, including all inherited members.
| all_constraints(const bool print_me=false, const bool print_unsatisfied=false) const | IASolverTool | |
| BEND enum value | IASolverInt | [private] |
| cleanup() | IASolverInt | [private] |
| COS enum value | IASolverInt | [private] |
| debugging | IASolverInt | [private] |
| debuggingTool | IASolverTool | [protected] |
| debuggingToolInt | IASolverToolInt | [protected] |
| equal_constraint(const int i, const bool print_me=false, const bool print_unsatisfied=false) const | IASolverTool | |
| equal_constraints(const bool print_me=false, const bool print_unsatisfied=false) const | IASolverTool | |
| equal_value(int i) const | IASolverTool | |
| even_constraint(const int i, const bool print_me=false, const bool print_unsatisfied=false) const | IASolverTool | |
| even_constraints(const bool print_me=false, const bool print_unsatisfied=false) const | IASolverTool | |
| even_floor_ceil(double s, double &s_floor, double &s_ceil) const | IASolverTool | |
| even_value(int i) const | IASolverTool | |
| get_frac(double x, int &integer, double &frac) const | IASolverToolInt | |
| get_km(int i, double x) const | IASolverToolInt | |
| get_km(int i, double x, int &km_integer, double &km_frac) const | IASolverToolInt | |
| get_kp(int i, double x) const | IASolverToolInt | |
| get_kp(int i, double x, int &kp_integer, double &kp_frac) const | IASolverToolInt | |
| get_xh(int i) const | IASolverToolInt | |
| get_xl(int i) const | IASolverToolInt | |
| ia_data() const | IASolverTool | [inline] |
| ia_data(const IAData *set_data) | IASolverTool | [inline] |
| ia_solution() const | IASolverTool | [inline] |
| ia_solution(IASolution *set_solution) | IASolverTool | [inline] |
| iaData | IASolverTool | [protected] |
| iaSolution | IASolverTool | [protected] |
| IASolverInt(const IAData *ia_data_ptr, IASolution *relaxed_solution_ptr, const bool set_silent=true) | IASolverInt | |
| IASolverInt(const IASolverInt &) | IASolverInt | [private] |
| IASolverTool() | IASolverTool | [inline] |
| IASolverTool(const IAData *ia_data, IASolution *ia_solution, bool debugging_set=false) | IASolverTool | [inline] |
| IASolverTool(const bool debugging_set) | IASolverTool | [inline] |
| IASolverToolInt() | IASolverToolInt | |
| IASolverToolInt(const bool debugging_set) | IASolverToolInt | |
| IASolverToolInt(const IAData *ia_data, IASolution *ia_solution, bool debugging_set=false) | IASolverToolInt | |
| int_floor_ceil(double x, double &x_floor, double &x_ceil) const | IASolverTool | |
| ip_data() | IASolverToolInt | [inline] |
| ip_data(IPData *set_data) | IASolverToolInt | [inline] |
| ipData | IASolverToolInt | [protected] |
| is_even(double y) const | IASolverTool | |
| is_even(double y, int &y_even) const | IASolverTool | |
| is_integer(const double x) const | IASolverTool | |
| is_integer(const double x, int &x_int) const | IASolverTool | |
| is_integer(const double x, double &x_int_double) const | IASolverTool | |
| operator=(const IASolverInt &) | IASolverInt | [private] |
| PARABOLA enum value | IASolverInt | [private] |
| print(const bool do_print_solution, const bool do_print_nonint, const bool do_print_equal_constraints, const bool do_print_nonequal, const bool do_print_even_constraints, const bool do_print_noneven) const | IASolverTool | |
| print() const | IASolverTool | [inline] |
| print_problem() const | IASolverTool | |
| print_solution() const | IASolverTool | |
| print_violations() const | IASolverTool | [inline] |
| randomize_weights_of_non_int(IAWeights *weights, const double rand_factor) | IASolverToolInt | |
| round_solution() | IASolverToolInt | |
| ROUNDING enum value | IASolverInt | [private] |
| set_debug(const bool debugging_set) | IASolverToolInt | [inline, virtual] |
| silent | IASolverInt | [private] |
| solution_is_integer(const bool print_non_integer=false) | IASolverToolInt | |
| solve() | IASolverInt | |
| solve_round() | IASolverInt | [private] |
| solve_wave(const SolverType solver_type) | IASolverInt | [private] |
| solve_wave_workhorse(IAIntWaveNlp *mynlp) | IASolverInt | [private] |
| SolverType enum name | IASolverInt | [private] |
| valid_solution() const | IASolverTool | |
| ~IASolverInt() | IASolverInt | [virtual] |
| ~IASolverTool() | IASolverTool | [virtual] |
| ~IASolverToolInt() | IASolverToolInt | [virtual] |
