Curve* curve_ptr = curve->get_curve_ptr(); 00578 curve_ptr->get_geometry_query_engine()->get_graphics( curve_ptr, &curve_graphics ); 00579 00580 GPoint* gp = curve_graphics.point_list(); 00581 CubitPoint* last = (CubitPoint*) new FaceterPointData( gp->x, gp->y, gp->z ); 00582 ((FaceterPointData*)last)->owner(dynamic_cast<RefEntity*>(curve)); 00583 CubitVector lastv = last->coordinates(); 00584 segments.append( last ); 00585 GPoint* end = gp + curve_graphics.pointListCount - 1; 00586 00587 for( gp++; gp < end; gp++ ) 00588 { 00589 CubitVector pos( gp->x, gp->y, gp->z ); 00590 CubitVector step1 = (pos - lastv); 00591 double len1 = step1.length(); 00592 if( len1 < dist_tol ) continue; 00593 00594 GPoint* np = gp + 1; 00595 CubitVector next( np->x, np->y, np->z ); 00596 CubitVector step2 = next - pos; 00597 double len2 = step2.length(); 00598 if( len2 < dist_tol ) continue; 00599 00600 double cosine = (step1 % step2) / (len1 * len2); 00601 if( cosine > COS_ANGLE_TOL ) continue; 00602 00603 last = new FaceterPointData( pos ); 00604 ((FaceterPointData*)last)->owner(dynamic_cast<RefEntity*>(curve)); 00605 segments.append( last ); 00606 lastv = last->coordinates(); 00607 } 00608 00609 CubitVector last_pos( gp->x, gp->y, gp->z ); 00610 segments.last(); 00611 while( (last_pos - (segments.get()->coordinates())).length_squared() < dist_tol_sqr ) 00612 { 00613 delete segments.pop(); 00614 segments.last(); 00615 } 00616 CubitPoint *tmp_point = (CubitPoint*) new FaceterPointData( last_pos ); 00617 segments.append( tmp_point ); 00618 ((FaceterPointData*)tmp_point)->owner( dynamic_cast<RefEntity*>(curve) ); 00619 00620 // Now check if the segment list is reversed wrt the curve direction. 00621 segments.reset(); 00622 double u1, u2; 00623 if( segments.size() > 2 ) 00624 { 00625 u1 = curve->u_from_position( (segments.next(1)->coordinates()) ); 00626 u2 = curve->u_from_position( (segments.next(2)->coordinates()) ); 00627 } 00628 else 00629 { 00630 u1 = curve->u_from_position( (segments.get()->coordinates() ) ); 00631 u2 = curve->u_from_position( (segments.next()->coordinates()) ); 00632 } 00633 if( (u2 < u1) && (curve->start_param() <= curve->end_param()) ) 00634 segments.reverse(); 00635 00636 //Make sure we don't have duplicate points. 00637 int jj; 00638 CubitVector curr, prev; 00639 for ( jj = segments.size(); jj > 0; jj-- ) 00640 { 00641 prev = segments.prev()->coordinates(); 00642 curr = segments.get_and_step()->coordinates(); 00643 if ( prev.about_equal(curr) ) 00644 { 00645 PRINT_DEBUG_129("Points on curve %d within tolerance...\n", curve->id()); 00646 segments.back(); 00647 delete segments.remove(); 00648 } 00649 } 00650 return CUBIT_SUCCESS; 00651 } 00652
