, including all inherited members.
| add_modelent(ModelEnt *model_ent) | EBMesher | [virtual] |
| can_mesh(iBase_EntityType dim) | EBMesher | [inline, static] |
| can_mesh(ModelEnt *me) | EBMesher | [static] |
| canmesh_edge(ModelEnt *model_ent) | MeshOp | [static] |
| canmesh_face(ModelEnt *model_ent) | MeshOp | [static] |
| canmesh_region(ModelEnt *model_ent) | MeshOp | [static] |
| canmesh_vertex(ModelEnt *model_ent) | MeshOp | [static] |
| constrain_even() | MeshScheme | |
| construct_obb_tree() | EBMesher | [private] |
| create_model_ents_from_previous_ops() | MeshOp | |
| debugLevel | MeshOp | [protected] |
| EBMesher(MKCore *mkcore, const MEntVector &me_vec, double size=-1., bool use_geom=true, int add_layer=3) | EBMesher | |
| EBMesher(const EBMesher &) | EBMesher | [private] |
| ensure_facet_dependencies(bool recurse_to_facets=true) | MeshOp | |
| execute_called() const | GraphNode | [inline] |
| execute_called(bool flag) | GraphNode | [inline] |
| execute_this() | EBMesher | [virtual] |
| executeCalled | GraphNode | [protected] |
| export_fraction_edges(std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &rmdCutCellSurfEdge) | EBMesher | [private] |
| export_fraction_points(std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &mdCutCellEdge) | EBMesher | [private] |
| export_mesh(const char *file_name, bool separate=false) | EBMesher | |
| find_intersections() | EBMesher | [private] |
| fire_ray(int &nIntersect, double startPnt[3], double endPnt[3], double tol, int dir, double rayLength) | EBMesher | [private] |
| fire_rays(int dir) | EBMesher | [private] |
| get_debug_verbosity() | MeshOp | [inline] |
| get_edge_fraction(int idHex, int dir) | EBMesher | [private] |
| get_edge_status(const double dZ, int &iSkip) | EBMesher | [private] |
| get_graph() const | GraphNode | [inline] |
| get_grid_and_edges(double *boxMin, double *boxMax, int *nDiv, std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &rmdCutCellEdge, std::vector< int > &rvnInsideCell, bool isCornerExterior=true) | EBMesher | |
| get_grid_and_edges_techX(double *boxMin, double *boxMax, int *nDiv, std::map< CutCellSurfEdgeKey, std::vector< double >, LessThan > &rmdCutCellSurfEdge, std::vector< int > &rvnInsideCell, bool isCornerExterior=true) | EBMesher | |
| get_inside_hex(std::vector< int > &rvnInsideCell) | EBMesher | [private] |
| get_name() const | GraphNode | [inline, virtual] |
| get_node() const | GraphNode | [inline] |
| get_scd_mesher() | EBMesher | [private] |
| get_tag(const char *name, int size, unsigned flags, moab::DataType type, const void *def_value=NULL, bool create_if_missing=true) | EBMesher | [private] |
| get_uncut_edge_fraction(int i, int j, int k, int dir) | EBMesher | [private] |
| get_various_length_tag(const char *name, unsigned store, moab::DataType type) | EBMesher | [private] |
| get_volume_fraction(int vol_frac_div) | EBMesher | |
| GraphNode(const GraphNode &graph_node) | GraphNode | [inline] |
| GraphNode(MKGraph *graph) | GraphNode | [inline] |
| graphNode | GraphNode | [protected] |
| in_arcs() const | GraphNode | [inline] |
| increase_box(double box_increase) | EBMesher | [inline] |
| init | EBMesher | [private, static] |
| is_ray_move_and_set_overlap_surf(bool &bMoveOnce) | EBMesher | [private] |
| is_same_direct_to_ray(int i, int dir) | EBMesher | [private] |
| is_shared_overlapped_surf(int index) | EBMesher | [private] |
| m_bbTag | EBMesher | [private] |
| m_bMovedOnce | EBMesher | [private] |
| m_boxIncrease | EBMesher | [private] |
| m_bUseGeom | EBMesher | [private] |
| m_bUseMeshGeom | EBMesher | [private] |
| m_bUseWholeGeom | EBMesher | [private] |
| m_curPnt | EBMesher | [private] |
| m_dFirstP | EBMesher | [private] |
| m_dInputSize | EBMesher | [private] |
| m_dIntervalSize | EBMesher | [private] |
| m_dSecondP | EBMesher | [private] |
| m_edgeCutFracLengthTag | EBMesher | [private] |
| m_edgeCutFracTag | EBMesher | [private] |
| m_elemStatusTag | EBMesher | [private] |
| m_GeomTopoTool | EBMesher | [private] |
| m_hObbTree | EBMesher | [private] |
| m_hRootSet | EBMesher | [private] |
| m_hTreeRoot | EBMesher | [private] |
| m_iElem | EBMesher | [private] |
| m_iFirstP | EBMesher | [private] |
| m_iInter | EBMesher | [private] |
| m_iOverlap | EBMesher | [private] |
| m_iSecondP | EBMesher | [private] |
| m_iStartHex | EBMesher | [private] |
| m_max | EBMesher | [private] |
| m_maxCoord | EBMesher | [private] |
| m_mdCutFraction | EBMesher | [private] |
| m_mesh | EBMesher | [private] |
| m_mhOverlappedSurf | EBMesher | [private] |
| m_min | EBMesher | [private] |
| m_minCoord | EBMesher | [private] |
| m_mRootSets | EBMesher | [private] |
| m_nAddLayer | EBMesher | [private] |
| m_nDiv | EBMesher | [private] |
| m_nFraction | EBMesher | [private] |
| m_nHex | EBMesher | [private] |
| m_nIteration | EBMesher | [private] |
| m_nMove | EBMesher | [private] |
| m_nNode | EBMesher | [private] |
| m_nStatus | EBMesher | [private] |
| m_nTri | EBMesher | [private] |
| m_origin_coords | EBMesher | [private] |
| m_prevPnt | EBMesher | [private] |
| m_vhInterFacet | EBMesher | [private] |
| m_vhInterSurf | EBMesher | [private] |
| m_vhVertex | EBMesher | [private] |
| m_vIntersection | EBMesher | [private] |
| m_vnEdgeStatus | EBMesher | [private] |
| m_vnHexStatus | EBMesher | [private] |
| m_volFracHandleTag | EBMesher | [private] |
| m_volFracLengthTag | EBMesher | [private] |
| m_volFracTag | EBMesher | [private] |
| make_edge(double ePnt[6], std::vector< iBase_EntityHandle > &edge_handles) | EBMesher | [private] |
| make_scd_hexes() | EBMesher | [private] |
| make_uscd_hexes() | EBMesher | [private] |
| me_selection() | MeshOp | [inline, virtual] |
| me_selection() const | MeshOp | [inline, virtual] |
| mentSelection | MeshOp | [protected] |
| mesh_types(std::vector< moab::EntityType > &mesh_types) | MeshOp | |
| mesh_types_arr() const | EBMesher | [inline, virtual] |
| MeshOp(const MeshOp &mesh_op) | MeshOp | |
| MeshOp(MKCore *mkcore, const MEntVector &me_vec=MEntVector()) | MeshOp | |
| MeshScheme(MKCore *mkcore, const MEntVector &me_vec=MEntVector()) | MeshScheme | [inline] |
| MeshScheme(const MeshScheme &mesh_scheme) | MeshScheme | [inline] |
| mk_core() const | MeshOp | [inline] |
| mkGraph | GraphNode | [protected] |
| MKGraph class | GraphNode | [friend] |
| moab_instance() | EBMesher | [inline, private] |
| move_intersections(int n_dir, int n_inter, double start_pnt[3]) | EBMesher | [private] |
| move_ray(int &nIntersect, double *startPnt, double *endPnt, double tol, int dir, bool bMoveOnce) | EBMesher | [private] |
| name() | EBMesher | [inline, static] |
| nodeName | GraphNode | [protected] |
| operator=(const EBMesher &) | EBMesher | [private] |
| other_node(lemon::ListDigraph::Arc arc) | GraphNode | [inline] |
| out_arcs() const | GraphNode | [inline] |
| output_types() | EBMesher | [static] |
| remove_intersection_duplicates() | EBMesher | [private] |
| remove_modelent(ModelEnt *model_ent) | MeshOp | [virtual] |
| set_debug_verbosity(int debug) | MeshOp | [inline] |
| set_division(double *min, double *max) | EBMesher | |
| set_division() | EBMesher | [private] |
| set_edge_status(int dir) | EBMesher | [private] |
| set_hex_status(int index, EdgeStatus value, int dir) | EBMesher | [private] |
| set_name(std::string new_name) | GraphNode | [inline, virtual] |
| set_neighbor_hex_status(int dir, int i, int j, int k) | EBMesher | [private] |
| set_num_interval(int *n_interval) | EBMesher | |
| set_obb_tree_box_dimension() | EBMesher | |
| set_tag_info() | EBMesher | [private] |
| set_tree_root(ModelEnt *me) | EBMesher | [private] |
| setup_boundary() | MeshOp | |
| setup_called() const | GraphNode | [inline] |
| setup_called(bool flag) | GraphNode | [inline] |
| setup_this() | EBMesher | [virtual] |
| setupCalled | GraphNode | [protected] |
| use_mesh_geometry(bool use) | EBMesher | [inline] |
| use_whole_geom(int use) | EBMesher | [inline] |
| write_mesh(const char *file_name, int type, iBase_EntityHandle *handles, int &n_elem) | EBMesher | [private] |
| ~EBMesher() | EBMesher | [virtual] |
| ~GraphNode() | GraphNode | [inline, virtual] |
| ~MeshOp() | MeshOp | [virtual] |
| ~MeshScheme() | MeshScheme | [inline, virtual] |
