, including all inherited members.
| data | IANlp | [private] |
| debugging | IANlp | [private] |
| eval_equal_sum(const int i, const Number *x) const | IANlp | |
| eval_even_sum(const int i, const Number *x) const | IANlp | |
| eval_f(Index n, const Number *x, bool new_x, Number &obj_value) | IANlp | [virtual] |
| eval_g(Index n, const Number *x, bool new_x, Index m, Number *g) | IANlp | [virtual] |
| eval_grad_f(Index n, const Number *x, bool new_x, Number *grad_f) | IANlp | [virtual] |
| eval_grad_r_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_grad_R_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_grad_S_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_grad_s_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_h(Index n, const Number *x, bool new_x, Number obj_factor, Index m, const Number *lambda, bool new_lambda, Index nele_hess, Index *iRow, Index *jCol, Number *values) | IANlp | [virtual] |
| eval_hess_r_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_hess_R_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_hess_S_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_hess_s_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_jac_g(Index n, const Number *x, bool new_x, Index m, Index nele_jac, Index *iRow, Index *jCol, Number *values) | IANlp | [virtual] |
| eval_r_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_R_i(const Number &I_i, const Number &x_i) | IANlp | [inline, static] |
| eval_S_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| eval_s_i(const Number &I_i, const Number &x_i) | IANlp | [inline, private, static] |
| finalize_solution(SolverReturn status, Index n, const Number *x, const Number *z_L, const Number *z_U, Index m, const Number *g, const Number *lambda, Number obj_value, const IpoptData *ip_data, IpoptCalculatedQuantities *ip_cq) | IANlp | [virtual] |
| get_bounds_info(Index n, Number *x_l, Number *x_u, Index m, Number *g_l, Number *g_u) | IANlp | [virtual] |
| get_neleJac() const | IANlp | [inline] |
| get_nlp_info(Index &n, Index &m, Index &nnz_jac_g, Index &nnz_h_lag, IndexStyleEnum &index_style) | IANlp | [virtual] |
| get_starting_point(Index n, bool init_x, Number *x_init, bool init_z, Number *z_L, Number *z_U, Index m, bool init_lambda, Number *lambda) | IANlp | [virtual] |
| IANlp(const IAData *data_ptr, IASolution *solution_ptr, const bool set_silent=true) | IANlp | |
| IANlp() | IANlp | [private] |
| IANlp(const IANlp &) | IANlp | [private] |
| neleJac | IANlp | [private] |
| operator=(const IANlp &) | IANlp | [private] |
| p_norm | IANlp | [private, static] |
| silent | IANlp | [private] |
| solution | IANlp | [private] |
| verbose | IANlp | [private] |
| ~IANlp() | IANlp | [virtual] |
