, including all inherited members.
| addEntArrToSet(const EntityHandle *entity_handles, int entity_handles_size, EntitySetHandle entity_set) | iGeom | [inline, virtual] |
| addEntSet(EntitySetHandle to_add, EntitySetHandle add_to) | iGeom | [inline, virtual] |
| addEntToSet(EntityHandle entity, EntitySetHandle set) | iGeom | [inline, virtual] |
| addPrntChld(EntitySetHandle parent, EntitySetHandle child) | iGeom | [inline, virtual] |
| copyEnt(EntityHandle source, EntityHandle ©) | iGeom | [inline, virtual] |
| createBrick(double x, double y, double z, EntityHandle &brick) | iGeom | [inline, virtual] |
| createCone(double height, double maj_rad, double min_rad, double top_rad, EntityHandle &cone) | iGeom | [inline, virtual] |
| createCylinder(double height, double maj_rad, double min_rad, EntityHandle &cylinder) | iGeom | [inline, virtual] |
| createEntSet(bool is_list, EntitySetHandle &handle_out) | iGeom | [inline, virtual] |
| createPrism(double height, int num_sides, double maj_radius, double min_radius, EntityHandle &prism) | iGeom | [inline, virtual] |
| createSphere(double radius, EntityHandle &sphere) | iGeom | [inline, virtual] |
| createTag(const char *tag_name, int tag_num_type_values, TagValueType tag_type, TagHandle &tag_handle_out) | iGeom | [inline, virtual] |
| createTorus(double maj_rad, double min_rad, EntityHandle &torus) | iGeom | [inline, virtual] |
| deleteAll() | iGeom | [inline, virtual] |
| deleteEnt(EntityHandle entity) | iGeom | [inline, virtual] |
| destroyEntSet(EntitySetHandle handle) | iGeom | [inline, virtual] |
| destroyTag(TagHandle tag_handle, bool forced) | iGeom | [inline, virtual] |
| EntityHandle typedef | iGeom | |
| EntitySetHandle typedef | iGeom | |
| EntityType typedef | iGeom | |
| Error typedef | iGeom | |
| getAllEntSetTags(EntitySetHandle set, std::vector< TagHandle > &tags_out) const | iGeom | [inline, virtual] |
| getAllTags(EntityHandle entity, std::vector< TagHandle > &tags_out) const | iGeom | [inline, virtual] |
| getArr1stDrvt(const EntityHandle *entities, int entities_size, StorageOrder order, const double *uv, int uv_size, double *dvtr_u, double *dvtr_v) const | iGeom | [inline, virtual] |
| getArr2ndAdj(const EntityHandle *entity_handles, int entity_handles_size, EntityType order_adjacent_key, EntityType type_requested, std::vector< EntityHandle > &adjacent_entity_handles_out, int *offsets_out) const | iGeom | [inline, virtual] |
| getArr2ndDrvt(const EntityHandle *entities, int entities_size, StorageOrder order, const double *uv, int uv_size, double *dvtr_uu, double *dvtr_vv, double *dvtr_uv) const | iGeom | [inline, virtual] |
| getArrAdj(const EntityHandle *entity_handles, int entity_handles_size, EntityType type_requested, std::vector< EntityHandle > &adjacent_entity_handles_out, int *offsets_out) const | iGeom | [inline, virtual] |
| getArrBoundBox(const EntityHandle *entities, int entities_size, StorageOrder order, double *min_corners, double *max_corners) const | iGeom | [inline, virtual] |
| getArrClosestPt(const EntityHandle *handles, int handles_size, StorageOrder order, const double *near_coordinates, int near_coordinates_size, double *on_coordinates) const | iGeom | [inline, virtual] |
| getArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, void *tag_values_out) const | iGeom | [inline, virtual] |
| getArrEgEvalXYZ(const EntityHandle *edges, int edges_size, StorageOrder order, const double *near_coords, int near_coords_size, double *on_coords, double *tangent, double *curvature) const | iGeom | [inline, virtual] |
| getArrFcEvalXYZ(const EntityHandle *faces, int faces_size, StorageOrder order, const double *near_coords, int near_coords_size, double *on_coords, double *normal, double *curvature1, double *curvature2) const | iGeom | [inline, virtual] |
| getArrNrmlPlXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *near_xyz, int near_xyz_size, double *on_xyz, double *nrml_ijk) const | iGeom | [inline, virtual] |
| getArrNrmlSense(const EntityHandle *faces, int faces_size, const EntityHandle *vols, int vols_size, int *senses_out) const | iGeom | [inline, virtual] |
| getArrNrmlUV(const EntityHandle *faces, int faces_size, StorageOrder order, const double *uv, int uv_size, double *normals) const | iGeom | [inline, virtual] |
| getArrNrmlXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *xyz, int xyz_size, double *ijk) const | iGeom | [inline, virtual] |
| getArrSense(const EntityHandle *ent, int num_ents, EntityHandle wrt_ent, int *sense) const | iGeom | [inline, virtual] |
| getArrTgntU(const EntityHandle *edges, int edges_size, StorageOrder order, const double *u, int u_size, double *normals) const | iGeom | [inline, virtual] |
| getArrTgntXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *xyz, int xyz_size, double *ijk) const | iGeom | [inline, virtual] |
| getArrTolerance(const EntityHandle *entities, int entities_size, double *tolerances) const | iGeom | [inline, virtual] |
| getArrType(const EntityHandle *entity_handles, int entity_handles_Size, EntityType *types_out) const | iGeom | [inline, virtual] |
| getArrURange(const EntityHandle *edges, int edges_size, double *u_min, double *u_max) const | iGeom | [inline, virtual] |
| getArrUtoUV(const EntityHandle *edges, int edges_size, const EntityHandle *faces, int faces_size, const double *edge_u, int edge_u_size, StorageOrder order, double *face_uv) const | iGeom | [inline, virtual] |
| getArrUtoXYZ(const EntityHandle *edges, int edges_size, const double *u, int u_size, StorageOrder order, double *xyz) const | iGeom | [inline, virtual] |
| getArrUVRange(const EntityHandle *faces, int faces_size, StorageOrder order, double *uv_min, double *uv_max) const | iGeom | [inline, virtual] |
| getArrUVtoXYZ(const EntityHandle *faces, int faces_size, StorageOrder order, const double *uv, int uv_size, double *xyz) const | iGeom | [inline, virtual] |
| getArrXYZtoU(const EntityHandle *edges, int edges_size, StorageOrder order, const double *coords, int coords_size, double *u) const | iGeom | [inline, virtual] |
| getArrXYZtoUV(const EntityHandle *faces, int faces_size, StorageOrder order, const double *coords, int coords_size, double *uv) const | iGeom | [inline, virtual] |
| getArrXYZtoUVHint(const EntityHandle *faces, int faces_size, StorageOrder order, const double *coords, int coords_size, double *uv) const | iGeom | [inline, virtual] |
| getBoundBox(double &min_x, double &min_y, double &min_z, double &max_x, double &max_y, double &max_z) const | iGeom | [inline, virtual] |
| getChldn(EntitySetHandle parent, int num_hops, std::vector< EntitySetHandle > &children_out) const | iGeom | [inline, virtual] |
| getData(EntityHandle entity_handle, TagHandle tag_handle, void *tag_value_out) const | iGeom | [inline, virtual] |
| getDblArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, double *tag_values_out) const | iGeom | [inline, virtual] |
| getDblData(EntityHandle entity_handle, TagHandle tag_handle, double &value_out) const | iGeom | [inline, virtual] |
| getDescription() const | iGeom | [inline, virtual] |
| getEgCvtrXYZ(EntityHandle edge, double x, double y, double z, double &i, double &j, double &k) const | iGeom | [inline, virtual] |
| getEgEvalXYZ(EntityHandle edge, double x, double y, double z, double &on_x, double &on_y, double &on_z, double &tngt_i, double &tngt_j, double &tngt_k, double &cvtr_i, double &cvtr_j, double &cvtr_k) const | iGeom | [inline, virtual] |
| getEgFcArrSense(const EntityHandle *edges, int edges_size, const EntityHandle *faces, int faces_size, int *senses_out) const | iGeom | [inline, virtual] |
| getEgFcSense(EntityHandle edge, EntityHandle face, int &sense) const | iGeom | [inline, virtual] |
| getEgVtxArrSense(const EntityHandle *edges, int edges_size, const EntityHandle *vertices1, int vertices1_size, const EntityHandle *vertices2, int vertices2_size, int *senses_out) const | iGeom | [inline, virtual] |
| getEgVtxSense(EntityHandle edge, EntityHandle vtx1, EntityHandle vtx2, int &sense) const | iGeom | [inline, virtual] |
| getEHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, EntityHandle *tag_values_out) const | iGeom | [inline, virtual] |
| getEHData(EntityHandle entity_handle, TagHandle tag_handle, EntityHandle &value_out) const | iGeom | [inline, virtual] |
| getEnt1stDrvt(EntityHandle handle, double u, double v, double &du_i, double &du_j, double &du_k, double &dv_i, double &dv_j, double &dv_k) const | iGeom | [inline, virtual] |
| getEnt2ndAdj(EntityHandle handle, EntityType bridge_dimension, EntityType type_requested, std::vector< EntityHandle > &adj_entities_out) const | iGeom | [inline, virtual] |
| getEnt2ndDrvt(EntityHandle handle, double u, double v, double &duu_i, double &duu_j, double &duu_k, double &dvv_i, double &dvv_j, double &dvv_k, double &duv_i, double &duv_j, double &duv_k) const | iGeom | [inline, virtual] |
| getEntAdj(EntityHandle handle, EntityType type_requested, std::vector< EntityHandle > &adj_entities_out) const | iGeom | [inline, virtual] |
| getEntArrCvtrXYZ(const EntityHandle *entities, int entities_size, StorageOrder order, const double *xyz, int xyz_size, double *cvtr_1, double *cvtr_2) const | iGeom | [inline, virtual] |
| getEntBoundBox(EntityHandle entity, double &min_x, double &min_y, double &min_z, double &max_x, double &max_y, double &max_z) const | iGeom | [inline, virtual] |
| getEntClosestPt(EntityHandle entity, double near_x, double near_y, double near_z, double &on_x, double &on_y, double &on_z) const | iGeom | [inline, virtual] |
| getEntClosestPtTrimmed(EntityHandle entity, double near_x, double near_y, double near_z, double &on_x, double &on_y, double &on_z) const | iGeom | [inline, virtual] |
| getEntities(EntitySetHandle set, EntityType type, std::vector< EntityHandle > &entities_out) const | iGeom | [inline, virtual] |
| getEntNrmlPlXYZ(EntityHandle entity, double x, double y, double z, double &on_x, double &on_y, double &on_z, double &i, double &j, double &k) const | iGeom | [inline, virtual] |
| getEntNrmlSense(EntityHandle face, EntityHandle region, int &sense) const | iGeom | [inline, virtual] |
| getEntNrmlUV(EntityHandle face, double u, double v, double &i, double &j, double &k) const | iGeom | [inline, virtual] |
| getEntNrmlXYZ(EntityHandle entity, double x, double y, double z, double &i, double &j, double &k) const | iGeom | [inline, virtual] |
| getEntSetData(EntitySetHandle set_handle, TagHandle tag_handle, void *tag_value_out) const | iGeom | [inline, virtual] |
| getEntSetDblData(EntitySetHandle set_handle, TagHandle tag_handle, double &value_out) const | iGeom | [inline, virtual] |
| getEntSetEHData(EntitySetHandle set_handle, TagHandle tag_handle, EntityHandle &value_out) const | iGeom | [inline, virtual] |
| getEntSetESHData(EntitySetHandle set_handle, TagHandle tag_handle, EntitySetHandle &value_out) const | iGeom | [inline, virtual] |
| getEntSetIntData(EntitySetHandle set_handle, TagHandle tag_handle, int &value_out) const | iGeom | [inline, virtual] |
| getEntSets(EntitySetHandle set, int num_hops, std::vector< EntitySetHandle > &contained_sets_out) const | iGeom | [inline, virtual] |
| getEntTgntU(EntityHandle edge, double u, double &i, double &j, double &k) const | iGeom | [inline, virtual] |
| getEntTgntXYZ(EntityHandle entity, double x, double y, double z, double &i, double &j, double &k) const | iGeom | [inline, virtual] |
| getEntTolerance(EntityHandle entity, double &tolerance) const | iGeom | [inline, virtual] |
| getEntType(EntityHandle handle, EntityType &type_out) const | iGeom | [inline, virtual] |
| getEntURange(EntityHandle edge, double &u_min, double &u_max) const | iGeom | [inline, virtual] |
| getEntUtoUV(EntityHandle edge, EntityHandle face, double edge_u, double &face_u, double &face_v) const | iGeom | [inline, virtual] |
| getEntUtoXYZ(EntityHandle edge, double u, double &x, double &y, double &z) const | iGeom | [inline, virtual] |
| getEntUVRange(EntityHandle face, double &u_min, double &v_min, double &u_max, double &v_max) const | iGeom | [inline, virtual] |
| getEntUVtoXYZ(EntityHandle face, double u, double v, double &x, double &y, double &z) const | iGeom | [inline, virtual] |
| getEntXYZtoU(EntityHandle edge, double x, double y, double z, double &u) const | iGeom | [inline, virtual] |
| getEntXYZtoUV(EntityHandle face, double x, double y, double z, double &u, double &v) const | iGeom | [inline, virtual] |
| getEntXYZtoUVHint(EntityHandle face, double x, double y, double z, double &u, double &v) const | iGeom | [inline, virtual] |
| getErrorType() const | iGeom | [inline, virtual] |
| getESHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, EntitySetHandle *tag_values_out) const | iGeom | [inline, virtual] |
| getESHData(EntityHandle entity_handle, TagHandle tag_handle, EntitySetHandle &value_out) const | iGeom | [inline, virtual] |
| getFacets(EntityHandle entity_handle, double dist_tolerance, std::vector< double > &point, std::vector< int > &facets) const | iGeom | [inline, virtual] |
| getFaceType(EntityHandle face, std::string &type) const | iGeom | [inline, virtual] |
| getFcArrCvtrUV(const EntityHandle *faces, int faces_size, StorageOrder order, const double *uv, int uv_size, double *cvtr1, double *cvtr2) const | iGeom | [inline, virtual] |
| getFcCvtrUV(EntityHandle face, double u, double v, double &i1, double &j1, double &k1, double &i2, double &j2, double &k2) const | iGeom | [inline, virtual] |
| getFcCvtrXYZ(EntityHandle face, double x, double y, double z, double &i1, double &j1, double &k1, double &i2, double &j2, double &k2) const | iGeom | [inline, virtual] |
| getFcEvalXYZ(EntityHandle face, double x, double y, double z, double &on_x, double &on_y, double &on_z, double &nrml_i, double &nrml_j, double &nrml_k, double &cvtr1_i, double &cvtr1_j, double &cvtr1_k, double &cvtr2_i, double &cvtr2_j, double &cvtr2_k) const | iGeom | [inline, virtual] |
| getIntArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, int *tag_values_out) const | iGeom | [inline, virtual] |
| getIntData(EntityHandle entity_handle, TagHandle tag_handle, int &value_out) const | iGeom | [inline, virtual] |
| getNumChld(EntitySetHandle parent, int num_hops, int &num_child_out) const | iGeom | [inline, virtual] |
| getNumEntSets(EntitySetHandle set, int num_hops, int &num_sets_out) const | iGeom | [inline, virtual] |
| getNumOfType(EntitySetHandle set, EntityType type, int &count_out) const | iGeom | [inline, virtual] |
| getNumPrnt(EntitySetHandle child, int num_hops, int &num_parent_out) const | iGeom | [inline, virtual] |
| getParametric() | iGeom | [inline, virtual] |
| getPntArrClsf(StorageOrder order, const double *coords, int coords_size, EntityHandle *entities_out) const | iGeom | [inline, virtual] |
| getPntClsf(double x, double y, double z, EntityHandle &handle_out) const | iGeom | [inline, virtual] |
| getPntRayIntsct(double x, double y, double z, double i, double j, double k, StorageOrder order, std::vector< EntityHandle > &entities_out, std::vector< double > &points_out, std::vector< double > ¶ms_out) const | iGeom | [inline, virtual] |
| getPrnts(EntitySetHandle child, int num_hops, std::vector< EntitySetHandle > &parents_out) const | iGeom | [inline, virtual] |
| getRootSet() const | iGeom | [inline, virtual] |
| getSense(EntityHandle ent, EntityHandle wrt_ent, int &sense) const | iGeom | [inline, virtual] |
| getTagHandle(const char *name, TagHandle &handle_out) const | iGeom | [inline, virtual] |
| getTagName(TagHandle tag_handle, std::string &name_out) const | iGeom | [inline, virtual] |
| getTagSizeBytes(TagHandle tag_handle, int &size_out) const | iGeom | [inline, virtual] |
| getTagSizeValues(TagHandle tag_handle, int &size_out) const | iGeom | [inline, virtual] |
| getTagType(TagHandle tag_handle, TagValueType &type_out) const | iGeom | [inline, virtual] |
| getTolerance(int &type_out, double &tolerance_out) const | iGeom | [inline, virtual] |
| getVtxArrCoords(const EntityHandle *vertices, int vertices_size, StorageOrder order, double *coords) const | iGeom | [inline, virtual] |
| getVtxArrToU(const EntityHandle *vertices, int vertices_size, const EntityHandle *edges, int edges_size, double *edge_u) const | iGeom | [inline, virtual] |
| getVtxArrToUV(const EntityHandle *vertices, int vertices_size, const EntityHandle *faces, int faces_size, StorageOrder order, double *face_uv) const | iGeom | [inline, virtual] |
| getVtxCoord(EntityHandle vertex, double &x, double &y, double &z) const | iGeom | [inline, virtual] |
| getVtxToU(EntityHandle vertex, EntityHandle edge, double &u) const | iGeom | [inline, virtual] |
| getVtxToUV(EntityHandle vertex, EntityHandle face, double &u, double &v) const | iGeom | [inline, virtual] |
| iface_type() const | iGeom | [inline, virtual] |
| iGeom(const char *options=0) | iGeom | [inline] |
| iGeom(iGeom_Instance instance) | iGeom | [inline] |
| iGeom(bool meshBased) | iGeom | [inline] |
| iGeom(const iGeom &) | iGeom | [inline, private] |
| iGeomInstanceOwner | iGeom | [private] |
| imprintEnts(const EntityHandle *entities, int entities_size) | iGeom | [inline, virtual] |
| initEntArrIter(EntitySetHandle set, EntityType requested_type, int requested_array_size, EntArrIter &iter) | iGeom | [inline, virtual] |
| initEntIter(EntitySetHandle set, EntityType requested_type, EntIter &iter) | iGeom | [inline, virtual] |
| instance() | iGeom | [inline] |
| intersect(EntitySetHandle set1, EntitySetHandle set2, EntitySetHandle &result_set_out) | iGeom | [inline, virtual] |
| intersectEnts(EntityHandle entity1, EntityHandle entity2, EntityHandle &result) | iGeom | [inline, virtual] |
| isArrAdj(const EntityHandle *entities1, const EntityHandle *entities2, int num_entity_pairs, int *is_adj_out) const | iGeom | [inline, virtual] |
| isArrParametric(const EntityHandle *entities, int entities_size, int *is_parametric) const | iGeom | [inline, virtual] |
| isArrPeriodic(const EntityHandle *entities, int entities_size, int *in_uv) const | iGeom | [inline, virtual] |
| isChildOf(EntitySetHandle parent, EntitySetHandle child, bool &is_child_out) const | iGeom | [inline, virtual] |
| isEntAdj(EntityHandle entity1, EntityHandle entity2, bool &adjacent_out) const | iGeom | [inline, virtual] |
| isEntArrContained(EntitySetHandle containing_set, const EntityHandle *entity_handles, int num_entity_handles, bool *is_contained_out) const | iGeom | [inline, virtual] |
| isEntContained(EntitySetHandle set, EntityHandle ent, bool &contained_out) const | iGeom | [inline, virtual] |
| isEntParametric(EntityHandle entity, bool ¶metric) const | iGeom | [inline, virtual] |
| isEntPeriodic(EntityHandle entity, bool &in_u, bool &in_v) const | iGeom | [inline, virtual] |
| isEntSetContained(EntitySetHandle containing_set, EntitySetHandle contained_set, bool &contained_out) const | iGeom | [inline, virtual] |
| isFBiGeom() | iGeom | [inline, virtual] |
| isFcArrDegenerate(const EntityHandle *faces, int faces_size, int *degenerate) const | iGeom | [inline, virtual] |
| isFcDegenerate(EntityHandle face, bool &is_degenerate) const | iGeom | [inline, virtual] |
| isList(EntitySetHandle handle, bool &is_list) | iGeom | [inline, virtual] |
| load(const char *file_name, const char *options=0) | iGeom | [inline, virtual] |
| measure(const EntityHandle *entities, int entities_size, double *measures) const | iGeom | [inline, virtual] |
| mergeEnts(const EntityHandle *entities, int entities_size, double tolerance) | iGeom | [inline, virtual] |
| mInstance | iGeom | [protected] |
| moveEnt(EntityHandle entity, double x, double y, double z) | iGeom | [inline, virtual] |
| operator=(const iGeom &) | iGeom | [inline, private] |
| reflectEnt(EntityHandle entity, double x, double y, double z, double norm_x, double norm_y, double norm_z) | iGeom | [inline, virtual] |
| rmvArrTag(const EntityHandle *handles, int size, TagHandle tag) | iGeom | [inline, virtual] |
| rmvEntArrFromSet(const EntityHandle *entity_handles, int entity_handles_size, EntitySetHandle entity_set) | iGeom | [inline, virtual] |
| rmvEntFromSet(EntityHandle entity, EntitySetHandle set) | iGeom | [inline, virtual] |
| rmvEntSet(EntitySetHandle to_rmv, EntitySetHandle rmv_from) | iGeom | [inline, virtual] |
| rmvEntSetTag(EntitySetHandle set, TagHandle tag) | iGeom | [inline, virtual] |
| rmvPrntChld(EntitySetHandle parent, EntitySetHandle child) | iGeom | [inline, virtual] |
| rmvTag(EntityHandle entity, TagHandle tag) | iGeom | [inline, virtual] |
| rotateEnt(EntityHandle entity, double angle, double axis_x, double axis_y, double axis_z) | iGeom | [inline, virtual] |
| save(const char *file_name, const char *options=0) | iGeom | [inline, virtual] |
| scaleEnt(EntityHandle entity, double x, double y, double z, double x_factor, double y_factor, double z_factor) | iGeom | [inline, virtual] |
| sectionEnt(EntityHandle entity, double plane_x, double plane_y, double plane_z, double offset, bool reverse, EntityHandle &result) | iGeom | [inline, virtual] |
| setArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const void *tag_values) | iGeom | [inline, virtual] |
| setData(EntityHandle entity_handle, TagHandle tag_handle, const void *tag_value) | iGeom | [inline, virtual] |
| setDblArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const double *tag_values) | iGeom | [inline, virtual] |
| setDblData(EntityHandle entity_handle, TagHandle tag_handle, double value) | iGeom | [inline, virtual] |
| setEHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const EntityHandle *tag_values) | iGeom | [inline, virtual] |
| setEHData(EntityHandle entity_handle, TagHandle tag_handle, EntityHandle value) | iGeom | [inline, virtual] |
| setEntSetData(EntitySetHandle set_handle, TagHandle tag_handle, const void *tag_value) | iGeom | [inline, virtual] |
| setEntSetDblData(EntitySetHandle set_handle, TagHandle tag_handle, double value) | iGeom | [inline, virtual] |
| setEntSetEHData(EntitySetHandle set_handle, TagHandle tag_handle, EntityHandle value) | iGeom | [inline, virtual] |
| setEntSetESHData(EntitySetHandle set_handle, TagHandle tag_handle, EntitySetHandle value) | iGeom | [inline, virtual] |
| setEntSetIntData(EntitySetHandle set_handle, TagHandle tag_handle, int value) | iGeom | [inline, virtual] |
| setESHArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const EntitySetHandle *tag_values) | iGeom | [inline, virtual] |
| setESHData(EntityHandle entity_handle, TagHandle tag_handle, EntitySetHandle value) | iGeom | [inline, virtual] |
| setIntArrData(const EntityHandle *entity_handles, int entity_handles_size, TagHandle tag_handle, const int *tag_values) | iGeom | [inline, virtual] |
| setIntData(EntityHandle entity_handle, TagHandle tag_handle, int value) | iGeom | [inline, virtual] |
| StorageOrder typedef | iGeom | |
| subtract(EntitySetHandle set1, EntitySetHandle set2, EntitySetHandle &result_set_out) | iGeom | [inline, virtual] |
| subtractEnts(EntityHandle blank, EntityHandle tool, EntityHandle &result) | iGeom | [inline, virtual] |
| sweepEntAboutAxis(EntityHandle entity, double angle, double axis_x, double axis_y, double axis_z, EntityHandle &swept_entity) | iGeom | [inline, virtual] |
| TagHandle typedef | iGeom | |
| TagValueType typedef | iGeom | |
| unite(EntitySetHandle set1, EntitySetHandle set2, EntitySetHandle &result_set_out) | iGeom | [inline, virtual] |
| uniteEnts(const EntityHandle *entities, int entities_size, EntityHandle &result_entity) | iGeom | [inline, virtual] |
| ~iGeom() | iGeom | [inline, virtual] |
