Mesh Oriented datABase
(version 5.4.1)
| _incells | moab::NestedRefine | [protected] |
| _inedges | moab::NestedRefine | [protected] |
| _infaces | moab::NestedRefine | [protected] |
| _inverts | moab::NestedRefine | [protected] |
| _rset | moab::NestedRefine | [protected] |
| ahf | moab::NestedRefine | [protected] |
| child_to_parent(EntityHandle child, int child_level, int parent_level, EntityHandle *parent) | moab::NestedRefine | |
| compute_coordinates(int cur_level, int deg, EntityType type, EntityHandle *vbuffer, int vtotal, double *corner_coords, std::vector< int > &vflag, int nverts_prev) | moab::NestedRefine | [protected] |
| construct_hm_1D(int cur_level, int deg) | moab::NestedRefine | [protected] |
| construct_hm_1D(int cur_level, int deg, EntityType type, std::vector< EntityHandle > &trackverts) | moab::NestedRefine | [protected] |
| construct_hm_2D(int cur_level, int deg) | moab::NestedRefine | [protected] |
| construct_hm_2D(int cur_level, int deg, EntityType type, std::vector< EntityHandle > &trackvertsC_edg, std::vector< EntityHandle > &trackvertsF) | moab::NestedRefine | [protected] |
| construct_hm_3D(int cur_level, int deg) | moab::NestedRefine | [protected] |
| construct_hm_entities(int cur_level, int deg) | moab::NestedRefine | [protected] |
| copy_vertices_from_prev_level(int cur_level) | moab::NestedRefine | [protected] |
| count_subentities(EntityHandle set, int cur_level, int *nedges, int *nfaces) | moab::NestedRefine | [protected] |
| create_hm_storage_single_level(EntityHandle *set, int cur_level, int estL[4]) | moab::NestedRefine | [protected] |
| deg_index | moab::NestedRefine | [protected] |
| elementype | moab::NestedRefine | [protected] |
| estimate_hm_storage(EntityHandle set, int level_degree, int cur_level, int hmest[4]) | moab::NestedRefine | [protected] |
| exchange_ghosts(std::vector< EntityHandle > &lsets, int num_glayers) | moab::NestedRefine | |
| find_shortest_diagonal_octahedron(int cur_level, int deg, EntityHandle *vbuffer) | moab::NestedRefine | [protected] |
| generate_hm(int *level_degrees, int num_level, EntityHandle *hm_set, bool optimize) | moab::NestedRefine | [protected] |
| generate_mesh_hierarchy(int num_level, int *level_degrees, std::vector< EntityHandle > &level_sets, bool optimize=false) | moab::NestedRefine | |
| get_adjacencies(const EntityHandle source_entity, const unsigned int target_dimension, std::vector< EntityHandle > &target_entities) | moab::NestedRefine | |
| get_connectivity(EntityHandle ent, int level, std::vector< EntityHandle > &conn) | moab::NestedRefine | |
| get_coordinates(EntityHandle *verts, int num_verts, int level, double *coords) | moab::NestedRefine | |
| get_index_from_degree(int degree) | moab::NestedRefine | [protected] |
| get_lid_inci_child(EntityType type, int deg, int lfid, int leid, std::vector< int > &child_ids, std::vector< int > &child_lvids) | moab::NestedRefine | [protected] |
| get_local_vid(EntityHandle vid, EntityHandle ent, int level) | moab::NestedRefine | [protected] |
| get_octahedron_corner_coords(int cur_level, int deg, EntityHandle *vbuffer, double *ocoords) | moab::NestedRefine | [protected] |
| get_vertex_duplicates(EntityHandle vertex, int level, EntityHandle &dupvertex) | moab::NestedRefine | |
| hasghost | moab::NestedRefine | [protected] |
| initialize() | moab::NestedRefine | |
| intFacEdg | moab::NestedRefine | [protected, static] |
| is_cell_on_boundary(const EntityHandle &entity) | moab::NestedRefine | [protected] |
| is_edge_on_boundary(const EntityHandle &entity) | moab::NestedRefine | [protected] |
| is_entity_on_boundary(const EntityHandle &entity) | moab::NestedRefine | |
| is_face_on_boundary(const EntityHandle &entity) | moab::NestedRefine | [protected] |
| is_vertex_on_boundary(const EntityHandle &entity) | moab::NestedRefine | [protected] |
| level_dsequence | moab::NestedRefine | [protected] |
| level_mesh | moab::NestedRefine | [protected] |
| mbImpl | moab::NestedRefine | [protected] |
| meshdim | moab::NestedRefine | [protected] |
| NestedRefine(Core *impl, ParallelComm *comm=0, EntityHandle rset=0) | moab::NestedRefine | |
| nlevels | moab::NestedRefine | [protected] |
| parent_to_child(EntityHandle parent, int parent_level, int child_level, std::vector< EntityHandle > &children) | moab::NestedRefine | |
| pcomm | moab::NestedRefine | [protected] |
| permutation | moab::NestedRefine | [protected, static] |
| print_maps_1D(int level) | moab::NestedRefine | [protected] |
| print_maps_2D(int level, EntityType type) | moab::NestedRefine | [protected] |
| print_maps_3D(int level, EntityType type) | moab::NestedRefine | [protected] |
| refTemplates | moab::NestedRefine | [protected, static] |
| reorder_indices(int cur_level, int deg, EntityHandle cell, int lfid, EntityHandle sib_cell, int sib_lfid, int index, int *id_sib) | moab::NestedRefine | [protected] |
| reorder_indices(int deg, EntityHandle *face1_conn, EntityHandle *face2_conn, int nvF, std::vector< int > &lemap, std::vector< int > &vidx, int *leorient=NULL) | moab::NestedRefine | [protected] |
| reorder_indices(int deg, int nvF, int comb, int *childfid_map) | moab::NestedRefine | [protected] |
| reorder_indices(EntityHandle *face1_conn, EntityHandle *face2_conn, int nvF, int *conn_map, int &comb, int *orient=NULL) | moab::NestedRefine | [protected] |
| subdivide_cells(EntityType type, int cur_level, int deg) | moab::NestedRefine | [protected] |
| subdivide_tets(int cur_level, int deg) | moab::NestedRefine | [protected] |
| timeall | moab::NestedRefine | |
| tm | moab::NestedRefine | [protected] |
| update_ahf_1D(int cur_level) | moab::NestedRefine | [protected] |
| update_global_ahf(EntityType type, int cur_level, int deg, std::vector< int > *pattern_ids=NULL) | moab::NestedRefine | [protected] |
| update_global_ahf_1D(int cur_level, int deg) | moab::NestedRefine | [protected] |
| update_global_ahf_1D_sub(int cur_level, int deg) | moab::NestedRefine | [protected] |
| update_global_ahf_2D(int cur_level, int deg) | moab::NestedRefine | [protected] |
| update_global_ahf_2D_sub(int cur_level, int deg) | moab::NestedRefine | [protected] |
| update_global_ahf_3D(int cur_level, int deg, std::vector< int > *pattern_ids=NULL) | moab::NestedRefine | [protected] |
| update_local_ahf(int deg, EntityType type, EntityHandle *vbuffer, EntityHandle *ent_buffer, int etotal) | moab::NestedRefine | [protected] |
| update_local_ahf(int deg, EntityType type, int pat_id, EntityHandle *vbuffer, EntityHandle *ent_buffer, int etotal) | moab::NestedRefine | [protected] |
| update_special_tags(int level, EntityHandle &lset) | moab::NestedRefine | |
| update_tracking_verts(EntityHandle cid, int cur_level, int deg, std::vector< EntityHandle > &trackvertsC_edg, std::vector< EntityHandle > &trackvertsC_face, EntityHandle *vbuffer) | moab::NestedRefine | [protected] |
| vertex_to_entities_down(EntityHandle vertex, int vert_level, int child_level, std::vector< EntityHandle > &incident_entities) | moab::NestedRefine | |
| vertex_to_entities_up(EntityHandle vertex, int vert_level, int parent_level, std::vector< EntityHandle > &incident_entities) | moab::NestedRefine | |
| ~NestedRefine() | moab::NestedRefine |
