Mesh Oriented datABase
(version 5.4.1)
| AdjacencyDataType typedef | moab::SequenceData | |
| allocate_adjacency_data() | moab::SequenceData | |
| allocate_tag_array(int index, int bytes_per_ent, const void *default_value=0) | moab::SequenceData | |
| arraySet | moab::SequenceData | [private] |
| copy_data_subset(int index, int size_per_ent, const void *source, size_t offset, size_t count) | moab::SequenceData | [private] |
| create_custom_data(int array_num, size_t total_bytes) | moab::SequenceData | |
| create_data(int index, int bytes_per_ent, const void *initial_val=0) | moab::SequenceData | [private] |
| create_sequence_data(int array_num, int bytes_per_ent, const void *initial_val=0) | moab::SequenceData | |
| end_handle() const | moab::SequenceData | [inline] |
| endHandle | moab::SequenceData | [private] |
| get_adjacency_data() | moab::SequenceData | [inline] |
| get_adjacency_data() const | moab::SequenceData | [inline] |
| get_sequence_data(int array_num) | moab::SequenceData | [inline] |
| get_sequence_data(int array_num) const | moab::SequenceData | [inline] |
| get_tag_data(unsigned tag_num) | moab::SequenceData | [inline] |
| get_tag_data(unsigned tag_num) const | moab::SequenceData | [inline] |
| increase_tag_count(unsigned by_this_many) | moab::SequenceData | [private] |
| move_tag_data(SequenceData *destination, const int *tag_sizes, int num_tag_sizes) | moab::SequenceData | |
| numSequenceData | moab::SequenceData | [private] |
| numTagData | moab::SequenceData | [private] |
| release_tag_data(const int *tag_sizes, int num_tag_sizes) | moab::SequenceData | |
| release_tag_data(int index, int tag_size) | moab::SequenceData | |
| seqManData | moab::SequenceData | |
| SequenceData(int num_sequence_arrays, EntityHandle start, EntityHandle end) | moab::SequenceData | [inline] |
| SequenceData(const SequenceData *subset_from, EntityHandle start, EntityHandle end, const int *sequence_data_sizes) | moab::SequenceData | [protected] |
| size() const | moab::SequenceData | [inline] |
| start_handle() const | moab::SequenceData | [inline] |
| startHandle | moab::SequenceData | [private] |
| subset(EntityHandle start, EntityHandle end, const int *sequence_data_sizes) const | moab::SequenceData | |
| ~SequenceData() | moab::SequenceData | [virtual] |
