moab::ParallelComm Class Reference
Parallel communications in MOAB. More...
#include <ParallelComm.hpp>
+ Collaboration diagram for moab::ParallelComm:
Classes
class  Buffer
struct  SharedEntityData
Public Member Functions
 ParallelComm (Interface *impl, MPI_Comm comm, int *pcomm_id_out=0)
 constructor
 ParallelComm (Interface *impl, std::vector< unsigned char > &tmp_buff, MPI_Comm comm, int *pcomm_id_out=0)
 constructor taking packed buffer, for testing
int get_id () const
 Get ID used to reference this PCOMM instance.
 ~ParallelComm ()
 destructor
ErrorCode assign_global_ids (EntityHandle this_set, const int dimension, const int start_id=1, const bool largest_dim_only=true, const bool parallel=true, const bool owned_only=false)
ErrorCode assign_global_ids (Range entities[], const int dimension, const int start_id, const bool parallel, const bool owned_only)
ErrorCode check_global_ids (EntityHandle this_set, const int dimension, const int start_id=1, const bool largest_dim_only=true, const bool parallel=true, const bool owned_only=false)
ErrorCode send_entities (const int to_proc, Range &orig_ents, const bool adjs, const bool tags, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incoming1, int &incoming2, TupleList &entprocs, std::vector< MPI_Request > &recv_remoteh_reqs, bool wait_all=true)
 send entities to another processor, optionally waiting until it's done
ErrorCode send_entities (std::vector< unsigned int > &send_procs, std::vector< Range * > &send_ents, int &incoming1, int &incoming2, const bool store_remote_handles)
ErrorCode recv_entities (const int from_proc, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incomming1, int &incoming2, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs, bool wait_all=true)
 Receive entities from another processor, optionally waiting until it's done.
ErrorCode recv_entities (std::set< unsigned int > &recv_procs, int incoming1, int incoming2, const bool store_remote_handles, const bool migrate=false)
ErrorCode recv_messages (const int from_proc, const bool store_remote_handles, const bool is_iface, Range &final_ents, int &incoming1, int &incoming2, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs)
 Receive messages from another processor in while loop.
ErrorCode recv_remote_handle_messages (const int from_proc, int &incoming2, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< MPI_Request > &recv_remoteh_reqs)
ErrorCode exchange_ghost_cells (int ghost_dim, int bridge_dim, int num_layers, int addl_ents, bool store_remote_handles, bool wait_all=true, EntityHandle *file_set=NULL)
 Exchange ghost cells with neighboring procs Neighboring processors are those sharing an interface with this processor. All entities of dimension ghost_dim within num_layers of interface, measured going through bridge_dim, are exchanged. See MeshTopoUtil::get_bridge_adjacencies for description of bridge adjacencies. If wait_all is false and store_remote_handles is true, MPI_Request objects are available in the sendReqs[2*MAX_SHARING_PROCS] member array, with inactive requests marked as MPI_REQUEST_NULL. If store_remote_handles or wait_all is false, this function returns after all entities have been received and processed.
ErrorCode post_irecv (std::vector< unsigned int > &exchange_procs)
 Post "MPI_Irecv" before meshing.
ErrorCode post_irecv (std::vector< unsigned int > &shared_procs, std::set< unsigned int > &recv_procs)
ErrorCode exchange_owned_meshs (std::vector< unsigned int > &exchange_procs, std::vector< Range * > &exchange_ents, std::vector< MPI_Request > &recv_ent_reqs, std::vector< MPI_Request > &recv_remoteh_reqs, bool store_remote_handles, bool wait_all=true, bool migrate=false, int dim=0)
 Exchange owned mesh for input mesh entities and sets This function should be called collectively over the communicator for this ParallelComm. If this version is called, all shared exchanged entities should have a value for this tag (or the tag should have a default value).
ErrorCode exchange_owned_mesh (std::vector< unsigned int > &exchange_procs, std::vector< Range * > &exchange_ents, std::vector< MPI_Request > &recv_ent_reqs, std::vector< MPI_Request > &recv_remoteh_reqs, const bool recv_posted, bool store_remote_handles, bool wait_all, bool migrate=false)
 Exchange owned mesh for input mesh entities and sets This function is called twice by exchange_owned_meshs to exchange entities before sets.
ErrorCode exchange_tags (const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const Range &entities)
 Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective.
ErrorCode exchange_tags (const char *tag_name, const Range &entities)
 Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective.
ErrorCode exchange_tags (Tag tagh, const Range &entities)
ErrorCode reduce_tags (const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const MPI_Op mpi_op, const Range &entities)
 Perform data reduction operation for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). Operation is any MPI_Op, with result stored in destination tag.
ErrorCode reduce_tags (const char *tag_name, const MPI_Op mpi_op, const Range &entities)
 Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by name.
ErrorCode reduce_tags (Tag tag_handle, const MPI_Op mpi_op, const Range &entities)
 Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by handle.
ErrorCode broadcast_entities (const int from_proc, Range &entities, const bool adjacencies=false, const bool tags=true)
 Broadcast all entities resident on from_proc to other processors This function assumes remote handles are *not* being stored, since (usually) every processor will know about the whole mesh.
ErrorCode scatter_entities (const int from_proc, std::vector< Range > &entities, const bool adjacencies=false, const bool tags=true)
 Scatter entities on from_proc to other processors This function assumes remote handles are *not* being stored, since (usually) every processor will know about the whole mesh.
ErrorCode send_recv_entities (std::vector< int > &send_procs, std::vector< std::vector< int > > &msgsizes, std::vector< std::vector< EntityHandle > > &senddata, std::vector< std::vector< EntityHandle > > &recvdata)
 Send and receives data from a set of processors.
ErrorCode update_remote_data (EntityHandle entity, std::vector< int > &procs, std::vector< EntityHandle > &handles)
ErrorCode get_remote_handles (EntityHandle *local_vec, EntityHandle *rem_vec, int num_ents, int to_proc)
ErrorCode resolve_shared_ents (EntityHandle this_set, Range &proc_ents, int resolve_dim=-1, int shared_dim=-1, Range *skin_ents=NULL, const Tag *id_tag=0)
 Resolve shared entities between processors.
ErrorCode resolve_shared_ents (EntityHandle this_set, int resolve_dim=3, int shared_dim=-1, const Tag *id_tag=0)
ErrorCode resolve_shared_sets (EntityHandle this_set, const Tag *id_tag=0)
ErrorCode resolve_shared_sets (Range &candidate_sets, Tag id_tag)
ErrorCode augment_default_sets_with_ghosts (EntityHandle file_set)
ErrorCode get_pstatus (EntityHandle entity, unsigned char &pstatus_val)
 Get parallel status of an entity Returns the parallel status of an entity.
ErrorCode get_pstatus_entities (int dim, unsigned char pstatus_val, Range &pstatus_ents)
 Get entities with the given pstatus bit(s) set Returns any entities whose pstatus tag value v satisfies (v & pstatus_val)
ErrorCode get_owner (EntityHandle entity, int &owner)
 Return the rank of the entity owner.
ErrorCode get_owner_handle (EntityHandle entity, int &owner, EntityHandle &handle)
 Return the owner processor and handle of a given entity.
ErrorCode get_sharing_data (const EntityHandle entity, int *ps, EntityHandle *hs, unsigned char &pstat, unsigned int &num_ps)
 Get the shared processors/handles for an entity Get the shared processors/handles for an entity. Arrays must be large enough to receive data for all sharing procs. Does *not* include this proc if only shared with one other proc.
ErrorCode get_sharing_data (const EntityHandle entity, int *ps, EntityHandle *hs, unsigned char &pstat, int &num_ps)
 Get the shared processors/handles for an entity Same as other version but with int num_ps.
ErrorCode get_sharing_data (const EntityHandle *entities, int num_entities, std::set< int > &procs, int op=Interface::INTERSECT)
 Get the intersection or union of all sharing processors Get the intersection or union of all sharing processors. Processor set is cleared as part of this function.
ErrorCode get_sharing_data (const Range &entities, std::set< int > &procs, int op=Interface::INTERSECT)
 Get the intersection or union of all sharing processors Same as previous variant but with range as input.
ErrorCode get_shared_entities (int other_proc, Range &shared_ents, int dim=-1, const bool iface=false, const bool owned_filter=false)
 Get shared entities of specified dimension If other_proc is -1, any shared entities are returned. If dim is -1, entities of all dimensions on interface are returned.
ErrorCode get_interface_procs (std::set< unsigned int > &iface_procs, const bool get_buffs=false)
 get processors with which this processor shares an interface
ErrorCode get_comm_procs (std::set< unsigned int > &procs)
 get processors with which this processor communicates
ErrorCode get_entityset_procs (EntityHandle entity_set, std::vector< unsigned > &ranks) const
ErrorCode get_entityset_owner (EntityHandle entity_set, unsigned &owner_rank, EntityHandle *remote_handle=0) const
ErrorCode get_entityset_local_handle (unsigned owning_rank, EntityHandle remote_handle, EntityHandle &local_handle) const
 Given set owner and handle on owner, find local set handle.
ErrorCode get_shared_sets (Range &result) const
 Get all shared sets.
ErrorCode get_entityset_owners (std::vector< unsigned > &ranks) const
ErrorCode get_owned_sets (unsigned owning_rank, Range &sets_out) const
 Get shared sets owned by process with specified rank.
const ProcConfigproc_config () const
 Get proc config for this communication object.
unsigned rank () const
unsigned size () const
MPI_Comm comm () const
ErrorCode get_shared_proc_tags (Tag &sharedp_tag, Tag &sharedps_tag, Tag &sharedh_tag, Tag &sharedhs_tag, Tag &pstatus_tag)
 return the tags used to indicate shared procs and handles
Rangepartition_sets ()
 return partition, interface set ranges
const Rangepartition_sets () const
Rangeinterface_sets ()
const Rangeinterface_sets () const
Tag sharedp_tag ()
 return sharedp tag
Tag sharedps_tag ()
 return sharedps tag
Tag sharedh_tag ()
 return sharedh tag
Tag sharedhs_tag ()
 return sharedhs tag
Tag pstatus_tag ()
 return pstatus tag
Tag partition_tag ()
 return partitions set tag
Tag part_tag ()
void print_pstatus (unsigned char pstat, std::string &ostr)
 print contents of pstatus value in human-readable form
void print_pstatus (unsigned char pstat)
 print contents of pstatus value in human-readable form to std::cut
ErrorCode get_part_entities (Range &ents, int dim=-1)
 return all the entities in parts owned locally
EntityHandle get_partitioning () const
ErrorCode set_partitioning (EntityHandle h)
ErrorCode get_global_part_count (int &count_out) const
ErrorCode get_part_owner (int part_id, int &owner_out) const
ErrorCode get_part_id (EntityHandle part, int &id_out) const
ErrorCode get_part_handle (int id, EntityHandle &handle_out) const
ErrorCode create_part (EntityHandle &part_out)
ErrorCode destroy_part (EntityHandle part)
ErrorCode collective_sync_partition ()
ErrorCode get_part_neighbor_ids (EntityHandle part, int neighbors_out[MAX_SHARING_PROCS], int &num_neighbors_out)
ErrorCode get_interface_sets (EntityHandle part, Range &iface_sets_out, int *adj_part_id=0)
ErrorCode get_owning_part (EntityHandle entity, int &owning_part_id_out, EntityHandle *owning_handle=0)
ErrorCode get_sharing_parts (EntityHandle entity, int part_ids_out[MAX_SHARING_PROCS], int &num_part_ids_out, EntityHandle remote_handles[MAX_SHARING_PROCS]=0)
ErrorCode filter_pstatus (Range &ents, const unsigned char pstatus_val, const unsigned char op, int to_proc=-1, Range *returned_ents=NULL)
ErrorCode get_iface_entities (int other_proc, int dim, Range &iface_ents)
 Get entities on interfaces shared with another proc.
Interfaceget_moab () const
ErrorCode clean_shared_tags (std::vector< Range * > &exchange_ents)
ErrorCode pack_buffer (Range &orig_ents, const bool adjacencies, const bool tags, const bool store_remote_handles, const int to_proc, Buffer *buff, TupleList *entprocs=NULL, Range *allsent=NULL)
 public 'cuz we want to unit test these externally
ErrorCode unpack_buffer (unsigned char *buff_ptr, const bool store_remote_handles, const int from_proc, const int ind, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< EntityHandle > &new_ents, const bool created_iface=false)
ErrorCode pack_entities (Range &entities, Buffer *buff, const bool store_remote_handles, const int to_proc, const bool is_iface, TupleList *entprocs=NULL, Range *allsent=NULL)
ErrorCode unpack_entities (unsigned char *&buff_ptr, const bool store_remote_handles, const int from_ind, const bool is_iface, std::vector< std::vector< EntityHandle > > &L1hloc, std::vector< std::vector< EntityHandle > > &L1hrem, std::vector< std::vector< int > > &L1p, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, std::vector< EntityHandle > &new_ents, const bool created_iface=false)
 unpack entities in buff_ptr
ErrorCode check_all_shared_handles (bool print_em=false)
ErrorCode pack_shared_handles (std::vector< std::vector< SharedEntityData > > &send_data)
ErrorCode check_local_shared ()
ErrorCode check_my_shared_handles (std::vector< std::vector< SharedEntityData > > &shents, const char *prefix=NULL)
void set_rank (unsigned int r)
 set rank for this pcomm; USED FOR TESTING ONLY!
void set_size (unsigned int r)
int get_buffers (int to_proc, bool *is_new=NULL)
const std::vector< unsigned int > & buff_procs () const
 get buff processor vector
ErrorCode unpack_remote_handles (unsigned int from_proc, unsigned char *&buff_ptr, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p)
ErrorCode pack_remote_handles (std::vector< EntityHandle > &L1hloc, std::vector< EntityHandle > &L1hrem, std::vector< int > &procs, unsigned int to_proc, Buffer *buff)
ErrorCode create_interface_sets (std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs)
ErrorCode create_interface_sets (EntityHandle this_set, int resolve_dim, int shared_dim)
ErrorCode tag_shared_verts (TupleList &shared_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs, Range &proc_verts, unsigned int i_extra=1)
ErrorCode list_entities (const EntityHandle *ents, int num_ents)
ErrorCode list_entities (const Range &ents)
void set_send_request (int n_request)
void set_recv_request (int n_request)
void reset_all_buffers ()
 reset message buffers to their initial state
void set_debug_verbosity (int verb)
 set the verbosity level of output from this pcomm
int get_debug_verbosity ()
 get the verbosity level of output from this pcomm
ErrorCode gather_data (Range &gather_ents, Tag &tag_handle, Tag id_tag=0, EntityHandle gather_set=0, int root_proc_rank=0)
ErrorCode settle_intersection_points (Range &edges, Range &shared_edges_owned, std::vector< std::vector< EntityHandle > * > &extraNodesVec, double tolerance)
ErrorCode delete_entities (Range &to_delete)
ErrorCode correct_thin_ghost_layers ()
Static Public Member Functions
static ParallelCommget_pcomm (Interface *impl, const int index)
 get the indexed pcomm object from the interface
static ParallelCommget_pcomm (Interface *impl, EntityHandle partitioning, const MPI_Comm *comm=0)
static ErrorCode get_all_pcomm (Interface *impl, std::vector< ParallelComm * > &list)
static ErrorCode exchange_ghost_cells (ParallelComm **pc, unsigned int num_procs, int ghost_dim, int bridge_dim, int num_layers, int addl_ents, bool store_remote_handles, EntityHandle *file_sets=NULL)
 Static version of exchange_ghost_cells, exchanging info through buffers rather than messages.
static ErrorCode resolve_shared_ents (ParallelComm **pc, const unsigned int np, EntityHandle this_set, const int to_dim)
static Tag pcomm_tag (Interface *impl, bool create_if_missing=true)
 return pcomm tag; passes in impl 'cuz this is a static function
static ErrorCode check_all_shared_handles (ParallelComm **pcs, int num_pcs)
Static Public Attributes
static unsigned char PROC_SHARED
static unsigned char PROC_OWNER
static const unsigned int INITIAL_BUFF_SIZE = 1024
Private Member Functions
ErrorCode reduce_void (int tag_data_type, const MPI_Op mpi_op, int num_ents, void *old_vals, void *new_vals)
template<class T >
ErrorCode reduce (const MPI_Op mpi_op, int num_ents, void *old_vals, void *new_vals)
void print_debug_isend (int from, int to, unsigned char *buff, int tag, int size)
void print_debug_irecv (int to, int from, unsigned char *buff, int size, int tag, int incoming)
void print_debug_recd (MPI_Status status)
void print_debug_waitany (std::vector< MPI_Request > &reqs, int tag, int proc)
void initialize ()
ErrorCode set_sharing_data (EntityHandle ent, unsigned char pstatus, int old_nump, int new_nump, int *ps, EntityHandle *hs)
ErrorCode check_clean_iface (Range &allsent)
void define_mpe ()
ErrorCode get_sent_ents (const bool is_iface, const int bridge_dim, const int ghost_dim, const int num_layers, const int addl_ents, Range *sent_ents, Range &allsent, TupleList &entprocs)
ErrorCode set_pstatus_entities (Range &pstatus_ents, unsigned char pstatus_val, bool lower_dim_ents=false, bool verts_too=true, int operation=Interface::UNION)
 Set pstatus values on entities.
ErrorCode set_pstatus_entities (EntityHandle *pstatus_ents, int num_ents, unsigned char pstatus_val, bool lower_dim_ents=false, bool verts_too=true, int operation=Interface::UNION)
 Set pstatus values on entities (vector-based function)
int estimate_ents_buffer_size (Range &entities, const bool store_remote_handles)
 estimate size required to pack entities
int estimate_sets_buffer_size (Range &entities, const bool store_remote_handles)
 estimate size required to pack sets
ErrorCode send_buffer (const unsigned int to_proc, Buffer *send_buff, const int msg_tag, MPI_Request &send_req, MPI_Request &ack_recv_req, int *ack_buff, int &this_incoming, int next_mesg_tag=-1, Buffer *next_recv_buff=NULL, MPI_Request *next_recv_req=NULL, int *next_incoming=NULL)
 send the indicated buffer, possibly sending size first
ErrorCode recv_buffer (int mesg_tag_expected, const MPI_Status &mpi_status, Buffer *recv_buff, MPI_Request &recv_2nd_req, MPI_Request &ack_req, int &this_incoming, Buffer *send_buff, MPI_Request &send_req, MPI_Request &sent_ack_req, bool &done, Buffer *next_buff=NULL, int next_tag=-1, MPI_Request *next_req=NULL, int *next_incoming=NULL)
ErrorCode pack_entity_seq (const int nodes_per_entity, const bool store_remote_handles, const int to_proc, Range &these_ents, std::vector< EntityHandle > &entities, Buffer *buff)
ErrorCode print_buffer (unsigned char *buff_ptr, int mesg_type, int from_proc, bool sent)
ErrorCode unpack_iface_entities (unsigned char *&buff_ptr, const int from_proc, const int ind, std::vector< EntityHandle > &recd_ents)
ErrorCode pack_sets (Range &entities, Buffer *buff, const bool store_handles, const int to_proc)
ErrorCode unpack_sets (unsigned char *&buff_ptr, std::vector< EntityHandle > &entities, const bool store_handles, const int to_proc)
ErrorCode pack_adjacencies (Range &entities, Range::const_iterator &start_rit, Range &whole_range, unsigned char *&buff_ptr, int &count, const bool just_count, const bool store_handles, const int to_proc)
ErrorCode unpack_adjacencies (unsigned char *&buff_ptr, Range &entities, const bool store_handles, const int from_proc)
ErrorCode unpack_remote_handles (unsigned int from_proc, const unsigned char *buff_ptr, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p)
ErrorCode find_existing_entity (const bool is_iface, const int owner_p, const EntityHandle owner_h, const int num_ents, const EntityHandle *connect, const int num_connect, const EntityType this_type, std::vector< EntityHandle > &L2hloc, std::vector< EntityHandle > &L2hrem, std::vector< unsigned int > &L2p, EntityHandle &new_h)
 given connectivity and type, find an existing entity, if there is one
ErrorCode build_sharedhps_list (const EntityHandle entity, const unsigned char pstatus, const int sharedp, const std::set< unsigned int > &procs, unsigned int &num_ents, int *tmp_procs, EntityHandle *tmp_handles)
ErrorCode get_tag_send_list (const Range &all_entities, std::vector< Tag > &all_tags, std::vector< Range > &tag_ranges)
 Get list of tags for which to exchange data.
ErrorCode pack_tags (Range &entities, const std::vector< Tag > &src_tags, const std::vector< Tag > &dst_tags, const std::vector< Range > &tag_ranges, Buffer *buff, const bool store_handles, const int to_proc)
 Serialize entity tag data.
ErrorCode packed_tag_size (Tag source_tag, const Range &entities, int &count_out)
 Calculate buffer size required to pack tag data.
ErrorCode pack_tag (Tag source_tag, Tag destination_tag, const Range &entities, const std::vector< EntityHandle > &whole_range, Buffer *buff, const bool store_remote_handles, const int to_proc)
 Serialize tag data.
ErrorCode unpack_tags (unsigned char *&buff_ptr, std::vector< EntityHandle > &entities, const bool store_handles, const int to_proc, const MPI_Op *const mpi_op=NULL)
ErrorCode tag_shared_verts (TupleList &shared_verts, Range *skin_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs, Range &proc_verts)
ErrorCode get_proc_nvecs (int resolve_dim, int shared_dim, Range *skin_ents, std::map< std::vector< int >, std::vector< EntityHandle > > &proc_nvecs)
ErrorCode create_iface_pc_links ()
ErrorCode pack_range_map (Range &this_range, EntityHandle actual_start, HandleMap &handle_map)
bool is_iface_proc (EntityHandle this_set, int to_proc)
 returns true if the set is an interface shared with to_proc
ErrorCode update_iface_sets (Range &sent_ents, std::vector< EntityHandle > &remote_handles, int from_proc)
ErrorCode get_ghosted_entities (int bridge_dim, int ghost_dim, int to_proc, int num_layers, int addl_ents, Range &ghosted_ents)
ErrorCode add_verts (Range &sent_ents)
 add vertices adjacent to entities in this list
ErrorCode exchange_all_shared_handles (std::vector< std::vector< SharedEntityData > > &send_data, std::vector< std::vector< SharedEntityData > > &result)
ErrorCode get_remote_handles (const bool store_remote_handles, EntityHandle *from_vec, EntityHandle *to_vec_tmp, int num_ents, int to_proc, const std::vector< EntityHandle > &new_ents)
ErrorCode get_remote_handles (const bool store_remote_handles, const Range &from_range, Range &to_range, int to_proc, const std::vector< EntityHandle > &new_ents)
ErrorCode get_remote_handles (const bool store_remote_handles, const Range &from_range, EntityHandle *to_vec, int to_proc, const std::vector< EntityHandle > &new_ents)
 same as other version, except packs range into vector
ErrorCode get_local_handles (EntityHandle *from_vec, int num_ents, const Range &new_ents)
ErrorCode get_local_handles (const Range &remote_handles, Range &local_handles, const std::vector< EntityHandle > &new_ents)
 same as above except puts results in range
ErrorCode get_local_handles (EntityHandle *from_vec, int num_ents, const std::vector< EntityHandle > &new_ents)
 same as above except gets new_ents from vector
ErrorCode update_remote_data (Range &local_range, Range &remote_range, int other_proc, const unsigned char add_pstat)
ErrorCode update_remote_data (const EntityHandle new_h, const int *ps, const EntityHandle *hs, const int num_ps, const unsigned char add_pstat)
ErrorCode update_remote_data_old (const EntityHandle new_h, const int *ps, const EntityHandle *hs, const int num_ps, const unsigned char add_pstat)
ErrorCode tag_iface_entities ()
 Set pstatus tag interface bit on entities in sets passed in.
int add_pcomm (ParallelComm *pc)
 add a pc to the iface instance tag PARALLEL_COMM
void remove_pcomm (ParallelComm *pc)
 remove a pc from the iface instance tag PARALLEL_COMM
ErrorCode check_sent_ents (Range &allsent)
ErrorCode assign_entities_part (std::vector< EntityHandle > &entities, const int proc)
 assign entities to the input processor part
ErrorCode remove_entities_part (Range &entities, const int proc)
 remove entities to the input processor part
void delete_all_buffers ()
Private Attributes
InterfacembImpl
 MB interface associated with this writer.
ProcConfig procConfig
 Proc config object, keeps info on parallel stuff.
SequenceManagersequenceManager
 Sequence manager, to get more efficient access to entities.
ErrorerrorHandler
 Error handler.
std::vector< Buffer * > localOwnedBuffs
 more data buffers, proc-specific
std::vector< Buffer * > remoteOwnedBuffs
std::vector< MPI_Request > sendReqs
 request objects, may be used if store_remote_handles is used
std::vector< MPI_Request > recvReqs
 receive request objects
std::vector< MPI_Request > recvRemotehReqs
std::vector< unsigned int > buffProcs
 processor rank for each buffer index
Range partitionSets
 the partition, interface sets for this comm'n instance
Range interfaceSets
std::set< EntityHandlesharedEnts
 all local entities shared with others, whether ghost or ghosted
Tag sharedpTag
 tags used to save sharing procs and handles
Tag sharedpsTag
Tag sharedhTag
Tag sharedhsTag
Tag pstatusTag
Tag ifaceSetsTag
Tag partitionTag
int globalPartCount
 Cache of global part count.
EntityHandle partitioningSet
 entity set containing all parts
std::ofstream myFile
int pcommID
int ackbuff
DebugOutputmyDebug
 used to set verbosity level and to report output
SharedSetDatasharedSetData
 Data about shared sets.
Friends
class ParallelMergeMesh
Detailed Description
Author:
Tim Tautges
This class implements methods to communicate mesh between processors
Examples:
ComputeTriDual.cpp, DeformMeshRemap.cpp, GenLargeMesh.cpp, HelloParMOAB.cpp, LaplacianSmoother.cpp, LloydRelaxation.cpp, ReadWriteTest.cpp, and ReduceExchangeTags.cpp.
Definition at line 54 of file ParallelComm.hpp.
moab::ParallelComm::ParallelComm ( Interface impl,
MPI_Comm  comm,
int *  pcomm_id_out = 0
constructor
Definition at line 313 of file ParallelComm.cpp.
References initialize(), pcommID, moab::ProcConfig::proc_rank(), procConfig, and sharedSetData.
Referenced by get_pcomm().
    : mbImpl( impl ), procConfig( cm ), sharedpTag( 0 ), sharedpsTag( 0 ), sharedhTag( 0 ), sharedhsTag( 0 ),
      pstatusTag( 0 ), ifaceSetsTag( 0 ), partitionTag( 0 ), globalPartCount( -1 ), partitioningSet( 0 ),
      myDebug( NULL )
    initialize();
    sharedSetData = new SharedSetData( *impl, pcommID, procConfig.proc_rank() );
    if( id ) *id = pcommID;
std::vector< unsigned char > &  tmp_buff,
MPI_Comm  comm,
Definition at line 323 of file ParallelComm.cpp.
      myDebug( NULL )
    initialize();
destructor
Definition at line 333 of file ParallelComm.cpp.
References delete_all_buffers(), myDebug, remove_pcomm(), and sharedSetData.
    remove_pcomm( this );
    delete_all_buffers();
    delete myDebug;
    delete sharedSetData;
Member Function Documentation
Definition at line 374 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_NOT_FOUND, mbImpl, pcomm_tag(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by initialize().
    // Add this pcomm to instance tag
    std::vector< ParallelComm* > pc_array( MAX_SHARING_PROCS, (ParallelComm*)NULL );
    Tag pc_tag = pcomm_tag( mbImpl, true );
    assert( 0 != pc_tag );
    const EntityHandle root = 0;
    ErrorCode result        = mbImpl->tag_get_data( pc_tag, &root, 1, (void*)&pc_array[0] );
    if( MB_SUCCESS != result && MB_TAG_NOT_FOUND != result ) return -1;
    int index = 0;
    while( index < MAX_SHARING_PROCS && pc_array[index] )
        index++;
    if( index == MAX_SHARING_PROCS )
        index = -1;
        assert( false );
    else
        pc_array[index] = pc;
        mbImpl->tag_set_data( pc_tag, &root, 1, (void*)&pc_array[0] );
    return index;
ErrorCode moab::ParallelComm::add_verts ( Range sent_ents) [private]
Definition at line 7502 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::equal_range(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, MBPOLYHEDRON, MBVERTEX, moab::Range::subset_by_type(), and moab::Interface::UNION.
Referenced by broadcast_entities(), exchange_owned_mesh(), get_ghosted_entities(), scatter_entities(), and send_entities().
    // Get the verts adj to these entities, since we'll have to send those too
    // First check sets
    std::pair< Range::const_iterator, Range::const_iterator > set_range = sent_ents.equal_range( MBENTITYSET );
    ErrorCode result                                                    = MB_SUCCESS, tmp_result;
    for( Range::const_iterator rit = set_range.first; rit != set_range.second; ++rit )
        tmp_result = mbImpl->get_entities_by_type( *rit, MBVERTEX, sent_ents );MB_CHK_SET_ERR( tmp_result, "Failed to get contained verts" );
    // Now non-sets
    Range tmp_ents;
    std::copy( sent_ents.begin(), set_range.first, range_inserter( tmp_ents ) );
    result = mbImpl->get_adjacencies( tmp_ents, 0, false, sent_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get vertices adj to ghosted ents" );
    // if polyhedra, need to add all faces from there
    Range polyhedra = sent_ents.subset_by_type( MBPOLYHEDRON );
    // get all faces adjacent to every polyhedra
    result = mbImpl->get_connectivity( polyhedra, sent_ents );MB_CHK_SET_ERR( result, "Failed to get polyhedra faces" );
    return result;
ErrorCode moab::ParallelComm::assign_entities_part ( std::vector< EntityHandle > &  entities,
const int  proc
) [private]
Definition at line 7297 of file ParallelComm.cpp.
References moab::Interface::add_entities(), ErrorCode, get_part_handle(), MB_CHK_SET_ERR, MB_SUCCESS, and mbImpl.
Referenced by exchange_owned_mesh(), and recv_entities().
    EntityHandle part_set;
    ErrorCode result = get_part_handle( proc, part_set );MB_CHK_SET_ERR( result, "Failed to get part handle" );
    if( part_set > 0 )
        result = mbImpl->add_entities( part_set, &entities[0], entities.size() );MB_CHK_SET_ERR( result, "Failed to add entities to part set" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::assign_global_ids ( EntityHandle  this_set,
const int  start_id = 1,
const bool  largest_dim_only = true,
const bool  parallel = true,
const bool  owned_only = false
assign a global id space, for largest-dimension or all entities (and in either case for vertices too)
Parameters:
owned_onlyIf true, do not get global IDs for non-owned entities from remote processors.
Assign a global id space, for largest-dimension or all entities (and in either case for vertices too)
Examples:
ComputeTriDual.cpp.
Definition at line 421 of file ParallelComm.cpp.
References dim, moab::Range::end(), entities, ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Range::insert(), MB_CHK_SET_ERR, mbImpl, PSTATUS_NOT_OWNED, pstatus_tag(), size(), moab::subtract(), and moab::Interface::tag_get_data().
Referenced by MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), check_global_ids(), compute_dual_mesh(), create_fine_mesh(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), iMeshP_assignGlobalIds(), main(), MetisPartitioner::partition_mesh(), resolve_shared_ents(), and test_assign_global_ids().
    Range entities[4];
    ErrorCode result;
    std::vector< unsigned char > pstatus;
    for( int dim = 0; dim <= dimension; dim++ )
        if( dim == 0 || !largest_dim_only || dim == dimension )
            result = mbImpl->get_entities_by_dimension( this_set, dim, entities[dim] );MB_CHK_SET_ERR( result, "Failed to get vertices in assign_global_ids" );
        // Need to filter out non-locally-owned entities!!!
        pstatus.resize( entities[dim].size() );
        result = mbImpl->tag_get_data( pstatus_tag(), entities[dim], &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus in assign_global_ids" );
        Range dum_range;
        Range::iterator rit;
        unsigned int i;
        for( rit = entities[dim].begin(), i = 0; rit != entities[dim].end(); ++rit, i++ )
            if( pstatus[i] & PSTATUS_NOT_OWNED ) dum_range.insert( *rit );
        entities[dim] = subtract( entities[dim], dum_range );
    return assign_global_ids( entities, dimension, start_id, parallel, owned_only );
ErrorCode moab::ParallelComm::assign_global_ids ( Range  entities[],
const int  start_id,
Definition at line 455 of file ParallelComm.cpp.
References dim, moab::Range::end(), ErrorCode, exchange_tags(), moab::Interface::globalId_tag(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), procConfig, moab::Range::size(), size(), and moab::Interface::tag_set_data().
    int local_num_elements[4];
    ErrorCode result;
        local_num_elements[dim] = entities[dim].size();
    // Communicate numbers
    std::vector< int > num_elements( procConfig.proc_size() * 4 );
#ifdef MOAB_HAVE_MPI
    if( procConfig.proc_size() > 1 && parallel )
        int retval =
            MPI_Allgather( local_num_elements, 4, MPI_INT, &num_elements[0], 4, MPI_INT, procConfig.proc_comm() );
        if( 0 != retval ) return MB_FAILURE;
    else
#endif
        for( int dim = 0; dim < 4; dim++ )
            num_elements[dim] = local_num_elements[dim];
    // My entities start at one greater than total_elems[d]
    int total_elems[4] = { start_id, start_id, start_id, start_id };
    for( unsigned int proc = 0; proc < procConfig.proc_rank(); proc++ )
            total_elems[dim] += num_elements[4 * proc + dim];
    // Assign global ids now
    Tag gid_tag = mbImpl->globalId_tag();
        if( entities[dim].empty() ) continue;
        num_elements.resize( entities[dim].size() );
        int i = 0;
        for( Range::iterator rit = entities[dim].begin(); rit != entities[dim].end(); ++rit )
            num_elements[i++] = total_elems[dim]++;
        result = mbImpl->tag_set_data( gid_tag, entities[dim], &num_elements[0] );MB_CHK_SET_ERR( result, "Failed to set global id tag in assign_global_ids" );
    if( owned_only ) return MB_SUCCESS;
    // Exchange tags
    for( int dim = 1; dim < 4; dim++ )
        entities[0].merge( entities[dim] );
    return exchange_tags( gid_tag, entities[0] );
extend shared sets with ghost entities After ghosting, ghost entities do not have yet information about the material set, partition set, Neumann or Dirichlet set they could belong to This method will assign ghosted entities to the those special entity sets In some case we might even have to create those sets, if they do not exist yet on the local processor
The special entity sets all have an unique identifier, in a form of an integer tag to the set. The shared sets data is not used, because we do not use the geometry sets, as they are not uniquely identified
Parameters:
file_set: file set used per application
Definition at line 4766 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Interface::contains_entities(), moab::Interface::create_meshset(), moab::ProcConfig::crystal_router(), DIRICHLET_SET_TAG_NAME, moab::TupleList::enableWriteAccess(), ErrorCode, get_debug_verbosity(), moab::Interface::get_entities_by_type_and_tag(), moab::TupleList::get_max(), moab::TupleList::get_n(), get_sharing_data(), moab::Interface::globalId_tag(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MATERIAL_SET_TAG_NAME, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_ANY, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, MESHSET_SET, NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME, moab::TupleList::print(), moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_size(), procConfig, PSTATUS_NOT_OWNED, rank(), moab::TupleList::resize(), sharedEnts, moab::Range::size(), size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::Interface::UNION, moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vul_rd, and moab::TupleList::vul_wr.
Referenced by moab::ReadParallel::load_file(), and test_read_and_ghost_after().
    // gather all default sets we are interested in, material, neumann, etc
    // we will skip geometry sets, because they are not uniquely identified with their tag value
    // maybe we will add another tag, like category
    if( procConfig.proc_size() < 2 ) return MB_SUCCESS;  // no reason to stop by
    const char* const shared_set_tag_names[] = { MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, NEUMANN_SET_TAG_NAME,
                                                 PARALLEL_PARTITION_TAG_NAME };
    int num_tags = sizeof( shared_set_tag_names ) / sizeof( shared_set_tag_names[0] );
    Range* rangeSets = new Range[num_tags];
    Tag* tags        = new Tag[num_tags + 1];  // one extra for global id tag, which is an int, so far
    int my_rank   = rank();
    int** tagVals = new int*[num_tags];
    for( int i = 0; i < num_tags; i++ )
        tagVals[i] = NULL;
    ErrorCode rval;
    // for each tag, we keep a local map, from the value to the actual set with that value
    // we assume that the tag values are unique, for a given set, otherwise we
    // do not know to which set to add the entity
    typedef std::map< int, EntityHandle > MVal;
    typedef std::map< int, EntityHandle >::iterator itMVal;
    MVal* localMaps = new MVal[num_tags];
        rval = mbImpl->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tags[i], MB_TAG_ANY );
        if( MB_SUCCESS != rval ) continue;
        rval = mbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &( tags[i] ), 0, 1, rangeSets[i],
                                                     Interface::UNION );MB_CHK_SET_ERR( rval, "can't get sets with a tag" );
        if( rangeSets[i].size() > 0 )
            tagVals[i] = new int[rangeSets[i].size()];
            // fill up with the tag values
            rval = mbImpl->tag_get_data( tags[i], rangeSets[i], tagVals[i] );MB_CHK_SET_ERR( rval, "can't get set tag values" );
            // now for inverse mapping:
            for( int j = 0; j < (int)rangeSets[i].size(); j++ )
                localMaps[i][tagVals[i][j]] = rangeSets[i][j];
    // get the global id tag too
    tags[num_tags] = mbImpl->globalId_tag();
    TupleList remoteEnts;
    // processor to send to, type of tag (0-mat,) tag value,     remote handle
    //                         1-diri
    //                         2-neum
    //                         3-part
    int initialSize = (int)sharedEnts.size();  // estimate that on average, each shared ent
    // will be sent to one processor, for one tag
    // we will actually send only entities that are owned locally, and from those
    // only those that do have a special tag (material, neumann, etc)
    // if we exceed the capacity, we resize the tuple
    remoteEnts.initialize( 3, 0, 1, 0, initialSize );
    remoteEnts.enableWriteAccess();
    // now, for each owned entity, get the remote handle(s) and Proc(s), and verify if it
    // belongs to one of the sets; if yes, create a tuple and append it
    std::set< EntityHandle > own_and_sha;
    int ir = 0, jr = 0;
    for( std::set< EntityHandle >::iterator vit = sharedEnts.begin(); vit != sharedEnts.end(); ++vit )
        // ghosted eh
        EntityHandle geh = *vit;
        if( own_and_sha.find( geh ) != own_and_sha.end() )  // already encountered
            continue;
        int procs[MAX_SHARING_PROCS];
        EntityHandle handles[MAX_SHARING_PROCS];
        int nprocs;
        unsigned char pstat;
        rval = get_sharing_data( geh, procs, handles, pstat, nprocs );
        if( rval != MB_SUCCESS )
                delete[] tagVals[i];
            delete[] tagVals;
            MB_CHK_SET_ERR( rval, "Failed to get sharing data" );
        if( pstat & PSTATUS_NOT_OWNED ) continue;  // we will send info only for entities that we own
        own_and_sha.insert( geh );
                EntityHandle specialSet = rangeSets[i][j];  // this set has tag i, value tagVals[i][j];
                if( mbImpl->contains_entities( specialSet, &geh, 1 ) )
                    // this ghosted entity is in a special set, so form the tuple
                    // to send to the processors that do not own this
                    for( int k = 0; k < nprocs; k++ )
                        if( procs[k] != my_rank )
                            if( remoteEnts.get_n() >= remoteEnts.get_max() - 1 )
                                // resize, so we do not overflow
                                int oldSize = remoteEnts.get_max();
                                // increase with 50% the capacity
                                remoteEnts.resize( oldSize + oldSize / 2 + 1 );
                            remoteEnts.vi_wr[ir++]  = procs[k];       // send to proc
                            remoteEnts.vi_wr[ir++]  = i;              // for the tags [i] (0-3)
                            remoteEnts.vi_wr[ir++]  = tagVals[i][j];  // actual value of the tag
                            remoteEnts.vul_wr[jr++] = handles[k];
                            remoteEnts.inc_n();
        // if the local entity has a global id, send it too, so we avoid
        // another "exchange_tags" for global id
        int gid;
        rval = mbImpl->tag_get_data( tags[num_tags], &geh, 1, &gid );MB_CHK_SET_ERR( rval, "Failed to get global id" );
        if( gid != 0 )
                    remoteEnts.vi_wr[ir++]  = num_tags;  // for the tags [j] (4)
                    remoteEnts.vi_wr[ir++]  = gid;       // actual value of the tag
                    remoteEnts.inc_n();
#ifndef NDEBUG
    if( my_rank == 1 && 1 == get_debug_verbosity() ) remoteEnts.print( " on rank 1, before augment routing" );
    MPI_Barrier( procConfig.proc_comm() );
    int sentEnts = remoteEnts.get_n();
    assert( ( sentEnts == jr ) && ( 3 * sentEnts == ir ) );
#endif
    // exchange the info now, and send to
    gs_data::crystal_data* cd = this->procConfig.crystal_router();
    // All communication happens here; no other mpi calls
    // Also, this is a collective call
    rval = cd->gs_transfer( 1, remoteEnts, 0 );MB_CHK_SET_ERR( rval, "Error in tuple transfer" );
#ifndef NDEBUG
    if( my_rank == 0 && 1 == get_debug_verbosity() ) remoteEnts.print( " on rank 0, after augment routing" );
#endif
    // now process the data received from other processors
    int received = remoteEnts.get_n();
    for( int i = 0; i < received; i++ )
        // int from = ents_to_delete.vi_rd[i];
        EntityHandle geh = (EntityHandle)remoteEnts.vul_rd[i];
        int from_proc    = remoteEnts.vi_rd[3 * i];
        if( my_rank == from_proc )
            std::cout << " unexpected receive from my rank " << my_rank << " during augmenting with ghosts\n ";
        int tag_type = remoteEnts.vi_rd[3 * i + 1];
        assert( ( 0 <= tag_type ) && ( tag_type <= num_tags ) );
        int value = remoteEnts.vi_rd[3 * i + 2];
        if( tag_type == num_tags )
            // it is global id
            rval = mbImpl->tag_set_data( tags[num_tags], &geh, 1, &value );MB_CHK_SET_ERR( rval, "Error in setting gid tag" );
        else
            // now, based on value and tag type, see if we have that value in the map
            MVal& lmap = localMaps[tag_type];
            itMVal itm = lmap.find( value );
            if( itm == lmap.end() )
                // the value was not found yet in the local map, so we have to create the set
                EntityHandle newSet;
                rval = mbImpl->create_meshset( MESHSET_SET, newSet );MB_CHK_SET_ERR( rval, "can't create new set" );
                lmap[value] = newSet;
                // set the tag value
                rval = mbImpl->tag_set_data( tags[tag_type], &newSet, 1, &value );MB_CHK_SET_ERR( rval, "can't set tag for new set" );
                // we also need to add the new created set to the file set, if not null
                if( file_set )
                    rval = mbImpl->add_entities( file_set, &newSet, 1 );MB_CHK_SET_ERR( rval, "can't add new set to the file set" );
            // add the entity to the set pointed to by the map
            rval = mbImpl->add_entities( lmap[value], &geh, 1 );MB_CHK_SET_ERR( rval, "can't add ghost ent to the set" );
    delete[] tagVals;
    delete[] rangeSets;
    delete[] tags;
    delete[] localMaps;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::broadcast_entities ( const int  from_proc,
Range entities,
const bool  adjacencies = false,
const bool  tags = true
Parameters:
from_procProcessor having the mesh to be broadcast
entitiesOn return, the entities sent or received in this call
adjacenciesIf true, adjacencies are sent for equiv entities (currently unsupported)
tagsIf true, all non-default-valued tags are sent for sent entities
Definition at line 536 of file ParallelComm.cpp.
References add_verts(), moab::ParallelComm::Buffer::buff_ptr, ErrorCode, INITIAL_BUFF_SIZE, moab::MAX_BCAST_SIZE, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, pack_buffer(), moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, moab::ParallelComm::Buffer::reserve(), moab::ParallelComm::Buffer::reset_ptr(), moab::ParallelComm::Buffer::set_stored_size(), and unpack_buffer().
Referenced by moab::ReadParallel::load_file().
#ifndef MOAB_HAVE_MPI
    return MB_FAILURE;
#else
    ErrorCode result = MB_SUCCESS;
    int success;
    int buff_size;
    Buffer buff( INITIAL_BUFF_SIZE );
    buff.reset_ptr( sizeof( int ) );
    if( (int)procConfig.proc_rank() == from_proc )
        result = add_verts( entities );MB_CHK_SET_ERR( result, "Failed to add adj vertices" );
        result = pack_buffer( entities, adjacencies, tags, false, -1, &buff );MB_CHK_SET_ERR( result, "Failed to compute buffer size in broadcast_entities" );
        buff.set_stored_size();
        buff_size = buff.buff_ptr - buff.mem_ptr;
    success = MPI_Bcast( &buff_size, 1, MPI_INT, from_proc, procConfig.proc_comm() );
    if( MPI_SUCCESS != success )
        MB_SET_ERR( MB_FAILURE, "MPI_Bcast of buffer size failed" );
    if( !buff_size )  // No data
        return MB_SUCCESS;
    if( (int)procConfig.proc_rank() != from_proc ) buff.reserve( buff_size );
    size_t offset = 0;
    while( buff_size )
        int sz  = std::min( buff_size, MAX_BCAST_SIZE );
        success = MPI_Bcast( buff.mem_ptr + offset, sz, MPI_UNSIGNED_CHAR, from_proc, procConfig.proc_comm() );
            MB_SET_ERR( MB_FAILURE, "MPI_Bcast of buffer failed" );
        offset += sz;
        buff_size -= sz;
        std::vector< std::vector< EntityHandle > > dum1a, dum1b;
        std::vector< std::vector< int > > dum1p;
        std::vector< EntityHandle > dum2, dum4;
        std::vector< unsigned int > dum3;
        result = unpack_buffer( buff.buff_ptr, false, from_proc, -1, dum1a, dum1b, dum1p, dum2, dum2, dum3, dum4 );MB_CHK_SET_ERR( result, "Failed to unpack buffer in broadcast_entities" );
        std::copy( dum4.begin(), dum4.end(), range_inserter( entities ) );
    return MB_SUCCESS;
#endif
const std::vector< unsigned int > & moab::ParallelComm::buff_procs ( ) const [inline]
Definition at line 1569 of file ParallelComm.hpp.
References buffProcs.
    return buffProcs;
ErrorCode moab::ParallelComm::build_sharedhps_list ( const EntityHandle  entity,
const int  sharedp,
const std::set< unsigned int > &  procs,
unsigned int &  num_ents,
int *  tmp_procs,
EntityHandle tmp_handles
) [private]
Definition at line 1748 of file ParallelComm.cpp.
References ErrorCode, get_sharing_data(), list_entities(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, and PSTATUS_SHARED.
Referenced by pack_entities().
    num_ents = 0;
    ErrorCode result = get_sharing_data( entity, tmp_procs, tmp_handles, pstat, num_ents );MB_CHK_SET_ERR( result, "Failed to get sharing data" );
    assert( pstat == pstatus );
    // Build shared proc/handle lists
    // Start with multi-shared, since if it is the owner will be first
    if( pstatus & PSTATUS_MULTISHARED )
    else if( pstatus & PSTATUS_NOT_OWNED )
        // If not multishared and not owned, other sharing proc is owner, put that
        // one first
        assert( "If not owned, I should be shared too" && pstatus & PSTATUS_SHARED && 1 == num_ents );
        tmp_procs[1]   = procConfig.proc_rank();
        tmp_handles[1] = entity;
        num_ents       = 2;
    else if( pstatus & PSTATUS_SHARED )
        // If not multishared and owned, I'm owner
        assert( "shared and owned, should be only 1 sharing proc" && 1 == num_ents );
        tmp_procs[1]   = tmp_procs[0];
        tmp_procs[0]   = procConfig.proc_rank();
        tmp_handles[1] = tmp_handles[0];
        tmp_handles[0] = entity;
        num_ents       = 2;
    else
        // Not shared yet, just add owner (me)
        num_ents       = 1;
#ifndef NDEBUG
    int tmp_ps = num_ents;
#endif
    // Now add others, with zero handle for now
    for( std::set< unsigned int >::iterator sit = procs.begin(); sit != procs.end(); ++sit )
#ifndef NDEBUG
        if( tmp_ps && std::find( tmp_procs, tmp_procs + tmp_ps, *sit ) != tmp_procs + tmp_ps )
            std::cerr << "Trouble with something already in shared list on proc " << procConfig.proc_rank()
                      << ". Entity:" << std::endl;
            list_entities( &entity, 1 );
            std::cerr << "pstatus = " << (int)pstatus << ", sharedp = " << sharedp << std::endl;
            std::cerr << "tmp_ps = ";
            for( int i = 0; i < tmp_ps; i++ )
                std::cerr << tmp_procs[i] << " ";
            std::cerr << std::endl;
            std::cerr << "procs = ";
            for( std::set< unsigned int >::iterator sit2 = procs.begin(); sit2 != procs.end(); ++sit2 )
                std::cerr << *sit2 << " ";
            assert( false );
#endif
        tmp_procs[num_ents]   = *sit;
        tmp_handles[num_ents] = 0;
        num_ents++;
    // Put -1 after procs and 0 after handles
    if( MAX_SHARING_PROCS > num_ents )
        tmp_procs[num_ents]   = -1;
    return MB_SUCCESS;
Call exchange_all_shared_handles, then compare the results with tag data on local shared entities.
Definition at line 8541 of file ParallelComm.cpp.
References buffProcs, check_local_shared(), check_my_shared_handles(), ErrorCode, exchange_all_shared_handles(), MB_SUCCESS, mbImpl, pack_shared_handles(), moab::ProcConfig::proc_rank(), procConfig, and moab::Interface::write_mesh().
Referenced by exchange_ghost_cells(), main(), read_mesh_parallel(), resolve_shared_ents(), moab::ScdInterface::tag_shared_vertices(), test_elements_on_several_procs(), test_ghost_elements(), test_ghosted_entity_shared_data(), test_intx_in_parallel_elem_based(), test_intx_mpas(), test_read(), test_read_parallel(), and test_tempest_to_moab_convert().
    // Get all shared ent data from other procs
    std::vector< std::vector< SharedEntityData > > shents( buffProcs.size() ), send_data( buffProcs.size() );
    ErrorCode result;
    bool done = false;
    while( !done )
        result = check_local_shared();
        if( MB_SUCCESS != result )
            done = true;
            continue;
        result = pack_shared_handles( send_data );
            done = true;
            continue;
        result = exchange_all_shared_handles( send_data, shents );
            done = true;
            continue;
        if( !shents.empty() ) result = check_my_shared_handles( shents );
        done = true;
    if( MB_SUCCESS != result && print_em )
#ifdef MOAB_HAVE_HDF5
        std::ostringstream ent_str;
        ent_str << "mesh." << procConfig.proc_rank() << ".h5m";
        mbImpl->write_mesh( ent_str.str().c_str() );
#endif
    return result;
Definition at line 8715 of file ParallelComm.cpp.
References buffProcs, check_my_shared_handles(), ErrorCode, get_buffers(), MB_SUCCESS, and pack_shared_handles().
    std::vector< std::vector< std::vector< SharedEntityData > > > shents, send_data;
    // Get all shared ent data from each proc to all other procs
    send_data.resize( num_pcs );
    for( int p = 0; p < num_pcs; p++ )
        tmp_result = pcs[p]->pack_shared_handles( send_data[p] );
        if( MB_SUCCESS != tmp_result ) result = tmp_result;
    if( MB_SUCCESS != result ) return result;
    // Move the data sorted by sending proc to data sorted by receiving proc
    shents.resize( num_pcs );
        shents[p].resize( pcs[p]->buffProcs.size() );
        for( unsigned int idx_p = 0; idx_p < pcs[p]->buffProcs.size(); idx_p++ )
            // Move send_data[p][to_p] to shents[to_p][idx_p]
            int to_p      = pcs[p]->buffProcs[idx_p];
            int top_idx_p = pcs[to_p]->get_buffers( p );
            assert( -1 != top_idx_p );
            shents[to_p][top_idx_p] = send_data[p][idx_p];
        std::ostringstream ostr;
        ostr << "Processor " << p << " bad entities:";
        tmp_result = pcs[p]->check_my_shared_handles( shents[p], ostr.str().c_str() );
    return result;
Definition at line 6256 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), moab::Range::erase(), ErrorCode, moab::Interface::get_number_entities_by_handle(), get_sharing_data(), moab::Range::insert(), interface_sets(), interfaceSets, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, MESHSET_SET, proc_config(), moab::ProcConfig::proc_rank(), procConfig, moab::ProcList::procs, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), moab::Range::rbegin(), moab::Interface::remove_entities(), moab::Range::rend(), set_sharing_data(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), swap(), moab::Interface::tag_clear_data(), and moab::Interface::tag_set_data().
Referenced by exchange_ghost_cells().
    // allsent is all entities I think are on interface; go over them, looking
    // for zero-valued handles, and fix any I find
    // Keep lists of entities for which teh sharing data changed, grouped
    // by set of sharing procs.
    typedef std::map< ProcList, Range > procmap_t;
    procmap_t old_procs, new_procs;
    Range::reverse_iterator rvit;
    unsigned char pstatus;
    int nump;
    ProcList sharedp;
    EntityHandle sharedh[MAX_SHARING_PROCS];
    for( rvit = allsent.rbegin(); rvit != allsent.rend(); ++rvit )
        result = get_sharing_data( *rvit, sharedp.procs, sharedh, pstatus, nump );MB_CHK_SET_ERR( result, "Failed to get sharing data" );
        assert( "Should be shared with at least one other proc" &&
                ( nump > 1 || sharedp.procs[0] != (int)procConfig.proc_rank() ) );
        assert( nump == MAX_SHARING_PROCS || sharedp.procs[nump] == -1 );
        // Look for first null handle in list
        int idx = std::find( sharedh, sharedh + nump, (EntityHandle)0 ) - sharedh;
        if( idx == nump ) continue;  // All handles are valid
        ProcList old_list( sharedp );
        std::sort( old_list.procs, old_list.procs + nump );
        old_procs[old_list].insert( *rvit );
        // Remove null handles and corresponding proc ranks from lists
        int new_nump       = idx;
        bool removed_owner = !idx;
        for( ++idx; idx < nump; ++idx )
            if( sharedh[idx] )
                sharedh[new_nump]       = sharedh[idx];
                sharedp.procs[new_nump] = sharedp.procs[idx];
                ++new_nump;
        sharedp.procs[new_nump] = -1;
        if( removed_owner && new_nump > 1 )
            // The proc that we choose as the entity owner isn't sharing the
            // entity (doesn't have a copy of it). We need to pick a different
            // owner. Choose the proc with lowest rank.
            idx = std::min_element( sharedp.procs, sharedp.procs + new_nump ) - sharedp.procs;
            std::swap( sharedp.procs[0], sharedp.procs[idx] );
            std::swap( sharedh[0], sharedh[idx] );
            if( sharedp.procs[0] == (int)proc_config().proc_rank() ) pstatus &= ~PSTATUS_NOT_OWNED;
        result = set_sharing_data( *rvit, pstatus, nump, new_nump, sharedp.procs, sharedh );MB_CHK_SET_ERR( result, "Failed to set sharing data in check_clean_iface" );
        if( new_nump > 1 )
            if( new_nump == 2 )
                if( sharedp.procs[1] != (int)proc_config().proc_rank() )
                    assert( sharedp.procs[0] == (int)proc_config().proc_rank() );
                    sharedp.procs[0] = sharedp.procs[1];
                sharedp.procs[1] = -1;
            else
                std::sort( sharedp.procs, sharedp.procs + new_nump );
            new_procs[sharedp].insert( *rvit );
    if( old_procs.empty() )
        assert( new_procs.empty() );
        return MB_SUCCESS;
    // Update interface sets
    procmap_t::iterator pmit;
    // std::vector<unsigned char> pstatus_list;
    rit = interface_sets().begin();
    while( rit != interface_sets().end() )
        result = get_sharing_data( *rit, sharedp.procs, sharedh, pstatus, nump );MB_CHK_SET_ERR( result, "Failed to get sharing data for interface set" );
        assert( nump != 2 );
        std::sort( sharedp.procs, sharedp.procs + nump );
        pmit = old_procs.find( sharedp );
        if( pmit != old_procs.end() )
            result = mbImpl->remove_entities( *rit, pmit->second );MB_CHK_SET_ERR( result, "Failed to remove entities from interface set" );
        pmit = new_procs.find( sharedp );
        if( pmit == new_procs.end() )
            int count;
            result = mbImpl->get_number_entities_by_handle( *rit, count );MB_CHK_SET_ERR( result, "Failed to get number of entities in interface set" );
            if( !count )
                result = mbImpl->delete_entities( &*rit, 1 );MB_CHK_SET_ERR( result, "Failed to delete entities from interface set" );
                rit = interface_sets().erase( rit );
            else
                ++rit;
        else
            result = mbImpl->add_entities( *rit, pmit->second );MB_CHK_SET_ERR( result, "Failed to add entities to interface set" );
            // Remove those that we've processed so that we know which ones
            // are new.
            new_procs.erase( pmit );
            ++rit;
    // Create interface sets for new proc id combinations
    std::fill( sharedh, sharedh + MAX_SHARING_PROCS, 0 );
    for( pmit = new_procs.begin(); pmit != new_procs.end(); ++pmit )
        EntityHandle new_set;
        result = mbImpl->create_meshset( MESHSET_SET, new_set );MB_CHK_SET_ERR( result, "Failed to create interface set" );
        interfaceSets.insert( new_set );
        // Add entities
        result = mbImpl->add_entities( new_set, pmit->second );MB_CHK_SET_ERR( result, "Failed to add entities to interface set" );
        // Tag set with the proc rank(s)
        assert( pmit->first.procs[0] >= 0 );
        pstatus = PSTATUS_SHARED | PSTATUS_INTERFACE;
        if( pmit->first.procs[1] == -1 )
            int other = pmit->first.procs[0];
            assert( other != (int)procConfig.proc_rank() );
            result = mbImpl->tag_set_data( sharedp_tag(), &new_set, 1, pmit->first.procs );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
            sharedh[0] = 0;
            result     = mbImpl->tag_set_data( sharedh_tag(), &new_set, 1, sharedh );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
            if( other < (int)proc_config().proc_rank() ) pstatus |= PSTATUS_NOT_OWNED;
        else
            result = mbImpl->tag_set_data( sharedps_tag(), &new_set, 1, pmit->first.procs );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
            result = mbImpl->tag_set_data( sharedhs_tag(), &new_set, 1, sharedh );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
            pstatus |= PSTATUS_MULTISHARED;
            if( pmit->first.procs[0] < (int)proc_config().proc_rank() ) pstatus |= PSTATUS_NOT_OWNED;
        result = mbImpl->tag_set_data( pstatus_tag(), &new_set, 1, &pstatus );MB_CHK_SET_ERR( result, "Failed to tag interface set with pstatus" );
        // Set pstatus on all interface entities in set
        result = mbImpl->tag_clear_data( pstatus_tag(), pmit->second, &pstatus );MB_CHK_SET_ERR( result, "Failed to tag interface entities with pstatus" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::check_global_ids ( EntityHandle  this_set,
check for global ids; based only on tag handle being there or not; if it's not there, create them for the specified dimensions
Parameters:
Definition at line 5532 of file ParallelComm.cpp.
References assign_global_ids(), moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and MBVERTEX.
    // Global id tag
    int def_val = -1;
    Range dum_range;
    void* tag_ptr    = &def_val;
    ErrorCode result = mbImpl->get_entities_by_type_and_tag( this_set, MBVERTEX, &gid_tag, &tag_ptr, 1, dum_range );MB_CHK_SET_ERR( result, "Failed to get entities by MBVERTEX type and gid tag" );
    if( !dum_range.empty() )
        // Just created it, so we need global ids
        result = assign_global_ids( this_set, dimension, start_id, largest_dim_only, parallel, owned_only );MB_CHK_SET_ERR( result, "Failed assigning global ids" );
    return MB_SUCCESS;
Definition at line 8588 of file ParallelComm.cpp.
References ErrorCode, moab::Interface::get_connectivity(), get_sharing_data(), list_entities(), MAX_SHARING_PROCS, MB_SUCCESS, MBENTITYSET, mbImpl, MBVERTEX, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, sharedEnts, and moab::Interface::type_from_handle().
Referenced by check_all_shared_handles().
    // Do some checks on shared entities to make sure things look
    // consistent
    // Check that non-vertex shared entities are shared by same procs as all
    // their vertices
    // std::pair<Range::const_iterator,Range::const_iterator> vert_it =
    //    sharedEnts.equal_range(MBVERTEX);
    std::vector< EntityHandle > dum_connect;
    const EntityHandle* connect;
    int num_connect;
    int tmp_procs[MAX_SHARING_PROCS];
    EntityHandle tmp_hs[MAX_SHARING_PROCS];
    std::set< int > tmp_set, vset;
    int num_ps;
    ErrorCode result;
    std::vector< EntityHandle > bad_ents;
    std::vector< std::string > errors;
    std::set< EntityHandle >::iterator vit;
    for( vit = sharedEnts.begin(); vit != sharedEnts.end(); ++vit )
        // Get sharing procs for this ent
        result = get_sharing_data( *vit, tmp_procs, tmp_hs, pstat, num_ps );
            bad_ents.push_back( *vit );
            errors.push_back( std::string( "Failure getting sharing data." ) );
            continue;
        bool bad = false;
        // Entity must be shared
        if( !( pstat & PSTATUS_SHARED ) )
            errors.push_back( std::string( "Entity should be shared but isn't." ) ), bad = true;
        // If entity is not owned this must not be first proc
        if( pstat & PSTATUS_NOT_OWNED && tmp_procs[0] == (int)procConfig.proc_rank() )
            errors.push_back( std::string( "Entity not owned but is first proc." ) ), bad = true;
        // If entity is owned and multishared, this must be first proc
        if( !( pstat & PSTATUS_NOT_OWNED ) && pstat & PSTATUS_MULTISHARED &&
            ( tmp_procs[0] != (int)procConfig.proc_rank() || tmp_hs[0] != *vit ) )
            errors.push_back( std::string( "Entity owned and multishared but not first proc or not first handle." ) ),
                bad = true;
        if( bad )
            continue;
        EntityType type = mbImpl->type_from_handle( *vit );
        if( type == MBVERTEX || type == MBENTITYSET ) continue;
        // Copy element's procs to vset and save size
        int orig_ps = num_ps;
        vset.clear();
        std::copy( tmp_procs, tmp_procs + num_ps, std::inserter( vset, vset.begin() ) );
        // Get vertices for this ent and intersection of sharing procs
        result = mbImpl->get_connectivity( *vit, connect, num_connect, false, &dum_connect );
            errors.push_back( std::string( "Failed to get connectivity." ) );
            continue;
        for( int i = 0; i < num_connect; i++ )
            result = get_sharing_data( connect[i], tmp_procs, NULL, pstat, num_ps );
                continue;
            if( !num_ps )
                vset.clear();
                break;
            std::sort( tmp_procs, tmp_procs + num_ps );
            tmp_set.clear();
            std::set_intersection( tmp_procs, tmp_procs + num_ps, vset.begin(), vset.end(),
                                   std::inserter( tmp_set, tmp_set.end() ) );
            vset.swap( tmp_set );
            if( vset.empty() ) break;
        // Intersect them; should be the same size as orig_ps
        tmp_set.clear();
        if( orig_ps != (int)tmp_set.size() )
            errors.push_back( std::string( "Vertex proc set not same size as entity proc set." ) );
                bad_ents.push_back( connect[i] );
                errors.push_back( std::string( "vertex in connect" ) );
    if( !bad_ents.empty() )
        std::cout << "Found bad entities in check_local_shared, proc rank " << procConfig.proc_rank() << ","
                  << std::endl;
        std::vector< std::string >::iterator sit;
        std::vector< EntityHandle >::iterator rit;
        for( rit = bad_ents.begin(), sit = errors.begin(); rit != bad_ents.end(); ++rit, ++sit )
            list_entities( &( *rit ), 1 );
            std::cout << "Reason: " << *sit << std::endl;
        return MB_FAILURE;
    // To do: check interface sets
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::check_my_shared_handles ( std::vector< std::vector< SharedEntityData > > &  shents,
const char *  prefix = NULL
Definition at line 8757 of file ParallelComm.cpp.
References buffProcs, moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, get_pstatus(), get_remote_handles(), get_shared_entities(), moab::Range::insert(), list_entities(), MB_SUCCESS, MBPOLYHEDRON, moab::Range::merge(), PSTATUS_NOT_OWNED, rank(), sharedEnts, and moab::Range::upper_bound().
    // Now check against what I think data should be
    // Get all shared entities
    ErrorCode result;
    Range all_shared;
    std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( all_shared ) );
    std::vector< EntityHandle > dum_vec;
    all_shared.erase( all_shared.upper_bound( MBPOLYHEDRON ), all_shared.end() );
    Range bad_ents, local_shared;
    std::vector< SharedEntityData >::iterator vit;
    unsigned char tmp_pstat;
    for( unsigned int i = 0; i < shents.size(); i++ )
        int other_proc = buffProcs[i];
        result         = get_shared_entities( other_proc, local_shared );
        for( vit = shents[i].begin(); vit != shents[i].end(); ++vit )
            EntityHandle localh = vit->local, remoteh = vit->remote, dumh;
            local_shared.erase( localh );
            result = get_remote_handles( true, &localh, &dumh, 1, other_proc, dum_vec );
            if( MB_SUCCESS != result || dumh != remoteh ) bad_ents.insert( localh );
            result = get_pstatus( localh, tmp_pstat );
            if( MB_SUCCESS != result || ( !( tmp_pstat & PSTATUS_NOT_OWNED ) && (unsigned)vit->owner != rank() ) ||
                ( tmp_pstat & PSTATUS_NOT_OWNED && (unsigned)vit->owner == rank() ) )
        if( !local_shared.empty() ) bad_ents.merge( local_shared );
        if( prefix ) std::cout << prefix << std::endl;
        list_entities( bad_ents );
        return MB_FAILURE;
    else
        return MB_SUCCESS;
check entities to make sure there are no zero-valued remote handles where they shouldn't be
Definition at line 7323 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Range::insert(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mbImpl, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by exchange_ghost_cells(), and exchange_owned_mesh().
    // Check entities to make sure there are no zero-valued remote handles
    // where they shouldn't be
    std::vector< unsigned char > pstat( allsent.size() );
    ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), allsent, &pstat[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" );
    std::vector< EntityHandle > handles( allsent.size() );
    result = mbImpl->tag_get_data( sharedh_tag(), allsent, &handles[0] );MB_CHK_SET_ERR( result, "Failed to get sharedh tag data" );
    std::vector< int > procs( allsent.size() );
    result = mbImpl->tag_get_data( sharedp_tag(), allsent, &procs[0] );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" );
    Range bad_entities;
    unsigned int i;
    EntityHandle dum_hs[MAX_SHARING_PROCS];
    int dum_ps[MAX_SHARING_PROCS];
    for( rit = allsent.begin(), i = 0; rit != allsent.end(); ++rit, i++ )
        if( -1 != procs[i] && 0 == handles[i] )
            bad_entities.insert( *rit );
        else
            // Might be multi-shared...
            result = mbImpl->tag_get_data( sharedps_tag(), &( *rit ), 1, dum_ps );
            if( MB_TAG_NOT_FOUND == result )
                continue;
            else if( MB_SUCCESS != result )
                MB_SET_ERR( result, "Failed to get sharedps tag data" );
            result = mbImpl->tag_get_data( sharedhs_tag(), &( *rit ), 1, dum_hs );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" );
            // Find first non-set proc
            int* ns_proc  = std::find( dum_ps, dum_ps + MAX_SHARING_PROCS, -1 );
            int num_procs = ns_proc - dum_ps;
            assert( num_procs <= MAX_SHARING_PROCS );
            // Now look for zero handles in active part of dum_hs
            EntityHandle* ns_handle = std::find( dum_hs, dum_hs + num_procs, 0 );
            int num_handles         = ns_handle - dum_hs;
            assert( num_handles <= num_procs );
            if( num_handles != num_procs ) bad_entities.insert( *rit );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::clean_shared_tags ( std::vector< Range * > &  exchange_ents)
Definition at line 8842 of file ParallelComm.cpp.
References moab::Range::begin(), ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_NOT_FOUND, mbImpl, pstatus_tag(), sharedh_tag(), sharedp_tag(), moab::Range::size(), moab::Interface::tag_delete_data(), and moab::Interface::tag_get_data().
    for( unsigned int i = 0; i < exchange_ents.size(); i++ )
        Range* ents        = exchange_ents[i];
        int num_ents       = ents->size();
        Range::iterator it = ents->begin();
        for( int n = 0; n < num_ents; n++ )
            int sharing_proc;
            ErrorCode result = mbImpl->tag_get_data( sharedp_tag(), &( *ents->begin() ), 1, &sharing_proc );
            if( result != MB_TAG_NOT_FOUND && sharing_proc == -1 )
                result = mbImpl->tag_delete_data( sharedp_tag(), &( *it ), 1 );MB_CHK_SET_ERR( result, "Failed to delete sharedp tag data" );
                result = mbImpl->tag_delete_data( sharedh_tag(), &( *it ), 1 );MB_CHK_SET_ERR( result, "Failed to delete sharedh tag data" );
                result = mbImpl->tag_delete_data( pstatus_tag(), &( *it ), 1 );MB_CHK_SET_ERR( result, "Failed to delete pstatus tag data" );
            ++it;
    return MB_SUCCESS;
Definition at line 8268 of file ParallelComm.cpp.
References globalPartCount, MB_SUCCESS, partition_sets(), proc_config(), and moab::Range::size().
Referenced by iMeshP_loadAll(), and iMeshP_syncPartitionAll().
    int count       = partition_sets().size();
    globalPartCount = 0;
    int err         = MPI_Allreduce( &count, &globalPartCount, 1, MPI_INT, MPI_SUM, proc_config().proc_comm() );
    return err ? MB_FAILURE : MB_SUCCESS;
Definition at line 9346 of file ParallelComm.cpp.
References buffProcs, ErrorCode, exchange_all_shared_handles(), get_buffers(), get_sharing_data(), moab::ParallelComm::SharedEntityData::local, MAX_SHARING_PROCS, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::ParallelComm::SharedEntityData::owner, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, pstatus_tag(), rank(), moab::ParallelComm::SharedEntityData::remote, sharedEnts, sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_set_data().
Referenced by moab::ReadParallel::load_file(), and test_correct_ghost().
    // will work only on multi-shared tags  sharedps_tag(), sharedhs_tag();
     *   domain0 | domain1 | domain2 | domain3
     *   vertices from domain 1 and 2 are visible from both 0 and 3, but
     *   domain 0 might not have info about multi-sharing from domain 3
     *   so we will force that domain 0 vertices owned by 1 and 2 have information
     *   about the domain 3 sharing
     *   SharedEntityData will have :
     *    struct SharedEntityData {
            EntityHandle local;  // this is same meaning, for the proc we sent to, it is local
            EntityHandle remote; // this will be the far away handle that will need to be added
            EntityID owner;      // this will be the remote proc
          // so we need to add data like this:
           a multishared entity owned by proc x will have data like
             multishared procs:  proc x, a, b, c
             multishared handles:     h1, h2, h3, h4
             we will need to send data from proc x like this:
               to proc a we will send
                 (h2, h3, b), (h2, h4, c)
               to proc b we will send
                  (h3, h2, a), (h3, h4, c)
               to proc c we will send
                  (h4, h2, a), (h4, h3, b)
    int ent_procs[MAX_SHARING_PROCS + 1];
    EntityHandle handles[MAX_SHARING_PROCS + 1];
    int num_sharing;
    SharedEntityData tmp;
    for( std::set< EntityHandle >::iterator i = sharedEnts.begin(); i != sharedEnts.end(); ++i )
        result = get_sharing_data( *i, ent_procs, handles, pstat, num_sharing );MB_CHK_SET_ERR( result, "can't get sharing data" );
        if( !( pstat & PSTATUS_MULTISHARED ) ||
            num_sharing <= 2 )  // if not multishared, skip, it should have no problems
            continue;
        // we should skip the ones that are not owned locally
        // the owned ones will have the most multi-shared info, because the info comes from other
        // remote processors
        for( int j = 1; j < num_sharing; j++ )
            // we will send to proc
            int send_to_proc = ent_procs[j];  //
            tmp.local        = handles[j];
            int ind          = get_buffers( send_to_proc );
            assert( -1 != ind );  // THIS SHOULD NEVER HAPPEN
            for( int k = 1; k < num_sharing; k++ )
                // do not send to self proc
                if( j == k ) continue;
                tmp.remote = handles[k];  // this will be the handle of entity on proc
                tmp.owner  = ent_procs[k];
                send_data[ind].push_back( tmp );
    result = exchange_all_shared_handles( send_data, shents );MB_CHK_ERR( result );
    // loop over all shents and add if vertex type, add if missing
    for( size_t i = 0; i < shents.size(); i++ )
        std::vector< SharedEntityData >& shEnts = shents[i];
        for( size_t j = 0; j < shEnts.size(); j++ )
            tmp = shEnts[j];
            // basically, check the shared data for tmp.local entity
            // it should have inside the tmp.owner and tmp.remote
            EntityHandle eh = tmp.local;
            result = get_sharing_data( eh, ent_procs, handles, pstat, num_sharing );MB_CHK_SET_ERR( result, "can't get sharing data" );
            // see if the proc tmp.owner is in the list of ent_procs; if not, we have to increase
            // handles, and ent_procs; and set
            int proc_remote = tmp.owner;  //
            if( std::find( ent_procs, ent_procs + num_sharing, proc_remote ) == ent_procs + num_sharing )
                // so we did not find on proc
#ifndef NDEBUG
                std::cout << "THIN GHOST: we did not find on proc " << rank() << " for shared ent " << eh
                          << " the proc " << proc_remote << "\n";
#endif
                // increase num_sharing, and set the multi-shared tags
                if( num_sharing >= MAX_SHARING_PROCS ) return MB_FAILURE;
                handles[num_sharing]       = tmp.remote;
                handles[num_sharing + 1]   = 0;  // end of list
                ent_procs[num_sharing]     = tmp.owner;
                ent_procs[num_sharing + 1] = -1;  // this should be already set
                result                     = mbImpl->tag_set_data( sharedps_tag(), &eh, 1, ent_procs );MB_CHK_SET_ERR( result, "Failed to set sharedps tag data" );
                result = mbImpl->tag_set_data( sharedhs_tag(), &eh, 1, handles );MB_CHK_SET_ERR( result, "Failed to set sharedhs tag data" );
                if( 2 == num_sharing )  // it means the sharedp and sharedh tags were set with a
                                        // value non default
                    // so entity eh was simple shared before, we need to set those dense tags back
                    // to default
                    //  values
                    EntityHandle zero = 0;
                    int no_proc       = -1;
                    result            = mbImpl->tag_set_data( sharedp_tag(), &eh, 1, &no_proc );MB_CHK_SET_ERR( result, "Failed to set sharedp tag data" );
                    result = mbImpl->tag_set_data( sharedh_tag(), &eh, 1, &zero );MB_CHK_SET_ERR( result, "Failed to set sharedh tag data" );
                    // also, add multishared pstatus tag
                    // also add multishared status to pstatus
                    pstat  = pstat | PSTATUS_MULTISHARED;
                    result = mbImpl->tag_set_data( pstatus_tag(), &eh, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" );
    return MB_SUCCESS;
Definition at line 5093 of file ParallelComm.cpp.
References moab::Interface::add_parent_child(), moab::Range::begin(), moab::Range::clear(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_handle(), interfaceSets, MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, mbImpl, moab::Range::rbegin(), moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
    // Now that we've resolved the entities in the iface sets,
    // set parent/child links between the iface sets
    // First tag all entities in the iface sets
    Tag tmp_iface_tag;
    EntityHandle tmp_iface_set = 0;
    ErrorCode result           = mbImpl->tag_get_handle( "__tmp_iface", 1, MB_TYPE_HANDLE, tmp_iface_tag,
                                                         MB_TAG_DENSE | MB_TAG_CREAT, &tmp_iface_set );MB_CHK_SET_ERR( result, "Failed to create temporary interface set tag" );
    Range iface_ents;
    std::vector< EntityHandle > tag_vals;
    for( rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit )
        // tag entities with interface set
        iface_ents.clear();
        result = mbImpl->get_entities_by_handle( *rit, iface_ents );MB_CHK_SET_ERR( result, "Failed to get entities in interface set" );
        if( iface_ents.empty() ) continue;
        tag_vals.resize( iface_ents.size() );
        std::fill( tag_vals.begin(), tag_vals.end(), *rit );
        result = mbImpl->tag_set_data( tmp_iface_tag, iface_ents, &tag_vals[0] );MB_CHK_SET_ERR( result, "Failed to tag iface entities with interface set" );
    // Now go back through interface sets and add parent/child links
    Range tmp_ents2;
    for( int d = 2; d >= 0; d-- )
            // Get entities on this interface
            iface_ents.clear();
            result = mbImpl->get_entities_by_handle( *rit, iface_ents, true );MB_CHK_SET_ERR( result, "Failed to get entities by handle" );
            if( iface_ents.empty() || mbImpl->dimension_from_handle( *iface_ents.rbegin() ) != d ) continue;
            // Get higher-dimensional entities and their interface sets
            result = mbImpl->get_adjacencies( &( *iface_ents.begin() ), 1, d + 1, false, tmp_ents2 );MB_CHK_SET_ERR( result, "Failed to get adjacencies for interface sets" );
            tag_vals.resize( tmp_ents2.size() );
            result = mbImpl->tag_get_data( tmp_iface_tag, tmp_ents2, &tag_vals[0] );MB_CHK_SET_ERR( result, "Failed to get tmp iface tag for interface sets" );
            // Go through and for any on interface make it a parent
            EntityHandle last_set = 0;
            for( unsigned int i = 0; i < tag_vals.size(); i++ )
                if( tag_vals[i] && tag_vals[i] != last_set )
                    result = mbImpl->add_parent_child( tag_vals[i], *rit );MB_CHK_SET_ERR( result, "Failed to add parent/child link for interface set" );
                    last_set = tag_vals[i];
    // Delete the temporary tag
    result = mbImpl->tag_delete( tmp_iface_tag );MB_CHK_SET_ERR( result, "Failed to delete tmp iface tag" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::create_interface_sets ( std::map< std::vector< int >, std::vector< EntityHandle > > &  proc_nvecs)
Definition at line 5017 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::CN::EntityTypeName(), ErrorCode, moab::GeomUtil::first(), get_shared_proc_tags(), moab::ID_FROM_HANDLE(), moab::Range::insert(), interfaceSets, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, MBVERTEX, MESHSET_SET, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, moab::Interface::tag_set_data(), moab::TYPE_FROM_HANDLE(), and moab::Interface::type_from_handle().
Referenced by create_interface_sets(), exchange_owned_meshs(), resolve_shared_ents(), moab::ScdInterface::tag_shared_vertices(), and moab::ParallelMergeMesh::TagSharedElements().
    if( proc_nvecs.empty() ) return MB_SUCCESS;
    int proc_ids[MAX_SHARING_PROCS];
    EntityHandle proc_handles[MAX_SHARING_PROCS];
    Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag;
    ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags in create_interface_sets" );
    // Create interface sets, tag them, and tag their contents with iface set tag
    for( std::map< std::vector< int >, std::vector< EntityHandle > >::iterator vit = proc_nvecs.begin();
         vit != proc_nvecs.end(); ++vit )
        // Create the set
        // Add entities
        assert( !vit->second.empty() );
        result = mbImpl->add_entities( new_set, &( vit->second )[0], ( vit->second ).size() );MB_CHK_SET_ERR( result, "Failed to add entities to interface set" );
        if( vit->first.size() == 1 )
            assert( ( vit->first )[0] != (int)procConfig.proc_rank() );
            result = mbImpl->tag_set_data( shp_tag, &new_set, 1, &( vit->first )[0] );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
            proc_handles[0] = 0;
            result          = mbImpl->tag_set_data( shh_tag, &new_set, 1, proc_handles );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
        else
            // Pad tag data out to MAX_SHARING_PROCS with -1
            if( vit->first.size() > MAX_SHARING_PROCS )
                std::cerr << "Exceeded MAX_SHARING_PROCS for " << CN::EntityTypeName( TYPE_FROM_HANDLE( new_set ) )
                          << ' ' << ID_FROM_HANDLE( new_set ) << " on process " << proc_config().proc_rank()
                          << std::endl;
                std::cerr.flush();
                MPI_Abort( proc_config().proc_comm(), 66 );
            // assert(vit->first.size() <= MAX_SHARING_PROCS);
            std::copy( vit->first.begin(), vit->first.end(), proc_ids );
            std::fill( proc_ids + vit->first.size(), proc_ids + MAX_SHARING_PROCS, -1 );
            result = mbImpl->tag_set_data( shps_tag, &new_set, 1, proc_ids );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
            unsigned int ind = std::find( proc_ids, proc_ids + vit->first.size(), procConfig.proc_rank() ) - proc_ids;
            assert( ind < vit->first.size() );
            std::fill( proc_handles, proc_handles + MAX_SHARING_PROCS, 0 );
            proc_handles[ind] = new_set;
            result            = mbImpl->tag_set_data( shhs_tag, &new_set, 1, proc_handles );MB_CHK_SET_ERR( result, "Failed to tag interface set with procs" );
        // Get the owning proc, then set the pstatus tag on iface set
        int min_proc       = ( vit->first )[0];
        unsigned char pval = ( PSTATUS_SHARED | PSTATUS_INTERFACE );
        if( min_proc < (int)procConfig.proc_rank() ) pval |= PSTATUS_NOT_OWNED;
        if( vit->first.size() > 1 ) pval |= PSTATUS_MULTISHARED;
        result = mbImpl->tag_set_data( pstat_tag, &new_set, 1, &pval );MB_CHK_SET_ERR( result, "Failed to tag interface set with pstatus" );
        // Tag the vertices with the same thing
        pstatus.clear();
        std::vector< EntityHandle > verts;
        for( std::vector< EntityHandle >::iterator v2it = ( vit->second ).begin(); v2it != ( vit->second ).end();
             ++v2it )
            if( mbImpl->type_from_handle( *v2it ) == MBVERTEX ) verts.push_back( *v2it );
        pstatus.resize( verts.size(), pval );
        if( !verts.empty() )
            result = mbImpl->tag_set_data( pstat_tag, &verts[0], verts.size(), &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to tag interface set vertices with pstatus" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::create_interface_sets ( EntityHandle  this_set,
int  resolve_dim,
int  shared_dim
Definition at line 4981 of file ParallelComm.cpp.
References create_interface_sets(), moab::Interface::dimension_from_handle(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), get_proc_nvecs(), get_sharing_data(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, mbImpl, sharedEnts, and moab::Interface::UNION.
    std::map< std::vector< int >, std::vector< EntityHandle > > proc_nvecs;
    // Build up the list of shared entities
    ErrorCode result;
    int nprocs;
        if( shared_dim != -1 && mbImpl->dimension_from_handle( *vit ) > shared_dim ) continue;
        result = get_sharing_data( *vit, procs, handles, pstat, nprocs );MB_CHK_SET_ERR( result, "Failed to get sharing data" );
        std::sort( procs, procs + nprocs );
        std::vector< int > tmp_procs( procs, procs + nprocs );
        assert( tmp_procs.size() != 2 );
        proc_nvecs[tmp_procs].push_back( *vit );
    Skinner skinner( mbImpl );
    Range skin_ents[4];
    result = mbImpl->get_entities_by_dimension( this_set, resolve_dim, skin_ents[resolve_dim] );MB_CHK_SET_ERR( result, "Failed to get skin entities by dimension" );
    result =
        skinner.find_skin( this_set, skin_ents[resolve_dim], false, skin_ents[resolve_dim - 1], 0, true, true, true );MB_CHK_SET_ERR( result, "Failed to find skin" );
    if( shared_dim > 1 )
        result = mbImpl->get_adjacencies( skin_ents[resolve_dim - 1], resolve_dim - 2, true, skin_ents[resolve_dim - 2],
                                          Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get skin adjacencies" );
    result = get_proc_nvecs( resolve_dim, shared_dim, skin_ents, proc_nvecs );
    return create_interface_sets( proc_nvecs );
Definition at line 8210 of file ParallelComm.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), ErrorCode, get_partitioning(), globalPartCount, moab::Range::index(), moab::Range::insert(), MB_SUCCESS, mbImpl, MESHSET_SET, part_tag(), partition_sets(), proc_config(), moab::ProcConfig::proc_rank(), and moab::Interface::tag_set_data().
Referenced by iMeshP_createPart().
    // Mark as invalid so we know that it needs to be updated
    globalPartCount = -1;
    // Create set representing part
    ErrorCode rval = mbImpl->create_meshset( MESHSET_SET, set_out );
    if( MB_SUCCESS != rval ) return rval;
    // Set tag on set
    int val = proc_config().proc_rank();
    rval    = mbImpl->tag_set_data( part_tag(), &set_out, 1, &val );
        mbImpl->delete_entities( &set_out, 1 );
        return rval;
    if( get_partitioning() )
        rval = mbImpl->add_entities( get_partitioning(), &set_out, 1 );
            return rval;
    moab::Range& pSets = this->partition_sets();
    if( pSets.index( set_out ) < 0 )
        pSets.insert( set_out );
    return MB_SUCCESS;
void moab::ParallelComm::define_mpe ( ) [private]
Definition at line 4228 of file ParallelComm.cpp.
References moab::DebugOutput::get_verbosity(), MPE_Describe_state, MPE_LOG_OK, and myDebug.
Referenced by resolve_shared_ents().
#ifdef MOAB_HAVE_MPE
    if( myDebug->get_verbosity() == 2 )
        // Define mpe states used for logging
        int success;
        MPE_Log_get_state_eventIDs( &IFACE_START, &IFACE_END );
        MPE_Log_get_state_eventIDs( &GHOST_START, &GHOST_END );
        MPE_Log_get_state_eventIDs( &SHAREDV_START, &SHAREDV_END );
        MPE_Log_get_state_eventIDs( &RESOLVE_START, &RESOLVE_END );
        MPE_Log_get_state_eventIDs( &ENTITIES_START, &ENTITIES_END );
        MPE_Log_get_state_eventIDs( &RHANDLES_START, &RHANDLES_END );
        MPE_Log_get_state_eventIDs( &OWNED_START, &OWNED_END );
        success = MPE_Describe_state( IFACE_START, IFACE_END, "Resolve interface ents", "green" );
        assert( MPE_LOG_OK == success );
        success = MPE_Describe_state( GHOST_START, GHOST_END, "Exchange ghost ents", "red" );
        success = MPE_Describe_state( SHAREDV_START, SHAREDV_END, "Resolve interface vertices", "blue" );
        success = MPE_Describe_state( RESOLVE_START, RESOLVE_END, "Resolve shared ents", "purple" );
        success = MPE_Describe_state( ENTITIES_START, ENTITIES_END, "Exchange shared ents", "yellow" );
        success = MPE_Describe_state( RHANDLES_START, RHANDLES_END, "Remote handles", "cyan" );
        success = MPE_Describe_state( OWNED_START, OWNED_END, "Exchange owned ents", "black" );
#endif
void moab::ParallelComm::delete_all_buffers ( ) [inline, private]
reset message buffers to their initial state
delete all buffers, freeing up any memory held by them
Definition at line 1557 of file ParallelComm.hpp.
References localOwnedBuffs, and remoteOwnedBuffs.
Referenced by ~ParallelComm().
    std::vector< Buffer* >::iterator vit;
    for( vit = localOwnedBuffs.begin(); vit != localOwnedBuffs.end(); ++vit )
        delete( *vit );
    localOwnedBuffs.clear();
    for( vit = remoteOwnedBuffs.begin(); vit != remoteOwnedBuffs.end(); ++vit )
        delete( *vit );
    remoteOwnedBuffs.clear();
Definition at line 9258 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ProcConfig::crystal_router(), moab::Interface::delete_entities(), moab::TupleList::enableWriteAccess(), moab::Range::end(), ErrorCode, moab::TupleList::get_n(), get_sharing_data(), moab::TupleList::inc_n(), moab::Range::index(), moab::TupleList::initialize(), moab::Range::insert(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, procConfig, sharedEnts, moab::Range::size(), moab::TupleList::vi_wr, moab::TupleList::vul_rd, and moab::TupleList::vul_wr.
Referenced by moab::NCHelperScrip::create_mesh(), and test_delete_entities().
    // Will not look at shared sets yet, but maybe we should
    // First, see if any of the entities to delete is shared; then inform the other processors
    // about their fate (to be deleted), using a crystal router transfer
    ErrorCode rval = MB_SUCCESS;
    EntityHandle tmp_handles[MAX_SHARING_PROCS];
    unsigned int num_ps;
    TupleList ents_to_delete;
    ents_to_delete.initialize( 1, 0, 1, 0, to_delete.size() * ( MAX_SHARING_PROCS + 1 ) );  // A little bit of overkill
    ents_to_delete.enableWriteAccess();
    unsigned int i = 0;
    for( Range::iterator it = to_delete.begin(); it != to_delete.end(); ++it )
        EntityHandle eh = *it;  // Entity to be deleted
        rval = get_sharing_data( eh, tmp_procs, tmp_handles, pstat, num_ps );
        if( rval != MB_SUCCESS || num_ps == 0 ) continue;
        // Add to the tuple list the information to be sent (to the remote procs)
        for( unsigned int p = 0; p < num_ps; p++ )
            ents_to_delete.vi_wr[i]  = tmp_procs[p];
            ents_to_delete.vul_wr[i] = (unsigned long)tmp_handles[p];
            i++;
            ents_to_delete.inc_n();
    rval = cd->gs_transfer( 1, ents_to_delete, 0 );MB_CHK_SET_ERR( rval, "Error in tuple transfer" );
    // Add to the range of ents to delete the new ones that were sent from other procs
    unsigned int received = ents_to_delete.get_n();
    for( i = 0; i < received; i++ )
        unsigned long valrec = ents_to_delete.vul_rd[i];
        to_delete.insert( (EntityHandle)valrec );
    rval = mbImpl->delete_entities( to_delete );MB_CHK_SET_ERR( rval, "Error in deleting actual entities" );
    std::set< EntityHandle > good_ents;
    for( std::set< EntityHandle >::iterator sst = sharedEnts.begin(); sst != sharedEnts.end(); sst++ )
        EntityHandle eh = *sst;
        int index       = to_delete.index( eh );
        if( -1 == index ) good_ents.insert( eh );
    sharedEnts = good_ents;
    // What about shared sets? Who is updating them?
    return MB_SUCCESS;
Definition at line 8248 of file ParallelComm.cpp.
References moab::Interface::delete_entities(), moab::Range::erase(), ErrorCode, get_partitioning(), globalPartCount, moab::Range::index(), MB_SUCCESS, mbImpl, partition_sets(), and moab::Interface::remove_entities().
Referenced by iMeshP_destroyPart().
    ErrorCode rval;
        rval = mbImpl->remove_entities( get_partitioning(), &part_id, 1 );
    if( pSets.index( part_id ) >= 0 )
        pSets.erase( part_id );
    return mbImpl->delete_entities( &part_id, 1 );
int moab::ParallelComm::estimate_ents_buffer_size ( Range entities,
const bool  store_remote_handles
) [private]
estimate size required to pack entities
Definition at line 1503 of file ParallelComm.cpp.
References ErrorCode, moab::Interface::get_connectivity(), moab::Range::lower_bound(), MB_CHK_SET_ERR_RET_VAL, MBEDGE, MBENTITYSET, mbImpl, MBVERTEX, moab::Range::num_of_type(), t, and moab::TYPE_FROM_HANDLE().
    int buff_size = 0;
    std::vector< EntityHandle > dum_connect_vec;
    int num_connect;
    int num_verts = entities.num_of_type( MBVERTEX );
    // # verts + coords + handles
    buff_size += 2 * sizeof( int ) + 3 * sizeof( double ) * num_verts;
    if( store_remote_handles ) buff_size += sizeof( EntityHandle ) * num_verts;
    // Do a rough count by looking at first entity of each type
    for( EntityType t = MBEDGE; t < MBENTITYSET; t++ )
        const Range::iterator rit = entities.lower_bound( t );
        if( TYPE_FROM_HANDLE( *rit ) != t ) continue;
        ErrorCode result = mbImpl->get_connectivity( *rit, connect, num_connect, false, &dum_connect_vec );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get connectivity to estimate buffer size", -1 );
        // Number, type, nodes per entity
        buff_size += 3 * sizeof( int );
        int num_ents = entities.num_of_type( t );
        // Connectivity, handle for each ent
        buff_size += ( num_connect + 1 ) * sizeof( EntityHandle ) * num_ents;
    // Extra entity type at end, passed as int
    buff_size += sizeof( int );
    return buff_size;
int moab::ParallelComm::estimate_sets_buffer_size ( Range entities,
) [private]
estimate size required to pack sets
Definition at line 1536 of file ParallelComm.cpp.
References moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), moab::Interface::get_meshset_options(), moab::Interface::get_number_entities_by_handle(), moab::Range::lower_bound(), MB_CHK_SET_ERR_RET_VAL, MBENTITYSET, mbImpl, MESHSET_SET, moab::Interface::num_child_meshsets(), moab::Interface::num_parent_meshsets(), and moab::RANGE_SIZE().
Referenced by pack_sets().
    // Number of sets
    int buff_size = sizeof( int );
    Range::iterator rit = entities.lower_bound( MBENTITYSET );
    ErrorCode result;
    for( ; rit != entities.end(); ++rit )
        unsigned int options;
        result = mbImpl->get_meshset_options( *rit, options );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get meshset options", -1 );
        Range set_range;
        if( options & MESHSET_SET )
            // Range-based set; count the subranges
            result = mbImpl->get_entities_by_handle( *rit, set_range );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get set entities", -1 );
            // Set range
            buff_size += RANGE_SIZE( set_range );
        else if( options & MESHSET_ORDERED )
            // Just get the number of entities in the set
            int num_ents;
            result = mbImpl->get_number_entities_by_handle( *rit, num_ents );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get number entities in ordered set", -1 );
            // Set vec
            buff_size += sizeof( EntityHandle ) * num_ents + sizeof( int );
        // Get numbers of parents/children
        int num_par, num_ch;
        result = mbImpl->num_child_meshsets( *rit, &num_ch );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get num children", -1 );
        result = mbImpl->num_parent_meshsets( *rit, &num_par );MB_CHK_SET_ERR_RET_VAL( result, "Failed to get num parents", -1 );
        buff_size += ( num_ch + num_par ) * sizeof( EntityHandle ) + 2 * sizeof( int );
    return buff_size;
ErrorCode moab::ParallelComm::exchange_all_shared_handles ( std::vector< std::vector< SharedEntityData > > &  send_data,
std::vector< std::vector< SharedEntityData > > &  result
) [private]
Every processor sends shared entity handle data to every other processor that it shares entities with. Passed back map is all received data, indexed by processor ID. This function is intended to be used for debugging.
Definition at line 8474 of file ParallelComm.cpp.
References buffProcs, ierr, MB_FILE_WRITE_ERROR, MB_SUCCESS, moab::ProcConfig::proc_comm(), and procConfig.
Referenced by check_all_shared_handles(), and correct_thin_ghost_layers().
    int ierr;
    const int tag      = 0;
    const MPI_Comm cm  = procConfig.proc_comm();
    const int num_proc = buffProcs.size();
    const std::vector< int > procs( buffProcs.begin(), buffProcs.end() );
    std::vector< MPI_Request > recv_req( buffProcs.size(), MPI_REQUEST_NULL );
    std::vector< MPI_Request > send_req( buffProcs.size(), MPI_REQUEST_NULL );
    // Set up to receive sizes
    std::vector< int > sizes_send( num_proc ), sizes_recv( num_proc );
    for( int i = 0; i < num_proc; i++ )
        ierr = MPI_Irecv( &sizes_recv[i], 1, MPI_INT, procs[i], tag, cm, &recv_req[i] );
        if( ierr ) return MB_FILE_WRITE_ERROR;
    // Send sizes
    assert( num_proc == (int)send_data.size() );
    result.resize( num_proc );
        sizes_send[i] = send_data[i].size();
        ierr          = MPI_Isend( &sizes_send[i], 1, MPI_INT, buffProcs[i], tag, cm, &send_req[i] );
    // Receive sizes
    std::vector< MPI_Status > stat( num_proc );
    ierr = MPI_Waitall( num_proc, &recv_req[0], &stat[0] );
    // Wait until all sizes are sent (clean up pending req's)
    ierr = MPI_Waitall( num_proc, &send_req[0], &stat[0] );
    // Set up to receive data
        result[i].resize( sizes_recv[i] );
        ierr = MPI_Irecv( (void*)( &( result[i][0] ) ), sizeof( SharedEntityData ) * sizes_recv[i], MPI_UNSIGNED_CHAR,
                          buffProcs[i], tag, cm, &recv_req[i] );
    // Send data
        ierr = MPI_Isend( (void*)( &( send_data[i][0] ) ), sizeof( SharedEntityData ) * sizes_send[i],
                          MPI_UNSIGNED_CHAR, buffProcs[i], tag, cm, &send_req[i] );
    // Receive data
    // Wait until everything is sent to release send buffers
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::exchange_ghost_cells ( int  ghost_dim,
int  bridge_dim,
int  num_layers,
int  addl_ents,
bool  store_remote_handles,
bool  wait_all = true,
EntityHandle file_set = NULL
Exchange ghost cells with neighboring procs Neighboring processors are those sharing an interface with this processor. All entities of dimension ghost_dim within num_layers of interface, measured going through bridge_dim, are exchanged. See MeshTopoUtil::get_bridge_adjacencies for description of bridge adjacencies. If wait_all is false and store_remote_handles is true, MPI_Request objects are available in the sendReqs[2*MAX_SHARING_PROCS] member array, with inactive requests marked as MPI_REQUEST_NULL. If store_remote_handles or wait_all is false, this function returns after all entities have been received and processed.
Parameters:
ghost_dimDimension of ghost entities to be exchanged
bridge_dimDimension of entities used to measure layers from interface
num_layersNumber of layers of ghosts requested
addl_entsDimension of additional adjacent entities to exchange with ghosts, 0 if none
store_remote_handlesIf true, send message with new entity handles to source processor
wait_allIf true, function does not return until all send buffers are cleared.
Examples:
HelloParMOAB.cpp.
Definition at line 5687 of file ParallelComm.cpp.
References moab::Interface::add_entities(), buffProcs, check_all_shared_handles(), check_clean_iface(), check_sent_ents(), moab::Range::compactness(), moab::Range::empty(), ErrorCode, get_sent_ents(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, mbImpl, MPE_Log_event, moab::msgs, myDebug, pack_entities(), pack_remote_handles(), print_buffer(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), remoteOwnedBuffs, moab::TupleList::reset(), reset_all_buffers(), send_buffer(), sendReqs, sharedEnts, moab::Range::size(), size(), tag_iface_entities(), moab::DebugOutput::tprintf(), unpack_entities(), and unpack_remote_handles().
Referenced by create_parallel_mesh(), moab::NestedRefine::exchange_ghosts(), iMesh_createStructuredMesh(), iMeshP_createGhostEntsAll(), moab::ReadParallel::load_file(), main(), resolve_and_exchange(), resolve_shared_ents(), moab::ParallelMergeMesh::TagSharedElements(), test_correct_ghost(), test_ghosted_entity_shared_data(), test_interface_owners_common(), test_pack_shared_entities_2d(), test_pack_shared_entities_3d(), test_read_and_ghost_after(), and test_read_with_thin_ghost_layer().
        if( !num_layers )
            MPE_Log_event( IFACE_START, procConfig.proc_rank(), "Starting interface exchange." );
        else
            MPE_Log_event( GHOST_START, procConfig.proc_rank(), "Starting ghost exchange." );
#endif
    myDebug->tprintf( 1, "Entering exchange_ghost_cells with num_layers = %d\n", num_layers );
    if( myDebug->get_verbosity() == 4 )
        msgs.clear();
        msgs.reserve( MAX_SHARING_PROCS );
    // If we're only finding out about existing ents, we have to be storing
    // remote handles too
    assert( num_layers > 0 || store_remote_handles );
    const bool is_iface = !num_layers;
    // Get the b-dimensional interface(s) with with_proc, where b = bridge_dim
    int success;
    int incoming1 = 0, incoming2 = 0;
    reset_all_buffers();
    // When this function is called, buffProcs should already have any
    // communicating procs
    // Post ghost irecv's for ghost entities from all communicating procs
        MPE_Log_event( ENTITIES_START, procConfig.proc_rank(), "Starting entity exchange." );
#endif
    // Index reqs the same as buffer/sharing procs indices
    std::vector< MPI_Request > recv_ent_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL ),
        recv_remoteh_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    std::vector< unsigned int >::iterator proc_it;
    int ind, p;
    sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    for( ind = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, ind++ )
        incoming1++;
        PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[ind], remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE,
                           MB_MESG_ENTS_SIZE, incoming1 );
        success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[ind],
                             MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recv_ent_reqs[3 * ind] );
        if( success != MPI_SUCCESS )
            MB_SET_ERR( MB_FAILURE, "Failed to post irecv in ghost exchange" );
    // Get entities to be sent to neighbors
    Range sent_ents[MAX_SHARING_PROCS], allsent, tmp_range;
    TupleList entprocs;
    int dum_ack_buff;
    result = get_sent_ents( is_iface, bridge_dim, ghost_dim, num_layers, addl_ents, sent_ents, allsent, entprocs );MB_CHK_SET_ERR( result, "get_sent_ents failed" );
    // augment file set with the entities to be sent
    // we might have created new entities if addl_ents>0, edges and/or faces
    if( addl_ents > 0 && file_set && !allsent.empty() )
        result = mbImpl->add_entities( *file_set, allsent );MB_CHK_SET_ERR( result, "Failed to add new sub-entities to set" );
    myDebug->tprintf( 1, "allsent ents compactness (size) = %f (%lu)\n", allsent.compactness(),
                      (unsigned long)allsent.size() );
    // Pack and send ents from this proc to others
    for( p = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, p++ )
        myDebug->tprintf( 1, "Sent ents compactness (size) = %f (%lu)\n", sent_ents[p].compactness(),
                          (unsigned long)sent_ents[p].size() );
        // Reserve space on front for size and for initial buff size
        localOwnedBuffs[p]->reset_buffer( sizeof( int ) );
        // Entities
        result = pack_entities( sent_ents[p], localOwnedBuffs[p], store_remote_handles, buffProcs[p], is_iface,
                                &entprocs, &allsent );MB_CHK_SET_ERR( result, "Packing entities failed" );
            msgs.resize( msgs.size() + 1 );
            msgs.back() = new Buffer( *localOwnedBuffs[p] );
        // Send the buffer (size stored in front in send_buffer)
        result = send_buffer( *proc_it, localOwnedBuffs[p], MB_MESG_ENTS_SIZE, sendReqs[3 * p],
                              recv_ent_reqs[3 * p + 2], &dum_ack_buff, incoming1, MB_MESG_REMOTEH_SIZE,
                              ( !is_iface && store_remote_handles ?  // this used for ghosting only
                                    localOwnedBuffs[p]
        : NULL ),
                              &recv_remoteh_reqs[3 * p], &incoming2 );MB_CHK_SET_ERR( result, "Failed to Isend in ghost exchange" );
    entprocs.reset();
    // Receive/unpack new entities
    // Number of incoming messages for ghosts is the number of procs we
    // communicate with; for iface, it's the number of those with lower rank
    MPI_Status status;
    std::vector< std::vector< EntityHandle > > recd_ents( buffProcs.size() );
    std::vector< std::vector< EntityHandle > > L1hloc( buffProcs.size() ), L1hrem( buffProcs.size() );
    std::vector< std::vector< int > > L1p( buffProcs.size() );
    std::vector< EntityHandle > L2hloc, L2hrem;
    std::vector< unsigned int > L2p;
    std::vector< EntityHandle > new_ents;
    while( incoming1 )
        // Wait for all recvs of ghost ents before proceeding to sending remote handles,
        // b/c some procs may have sent to a 3rd proc ents owned by me;
        PRINT_DEBUG_WAITANY( recv_ent_reqs, MB_MESG_ENTS_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 3 * buffProcs.size(), &recv_ent_reqs[0], &ind, &status );
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in ghost exchange" );
        PRINT_DEBUG_RECD( status );
        // OK, received something; decrement incoming counter
        incoming1--;
        bool done = false;
        // In case ind is for ack, we need index of one before it
        unsigned int base_ind = 3 * ( ind / 3 );
        result = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind / 3], recv_ent_reqs[base_ind + 1],
                              recv_ent_reqs[base_ind + 2], incoming1, localOwnedBuffs[ind / 3], sendReqs[base_ind + 1],
                              sendReqs[base_ind + 2], done,
                              ( !is_iface && store_remote_handles ? localOwnedBuffs[ind / 3] : NULL ),
                              MB_MESG_REMOTEH_SIZE,  // maybe base_ind+1?
                              &recv_remoteh_reqs[base_ind + 1], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" );
        if( done )
                msgs.back() = new Buffer( *remoteOwnedBuffs[ind / 3] );
            // Message completely received - process buffer that was sent
            remoteOwnedBuffs[ind / 3]->reset_ptr( sizeof( int ) );
            result = unpack_entities( remoteOwnedBuffs[ind / 3]->buff_ptr, store_remote_handles, ind / 3, is_iface,
                                      L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents );
                std::cout << "Failed to unpack entities. Buffer contents:" << std::endl;
                print_buffer( remoteOwnedBuffs[ind / 3]->mem_ptr, MB_MESG_ENTS_SIZE, buffProcs[ind / 3], false );
                return result;
            if( recv_ent_reqs.size() != 3 * buffProcs.size() )
                // Post irecv's for remote handles from new proc; shouldn't be iface,
                // since we know about all procs we share with
                assert( !is_iface );
                recv_remoteh_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL );
                for( unsigned int i = recv_ent_reqs.size(); i < 3 * buffProcs.size(); i += 3 )
                    localOwnedBuffs[i / 3]->reset_buffer();
                    incoming2++;
                    PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[i / 3], localOwnedBuffs[i / 3]->mem_ptr,
                                       INITIAL_BUFF_SIZE, MB_MESG_REMOTEH_SIZE, incoming2 );
                    success = MPI_Irecv( localOwnedBuffs[i / 3]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR,
                                         buffProcs[i / 3], MB_MESG_REMOTEH_SIZE, procConfig.proc_comm(),
                                         &recv_remoteh_reqs[i] );
                        MB_SET_ERR( MB_FAILURE, "Failed to post irecv for remote handles in ghost exchange" );
                recv_ent_reqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    // Add requests for any new addl procs
        // Shouldn't get here...
        MB_SET_ERR( MB_FAILURE, "Requests length doesn't match proc count in ghost exchange" );
        MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending entity exchange." );
#endif
    if( is_iface )
        // Need to check over entities I sent and make sure I received
        // handles for them from all expected procs; if not, need to clean
        // them up
        result = check_clean_iface( allsent );
        if( MB_SUCCESS != result ) std::cout << "Failed check." << std::endl;
        // Now set the shared/interface tag on non-vertex entities on interface
        result = tag_iface_entities();MB_CHK_SET_ERR( result, "Failed to tag iface entities" );
#ifndef NDEBUG
        result = check_sent_ents( allsent );
        result = check_all_shared_handles( true );
#endif
            MPE_Log_event( IFACE_END, procConfig.proc_rank(), "Ending interface exchange." );
#endif
        // Wait if requested
        if( wait_all )
            if( myDebug->get_verbosity() == 5 )
                success = MPI_Barrier( procConfig.proc_comm() );
            else
                MPI_Status mult_status[3 * MAX_SHARING_PROCS];
                success = MPI_Waitall( 3 * buffProcs.size(), &recv_ent_reqs[0], mult_status );
                    MB_SET_ERR( MB_FAILURE, "Failed in waitall in ghost exchange" );
                success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], mult_status );
                /*success = MPI_Waitall(3*buffProcs.size(), &recv_remoteh_reqs[0], mult_status);
                if (MPI_SUCCESS != success) {
                  MB_SET_ERR(MB_FAILURE, "Failed in waitall in ghost exchange");
        myDebug->tprintf( 1, "Total number of shared entities = %lu.\n", (unsigned long)sharedEnts.size() );
        myDebug->tprintf( 1, "Exiting exchange_ghost_cells for is_iface==true \n" );
        return MB_SUCCESS;
    // we still need to wait on sendReqs, if they are not fulfilled yet
    if( wait_all )
        else
    // Send local handles for new ghosts to owner, then add
    // those to ghost list for that owner
        remoteOwnedBuffs[p]->reset_buffer( sizeof( int ) );
        result = pack_remote_handles( L1hloc[p], L1hrem[p], L1p[p], *proc_it, remoteOwnedBuffs[p] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" );
        remoteOwnedBuffs[p]->set_stored_size();
            msgs.back() = new Buffer( *remoteOwnedBuffs[p] );
        result = send_buffer( buffProcs[p], remoteOwnedBuffs[p], MB_MESG_REMOTEH_SIZE, sendReqs[3 * p],
                              recv_remoteh_reqs[3 * p + 2], &dum_ack_buff, incoming2 );MB_CHK_SET_ERR( result, "Failed to send remote handles" );
    // Process remote handles of my ghosteds
    while( incoming2 )
        PRINT_DEBUG_WAITANY( recv_remoteh_reqs, MB_MESG_REMOTEH_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 3 * buffProcs.size(), &recv_remoteh_reqs[0], &ind, &status );
        incoming2--;
        bool done             = false;
        result = recv_buffer( MB_MESG_REMOTEH_SIZE, status, localOwnedBuffs[ind / 3], recv_remoteh_reqs[base_ind + 1],
                              recv_remoteh_reqs[base_ind + 2], incoming2, remoteOwnedBuffs[ind / 3],
                              sendReqs[base_ind + 1], sendReqs[base_ind + 2], done );MB_CHK_SET_ERR( result, "Failed to receive remote handles" );
        if( done )
            // Incoming remote handles
                msgs.back() = new Buffer( *localOwnedBuffs[ind / 3] );
            localOwnedBuffs[ind / 3]->reset_ptr( sizeof( int ) );
            result =
                unpack_remote_handles( buffProcs[ind / 3], localOwnedBuffs[ind / 3]->buff_ptr, L2hloc, L2hrem, L2p );MB_CHK_SET_ERR( result, "Failed to unpack remote handles" );
        MPE_Log_event( RHANDLES_END, procConfig.proc_rank(), "Ending remote handles." );
        MPE_Log_event( GHOST_END, procConfig.proc_rank(), "Ending ghost exchange (still doing checks)." );
#endif
    if( wait_all )
        else
            success = MPI_Waitall( 3 * buffProcs.size(), &recv_remoteh_reqs[0], mult_status );
            if( MPI_SUCCESS == success ) success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], mult_status );
        if( MPI_SUCCESS != success )
#ifndef NDEBUG
    result = check_sent_ents( allsent );MB_CHK_SET_ERR( result, "Failed check on shared entities" );
    result = check_all_shared_handles( true );MB_CHK_SET_ERR( result, "Failed check on all shared handles" );
#endif
    if( file_set && !new_ents.empty() )
        result = mbImpl->add_entities( *file_set, &new_ents[0], new_ents.size() );MB_CHK_SET_ERR( result, "Failed to add new entities to set" );
    myDebug->tprintf( 1, "Exiting exchange_ghost_cells for is_iface==false \n" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::exchange_ghost_cells ( ParallelComm **  pc,
unsigned int  num_procs,
int  ghost_dim,
int  bridge_dim,
int  num_layers,
int  addl_ents,
EntityHandle file_sets = NULL
) [static]
Static version of exchange_ghost_cells, exchanging info through buffers rather than messages.
Definition at line 6588 of file ParallelComm.cpp.
References moab::Interface::add_entities(), buffProcs, check_all_shared_handles(), check_clean_iface(), check_sent_ents(), ErrorCode, get_moab(), get_sent_ents(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, pack_entities(), pack_remote_handles(), moab::Interface::query_interface(), moab::TupleList::reset(), size(), unpack_entities(), and unpack_remote_handles().
    // Static version of function, exchanging info through buffers rather
    // than through messages
    unsigned int ind;
    ParallelComm* pc;
    ErrorCode result = MB_SUCCESS;
    std::vector< Error* > ehs( num_procs );
    for( unsigned int i = 0; i < num_procs; i++ )
        result = pcs[i]->get_moab()->query_interface( ehs[i] );
        assert( MB_SUCCESS == result );
    // Done in a separate loop over procs because sometimes later procs
    // need to add info to earlier procs' messages
    Range sent_ents[MAX_SHARING_PROCS][MAX_SHARING_PROCS], allsent[MAX_SHARING_PROCS];
    TupleList entprocs[MAX_SHARING_PROCS];
    for( unsigned int p = 0; p < num_procs; p++ )
        pc     = pcs[p];
        result = pc->get_sent_ents( is_iface, bridge_dim, ghost_dim, num_layers, addl_ents, sent_ents[p], allsent[p],
                                    entprocs[p] );MB_CHK_SET_ERR( result, "p = " << p << ", get_sent_ents failed" );
        // Pack entities into buffers
        for( ind = 0; ind < pc->buffProcs.size(); ind++ )
            // Entities
            pc->localOwnedBuffs[ind]->reset_ptr( sizeof( int ) );
            result = pc->pack_entities( sent_ents[p][ind], pc->localOwnedBuffs[ind], store_remote_handles,
                                        pc->buffProcs[ind], is_iface, &entprocs[p], &allsent[p] );MB_CHK_SET_ERR( result, "p = " << p << ", packing entities failed" );
        entprocs[p].reset();
    std::vector< std::vector< EntityHandle > > L1hloc[MAX_SHARING_PROCS], L1hrem[MAX_SHARING_PROCS];
    std::vector< std::vector< int > > L1p[MAX_SHARING_PROCS];
    std::vector< EntityHandle > L2hloc[MAX_SHARING_PROCS], L2hrem[MAX_SHARING_PROCS];
    std::vector< unsigned int > L2p[MAX_SHARING_PROCS];
    std::vector< EntityHandle > new_ents[MAX_SHARING_PROCS];
        L1hloc[p].resize( pcs[p]->buffProcs.size() );
        L1hrem[p].resize( pcs[p]->buffProcs.size() );
        L1p[p].resize( pcs[p]->buffProcs.size() );
        pc = pcs[p];
            // Incoming ghost entities; unpack; returns entities received
            // both from sending proc and from owning proc (which may be different)
            // Buffer could be empty, which means there isn't any message to
            // unpack (due to this comm proc getting added as a result of indirect
            // communication); just skip this unpack
            if( pc->localOwnedBuffs[ind]->get_stored_size() == 0 ) continue;
            unsigned int to_p = pc->buffProcs[ind];
            result = pcs[to_p]->unpack_entities( pc->localOwnedBuffs[ind]->buff_ptr, store_remote_handles, ind,
                                                 is_iface, L1hloc[to_p], L1hrem[to_p], L1p[to_p], L2hloc[to_p],
                                                 L2hrem[to_p], L2p[to_p], new_ents[to_p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to unpack entities" );
    if( is_iface )
        // them up
            result = pcs[p]->check_clean_iface( allsent[p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to check on shared entities" );
#ifndef NDEBUG
            result = pcs[p]->check_sent_ents( allsent[p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to check on shared entities" );
        result = check_all_shared_handles( pcs, num_procs );MB_CHK_SET_ERR( result, "Failed to check on all shared handles" );
#endif
        return MB_SUCCESS;
        pc = pcs[p];
        for( ind = 0, proc_it = pc->buffProcs.begin(); proc_it != pc->buffProcs.end(); ++proc_it, ind++ )
            // Skip if iface layer and higher-rank proc
            result = pc->pack_remote_handles( L1hloc[p][ind], L1hrem[p][ind], L1p[p][ind], *proc_it,
                                              pc->localOwnedBuffs[ind] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to pack remote handles" );
        pc = pcs[p];
            result = pcs[to_p]->unpack_remote_handles( p, pc->localOwnedBuffs[ind]->buff_ptr, L2hloc[to_p],
                                                       L2hrem[to_p], L2p[to_p] );MB_CHK_SET_ERR( result, "p = " << p << ", failed to unpack remote handles" );
#ifndef NDEBUG
    result = ParallelComm::check_all_shared_handles( pcs, num_procs );MB_CHK_SET_ERR( result, "Failed to check on all shared handles" );
#endif
    if( file_sets )
            if( new_ents[p].empty() ) continue;
            result = pcs[p]->get_moab()->add_entities( file_sets[p], &new_ents[p][0], new_ents[p].size() );MB_CHK_SET_ERR( result, "p = " << p << ", failed to add new entities to set" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::exchange_owned_mesh ( std::vector< unsigned int > &  exchange_procs,
std::vector< Range * > &  exchange_ents,
std::vector< MPI_Request > &  recv_ent_reqs,
std::vector< MPI_Request > &  recv_remoteh_reqs,
const bool  recv_posted,
bool  wait_all,
bool  migrate = false
Exchange owned mesh for input mesh entities and sets This function is called twice by exchange_owned_meshs to exchange entities before sets.
Parameters:
migrateif the owner if entities are changed or not
Definition at line 6912 of file ParallelComm.cpp.
References add_verts(), assign_entities_part(), buffProcs, check_sent_ents(), moab::Range::compactness(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), ErrorCode, filter_pstatus(), get_buffers(), moab::TupleList::get_n(), moab::DebugOutput::get_verbosity(), moab::TupleList::inc_n(), INITIAL_BUFF_SIZE, moab::TupleList::initialize(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, moab::Range::merge(), MPE_Log_event, moab::msgs, myDebug, pack_buffer(), pack_remote_handles(), print_buffer(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, remove_entities_part(), moab::TupleList::buffer::reset(), moab::TupleList::reset(), reset_all_buffers(), send_buffer(), sendReqs, moab::Range::size(), size(), moab::TupleList::sort(), moab::subtract(), moab::DebugOutput::tprintf(), unpack_buffer(), unpack_remote_handles(), moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
Referenced by exchange_owned_meshs().
        MPE_Log_event( OWNED_START, procConfig.proc_rank(), "Starting owned ents exchange." );
#endif
    myDebug->tprintf( 1, "Entering exchange_owned_mesh\n" );
        msgs.clear();
    unsigned int i;
    int ind, success;
    // Set buffProcs with communicating procs
    unsigned int n_proc = exchange_procs.size();
    for( i = 0; i < n_proc; i++ )
        ind    = get_buffers( exchange_procs[i] );
        result = add_verts( *exchange_ents[i] );MB_CHK_SET_ERR( result, "Failed to add verts" );
        // Filter out entities already shared with destination
        Range tmp_range;
        result = filter_pstatus( *exchange_ents[i], PSTATUS_SHARED, PSTATUS_AND, buffProcs[ind], &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" );
        if( !tmp_range.empty() )
            *exchange_ents[i] = subtract( *exchange_ents[i], tmp_range );
    // Post ghost irecv's for entities from all communicating procs
#endif
    if( !recv_posted )
            incoming1++;
                               INITIAL_BUFF_SIZE, MB_MESG_ENTS_SIZE, incoming1 );
                MB_SET_ERR( MB_FAILURE, "Failed to post irecv in owned entity exchange" );
    else
        incoming1 += n_proc;
    // Need to get procs each entity is sent to
    Range allsent, tmp_range;
    int dum_ack_buff;
    int npairs = 0;
    TupleList entprocs;
        int n_ents = exchange_ents[i]->size();
        if( n_ents > 0 )
            npairs += n_ents;  // Get the total # of proc/handle pairs
            allsent.merge( *exchange_ents[i] );
    // Allocate a TupleList of that size
    entprocs.initialize( 1, 0, 1, 0, npairs );
    entprocs.enableWriteAccess();
    // Put the proc/handle pairs in the list
        for( Range::iterator rit = exchange_ents[i]->begin(); rit != exchange_ents[i]->end(); ++rit )
            entprocs.vi_wr[entprocs.get_n()]  = exchange_procs[i];
            entprocs.vul_wr[entprocs.get_n()] = *rit;
            entprocs.inc_n();
    // Sort by handle
    moab::TupleList::buffer sort_buffer;
    sort_buffer.buffer_init( npairs );
    entprocs.sort( 1, &sort_buffer );
    sort_buffer.reset();
        myDebug->tprintf( 1, "Sent ents compactness (size) = %f (%lu)\n", exchange_ents[i]->compactness(),
                          (unsigned long)exchange_ents[i]->size() );
        localOwnedBuffs[ind]->reset_buffer( sizeof( int ) );
        result = pack_buffer( *exchange_ents[i], false, true, store_remote_handles, buffProcs[ind],
                              localOwnedBuffs[ind], &entprocs, &allsent );
            msgs.back() = new Buffer( *localOwnedBuffs[ind] );
        result = send_buffer( exchange_procs[i], localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[3 * ind],
                              recv_ent_reqs[3 * ind + 2], &dum_ack_buff, incoming1, MB_MESG_REMOTEH_SIZE,
                              ( store_remote_handles ? localOwnedBuffs[ind] : NULL ), &recv_remoteh_reqs[3 * ind],
    entprocs.reset();
    // Number of incoming messages is the number of procs we communicate with
    MPI_Status status;
    while( incoming1 )
        // Wait for all recvs of ents before proceeding to sending remote handles,
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in owned entity exchange" );
        incoming1--;
        bool done = false;
                              sendReqs[base_ind + 2], done, ( store_remote_handles ? localOwnedBuffs[ind / 3] : NULL ),
                              MB_MESG_REMOTEH_SIZE, &recv_remoteh_reqs[base_ind + 1], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" );
        if( done )
            result = unpack_buffer( remoteOwnedBuffs[ind / 3]->buff_ptr, store_remote_handles, buffProcs[ind / 3],
                                    ind / 3, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents, true );
                return result;
                for( i = recv_ent_reqs.size(); i < 3 * buffProcs.size(); i += 3 )
                    incoming2++;
    // Assign and remove newly created elements from/to receive processor
    result = assign_entities_part( new_ents, procConfig.proc_rank() );MB_CHK_SET_ERR( result, "Failed to assign entities to part" );
    if( migrate )
        result = remove_entities_part( allsent, procConfig.proc_rank() );MB_CHK_SET_ERR( result, "Failed to remove entities to part" );
        MB_SET_ERR( MB_FAILURE, "Requests length doesn't match proc count in entity exchange" );
#endif
    if( wait_all )
        else
                MB_SET_ERR( MB_FAILURE, "Failed in waitall in exchange owned mesh" );
    // Send local handles for new entity to owner
        remoteOwnedBuffs[ind]->reset_buffer( sizeof( int ) );
        result = pack_remote_handles( L1hloc[ind], L1hrem[ind], L1p[ind], buffProcs[ind], remoteOwnedBuffs[ind] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" );
        remoteOwnedBuffs[ind]->set_stored_size();
            msgs.back() = new Buffer( *remoteOwnedBuffs[ind] );
        result = send_buffer( buffProcs[ind], remoteOwnedBuffs[ind], MB_MESG_REMOTEH_SIZE, sendReqs[3 * ind],
                              recv_remoteh_reqs[3 * ind + 2], &dum_ack_buff, incoming2 );MB_CHK_SET_ERR( result, "Failed to send remote handles" );
    while( incoming2 )
        incoming2--;
        bool done             = false;
        if( done )
            result =
        MPE_Log_event( OWNED_END, procConfig.proc_rank(), "Ending ghost exchange (still doing checks)." );
#endif
    if( wait_all )
        else
            MB_SET_ERR( MB_FAILURE, "Failed in waitall in owned entity exchange" );
#ifndef NDEBUG
#endif
    myDebug->tprintf( 1, "Exiting exchange_owned_mesh\n" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::exchange_owned_meshs ( std::vector< unsigned int > &  exchange_procs,
bool  migrate = false,
int  dim = 0
Exchange owned mesh for input mesh entities and sets This function should be called collectively over the communicator for this ParallelComm. If this version is called, all shared exchanged entities should have a value for this tag (or the tag should have a default value).
Parameters:
exchange_procsprocessor vector exchanged
exchange_entsexchanged entities for each processors
Definition at line 6842 of file ParallelComm.cpp.
References create_interface_sets(), moab::Interface::dimension_from_handle(), ErrorCode, exchange_owned_mesh(), get_sharing_data(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, recvRemotehReqs, recvReqs, sharedEnts, moab::Range::subset_by_type(), and moab::subtract().
Referenced by iMeshP_exchEntArrToPartsAll().
    // Exchange twice for entities and sets
    ErrorCode result;
    std::vector< unsigned int > exchange_procs_sets;
    std::vector< Range* > exchange_sets;
    for( int i = 0; i < n_proc; i++ )
        Range set_range   = exchange_ents[i]->subset_by_type( MBENTITYSET );
        *exchange_ents[i] = subtract( *exchange_ents[i], set_range );
        Range* tmp_range  = new Range( set_range );
        exchange_sets.push_back( tmp_range );
        exchange_procs_sets.push_back( exchange_procs[i] );
    if( dim == 2 )
        // Exchange entities first
        result = exchange_owned_mesh( exchange_procs, exchange_ents, recvReqs, recvRemotehReqs, true,
                                      store_remote_handles, wait_all, migrate );MB_CHK_SET_ERR( result, "Failed to exchange owned mesh entities" );
        // Exchange sets
        result = exchange_owned_mesh( exchange_procs_sets, exchange_sets, recvReqs, recvRemotehReqs, false,
    else
        result = exchange_owned_mesh( exchange_procs, exchange_ents, recv_ent_reqs, recv_remoteh_reqs, false,
        // Exchange sets
        result = exchange_owned_mesh( exchange_procs_sets, exchange_sets, recv_ent_reqs, recv_remoteh_reqs, false,
                                      store_remote_handles, wait_all, migrate );MB_CHK_SET_ERR( result, "Failed to exchange owned mesh sets" );
        delete exchange_sets[i];
    int procs[MAX_SHARING_PROCS];
    EntityHandle handles[MAX_SHARING_PROCS];
    int nprocs;
    unsigned char pstat;
    for( std::set< EntityHandle >::iterator vit = sharedEnts.begin(); vit != sharedEnts.end(); ++vit )
        if( mbImpl->dimension_from_handle( *vit ) > 2 ) continue;
        result = get_sharing_data( *vit, procs, handles, pstat, nprocs );MB_CHK_SET_ERR( result, "Failed to get sharing data in exchange_owned_meshs" );
    // Create interface sets from shared entities
    result = create_interface_sets( proc_nvecs );MB_CHK_SET_ERR( result, "Failed to create interface sets" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::exchange_tags ( const std::vector< Tag > &  src_tags,
const std::vector< Tag > &  dst_tags,
const Range entities
Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective.
Parameters:
src_tagsVector of tag handles to be exchanged
dst_tagsTag handles to store the tags on the non-owning procs
entitiesEntities for which tags are exchanged
Examples:
LaplacianSmoother.cpp, LloydRelaxation.cpp, and ReduceExchangeTags.cpp.
Definition at line 7526 of file ParallelComm.cpp.
References buffProcs, moab::Range::empty(), entities, ErrorCode, filter_pstatus(), get_comm_procs(), moab::Interface::get_entities_by_type_and_tag(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, moab::Interface::INTERSECT, moab::intersect(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, mbImpl, MBMAXTYPE, myDebug, pack_tags(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_NOT, PSTATUS_NOT_OWNED, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), send_buffer(), sendReqs, sharedEnts, moab::Range::size(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_default_value(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), and unpack_tags().
Referenced by assign_global_ids(), create_parallel_mesh(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::NestedRefine::exchange_ghosts(), exchange_tags(), iMeshP_pushTags(), iMeshP_pushTagsEnt(), iMOAB_SynchronizeTags(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), regression_ghost_tag_exchange_no_default(), test_ghost_elements(), and test_ghost_tag_exchange().
    ErrorCode result;
    int success;
    myDebug->tprintf( 1, "Entering exchange_tags\n" );
    // Get all procs interfacing to this proc
    std::set< unsigned int > exch_procs;
    result = get_comm_procs( exch_procs );
    // Post ghost irecv's for all interface procs
    // Index requests the same as buffer/sharing procs indices
    std::vector< MPI_Request > recv_tag_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    // sent_ack_reqs(buffProcs.size(), MPI_REQUEST_NULL);
    std::vector< unsigned int >::iterator sit;
    int ind;
    int incoming = 0;
    for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ )
        incoming++;
        PRINT_DEBUG_IRECV( *sit, procConfig.proc_rank(), remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE,
                           MB_MESG_TAGS_SIZE, incoming );
        success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, *sit,
                             MB_MESG_TAGS_SIZE, procConfig.proc_comm(), &recv_tag_reqs[3 * ind] );
    // Pack and send tags from this proc to others
    // Make sendReqs vector to simplify initialization
    // Take all shared entities if incoming list is empty
    Range entities;
    if( entities_in.empty() )
        std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( entities ) );
    else
        entities = entities_in;
    int dum_ack_buff;
        Range tag_ents = entities;
        // Get ents shared by proc *sit
        result = filter_pstatus( tag_ents, PSTATUS_SHARED, PSTATUS_AND, *sit );MB_CHK_SET_ERR( result, "Failed pstatus AND check" );
        // Remote nonowned entities
        if( !tag_ents.empty() )
            result = filter_pstatus( tag_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( result, "Failed pstatus NOT check" );
        // Pack-send; this also posts receives if store_remote_handles is true
        std::vector< Range > tag_ranges;
        for( std::vector< Tag >::const_iterator vit = src_tags.begin(); vit != src_tags.end(); ++vit )
            const void* ptr;
            int sz;
            if( mbImpl->tag_get_default_value( *vit, ptr, sz ) != MB_SUCCESS )
                Range tagged_ents;
                mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE, &*vit, 0, 1, tagged_ents );
                tag_ranges.push_back( intersect( tag_ents, tagged_ents ) );
            else
                tag_ranges.push_back( tag_ents );
        // Pack the data
        result = pack_tags( tag_ents, src_tags, dst_tags, tag_ranges, localOwnedBuffs[ind], true, *sit );MB_CHK_SET_ERR( result, "Failed to count buffer in pack_send_tag" );
        // Now send it
        result = send_buffer( *sit, localOwnedBuffs[ind], MB_MESG_TAGS_SIZE, sendReqs[3 * ind],
                              recv_tag_reqs[3 * ind + 2], &dum_ack_buff, incoming );MB_CHK_SET_ERR( result, "Failed to send buffer" );
    // Receive/unpack tags
    while( incoming )
        MPI_Status status;
        int index_in_recv_requests;
        PRINT_DEBUG_WAITANY( recv_tag_reqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 3 * buffProcs.size(), &recv_tag_reqs[0], &index_in_recv_requests, &status );
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in tag exchange" );
        // Processor index in the list is divided by 3
        ind = index_in_recv_requests / 3;
        incoming--;
        bool done = false;
        std::vector< EntityHandle > dum_vec;
        result = recv_buffer( MB_MESG_TAGS_SIZE, status, remoteOwnedBuffs[ind],
                              recv_tag_reqs[3 * ind + 1],  // This is for receiving the second message
                              recv_tag_reqs[3 * ind + 2],  // This would be for ack, but it is not
                                                           // used; consider removing it
                              incoming, localOwnedBuffs[ind],
                              sendReqs[3 * ind + 1],  // Send request for sending the second message
                              sendReqs[3 * ind + 2],  // This is for sending the ack
                              done );MB_CHK_SET_ERR( result, "Failed to resize recv buffer" );
        if( done )
            remoteOwnedBuffs[ind]->reset_ptr( sizeof( int ) );
            result = unpack_tags( remoteOwnedBuffs[ind]->buff_ptr, dum_vec, true, buffProcs[ind] );MB_CHK_SET_ERR( result, "Failed to recv-unpack-tag message" );
    // OK, now wait
    else
        MPI_Status status[3 * MAX_SHARING_PROCS];
        success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], status );
        MB_SET_ERR( MB_FAILURE, "Failure in waitall in tag exchange" );
    // If source tag is not equal to destination tag, then
    // do local copy for owned entities (communicate w/ self)
    assert( src_tags.size() == dst_tags.size() );
    if( src_tags != dst_tags )
        std::vector< unsigned char > data;
        Range owned_ents;
        else
            owned_ents = entities_in;
        result = filter_pstatus( owned_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( result, "Failure to get subset of owned entities" );
        if( !owned_ents.empty() )
        {  // Check this here, otherwise we get
            // Unexpected results from get_entities_by_type_and_tag w/ Interface::INTERSECT
            for( size_t i = 0; i < src_tags.size(); i++ )
                if( src_tags[i] == dst_tags[i] ) continue;
                Range tagged_ents( owned_ents );
                result = mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE, &src_tags[0], 0, 1, tagged_ents,
                                                               Interface::INTERSECT );MB_CHK_SET_ERR( result, "get_entities_by_type_and_tag(type == MBMAXTYPE) failed" );
                int sz, size2;
                result = mbImpl->tag_get_bytes( src_tags[i], sz );MB_CHK_SET_ERR( result, "tag_get_size failed" );
                result = mbImpl->tag_get_bytes( dst_tags[i], size2 );MB_CHK_SET_ERR( result, "tag_get_size failed" );
                if( sz != size2 )
                    MB_SET_ERR( MB_FAILURE, "tag sizes don't match" );
                data.resize( sz * tagged_ents.size() );
                result = mbImpl->tag_get_data( src_tags[i], tagged_ents, &data[0] );MB_CHK_SET_ERR( result, "tag_get_data failed" );
                result = mbImpl->tag_set_data( dst_tags[i], tagged_ents, &data[0] );MB_CHK_SET_ERR( result, "tag_set_data failed" );
    myDebug->tprintf( 1, "Exiting exchange_tags" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::exchange_tags ( const char *  tag_name,
) [inline]
Exchange tags for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If the entities vector is empty, all shared entities participate in the exchange. If a proc has no owned entities this function must still be called since it is collective.
Parameters:
tag_nameName of tag to be exchanged
Definition at line 1589 of file ParallelComm.hpp.
References ErrorCode, exchange_tags(), MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_OPAQUE, mbImpl, and moab::Interface::tag_get_handle().
    // get the tag handle
    std::vector< Tag > tags( 1 );
    ErrorCode result = mbImpl->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tags[0], MB_TAG_ANY );
        return result;
    else if( !tags[0] )
        return MB_TAG_NOT_FOUND;
    return exchange_tags( tags, tags, entities );
ErrorCode moab::ParallelComm::exchange_tags ( Tag  tagh,
) [inline]
Parameters:
taghHandle of tag to be exchanged
Definition at line 1602 of file ParallelComm.hpp.
References exchange_tags().
    std::vector< Tag > tags;
    tags.push_back( tagh );
ErrorCode moab::ParallelComm::filter_pstatus ( Range ents,
const unsigned char  pstatus_val,
const unsigned char  op,
int  to_proc = -1,
Range returned_ents = NULL
Filter the entities by pstatus tag. op is one of PSTATUS_ AND, OR, NOT; an entity is output if: AND: all bits set in pstatus_val are also set on entity OR: any bits set in pstatus_val also set on entity NOT: any bits set in pstatus_val are not set on entity
Results returned in input list, unless result_ents is passed in non-null, in which case results are returned in result_ents.
If ents is passed in empty, filter is done on shared entities in this pcomm instance, i.e. contents of sharedEnts.
Parameters:
entsInput entities to filter
pstatus_valpstatus value to which entities are compared
opBitwise operation performed between pstatus values
to_procIf non-negative and PSTATUS_SHARED is set on pstatus_val, only entities shared with to_proc are returned
result_entsIf non-null, results of filter are put in the pointed-to range
Examples:
GenLargeMesh.cpp, HelloParMOAB.cpp, LaplacianSmoother.cpp, and LloydRelaxation.cpp.
Definition at line 5577 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Range::insert(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, PSTATUS_AND, PSTATUS_MULTISHARED, PSTATUS_NOT, PSTATUS_OR, PSTATUS_SHARED, pstatus_tag(), sharedp_tag(), sharedps_tag(), moab::Range::size(), moab::Range::swap(), and moab::Interface::tag_get_data().
Referenced by closedsurface_uref_hirec_convergence_study(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), count_owned_entities(), create_fine_mesh(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::WriteHDF5Parallel::exchange_file_ids(), exchange_owned_mesh(), exchange_tags(), moab::WriteHDF5Parallel::gather_interface_meshes(), gather_one_cell_var(), get_ghosted_entities(), get_max_volume(), get_sent_ents(), get_shared_entities(), hcFilter(), iMOAB_UpdateMeshInfo(), moab::HiReconstruction::initialize(), moab::HalfFacetRep::initialize(), moab::LloydSmoother::initialize(), laplacianFilter(), moab::ReadParallel::load_file(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), read_mesh_parallel(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), reduce_tags(), refine_entities(), resolve_shared_sets(), send_entities(), settle_intersection_points(), test_gather_onevar(), and test_read_parallel().
    Range tmp_ents;
    // assert(!ents.empty());
    if( ents.empty() )
        if( returned_ents ) returned_ents->clear();
        return MB_SUCCESS;
    // Put into tmp_ents any entities which are not owned locally or
    // who are already shared with to_proc
    std::vector< unsigned char > shared_flags( ents.size() ), shared_flags2;
    ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), ents, &shared_flags[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus flag" );
    Range::const_iterator rit, hint = tmp_ents.begin();
    int i;
    if( op == PSTATUS_OR )
        for( rit = ents.begin(), i = 0; rit != ents.end(); ++rit, i++ )
            if( ( ( shared_flags[i] & ~pstat ) ^ shared_flags[i] ) & pstat )
                hint = tmp_ents.insert( hint, *rit );
                if( -1 != to_proc ) shared_flags2.push_back( shared_flags[i] );
    else if( op == PSTATUS_AND )
            if( ( shared_flags[i] & pstat ) == pstat )
    else if( op == PSTATUS_NOT )
            if( !( shared_flags[i] & pstat ) )
    else
        assert( false );
        return MB_FAILURE;
    if( -1 != to_proc )
        int sharing_procs[MAX_SHARING_PROCS];
        std::fill( sharing_procs, sharing_procs + MAX_SHARING_PROCS, -1 );
        Range tmp_ents2;
        hint = tmp_ents2.begin();
        for( rit = tmp_ents.begin(), i = 0; rit != tmp_ents.end(); ++rit, i++ )
            // We need to check sharing procs
            if( shared_flags2[i] & PSTATUS_MULTISHARED )
                result = mbImpl->tag_get_data( sharedps_tag(), &( *rit ), 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedps tag" );
                assert( -1 != sharing_procs[0] );
                for( unsigned int j = 0; j < MAX_SHARING_PROCS; j++ )
                    // If to_proc shares this entity, add it to list
                    if( sharing_procs[j] == to_proc )
                        hint = tmp_ents2.insert( hint, *rit );
                    else if( -1 == sharing_procs[j] )
                        break;
                    sharing_procs[j] = -1;
            else if( shared_flags2[i] & PSTATUS_SHARED )
                result = mbImpl->tag_get_data( sharedp_tag(), &( *rit ), 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedp tag" );
                if( sharing_procs[0] == to_proc ) hint = tmp_ents2.insert( hint, *rit );
                sharing_procs[0] = -1;
            else
                assert( "should never get here" && false );
        tmp_ents.swap( tmp_ents2 );
    if( returned_ents )
        returned_ents->swap( tmp_ents );
    else
        ents.swap( tmp_ents );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::find_existing_entity ( const bool  is_iface,
const int  owner_p,
const EntityHandle  owner_h,
const int  num_ents,
const EntityHandle connect,
const int  num_connect,
const EntityType  this_type,
std::vector< EntityHandle > &  L2hloc,
std::vector< EntityHandle > &  L2hrem,
std::vector< unsigned int > &  L2p,
EntityHandle new_h
) [private]
given connectivity and type, find an existing entity, if there is one
Definition at line 3047 of file ParallelComm.cpp.
References moab::Range::begin(), moab::CN::Dimension(), moab::Range::empty(), ErrorCode, moab::Interface::get_adjacencies(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and MBVERTEX.
Referenced by unpack_entities(), and unpack_remote_handles().
    new_h = 0;
    if( !is_iface && num_ps > 2 )
        for( unsigned int i = 0; i < L2hrem.size(); i++ )
            if( L2hrem[i] == owner_h && owner_p == (int)L2p[i] )
                new_h = L2hloc[i];
                return MB_SUCCESS;
    // If we got here and it's a vertex, we don't need to look further
    if( MBVERTEX == this_type || !connect || !num_connect ) return MB_SUCCESS;
    Range tmp_range;
    ErrorCode result = mbImpl->get_adjacencies( connect, num_connect, CN::Dimension( this_type ), false, tmp_range );MB_CHK_SET_ERR( result, "Failed to get existing entity" );
        // Found a corresponding entity - return target
        new_h = *tmp_range.begin();
    else
        new_h = 0;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::gather_data ( Range gather_ents,
Tag tag_handle,
Tag  id_tag = 0,
EntityHandle  gather_set = 0,
int  root_proc_rank = 0
Definition at line 8914 of file ParallelComm.cpp.
References moab::Range::begin(), comm(), dim, moab::Interface::dimension_from_handle(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_size(), moab::Range::psize(), rank(), moab::Range::size(), size(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), and moab::Interface::tag_iterate().
Referenced by gather_one_cell_var(), and test_gather_onevar().
    int dim           = mbImpl->dimension_from_handle( *gather_ents.begin() );
    int bytes_per_tag = 0;
    ErrorCode rval    = mbImpl->tag_get_bytes( tag_handle, bytes_per_tag );
    if( rval != MB_SUCCESS ) return rval;
    int sz_buffer         = sizeof( int ) + gather_ents.size() * ( sizeof( int ) + bytes_per_tag );
    void* senddata        = malloc( sz_buffer );
    ( (int*)senddata )[0] = (int)gather_ents.size();
    int* ptr_int          = (int*)senddata + 1;
    rval                  = mbImpl->tag_get_data( id_tag, gather_ents, (void*)ptr_int );
    ptr_int = (int*)( senddata ) + 1 + gather_ents.size();
    rval    = mbImpl->tag_get_data( tag_handle, gather_ents, (void*)ptr_int );
    std::vector< int > displs( proc_config().proc_size(), 0 );
    MPI_Gather( &sz_buffer, 1, MPI_INT, &displs[0], 1, MPI_INT, root_proc_rank, comm() );
    std::vector< int > recvcnts( proc_config().proc_size(), 0 );
    std::copy( displs.begin(), displs.end(), recvcnts.begin() );
    std::partial_sum( displs.begin(), displs.end(), displs.begin() );
    std::vector< int >::iterator lastM1 = displs.end() - 1;
    std::copy_backward( displs.begin(), lastM1, displs.end() );
    // std::copy_backward(displs.begin(), --displs.end(), displs.end());
    displs[0] = 0;
    if( (int)rank() != root_proc_rank )
        MPI_Gatherv( senddata, sz_buffer, MPI_BYTE, NULL, NULL, NULL, MPI_BYTE, root_proc_rank, comm() );
    else
        Range gents;
        mbImpl->get_entities_by_dimension( gather_set, dim, gents );
        int recvbuffsz = gents.size() * ( bytes_per_tag + sizeof( int ) ) + proc_config().proc_size() * sizeof( int );
        void* recvbuf  = malloc( recvbuffsz );
        MPI_Gatherv( senddata, sz_buffer, MPI_BYTE, recvbuf, &recvcnts[0], &displs[0], MPI_BYTE, root_proc_rank,
                     comm() );
        void* gvals = NULL;
        // Test whether gents has multiple sequences
        bool multiple_sequences = false;
        if( gents.psize() > 1 )
            multiple_sequences = true;
        else
            int count;
            rval = mbImpl->tag_iterate( tag_handle, gents.begin(), gents.end(), count, gvals );
            assert( NULL != gvals );
            assert( count > 0 );
            if( (size_t)count != gents.size() )
                gvals              = NULL;
        // If gents has multiple sequences, create a temp buffer for gathered values
        if( multiple_sequences )
            gvals = malloc( gents.size() * bytes_per_tag );
        for( int i = 0; i != (int)size(); i++ )
            int numents   = *(int*)( ( (char*)recvbuf ) + displs[i] );
            int* id_ptr   = (int*)( ( (char*)recvbuf ) + displs[i] + sizeof( int ) );
            char* val_ptr = (char*)( id_ptr + numents );
            for( int j = 0; j != numents; j++ )
                int idx = id_ptr[j];
                memcpy( (char*)gvals + ( idx - 1 ) * bytes_per_tag, val_ptr + j * bytes_per_tag, bytes_per_tag );
        // Free the receive buffer
        free( recvbuf );
        // If gents has multiple sequences, copy tag data (stored in the temp buffer) to each
        // sequence separately
            Range::iterator iter = gents.begin();
            size_t start_idx     = 0;
            while( iter != gents.end() )
                int count;
                void* ptr;
                rval = mbImpl->tag_iterate( tag_handle, iter, gents.end(), count, ptr );
                assert( NULL != ptr );
                memcpy( (char*)ptr, (char*)gvals + start_idx * bytes_per_tag, bytes_per_tag * count );
                iter += count;
                start_idx += count;
            assert( start_idx == gents.size() );
            // Free the temp buffer
            free( gvals );
    // Free the send data
    free( senddata );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_all_pcomm ( Interface impl,
std::vector< ParallelComm * > &  list
) [static]
Definition at line 8023 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_NOT_FOUND, pcomm_tag(), and moab::Interface::tag_get_data().
Referenced by moab::Core::deinitialize(), iMeshP_getNumPartitions(), iMeshP_getPartitions(), and save_and_load_on_root().
    Tag pc_tag = pcomm_tag( impl, false );
    if( 0 == pc_tag ) return MB_TAG_NOT_FOUND;
    const EntityHandle root = 0;
    ParallelComm* pc_array[MAX_SHARING_PROCS];
    ErrorCode rval = impl->tag_get_data( pc_tag, &root, 1, pc_array );
    for( int i = 0; i < MAX_SHARING_PROCS; i++ )
        if( pc_array[i] ) list.push_back( pc_array[i] );
    return MB_SUCCESS;
int moab::ParallelComm::get_buffers ( int  to_proc,
bool *  is_new = NULL
get (and possibly allocate) buffers for messages to/from to_proc; returns index of to_proc in buffProcs vector; if is_new is non-NULL, sets to whether new buffer was allocated PUBLIC ONLY FOR TESTING!
Definition at line 514 of file ParallelComm.cpp.
References buffProcs, INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, moab::ProcConfig::proc_rank(), procConfig, and remoteOwnedBuffs.
Referenced by check_all_shared_handles(), correct_thin_ghost_layers(), exchange_owned_mesh(), get_interface_procs(), pack_shared_handles(), post_irecv(), recv_entities(), recv_messages(), recv_remote_handle_messages(), send_entities(), send_recv_entities(), moab::ScdInterface::tag_shared_vertices(), test_pack_shared_entities_3d(), and unpack_entities().
    int ind                                   = -1;
    std::vector< unsigned int >::iterator vit = std::find( buffProcs.begin(), buffProcs.end(), to_proc );
    if( vit == buffProcs.end() )
        assert( "shouldn't need buffer to myself" && to_proc != (int)procConfig.proc_rank() );
        ind = buffProcs.size();
        buffProcs.push_back( (unsigned int)to_proc );
        localOwnedBuffs.push_back( new Buffer( INITIAL_BUFF_SIZE ) );
        remoteOwnedBuffs.push_back( new Buffer( INITIAL_BUFF_SIZE ) );
        if( is_new ) *is_new = true;
    else
        ind = vit - buffProcs.begin();
        if( is_new ) *is_new = false;
    assert( ind < MAX_SHARING_PROCS );
    return ind;
ErrorCode moab::ParallelComm::get_comm_procs ( std::set< unsigned int > &  procs) [inline]
get processors with which this processor communicates
Definition at line 1633 of file ParallelComm.hpp.
References buffProcs, ErrorCode, get_interface_procs(), and MB_SUCCESS.
Referenced by exchange_tags(), reduce_tags(), settle_intersection_points(), and test_mesh().
    ErrorCode result = get_interface_procs( procs );
    if( MB_SUCCESS != result ) return result;
    std::copy( buffProcs.begin(), buffProcs.end(), std::inserter( procs, procs.begin() ) );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_entityset_local_handle ( unsigned  owning_rank,
EntityHandle  remote_handle,
EntityHandle local_handle
) const
Given set owner and handle on owner, find local set handle.
Definition at line 8892 of file ParallelComm.cpp.
References moab::SharedSetData::get_local_handle(), and sharedSetData.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_ids(), and test_shared_sets().
    return sharedSetData->get_local_handle( owning_rank, remote_handle, local_handle );
ErrorCode moab::ParallelComm::get_entityset_owner ( EntityHandle  entity_set,
unsigned &  owner_rank,
EntityHandle remote_handle = 0
) const
Get rank of the owner of a shared set. Returns this proc if set is not shared. Optionally returns handle on owning process for shared set.
Definition at line 8882 of file ParallelComm.cpp.
References moab::SharedSetData::get_owner(), and sharedSetData.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::WriteHDF5Parallel::print_set_sharing_data(), and test_shared_sets().
    if( remote_handle )
        return sharedSetData->get_owner( entity_set, owner_rank, *remote_handle );
    else
        return sharedSetData->get_owner( entity_set, owner_rank );
ErrorCode moab::ParallelComm::get_entityset_owners ( std::vector< unsigned > &  ranks) const
Get ranks of all processes that own at least one set that is shared with this process. Will include the rank of this process if this process owns any shared set.
Definition at line 8904 of file ParallelComm.cpp.
References moab::SharedSetData::get_owning_procs(), and sharedSetData.
    return sharedSetData->get_owning_procs( ranks );
ErrorCode moab::ParallelComm::get_entityset_procs ( EntityHandle  entity_set,
) const
Get array of process IDs sharing a set. Returns zero and passes back NULL if set is not shared.
Definition at line 8877 of file ParallelComm.cpp.
References moab::SharedSetData::get_sharing_procs(), and sharedSetData.
    return sharedSetData->get_sharing_procs( set, ranks );
ErrorCode moab::ParallelComm::get_ghosted_entities ( int  bridge_dim,
int  ghost_dim,
int  to_proc,
int  num_layers,
int  addl_ents,
Range ghosted_ents
) [private]
for specified bridge/ghost dimension, to_proc, and number of layers, get the entities to be ghosted, and info on additional procs needing to communicate with to_proc
Definition at line 7437 of file ParallelComm.cpp.
References add_verts(), moab::Range::begin(), moab::Range::empty(), moab::Range::end(), ErrorCode, filter_pstatus(), moab::Interface::get_adjacencies(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), interfaceSets, is_iface_proc(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::Range::merge(), PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::subset_by_dimension(), and moab::Interface::UNION.
Referenced by get_sent_ents().
    // Get bridge ents on interface(s)
    Range from_ents;
    assert( 0 < num_layers );
    for( Range::iterator rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit )
        if( !is_iface_proc( *rit, to_proc ) ) continue;
        // Get starting "from" entities
        if( bridge_dim == -1 )
            result = mbImpl->get_entities_by_handle( *rit, from_ents );MB_CHK_SET_ERR( result, "Failed to get bridge ents in the set" );
        else
            result = mbImpl->get_entities_by_dimension( *rit, bridge_dim, from_ents );MB_CHK_SET_ERR( result, "Failed to get bridge ents in the set" );
        // Need to get layers of bridge-adj entities
        if( from_ents.empty() ) continue;
        result =
            MeshTopoUtil( mbImpl ).get_bridge_adjacencies( from_ents, bridge_dim, ghost_dim, ghosted_ents, num_layers );MB_CHK_SET_ERR( result, "Failed to get bridge adjacencies" );
    result = add_verts( ghosted_ents );MB_CHK_SET_ERR( result, "Failed to add verts" );
    if( addl_ents )
        // First get the ents of ghost_dim
        Range tmp_ents, tmp_owned, tmp_notowned;
        tmp_owned = ghosted_ents.subset_by_dimension( ghost_dim );
        if( tmp_owned.empty() ) return result;
        tmp_notowned = tmp_owned;
        // Next, filter by pstatus; can only create adj entities for entities I own
        result = filter_pstatus( tmp_owned, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &tmp_owned );MB_CHK_SET_ERR( result, "Failed to filter owned entities" );
        tmp_notowned -= tmp_owned;
        // Get edges first
        if( 1 == addl_ents || 3 == addl_ents )
            result = mbImpl->get_adjacencies( tmp_owned, 1, true, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get edge adjacencies for owned ghost entities" );
            result = mbImpl->get_adjacencies( tmp_notowned, 1, false, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get edge adjacencies for notowned ghost entities" );
        if( 2 == addl_ents || 3 == addl_ents )
            result = mbImpl->get_adjacencies( tmp_owned, 2, true, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get face adjacencies for owned ghost entities" );
            result = mbImpl->get_adjacencies( tmp_notowned, 2, false, tmp_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get face adjacencies for notowned ghost entities" );
        ghosted_ents.merge( tmp_ents );
    return result;
Definition at line 8182 of file ParallelComm.cpp.
References globalPartCount, and MB_SUCCESS.
Referenced by iMeshP_getNumGlobalParts().
    count_out = globalPartCount;
    return count_out < 0 ? MB_FAILURE : MB_SUCCESS;
int moab::ParallelComm::get_id ( ) const [inline]
Get ID used to reference this PCOMM instance.
Examples:
DeformMeshRemap.cpp.
Definition at line 70 of file ParallelComm.hpp.
References pcommID.
Referenced by iMeshP_createPartitionAll(), iMeshP_loadAll(), iMOAB_RegisterApplication(), main(), and DeformMeshRemap::read_file().
        return pcommID;
ErrorCode moab::ParallelComm::get_iface_entities ( int  other_proc,
int  dim,
Range iface_ents
Get entities on interfaces shared with another proc.
Parameters:
other_procOther proc sharing the interface
dimDimension of entities to return, -1 if all dims
iface_entsReturned entities
Definition at line 7275 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), interfaceSets, is_iface_proc(), MB_CHK_SET_ERR, MB_SUCCESS, and mbImpl.
    Range iface_sets;
        if( -1 != other_proc && !is_iface_proc( *rit, other_proc ) ) continue;
        if( -1 == dim )
            result = mbImpl->get_entities_by_handle( *rit, iface_ents );MB_CHK_SET_ERR( result, "Failed to get entities in iface set" );
        else
            result = mbImpl->get_entities_by_dimension( *rit, dim, iface_ents );MB_CHK_SET_ERR( result, "Failed to get entities in iface set" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_interface_procs ( std::set< unsigned int > &  iface_procs,
const bool  get_buffs = false
get processors with which this processor shares an interface
Get processors with which this processor communicates; sets are sorted by processor.
Definition at line 5440 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_buffers(), interfaceSets, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::ProcConfig::proc_rank(), procConfig, sharedp_tag(), sharedps_tag(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by get_comm_procs(), resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
    // Make sure the sharing procs vector is empty
    procs_set.clear();
    // Pre-load vector of single-proc tag values
    unsigned int i, j;
    std::vector< int > iface_proc( interfaceSets.size() );
    ErrorCode result = mbImpl->tag_get_data( sharedp_tag(), interfaceSets, &iface_proc[0] );MB_CHK_SET_ERR( result, "Failed to get iface_proc for iface sets" );
    // Get sharing procs either from single-proc vector or by getting
    // multi-proc tag value
    int tmp_iface_procs[MAX_SHARING_PROCS];
    std::fill( tmp_iface_procs, tmp_iface_procs + MAX_SHARING_PROCS, -1 );
    Range::iterator rit;
    for( rit = interfaceSets.begin(), i = 0; rit != interfaceSets.end(); ++rit, i++ )
        if( -1 != iface_proc[i] )
            assert( iface_proc[i] != (int)procConfig.proc_rank() );
            procs_set.insert( (unsigned int)iface_proc[i] );
        else
            // Get the sharing_procs tag
            result = mbImpl->tag_get_data( sharedps_tag(), &( *rit ), 1, tmp_iface_procs );MB_CHK_SET_ERR( result, "Failed to get iface_procs for iface set" );
            for( j = 0; j < MAX_SHARING_PROCS; j++ )
                if( -1 != tmp_iface_procs[j] && tmp_iface_procs[j] != (int)procConfig.proc_rank() )
                    procs_set.insert( (unsigned int)tmp_iface_procs[j] );
                else if( -1 == tmp_iface_procs[j] )
                    std::fill( tmp_iface_procs, tmp_iface_procs + j, -1 );
                    break;
    if( get_buffs )
        for( std::set< unsigned int >::iterator sit = procs_set.begin(); sit != procs_set.end(); ++sit )
            get_buffers( *sit );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_interface_sets ( EntityHandle  part,
Range iface_sets_out,
int *  adj_part_id = 0
Definition at line 8310 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), moab::Range::erase(), ErrorCode, get_sharing_data(), interface_sets(), MAX_SHARING_PROCS, and MB_SUCCESS.
Referenced by get_boundary_entities(), and get_part_neighbor_ids().
    // FIXME : assumes one part per processor.
    // Need to store part iface sets as children to implement
    // this correctly.
    iface_sets_out = interface_sets();
    if( adj_part_id )
        int part_ids[MAX_SHARING_PROCS], num_parts;
        Range::iterator i = iface_sets_out.begin();
        while( i != iface_sets_out.end() )
            ErrorCode rval = get_sharing_data( *i, part_ids, NULL, pstat, num_parts );
            if( MB_SUCCESS != rval ) return rval;
            if( std::find( part_ids, part_ids + num_parts, *adj_part_id ) - part_ids != num_parts )
                ++i;
            else
                i = iface_sets_out.erase( i );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_local_handles ( EntityHandle from_vec,
int  num_ents,
const Range new_ents
) [private]
goes through from_vec, and for any with type MBMAXTYPE, replaces with new_ents value at index corresponding to id of entity in from_vec
Definition at line 3102 of file ParallelComm.cpp.
References moab::Range::begin(), and moab::Range::end().
Referenced by get_local_handles(), unpack_entities(), unpack_sets(), and unpack_tags().
    std::vector< EntityHandle > tmp_ents;
    std::copy( new_ents.begin(), new_ents.end(), std::back_inserter( tmp_ents ) );
    return get_local_handles( from_vec, num_ents, tmp_ents );
ErrorCode moab::ParallelComm::get_local_handles ( const Range remote_handles,
Range local_handles,
const std::vector< EntityHandle > &  new_ents
) [private]
same as above except puts results in range
Definition at line 3090 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_local_handles(), and moab::Range::size().
    std::vector< EntityHandle > rh_vec;
    rh_vec.reserve( remote_handles.size() );
    std::copy( remote_handles.begin(), remote_handles.end(), std::back_inserter( rh_vec ) );
    ErrorCode result = get_local_handles( &rh_vec[0], remote_handles.size(), new_ents );
    std::copy( rh_vec.begin(), rh_vec.end(), range_inserter( local_handles ) );
    return result;
int  num_ents,
) [private]
same as above except gets new_ents from vector
Definition at line 3109 of file ParallelComm.cpp.
References moab::ID_FROM_HANDLE(), MB_SUCCESS, MBMAXTYPE, and moab::TYPE_FROM_HANDLE().
    for( int i = 0; i < num_ents; i++ )
        if( TYPE_FROM_HANDLE( from_vec[i] ) == MBMAXTYPE )
            assert( ID_FROM_HANDLE( from_vec[i] ) < (int)new_ents.size() );
            from_vec[i] = new_ents[ID_FROM_HANDLE( from_vec[i] )];
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_owned_sets ( unsigned  owning_rank,
Range sets_out
) const
Get shared sets owned by process with specified rank.
Definition at line 8909 of file ParallelComm.cpp.
References moab::SharedSetData::get_shared_sets(), and sharedSetData.
Referenced by moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::WriteHDF5Parallel::create_meshset_tables(), and test_shared_sets().
    return sharedSetData->get_shared_sets( owning_rank, sets_out );
ErrorCode moab::ParallelComm::get_owner_handle ( EntityHandle  entity,
int &  owner,
EntityHandle handle
Return the owner processor and handle of a given entity.
Return the rank of the entity owner.
Definition at line 8147 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by get_owner(), and get_owner_handles().
    EntityHandle sharing_handles[MAX_SHARING_PROCS];
    ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &entity, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" );
    if( !( pstat & PSTATUS_NOT_OWNED ) )
        owner  = proc_config().proc_rank();
        handle = entity;
    else if( pstat & PSTATUS_MULTISHARED )
        result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedps tag data" );
        owner  = sharing_procs[0];
        result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, sharing_handles );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" );
        handle = sharing_handles[0];
    else if( pstat & PSTATUS_SHARED )
        result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, sharing_procs );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" );
        result = mbImpl->tag_get_data( sharedh_tag(), &entity, 1, sharing_handles );MB_CHK_SET_ERR( result, "Failed to get sharedh tag data" );
    else
        owner  = -1;
        handle = 0;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_owning_part ( EntityHandle  entity,
int &  owning_part_id_out,
EntityHandle owning_handle = 0
Definition at line 8337 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_NOT_OWNED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Interface::tag_get_by_ptr(), and moab::Interface::tag_get_data().
Referenced by iMeshP_getEntOwnerPartArr(), and iMeshP_getOwnerCopy().
    // FIXME : assumes one part per proc, and therefore part_id == rank
    // If entity is not shared, then we're the owner.
    ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &handle, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" );
        owning_part_id = proc_config().proc_rank();
        if( remote_handle ) *remote_handle = handle;
        return MB_SUCCESS;
    // If entity is shared with one other proc, then
    // sharedp_tag will contain a positive value.
    result = mbImpl->tag_get_data( sharedp_tag(), &handle, 1, &owning_part_id );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" );
    if( owning_part_id != -1 )
        // Done?
        if( !remote_handle ) return MB_SUCCESS;
        // Get handles on remote processors (and this one)
        return mbImpl->tag_get_data( sharedh_tag(), &handle, 1, remote_handle );
    // If here, then the entity is shared with at least two other processors.
    // Get the list from the sharedps_tag
    const void* part_id_list = 0;
    result                   = mbImpl->tag_get_by_ptr( sharedps_tag(), &handle, 1, &part_id_list );
    owning_part_id = ( (const int*)part_id_list )[0];
    // Done?
    // Get remote handles
    const void* handle_list = 0;
    result                  = mbImpl->tag_get_by_ptr( sharedhs_tag(), &handle, 1, &handle_list );
    *remote_handle = ( (const EntityHandle*)handle_list )[0];
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_part_entities ( Range ents,
int  dim = -1
return all the entities in parts owned locally
Examples:
Definition at line 8126 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), MB_SUCCESS, mbImpl, moab::Range::merge(), and partitionSets.
Referenced by moab::Coupler::initialize_tree(), and main().
    ErrorCode result;
    for( Range::iterator rit = partitionSets.begin(); rit != partitionSets.end(); ++rit )
        Range tmp_ents;
        if( -1 == dim )
            result = mbImpl->get_entities_by_handle( *rit, tmp_ents, true );
        else
            result = mbImpl->get_entities_by_dimension( *rit, dim, tmp_ents, true );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_part_handle ( int  id,
EntityHandle handle_out
) const
Definition at line 8202 of file ParallelComm.cpp.
References moab::Range::front(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, partition_sets(), and proc_config().
Referenced by assign_entities_part(), iMeshP_getPartHandlesFromPartsIdsArr(), and remove_entities_part().
    // FIXME: assumes only 1 local part
    if( (unsigned)id != proc_config().proc_rank() ) return MB_ENTITY_NOT_FOUND;
    handle_out = partition_sets().front();
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_part_id ( EntityHandle  part,
int &  id_out
) const
Definition at line 8195 of file ParallelComm.cpp.
References MB_SUCCESS, proc_config(), and moab::ProcConfig::proc_rank().
Referenced by get_part_neighbor_ids(), iMeshP_getPartIdsFromPartHandlesArr(), and iMeshP_isEntOwnerArr().
    id_out = proc_config().proc_rank();
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_part_neighbor_ids ( EntityHandle  part,
int  neighbors_out[MAX_SHARING_PROCS],
int &  num_neighbors_out
Definition at line 8276 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_interface_sets(), get_part_id(), get_sharing_data(), iface, MAX_SHARING_PROCS, and MB_SUCCESS.
Referenced by iMeshP_getNumPartNborsArr(), and iMeshP_getPartNborsArr().
    ErrorCode rval;
    Range iface;
    rval = get_interface_sets( part, iface );
    num_neighbors_out = 0;
    int n, j = 0;
    int tmp[MAX_SHARING_PROCS] = { 0 }, curr[MAX_SHARING_PROCS] = { 0 };
    int* parts[2] = { neighbors_out, tmp };
    for( Range::iterator i = iface.begin(); i != iface.end(); ++i )
        rval = get_sharing_data( *i, curr, NULL, pstat, n );
        std::sort( curr, curr + n );
        assert( num_neighbors_out < MAX_SHARING_PROCS );
        int* k            = std::set_union( parts[j], parts[j] + num_neighbors_out, curr, curr + n, parts[1 - j] );
        j                 = 1 - j;
        num_neighbors_out = k - parts[j];
    if( parts[j] != neighbors_out ) std::copy( parts[j], parts[j] + num_neighbors_out, neighbors_out );
    // Remove input part from list
    int id;
    rval = get_part_id( part, id );
    if( MB_SUCCESS == rval )
        num_neighbors_out = std::remove( neighbors_out, neighbors_out + num_neighbors_out, id ) - neighbors_out;
    return rval;
ErrorCode moab::ParallelComm::get_part_owner ( int  part_id,
int &  owner_out
) const
Definition at line 8188 of file ParallelComm.cpp.
References MB_SUCCESS.
Referenced by iMeshP_exchEntArrToPartsAll(), and iMeshP_getRankOfPartArr().
    owner = part_id;
    return MB_SUCCESS;
Definition at line 725 of file ParallelComm.hpp.
References partitioningSet.
Referenced by create_part(), and destroy_part().
        return partitioningSet;
ParallelComm * moab::ParallelComm::get_pcomm ( Interface impl,
const int  index
) [static]
get the indexed pcomm object from the interface
Examples:
GenLargeMesh.cpp, LaplacianSmoother.cpp, LloydRelaxation.cpp, and ReduceExchangeTags.cpp.
Definition at line 8010 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, pcomm_tag(), and moab::Interface::tag_get_data().
Referenced by ahf_test(), closedsurface_uref_hirec_convergence_study(), moab::ScdInterface::construct_box(), count_owned_entities(), gather_one_cell_var(), get_max_volume(), get_pcomm(), moab::HiReconstruction::HiReconstruction(), iMeshP_assignGlobalIds(), iMeshP_createPartitionAll(), iMeshP_getPartsArrOnRank(), iMeshP_getPartsOnRank(), iMeshP_loadAll(), intersection_at_level(), moab::Core::load_file(), load_meshset_hirec(), main(), moab::MeshGeneration::MeshGeneration(), moab::MeshRefiner::MeshRefiner(), multiple_loads_of_same_file(), moab::NestedRefine::NestedRefine(), moab::WriteHDF5Parallel::parallel_create_file(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), read_file(), read_mesh_parallel(), read_one_cell_var(), moab::ReadParallel::ReadParallel(), moab::RefinerTagManager::RefinerTagManager(), regression_ghost_tag_exchange_no_default(), moab::ReadHDF5::set_up_read(), test_closedsurface_mesh(), test_delete_entities(), test_elements_on_several_procs(), test_gather_onevar(), test_ghost_elements(), test_ghost_tag_exchange(), test_intx_in_parallel_elem_based(), test_intx_mpas(), test_locator(), test_mesh(), test_read(), test_read_all(), test_read_conn(), test_read_eul_onevar(), test_read_fv_onevar(), test_read_no_mixed_elements(), test_read_novars(), test_read_onevar(), test_read_parallel(), and test_write_unbalanced().
    if( 0 == pc_tag ) return NULL;
    ErrorCode result = impl->tag_get_data( pc_tag, &root, 1, (void*)pc_array );
    if( MB_SUCCESS != result ) return NULL;
    return pc_array[index];
EntityHandle  partitioning,
const MPI_Comm comm = 0
) [static]
Get ParallelComm instance associated with partition handle Will create ParallelComm instance if a) one does not already exist and b) a valid value for MPI_Comm is passed.
Definition at line 8042 of file ParallelComm.cpp.
References ErrorCode, get_pcomm(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_INTEGER, ParallelComm(), moab::PARTITIONING_PCOMM_TAG_NAME, set_partitioning(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    ErrorCode rval;
    ParallelComm* result = 0;
    Tag prtn_tag;
    rval =
        impl->tag_get_handle( PARTITIONING_PCOMM_TAG_NAME, 1, MB_TYPE_INTEGER, prtn_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
    if( MB_SUCCESS != rval ) return 0;
    int pcomm_id;
    rval = impl->tag_get_data( prtn_tag, &prtn, 1, &pcomm_id );
        result = get_pcomm( impl, pcomm_id );
    else if( MB_TAG_NOT_FOUND == rval && comm )
        result = new ParallelComm( impl, *comm, &pcomm_id );
        if( !result ) return 0;
        result->set_partitioning( prtn );
        rval = impl->tag_set_data( prtn_tag, &prtn, 1, &pcomm_id );
            delete result;
            result = 0;
    return result;
ErrorCode moab::ParallelComm::get_proc_nvecs ( int  resolve_dim,
int  shared_dim,
Range skin_ents,
std::map< std::vector< int >, std::vector< EntityHandle > > &  proc_nvecs
) [private]
Definition at line 5156 of file ParallelComm.cpp.
References moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), get_sharing_data(), INTERSECT, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, and moab::Interface::UNION.
Referenced by create_interface_sets(), resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
    // Set sharing procs tags on other skin ents
    ErrorCode result;
    const EntityHandle* connect;
    int num_connect;
    std::set< int > sharing_procs;
    std::vector< EntityHandle > dum_connect;
    std::vector< int > sp_vec;
    for( int d = 3; d > 0; d-- )
        if( resolve_dim == d ) continue;
        for( Range::iterator rit = skin_ents[d].begin(); rit != skin_ents[d].end(); ++rit )
            // Get connectivity
            result = mbImpl->get_connectivity( *rit, connect, num_connect, false, &dum_connect );MB_CHK_SET_ERR( result, "Failed to get connectivity on non-vertex skin entities" );
            int op = ( resolve_dim < shared_dim ? Interface::UNION : Interface::INTERSECT );
            result = get_sharing_data( connect, num_connect, sharing_procs, op );MB_CHK_SET_ERR( result, "Failed to get sharing data in get_proc_nvecs" );
            if( sharing_procs.empty() ||
                ( sharing_procs.size() == 1 && *sharing_procs.begin() == (int)procConfig.proc_rank() ) )
                continue;
            // Need to specify sharing data correctly for entities or they will
            // end up in a different interface set than corresponding vertices
            if( sharing_procs.size() == 2 )
                std::set< int >::iterator it = sharing_procs.find( proc_config().proc_rank() );
                assert( it != sharing_procs.end() );
                sharing_procs.erase( it );
            // Intersection is the owning proc(s) for this skin ent
            sp_vec.clear();
            std::copy( sharing_procs.begin(), sharing_procs.end(), std::back_inserter( sp_vec ) );
            assert( sp_vec.size() != 2 );
            proc_nvecs[sp_vec].push_back( *rit );
#ifndef NDEBUG
    // Shouldn't be any repeated entities in any of the vectors in proc_nvecs
    for( std::map< std::vector< int >, std::vector< EntityHandle > >::iterator mit = proc_nvecs.begin();
         mit != proc_nvecs.end(); ++mit )
        std::vector< EntityHandle > tmp_vec = ( mit->second );
        std::sort( tmp_vec.begin(), tmp_vec.end() );
        std::vector< EntityHandle >::iterator vit = std::unique( tmp_vec.begin(), tmp_vec.end() );
        assert( vit == tmp_vec.end() );
#endif
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_pstatus ( EntityHandle  entity,
unsigned char &  pstatus_val
Get parallel status of an entity Returns the parallel status of an entity.
Parameters:
entityThe entity being queried
pstatus_valParallel status of the entity
Definition at line 5488 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, mbImpl, pstatus_tag(), and moab::Interface::tag_get_data().
Referenced by check_my_shared_handles().
    ErrorCode result = mbImpl->tag_get_data( pstatus_tag(), &entity, 1, &pstatus_val );MB_CHK_SET_ERR( result, "Failed to get pastatus tag data" );
    return result;
ErrorCode moab::ParallelComm::get_pstatus_entities ( int  dim,
Range pstatus_ents
Get entities with the given pstatus bit(s) set Returns any entities whose pstatus tag value v satisfies (v & pstatus_val)
Parameters:
dimDimension of entities to be returned, or -1 if any
pstatus_valpstatus value of desired entities
pstatus_entsEntities returned from function
Definition at line 5494 of file ParallelComm.cpp.
References moab::Range::begin(), dim, moab::Interface::dimension_from_handle(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, pstatus_tag(), moab::Range::size(), and moab::Interface::tag_get_data().
Referenced by main().
    Range ents;
    ErrorCode result;
    if( -1 == dim )
        result = mbImpl->get_entities_by_handle( 0, ents );MB_CHK_SET_ERR( result, "Failed to get all entities" );
    else
        result = mbImpl->get_entities_by_dimension( 0, dim, ents );MB_CHK_SET_ERR( result, "Failed to get entities of dimension " << dim );
    std::vector< unsigned char > pstatus( ents.size() );
    result = mbImpl->tag_get_data( pstatus_tag(), ents, &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to get pastatus tag data" );
    Range::iterator rit = ents.begin();
    int i               = 0;
    if( pstatus_val )
        for( ; rit != ents.end(); i++, ++rit )
            if( pstatus[i] & pstatus_val && ( -1 == dim || mbImpl->dimension_from_handle( *rit ) == dim ) )
                pstatus_ents.insert( *rit );
    else
            if( !pstatus[i] && ( -1 == dim || mbImpl->dimension_from_handle( *rit ) == dim ) )
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_remote_handles ( EntityHandle local_vec,
EntityHandle rem_vec,
int  num_ents,
int  to_proc
Definition at line 1064 of file ParallelComm.cpp.
References moab::error(), ErrorCode, MB_CHK_ERR, and MB_SUCCESS.
Referenced by check_my_shared_handles(), get_remote_handles(), pack_entity_seq(), pack_sets(), pack_tag(), and settle_intersection_points().
    ErrorCode error;
    std::vector< EntityHandle > newents;
    error = get_remote_handles( true, local_vec, rem_vec, num_ents, to_proc, newents );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_remote_handles ( const bool  store_remote_handles,
EntityHandle to_vec_tmp,
int  num_ents,
int  to_proc,
) [private]
replace handles in from_vec with corresponding handles on to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag; if no remote handle and new_ents is non-null, substitute instead CREATE_HANDLE(MBMAXTYPE, index) where index is handle's position in new_ents
Definition at line 1875 of file ParallelComm.cpp.
References moab::CREATE_HANDLE(), ErrorCode, get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MBMAXTYPE, moab::ProcConfig::proc_rank(), procConfig, and moab::Interface::tag_get_data().
    // NOTE: THIS IMPLEMENTATION IS JUST LIKE THE RANGE-BASED VERSION, NO REUSE
    // AT THIS TIME, SO IF YOU FIX A BUG IN THIS VERSION, IT MAY BE IN THE
    // OTHER VERSION TOO!!!
    if( 0 == num_ents ) return MB_SUCCESS;
    // Use a local destination ptr in case we're doing an in-place copy
    std::vector< EntityHandle > tmp_vector;
    EntityHandle* to_vec = to_vec_tmp;
    if( to_vec == from_vec )
        tmp_vector.resize( num_ents );
        to_vec = &tmp_vector[0];
    if( !store_remote_handles )
        int err;
        // In this case, substitute position in new_ents list
            int ind = std::lower_bound( new_ents.begin(), new_ents.end(), from_vec[i] ) - new_ents.begin();
            assert( new_ents[ind] == from_vec[i] );
            to_vec[i] = CREATE_HANDLE( MBMAXTYPE, ind, err );
            assert( to_vec[i] != 0 && !err && -1 != ind );
    else
        Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag;
        ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags" );
        // Get single-proc destination handles and shared procs
        std::vector< int > sharing_procs( num_ents );
        result = mbImpl->tag_get_data( shh_tag, from_vec, num_ents, to_vec );MB_CHK_SET_ERR( result, "Failed to get shared handle tag for remote_handles" );
        result = mbImpl->tag_get_data( shp_tag, from_vec, num_ents, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to get sharing proc tag in remote_handles" );
        for( int j = 0; j < num_ents; j++ )
            if( to_vec[j] && sharing_procs[j] != to_proc ) to_vec[j] = 0;
        EntityHandle tmp_handles[MAX_SHARING_PROCS];
        int tmp_procs[MAX_SHARING_PROCS];
        int i;
        // Go through results, and for 0-valued ones, look for multiple shared proc
        for( i = 0; i < num_ents; i++ )
            if( !to_vec[i] )
                result = mbImpl->tag_get_data( shps_tag, from_vec + i, 1, tmp_procs );
                if( MB_SUCCESS == result )
                    for( int j = 0; j < MAX_SHARING_PROCS; j++ )
                        if( -1 == tmp_procs[j] )
                            break;
                        else if( tmp_procs[j] == to_proc )
                            result = mbImpl->tag_get_data( shhs_tag, from_vec + i, 1, tmp_handles );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" );
                            to_vec[i] = tmp_handles[j];
                            assert( to_vec[i] );
                            break;
                if( !to_vec[i] )
                    int j = std::lower_bound( new_ents.begin(), new_ents.end(), from_vec[i] ) - new_ents.begin();
                    if( (int)new_ents.size() == j )
                        std::cout << "Failed to find new entity in send list, proc " << procConfig.proc_rank()
                                  << std::endl;
                        for( int k = 0; k <= num_ents; k++ )
                            std::cout << k << ": " << from_vec[k] << " " << to_vec[k] << std::endl;
                        MB_SET_ERR( MB_FAILURE, "Failed to find new entity in send list" );
                    int err;
                    to_vec[i] = CREATE_HANDLE( MBMAXTYPE, j, err );
                    if( err )
                        MB_SET_ERR( MB_FAILURE, "Failed to create handle in remote_handles" );
    // memcpy over results if from_vec and to_vec are the same
    if( to_vec_tmp == from_vec ) memcpy( from_vec, to_vec, num_ents * sizeof( EntityHandle ) );
    return MB_SUCCESS;
const Range from_range,
Range to_range,
int  to_proc,
) [private]
same as other version, except from_range and to_range should be different here
Definition at line 2055 of file ParallelComm.cpp.
References ErrorCode, get_remote_handles(), MB_CHK_SET_ERR, and moab::Range::size().
    std::vector< EntityHandle > to_vector( from_range.size() );
    ErrorCode result = get_remote_handles( store_remote_handles, from_range, &to_vector[0], to_proc, new_ents );MB_CHK_SET_ERR( result, "Failed to get remote handles" );
    std::copy( to_vector.begin(), to_vector.end(), range_inserter( to_range ) );
    return result;
EntityHandle to_vec,
int  to_proc,
) [private]
same as other version, except packs range into vector
Definition at line 1974 of file ParallelComm.cpp.
References moab::Range::begin(), moab::CREATE_HANDLE(), moab::Range::empty(), moab::Range::end(), ErrorCode, get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MBMAXTYPE, moab::Range::size(), and moab::Interface::tag_get_data().
    // NOTE: THIS IMPLEMENTATION IS JUST LIKE THE VECTOR-BASED VERSION, NO REUSE
    if( from_range.empty() ) return MB_SUCCESS;
        int err;
        unsigned int i;
        for( rit = from_range.begin(), i = 0; rit != from_range.end(); ++rit, i++ )
            int ind = std::lower_bound( new_ents.begin(), new_ents.end(), *rit ) - new_ents.begin();
            assert( new_ents[ind] == *rit );
    else
        std::vector< int > sharing_procs( from_range.size() );
        result = mbImpl->tag_get_data( shh_tag, from_range, to_vec );MB_CHK_SET_ERR( result, "Failed to get shared handle tag for remote_handles" );
        result = mbImpl->tag_get_data( shp_tag, from_range, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to get sharing proc tag in remote_handles" );
        for( unsigned int j = 0; j < from_range.size(); j++ )
        unsigned int i;
            if( !to_vec[i] )
                result = mbImpl->tag_get_data( shhs_tag, &( *rit ), 1, tmp_handles );
                    result = mbImpl->tag_get_data( shps_tag, &( *rit ), 1, tmp_procs );MB_CHK_SET_ERR( result, "Failed to get sharedps tag data" );
                            break;
                if( !to_vec[i] )
                    int j = std::lower_bound( new_ents.begin(), new_ents.end(), *rit ) - new_ents.begin();
                    int err;
                    if( err )
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_sent_ents ( const bool  is_iface,
const int  bridge_dim,
const int  ghost_dim,
const int  num_layers,
const int  addl_ents,
Range sent_ents,
Range allsent,
TupleList entprocs
) [private]
Definition at line 6518 of file ParallelComm.cpp.
References buffProcs, moab::Range::clear(), moab::TupleList::disableWriteAccess(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), moab::Range::end(), ErrorCode, filter_pstatus(), get_ghosted_entities(), get_iface_entities(), moab::TupleList::get_n(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::merge(), PSTATUS_AND, PSTATUS_SHARED, moab::TupleList::buffer::reset(), size(), moab::TupleList::sort(), moab::subtract(), moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
Referenced by exchange_ghost_cells().
    ErrorCode result;
    unsigned int ind;
    std::vector< unsigned int >::iterator proc_it;
    Range tmp_range;
    // Done in a separate loop over procs because sometimes later procs
    // need to add info to earlier procs' messages
    for( ind = 0, proc_it = buffProcs.begin(); proc_it != buffProcs.end(); ++proc_it, ind++ )
        if( !is_iface )
            result =
                get_ghosted_entities( bridge_dim, ghost_dim, buffProcs[ind], num_layers, addl_ents, sent_ents[ind] );MB_CHK_SET_ERR( result, "Failed to get ghost layers" );
        else
            result = get_iface_entities( buffProcs[ind], -1, sent_ents[ind] );MB_CHK_SET_ERR( result, "Failed to get interface layers" );
        // Filter out entities already shared with destination
        tmp_range.clear();
        result = filter_pstatus( sent_ents[ind], PSTATUS_SHARED, PSTATUS_AND, buffProcs[ind], &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" );
        if( !tmp_range.empty() ) sent_ents[ind] = subtract( sent_ents[ind], tmp_range );
        allsent.merge( sent_ents[ind] );
    // Need to get procs each entity is sent to
    // Get the total # of proc/handle pairs
    int npairs = 0;
    for( ind = 0; ind < buffProcs.size(); ind++ )
        npairs += sent_ents[ind].size();
    // Allocate a TupleList of that size
    entprocs.initialize( 1, 0, 1, 0, npairs );
    entprocs.enableWriteAccess();
    // Put the proc/handle pairs in the list
        for( Range::iterator rit = sent_ents[ind].begin(); rit != sent_ents[ind].end(); ++rit )
            entprocs.vi_wr[entprocs.get_n()]  = *proc_it;
            entprocs.vul_wr[entprocs.get_n()] = *rit;
            entprocs.inc_n();
    // Sort by handle
    moab::TupleList::buffer sort_buffer;
    sort_buffer.buffer_init( npairs );
    entprocs.sort( 1, &sort_buffer );
    entprocs.disableWriteAccess();
    sort_buffer.reset();
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_shared_entities ( int  other_proc,
Range shared_ents,
int  dim = -1,
const bool  iface = false,
const bool  owned_filter = false
Get shared entities of specified dimension If other_proc is -1, any shared entities are returned. If dim is -1, entities of all dimensions on interface are returned.
Parameters:
other_procRank of processor for which interface entities are requested
shared_entsEntities returned from function
dimDimension of interface entities requested
ifaceIf true, return only entities on the interface
owned_filterIf true, return only owned shared entities
Examples:
Definition at line 8801 of file ParallelComm.cpp.
References moab::Range::clear(), dim, ErrorCode, filter_pstatus(), moab::Range::lower_bound(), MB_CHK_SET_ERR, MB_SUCCESS, moab::Range::merge(), PSTATUS_AND, PSTATUS_INTERFACE, PSTATUS_NOT, PSTATUS_NOT_OWNED, PSTATUS_SHARED, sharedEnts, moab::CN::TypeDimensionMap, and moab::Range::upper_bound().
Referenced by check_my_shared_handles(), check_shared_ents(), moab::ParCommGraph::compute_partition(), main(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), test_ghost_elements(), test_reduce_tag_explicit_dest(), and test_reduce_tags().
    shared_ents.clear();
    ErrorCode result = MB_SUCCESS;
    // Dimension
    if( -1 != dim )
        DimensionPair dp = CN::TypeDimensionMap[dim];
        Range dum_range;
        std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( dum_range ) );
        shared_ents.merge( dum_range.lower_bound( dp.first ), dum_range.upper_bound( dp.second ) );
    else
        std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( shared_ents ) );
    // Filter by iface
    if( iface )
        result = filter_pstatus( shared_ents, PSTATUS_INTERFACE, PSTATUS_AND );MB_CHK_SET_ERR( result, "Failed to filter by iface" );
    // Filter by owned
    if( owned_filter )
        result = filter_pstatus( shared_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT );MB_CHK_SET_ERR( result, "Failed to filter by owned" );
    // Filter by proc
    if( -1 != other_proc )
        result = filter_pstatus( shared_ents, PSTATUS_SHARED, PSTATUS_AND, other_proc );MB_CHK_SET_ERR( result, "Failed to filter by proc" );
    return result;
ErrorCode moab::ParallelComm::get_shared_proc_tags ( Tag sharedp_tag,
Tag sharedps_tag,
Tag sharedh_tag,
Tag sharedhs_tag,
Tag pstatus_tag
) [inline]
return the tags used to indicate shared procs and handles
Definition at line 1574 of file ParallelComm.hpp.
References MB_SUCCESS, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), and sharedps_tag().
Referenced by create_interface_sets(), get_remote_handles(), moab::RefinerTagManager::RefinerTagManager(), resolve_shared_ents(), and tag_shared_verts().
    sharedp  = sharedp_tag();
    sharedps = sharedps_tag();
    sharedh  = sharedh_tag();
    sharedhs = sharedhs_tag();
    pstatus  = pstatus_tag();
    return MB_SUCCESS;
Get all shared sets.
Definition at line 8899 of file ParallelComm.cpp.
Referenced by moab::WriteHDF5Parallel::create_meshset_tables().
    return sharedSetData->get_shared_sets( result );
ErrorCode moab::ParallelComm::get_sharing_data ( const EntityHandle  entity,
int *  ps,
EntityHandle hs,
unsigned char &  pstat,
unsigned int &  num_ps
Get the shared processors/handles for an entity Get the shared processors/handles for an entity. Arrays must be large enough to receive data for all sharing procs. Does *not* include this proc if only shared with one other proc.
Parameters:
entityEntity being queried
psPointer to sharing proc data
hsPointer to shared proc handle data
pstatReference to pstatus data returned from this function
Definition at line 3007 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, PSTATUS_MULTISHARED, PSTATUS_SHARED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by augment_default_sets_with_ghosts(), build_sharedhps_list(), check_clean_iface(), check_local_shared(), check_shared_ents(), moab::ParCommGraph::compute_partition(), correct_thin_ghost_layers(), create_interface_sets(), delete_entities(), exchange_owned_meshs(), get_interface_sets(), get_part_neighbor_ids(), get_proc_nvecs(), get_sharing_data(), list_entities(), pack_shared_handles(), update_remote_data(), and update_remote_data_old().
        result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, ps );MB_CHK_SET_ERR( result, "Failed to get sharedps tag data" );
        if( hs )
            result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, hs );MB_CHK_SET_ERR( result, "Failed to get sharedhs tag data" );
        num_ps = std::find( ps, ps + MAX_SHARING_PROCS, -1 ) - ps;
        result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, ps );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" );
        if( hs )
            result = mbImpl->tag_get_data( sharedh_tag(), &entity, 1, hs );MB_CHK_SET_ERR( result, "Failed to get sharedh tag data" );
            hs[1] = 0;
        // Initialize past end of data
        ps[1]  = -1;
        num_ps = 1;
    else
        ps[0] = -1;
        if( hs ) hs[0] = 0;
        num_ps = 0;
    assert( MAX_SHARING_PROCS >= num_ps );
    return MB_SUCCESS;
int *  ps,
EntityHandle hs,
int &  num_ps
) [inline]
Get the shared processors/handles for an entity Same as other version but with int num_ps.
Parameters:
Definition at line 1685 of file ParallelComm.hpp.
References ErrorCode, get_sharing_data(), and MB_SUCCESS.
    unsigned int dum_ps;
    ErrorCode result = get_sharing_data( entity, ps, hs, pstat, dum_ps );
    if( MB_SUCCESS == result ) num_ps = dum_ps;
    return result;
ErrorCode moab::ParallelComm::get_sharing_data ( const EntityHandle entities,
int  num_entities,
std::set< int > &  procs,
int  op = Interface::INTERSECT
) [inline]
Get the intersection or union of all sharing processors Get the intersection or union of all sharing processors. Processor set is cleared as part of this function.
Parameters:
entitiesEntity list ptr
num_entitiesNumber of entities
procsProcessors returned
opEither Interface::UNION or Interface::INTERSECT
Definition at line 1673 of file ParallelComm.hpp.
References entities, and get_sharing_data().
    Range dum_range;
    // cast away constness 'cuz the range is passed as const
    EntityHandle* ents_cast = const_cast< EntityHandle* >( entities );
    std::copy( ents_cast, ents_cast + num_entities, range_inserter( dum_range ) );
    return get_sharing_data( dum_range, procs, op );
ErrorCode moab::ParallelComm::get_sharing_data ( const Range entities,
Get the intersection or union of all sharing processors Same as previous variant but with range as input.
Definition at line 2960 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, get_sharing_data(), moab::Interface::INTERSECT, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, PSTATUS_SHARED, and moab::Interface::UNION.
    // Get the union or intersection of sharing data for multiple entities
    ErrorCode result;
    int sp2[MAX_SHARING_PROCS];
    int num_ps;
    unsigned char pstat;
    std::set< int > tmp_procs;
    procs.clear();
    for( Range::const_iterator rit = entities.begin(); rit != entities.end(); ++rit )
        result = get_sharing_data( *rit, sp2, NULL, pstat, num_ps );MB_CHK_SET_ERR( result, "Failed to get sharing data in get_sharing_data" );
        if( !( pstat & PSTATUS_SHARED ) && Interface::INTERSECT == operation )
            procs.clear();
            return MB_SUCCESS;
        if( rit == entities.begin() )
            std::copy( sp2, sp2 + num_ps, std::inserter( procs, procs.begin() ) );
        else
            std::sort( sp2, sp2 + num_ps );
            tmp_procs.clear();
            if( Interface::UNION == operation )
                std::set_union( procs.begin(), procs.end(), sp2, sp2 + num_ps,
                                std::inserter( tmp_procs, tmp_procs.end() ) );
            else if( Interface::INTERSECT == operation )
                std::set_intersection( procs.begin(), procs.end(), sp2, sp2 + num_ps,
            else
                assert( "Unknown operation." && false );
                return MB_FAILURE;
            procs.swap( tmp_procs );
        if( Interface::INTERSECT == operation && procs.empty() ) return MB_SUCCESS;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::get_sharing_parts ( EntityHandle  entity,
int  part_ids_out[MAX_SHARING_PROCS],
int &  num_part_ids_out,
EntityHandle  remote_handles[MAX_SHARING_PROCS] = 0
Definition at line 8382 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), PSTATUS_SHARED, pstatus_tag(), sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by iMeshP_getCopies(), iMeshP_getCopyOnPart(), iMeshP_getCopyParts(), and iMeshP_getNumCopies().
    if( !( pstat & PSTATUS_SHARED ) )
        part_ids_out[0] = proc_config().proc_rank();
        if( remote_handles ) remote_handles[0] = entity;
        num_part_ids_out = 1;
        return MB_SUCCESS;
    result = mbImpl->tag_get_data( sharedp_tag(), &entity, 1, part_ids_out );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" );
    if( part_ids_out[0] != -1 )
        num_part_ids_out = 2;
        part_ids_out[1]  = proc_config().proc_rank();
        // Done?
        if( !remote_handles ) return MB_SUCCESS;
        remote_handles[1] = entity;
        return mbImpl->tag_get_data( sharedh_tag(), &entity, 1, remote_handles );
    result = mbImpl->tag_get_data( sharedps_tag(), &entity, 1, part_ids_out );
    // Count number of valid (positive) entries in sharedps_tag
    for( num_part_ids_out = 0; num_part_ids_out < MAX_SHARING_PROCS && part_ids_out[num_part_ids_out] >= 0;
         num_part_ids_out++ )
        // part_ids_out[num_part_ids_out++] = proc_config().proc_rank();
#ifndef NDEBUG
    int my_idx = std::find( part_ids_out, part_ids_out + num_part_ids_out, proc_config().proc_rank() ) - part_ids_out;
    assert( my_idx < num_part_ids_out );
#endif
    // Done?
    result = mbImpl->tag_get_data( sharedhs_tag(), &entity, 1, remote_handles );
    // remote_handles[num_part_ids_out - 1] = entity;
    assert( remote_handles[my_idx] == entity );
    return result;
ErrorCode moab::ParallelComm::get_tag_send_list ( const Range all_entities,
std::vector< Tag > &  all_tags,
std::vector< Range > &  tag_ranges
) [private]
Get list of tags for which to exchange data.
Get tags and entities for which to exchange tag data. This function was originally part of 'pack_tags' requested with the 'all_possible_tags' parameter.
Parameters:
all_entitiesInput. The set of entities for which data is to be communicated.
all_tagsOutput. Populated with the handles of tags to be sent.
tag_rangesOutput. For each corresponding tag in all_tags, the subset of 'all_entities' for which a tag value has been set.
Definition at line 3650 of file ParallelComm.cpp.
References moab::Range::empty(), ErrorCode, moab::intersect(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, sequenceManager, moab::Interface::tag_get_name(), and moab::Interface::tag_get_tags().
Referenced by pack_buffer().
    std::vector< Tag > tmp_tags;
    ErrorCode result = mbImpl->tag_get_tags( tmp_tags );MB_CHK_SET_ERR( result, "Failed to get tags in pack_tags" );
    std::vector< Tag >::iterator tag_it;
    for( tag_it = tmp_tags.begin(); tag_it != tmp_tags.end(); ++tag_it )
        std::string tag_name;
        result = mbImpl->tag_get_name( *tag_it, tag_name );
        if( tag_name.c_str()[0] == '_' && tag_name.c_str()[1] == '_' ) continue;
        Range tmp_range;
        result = ( *tag_it )->get_tagged_entities( sequenceManager, tmp_range );MB_CHK_SET_ERR( result, "Failed to get entities for tag in pack_tags" );
        tmp_range = intersect( tmp_range, whole_range );
        if( tmp_range.empty() ) continue;
        // OK, we'll be sending this tag
        all_tags.push_back( *tag_it );
        tag_ranges.push_back( Range() );
        tag_ranges.back().swap( tmp_range );
    return MB_SUCCESS;
void moab::ParallelComm::initialize ( ) [private]
Definition at line 341 of file ParallelComm.cpp.
References add_pcomm(), buffProcs, errorHandler, localOwnedBuffs, MAX_SHARING_PROCS, mbImpl, myDebug, pcommID, moab::ProcConfig::proc_rank(), procConfig, moab::Interface::query_interface(), remoteOwnedBuffs, moab::Core::sequence_manager(), sequenceManager, and moab::DebugOutput::set_rank().
Referenced by ParallelComm().
    Core* core      = dynamic_cast< Core* >( mbImpl );
    sequenceManager = core->sequence_manager();
    mbImpl->query_interface( errorHandler );
    // Initialize MPI, if necessary
    int flag   = 1;
    int retval = MPI_Initialized( &flag );
    if( MPI_SUCCESS != retval || !flag )
        int argc    = 0;
        char** argv = NULL;
        // mpi not initialized yet - initialize here
        retval = MPI_Init( &argc, &argv );
        assert( MPI_SUCCESS == retval );
    // Reserve space for vectors
    buffProcs.reserve( MAX_SHARING_PROCS );
    localOwnedBuffs.reserve( MAX_SHARING_PROCS );
    remoteOwnedBuffs.reserve( MAX_SHARING_PROCS );
    pcommID = add_pcomm( this );
    if( !myDebug )
        myDebug = new DebugOutput( "ParallelComm", std::cerr );
        myDebug->set_rank( procConfig.proc_rank() );
const Range& moab::ParallelComm::interface_sets ( ) const [inline]
Definition at line 677 of file ParallelComm.hpp.
References interfaceSets.
        return interfaceSets;
bool moab::ParallelComm::is_iface_proc ( EntityHandle  this_set,
int  to_proc
) [private]
returns true if the set is an interface shared with to_proc
Definition at line 5556 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, mbImpl, sharedp_tag(), sharedps_tag(), and moab::Interface::tag_get_data().
Referenced by get_ghosted_entities(), and get_iface_entities().
    ErrorCode result = mbImpl->tag_get_data( sharedp_tag(), &this_set, 1, sharing_procs );
    if( MB_SUCCESS == result && to_proc == sharing_procs[0] ) return true;
    result = mbImpl->tag_get_data( sharedps_tag(), &this_set, 1, sharing_procs );
    if( MB_SUCCESS != result ) return false;
        if( to_proc == sharing_procs[i] )
            return true;
        else if( -1 == sharing_procs[i] )
            return false;
    return false;
ErrorCode moab::ParallelComm::list_entities ( const EntityHandle ents,
int  num_ents
Definition at line 2573 of file ParallelComm.cpp.
References ErrorCode, moab::Interface::get_coords(), get_sharing_data(), moab::Interface::id_from_handle(), moab::Interface::list_entities(), MAX_SHARING_PROCS, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::Range::print(), PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, and sharedEnts.
Referenced by build_sharedhps_list(), check_local_shared(), check_my_shared_handles(), list_entities(), moab::ReadParallel::load_file(), and moab::ScdInterface::tag_shared_vertices().
    if( NULL == ents )
        Range shared_ents;
        shared_ents.print( "Shared entities:\n" );
        return MB_SUCCESS;
    unsigned int num_ps;
    ErrorCode result;
        result = mbImpl->list_entities( ents + i, 1 );MB_CHK_ERR( result );
        double coords[3];
        result = mbImpl->get_coords( ents + i, 1, coords );
        std::cout << " coords: " << coords[0] << " " << coords[1] << " " << coords[2] << "\n";
        result = get_sharing_data( ents[i], tmp_procs, tmp_handles, pstat, num_ps );MB_CHK_SET_ERR( result, "Failed to get sharing data" );
        std::cout << "Pstatus: ";
        if( !num_ps )
            std::cout << "local " << std::endl;
        else
            if( pstat & PSTATUS_NOT_OWNED ) std::cout << "NOT_OWNED; ";
            if( pstat & PSTATUS_SHARED ) std::cout << "SHARED; ";
            if( pstat & PSTATUS_MULTISHARED ) std::cout << "MULTISHARED; ";
            if( pstat & PSTATUS_INTERFACE ) std::cout << "INTERFACE; ";
            if( pstat & PSTATUS_GHOST ) std::cout << "GHOST; ";
            std::cout << std::endl;
            for( unsigned int j = 0; j < num_ps; j++ )
                std::cout << "  proc " << tmp_procs[j] << " id (handle) " << mbImpl->id_from_handle( tmp_handles[j] )
                          << "(" << tmp_handles[j] << ")" << std::endl;
    return MB_SUCCESS;
Definition at line 2621 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), list_entities(), and MB_SUCCESS.
    for( Range::iterator rit = ents.begin(); rit != ents.end(); ++rit )
        list_entities( &( *rit ), 1 );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::pack_adjacencies ( Range entities,
Range::const_iterator start_rit,
Range whole_range,
unsigned char *&  buff_ptr,
int &  count,
const bool  just_count,
const bool  store_handles,
const int  to_proc
) [private]
Definition at line 3450 of file ParallelComm.cpp.
    return MB_FAILURE;
ErrorCode moab::ParallelComm::pack_buffer ( Range orig_ents,
const bool  adjacencies,
const bool  tags,
const int  to_proc,
Buffer buff,
TupleList entprocs = NULL,
Range allsent = NULL
public 'cuz we want to unit test these externally
Definition at line 1418 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), ErrorCode, get_tag_send_list(), MB_CHK_SET_ERR, pack_entities(), moab::PACK_INT(), pack_sets(), pack_tags(), and moab::ParallelComm::Buffer::set_stored_size().
Referenced by broadcast_entities(), exchange_owned_mesh(), pack_unpack_noremoteh(), scatter_entities(), send_entities(), moab::ParCommGraph::send_mesh_parts(), and test_packing().
    // Pack the buffer with the entity ranges, adjacencies, and tags sections
    // Note: new entities used in subsequent connectivity lists, sets, or tags,
    // are referred to as (MBMAXTYPE + index), where index is into vector
    // of new entities, 0-based
    ErrorCode result;
    Range set_range;
    std::vector< Tag > all_tags;
    std::vector< Range > tag_ranges;
    Range::const_iterator rit;
    // Entities
    result = pack_entities( orig_ents, buff, store_remote_handles, to_proc, false, entprocs, allsent );MB_CHK_SET_ERR( result, "Packing entities failed" );
    // Sets
    result = pack_sets( orig_ents, buff, store_remote_handles, to_proc );MB_CHK_SET_ERR( result, "Packing sets (count) failed" );
    // Tags
    Range final_ents;
    if( tags )
        result = get_tag_send_list( orig_ents, all_tags, tag_ranges );MB_CHK_SET_ERR( result, "Failed to get tagged entities" );
        result = pack_tags( orig_ents, all_tags, all_tags, tag_ranges, buff, store_remote_handles, to_proc );MB_CHK_SET_ERR( result, "Packing tags (count) failed" );
    else
    {  // Set tag size to 0
        buff->check_space( sizeof( int ) );
        PACK_INT( buff->buff_ptr, 0 );
        buff->set_stored_size();
    return result;
ErrorCode moab::ParallelComm::pack_entities ( Range entities,
Buffer buff,
const int  to_proc,
Definition at line 1582 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, build_sharedhps_list(), moab::ParallelComm::Buffer::check_space(), moab::Range::clear(), moab::Range::empty(), moab::Range::end(), moab::EntitySequence::end_handle(), moab::CN::EntityTypeName(), ErrorCode, estimate_ents_buffer_size(), moab::SequenceManager::find(), moab::Range::find(), moab::Interface::get_coords(), moab::TupleList::get_n(), moab::Range::lower_bound(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, MBMAXTYPE, MBVERTEX, myDebug, moab::ElementSequence::nodes_per_element(), moab::PACK_DBLS(), moab::PACK_EH(), pack_entity_seq(), moab::PACK_INT(), moab::PACK_INTS(), pstatus_tag(), moab::Range::rbegin(), sequenceManager, moab::ParallelComm::Buffer::set_stored_size(), sharedp_tag(), moab::Range::size(), moab::Range::subset_by_type(), moab::Interface::tag_get_data(), moab::DebugOutput::tprintf(), moab::EntitySequence::type(), moab::TYPE_FROM_HANDLE(), moab::TupleList::vi_rd, and moab::TupleList::vul_rd.
Referenced by exchange_ghost_cells(), and pack_buffer().
    // Packed information:
    // 1. # entities = E
    // 2. for e in E
    //   a. # procs sharing e, incl. sender and receiver = P
    //   b. for p in P (procs sharing e)
    //   c. for p in P (handle for e on p) (Note1)
    // 3. vertex/entity info
    // Get an estimate of the buffer size & pre-allocate buffer size
    int buff_size = estimate_ents_buffer_size( entities, store_remote_handles );
    if( buff_size < 0 ) MB_SET_ERR( MB_FAILURE, "Failed to estimate ents buffer size" );
    buff->check_space( buff_size );
    myDebug->tprintf( 3, "estimate buffer size for %d entities: %d \n", (int)entities.size(), buff_size );
    unsigned int num_ents;
    ErrorCode result;
    std::vector< EntityHandle > entities_vec( entities.size() );
    std::copy( entities.begin(), entities.end(), entities_vec.begin() );
    // First pack procs/handles sharing this ent, not including this dest but including
    // others (with zero handles)
    if( store_remote_handles )
        // Buff space is at least proc + handle for each entity; use avg of 4 other procs
        // to estimate buff size, but check later
        buff->check_space( sizeof( int ) + ( 5 * sizeof( int ) + sizeof( EntityHandle ) ) * entities.size() );
        PACK_INT( buff->buff_ptr, entities.size() );
        // Pre-fetch sharedp and pstatus
        std::vector< int > sharedp_vals( entities.size() );
        result = mbImpl->tag_get_data( sharedp_tag(), entities, &sharedp_vals[0] );MB_CHK_SET_ERR( result, "Failed to get sharedp tag data" );
        std::vector< char > pstatus_vals( entities.size() );
        result = mbImpl->tag_get_data( pstatus_tag(), entities, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" );
        unsigned int i;
        std::set< unsigned int > dumprocs;
        // 2. for e in E
        for( rit = entities.begin(), i = 0; rit != entities.end(); ++rit, i++ )
            unsigned int ind =
                std::lower_bound( entprocs->vul_rd, entprocs->vul_rd + entprocs->get_n(), *rit ) - entprocs->vul_rd;
            assert( ind < entprocs->get_n() );
            while( ind < entprocs->get_n() && entprocs->vul_rd[ind] == *rit )
                dumprocs.insert( entprocs->vi_rd[ind++] );
            result = build_sharedhps_list( *rit, pstatus_vals[i], sharedp_vals[i], dumprocs, num_ents, tmp_procs,
                                           tmp_handles );MB_CHK_SET_ERR( result, "Failed to build sharedhps" );
            dumprocs.clear();
            // Now pack them
            buff->check_space( ( num_ents + 1 ) * sizeof( int ) + num_ents * sizeof( EntityHandle ) );
            PACK_INT( buff->buff_ptr, num_ents );
            PACK_INTS( buff->buff_ptr, tmp_procs, num_ents );
            PACK_EH( buff->buff_ptr, tmp_handles, num_ents );
#ifndef NDEBUG
            // Check for duplicates in proc list
            unsigned int dp = 0;
            for( ; dp < MAX_SHARING_PROCS && -1 != tmp_procs[dp]; dp++ )
                dumprocs.insert( tmp_procs[dp] );
            assert( dumprocs.size() == dp );
            dumprocs.clear();
#endif
    // Pack vertices
    Range these_ents = entities.subset_by_type( MBVERTEX );
    num_ents         = these_ents.size();
    if( num_ents )
        buff_size = 2 * sizeof( int ) + 3 * num_ents * sizeof( double );
        // Type, # ents
        PACK_INT( buff->buff_ptr, ( (int)MBVERTEX ) );
        PACK_INT( buff->buff_ptr, ( (int)num_ents ) );
        std::vector< double > tmp_coords( 3 * num_ents );
        result = mbImpl->get_coords( these_ents, &tmp_coords[0] );MB_CHK_SET_ERR( result, "Failed to get vertex coordinates" );
        PACK_DBLS( buff->buff_ptr, &tmp_coords[0], 3 * num_ents );
        myDebug->tprintf( 4, "Packed %lu ents of type %s\n", (unsigned long)these_ents.size(),
                          CN::EntityTypeName( TYPE_FROM_HANDLE( *these_ents.begin() ) ) );
    // Now entities; go through range, packing by type and equal # verts per element
    Range::iterator start_rit = entities.find( *these_ents.rbegin() );
    ++start_rit;
    int last_nodes       = -1;
    EntityType last_type = MBMAXTYPE;
    these_ents.clear();
    Range::iterator end_rit = start_rit;
    EntitySequence* seq;
    ElementSequence* eseq;
    while( start_rit != entities.end() || !these_ents.empty() )
        // Cases:
        // A: !end, last_type == MBMAXTYPE, seq: save contig sequence in these_ents
        // B: !end, last type & nodes same, seq: save contig sequence in these_ents
        // C: !end, last type & nodes different: pack these_ents, then save contig sequence in
        // these_ents D: end: pack these_ents
        // Find the sequence holding current start entity, if we're not at end
        eseq = NULL;
        if( start_rit != entities.end() )
            result = sequenceManager->find( *start_rit, seq );MB_CHK_SET_ERR( result, "Failed to find entity sequence" );
            if( NULL == seq ) return MB_FAILURE;
            eseq = dynamic_cast< ElementSequence* >( seq );
        // Pack the last batch if at end or next one is different
        if( !these_ents.empty() &&
            ( !eseq || eseq->type() != last_type || last_nodes != (int)eseq->nodes_per_element() ) )
            result = pack_entity_seq( last_nodes, store_remote_handles, to_proc, these_ents, entities_vec, buff );MB_CHK_SET_ERR( result, "Failed to pack entities from a sequence" );
            these_ents.clear();
        if( eseq )
            // Continuation of current range, just save these entities
            // Get position in entities list one past end of this sequence
            end_rit = entities.lower_bound( start_rit, entities.end(), eseq->end_handle() + 1 );
            // Put these entities in the range
            std::copy( start_rit, end_rit, range_inserter( these_ents ) );
            last_type  = eseq->type();
            last_nodes = eseq->nodes_per_element();
        else if( start_rit != entities.end() && TYPE_FROM_HANDLE( *start_rit ) == MBENTITYSET )
            break;
        start_rit = end_rit;
    // Pack MBMAXTYPE to indicate end of ranges
    PACK_INT( buff->buff_ptr, ( (int)MBMAXTYPE ) );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::pack_entity_seq ( const int  nodes_per_entity,
const int  to_proc,
Range these_ents,
std::vector< EntityHandle > &  entities,
Buffer buff
) [private]
pack a range of entities with equal # verts per entity, along with the range on the sending proc
Definition at line 1836 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), moab::Range::end(), moab::CN::EntityTypeName(), ErrorCode, moab::Interface::get_connectivity(), moab::ParallelComm::Buffer::get_current_size(), get_remote_handles(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, myDebug, moab::PACK_EH(), moab::PACK_INT(), moab::Range::size(), moab::DebugOutput::tprintf(), and moab::TYPE_FROM_HANDLE().
Referenced by pack_entities().
    int tmp_space = 3 * sizeof( int ) + nodes_per_entity * these_ents.size() * sizeof( EntityHandle );
    buff->check_space( tmp_space );
    // Pack the entity type
    PACK_INT( buff->buff_ptr, ( (int)TYPE_FROM_HANDLE( *these_ents.begin() ) ) );
    // Pack # ents
    PACK_INT( buff->buff_ptr, these_ents.size() );
    // Pack the nodes per entity
    PACK_INT( buff->buff_ptr, nodes_per_entity );
    myDebug->tprintf( 3, "after some pack int  %d \n", buff->get_current_size() );
    // Pack the connectivity
    std::vector< EntityHandle > connect;
    for( Range::const_iterator rit = these_ents.begin(); rit != these_ents.end(); ++rit )
        connect.clear();
        result = mbImpl->get_connectivity( &( *rit ), 1, connect, false );MB_CHK_SET_ERR( result, "Failed to get connectivity" );
        assert( (int)connect.size() == nodes_per_entity );
        result =
            get_remote_handles( store_remote_handles, &connect[0], &connect[0], connect.size(), to_proc, entities_vec );MB_CHK_SET_ERR( result, "Failed in get_remote_handles" );
        PACK_EH( buff->buff_ptr, &connect[0], connect.size() );
    myDebug->tprintf( 3, "Packed %lu ents of type %s\n", (unsigned long)these_ents.size(),
    return result;
ErrorCode moab::ParallelComm::pack_range_map ( Range this_range,
EntityHandle  actual_start,
HandleMap handle_map
) [private]
pack a range map with keys in this_range and values a contiguous series of handles starting at actual_start
Definition at line 3136 of file ParallelComm.cpp.
References moab::Range::const_pair_begin(), moab::Range::const_pair_end(), moab::RangeMap< KeyType, ValType, NullVal >::insert(), and MB_SUCCESS.
    for( Range::const_pair_iterator key_it = key_range.const_pair_begin(); key_it != key_range.const_pair_end();
         ++key_it )
        int tmp_num = ( *key_it ).second - ( *key_it ).first + 1;
        handle_map.insert( ( *key_it ).first, val_start, tmp_num );
        val_start += tmp_num;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::pack_remote_handles ( std::vector< EntityHandle > &  L1hloc,
std::vector< EntityHandle > &  L1hrem,
std::vector< int > &  procs,
unsigned int  to_proc,
Buffer buff
Definition at line 7370 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), MB_SUCCESS, moab::PACK_EH(), moab::PACK_INT(), moab::PACK_INTS(), and moab::ParallelComm::Buffer::set_stored_size().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), recv_entities(), and recv_messages().
    assert( std::find( L1hloc.begin(), L1hloc.end(), (EntityHandle)0 ) == L1hloc.end() );
    // 2 vectors of handles plus ints
    buff->check_space( ( ( L1p.size() + 1 ) * sizeof( int ) + ( L1hloc.size() + 1 ) * sizeof( EntityHandle ) +
                         ( L1hrem.size() + 1 ) * sizeof( EntityHandle ) ) );
    // Should be in pairs of handles
    PACK_INT( buff->buff_ptr, L1hloc.size() );
    PACK_INTS( buff->buff_ptr, &L1p[0], L1p.size() );
    // Pack handles in reverse order, (remote, local), so on destination they
    // are ordered (local, remote)
    PACK_EH( buff->buff_ptr, &L1hrem[0], L1hrem.size() );
    PACK_EH( buff->buff_ptr, &L1hloc[0], L1hloc.size() );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::pack_sets ( Range entities,
Buffer buff,
const int  to_proc
) [private]
Definition at line 3149 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), moab::Range::empty(), moab::Range::end(), ErrorCode, estimate_sets_buffer_size(), moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::Interface::get_meshset_options(), moab::Interface::get_parent_meshsets(), get_remote_handles(), moab::ID_FROM_HANDLE(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_NOT_FOUND, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, MBMAXTYPE, myDebug, moab::Interface::num_child_meshsets(), moab::Interface::num_parent_meshsets(), moab::PACK_EH(), moab::PACK_INT(), moab::PACK_INTS(), moab::PACK_RANGE(), moab::PACK_VOID(), moab::RANGE_SIZE(), moab::ParallelComm::Buffer::set_stored_size(), moab::Range::size(), moab::Range::subset_by_type(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::DebugOutput::tprintf(), and moab::TYPE_FROM_HANDLE().
    // SETS:
    // . #sets
    // . for each set:
    //   - options[#sets] (unsigned int)
    //   - if (unordered) set range
    //   - else if ordered
    //     . #ents in set
    //     . handles[#ents]
    //   - #parents
    //   - if (#parents) handles[#parents]
    //   - #children
    //   - if (#children) handles[#children]
    // Now the sets; assume any sets the application wants to pass are in the entities list
    ErrorCode result;
    Range all_sets = entities.subset_by_type( MBENTITYSET );
    int buff_size = estimate_sets_buffer_size( all_sets, store_remote_handles );
    if( buff_size < 0 ) MB_SET_ERR( MB_FAILURE, "Failed to estimate sets buffer size" );
    // Number of sets
    PACK_INT( buff->buff_ptr, all_sets.size() );
    // Options for all sets
    std::vector< unsigned int > options( all_sets.size() );
    std::vector< EntityHandle > members;
    int i;
    for( rit = all_sets.begin(), i = 0; rit != all_sets.end(); ++rit, i++ )
        result = mbImpl->get_meshset_options( *rit, options[i] );MB_CHK_SET_ERR( result, "Failed to get meshset options" );
    buff->check_space( all_sets.size() * sizeof( unsigned int ) );
    PACK_VOID( buff->buff_ptr, &options[0], all_sets.size() * sizeof( unsigned int ) );
    // Pack parallel geometry unique id
    if( !all_sets.empty() )
        Tag uid_tag;
        int n_sets  = all_sets.size();
        bool b_pack = false;
        std::vector< int > id_data( n_sets );
        result =
            mbImpl->tag_get_handle( "PARALLEL_UNIQUE_ID", 1, MB_TYPE_INTEGER, uid_tag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( result, "Failed to create parallel geometry unique id tag" );
        result = mbImpl->tag_get_data( uid_tag, all_sets, &id_data[0] );
        if( MB_TAG_NOT_FOUND != result )
            if( MB_SUCCESS != result ) MB_SET_ERR( result, "Failed to get parallel geometry unique ids" );
            for( i = 0; i < n_sets; i++ )
                if( id_data[i] != 0 )
                    b_pack = true;
                    break;
        if( b_pack )
        {  // If you find
            buff->check_space( ( n_sets + 1 ) * sizeof( int ) );
            PACK_INT( buff->buff_ptr, n_sets );
            PACK_INTS( buff->buff_ptr, &id_data[0], n_sets );
        else
    // Vectors/ranges
        members.clear();
        result = mbImpl->get_entities_by_handle( *rit, members );MB_CHK_SET_ERR( result, "Failed to get entities in ordered set" );
        result =
            get_remote_handles( store_remote_handles, &members[0], &members[0], members.size(), to_proc, entities_vec );MB_CHK_SET_ERR( result, "Failed in get_remote_handles" );
        buff->check_space( members.size() * sizeof( EntityHandle ) + sizeof( int ) );
        PACK_INT( buff->buff_ptr, members.size() );
        PACK_EH( buff->buff_ptr, &members[0], members.size() );
    // Pack parent/child sets
    {  // Only works not store remote handles
        // Pack numbers of parents/children
        unsigned int tot_pch = 0;
        int num_pch;
        buff->check_space( 2 * all_sets.size() * sizeof( int ) );
            // Pack parents
            result = mbImpl->num_parent_meshsets( *rit, &num_pch );MB_CHK_SET_ERR( result, "Failed to get num parents" );
            PACK_INT( buff->buff_ptr, num_pch );
            tot_pch += num_pch;
            result = mbImpl->num_child_meshsets( *rit, &num_pch );MB_CHK_SET_ERR( result, "Failed to get num children" );
            tot_pch += num_pch;
        // Now pack actual parents/children
        members.clear();
        members.reserve( tot_pch );
        std::vector< EntityHandle > tmp_pch;
            result = mbImpl->get_parent_meshsets( *rit, tmp_pch );MB_CHK_SET_ERR( result, "Failed to get parents" );
            std::copy( tmp_pch.begin(), tmp_pch.end(), std::back_inserter( members ) );
            tmp_pch.clear();
            result = mbImpl->get_child_meshsets( *rit, tmp_pch );MB_CHK_SET_ERR( result, "Failed to get children" );
            tmp_pch.clear();
        assert( members.size() == tot_pch );
        if( !members.empty() )
            result = get_remote_handles( store_remote_handles, &members[0], &members[0], members.size(), to_proc,
                                         entities_vec );MB_CHK_SET_ERR( result, "Failed to get remote handles for set parent/child sets" );
#ifndef NDEBUG
            // Check that all handles are either sets or maxtype
            for( unsigned int __j = 0; __j < members.size(); __j++ )
                assert( ( TYPE_FROM_HANDLE( members[__j] ) == MBMAXTYPE &&
                          ID_FROM_HANDLE( members[__j] ) < (int)entities.size() ) ||
                        TYPE_FROM_HANDLE( members[__j] ) == MBENTITYSET );
#endif
            buff->check_space( members.size() * sizeof( EntityHandle ) );
    else
        for( rit = all_sets.begin(); rit != all_sets.end(); ++rit )
    // Pack the handles
    if( store_remote_handles && !all_sets.empty() )
        buff_size = RANGE_SIZE( all_sets );
        PACK_RANGE( buff->buff_ptr, all_sets );
    myDebug->tprintf( 4, "Done packing sets.\n" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::pack_shared_handles ( std::vector< std::vector< SharedEntityData > > &  send_data)
Definition at line 8441 of file ParallelComm.cpp.
References buffProcs, ErrorCode, get_buffers(), get_owner(), get_sharing_data(), moab::ParallelComm::SharedEntityData::local, MAX_SHARING_PROCS, MB_SUCCESS, moab::ParallelComm::SharedEntityData::owner, proc_config(), moab::ParallelComm::SharedEntityData::remote, and sharedEnts.
Referenced by check_all_shared_handles().
    // Build up send buffers
    ErrorCode rval = MB_SUCCESS;
    int ent_procs[MAX_SHARING_PROCS];
    EntityHandle handles[MAX_SHARING_PROCS];
    int num_sharing, tmp_int;
    SharedEntityData tmp;
    send_data.resize( buffProcs.size() );
    for( std::set< EntityHandle >::iterator i = sharedEnts.begin(); i != sharedEnts.end(); ++i )
        tmp.remote = *i;  // Swap local/remote so they're correct on the remote proc.
        rval       = get_owner( *i, tmp_int );
        tmp.owner  = tmp_int;
        rval = get_sharing_data( *i, ent_procs, handles, pstat, num_sharing );
        for( int j = 0; j < num_sharing; j++ )
            if( ent_procs[j] == (int)proc_config().proc_rank() ) continue;
            tmp.local = handles[j];
            int ind   = get_buffers( ent_procs[j] );
            assert( -1 != ind );
            if( (int)send_data.size() < ind + 1 ) send_data.resize( ind + 1 );
            send_data[ind].push_back( tmp );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::pack_tag ( Tag  source_tag,
Tag  destination_tag,
const std::vector< EntityHandle > &  whole_range,
Buffer buff,
const int  to_proc
) [private]
Serialize tag data.
Parameters:
source_tagThe tag for which data will be serialized
destination_tagTag in which to store unpacked tag data. Typically the same as source_tag.
entitiesThe entities for which tag values will be serialized
whole_rangeCalculate entity indices as location in this range
buff_ptrInput/Output: As input, pointer to the start of the buffer in which to serialize data. As output, the position just passed the serialized data.
count_outOutput: The required buffer size, in bytes.
store_handlesThe data for each tag is preceded by a list of EntityHandles designating the entity each of the subsequent tag values corresponds to. This value may be one of: 1) If store_handles == false: An invalid handle composed of {MBMAXTYPE,idx}, where idx is the position of the entity in "whole_range". 2) If store_hanldes == true and a valid remote handle exists, the remote handle. 3) If store_hanldes == true and no valid remote handle is defined for the entity, the same as 1).
to_procIf 'store_handles' is true, the processor rank for which to store the corresponding remote entity handles.
Definition at line 3556 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), ErrorCode, moab::TagInfo::get_data_type(), moab::TagInfo::get_default_value(), moab::TagInfo::get_default_value_size(), moab::TagInfo::get_name(), get_remote_handles(), moab::TagInfo::get_size(), moab::DebugOutput::get_verbosity(), MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OPAQUE, MB_TYPE_OUT_OF_RANGE, MB_VARIABLE_LENGTH, mbImpl, myDebug, moab::PACK_BYTES(), moab::PACK_EH(), moab::PACK_INT(), moab::PACK_INTS(), moab::PACK_VOID(), PC, moab::Range::print(), moab::Range::size(), moab::TagInfo::size_from_data_type(), moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data(), moab::Interface::tag_get_type(), TagType, and moab::DebugOutput::tprintf().
Referenced by pack_tags().
    ErrorCode result;
    std::vector< int > var_len_sizes;
    std::vector< const void* > var_len_values;
    if( src_tag != dst_tag )
        if( dst_tag->get_size() != src_tag->get_size() ) return MB_TYPE_OUT_OF_RANGE;
        if( dst_tag->get_data_type() != src_tag->get_data_type() && dst_tag->get_data_type() != MB_TYPE_OPAQUE &&
            src_tag->get_data_type() != MB_TYPE_OPAQUE )
    // Size, type, data type
    buff->check_space( 3 * sizeof( int ) );
    PACK_INT( buff->buff_ptr, src_tag->get_size() );
    TagType this_type;
    result = mbImpl->tag_get_type( dst_tag, this_type );
    PACK_INT( buff->buff_ptr, (int)this_type );
    DataType data_type = src_tag->get_data_type();
    PACK_INT( buff->buff_ptr, (int)data_type );
    int type_size = TagInfo::size_from_data_type( data_type );
    // Default value
    if( NULL == src_tag->get_default_value() )
    else
        buff->check_space( src_tag->get_default_value_size() );
        PACK_BYTES( buff->buff_ptr, src_tag->get_default_value(), src_tag->get_default_value_size() );
    // Name
    buff->check_space( src_tag->get_name().size() );
    PACK_BYTES( buff->buff_ptr, dst_tag->get_name().c_str(), dst_tag->get_name().size() );
    myDebug->tprintf( 4, "Packing tag \"%s\"", src_tag->get_name().c_str() );
    if( src_tag != dst_tag ) myDebug->tprintf( 4, " (as tag \"%s\")", dst_tag->get_name().c_str() );
    myDebug->tprintf( 4, "\n" );
    // Pack entities
    buff->check_space( tagged_entities.size() * sizeof( EntityHandle ) + sizeof( int ) );
    PACK_INT( buff->buff_ptr, tagged_entities.size() );
    std::vector< EntityHandle > dum_tagged_entities( tagged_entities.size() );
    result = get_remote_handles( store_remote_handles, tagged_entities, &dum_tagged_entities[0], to_proc, whole_vec );
        if( myDebug->get_verbosity() == 3 )
            std::cerr << "Failed to get remote handles for tagged entities:" << std::endl;
            tagged_entities.print( "  " );
        MB_SET_ERR( result, "Failed to get remote handles for tagged entities" );
    PACK_EH( buff->buff_ptr, &dum_tagged_entities[0], dum_tagged_entities.size() );
    const size_t num_ent = tagged_entities.size();
    if( src_tag->get_size() == MB_VARIABLE_LENGTH )
        var_len_sizes.resize( num_ent, 0 );
        var_len_values.resize( num_ent, 0 );
        result = mbImpl->tag_get_by_ptr( src_tag, tagged_entities, &var_len_values[0], &var_len_sizes[0] );MB_CHK_SET_ERR( result, "Failed to get variable-length tag data in pack_tags" );
        buff->check_space( num_ent * sizeof( int ) );
        PACK_INTS( buff->buff_ptr, &var_len_sizes[0], num_ent );
        for( unsigned int i = 0; i < num_ent; i++ )
            buff->check_space( var_len_sizes[i] );
            PACK_VOID( buff->buff_ptr, var_len_values[i], type_size * var_len_sizes[i] );
    else
        buff->check_space( num_ent * src_tag->get_size() );
        // Should be OK to read directly into buffer, since tags are untyped and
        // handled by memcpy
        result = mbImpl->tag_get_data( src_tag, tagged_entities, buff->buff_ptr );MB_CHK_SET_ERR( result, "Failed to get tag data in pack_tags" );
        buff->buff_ptr += num_ent * src_tag->get_size();
        PC( num_ent * src_tag->get_size(), " void" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::pack_tags ( Range entities,
const std::vector< Tag > &  src_tags,
const std::vector< Tag > &  dst_tags,
const std::vector< Range > &  tag_ranges,
Buffer buff,
const int  to_proc
) [private]
Serialize entity tag data.
This function operates in two passes. The first phase, specified by 'just_count == true' calculates the necessary buffer size for the serialized data. The second phase writes the actual binary serialized representation of the data to the passed buffer.
First two arguments are not used. (Legacy interface?)
Parameters:
entitiesNOT USED
start_ritNOT USED
whole_rangeShould be the union of the sets of entities for which tag values are to be serialized. Also specifies ordering for indexes for tag values and serves as the superset from which to compose entity lists from individual tags if just_count and all_possible_tags are both true.
buff_ptrBuffer into which to write binary serialized data
countOutput: The size of the serialized data is added to this parameter. NOTE: Should probably initialize to zero before calling.
just_countIf true, just calculate the buffer size required to hold the serialized data. Will also append to 'all_tags' and 'tag_ranges' if all_possible_tags == true.
all_tagsList of tags to write
tag_rangesList of entities to serialize tag data, one for each corresponding tag handle in 'all_tags.
Definition at line 3470 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, moab::ParallelComm::Buffer::check_space(), moab::Range::end(), ErrorCode, MB_SUCCESS, myDebug, moab::PACK_INT(), pack_tag(), packed_tag_size(), moab::ParallelComm::Buffer::set_stored_size(), moab::Range::size(), and moab::DebugOutput::tprintf().
Referenced by exchange_tags(), pack_buffer(), and reduce_tags().
    ErrorCode result;
    std::vector< Tag >::const_iterator tag_it, dst_it;
    std::vector< Range >::const_iterator rit;
    int count = 0;
    for( tag_it = src_tags.begin(), rit = tag_ranges.begin(); tag_it != src_tags.end(); ++tag_it, ++rit )
        result = packed_tag_size( *tag_it, *rit, count );
        if( MB_SUCCESS != result ) return result;
    // Number of tags
    count += sizeof( int );
    buff->check_space( count );
    PACK_INT( buff->buff_ptr, src_tags.size() );
    for( tag_it = src_tags.begin(), dst_it = dst_tags.begin(), rit = tag_ranges.begin(); tag_it != src_tags.end();
         ++tag_it, ++dst_it, ++rit )
        result = pack_tag( *tag_it, *dst_it, *rit, entities_vec, buff, store_remote_handles, to_proc );
    myDebug->tprintf( 4, "Done packing tags." );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::packed_tag_size ( Tag  source_tag,
int &  count_out
) [private]
Calculate buffer size required to pack tag data.
Parameters:
Definition at line 3513 of file ParallelComm.cpp.
References ErrorCode, errorHandler, moab::TagInfo::get_data(), moab::TagInfo::get_default_value(), moab::TagInfo::get_default_value_size(), moab::TagInfo::get_name(), moab::TagInfo::get_size(), MB_CHK_SET_ERR, MB_SUCCESS, MB_VARIABLE_LENGTH, sequenceManager, and moab::Range::size().
    // For dense tags, compute size assuming all entities have that tag
    // For sparse tags, get number of entities w/ that tag to compute size
    // Default value
    if( NULL != tag->get_default_value() ) count += tag->get_default_value_size();
    count += 3 * sizeof( int );
    // Name
    count += tag->get_name().size();
    // Range of tag
    count += sizeof( int ) + tagged_entities.size() * sizeof( EntityHandle );
    if( tag->get_size() == MB_VARIABLE_LENGTH )
        const int num_ent = tagged_entities.size();
        // Send a tag size for each entity
        count += num_ent * sizeof( int );
        // Send tag data for each entity
        var_len_sizes.resize( num_ent );
        var_len_values.resize( num_ent );
        ErrorCode result =
            tag->get_data( sequenceManager, errorHandler, tagged_entities, &var_len_values[0], &var_len_sizes[0] );MB_CHK_SET_ERR( result, "Failed to get lenghts of variable-length tag values" );
        count += std::accumulate( var_len_sizes.begin(), var_len_sizes.end(), 0 );
    else
        // Tag data values for range or vector
        count += tagged_entities.size() * tag->get_size();
    return MB_SUCCESS;
Definition at line 703 of file ParallelComm.hpp.
References partition_tag().
Referenced by create_part().
        return partition_tag();
const Range& moab::ParallelComm::partition_sets ( ) const [inline]
Definition at line 669 of file ParallelComm.hpp.
References partitionSets.
        return partitionSets;
Tag moab::ParallelComm::pcomm_tag ( Interface impl,
bool  create_if_missing = true
) [static]
return pcomm tag; passes in impl 'cuz this is a static function
return pcomm tag; static because might not have a pcomm before going to look for one on the interface
Definition at line 7989 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_OPAQUE, PARALLEL_COMM_TAG_NAME, and moab::Interface::tag_get_handle().
Referenced by add_pcomm(), get_all_pcomm(), get_pcomm(), remove_pcomm(), and set_partitioning().
    Tag this_tag = 0;
    ErrorCode result;
    if( create_if_missing )
        result = impl->tag_get_handle( PARALLEL_COMM_TAG_NAME, MAX_SHARING_PROCS * sizeof( ParallelComm* ),
                                       MB_TYPE_OPAQUE, this_tag, MB_TAG_SPARSE | MB_TAG_CREAT );
    else
                                       MB_TYPE_OPAQUE, this_tag, MB_TAG_SPARSE );
    if( MB_SUCCESS != result ) return 0;
    return this_tag;
ErrorCode moab::ParallelComm::post_irecv ( std::vector< unsigned int > &  exchange_procs)
Post "MPI_Irecv" before meshing.
Parameters:
exchange_procsprocessor vector exchanged
Definition at line 6768 of file ParallelComm.cpp.
References buffProcs, get_buffers(), INITIAL_BUFF_SIZE, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, MB_SUCCESS, PRINT_DEBUG_IRECV, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recvRemotehReqs, recvReqs, remoteOwnedBuffs, reset_all_buffers(), and sendReqs.
    // Set buffers
    int n_proc = exchange_procs.size();
    for( int i = 0; i < n_proc; i++ )
        get_buffers( exchange_procs[i] );
    reset_all_buffers();
    // Post ghost irecv's for entities from all communicating procs
    // Index requests the same as buffer/sharing procs indices
    int success;
    recvReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL );
    recvRemotehReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL );
    sendReqs.resize( 2 * buffProcs.size(), MPI_REQUEST_NULL );
    int incoming = 0;
        int ind = get_buffers( exchange_procs[i] );
        incoming++;
        PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[ind], remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE,
                           MB_MESG_ENTS_SIZE, incoming );
        success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, buffProcs[ind],
                             MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recvReqs[2 * ind] );
        if( success != MPI_SUCCESS )
            MB_SET_ERR( MB_FAILURE, "Failed to post irecv in owned entity exchange" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::post_irecv ( std::vector< unsigned int > &  shared_procs,
std::set< unsigned int > &  recv_procs
Definition at line 6801 of file ParallelComm.cpp.
References buffProcs, get_buffers(), INITIAL_BUFF_SIZE, localOwnedBuffs, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, MB_SUCCESS, PRINT_DEBUG_IRECV, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recvRemotehReqs, recvReqs, remoteOwnedBuffs, reset_all_buffers(), and sendReqs.
    // Set buffers
    int num = shared_procs.size();
    for( int i = 0; i < num; i++ )
        get_buffers( shared_procs[i] );
    num = remoteOwnedBuffs.size();
        remoteOwnedBuffs[i]->set_stored_size();
    num = localOwnedBuffs.size();
        localOwnedBuffs[i]->set_stored_size();
    int success;
    int incoming                           = 0;
    std::set< unsigned int >::iterator it  = recv_procs.begin();
    std::set< unsigned int >::iterator eit = recv_procs.end();
    for( ; it != eit; ++it )
        int ind = get_buffers( *it );
        incoming++;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::print_buffer ( unsigned char *  buff_ptr,
int  mesg_type,
int  from_proc,
bool  sent
) [private]
Definition at line 2357 of file ParallelComm.cpp.
References moab::CN::EntityTypeName(), moab::ID_FROM_HANDLE(), moab::CN::MAX_NODES_PER_ELEMENT, MAX_NODES_PER_ELEMENT, moab::MB_MESG_ENTS_LARGE, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_LARGE, moab::MB_MESG_REMOTEH_SIZE, moab::MB_MESG_TAGS_LARGE, moab::MB_MESG_TAGS_SIZE, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MB_VARIABLE_LENGTH, MBENTITYSET, MBMAXTYPE, MBVERTEX, moab::ProcConfig::proc_rank(), procConfig, moab::TYPE_FROM_HANDLE(), moab::UNPACK_DBL(), moab::UNPACK_DBLS(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), and moab::UNPACK_TYPE().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), and recv_entities().
    std::cerr << procConfig.proc_rank();
    if( sent )
        std::cerr << " sent";
    else
        std::cerr << " received";
    std::cerr << " message type " << mesg_tag << " to/from proc " << from_proc << "; contents:" << std::endl;
    int msg_length, num_ents;
    unsigned char* orig_ptr = buff_ptr;
    UNPACK_INT( buff_ptr, msg_length );
    std::cerr << msg_length << " bytes..." << std::endl;
    if( MB_MESG_ENTS_SIZE == mesg_tag || MB_MESG_ENTS_LARGE == mesg_tag )
        int i, j, k;
        std::vector< int > ps;
        std::vector< EntityHandle > hs;
        UNPACK_INT( buff_ptr, num_ents );
        std::cerr << num_ents << " entities..." << std::endl;
        // Save place where remote handle info starts, then scan forward to ents
            UNPACK_INT( buff_ptr, j );
            if( 0 > j ) return MB_FAILURE;
            ps.resize( j );
            hs.resize( j );
            std::cerr << "Entity " << i << ", # procs = " << j << std::endl;
            UNPACK_INTS( buff_ptr, &ps[0], j );
            UNPACK_EH( buff_ptr, &hs[0], j );
            std::cerr << "   Procs: ";
            for( k = 0; k < j; k++ )
                std::cerr << ps[k] << " ";
            std::cerr << std::endl;
            std::cerr << "   Handles: ";
                std::cerr << hs[k] << " ";
            if( buff_ptr - orig_ptr > msg_length )
                std::cerr << "End of buffer..." << std::endl;
                std::cerr.flush();
                return MB_FAILURE;
        while( true )
            EntityType this_type = MBMAXTYPE;
            UNPACK_TYPE( buff_ptr, this_type );
            assert( this_type != MBENTITYSET );
            // MBMAXTYPE signifies end of entities data
            if( MBMAXTYPE == this_type ) break;
            // Get the number of ents
            int num_ents2, verts_per_entity = 0;
            UNPACK_INT( buff_ptr, num_ents2 );
            // Unpack the nodes per entity
            if( MBVERTEX != this_type && num_ents2 )
                UNPACK_INT( buff_ptr, verts_per_entity );
            std::cerr << "Type: " << CN::EntityTypeName( this_type ) << "; num_ents = " << num_ents2;
            if( MBVERTEX != this_type ) std::cerr << "; verts_per_ent = " << verts_per_entity;
            if( num_ents2 < 0 || num_ents2 > msg_length )
                std::cerr << "Wrong number of entities, returning." << std::endl;
                return MB_FAILURE;
            for( int e = 0; e < num_ents2; e++ )
                // Check for existing entity, otherwise make new one
                if( MBVERTEX == this_type )
                    double coords[3];
                    UNPACK_DBLS( buff_ptr, coords, 3 );
                    std::cerr << "xyz = " << coords[0] << ", " << coords[1] << ", " << coords[2] << std::endl;
                else
                    EntityHandle connect[CN::MAX_NODES_PER_ELEMENT];
                    assert( verts_per_entity <= CN::MAX_NODES_PER_ELEMENT );
                    UNPACK_EH( buff_ptr, connect, verts_per_entity );
                    // Update connectivity to local handles
                    std::cerr << "Connectivity: ";
                    for( k = 0; k < verts_per_entity; k++ )
                        std::cerr << connect[k] << " ";
                    std::cerr.flush();
                    return MB_FAILURE;
    else if( MB_MESG_REMOTEH_SIZE == mesg_tag || MB_MESG_REMOTEH_LARGE == mesg_tag )
        if( 0 > num_ents || num_ents > msg_length )
            return MB_FAILURE;
        std::vector< EntityHandle > L1hloc( num_ents ), L1hrem( num_ents );
        std::vector< int > L1p( num_ents );
        UNPACK_INTS( buff_ptr, &L1p[0], num_ents );
        UNPACK_EH( buff_ptr, &L1hrem[0], num_ents );
        UNPACK_EH( buff_ptr, &L1hloc[0], num_ents );
        std::cerr << num_ents << " Entity pairs; hremote/hlocal/proc: " << std::endl;
        for( int i = 0; i < num_ents; i++ )
            EntityType etype = TYPE_FROM_HANDLE( L1hloc[i] );
            std::cerr << CN::EntityTypeName( etype ) << ID_FROM_HANDLE( L1hrem[i] ) << ", "
                      << CN::EntityTypeName( etype ) << ID_FROM_HANDLE( L1hloc[i] ) << ", " << L1p[i] << std::endl;
            std::cerr.flush();
            return MB_FAILURE;
    else if( mesg_tag == MB_MESG_TAGS_SIZE || mesg_tag == MB_MESG_TAGS_LARGE )
        int num_tags, dum1, data_type, tag_size;
        UNPACK_INT( buff_ptr, num_tags );
        std::cerr << "Number of tags = " << num_tags << std::endl;
        for( int i = 0; i < num_tags; i++ )
            std::cerr << "Tag " << i << ":" << std::endl;
            UNPACK_INT( buff_ptr, tag_size );
            UNPACK_INT( buff_ptr, dum1 );
            UNPACK_INT( buff_ptr, data_type );
            std::cerr << "Tag size, type, data type = " << tag_size << ", " << dum1 << ", " << data_type << std::endl;
            std::cerr << "Default value size = " << dum1 << std::endl;
            buff_ptr += dum1;
            std::string name( (char*)buff_ptr, dum1 );
            std::cerr << "Tag name = " << name.c_str() << std::endl;
            buff_ptr += dum1;
            std::cerr << "Number of ents = " << num_ents << std::endl;
            std::vector< EntityHandle > tmp_buff( num_ents );
            UNPACK_EH( buff_ptr, &tmp_buff[0], num_ents );
            int tot_length = 0;
                EntityType etype = TYPE_FROM_HANDLE( tmp_buff[j] );
                std::cerr << CN::EntityTypeName( etype ) << " " << ID_FROM_HANDLE( tmp_buff[j] ) << ", tag = ";
                if( tag_size == MB_VARIABLE_LENGTH )
                    tot_length += dum1;
                    std::cerr << "(variable, length = " << dum1 << ")" << std::endl;
                else if( data_type == MB_TYPE_DOUBLE )
                    double dum_dbl;
                    UNPACK_DBL( buff_ptr, dum_dbl );
                    std::cerr << dum_dbl << std::endl;
                else if( data_type == MB_TYPE_INTEGER )
                    int dum_int;
                    UNPACK_INT( buff_ptr, dum_int );
                    std::cerr << dum_int << std::endl;
                else if( data_type == MB_TYPE_OPAQUE )
                    std::cerr << "(opaque)" << std::endl;
                    buff_ptr += tag_size;
                else if( data_type == MB_TYPE_HANDLE )
                    EntityHandle dum_eh;
                    UNPACK_EH( buff_ptr, &dum_eh, 1 );
                    std::cerr << dum_eh << std::endl;
                else if( data_type == MB_TYPE_BIT )
                    std::cerr << "(bit)" << std::endl;
            if( tag_size == MB_VARIABLE_LENGTH ) buff_ptr += tot_length;
    else
        assert( false );
        return MB_FAILURE;
    std::cerr.flush();
    return MB_SUCCESS;
void moab::ParallelComm::print_debug_irecv ( int  to,
int  from,
unsigned char *  buff,
int  size,
int  tag,
int  incoming
) [private]
Definition at line 255 of file ParallelComm.cpp.
References moab::MB_MESG_REMOTEH_ACK, moab::MB_MESG_TAGS_ACK, myDebug, moab::DebugOutput::printf(), and moab::DebugOutput::tprintf().
    myDebug->tprintf( 3, "Irecv, %d<-%d, buffer ptr = %p, tag=%d, size=%d", to, from, (void*)buff, tag, sz );
    if( tag < MB_MESG_REMOTEH_ACK )
        myDebug->printf( 3, ", incoming1=%d\n", incoming );
    else if( tag < MB_MESG_TAGS_ACK )
        myDebug->printf( 3, ", incoming2=%d\n", incoming );
    else
        myDebug->printf( 3, ", incoming=%d\n", incoming );
void moab::ParallelComm::print_debug_isend ( int  from,
int  to,
int  tag,
int  size
) [private]
Definition at line 250 of file ParallelComm.cpp.
References myDebug, and moab::DebugOutput::tprintf().
    myDebug->tprintf( 3, "Isend, %d->%d, buffer ptr = %p, tag=%d, size=%d\n", from, to, (void*)buff, tag, sz );
void moab::ParallelComm::print_debug_recd ( MPI_Status  status) [private]
Definition at line 266 of file ParallelComm.cpp.
References moab::DebugOutput::get_verbosity(), myDebug, and moab::DebugOutput::tprintf().
        int this_count;
        int success = MPI_Get_count( &status, MPI_UNSIGNED_CHAR, &this_count );
        if( MPI_SUCCESS != success ) this_count = -1;
        myDebug->tprintf( 3, "Received from %d, count = %d, tag = %d\n", status.MPI_SOURCE, this_count,
                          status.MPI_TAG );
void moab::ParallelComm::print_debug_waitany ( std::vector< MPI_Request > &  reqs,
int  tag,
int  proc
) [private]
Definition at line 278 of file ParallelComm.cpp.
References moab::DebugOutput::get_verbosity(), moab::MB_MESG_REMOTEH_ACK, moab::MB_MESG_TAGS_ACK, myDebug, moab::DebugOutput::print(), moab::DebugOutput::printf(), and moab::DebugOutput::tprintf().
        myDebug->tprintf( 3, "Waitany, p=%d, ", proc );
            myDebug->print( 3, ", recv_ent_reqs=" );
            myDebug->print( 3, ", recv_remoteh_reqs=" );
        else
            myDebug->print( 3, ", recv_tag_reqs=" );
        for( unsigned int i = 0; i < reqs.size(); i++ )
            myDebug->printf( 3, " %p", (void*)(intptr_t)reqs[i] );
        myDebug->print( 3, "\n" );
void moab::ParallelComm::print_pstatus ( unsigned char  pstat,
std::string &  ostr
print contents of pstatus value in human-readable form
Definition at line 9316 of file ParallelComm.cpp.
References ppstat, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, and PSTATUS_SHARED.
Referenced by print_pstatus().
    std::ostringstream str;
    int num = 0;
#define ppstat( a, b )             \
        if( pstat & ( a ) )        \
            if( num ) str << ", "; \
            str << ( b );          \
            num++;                 \
    ppstat( PSTATUS_NOT_OWNED, "NOT_OWNED" );
    ppstat( PSTATUS_SHARED, "SHARED" );
    ppstat( PSTATUS_MULTISHARED, "MULTISHARED" );
    ppstat( PSTATUS_INTERFACE, "INTERFACE" );
    ppstat( PSTATUS_GHOST, "GHOST" );
    ostr = str.str();
void moab::ParallelComm::print_pstatus ( unsigned char  pstat)
print contents of pstatus value in human-readable form to std::cut
Definition at line 9339 of file ParallelComm.cpp.
References print_pstatus().
    std::string str;
    print_pstatus( pstat, str );
    std::cout << str.c_str() << std::endl;
const ProcConfig& moab::ParallelComm::proc_config ( ) const [inline]
Get proc config for this communication object.
Examples:
HelloParMOAB.cpp, and ReadWriteTest.cpp.
Definition at line 633 of file ParallelComm.hpp.
References procConfig.
Referenced by moab::MeshOutputFunctor::assign_global_ids(), ZoltanPartitioner::balance_mesh(), check_clean_iface(), check_shared_ents(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), collective_sync_partition(), comm(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::ParCommGraph::compute_partition(), create_coarse_mesh(), moab::WriteHDF5Parallel::create_dataset(), create_fine_mesh(), create_interface_sets(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::WriteHDF5Parallel::create_meshset_tables(), create_part(), moab::ReadParallel::create_partition_sets(), moab::WriteHDF5Parallel::create_tag_tables(), moab::WriteHDF5Parallel::debug_barrier_line(), moab::ReadParallel::delete_nonlocal_entities(), moab::Coupler::do_normalization(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ReadHDF5::find_sets_containing(), gather_data(), gather_one_cell_var(), moab::ParallelData::get_interface_sets(), moab::Coupler::get_matching_entities(), get_owner_handle(), get_owning_part(), get_part_handle(), get_part_id(), get_proc_nvecs(), moab::ScdInterface::get_shared_vertices(), get_sharing_parts(), iMeshP_getNumOfTopoAll(), iMeshP_getNumOfTypeAll(), iMeshP_getPartitionComm(), iMOAB_SetDoubleTagStorageWithGid(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::Coupler::initialize_tree(), moab::DataCoupler::interpolate(), moab::Coupler::interpolate(), intersection_at_level(), moab::ReadParallel::load_file(), moab::ReadDamsel::load_file(), moab::Coupler::locate_points(), main(), ZoltanPartitioner::mbFinalizePoints(), ZoltanPartitioner::mbGlobalSuccess(), ZoltanPartitioner::mbInitializePoints(), ZoltanPartitioner::mbPrintGlobalResult(), ZoltanPartitioner::mbShowError(), multiple_loads_of_same_file(), moab::WriteHDF5Parallel::negotiate_type_list(), pack_shared_handles(), moab::WriteHDF5Parallel::parallel_create_file(), MetisPartitioner::partition_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), moab::WriteHDF5Parallel::print_times(), moab::ReadHDF5::print_times(), rank(), moab::ReadHDF5::read_all_set_meta(), read_mesh_parallel(), moab::ReadParallel::ReadParallel(), moab::RefinerTagManager::RefinerTagManager(), ZoltanPartitioner::repartition(), resolve_shared_ents(), resolve_shared_sets(), moab::ReadHDF5::set_up_read(), ZoltanPartitioner::SetHSFC_Parameters(), ZoltanPartitioner::SetHypergraph_Parameters(), ZoltanPartitioner::SetOCTPART_Parameters(), ZoltanPartitioner::SetPARMETIS_Parameters(), ZoltanPartitioner::SetRCB_Parameters(), ZoltanPartitioner::SetRIB_Parameters(), size(), moab::ScdInterface::tag_shared_vertices(), tag_shared_verts(), test_delete_entities(), test_elements_on_several_procs(), test_gather_onevar(), test_ghost_elements(), test_ghost_tag_exchange(), test_intx_in_parallel_elem_based(), test_intx_mpas(), test_read_all(), test_read_conn(), test_read_eul_onevar(), test_read_fv_onevar(), test_read_no_mixed_elements(), test_read_novars(), test_read_onevar(), test_read_parallel(), update_remote_data_old(), and moab::NCWriteHelper::write_set_variables().
        return procConfig;
Definition at line 639 of file ParallelComm.hpp.
        return procConfig;
ErrorCode moab::ParallelComm::recv_buffer ( int  mesg_tag_expected,
const MPI_Status &  mpi_status,
Buffer recv_buff,
MPI_Request &  recv_2nd_req,
MPI_Request &  ack_req,
int &  this_incoming,
Buffer send_buff,
MPI_Request &  send_req,
MPI_Request &  sent_ack_req,
bool &  done,
Buffer next_buff = NULL,
int  next_tag = -1,
MPI_Request *  next_req = NULL,
int *  next_incoming = NULL
) [private]
process incoming message; if longer than the initial size, post recv for next part then send ack; if ack, send second part; else indicate that we're done and buffer is ready for processing
Definition at line 6139 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::alloc_size, moab::ParallelComm::Buffer::get_stored_size(), INITIAL_BUFF_SIZE, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, PRINT_DEBUG_IRECV, PRINT_DEBUG_ISEND, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, moab::ParallelComm::Buffer::reserve(), and moab::ParallelComm::Buffer::reset_ptr().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), recv_entities(), recv_messages(), recv_remote_handle_messages(), reduce_tags(), send_recv_entities(), and settle_intersection_points().
    // Process a received message; if there will be more coming,
    // post a receive for 2nd part then send an ack message
    int from_proc = mpi_status.MPI_SOURCE;
    int success;
    // Set the buff_ptr on the recv_buffer; needs to point beyond any
    // valid data already in the buffer
    recv_buff->reset_ptr( std::min( recv_buff->get_stored_size(), (int)recv_buff->alloc_size ) );
    if( mpi_status.MPI_TAG == mesg_tag_expected && recv_buff->get_stored_size() > (int)INITIAL_BUFF_SIZE )
        // 1st message & large - allocate buffer, post irecv for 2nd message,
        // then send ack
        recv_buff->reserve( recv_buff->get_stored_size() );
        assert( recv_buff->alloc_size > INITIAL_BUFF_SIZE );
        // Will expect a 2nd message
        this_incoming++;
        PRINT_DEBUG_IRECV( procConfig.proc_rank(), from_proc, recv_buff->mem_ptr + INITIAL_BUFF_SIZE,
                           recv_buff->get_stored_size() - INITIAL_BUFF_SIZE, mesg_tag_expected + 1, this_incoming );
        success = MPI_Irecv( recv_buff->mem_ptr + INITIAL_BUFF_SIZE, recv_buff->get_stored_size() - INITIAL_BUFF_SIZE,
                             MPI_UNSIGNED_CHAR, from_proc, mesg_tag_expected + 1, procConfig.proc_comm(), &recv_req );
            MB_SET_ERR( MB_FAILURE, "Failed to post 2nd iRecv in ghost exchange" );
        // Send ack, doesn't matter what data actually is
        PRINT_DEBUG_ISEND( procConfig.proc_rank(), from_proc, recv_buff->mem_ptr, mesg_tag_expected - 1,
                           sizeof( int ) );
        success = MPI_Isend( recv_buff->mem_ptr, sizeof( int ), MPI_UNSIGNED_CHAR, from_proc, mesg_tag_expected - 1,
                             procConfig.proc_comm(), &sent_ack_req );
            MB_SET_ERR( MB_FAILURE, "Failed to send ack in ghost exchange" );
    else if( mpi_status.MPI_TAG == mesg_tag_expected - 1 )
        // Got an ack back, send the 2nd half of message
        // Should be a large message if we got this
        assert( *( (size_t*)send_buff->mem_ptr ) > INITIAL_BUFF_SIZE );
        // Post irecv for next message, then send 2nd message
        if( next_buff )
            // We'll expect a return message
            ( *next_incoming )++;
            PRINT_DEBUG_IRECV( procConfig.proc_rank(), from_proc, next_buff->mem_ptr, INITIAL_BUFF_SIZE, next_tag,
                               *next_incoming );
            success = MPI_Irecv( next_buff->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, from_proc, next_tag,
                                 procConfig.proc_comm(), next_req );
                MB_SET_ERR( MB_FAILURE, "Failed to post next irecv in ghost exchange" );
        // Send 2nd message
        PRINT_DEBUG_ISEND( procConfig.proc_rank(), from_proc, send_buff->mem_ptr + INITIAL_BUFF_SIZE,
                           mesg_tag_expected + 1, send_buff->get_stored_size() - INITIAL_BUFF_SIZE );
        assert( send_buff->get_stored_size() - INITIAL_BUFF_SIZE < send_buff->alloc_size &&
                0 <= send_buff->get_stored_size() );
        success = MPI_Isend( send_buff->mem_ptr + INITIAL_BUFF_SIZE, send_buff->get_stored_size() - INITIAL_BUFF_SIZE,
                             MPI_UNSIGNED_CHAR, from_proc, mesg_tag_expected + 1, procConfig.proc_comm(), &send_req );
            MB_SET_ERR( MB_FAILURE, "Failed to send 2nd message in ghost exchange" );
    else if( ( mpi_status.MPI_TAG == mesg_tag_expected && recv_buff->get_stored_size() <= (int)INITIAL_BUFF_SIZE ) ||
             mpi_status.MPI_TAG == mesg_tag_expected + 1 )
        // Message completely received - signal that we're done
        done = true;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::recv_entities ( const int  from_proc,
const bool  store_remote_handles,
const bool  is_iface,
Range final_ents,
int &  incomming1,
int &  incoming2,
std::vector< std::vector< EntityHandle > > &  L1hloc,
std::vector< std::vector< EntityHandle > > &  L1hrem,
std::vector< std::vector< int > > &  L1p,
std::vector< EntityHandle > &  L2hloc,
std::vector< EntityHandle > &  L2hrem,
std::vector< unsigned int > &  L2p,
std::vector< MPI_Request > &  recv_remoteh_reqs,
bool  wait_all = true
Receive entities from another processor, optionally waiting until it's done.
Receive entities from another processor, with adjs, sets, and tags. If store_remote_handles is true, this call sends back handles assigned to the entities received.
Parameters:
from_procSource processor
store_remote_handlesIf true, send message with new entity handles to source processor (currently unsupported)
final_entsRange containing all entities received
incomingkeep track if any messages are coming to this processor (newly added)
wait_allIf true, wait until all messages received/sent complete
Definition at line 1075 of file ParallelComm.cpp.
References get_buffers(), INITIAL_BUFF_SIZE, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, PRINT_DEBUG_IRECV, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_messages(), recvReqs, and remoteOwnedBuffs.
#ifndef MOAB_HAVE_MPI
    return MB_FAILURE;
#else
    // Non-blocking receive for the first message (having size info)
    int ind1 = get_buffers( from_proc );
    incoming1++;
    PRINT_DEBUG_IRECV( procConfig.proc_rank(), from_proc, remoteOwnedBuffs[ind1]->mem_ptr, INITIAL_BUFF_SIZE,
                       MB_MESG_ENTS_SIZE, incoming1 );
    int success = MPI_Irecv( remoteOwnedBuffs[ind1]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, from_proc,
                             MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recvReqs[2 * ind1] );
        MB_SET_ERR( MB_FAILURE, "Failed to post irecv in ghost exchange" );
    // Receive messages in while loop
    return recv_messages( from_proc, store_remote_handles, is_iface, final_ents, incoming1, incoming2, L1hloc, L1hrem,
                          L1p, L2hloc, L2hrem, L2p, recv_remoteh_reqs );
#endif
ErrorCode moab::ParallelComm::recv_entities ( std::set< unsigned int > &  recv_procs,
int  incoming1,
int  incoming2,
const bool  migrate = false
Definition at line 1111 of file ParallelComm.cpp.
References ackbuff, assign_entities_part(), buffProcs, ErrorCode, get_buffers(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, MPE_Log_event, moab::msgs, myDebug, pack_remote_handles(), print_buffer(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), recvRemotehReqs, recvReqs, remoteOwnedBuffs, send_buffer(), sendReqs, moab::DebugOutput::tprintf(), unpack_buffer(), and unpack_remote_handles().
    // Receive/unpack new entities
    // Number of incoming messages is the number of procs we communicate with
    int success, ind, i;
    ErrorCode result;
    MPI_Status status;
    std::vector< std::vector< EntityHandle > > recd_ents( buffProcs.size() );
    std::vector< std::vector< EntityHandle > > L1hloc( buffProcs.size() ), L1hrem( buffProcs.size() );
    std::vector< std::vector< int > > L1p( buffProcs.size() );
    std::vector< EntityHandle > L2hloc, L2hrem;
    std::vector< unsigned int > L2p;
    std::vector< EntityHandle > new_ents;
    while( incoming1 )
        // Wait for all recvs of ents before proceeding to sending remote handles,
        // b/c some procs may have sent to a 3rd proc ents owned by me;
        PRINT_DEBUG_WAITANY( recvReqs, MB_MESG_ENTS_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 2 * buffProcs.size(), &recvReqs[0], &ind, &status );
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in owned entity exchange" );
        PRINT_DEBUG_RECD( status );
        // OK, received something; decrement incoming counter
        incoming1--;
        bool done = false;
        // In case ind is for ack, we need index of one before it
        unsigned int base_ind = 2 * ( ind / 2 );
        result = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind / 2], recvReqs[ind], recvReqs[ind + 1],
                              incoming1, localOwnedBuffs[ind / 2], sendReqs[base_ind], sendReqs[base_ind + 1], done,
                              ( store_remote_handles ? localOwnedBuffs[ind / 2] : NULL ), MB_MESG_REMOTEH_SIZE,
                              &recvRemotehReqs[base_ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" );
        if( done )
            if( myDebug->get_verbosity() == 4 )
                msgs.resize( msgs.size() + 1 );
                msgs.back() = new Buffer( *remoteOwnedBuffs[ind / 2] );
            // Message completely received - process buffer that was sent
            remoteOwnedBuffs[ind / 2]->reset_ptr( sizeof( int ) );
            result = unpack_buffer( remoteOwnedBuffs[ind / 2]->buff_ptr, store_remote_handles, buffProcs[ind / 2],
                                    ind / 2, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents, true );
                std::cout << "Failed to unpack entities. Buffer contents:" << std::endl;
                print_buffer( remoteOwnedBuffs[ind / 2]->mem_ptr, MB_MESG_ENTS_SIZE, buffProcs[ind / 2], false );
                return result;
            if( recvReqs.size() != 2 * buffProcs.size() )
                // Post irecv's for remote handles from new proc
                for( i = recvReqs.size(); i < (int)( 2 * buffProcs.size() ); i += 2 )
                    localOwnedBuffs[i / 2]->reset_buffer();
                    incoming2++;
                    PRINT_DEBUG_IRECV( procConfig.proc_rank(), buffProcs[i / 2], localOwnedBuffs[i / 2]->mem_ptr,
                                       INITIAL_BUFF_SIZE, MB_MESG_REMOTEH_SIZE, incoming2 );
                    success = MPI_Irecv( localOwnedBuffs[i / 2]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR,
                                         buffProcs[i / 2], MB_MESG_REMOTEH_SIZE, procConfig.proc_comm(),
                                         &recvRemotehReqs[i] );
                        MB_SET_ERR( MB_FAILURE, "Failed to post irecv for remote handles in ghost exchange" );
    // Assign and remove newly created elements from/to receive processor
    result = assign_entities_part( new_ents, procConfig.proc_rank() );MB_CHK_SET_ERR( result, "Failed to assign entities to part" );
    if( migrate )
        // result = remove_entities_part(allsent, procConfig.proc_rank());MB_CHK_SET_ERR(ressult,
        // "Failed to remove entities to part");
    // Add requests for any new addl procs
        // Shouldn't get here...
        MB_SET_ERR( MB_FAILURE, "Requests length doesn't match proc count in entity exchange" );
#ifdef MOAB_HAVE_MPE
    if( myDebug->get_verbosity() == 2 )
        MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending recv entities." );
#endif
    // Send local handles for new entity to owner
        // Reserve space on front for size and for initial buff size
        remoteOwnedBuffs[ind]->reset_buffer( sizeof( int ) );
        result = pack_remote_handles( L1hloc[ind], L1hrem[ind], L1p[ind], buffProcs[ind], remoteOwnedBuffs[ind] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" );
        remoteOwnedBuffs[ind]->set_stored_size();
            msgs.back() = new Buffer( *remoteOwnedBuffs[ind] );
        result = send_buffer( buffProcs[ind], remoteOwnedBuffs[ind], MB_MESG_REMOTEH_SIZE, sendReqs[2 * ind],
                              recvRemotehReqs[2 * ind + 1], &ackbuff, incoming2 );MB_CHK_SET_ERR( result, "Failed to send remote handles" );
    // Process remote handles of my ghosteds
    while( incoming2 )
        PRINT_DEBUG_WAITANY( recvRemotehReqs, MB_MESG_REMOTEH_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 2 * buffProcs.size(), &recvRemotehReqs[0], &ind, &status );
        incoming2--;
        bool done             = false;
        result = recv_buffer( MB_MESG_REMOTEH_SIZE, status, localOwnedBuffs[ind / 2], recvRemotehReqs[ind],
                              recvRemotehReqs[ind + 1], incoming2, remoteOwnedBuffs[ind / 2], sendReqs[base_ind],
                              sendReqs[base_ind + 1], done );MB_CHK_SET_ERR( result, "Failed to receive remote handles" );
        if( done )
            // Incoming remote handles
                msgs.back() = new Buffer( *localOwnedBuffs[ind] );
            localOwnedBuffs[ind / 2]->reset_ptr( sizeof( int ) );
            result =
                unpack_remote_handles( buffProcs[ind / 2], localOwnedBuffs[ind / 2]->buff_ptr, L2hloc, L2hrem, L2p );MB_CHK_SET_ERR( result, "Failed to unpack remote handles" );
        MPE_Log_event( RHANDLES_END, procConfig.proc_rank(), "Ending remote handles." );
        MPE_Log_event( OWNED_END, procConfig.proc_rank(), "Ending recv entities (still doing checks)." );
#endif
    myDebug->tprintf( 1, "Exiting recv_entities.\n" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::recv_messages ( const int  from_proc,
Range final_ents,
int &  incoming1,
int &  incoming2,
Receive messages from another processor in while loop.
Receive messages from another processor.
Parameters:
Definition at line 1292 of file ParallelComm.cpp.
References buffProcs, ErrorCode, get_buffers(), localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, pack_remote_handles(), PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), recvReqs, remoteOwnedBuffs, send_buffer(), sendReqs, and unpack_buffer().
Referenced by recv_entities().
    return MB_FAILURE;
#else
    MPI_Status status;
    ErrorCode result;
    int success, ind2;
    // Wait and receive messages
    while( incoming1 )
        PRINT_DEBUG_WAITANY( recvReqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 2, &recvReqs[2 * ind1], &ind2, &status );
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in recv_messages" );
        incoming1--;
        bool done = false;
        ind2 += 2 * ind1;
        unsigned int base_ind = 2 * ( ind2 / 2 );
        result = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind2 / 2],
                              // recvbuff,
                              recvReqs[ind2], recvReqs[ind2 + 1], incoming1, localOwnedBuffs[ind2 / 2],
                              ( !is_iface && store_remote_handles ? localOwnedBuffs[ind2 / 2] : NULL ),
                              MB_MESG_REMOTEH_SIZE, &recv_remoteh_reqs[base_ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to receive buffer" );
        if( done )
            // If it is done, unpack buffer
            remoteOwnedBuffs[ind2 / 2]->reset_ptr( sizeof( int ) );
            result = unpack_buffer( remoteOwnedBuffs[ind2 / 2]->buff_ptr, store_remote_handles, from_proc, ind2 / 2,
                                    L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents );MB_CHK_SET_ERR( result, "Failed to unpack buffer in recev_messages" );
            std::copy( new_ents.begin(), new_ents.end(), range_inserter( final_ents ) );
            // Send local handles for new elements to owner
            remoteOwnedBuffs[ind2 / 2]->reset_buffer( sizeof( int ) );
            result = pack_remote_handles( L1hloc[ind2 / 2], L1hrem[ind2 / 2], L1p[ind2 / 2], from_proc,
                                          remoteOwnedBuffs[ind2 / 2] );MB_CHK_SET_ERR( result, "Failed to pack remote handles" );
            remoteOwnedBuffs[ind2 / 2]->set_stored_size();
            result = send_buffer( buffProcs[ind2 / 2], remoteOwnedBuffs[ind2 / 2], MB_MESG_REMOTEH_SIZE, sendReqs[ind2],
                                  recv_remoteh_reqs[ind2 + 1], (int*)( localOwnedBuffs[ind2 / 2]->mem_ptr ),
                                  //&ackbuff,
    return MB_SUCCESS;
#endif
ErrorCode moab::ParallelComm::recv_remote_handle_messages ( const int  from_proc,
int &  incoming2,
Definition at line 1370 of file ParallelComm.cpp.
References buffProcs, ErrorCode, get_buffers(), localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_REMOTEH_SIZE, MB_SET_ERR, MB_SUCCESS, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), remoteOwnedBuffs, sendReqs, and unpack_remote_handles().
    return MB_FAILURE;
#else
    MPI_Status status;
    ErrorCode result;
    int success, ind2;
    while( incoming2 )
        PRINT_DEBUG_WAITANY( recv_remoteh_reqs, MB_MESG_REMOTEH_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 2, &recv_remoteh_reqs[2 * ind1], &ind2, &status );
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in recv_remote_handle_messages" );
        incoming2--;
        bool done = false;
        ind2 += 2 * ind1;
        result = recv_buffer( MB_MESG_REMOTEH_SIZE, status, localOwnedBuffs[ind2 / 2], recv_remoteh_reqs[ind2],
                              recv_remoteh_reqs[ind2 + 1], incoming2, remoteOwnedBuffs[ind2 / 2], sendReqs[base_ind],
        if( done )
            localOwnedBuffs[ind2 / 2]->reset_ptr( sizeof( int ) );
            result =
                unpack_remote_handles( buffProcs[ind2 / 2], localOwnedBuffs[ind2 / 2]->buff_ptr, L2hloc, L2hrem, L2p );MB_CHK_SET_ERR( result, "Failed to unpack remote handles" );
    return MB_SUCCESS;
#endif
template<class T >
ErrorCode moab::ParallelComm::reduce ( const MPI_Op  mpi_op,
int  num_ents,
void *  old_vals,
void *  new_vals
) [private]
Definition at line 3843 of file ParallelComm.cpp.
References MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, swap(), and T.
    T* old_tmp = reinterpret_cast< T* >( old_vals );
    // T *new_tmp = reinterpret_cast<T*>(new_vals);
    // new vals pointer needs to be aligned , some compilers will optimize and will shift
    std::vector< T > new_values;
    new_values.resize( num_ents );
    memcpy( &new_values[0], new_vals, num_ents * sizeof( T ) );
    T* new_tmp = &new_values[0];
    if( mpi_op == MPI_SUM )
        std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, ADD< T > );
    else if( mpi_op == MPI_PROD )
        std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, MULT< T > );
    else if( mpi_op == MPI_MAX )
        std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, MAX< T > );
    else if( mpi_op == MPI_MIN )
        std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, MIN< T > );
    else if( mpi_op == MPI_LAND )
        std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, LAND< T > );
    else if( mpi_op == MPI_LOR )
        std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, LOR< T > );
    else if( mpi_op == MPI_LXOR )
        std::transform( old_tmp, old_tmp + num_ents, new_tmp, new_tmp, LXOR< T > );
    else if( mpi_op == MPI_BAND || mpi_op == MPI_BOR || mpi_op == MPI_BXOR )
        std::cerr << "Bitwise operations not allowed in tag reductions." << std::endl;
        return MB_FAILURE;
    else if( mpi_op != MPI_OP_NULL )
        std::cerr << "Unknown MPI operation type." << std::endl;
    // copy now the result back where it should be
    memcpy( new_vals, new_tmp, num_ents * sizeof( T ) );
    std::vector< T >().swap( new_values );  // way to release allocated vector
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::reduce_tags ( const std::vector< Tag > &  src_tags,
const Range entities
Perform data reduction operation for all shared and ghosted entities This function should be called collectively over the communicator for this ParallelComm. If this version is called, all ghosted/shared entities should have a value for this tag (or the tag should have a default value). Operation is any MPI_Op, with result stored in destination tag.
Parameters:
src_tagsVector of tag handles to be reduced
dst_tagsVector of tag handles in which the answer will be stored
mpi_opOperation type
entitiesEntities on which reduction will be made; if empty, operates on all shared entities
Examples:
ReduceExchangeTags.cpp.
Definition at line 7713 of file ParallelComm.cpp.
References moab::Range::begin(), buffProcs, moab::Range::empty(), entities, ErrorCode, filter_pstatus(), get_comm_procs(), moab::Interface::get_entities_by_type_and_tag(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, moab::intersect(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, mbImpl, MBMAXTYPE, myDebug, pack_tags(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), send_buffer(), sendReqs, sharedEnts, moab::Range::size(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), and unpack_tags().
Referenced by iMOAB_ReduceTagsMax(), main(), reduce_tags(), test_reduce_tag_explicit_dest(), test_reduce_tag_failures(), and test_reduce_tags().
    ErrorCode result;
    int success;
    myDebug->tprintf( 1, "Entering reduce_tags\n" );
    // Check that restrictions are met: number of source/dst tags...
    if( src_tags.size() != dst_tags.size() )
        MB_SET_ERR( MB_FAILURE, "Source and destination tag handles must be specified for reduce_tags" );
    // ... tag data types
    std::vector< Tag >::const_iterator vits, vitd;
    int tags_size, tagd_size;
    DataType tags_type, tagd_type;
    std::vector< unsigned char > vals;
    std::vector< int > tags_sizes;
    for( vits = src_tags.begin(), vitd = dst_tags.begin(); vits != src_tags.end(); ++vits, ++vitd )
        // Checks on tag characteristics
        result = mbImpl->tag_get_data_type( *vits, tags_type );MB_CHK_SET_ERR( result, "Failed to get src tag data type" );
        if( tags_type != MB_TYPE_INTEGER && tags_type != MB_TYPE_DOUBLE && tags_type != MB_TYPE_BIT )
            MB_SET_ERR( MB_FAILURE, "Src/dst tags must have integer, double, or bit data type" );
        result = mbImpl->tag_get_bytes( *vits, tags_size );MB_CHK_SET_ERR( result, "Failed to get src tag bytes" );
        vals.resize( tags_size );
        result = mbImpl->tag_get_default_value( *vits, &vals[0] );MB_CHK_SET_ERR( result, "Src tag must have default value" );
        tags_sizes.push_back( tags_size );
        // OK, those passed; now check whether dest tags, if specified, agree with src tags
        if( *vits == *vitd ) continue;
        result = mbImpl->tag_get_bytes( *vitd, tagd_size );MB_CHK_SET_ERR( result, "Coudln't get dst tag bytes" );
        if( tags_size != tagd_size )
            MB_SET_ERR( MB_FAILURE, "Sizes between src and dst tags don't match" );
        result = mbImpl->tag_get_data_type( *vitd, tagd_type );MB_CHK_SET_ERR( result, "Coudln't get dst tag data type" );
        if( tags_type != tagd_type )
            MB_SET_ERR( MB_FAILURE, "Src and dst tags must be of same data type" );
    // Get all procs interfacing to this proc
    std::set< unsigned int > exch_procs;
    result = get_comm_procs( exch_procs );
    // Post ghost irecv's for all interface procs
    std::vector< MPI_Request > recv_tag_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    std::vector< unsigned int >::iterator sit;
    int ind;
    int incoming = 0;
    for( ind = 0, sit = buffProcs.begin(); sit != buffProcs.end(); ++sit, ind++ )
        incoming++;
        PRINT_DEBUG_IRECV( *sit, procConfig.proc_rank(), remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE,
                           MB_MESG_TAGS_SIZE, incoming );
        success = MPI_Irecv( remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, *sit,
                             MB_MESG_TAGS_SIZE, procConfig.proc_comm(), &recv_tag_reqs[3 * ind] );
    // Pack and send tags from this proc to others
    // Make sendReqs vector to simplify initialization
    sendReqs.resize( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    // Take all shared entities if incoming list is empty
    Range entities;
    if( entities_in.empty() )
        std::copy( sharedEnts.begin(), sharedEnts.end(), range_inserter( entities ) );
    else
        entities = entities_in;
    // If the tags are different, copy the source to the dest tag locally
    std::vector< Tag >::const_iterator vit = src_tags.begin(), vit2 = dst_tags.begin();
    std::vector< int >::const_iterator vsizes = tags_sizes.begin();
    for( ; vit != src_tags.end(); ++vit, ++vit2, ++vsizes )
        if( *vit == *vit2 ) continue;
        vals.resize( entities.size() * ( *vsizes ) );
        result = mbImpl->tag_get_data( *vit, entities, &vals[0] );MB_CHK_SET_ERR( result, "Didn't get data properly" );
        result = mbImpl->tag_set_data( *vit2, entities, &vals[0] );MB_CHK_SET_ERR( result, "Didn't set data properly" );
    int dum_ack_buff;
        Range tag_ents = entities;
        // Get ents shared by proc *sit
        result = filter_pstatus( tag_ents, PSTATUS_SHARED, PSTATUS_AND, *sit );MB_CHK_SET_ERR( result, "Failed pstatus AND check" );
        // Pack-send
        std::vector< Range > tag_ranges;
        for( vit = src_tags.begin(); vit != src_tags.end(); ++vit )
            const void* ptr;
            int sz;
            if( mbImpl->tag_get_default_value( *vit, ptr, sz ) != MB_SUCCESS )
                Range tagged_ents;
                mbImpl->get_entities_by_type_and_tag( 0, MBMAXTYPE, &*vit, 0, 1, tagged_ents );
                tag_ranges.push_back( intersect( tag_ents, tagged_ents ) );
            else
                tag_ranges.push_back( tag_ents );
        // Pack the data
        localOwnedBuffs[ind]->reset_ptr( sizeof( int ) );
        result = pack_tags( tag_ents, src_tags, dst_tags, tag_ranges, localOwnedBuffs[ind], true, *sit );MB_CHK_SET_ERR( result, "Failed to count buffer in pack_send_tag" );
        // Now send it
        result = send_buffer( *sit, localOwnedBuffs[ind], MB_MESG_TAGS_SIZE, sendReqs[3 * ind],
                              recv_tag_reqs[3 * ind + 2], &dum_ack_buff, incoming );MB_CHK_SET_ERR( result, "Failed to send buffer" );
    // Receive/unpack tags
    while( incoming )
        MPI_Status status;
        int index_in_recv_requests;
        PRINT_DEBUG_WAITANY( recv_tag_reqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 3 * buffProcs.size(), &recv_tag_reqs[0], &index_in_recv_requests, &status );
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in ghost exchange" );
        ind = index_in_recv_requests / 3;
        incoming--;
        bool done = false;
        std::vector< EntityHandle > dum_vec;
        result = recv_buffer( MB_MESG_TAGS_SIZE, status, remoteOwnedBuffs[ind],
                              recv_tag_reqs[3 * ind + 1],  // This is for receiving the second message
                              recv_tag_reqs[3 * ind + 2],  // This would be for ack, but it is not
                                                           // used; consider removing it
                              incoming, localOwnedBuffs[ind],
                              sendReqs[3 * ind + 1],  // Send request for sending the second message
                              sendReqs[3 * ind + 2],  // This is for sending the ack
                              done );MB_CHK_SET_ERR( result, "Failed to resize recv buffer" );
        if( done )
            remoteOwnedBuffs[ind]->reset_ptr( sizeof( int ) );
            result = unpack_tags( remoteOwnedBuffs[ind]->buff_ptr, dum_vec, true, buffProcs[ind], &mpi_op );MB_CHK_SET_ERR( result, "Failed to recv-unpack-tag message" );
    // OK, now wait
    if( myDebug->get_verbosity() == 5 )
        success = MPI_Barrier( procConfig.proc_comm() );
    else
        MPI_Status status[3 * MAX_SHARING_PROCS];
        success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], status );
        MB_SET_ERR( MB_FAILURE, "Failure in waitall in tag exchange" );
    myDebug->tprintf( 1, "Exiting reduce_tags" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::reduce_tags ( const char *  tag_name,
) [inline]
Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by name.
Parameters:
tag_nameName of tag to be reduced
Definition at line 1611 of file ParallelComm.hpp.
References ErrorCode, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_OPAQUE, mbImpl, reduce_tags(), and moab::Interface::tag_get_handle().
    // get the tag handle
    std::vector< Tag > tags( 1 );
    ErrorCode result = mbImpl->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tags[0], MB_TAG_ANY );
        return result;
    else if( !tags[0] )
        return MB_TAG_NOT_FOUND;
    return reduce_tags( tags, tags, mpi_op, entities );
ErrorCode moab::ParallelComm::reduce_tags ( Tag  tag_handle,
) [inline]
Perform data reduction operation for all shared and ghosted entities Same as std::vector variant except for one tag specified by handle.
Parameters:
Definition at line 1624 of file ParallelComm.hpp.
References reduce_tags().
    std::vector< Tag > tags;
    tags.push_back( tagh );
ErrorCode moab::ParallelComm::reduce_void ( int  tag_data_type,
int  num_ents,
void *  old_vals,
void *  new_vals
) [private]
Definition at line 3886 of file ParallelComm.cpp.
References ErrorCode, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, and MB_TYPE_INTEGER.
Referenced by unpack_tags().
    ErrorCode result;
    switch( tag_data_type )
        case MB_TYPE_INTEGER:
            result = reduce< int >( mpi_op, num_ents, old_vals, new_vals );
            break;
        case MB_TYPE_DOUBLE:
            result = reduce< double >( mpi_op, num_ents, old_vals, new_vals );
            break;
        case MB_TYPE_BIT:
            result = reduce< unsigned char >( mpi_op, num_ents, old_vals, new_vals );
            break;
        default:
            result = MB_SUCCESS;
            break;
    return result;
ErrorCode moab::ParallelComm::remove_entities_part ( Range entities,
const int  proc
) [private]
remove entities to the input processor part
Definition at line 7310 of file ParallelComm.cpp.
References ErrorCode, get_part_handle(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, and moab::Interface::remove_entities().
Referenced by exchange_owned_mesh().
    EntityHandle part_set;
    ErrorCode result = get_part_handle( proc, part_set );MB_CHK_SET_ERR( result, "Failed to get part handle" );
    if( part_set > 0 )
        result = mbImpl->remove_entities( part_set, entities );MB_CHK_SET_ERR( result, "Failed to remove entities from part set" );
    return MB_SUCCESS;
remove a pc from the iface instance tag PARALLEL_COMM
Definition at line 400 of file ParallelComm.cpp.
References ErrorCode, MAX_SHARING_PROCS, MB_SUCCESS, mbImpl, pcomm_tag(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by ~ParallelComm().
    // Remove this pcomm from instance tag
    std::vector< ParallelComm* > pc_array( MAX_SHARING_PROCS );
    Tag pc_tag = pcomm_tag( mbImpl, true );
    const EntityHandle root                      = 0;
    ErrorCode result                             = mbImpl->tag_get_data( pc_tag, &root, 1, (void*)&pc_array[0] );
    std::vector< ParallelComm* >::iterator pc_it = std::find( pc_array.begin(), pc_array.end(), pc );
    assert( MB_SUCCESS == result && pc_it != pc_array.end() );
    // Empty if test to get around compiler warning about unused var
    if( MB_SUCCESS == result )
    *pc_it = NULL;
    mbImpl->tag_set_data( pc_tag, &root, 1, (void*)&pc_array[0] );
reset message buffers to their initial state
Definition at line 1548 of file ParallelComm.hpp.
References localOwnedBuffs, and remoteOwnedBuffs.
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), post_irecv(), reduce_tags(), send_recv_entities(), and settle_intersection_points().
    std::vector< Buffer* >::iterator vit;
    for( vit = localOwnedBuffs.begin(); vit != localOwnedBuffs.end(); ++vit )
        ( *vit )->reset_buffer();
    for( vit = remoteOwnedBuffs.begin(); vit != remoteOwnedBuffs.end(); ++vit )
ErrorCode moab::ParallelComm::resolve_shared_ents ( EntityHandle  this_set,
Range proc_ents,
int  resolve_dim = -1,
int  shared_dim = -1,
Range skin_ents = NULL,
const Tag id_tag = 0
Resolve shared entities between processors.
Resolve shared entities between processors for entities in proc_ents, by comparing global id tag values on vertices on skin of elements in proc_ents. Shared entities are assigned a tag that's either PARALLEL_SHARED_PROC_TAG_NAME, which is 1 integer in length, or PARALLEL_SHARED_PROCS_TAG_NAME, whose length depends on the maximum number of sharing processors. Values in these tags denote the ranks of sharing processors, and the list ends with the value -1.
If shared_dim is input as -1 or not input, a value one less than the maximum dimension of entities in proc_ents is used.
Parameters:
proc_entsEntities for which to resolve shared entities
shared_dimMaximum dimension of shared entities to look for
Definition at line 3967 of file ParallelComm.cpp.
References moab::Interface::add_entities(), assign_global_ids(), moab::Range::begin(), check_all_shared_handles(), create_iface_pc_links(), create_interface_sets(), moab::ProcConfig::crystal_router(), define_mpe(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), ErrorCode, exchange_ghost_cells(), moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), get_interface_procs(), moab::TupleList::get_n(), get_proc_nvecs(), get_shared_proc_tags(), moab::DebugOutput::get_verbosity(), GLOBAL_ID_TAG_NAME, id_tag, moab::TupleList::inc_n(), moab::TupleList::initialize(), moab::gs_data::initialize(), MAX_SHARING_PROCS, MB_ALREADY_ALLOCATED, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mbImpl, MPE_Log_event, myDebug, np, moab::DebugOutput::print(), moab::DebugOutput::printf(), proc_config(), moab::ProcConfig::proc_rank(), procConfig, moab::TupleList::buffer::reset(), moab::TupleList::reset(), moab::gs_data::reset(), moab::Range::size(), size(), moab::TupleList::sort(), moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), tag_shared_verts(), moab::DebugOutput::tprintf(), moab::Interface::UNION, moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
Referenced by create_coarse_mesh(), create_parallel_mesh(), create_shared_grid_2d(), create_shared_grid_3d(), iMesh_createStructuredMesh(), iMeshP_syncMeshAll(), moab::ReadParallel::load_file(), main(), resolve_and_exchange(), resolve_shared_ents(), test_assign_global_ids(), test_ghosted_entity_shared_data(), test_interface_owners_common(), test_reduce_tag_explicit_dest(), test_reduce_tag_failures(), test_reduce_tags(), test_shared_sets(), and test_write_unbalanced().
        define_mpe();
        MPE_Log_event( RESOLVE_START, procConfig.proc_rank(), "Entering resolve_shared_ents." );
#endif
    ErrorCode result;
    myDebug->tprintf( 1, "Resolving shared entities.\n" );
    if( resolve_dim < shared_dim )
        MB_SET_ERR( MB_FAILURE, "MOAB does not support vertex-based partitions, only element-based ones" );
    if( -1 == shared_dim )
        if( !proc_ents.empty() )
            shared_dim = mbImpl->dimension_from_handle( *proc_ents.begin() ) - 1;
        else if( resolve_dim == 3 )
            shared_dim = 2;
    int max_global_resolve_dim = -1;
    int err = MPI_Allreduce( &resolve_dim, &max_global_resolve_dim, 1, MPI_INT, MPI_MAX, proc_config().proc_comm() );
    if( MPI_SUCCESS != err )
        MB_SET_ERR( MB_FAILURE, "Unable to guess global resolve_dim" );
    if( shared_dim < 0 || resolve_dim < 0 )
        // MB_SET_ERR(MB_FAILURE, "Unable to guess shared_dim or resolve_dim");
        resolve_dim = max_global_resolve_dim;
        shared_dim  = resolve_dim - 1;
    if( resolve_dim < 0 || shared_dim < 0 ) return MB_SUCCESS;
    // no task has any mesh, get out
    // Get the skin entities by dimension
    Range tmp_skin_ents[4];
    // Get the entities to be skinned
    // Find the skin
    int skin_dim = resolve_dim - 1;
    if( !skin_ents )
        skin_ents              = tmp_skin_ents;
        skin_ents[resolve_dim] = proc_ents;
        Skinner skinner( mbImpl );
        result =
            skinner.find_skin( this_set, skin_ents[skin_dim + 1], false, skin_ents[skin_dim], NULL, true, true, true );MB_CHK_SET_ERR( result, "Failed to find skin" );
        myDebug->tprintf( 1, "Found skin:   skin_dim: %d resolve_dim: %d , now resolving.\n", skin_dim, resolve_dim );
        myDebug->tprintf( 3, "skin_ents[0].size(): %d skin_ents[1].size(): %d  \n", (int)skin_ents[0].size(),
                          (int)skin_ents[1].size() );
        // Get entities adjacent to skin ents from shared_dim down to zero
        for( int this_dim = skin_dim - 1; this_dim >= 0; this_dim-- )
            result =
                mbImpl->get_adjacencies( skin_ents[skin_dim], this_dim, true, skin_ents[this_dim], Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get skin adjacencies" );
            if( this_set && skin_dim == 2 && this_dim == 1 )
                result = mbImpl->add_entities( this_set, skin_ents[this_dim] );MB_CHK_ERR( result );
    else if( skin_ents[resolve_dim].empty() )
    // Global id tag
    Tag gid_tag;
    if( id_tag )
        gid_tag = *id_tag;
    else
        bool tag_created = false;
        int def_val      = -1;
        result = mbImpl->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_DENSE | MB_TAG_CREAT,
                                         &def_val, &tag_created );
        if( MB_ALREADY_ALLOCATED != result && MB_SUCCESS != result )
            MB_SET_ERR( result, "Failed to create/get gid tag handle" );
        else if( tag_created )
            // Just created it, so we need global ids
            result = assign_global_ids( this_set, skin_dim + 1, true, true, true );MB_CHK_SET_ERR( result, "Failed to assign global ids" );
    DataType tag_type;
    result = mbImpl->tag_get_data_type( gid_tag, tag_type );MB_CHK_SET_ERR( result, "Failed to get tag data type" );
    int bytes_per_tag;
    result = mbImpl->tag_get_bytes( gid_tag, bytes_per_tag );MB_CHK_SET_ERR( result, "Failed to get number of bytes per tag" );
    // On 64 bits, long and int are different
    // On 32 bits, they are not; if size of long is 8, it is a 64 bit machine (really?)
    // Get gids for skin ents in a vector, to pass to gs
    std::vector< long > lgid_data( skin_ents[0].size() );
    // Size is either long or int
    // On 64 bit is 8 or 4
    if( sizeof( long ) == bytes_per_tag && ( ( MB_TYPE_HANDLE == tag_type ) || ( MB_TYPE_OPAQUE == tag_type ) ) )
    {  // It is a special id tag
        result = mbImpl->tag_get_data( gid_tag, skin_ents[0], &lgid_data[0] );MB_CHK_SET_ERR( result, "Couldn't get gid tag for skin vertices" );
    else if( 4 == bytes_per_tag )
    {  // Must be GLOBAL_ID tag or 32 bits ...
        std::vector< int > gid_data( lgid_data.size() );
        result = mbImpl->tag_get_data( gid_tag, skin_ents[0], &gid_data[0] );MB_CHK_SET_ERR( result, "Failed to get gid tag for skin vertices" );
        std::copy( gid_data.begin(), gid_data.end(), lgid_data.begin() );
    else
        // Not supported flag
        MB_SET_ERR( MB_FAILURE, "Unsupported id tag" );
    // Put handles in vector for passing to gs setup
    std::vector< Ulong > handle_vec;  // Assumes that we can do conversion from Ulong to EntityHandle
    std::copy( skin_ents[0].begin(), skin_ents[0].end(), std::back_inserter( handle_vec ) );
        MPE_Log_event( SHAREDV_START, procConfig.proc_rank(), "Creating crystal router." );
#endif
    // Get a crystal router
    gs_data::crystal_data* cd = procConfig.crystal_router();
    // Get total number of entities; will overshoot highest global id, but
    // that's OK
    int num_total[2] = {0, 0}, num_local[2] = {0, 0};
    result = mbImpl->get_number_entities_by_dimension(this_set, 0, num_local);
    if (MB_SUCCESS != result)return result;
    int failure = MPI_Allreduce(num_local, num_total, 1,
    MPI_INT, MPI_SUM, procConfig.proc_comm());
    if (failure) {
      MB_SET_ERR(MB_FAILURE, "Allreduce for total number of shared ents failed");
    // Call gather-scatter to get shared ids & procs
    gs_data* gsd = new gs_data();
    // assert(sizeof(ulong_) == sizeof(EntityHandle));
    result = gsd->initialize( skin_ents[0].size(), &lgid_data[0], &handle_vec[0], 2, 1, 1, cd );MB_CHK_SET_ERR( result, "Failed to create gs data" );
    // Get shared proc tags
    Tag shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag;
    result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags" );
    // Load shared verts into a tuple, then sort by index
    TupleList shared_verts;
    shared_verts.initialize( 2, 0, 1, 0, skin_ents[0].size() * ( MAX_SHARING_PROCS + 1 ) );
    shared_verts.enableWriteAccess();
    unsigned int i = 0, j = 0;
    for( unsigned int p = 0; p < gsd->nlinfo->_np; p++ )
        for( unsigned int np = 0; np < gsd->nlinfo->_nshared[p]; np++ )
            shared_verts.vi_wr[i++] = gsd->nlinfo->_sh_ind[j];
            shared_verts.vi_wr[i++] = gsd->nlinfo->_target[p];
            shared_verts.vul_wr[j]  = gsd->nlinfo->_ulabels[j];
            j++;
            shared_verts.inc_n();
    myDebug->tprintf( 3, " shared verts size %d \n", (int)shared_verts.get_n() );
    int max_size = skin_ents[0].size() * ( MAX_SHARING_PROCS + 1 );
    moab::TupleList::buffer sort_buffer;
    sort_buffer.buffer_init( max_size );
    shared_verts.sort( 0, &sort_buffer );
    sort_buffer.reset();
    // Set sharing procs and handles tags on skin ents
    int maxp = -1;
    std::vector< int > sharing_procs( MAX_SHARING_PROCS );
    std::fill( sharing_procs.begin(), sharing_procs.end(), maxp );
    j = 0;
    i = 0;
    // Get ents shared by 1 or n procs
    std::map< std::vector< int >, std::vector< EntityHandle > > proc_nvecs;
    Range proc_verts;
    result = mbImpl->get_adjacencies( proc_ents, 0, false, proc_verts, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get proc_verts" );
    myDebug->print( 3, " resolve shared ents:  proc verts ", proc_verts );
    result = tag_shared_verts( shared_verts, skin_ents, proc_nvecs, proc_verts );MB_CHK_SET_ERR( result, "Failed to tag shared verts" );
        MPE_Log_event( SHAREDV_END, procConfig.proc_rank(), "Finished tag_shared_verts." );
#endif
    // Get entities shared by 1 or n procs
    result = get_proc_nvecs( resolve_dim, shared_dim, skin_ents, proc_nvecs );MB_CHK_SET_ERR( result, "Failed to tag shared entities" );
    shared_verts.reset();
    if( myDebug->get_verbosity() > 0 )
        for( std::map< std::vector< int >, std::vector< EntityHandle > >::const_iterator mit = proc_nvecs.begin();
             mit != proc_nvecs.end(); ++mit )
            myDebug->tprintf( 1, "Iface: " );
            for( std::vector< int >::const_iterator vit = ( mit->first ).begin(); vit != ( mit->first ).end(); ++vit )
                myDebug->printf( 1, " %d", *vit );
            myDebug->print( 1, "\n" );
    // Create the sets for each interface; store them as tags on
    // the interface instance
    Range iface_sets;
    result = create_interface_sets( proc_nvecs );MB_CHK_SET_ERR( result, "Failed to create interface sets" );
    // Establish comm procs and buffers for them
    std::set< unsigned int > procs;
    result = get_interface_procs( procs, true );MB_CHK_SET_ERR( result, "Failed to get interface procs" );
#ifndef NDEBUG
    result = check_all_shared_handles( true );MB_CHK_SET_ERR( result, "Shared handle check failed after interface vertex exchange" );
#endif
    // Resolve shared entity remote handles; implemented in ghost cell exchange
    // code because it's so similar
    result = exchange_ghost_cells( -1, -1, 0, 0, true, true );MB_CHK_SET_ERR( result, "Failed to resolve shared entity remote handles" );
    // Now build parent/child links for interface sets
    result = create_iface_pc_links();MB_CHK_SET_ERR( result, "Failed to create interface parent/child links" );
    gsd->reset();
    delete gsd;
        MPE_Log_event( RESOLVE_END, procConfig.proc_rank(), "Exiting resolve_shared_ents." );
#endif
    // std::ostringstream ent_str;
    // ent_str << "mesh." << procConfig.proc_rank() << ".h5m";
    // mbImpl->write_mesh(ent_str.str().c_str());
    // Done
    return result;
int  resolve_dim = 3,
Same as resolve_shared_ents(Range&), except works for all entities in instance of dimension dim.
If shared_dim is input as -1 or not input, a value one less than the maximum dimension of entities is used.
Parameters:
dimDimension of entities in the partition
Definition at line 3912 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Interface::dimension_from_handle(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::GeomUtil::first(), moab::Interface::get_entities_by_handle(), moab::Range::lower_bound(), MB_SUCCESS, mbImpl, moab::Range::merge(), myDebug, partitionSets, moab::Interface::query_interface(), moab::Range::rbegin(), resolve_shared_ents(), sharedEnts, moab::ScdInterface::tag_shared_vertices(), moab::DebugOutput::tprintf(), moab::CN::TypeDimensionMap, and moab::Range::upper_bound().
    ErrorCode result;
    Range proc_ents;
    // Check for structured mesh, and do it differently if it is
    ScdInterface* scdi;
    result = mbImpl->query_interface( scdi );
    if( scdi )
        result = scdi->tag_shared_vertices( this, this_set );
            myDebug->tprintf( 1, "Total number of shared entities = %lu.\n", (unsigned long)sharedEnts.size() );
            return result;
    if( 0 == this_set )
        // Get the entities in the partition sets
        for( Range::iterator rit = partitionSets.begin(); rit != partitionSets.end(); ++rit )
            Range tmp_ents;
            result = mbImpl->get_entities_by_handle( *rit, tmp_ents, true );
            if( MB_SUCCESS != result ) return result;
            proc_ents.merge( tmp_ents );
    else
        result = mbImpl->get_entities_by_handle( this_set, proc_ents, true );
    // Resolve dim is maximal dim of entities in proc_ents
    if( -1 == resolve_dim )
        if( !proc_ents.empty() ) resolve_dim = mbImpl->dimension_from_handle( *proc_ents.rbegin() );
    // proc_ents should all be of same dimension
    if( resolve_dim > shared_dim &&
        mbImpl->dimension_from_handle( *proc_ents.rbegin() ) != mbImpl->dimension_from_handle( *proc_ents.begin() ) )
        Range::iterator lower = proc_ents.lower_bound( CN::TypeDimensionMap[0].first ),
                        upper = proc_ents.upper_bound( CN::TypeDimensionMap[resolve_dim - 1].second );
        proc_ents.erase( lower, upper );
    // Must call even if we don't have any entities, to make sure
    // collective comm'n works
    return resolve_shared_ents( this_set, proc_ents, resolve_dim, shared_dim, NULL, id_tag );
ErrorCode moab::ParallelComm::resolve_shared_ents ( ParallelComm **  pc,
const unsigned int  np,
const int  to_dim
) [static]
Definition at line 4260 of file ParallelComm.cpp.
References create_interface_sets(), moab::TupleList::enableWriteAccess(), ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), get_interface_procs(), get_moab(), moab::TupleList::get_n(), moab::Interface::globalId_tag(), moab::TupleList::inc_n(), moab::TupleList::initialize(), MB_SUCCESS, np, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, rank(), moab::TupleList::buffer::reset(), moab::TupleList::reset(), size(), moab::TupleList::sort(), moab::Interface::tag_get_data(), moab::Interface::UNION, update_remote_data(), moab::TupleList::vi_rd, moab::TupleList::vi_wr, moab::TupleList::vul_rd, and moab::TupleList::vul_wr.
    std::vector< Range > verts( np );
    int tot_verts = 0;
    unsigned int p, i, j, v;
    ErrorCode rval;
    for( p = 0; p < np; p++ )
        Skinner skinner( pc[p]->get_moab() );
        Range part_ents, skin_ents;
        rval = pc[p]->get_moab()->get_entities_by_dimension( this_set, part_dim, part_ents );
        if( MB_SUCCESS != rval ) return rval;
        rval = skinner.find_skin( this_set, part_ents, false, skin_ents, 0, true, true, true );
        rval = pc[p]->get_moab()->get_adjacencies( skin_ents, 0, true, verts[p], Interface::UNION );
        tot_verts += verts[p].size();
    TupleList shared_ents;
    shared_ents.initialize( 2, 0, 1, 0, tot_verts );
    shared_ents.enableWriteAccess();
    i = 0;
    j = 0;
    std::vector< int > gids;
    Range::iterator rit;
    Tag gid_tag;
        gid_tag = pc[p]->get_moab()->globalId_tag();
        gids.resize( verts[p].size() );
        rval = pc[p]->get_moab()->tag_get_data( gid_tag, verts[p], &gids[0] );
        for( v = 0, rit = verts[p].begin(); v < gids.size(); v++, ++rit )
            shared_ents.vi_wr[i++] = gids[v];
            shared_ents.vi_wr[i++] = p;
            shared_ents.vul_wr[j]  = *rit;
            j++;
            shared_ents.inc_n();
    sort_buffer.buffer_init( tot_verts );
    shared_ents.sort( 0, &sort_buffer );
    j = 0;
    i = 0;
    std::vector< EntityHandle > handles;
    std::vector< int > procs;
    while( i < shared_ents.get_n() )
        handles.clear();
        procs.clear();
        // Count & accumulate sharing procs
        int this_gid = shared_ents.vi_rd[j];
        while( i < shared_ents.get_n() && shared_ents.vi_rd[j] == this_gid )
            j++;
            procs.push_back( shared_ents.vi_rd[j++] );
            handles.push_back( shared_ents.vul_rd[i++] );
        if( 1 == procs.size() ) continue;
        for( v = 0; v < procs.size(); v++ )
            rval = pc[procs[v]]->update_remote_data( handles[v], &procs[0], &handles[0], procs.size(),
                                                     ( procs[0] == (int)pc[procs[v]]->rank()
                                                           ? PSTATUS_INTERFACE
                                                           : ( PSTATUS_NOT_OWNED | PSTATUS_INTERFACE ) ) );
    std::set< unsigned int > psets;
        rval = pc[p]->create_interface_sets( this_set, part_dim, part_dim - 1 );
        psets.clear();
        rval = pc[p]->get_interface_procs( psets, true );
    shared_ents.reset();
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::resolve_shared_sets ( EntityHandle  this_set,
Remove shared sets.
Generates list of candidate sets using from those (directly) contained in passed set and passes them to the other version of resolve_shared_sets.
Parameters:
this_setSet directly containing candidate sets (e.g. file set)
id_tagTag containing global IDs for entity sets.
Definition at line 4500 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::clear(), DIRICHLET_SET_TAG_NAME, moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, filter_pstatus(), GEOM_DIMENSION_TAG_NAME, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), moab::Range::insert(), moab::intersect(), moab::Range::lower_bound(), MATERIAL_SET_TAG_NAME, MB_SUCCESS, MB_TAG_ANY, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, moab::Range::merge(), NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME, PSTATUS_OR, PSTATUS_SHARED, moab::subtract(), moab::Range::swap(), moab::Interface::tag_get_handle(), and moab::Interface::UNION.
Referenced by moab::ReadParallel::load_file(), test_shared_sets(), and test_write_unbalanced().
    // Find all sets with any of the following tags:
    const char* const shared_set_tag_names[] = { GEOM_DIMENSION_TAG_NAME, MATERIAL_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME,
                                                 NEUMANN_SET_TAG_NAME, PARALLEL_PARTITION_TAG_NAME };
    int num_tags                             = sizeof( shared_set_tag_names ) / sizeof( shared_set_tag_names[0] );
    Range candidate_sets;
    ErrorCode result = MB_FAILURE;
    // If we're not given an ID tag to use to globally identify sets,
    // then fall back to using known tag values
    if( !idtag )
        Tag gid, tag;
        gid = mbImpl->globalId_tag();
        if( NULL != gid ) result = mbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tag );
            for( int d = 0; d < 4; d++ )
                candidate_sets.clear();
                const void* vals[] = { &d };
                result = mbImpl->get_entities_by_type_and_tag( file, MBENTITYSET, &tag, vals, 1, candidate_sets );
                if( MB_SUCCESS == result ) resolve_shared_sets( candidate_sets, gid );
        for( int i = 1; i < num_tags; i++ )
            result = mbImpl->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tag );
                result = mbImpl->get_entities_by_type_and_tag( file, MBENTITYSET, &tag, 0, 1, candidate_sets );
                if( MB_SUCCESS == result ) resolve_shared_sets( candidate_sets, tag );
        return MB_SUCCESS;
        Tag tag;
        result = mbImpl->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, tag, MB_TAG_ANY );
        if( MB_SUCCESS != result ) continue;
        mbImpl->get_entities_by_type_and_tag( file, MBENTITYSET, &tag, 0, 1, candidate_sets, Interface::UNION );
    // Find any additional sets that contain shared entities
    Range::iterator hint = candidate_sets.begin();
    Range all_sets;
    mbImpl->get_entities_by_type( file, MBENTITYSET, all_sets );
    all_sets           = subtract( all_sets, candidate_sets );
    Range::iterator it = all_sets.begin();
    while( it != all_sets.end() )
        Range contents;
        mbImpl->get_entities_by_handle( *it, contents );
        contents.erase( contents.lower_bound( MBENTITYSET ), contents.end() );
        filter_pstatus( contents, PSTATUS_SHARED, PSTATUS_OR );
        if( contents.empty() )
            ++it;
        else
            hint = candidate_sets.insert( hint, *it );
            it   = all_sets.erase( it );
    // Find any additionl sets that contain or are parents of potential shared sets
    Range prev_list = candidate_sets;
    while( !prev_list.empty() )
        Range new_list;
        hint = new_list.begin();
            Range contents;
            mbImpl->get_entities_by_type( *it, MBENTITYSET, contents );
            if( !intersect( prev_list, contents ).empty() )
                hint = new_list.insert( hint, *it );
            else
                new_list.clear();
                mbImpl->get_child_meshsets( *it, contents );
                else
                    ++it;
        candidate_sets.merge( new_list );
        prev_list.swap( new_list );
    return resolve_shared_sets( candidate_sets, *idtag );
ErrorCode moab::ParallelComm::resolve_shared_sets ( Range candidate_sets,
Tag  id_tag
Remove shared sets.
Use values of id_tag to match sets across processes and populate sharing data for sets.
Parameters:
candidate_setsSets to consider as potentially shared.
Definition at line 4621 of file ParallelComm.cpp.
References moab::Range::begin(), moab::choose_owner_idx(), moab::ProcConfig::crystal_router(), moab::dum, moab::Range::end(), ErrorCode, moab::set_tuple::handle, moab::set_tuple::idx, moab::gs_data::initialize(), moab::Range::insert(), moab::is_sorted_unique(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TYPE_HANDLE, MB_TYPE_OPAQUE, mbImpl, np, moab::set_tuple::proc, moab::ProcConfig::proc_comm(), proc_config(), moab::ProcConfig::proc_rank(), procConfig, moab::gs_data::reset(), moab::SharedSetData::set_owner(), moab::SharedSetData::set_sharing_procs(), sharedSetData, t, moab::Interface::tag_get_bytes(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_data_type().
    ErrorCode result;
    const unsigned rk = proc_config().proc_rank();
    MPI_Comm cm       = proc_config().proc_comm();
    // Build sharing list for all sets
    // Get ids for sets in a vector, to pass to gs
    std::vector< long > larray;  // Allocate sufficient space for longs
    std::vector< Ulong > handles;
    Range tmp_sets;
    // The id tag can be size 4 or size 8
    // Based on that, convert to int or to long, similarly to what we do
    // for resolving shared vertices;
    // This code must work on 32 bit too, where long is 4 bytes, also
    // so test first size 4, then we should be fine
    DataType tag_type;
    result = mbImpl->tag_get_data_type( idtag, tag_type );MB_CHK_SET_ERR( result, "Failed getting tag data type" );
    int bytes_per_tag;
    result = mbImpl->tag_get_bytes( idtag, bytes_per_tag );MB_CHK_SET_ERR( result, "Failed getting number of bytes per tag" );
    for( Range::iterator rit = sets.begin(); rit != sets.end(); ++rit )
            long dum;
            result = mbImpl->tag_get_data( idtag, &( *rit ), 1, &dum );
                larray.push_back( dum );
                handles.push_back( *rit );
                tmp_sets.insert( tmp_sets.end(), *rit );
        {  // Must be GLOBAL_ID tag or MATERIAL_ID, etc
            int dum;
    const size_t nsets = handles.size();
    // Get handle array for sets
    // This is not true on windows machine, 64 bits: entity handle is 64 bit, long is 32
    // assert(sizeof(EntityHandle) <= sizeof(unsigned long));
    // Do communication of data
    result                    = gsd->initialize( nsets, &larray[0], &handles[0], 2, 1, 1, cd );MB_CHK_SET_ERR( result, "Failed to create gs data" );
    // Convert from global IDs grouped by process rank to list
    // of <idx, rank> pairs so that we can sort primarily
    // by idx and secondarily by rank (we want lists of procs for each
    // idx, not lists if indices for each proc).
    size_t ntuple = 0;
    for( unsigned p = 0; p < gsd->nlinfo->_np; p++ )
        ntuple += gsd->nlinfo->_nshared[p];
    std::vector< set_tuple > tuples;
    tuples.reserve( ntuple );
    size_t j = 0;
        for( unsigned np = 0; np < gsd->nlinfo->_nshared[p]; np++ )
            set_tuple t;
            t.idx    = gsd->nlinfo->_sh_ind[j];
            t.proc   = gsd->nlinfo->_target[p];
            t.handle = gsd->nlinfo->_ulabels[j];
            tuples.push_back( t );
            j++;
    std::sort( tuples.begin(), tuples.end() );
    // Release crystal router stuff
    gsd->reset();
    delete gsd;
    // Storing sharing data for each set
    size_t ti    = 0;
    unsigned idx = 0;
    std::vector< unsigned > procs;
    Range::iterator si = tmp_sets.begin();
    while( si != tmp_sets.end() && ti < tuples.size() )
        assert( idx <= tuples[ti].idx );
        if( idx < tuples[ti].idx ) si += ( tuples[ti].idx - idx );
        idx = tuples[ti].idx;
        procs.clear();
        size_t ti_init = ti;
        while( ti < tuples.size() && tuples[ti].idx == idx )
            procs.push_back( tuples[ti].proc );
            ++ti;
        assert( is_sorted_unique( procs ) );
        result = sharedSetData->set_sharing_procs( *si, procs );
            std::cerr << "Failure at " __FILE__ ":" << __LINE__ << std::endl;
            std::cerr.flush();
            MPI_Abort( cm, 1 );
        // Add this proc to list of sharing procs in correct position
        // so that all procs select owner based on same list
        std::vector< unsigned >::iterator it = std::lower_bound( procs.begin(), procs.end(), rk );
        assert( it == procs.end() || *it > rk );
        procs.insert( it, rk );
        size_t owner_idx = choose_owner_idx( procs );
        EntityHandle owner_handle;
        if( procs[owner_idx] == rk )
            owner_handle = *si;
        else if( procs[owner_idx] > rk )
            owner_handle = tuples[ti_init + owner_idx - 1].handle;
        else
            owner_handle = tuples[ti_init + owner_idx].handle;
        result = sharedSetData->set_owner( *si, procs[owner_idx], owner_handle );
            std::cerr.flush();
            MPI_Abort( cm, 1 );
        ++si;
        ++idx;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::scatter_entities ( const int  from_proc,
std::vector< Range > &  entities,
const bool  adjacencies = false,
const bool  tags = true
Scatter entities on from_proc to other processors This function assumes remote handles are *not* being stored, since (usually) every processor will know about the whole mesh.
Parameters:
from_procProcessor having the mesh to be broadcast
entitiesOn return, the entities sent or received in this call
adjacenciesIf true, adjacencies are sent for equiv entities (currently unsupported)
tagsIf true, all non-default-valued tags are sent for sent entities
Definition at line 601 of file ParallelComm.cpp.
References add_verts(), moab::ParallelComm::Buffer::buff_ptr, ErrorCode, INITIAL_BUFF_SIZE, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, pack_buffer(), moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), procConfig, moab::ParallelComm::Buffer::reserve(), moab::ParallelComm::Buffer::reset_ptr(), moab::ParallelComm::Buffer::set_stored_size(), and unpack_buffer().
    return MB_FAILURE;
#else
    ErrorCode result = MB_SUCCESS;
    int i, success, buff_size, prev_size;
    int nProcs         = (int)procConfig.proc_size();
    int* sendCounts    = new int[nProcs];
    int* displacements = new int[nProcs];
    sendCounts[0]      = sizeof( int );
    displacements[0]   = 0;
    Buffer buff( INITIAL_BUFF_SIZE );
    buff.reset_ptr( sizeof( int ) );
    buff.set_stored_size();
    unsigned int my_proc = procConfig.proc_rank();
    // Get buffer size array for each remote processor
    if( my_proc == (unsigned int)from_proc )
        for( i = 1; i < nProcs; i++ )
            prev_size = buff.buff_ptr - buff.mem_ptr;
            buff.reset_ptr( prev_size + sizeof( int ) );
            result = add_verts( entities[i] );MB_CHK_SET_ERR( result, "Failed to add verts" );
            result = pack_buffer( entities[i], adjacencies, tags, false, -1, &buff );
                delete[] sendCounts;
                delete[] displacements;
                MB_SET_ERR( result, "Failed to pack buffer in scatter_entities" );
            buff_size                               = buff.buff_ptr - buff.mem_ptr - prev_size;
            *( (int*)( buff.mem_ptr + prev_size ) ) = buff_size;
            sendCounts[i]                           = buff_size;
    // Broadcast buffer size array
    success = MPI_Bcast( sendCounts, nProcs, MPI_INT, from_proc, procConfig.proc_comm() );
    if( MPI_SUCCESS != success )
        MB_SET_ERR( MB_FAILURE, "MPI_Bcast of buffer size failed" );
        displacements[i] = displacements[i - 1] + sendCounts[i - 1];
    Buffer rec_buff;
    rec_buff.reserve( sendCounts[my_proc] );
    // Scatter actual geometry
    success = MPI_Scatterv( buff.mem_ptr, sendCounts, displacements, MPI_UNSIGNED_CHAR, rec_buff.mem_ptr,
                            sendCounts[my_proc], MPI_UNSIGNED_CHAR, from_proc, procConfig.proc_comm() );
        MB_SET_ERR( MB_FAILURE, "MPI_Scatterv of buffer failed" );
    // Unpack in remote processors
    if( my_proc != (unsigned int)from_proc )
        std::vector< std::vector< EntityHandle > > dum1a, dum1b;
        std::vector< std::vector< int > > dum1p;
        std::vector< EntityHandle > dum2, dum4;
        std::vector< unsigned int > dum3;
        rec_buff.reset_ptr( sizeof( int ) );
        result = unpack_buffer( rec_buff.buff_ptr, false, from_proc, -1, dum1a, dum1b, dum1p, dum2, dum2, dum3, dum4 );
            MB_SET_ERR( result, "Failed to unpack buffer in scatter_entities" );
        std::copy( dum4.begin(), dum4.end(), range_inserter( entities[my_proc] ) );
    return MB_SUCCESS;
#endif
ErrorCode moab::ParallelComm::send_buffer ( const unsigned int  to_proc,
Buffer send_buff,
const int  msg_tag,
MPI_Request &  ack_recv_req,
int *  ack_buff,
int  next_mesg_tag = -1,
Buffer next_recv_buff = NULL,
MPI_Request *  next_recv_req = NULL,
) [private]
send the indicated buffer, possibly sending size first
Definition at line 6086 of file ParallelComm.cpp.
References moab::ParallelComm::Buffer::alloc_size, ErrorCode, moab::ParallelComm::Buffer::get_stored_size(), INITIAL_BUFF_SIZE, MB_SET_ERR, MB_SUCCESS, moab::ParallelComm::Buffer::mem_ptr, PRINT_DEBUG_IRECV, PRINT_DEBUG_ISEND, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), and procConfig.
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), exchange_tags(), recv_entities(), recv_messages(), reduce_tags(), send_entities(), send_recv_entities(), and settle_intersection_points().
    int success;
    // If small message, post recv for remote handle message
    if( send_buff->get_stored_size() <= (int)INITIAL_BUFF_SIZE && next_recv_buff )
        PRINT_DEBUG_IRECV( procConfig.proc_rank(), to_proc, next_recv_buff->mem_ptr, INITIAL_BUFF_SIZE, next_mesg_tag,
                           *next_incoming );
        success = MPI_Irecv( next_recv_buff->mem_ptr, INITIAL_BUFF_SIZE, MPI_UNSIGNED_CHAR, to_proc, next_mesg_tag,
                             procConfig.proc_comm(), next_recv_req );
        if( success != MPI_SUCCESS )
            MB_SET_ERR( MB_FAILURE, "Failed to post irecv for next message in ghost exchange" );
    // If large, we'll need an ack before sending the rest
    else if( send_buff->get_stored_size() > (int)INITIAL_BUFF_SIZE )
        this_incoming++;
        PRINT_DEBUG_IRECV( procConfig.proc_rank(), to_proc, (unsigned char*)ack_buff, sizeof( int ), mesg_tag - 1,
                           this_incoming );
        success = MPI_Irecv( (void*)ack_buff, sizeof( int ), MPI_UNSIGNED_CHAR, to_proc, mesg_tag - 1,
                             procConfig.proc_comm(), &ack_req );
            MB_SET_ERR( MB_FAILURE, "Failed to post irecv for entity ack in ghost exchange" );
    // Send the buffer
    PRINT_DEBUG_ISEND( procConfig.proc_rank(), to_proc, send_buff->mem_ptr, mesg_tag,
                       std::min( send_buff->get_stored_size(), (int)INITIAL_BUFF_SIZE ) );
    assert( 0 <= send_buff->get_stored_size() && send_buff->get_stored_size() <= (int)send_buff->alloc_size );
    success = MPI_Isend( send_buff->mem_ptr, std::min( send_buff->get_stored_size(), (int)INITIAL_BUFF_SIZE ),
                         MPI_UNSIGNED_CHAR, to_proc, mesg_tag, procConfig.proc_comm(), &send_req );
    if( success != MPI_SUCCESS ) return MB_FAILURE;
    return result;
ErrorCode moab::ParallelComm::send_entities ( const int  to_proc,
Range orig_ents,
const bool  adjs,
const bool  tags,
Range final_ents,
int &  incoming1,
int &  incoming2,
TupleList entprocs,
send entities to another processor, optionally waiting until it's done
Send entities to another processor, with adjs, sets, and tags. If store_remote_handles is true, this call receives back handles assigned to entities sent to destination processor and stores them in sharedh_tag or sharedhs_tag.
Parameters:
to_procDestination processor
orig_entsEntities requested to send
adjsIf true, send adjacencies for equiv entities (currently unsupported)
tagsIf true, send tag values for all tags assigned to entities
store_remote_handlesIf true, also recv message with handles on destination processor (currently unsupported)
final_entsRange containing all entities sent
Definition at line 698 of file ParallelComm.cpp.
References add_verts(), moab::Range::empty(), ErrorCode, filter_pstatus(), get_buffers(), localOwnedBuffs, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SUCCESS, pack_buffer(), PSTATUS_AND, PSTATUS_SHARED, recvReqs, remoteOwnedBuffs, send_buffer(), sendReqs, and moab::subtract().
    return MB_FAILURE;
#else
    // Pack entities to local buffer
    int ind = get_buffers( to_proc );
    // Add vertices
    ErrorCode result = add_verts( orig_ents );MB_CHK_SET_ERR( result, "Failed to add verts in send_entities" );
    // Filter out entities already shared with destination
    Range tmp_range;
    result = filter_pstatus( orig_ents, PSTATUS_SHARED, PSTATUS_AND, to_proc, &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" );
    if( !tmp_range.empty() )
        orig_ents = subtract( orig_ents, tmp_range );
    result = pack_buffer( orig_ents, adjs, tags, store_remote_handles, to_proc, localOwnedBuffs[ind], &entprocs );MB_CHK_SET_ERR( result, "Failed to pack buffer in send_entities" );
    // Send buffer
    result = send_buffer( to_proc, localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[2 * ind], recvReqs[2 * ind + 1],
                          (int*)( remoteOwnedBuffs[ind]->mem_ptr ),
                          //&ackbuff,
                          incoming1, MB_MESG_REMOTEH_SIZE,
                          ( !is_iface && store_remote_handles ? localOwnedBuffs[ind] : NULL ),
                          &recv_remoteh_reqs[2 * ind], &incoming2 );MB_CHK_SET_ERR( result, "Failed to send buffer" );
    return MB_SUCCESS;
#endif
ErrorCode moab::ParallelComm::send_entities ( std::vector< unsigned int > &  send_procs,
std::vector< Range * > &  send_ents,
int &  incoming1,
int &  incoming2,
Definition at line 743 of file ParallelComm.cpp.
References ackbuff, add_verts(), buffProcs, moab::Range::compactness(), moab::TupleList::disableWriteAccess(), moab::Range::empty(), moab::TupleList::enableWriteAccess(), ErrorCode, filter_pstatus(), get_buffers(), moab::TupleList::get_n(), moab::DebugOutput::get_verbosity(), moab::TupleList::inc_n(), moab::TupleList::initialize(), localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, moab::MB_MESG_REMOTEH_SIZE, MB_SUCCESS, moab::Range::merge(), MPE_Log_event, moab::msgs, myDebug, pack_buffer(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recvRemotehReqs, recvReqs, moab::TupleList::buffer::reset(), moab::TupleList::reset(), send_buffer(), sendReqs, moab::Range::size(), size(), moab::TupleList::sort(), moab::subtract(), moab::DebugOutput::tprintf(), moab::TupleList::vi_wr, and moab::TupleList::vul_wr.
        MPE_Log_event( OWNED_START, procConfig.proc_rank(), "Starting send_entities." );
#endif
    myDebug->tprintf( 1, "Entering send_entities\n" );
        msgs.clear();
        msgs.reserve( MAX_SHARING_PROCS );
    unsigned int i;
    int ind;
    // Set buffProcs with communicating procs
    unsigned int n_proc = send_procs.size();
    for( i = 0; i < n_proc; i++ )
        ind    = get_buffers( send_procs[i] );
        result = add_verts( *send_ents[i] );MB_CHK_SET_ERR( result, "Failed to add verts" );
        Range tmp_range;
        result = filter_pstatus( *send_ents[i], PSTATUS_SHARED, PSTATUS_AND, buffProcs[ind], &tmp_range );MB_CHK_SET_ERR( result, "Failed to filter on owner" );
            *send_ents[i] = subtract( *send_ents[i], tmp_range );
    // Get entities to be sent to neighbors
    // Need to get procs each entity is sent to
    Range allsent, tmp_range;
    int npairs = 0;
    TupleList entprocs;
        int n_ents = send_ents[i]->size();
        if( n_ents > 0 )
            npairs += n_ents;  // Get the total # of proc/handle pairs
            allsent.merge( *send_ents[i] );
    // Allocate a TupleList of that size
    entprocs.initialize( 1, 0, 1, 0, npairs );
    entprocs.enableWriteAccess();
    // Put the proc/handle pairs in the list
        for( Range::iterator rit = send_ents[i]->begin(); rit != send_ents[i]->end(); ++rit )
            entprocs.vi_wr[entprocs.get_n()]  = send_procs[i];
            entprocs.vul_wr[entprocs.get_n()] = *rit;
            entprocs.inc_n();
    // Sort by handle
    sort_buffer.buffer_init( npairs );
    entprocs.sort( 1, &sort_buffer );
    entprocs.disableWriteAccess();
    myDebug->tprintf( 1, "allsent ents compactness (size) = %f (%lu)\n", allsent.compactness(),
                      (unsigned long)allsent.size() );
    // Pack and send ents from this proc to others
        if( send_ents[i]->size() > 0 )
            myDebug->tprintf( 1, "Sent ents compactness (size) = %f (%lu)\n", send_ents[i]->compactness(),
                              (unsigned long)send_ents[i]->size() );
            localOwnedBuffs[ind]->reset_buffer( sizeof( int ) );
            result = pack_buffer( *send_ents[i], false, true, store_remote_handles, buffProcs[ind],
                                  localOwnedBuffs[ind], &entprocs, &allsent );
            // Send the buffer (size stored in front in send_buffer)
            result = send_buffer( send_procs[i], localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[2 * ind],
                                  recvReqs[2 * ind + 1], &ackbuff, incoming1, MB_MESG_REMOTEH_SIZE,
                                  ( store_remote_handles ? localOwnedBuffs[ind] : NULL ), &recvRemotehReqs[2 * ind],
                                  &incoming2 );MB_CHK_SET_ERR( result, "Failed to Isend in ghost send" );
    entprocs.reset();
        MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending send_entities." );
#endif
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::send_recv_entities ( std::vector< int > &  send_procs,
std::vector< std::vector< int > > &  msgsizes,
std::vector< std::vector< EntityHandle > > &  senddata,
std::vector< std::vector< EntityHandle > > &  recvdata
Send and receives data from a set of processors.
Definition at line 873 of file ParallelComm.cpp.
References buffProcs, entities, moab::error(), ErrorCode, get_buffers(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_ENTS_SIZE, MB_SET_ERR, MB_SUCCESS, MPE_Log_event, moab::msgs, myDebug, moab::PACK_EH(), moab::PACK_INTS(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), send_buffer(), sendReqs, size(), moab::DebugOutput::tprintf(), moab::UNPACK_EH(), and moab::UNPACK_INTS().
#ifdef USE_MPE
        MPE_Log_event( OWNED_START, procConfig.proc_rank(), "Starting send_recv_entities." );
#endif
    myDebug->tprintf( 1, "Entering send_recv_entities\n" );
        msgs.clear();
    // unsigned int i;
    int i, ind, success;
    ErrorCode error = MB_SUCCESS;
    // std::cout<<"resetting all buffers"<<std::endl;
    reset_all_buffers();
    std::vector< MPI_Request > recv_ent_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    int ack_buff;
    int incoming = 0;
        incoming++;
                           MB_MESG_ENTS_SIZE, incoming );
                             MB_MESG_ENTS_SIZE, procConfig.proc_comm(), &recv_ent_reqs[3 * ind] );
            MB_SET_ERR( MB_FAILURE, "Failed to post irecv in send_recv_entities" );
    //  std::set<unsigned int>::iterator it;
    for( i = 0; i < (int)send_procs.size(); i++ )
        // Get index of the shared processor in the local buffer
        int buff_size = msgsizes[i].size() * sizeof( int ) + senddata[i].size() * sizeof( EntityHandle );
        localOwnedBuffs[ind]->check_space( buff_size );
        // Pack entities
        std::vector< int > msg;
        msg.insert( msg.end(), msgsizes[i].begin(), msgsizes[i].end() );
        PACK_INTS( localOwnedBuffs[ind]->buff_ptr, &msg[0], msg.size() );
        std::vector< EntityHandle > entities;
        entities.insert( entities.end(), senddata[i].begin(), senddata[i].end() );
        PACK_EH( localOwnedBuffs[ind]->buff_ptr, &entities[0], entities.size() );
        localOwnedBuffs[ind]->set_stored_size();
        error = send_buffer( send_procs[i], localOwnedBuffs[ind], MB_MESG_ENTS_SIZE, sendReqs[3 * ind],
                             recv_ent_reqs[3 * ind + 2], &ack_buff, incoming );MB_CHK_SET_ERR( error, "Failed to Isend in send_recv_entities" );
    // Receive and unpack ents from received data
    while( incoming )
        MPI_Status status;
        PRINT_DEBUG_WAITANY( recv_ent_reqs, MB_MESG_ENTS_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 3 * buffProcs.size(), &recv_ent_reqs[0], &index_in_recv_requests, &status );
            MB_SET_ERR( MB_FAILURE, "Failed in waitany in send_recv_entities" );
        // Processor index in the list is divided by 3
        PRINT_DEBUG_RECD( status );
        // OK, received something; decrement incoming counter
        incoming--;
        bool done = false;
        error = recv_buffer( MB_MESG_ENTS_SIZE, status, remoteOwnedBuffs[ind],
                             recv_ent_reqs[3 * ind + 1],  // This is for receiving the second message
                             recv_ent_reqs[3 * ind + 2],  // This would be for ack, but it is not
                             done );MB_CHK_SET_ERR( error, "Failed to resize recv buffer" );
        if( done )
            int from_proc = status.MPI_SOURCE;
            int idx       = std::find( send_procs.begin(), send_procs.end(), from_proc ) - send_procs.begin();
            int msg = msgsizes[idx].size();
            std::vector< int > recvmsg( msg );
            int ndata = senddata[idx].size();
            std::vector< EntityHandle > dum_vec( ndata );
            UNPACK_INTS( remoteOwnedBuffs[ind]->buff_ptr, &recvmsg[0], msg );
            UNPACK_EH( remoteOwnedBuffs[ind]->buff_ptr, &dum_vec[0], ndata );
            recvdata[idx].insert( recvdata[idx].end(), dum_vec.begin(), dum_vec.end() );
#ifdef USE_MPE
        MPE_Log_event( ENTITIES_END, procConfig.proc_rank(), "Ending send_recv_entities." );
#endif
    return MB_SUCCESS;
set the verbosity level of output from this pcomm
Definition at line 8867 of file ParallelComm.cpp.
References myDebug, and moab::DebugOutput::set_verbosity().
Referenced by moab::ReadParallel::load_file(), and test_read_and_ghost_after().
    myDebug->set_verbosity( verb );
Definition at line 8075 of file ParallelComm.cpp.
References moab::Interface::add_entities(), ErrorCode, moab::Interface::get_entities_by_handle(), MAX_SHARING_PROCS, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, mbImpl, partition_sets(), moab::PARTITIONING_PCOMM_TAG_NAME, partitioningSet, pcomm_tag(), moab::Interface::tag_delete_data(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by get_pcomm().
    ErrorCode rval;
    Tag prtn_tag;
    rval = mbImpl->tag_get_handle( PARTITIONING_PCOMM_TAG_NAME, 1, MB_TYPE_INTEGER, prtn_tag,
                                   MB_TAG_SPARSE | MB_TAG_CREAT );
    // Get my id
    ParallelComm* pcomm_arr[MAX_SHARING_PROCS];
    Tag pc_tag = pcomm_tag( mbImpl, false );
    if( 0 == pc_tag ) return MB_FAILURE;
    ErrorCode result        = mbImpl->tag_get_data( pc_tag, &root, 1, pcomm_arr );
    if( MB_SUCCESS != result ) return MB_FAILURE;
    int id = std::find( pcomm_arr, pcomm_arr + MAX_SHARING_PROCS, this ) - pcomm_arr;
    if( id == MAX_SHARING_PROCS ) return MB_FAILURE;
    EntityHandle old = partitioningSet;
    if( old )
        rval = mbImpl->tag_delete_data( prtn_tag, &old, 1 );
        partitioningSet = 0;
    if( !set ) return MB_SUCCESS;
    Range contents;
    if( old )
        rval = mbImpl->get_entities_by_handle( old, contents );
    else
        contents = partition_sets();
    rval = mbImpl->add_entities( set, contents );
    // Store pcomm id on new partition set
    rval = mbImpl->tag_set_data( prtn_tag, &set, 1, &id );
    partitioningSet = set;
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::set_pstatus_entities ( Range pstatus_ents,
unsigned char  pstatus_val,
bool  lower_dim_ents = false,
bool  verts_too = true,
int  operation = Interface::UNION
) [private]
Set pstatus values on entities.
Parameters:
pstatus_entsEntities to be set
pstatus_valPstatus value to be set
lower_dim_entsIf true, lower-dimensional ents (incl. vertices) set too (and created if they don't exist)
verts_tooIf true, vertices also set
operationIf UNION, pstatus_val is OR-d with existing value, otherwise existing value is over-written
Definition at line 4410 of file ParallelComm.cpp.
References moab::Interface::dimension_from_handle(), ErrorCode, moab::Interface::get_adjacencies(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, pstatus_tag(), moab::Range::rbegin(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
Referenced by set_pstatus_entities().
    std::vector< unsigned char > pstatus_vals( pstatus_ents.size() );
    Range all_ents, *range_ptr = &pstatus_ents;
    ErrorCode result;
    if( lower_dim_ents || verts_too )
        all_ents      = pstatus_ents;
        range_ptr     = &all_ents;
        int start_dim = ( lower_dim_ents ? mbImpl->dimension_from_handle( *pstatus_ents.rbegin() ) - 1 : 0 );
        for( ; start_dim >= 0; start_dim-- )
            result = mbImpl->get_adjacencies( all_ents, start_dim, true, all_ents, Interface::UNION );MB_CHK_SET_ERR( result, "Failed to get adjacencies for pstatus entities" );
    if( Interface::UNION == operation )
        result = mbImpl->tag_get_data( pstatus_tag(), *range_ptr, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" );
        for( unsigned int i = 0; i < pstatus_vals.size(); i++ )
            pstatus_vals[i] |= pstatus_val;
    else
            pstatus_vals[i] = pstatus_val;
    result = mbImpl->tag_set_data( pstatus_tag(), *range_ptr, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::set_pstatus_entities ( EntityHandle pstatus_ents,
int  num_ents,
) [private]
Set pstatus values on entities (vector-based function)
Parameters:
Definition at line 4445 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, pstatus_tag(), set_pstatus_entities(), moab::Interface::tag_get_data(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
    std::vector< unsigned char > pstatus_vals( num_ents );
    ErrorCode result;
        // In this case, call the range-based version
        Range tmp_range;
        std::copy( pstatus_ents, pstatus_ents + num_ents, range_inserter( tmp_range ) );
        return set_pstatus_entities( tmp_range, pstatus_val, lower_dim_ents, verts_too, operation );
        result = mbImpl->tag_get_data( pstatus_tag(), pstatus_ents, num_ents, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus tag data" );
        for( unsigned int i = 0; i < (unsigned int)num_ents; i++ )
    else
    result = mbImpl->tag_set_data( pstatus_tag(), pstatus_ents, num_ents, &pstatus_vals[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" );
    return MB_SUCCESS;
void moab::ParallelComm::set_rank ( unsigned int  r) [inline]
set rank for this pcomm; USED FOR TESTING ONLY!
Definition at line 1662 of file ParallelComm.hpp.
References moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), and procConfig.
Referenced by test_pack_shared_entities_2d(), and test_pack_shared_entities_3d().
    procConfig.proc_rank( r );
    if( procConfig.proc_size() < r ) procConfig.proc_size( r + 1 );
void moab::ParallelComm::set_recv_request ( int  n_request) [inline]
Definition at line 1702 of file ParallelComm.hpp.
References recvReqs.
    recvReqs.resize( n_request, MPI_REQUEST_NULL );
void moab::ParallelComm::set_send_request ( int  n_request) [inline]
Definition at line 1697 of file ParallelComm.hpp.
References sendReqs.
    sendReqs.resize( n_request, MPI_REQUEST_NULL );
ErrorCode moab::ParallelComm::set_sharing_data ( EntityHandle  ent,
unsigned char  pstatus,
int  old_nump,
int  new_nump,
int *  ps,
EntityHandle hs
) [private]
Definition at line 6422 of file ParallelComm.cpp.
References ErrorCode, MB_CHK_SET_ERR, mbImpl, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), rank(), sharedEnts, sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Interface::tag_delete_data(), and moab::Interface::tag_set_data().
Referenced by check_clean_iface(), and update_remote_data().
    // If new nump is less than 3, the entity is no longer mutishared
    if( old_nump > 2 && ( pstatus & PSTATUS_MULTISHARED ) && new_nump < 3 )
        // Unset multishared flag
        pstatus ^= PSTATUS_MULTISHARED;
    // Check for consistency in input data
    // DBG
    /*  bool con1 = ((new_nump == 2 && pstatus&PSTATUS_SHARED && !(pstatus&PSTATUS_MULTISHARED)) ||
      (new_nump > 2 && pstatus&PSTATUS_SHARED && pstatus&PSTATUS_MULTISHARED)); bool con2 =
      (!(pstatus&PSTATUS_GHOST) || pstatus&PSTATUS_SHARED); bool con3 = (new_nump < 3 ||
      (pstatus&PSTATUS_NOT_OWNED && ps[0] != (int)rank()) || (!(pstatus&PSTATUS_NOT_OWNED) && ps[0]
      == (int)rank())); std::cout<<"current rank = "<<rank()<<std::endl; std::cout<<"condition
      1::"<<con1<<std::endl; std::cout<<"condition 2::"<<con2<<std::endl; std::cout<<"condition
      3::"<<con3<<std::endl;*/
    // DBG
    assert( new_nump > 1 &&
            ( ( new_nump == 2 && pstatus & PSTATUS_SHARED &&
                !( pstatus & PSTATUS_MULTISHARED ) ) ||  // If <= 2 must not be multishared
              ( new_nump > 2 && pstatus & PSTATUS_SHARED &&
                pstatus & PSTATUS_MULTISHARED ) ) &&                         // If > 2 procs, must be multishared
            ( !( pstatus & PSTATUS_GHOST ) || pstatus & PSTATUS_SHARED ) &&  // If ghost, it must also be shared
            ( new_nump < 3 ||
              ( pstatus & PSTATUS_NOT_OWNED && ps[0] != (int)rank() ) ||      // I'm not owner and first proc not me
              ( !( pstatus & PSTATUS_NOT_OWNED ) && ps[0] == (int)rank() ) )  // I'm owner and first proc is me
#ifndef NDEBUG
        // Check for duplicates in proc list
        std::set< unsigned int > dumprocs;
        int dp = 0;
        for( ; dp < old_nump && -1 != ps[dp]; dp++ )
            dumprocs.insert( ps[dp] );
        assert( dp == (int)dumprocs.size() );
#endif
    ErrorCode result;
    // Reset any old data that needs to be
    if( old_nump > 2 && new_nump < 3 )
        // Need to remove multishared tags
        result = mbImpl->tag_delete_data( sharedps_tag(), &ent, 1 );MB_CHK_SET_ERR( result, "set_sharing_data:1" );
        result = mbImpl->tag_delete_data( sharedhs_tag(), &ent, 1 );MB_CHK_SET_ERR( result, "set_sharing_data:2" );
        //    if (new_nump < 2)
        //      pstatus = 0x0;
        //    else if (ps[0] != (int)proc_config().proc_rank())
        //      pstatus |= PSTATUS_NOT_OWNED;
    else if( ( old_nump < 3 && new_nump > 2 ) || ( old_nump > 1 && new_nump == 1 ) )
        // Reset sharedp and sharedh tags
        int tmp_p          = -1;
        EntityHandle tmp_h = 0;
        result             = mbImpl->tag_set_data( sharedp_tag(), &ent, 1, &tmp_p );MB_CHK_SET_ERR( result, "set_sharing_data:3" );
        result = mbImpl->tag_set_data( sharedh_tag(), &ent, 1, &tmp_h );MB_CHK_SET_ERR( result, "set_sharing_data:4" );
    assert( "check for multishared/owner I'm first proc" &&
            ( !( pstatus & PSTATUS_MULTISHARED ) || ( pstatus & ( PSTATUS_NOT_OWNED | PSTATUS_GHOST ) ) ||
              ( ps[0] == (int)rank() ) ) &&
            "interface entities should have > 1 proc" && ( !( pstatus & PSTATUS_INTERFACE ) || new_nump > 1 ) &&
            "ghost entities should have > 1 proc" && ( !( pstatus & PSTATUS_GHOST ) || new_nump > 1 ) );
    // Now set new data
    if( new_nump > 2 )
        result = mbImpl->tag_set_data( sharedps_tag(), &ent, 1, ps );MB_CHK_SET_ERR( result, "set_sharing_data:5" );
        result = mbImpl->tag_set_data( sharedhs_tag(), &ent, 1, hs );MB_CHK_SET_ERR( result, "set_sharing_data:6" );
    else
        unsigned int j = ( ps[0] == (int)procConfig.proc_rank() ? 1 : 0 );
        assert( -1 != ps[j] );
        result = mbImpl->tag_set_data( sharedp_tag(), &ent, 1, ps + j );MB_CHK_SET_ERR( result, "set_sharing_data:7" );
        result = mbImpl->tag_set_data( sharedh_tag(), &ent, 1, hs + j );MB_CHK_SET_ERR( result, "set_sharing_data:8" );
    result = mbImpl->tag_set_data( pstatus_tag(), &ent, 1, &pstatus );MB_CHK_SET_ERR( result, "set_sharing_data:9" );
    if( old_nump > 1 && new_nump < 2 ) sharedEnts.erase( ent );
    return result;
void moab::ParallelComm::set_size ( unsigned int  r) [inline]
Definition at line 1668 of file ParallelComm.hpp.
References moab::ProcConfig::proc_size(), and procConfig.
ErrorCode moab::ParallelComm::settle_intersection_points ( Range edges,
Range shared_edges_owned,
std::vector< std::vector< EntityHandle > * > &  extraNodesVec,
double  tolerance
Definition at line 9036 of file ParallelComm.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, buffProcs, moab::ParallelComm::Buffer::check_space(), moab::Range::end(), entities, ErrorCode, filter_pstatus(), moab::Range::find(), get_comm_procs(), moab::Interface::get_coords(), get_remote_handles(), moab::DebugOutput::get_verbosity(), INITIAL_BUFF_SIZE, localOwnedBuffs, MAX_SHARING_PROCS, MB_CHK_SET_ERR, moab::MB_MESG_TAGS_SIZE, MB_SET_ERR, MB_SUCCESS, mbImpl, myDebug, moab::PACK_EH(), moab::PACK_INT(), PRINT_DEBUG_IRECV, PRINT_DEBUG_RECD, PRINT_DEBUG_WAITANY, moab::ProcConfig::proc_comm(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_AND, PSTATUS_SHARED, recv_buffer(), remoteOwnedBuffs, reset_all_buffers(), moab::ParallelComm::Buffer::reset_ptr(), send_buffer(), sendReqs, moab::Interface::set_coords(), moab::ParallelComm::Buffer::set_stored_size(), moab::Range::size(), moab::DebugOutput::tprintf(), moab::UNPACK_DBLS(), moab::UNPACK_EH(), and moab::UNPACK_INT().
    // The index of an edge in the edges Range will give the index for extraNodesVec
    // the strategy of this follows exchange tags strategy:
    ErrorCode result;
    int success;
    myDebug->tprintf( 1, "Entering settle_intersection_points\n" );
    // Index requests the same as buffer/sharing procs indices
    std::vector< MPI_Request > recv_intx_reqs( 3 * buffProcs.size(), MPI_REQUEST_NULL );
    int ind;
    int incoming = 0;
        incoming++;
                             MB_MESG_TAGS_SIZE, procConfig.proc_comm(), &recv_intx_reqs[3 * ind] );
            MB_SET_ERR( MB_FAILURE, "Failed to post irecv in settle intersection point" );
    // Pack and send intersection points from this proc to others
    Range& entities = shared_edges_owned;
    int dum_ack_buff;
        Range edges_to_send = entities;
        result = filter_pstatus( edges_to_send, PSTATUS_SHARED, PSTATUS_AND, *sit );MB_CHK_SET_ERR( result, "Failed pstatus AND check" );
        // Remote nonowned entities; not needed, edges are already owned by this proc
        // Pack the data
        // Reserve space on front for size and for initial buff size
        Buffer* buff = localOwnedBuffs[ind];
        buff->reset_ptr( sizeof( int ) );
        /*result = pack_intx_points(edges_to_send, edges, extraNodesVec,
            localOwnedBuffs[ind], *sit);*/
        // Count first data, and see if it is enough room?
        // Send the remote handles
        std::vector< EntityHandle > dum_remote_edges( edges_to_send.size() );
         *  get_remote_handles(const bool store_remote_handles,
                                   EntityHandle *from_vec,
                                   EntityHandle *to_vec_tmp,
                                   int num_ents, int to_proc,
                                   const std::vector<EntityHandle> &new_ents);
        // We are sending count, num edges, remote edges handles, and then, for each edge:
        //          -- nb intx points, 3*nbintPointsforEdge "doubles"
        result = get_remote_handles( true, edges_to_send, &dum_remote_edges[0], *sit, dum_vec );MB_CHK_SET_ERR( result, "Failed to get remote handles" );
        int count = 4;  // Size of data
        count += sizeof( int ) * (int)edges_to_send.size();
        count += sizeof( EntityHandle ) * (int)edges_to_send.size();  // We will send the remote handles
        for( Range::iterator eit = edges_to_send.begin(); eit != edges_to_send.end(); ++eit )
            EntityHandle edge                       = *eit;
            unsigned int indx                       = edges.find( edge ) - edges.begin();
            std::vector< EntityHandle >& intx_nodes = *( extraNodesVec[indx] );
            count += (int)intx_nodes.size() * 3 * sizeof( double );  // 3 integer for each entity handle
        buff->check_space( count );
        PACK_INT( buff->buff_ptr, edges_to_send.size() );
        PACK_EH( buff->buff_ptr, &dum_remote_edges[0], dum_remote_edges.size() );
            // Pack the remote edge
            PACK_INT( buff->buff_ptr, intx_nodes.size() );
            result = mbImpl->get_coords( &intx_nodes[0], intx_nodes.size(), (double*)buff->buff_ptr );MB_CHK_SET_ERR( result, "Failed to get coords" );
            buff->buff_ptr += 3 * sizeof( double ) * intx_nodes.size();
        // Done packing the intx points and remote edges
        buff->set_stored_size();
        // Now send it
                              recv_intx_reqs[3 * ind + 2], &dum_ack_buff, incoming );MB_CHK_SET_ERR( result, "Failed to send buffer" );
    // Receive/unpack intx points
    while( incoming )
        MPI_Status status;
        PRINT_DEBUG_WAITANY( recv_intx_reqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank() );
        success = MPI_Waitany( 3 * buffProcs.size(), &recv_intx_reqs[0], &index_in_recv_requests, &status );
        incoming--;
        bool done = false;
                                 recv_intx_reqs[3 * ind + 1],  // This is for receiving the second message
                                 recv_intx_reqs[3 * ind + 2],  // This would be for ack, but it is not
        if( done )
            Buffer* buff = remoteOwnedBuffs[ind];
            /*result = unpack_tags(remoteOwnedBuffs[ind/2]->buff_ptr, dum_vec, true,
                buffProcs[ind/2]);*/
            // Unpack now the edges and vertex info; compare with the existing vertex positions
            int num_edges;
            UNPACK_INT( buff->buff_ptr, num_edges );
            std::vector< EntityHandle > rec_edges;
            rec_edges.resize( num_edges );
            UNPACK_EH( buff->buff_ptr, &rec_edges[0], num_edges );
            for( int i = 0; i < num_edges; i++ )
                EntityHandle edge                       = rec_edges[i];
                // Now get the number of nodes on this (now local) edge
                int nverts;
                UNPACK_INT( buff->buff_ptr, nverts );
                std::vector< double > pos_from_owner;
                pos_from_owner.resize( 3 * nverts );
                UNPACK_DBLS( buff->buff_ptr, &pos_from_owner[0], 3 * nverts );
                std::vector< double > current_positions( 3 * intx_nodes.size() );
                result = mbImpl->get_coords( &intx_nodes[0], intx_nodes.size(), &current_positions[0] );MB_CHK_SET_ERR( result, "Failed to get current positions" );
                // Now, look at what we have in current pos, compare to pos from owner, and reset
                for( int k = 0; k < (int)intx_nodes.size(); k++ )
                    double* pk = &current_positions[3 * k];
                    // Take the current pos k, and settle among the ones from owner:
                    bool found = false;
                    for( int j = 0; j < nverts && !found; j++ )
                        double* pj   = &pos_from_owner[3 * j];
                        double dist2 = ( pk[0] - pj[0] ) * ( pk[0] - pj[0] ) + ( pk[1] - pj[1] ) * ( pk[1] - pj[1] ) +
                                       ( pk[2] - pj[2] ) * ( pk[2] - pj[2] );
                        if( dist2 < tolerance )
                            pk[0] = pj[0];
                            pk[1] = pj[1];
                            pk[2] = pj[2];  // Correct it!
                            found = true;
                            break;
                    if( !found )
#ifndef NDEBUG
                        std::cout << " pk:" << pk[0] << " " << pk[1] << " " << pk[2] << " not found \n";
#endif
                // After we are done resetting, we can set the new positions of nodes:
                result = mbImpl->set_coords( &intx_nodes[0], (int)intx_nodes.size(), &current_positions[0] );MB_CHK_SET_ERR( result, "Failed to set new current positions" );
    // OK, now wait
    if( myDebug->get_verbosity() == 5 )
        success = MPI_Barrier( procConfig.proc_comm() );
    else
        MPI_Status status[3 * MAX_SHARING_PROCS];
        success = MPI_Waitall( 3 * buffProcs.size(), &sendReqs[0], status );
        MB_SET_ERR( MB_FAILURE, "Failure in waitall in tag exchange" );
    myDebug->tprintf( 1, "Exiting settle_intersection_points" );
    return MB_SUCCESS;
Set pstatus tag interface bit on entities in sets passed in.
Definition at line 4360 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), moab::Range::insert(), interfaceSets, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, pstatus_tag(), moab::Interface::remove_entities(), moab::Range::size(), moab::subtract(), moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by exchange_ghost_cells().
    Range iface_ents, tmp_ents, rmv_ents;
    std::vector< unsigned char > pstat;
    unsigned char set_pstat;
    Range::iterator rit2;
    unsigned int i;
    for( Range::iterator rit = interfaceSets.begin(); rit != interfaceSets.end(); ++rit )
        iface_ents.clear();
        result = mbImpl->get_entities_by_handle( *rit, iface_ents );MB_CHK_SET_ERR( result, "Failed to get interface set contents" );
        pstat.resize( iface_ents.size() );
        result = mbImpl->tag_get_data( pstatus_tag(), iface_ents, &pstat[0] );MB_CHK_SET_ERR( result, "Failed to get pstatus values for interface set entities" );
        result = mbImpl->tag_get_data( pstatus_tag(), &( *rit ), 1, &set_pstat );MB_CHK_SET_ERR( result, "Failed to get pstatus values for interface set" );
        rmv_ents.clear();
        for( rit2 = iface_ents.begin(), i = 0; rit2 != iface_ents.end(); ++rit2, i++ )
            if( !( pstat[i] & PSTATUS_INTERFACE ) )
                rmv_ents.insert( *rit2 );
                pstat[i] = 0x0;
        result = mbImpl->remove_entities( *rit, rmv_ents );MB_CHK_SET_ERR( result, "Failed to remove entities from interface set" );
        if( !( set_pstat & PSTATUS_NOT_OWNED ) ) continue;
        // If we're here, we need to set the notowned status on (remaining) set contents
        // Remove rmv_ents from the contents list
        iface_ents = subtract( iface_ents, rmv_ents );
        // Compress the pstat vector (removing 0x0's)
        std::remove_if( pstat.begin(), pstat.end(),
                        std::bind( std::equal_to< unsigned char >(), std::placeholders::_1, 0x0 ) );
        // std::bind2nd(std::equal_to<unsigned char>(), 0x0));
        // https://stackoverflow.com/questions/32739018/a-replacement-for-stdbind2nd
        // Fold the not_owned bit into remaining values
        unsigned int sz = iface_ents.size();
        for( i = 0; i < sz; i++ )
            pstat[i] |= PSTATUS_NOT_OWNED;
        // Set the tag on the entities
        result = mbImpl->tag_set_data( pstatus_tag(), iface_ents, &pstat[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus values for interface set entities" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::tag_shared_verts ( TupleList shared_ents,
std::map< std::vector< int >, std::vector< EntityHandle > > &  proc_nvecs,
Range proc_verts,
unsigned int  i_extra = 1
Definition at line 5219 of file ParallelComm.cpp.
References ErrorCode, moab::TupleList::get_n(), get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_SHARED, sharedEnts, moab::Interface::tag_set_data(), moab::TupleList::vi_rd, and moab::TupleList::vul_rd.
Referenced by resolve_shared_ents(), moab::ScdInterface::tag_shared_vertices(), and moab::ParallelMergeMesh::TagSharedElements().
    ErrorCode result = get_shared_proc_tags( shp_tag, shps_tag, shh_tag, shhs_tag, pstat_tag );MB_CHK_SET_ERR( result, "Failed to get shared proc tags in tag_shared_verts" );
    unsigned int j = 0, i = 0;
    std::vector< int > sharing_procs, sharing_procs2, tag_procs;
    std::vector< EntityHandle > sharing_handles, sharing_handles2, tag_lhandles, tag_rhandles;
    std::vector< unsigned char > pstatus;
    // Were on tuple j/2
    if( i_extra ) i += i_extra;
    while( j < 2 * shared_ents.get_n() )
        EntityHandle this_ent = shared_ents.vul_rd[j], other_ent = 0;
        int other_proc = -1;
        while( j < 2 * shared_ents.get_n() && shared_ents.vul_rd[j] == this_ent )
            j++;
            // Shouldn't have same proc
            assert( shared_ents.vi_rd[i] != (int)procConfig.proc_rank() );
            // Grab the remote data if its not a dublicate
            if( shared_ents.vul_rd[j] != other_ent || shared_ents.vi_rd[i] != other_proc )
                assert( 0 != shared_ents.vul_rd[j] );
                sharing_procs.push_back( shared_ents.vi_rd[i] );
                sharing_handles.push_back( shared_ents.vul_rd[j] );
            other_proc = shared_ents.vi_rd[i];
            other_ent  = shared_ents.vul_rd[j];
            j++;
            i += 1 + i_extra;
        if( sharing_procs.size() > 1 )
            // Add current proc/handle to list
            sharing_procs.push_back( procConfig.proc_rank() );
            sharing_handles.push_back( this_ent );
            // Sort sharing_procs and sharing_handles such that
            // sharing_procs is in ascending order. Use temporary
            // lists and binary search to re-order sharing_handles.
            sharing_procs2 = sharing_procs;
            std::sort( sharing_procs2.begin(), sharing_procs2.end() );
            sharing_handles2.resize( sharing_handles.size() );
            for( size_t k = 0; k < sharing_handles.size(); k++ )
                size_t idx = std::lower_bound( sharing_procs2.begin(), sharing_procs2.end(), sharing_procs[k] ) -
                             sharing_procs2.begin();
                sharing_handles2[idx] = sharing_handles[k];
            sharing_procs.swap( sharing_procs2 );
            sharing_handles.swap( sharing_handles2 );
        assert( sharing_procs.size() != 2 );
        proc_nvecs[sharing_procs].push_back( this_ent );
        unsigned char share_flag = PSTATUS_SHARED, ms_flag = ( PSTATUS_SHARED | PSTATUS_MULTISHARED );
        if( sharing_procs.size() == 1 )
            tag_procs.push_back( sharing_procs[0] );
            tag_lhandles.push_back( this_ent );
            tag_rhandles.push_back( sharing_handles[0] );
            pstatus.push_back( share_flag );
        else
            // Pad lists
            // assert(sharing_procs.size() <= MAX_SHARING_PROCS);
            if( sharing_procs.size() > MAX_SHARING_PROCS )
                std::cerr << "MAX_SHARING_PROCS exceeded for vertex " << this_ent << " on process "
                          << proc_config().proc_rank() << std::endl;
                std::cerr.flush();
                MPI_Abort( proc_config().proc_comm(), 66 );
            sharing_procs.resize( MAX_SHARING_PROCS, -1 );
            sharing_handles.resize( MAX_SHARING_PROCS, 0 );
            result = mbImpl->tag_set_data( shps_tag, &this_ent, 1, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to set sharedps tag on shared vertex" );
            result = mbImpl->tag_set_data( shhs_tag, &this_ent, 1, &sharing_handles[0] );MB_CHK_SET_ERR( result, "Failed to set sharedhs tag on shared vertex" );
            result = mbImpl->tag_set_data( pstat_tag, &this_ent, 1, &ms_flag );MB_CHK_SET_ERR( result, "Failed to set pstatus tag on shared vertex" );
            sharedEnts.insert( this_ent );
        // Reset sharing proc(s) tags
        sharing_procs.clear();
        sharing_handles.clear();
    if( !tag_procs.empty() )
        result = mbImpl->tag_set_data( shp_tag, &tag_lhandles[0], tag_procs.size(), &tag_procs[0] );MB_CHK_SET_ERR( result, "Failed to set sharedp tag on shared vertex" );
        result = mbImpl->tag_set_data( shh_tag, &tag_lhandles[0], tag_procs.size(), &tag_rhandles[0] );MB_CHK_SET_ERR( result, "Failed to set sharedh tag on shared vertex" );
        result = mbImpl->tag_set_data( pstat_tag, &tag_lhandles[0], tag_procs.size(), &pstatus[0] );MB_CHK_SET_ERR( result, "Failed to set pstatus tag on shared vertex" );
        for( std::vector< EntityHandle >::iterator vvt = tag_lhandles.begin(); vvt != tag_lhandles.end(); vvt++ )
            sharedEnts.insert( *vvt );
#ifndef NDEBUG
    // Shouldn't be any repeated entities in any of the vectors in proc_nvecs
    for( std::map< std::vector< int >, std::vector< EntityHandle > >::iterator mit = proc_nvecs.begin();
        std::vector< EntityHandle > tmp_vec = ( mit->second );
        std::sort( tmp_vec.begin(), tmp_vec.end() );
        std::vector< EntityHandle >::iterator vit = std::unique( tmp_vec.begin(), tmp_vec.end() );
        assert( vit == tmp_vec.end() );
#endif
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::tag_shared_verts ( TupleList shared_verts,
Range skin_ents,
Range proc_verts
) [private]
Definition at line 5338 of file ParallelComm.cpp.
References moab::Range::end(), ErrorCode, moab::TupleList::get_n(), get_shared_proc_tags(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_MULTISHARED, PSTATUS_SHARED, sharedEnts, size(), moab::Interface::tag_set_data(), moab::TupleList::vi_rd, and moab::TupleList::vul_rd.
    std::vector< int > sharing_procs, sharing_procs2;
    std::vector< EntityHandle > sharing_handles, sharing_handles2, skin_verts( skin_ents[0].size() );
    for( Range::iterator rit = skin_ents[0].begin(); rit != skin_ents[0].end(); ++rit, i++ )
        skin_verts[i] = *rit;
    i = 0;
        int this_idx          = shared_ents.vi_rd[j];
        EntityHandle this_ent = skin_verts[this_idx];
        while( j < 2 * shared_ents.get_n() && shared_ents.vi_rd[j] == this_idx )
            j++;
            assert( shared_ents.vi_rd[j] != (int)procConfig.proc_rank() );
            sharing_procs.push_back( shared_ents.vi_rd[j++] );
            sharing_handles.push_back( shared_ents.vul_rd[i++] );
            result = mbImpl->tag_set_data( shp_tag, &this_ent, 1, &sharing_procs[0] );MB_CHK_SET_ERR( result, "Failed to set sharedp tag on shared vertex" );
            result = mbImpl->tag_set_data( shh_tag, &this_ent, 1, &sharing_handles[0] );MB_CHK_SET_ERR( result, "Failed to set sharedh tag on shared vertex" );
            result = mbImpl->tag_set_data( pstat_tag, &this_ent, 1, &share_flag );MB_CHK_SET_ERR( result, "Failed to set pstatus tag on shared vertex" );
        else
            // Pad lists
                std::cerr.flush();
#ifndef NDEBUG
#endif
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::unpack_adjacencies ( unsigned char *&  buff_ptr,
Range entities,
const bool  store_handles,
const int  from_proc
) [private]
Definition at line 3462 of file ParallelComm.cpp.
    return MB_FAILURE;
ErrorCode moab::ParallelComm::unpack_buffer ( unsigned char *  buff_ptr,
const int  ind,
std::vector< std::vector< EntityHandle > > &  L1hloc,
std::vector< std::vector< EntityHandle > > &  L1hrem,
std::vector< std::vector< int > > &  L1p,
std::vector< EntityHandle > &  L2hloc,
std::vector< EntityHandle > &  L2hrem,
std::vector< unsigned int > &  L2p,
std::vector< EntityHandle > &  new_ents,
const bool  created_iface = false
Definition at line 1463 of file ParallelComm.cpp.
References ErrorCode, moab::DebugOutput::get_verbosity(), MB_CHK_SET_ERR, MB_SUCCESS, myDebug, moab::DebugOutput::print(), moab::DebugOutput::tprintf(), unpack_entities(), unpack_sets(), and unpack_tags().
Referenced by broadcast_entities(), exchange_owned_mesh(), pack_unpack_noremoteh(), moab::ParCommGraph::receive_mesh(), recv_entities(), recv_messages(), scatter_entities(), and test_packing().
    unsigned char* tmp_buff = buff_ptr;
    ErrorCode result;
    result = unpack_entities( buff_ptr, store_remote_handles, ind, false, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p,
                              new_ents, created_iface );MB_CHK_SET_ERR( result, "Unpacking entities failed" );
    if( myDebug->get_verbosity() == 3 )
        myDebug->tprintf( 4, "unpack_entities buffer space: %ld bytes.\n", (long int)( buff_ptr - tmp_buff ) );
    result = unpack_sets( buff_ptr, new_ents, store_remote_handles, from_proc );MB_CHK_SET_ERR( result, "Unpacking sets failed" );
        myDebug->tprintf( 4, "unpack_sets buffer space: %ld bytes.\n", (long int)( buff_ptr - tmp_buff ) );
    result = unpack_tags( buff_ptr, new_ents, store_remote_handles, from_proc );MB_CHK_SET_ERR( result, "Unpacking tags failed" );
        myDebug->tprintf( 4, "unpack_tags buffer space: %ld bytes.\n", (long int)( buff_ptr - tmp_buff ) );
        // tmp_buff = buff_ptr;
    if( myDebug->get_verbosity() == 3 ) myDebug->print( 4, "\n" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::unpack_entities ( unsigned char *&  buff_ptr,
const int  from_ind,
const bool  is_iface,
unpack entities in buff_ptr
Definition at line 2068 of file ParallelComm.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertex(), moab::CN::EntityTypeName(), ErrorCode, find_existing_entity(), get_buffers(), get_local_handles(), moab::CN::MAX_NODES_PER_ELEMENT, MAX_NODES_PER_ELEMENT, MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SUCCESS, MBENTITYSET, mbImpl, MBMAXTYPE, MBVERTEX, myDebug, moab::ProcConfig::proc_rank(), procConfig, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, moab::Interface::query_interface(), rank(), swap(), moab::DebugOutput::tprintf(), moab::UNPACK_DBLS(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), moab::UNPACK_TYPE(), moab::ReadUtilIface::update_adjacencies(), and update_remote_data().
Referenced by exchange_ghost_cells(), and unpack_buffer().
    // General algorithm:
    // - unpack # entities
    // - save start of remote handle info, then scan forward to entity definition data
    // - for all vertices or entities w/ same # verts:
    //   . get entity type, num ents, and (if !vert) # verts
    //   . for each ent:
    //      o get # procs/handles in remote handle info
    //      o if # procs/handles > 2, check for already-created entity:
    //        x get index of owner proc (1st in proc list), resize L1 list if nec
    //        x look for already-arrived entity in L2 by owner handle
    //      o if no existing entity:
    //        x if iface, look for existing entity with same connect & type
    //        x if none found, create vertex or element
    //        x if !iface & multi-shared, save on L2
    //        x if !iface, put new entity on new_ents list
    //      o update proc/handle, pstatus tags, adjusting to put owner first if iface
    //      o if !iface, save new handle on L1 for all sharing procs
    // Lists of handles/procs to return to sending/other procs
    // L1hloc[p], L1hrem[p]: handle pairs [h, h'], where h is the local proc handle
    //         and h' is either the remote proc handle (if that is known) or
    //         the owner proc handle (otherwise);
    // L1p[p]: indicates whether h is remote handle (= -1) or owner (rank of owner)
    // L2hloc, L2hrem: local/remote handles for entities shared by > 2 procs;
    //         remote handles are on owning proc
    // L2p: owning procs for handles in L2hrem
    ErrorCode result;
    bool done         = false;
    ReadUtilIface* ru = NULL;
    result = mbImpl->query_interface( ru );MB_CHK_SET_ERR( result, "Failed to get ReadUtilIface" );
    // 1. # entities = E
    int num_ents             = 0;
    unsigned char* buff_save = buff_ptr;
    int i, j;
    if( store_remote_handles )
        UNPACK_INT( buff_ptr, num_ents );
        // Save place where remote handle info starts, then scan forward to ents
        for( i = 0; i < num_ents; i++ )
            UNPACK_INT( buff_ptr, j );
            if( j < 0 )
                std::cout << "Should be non-negative # proc/handles.";
                return MB_FAILURE;
            buff_ptr += j * ( sizeof( int ) + sizeof( EntityHandle ) );
    std::vector< EntityHandle > msg_ents;
    while( !done )
        EntityType this_type = MBMAXTYPE;
        UNPACK_TYPE( buff_ptr, this_type );
        assert( this_type != MBENTITYSET );
        // MBMAXTYPE signifies end of entities data
        if( MBMAXTYPE == this_type ) break;
        // Get the number of ents
        int num_ents2, verts_per_entity = 0;
        UNPACK_INT( buff_ptr, num_ents2 );
        // Unpack the nodes per entity
        if( MBVERTEX != this_type && num_ents2 )
            UNPACK_INT( buff_ptr, verts_per_entity );
        std::vector< int > ps( MAX_SHARING_PROCS, -1 );
        std::vector< EntityHandle > hs( MAX_SHARING_PROCS, 0 );
        for( int e = 0; e < num_ents2; e++ )
            // Check for existing entity, otherwise make new one
            EntityHandle new_h = 0;
            EntityHandle connect[CN::MAX_NODES_PER_ELEMENT];
            double coords[3];
            int num_ps = -1;
            // Unpack all the data at once, to make sure the buffer pointers
            // are tracked correctly
                // Pointers to other procs/handles
                UNPACK_INT( buff_save, num_ps );
                if( 0 >= num_ps )
                    std::cout << "Shouldn't ever be fewer than 1 procs here." << std::endl;
                    return MB_FAILURE;
                UNPACK_INTS( buff_save, &ps[0], num_ps );
                UNPACK_EH( buff_save, &hs[0], num_ps );
            if( MBVERTEX == this_type )
                UNPACK_DBLS( buff_ptr, coords, 3 );
            else
                assert( verts_per_entity <= CN::MAX_NODES_PER_ELEMENT );
                UNPACK_EH( buff_ptr, connect, verts_per_entity );
                // Update connectivity to local handles
                result = get_local_handles( connect, verts_per_entity, msg_ents );MB_CHK_SET_ERR( result, "Failed to get local handles" );
            // Now, process that data; begin by finding an identical
            // entity, if there is one
                result = find_existing_entity( is_iface, ps[0], hs[0], num_ps, connect, verts_per_entity, this_type,
                                               L2hloc, L2hrem, L2p, new_h );MB_CHK_SET_ERR( result, "Failed to get existing entity" );
            // If we didn't find one, we'll have to create one
            bool created_here = false;
            if( !new_h && !is_iface )
                    // Create a vertex
                    result = mbImpl->create_vertex( coords, new_h );MB_CHK_SET_ERR( result, "Failed to make new vertex" );
                else
                    // Create the element
                    result = mbImpl->create_element( this_type, connect, verts_per_entity, new_h );MB_CHK_SET_ERR( result, "Failed to make new element" );
                    // Update adjacencies
                    result = ru->update_adjacencies( new_h, 1, verts_per_entity, connect );MB_CHK_SET_ERR( result, "Failed to update adjacencies" );
                // Should have a new handle now
                assert( new_h );
                created_here = true;
            // Take care of sharing data
            // Need to save entities found in order, for interpretation of
            // later parts of this message
            if( !is_iface )
                assert( new_h );
                msg_ents.push_back( new_h );
            if( created_here ) new_ents.push_back( new_h );
            if( new_h && store_remote_handles )
                unsigned char new_pstat = 0x0;
                if( is_iface )
                    new_pstat = PSTATUS_INTERFACE;
                    // Here, lowest rank proc should be first
                    int idx = std::min_element( &ps[0], &ps[0] + num_ps ) - &ps[0];
                    if( idx )
                        std::swap( ps[0], ps[idx] );
                        std::swap( hs[0], hs[idx] );
                    // Set ownership based on lowest rank; can't be in update_remote_data, because
                    // there we don't know whether it resulted from ghosting or not
                    if( ( num_ps > 1 && ps[0] != (int)rank() ) ) new_pstat |= PSTATUS_NOT_OWNED;
                else if( created_here )
                    if( created_iface )
                        new_pstat = PSTATUS_NOT_OWNED;
                    else
                        new_pstat = PSTATUS_GHOST | PSTATUS_NOT_OWNED;
                // Update sharing data and pstatus, adjusting order if iface
                result = update_remote_data( new_h, &ps[0], &hs[0], num_ps, new_pstat );MB_CHK_SET_ERR( result, "unpack_entities" );
                // If a new multi-shared entity, save owner for subsequent lookup in L2 lists
                if( store_remote_handles && !is_iface && num_ps > 2 )
                    L2hrem.push_back( hs[0] );
                    L2hloc.push_back( new_h );
                    L2p.push_back( ps[0] );
                // Need to send this new handle to all sharing procs
                if( !is_iface )
                    for( j = 0; j < num_ps; j++ )
                        if( ps[j] == (int)procConfig.proc_rank() ) continue;
                        int idx = get_buffers( ps[j] );
                        if( idx == (int)L1hloc.size() )
                            L1hloc.resize( idx + 1 );
                            L1hrem.resize( idx + 1 );
                            L1p.resize( idx + 1 );
                        // Don't bother adding if it's already in the list
                            std::find( L1hloc[idx].begin(), L1hloc[idx].end(), new_h );
                        if( vit != L1hloc[idx].end() )
                            // If it's in the list but remote handle isn't known but we know
                            // it, replace in the list
                            if( L1p[idx][vit - L1hloc[idx].begin()] != -1 && hs[j] )
                                L1hrem[idx][vit - L1hloc[idx].begin()] = hs[j];
                                L1p[idx][vit - L1hloc[idx].begin()]    = -1;
                            else
                                continue;
                        else
                            if( !hs[j] )
                                assert( -1 != ps[0] && num_ps > 2 );
                                L1p[idx].push_back( ps[0] );
                                L1hrem[idx].push_back( hs[0] );
                            else
                                assert(
                                    "either this remote handle isn't in the remote list, or "
                                    "it's for another proc" &&
                                    ( std::find( L1hrem[idx].begin(), L1hrem[idx].end(), hs[j] ) == L1hrem[idx].end() ||
                                      L1p[idx][std::find( L1hrem[idx].begin(), L1hrem[idx].end(), hs[j] ) -
                                               L1hrem[idx].begin()] != -1 ) );
                                L1p[idx].push_back( -1 );
                                L1hrem[idx].push_back( hs[j] );
                            L1hloc[idx].push_back( new_h );
                assert( "Shouldn't be here for non-shared entities" && -1 != num_ps );
                std::fill( &ps[0], &ps[num_ps], -1 );
                std::fill( &hs[0], &hs[num_ps], 0 );
        myDebug->tprintf( 4, "Unpacked %d ents of type %s", num_ents2, CN::EntityTypeName( this_type ) );
    myDebug->tprintf( 4, "Done unpacking entities.\n" );
    // Need to sort here, to enable searching
    std::sort( new_ents.begin(), new_ents.end() );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::unpack_iface_entities ( unsigned char *&  buff_ptr,
const int  ind,
std::vector< EntityHandle > &  recd_ents
) [private]
for all the entities in the received buffer; for each, save entities in this instance which match connectivity, or zero if none found
ErrorCode moab::ParallelComm::unpack_remote_handles ( unsigned int  from_proc,
Definition at line 7395 of file ParallelComm.cpp.
References ErrorCode, find_existing_entity(), MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, moab::Interface::type_from_handle(), moab::UNPACK_EH(), moab::UNPACK_INT(), and update_remote_data().
Referenced by exchange_ghost_cells(), exchange_owned_mesh(), recv_entities(), recv_remote_handle_messages(), and unpack_remote_handles().
    // Incoming remote handles; use to set remote handles
    int num_eh;
    UNPACK_INT( buff_ptr, num_eh );
    unsigned char* buff_proc = buff_ptr;
    buff_ptr += num_eh * sizeof( int );
    unsigned char* buff_rem = buff_ptr + num_eh * sizeof( EntityHandle );
    ErrorCode result;
    EntityHandle hpair[2], new_h;
    int proc;
    for( int i = 0; i < num_eh; i++ )
        UNPACK_INT( buff_proc, proc );
        // Handles packed (local, remote), though here local is either on this
        // proc or owner proc, depending on value of proc (-1 = here, otherwise owner);
        // this is decoded in find_existing_entity
        UNPACK_EH( buff_ptr, hpair, 1 );
        UNPACK_EH( buff_rem, hpair + 1, 1 );
        if( -1 != proc )
            result = find_existing_entity( false, proc, hpair[0], 3, NULL, 0, mbImpl->type_from_handle( hpair[1] ),
                                           L2hloc, L2hrem, L2p, new_h );MB_CHK_SET_ERR( result, "Didn't get existing entity" );
            if( new_h )
                hpair[0] = new_h;
            else
                hpair[0] = 0;
        if( !( hpair[0] && hpair[1] ) ) return MB_FAILURE;
        int this_proc = from_proc;
        result        = update_remote_data( hpair[0], &this_proc, hpair + 1, 1, 0 );MB_CHK_SET_ERR( result, "Failed to set remote data range on sent entities in ghost exchange" );
    return MB_SUCCESS;
const unsigned char *  buff_ptr,
) [inline, private]
Definition at line 1651 of file ParallelComm.hpp.
References unpack_remote_handles().
    // cast away const-ness, we won't be passing back a modified ptr
    unsigned char* tmp_buff = const_cast< unsigned char* >( buff_ptr );
    return unpack_remote_handles( from_proc, tmp_buff, L2hloc, L2hrem, L2p );
ErrorCode moab::ParallelComm::unpack_sets ( unsigned char *&  buff_ptr,
std::vector< EntityHandle > &  entities,
const int  to_proc
) [private]
Definition at line 3310 of file ParallelComm.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_entities(), moab::Interface::add_parent_meshset(), moab::Range::begin(), moab::Interface::create_meshset(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), get_local_handles(), moab::Range::insert(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, mbImpl, myDebug, moab::Range::rbegin(), moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), moab::Interface::type_from_handle(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), moab::UNPACK_RANGE(), moab::UNPACK_VOID(), and update_remote_data().
Referenced by unpack_buffer().
    // Now the sets; assume any sets the application wants to pass are in the entities list
    ErrorCode result;
    bool no_sets = ( entities.empty() || ( mbImpl->type_from_handle( *entities.rbegin() ) == MBENTITYSET ) );
    Range new_sets;
    int num_sets;
    UNPACK_INT( buff_ptr, num_sets );
    if( !num_sets ) return MB_SUCCESS;
    int i;
    Range::const_iterator rit;
    std::vector< EntityHandle > members;
    int num_ents;
    std::vector< unsigned int > options_vec( num_sets );
    // Option value
    if( num_sets ) UNPACK_VOID( buff_ptr, &options_vec[0], num_sets * sizeof( unsigned int ) );
    // Unpack parallel geometry unique id
    int n_uid;
    UNPACK_INT( buff_ptr, n_uid );
    if( n_uid > 0 && n_uid != num_sets )
        std::cerr << "The number of Parallel geometry unique ids should be same." << std::endl;
    if( n_uid > 0 )
    {  // If parallel geometry unique id is packed
        std::vector< int > uids( n_uid );
        UNPACK_INTS( buff_ptr, &uids[0], n_uid );
        Tag uid_tag;
        result =
            mbImpl->tag_get_handle( "PARALLEL_UNIQUE_ID", 1, MB_TYPE_INTEGER, uid_tag, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( result, "Failed to create parallel geometry unique id tag" );
        // Find existing sets
        for( i = 0; i < n_uid; i++ )
            EntityHandle set_handle;
            Range temp_sets;
            void* tag_vals[] = { &uids[i] };
            if( uids[i] > 0 )
                result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &uid_tag, tag_vals, 1, temp_sets );
            if( !temp_sets.empty() )
            {  // Existing set
                set_handle = *temp_sets.begin();
            else
            {  // Create a new set
                result = mbImpl->create_meshset( options_vec[i], set_handle );MB_CHK_SET_ERR( result, "Failed to create set in unpack" );
                result = mbImpl->tag_set_data( uid_tag, &set_handle, 1, &uids[i] );MB_CHK_SET_ERR( result, "Failed to set parallel geometry unique ids" );
            new_sets.insert( set_handle );
    else
        // Create sets
        for( i = 0; i < num_sets; i++ )
            // Make sure new sets handles are monotonically increasing
            assert( set_handle > *new_sets.rbegin() );
    std::copy( new_sets.begin(), new_sets.end(), std::back_inserter( entities ) );
    // Only need to sort if we came in with no sets on the end
    if( !no_sets ) std::sort( entities.begin(), entities.end() );
    for( rit = new_sets.begin(), i = 0; rit != new_sets.end(); ++rit, i++ )
        // Unpack entities as vector, with length
        members.resize( num_ents );
        if( num_ents ) UNPACK_EH( buff_ptr, &members[0], num_ents );
        result = get_local_handles( &members[0], num_ents, entities );MB_CHK_SET_ERR( result, "Failed to get local handles for ordered set contents" );
        result = mbImpl->add_entities( *rit, &members[0], num_ents );MB_CHK_SET_ERR( result, "Failed to add ents to ordered set in unpack" );
    std::vector< int > num_pch( 2 * new_sets.size() );
    std::vector< int >::iterator vit;
    int tot_pch = 0;
    for( vit = num_pch.begin(); vit != num_pch.end(); ++vit )
        UNPACK_INT( buff_ptr, *vit );
        tot_pch += *vit;
    members.resize( tot_pch );
    UNPACK_EH( buff_ptr, &members[0], tot_pch );
    result = get_local_handles( &members[0], tot_pch, entities );MB_CHK_SET_ERR( result, "Failed to get local handle for parent/child sets" );
    int num               = 0;
    EntityHandle* mem_ptr = &members[0];
    for( rit = new_sets.begin(); rit != new_sets.end(); ++rit )
        // Unpack parents/children
        int num_par = num_pch[num++], num_child = num_pch[num++];
        if( num_par + num_child )
            for( i = 0; i < num_par; i++ )
                assert( 0 != mem_ptr[i] );
                result = mbImpl->add_parent_meshset( *rit, mem_ptr[i] );MB_CHK_SET_ERR( result, "Failed to add parent to set in unpack" );
            mem_ptr += num_par;
            for( i = 0; i < num_child; i++ )
                result = mbImpl->add_child_meshset( *rit, mem_ptr[i] );MB_CHK_SET_ERR( result, "Failed to add child to set in unpack" );
            mem_ptr += num_child;
    // Unpack source handles
    Range dum_range;
    if( store_remote_handles && !new_sets.empty() )
        UNPACK_RANGE( buff_ptr, dum_range );
        result = update_remote_data( new_sets, dum_range, from_proc, 0 );MB_CHK_SET_ERR( result, "Failed to set sharing data for sets" );
    myDebug->tprintf( 4, "Done unpacking sets." );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::unpack_tags ( unsigned char *&  buff_ptr,
const int  to_proc,
const MPI_Op *const  mpi_op = NULL
) [private]
Definition at line 3679 of file ParallelComm.cpp.
References ErrorCode, get_local_handles(), MB_CHK_SET_ERR, MB_SUCCESS, MB_TAG_BYTES, MB_TAG_CREAT, MB_TAG_VARLEN, MB_TYPE_HANDLE, MB_VARIABLE_LENGTH, mbImpl, myDebug, reduce_void(), moab::TagInfo::size_from_data_type(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_set_by_ptr(), moab::Interface::tag_set_data(), moab::DebugOutput::tprintf(), moab::UNPACK_EH(), moab::UNPACK_INT(), moab::UNPACK_INTS(), and UPC.
Referenced by exchange_tags(), reduce_tags(), and unpack_buffer().
    // Tags
    // Get all the tags
    // For dense tags, compute size assuming all entities have that tag
    // For sparse tags, get number of entities w/ that tag to compute size
    ErrorCode result;
    int num_tags;
    UNPACK_INT( buff_ptr, num_tags );
    std::vector< const void* > var_len_vals;
    std::vector< unsigned char > dum_vals;
    std::vector< EntityHandle > dum_ehvals;
    for( int i = 0; i < num_tags; i++ )
        // Tag handle
        Tag tag_handle;
        // Size, data type
        int tag_size, tag_data_type, tag_type;
        UNPACK_INT( buff_ptr, tag_size );
        UNPACK_INT( buff_ptr, tag_type );
        UNPACK_INT( buff_ptr, tag_data_type );
        // Default value
        int def_val_size;
        UNPACK_INT( buff_ptr, def_val_size );
        void* def_val_ptr = NULL;
        if( def_val_size )
            def_val_ptr = buff_ptr;
            buff_ptr += def_val_size;
            UPC( tag_size, " void" );
        // Name
        int name_len;
        UNPACK_INT( buff_ptr, name_len );
        std::string tag_name( reinterpret_cast< char* >( buff_ptr ), name_len );
        buff_ptr += name_len;
        UPC( 64, " chars" );
        myDebug->tprintf( 4, "Unpacking tag %s\n", tag_name.c_str() );
        // Create the tag
        if( tag_size == MB_VARIABLE_LENGTH )
            result = mbImpl->tag_get_handle( tag_name.c_str(), def_val_size, (DataType)tag_data_type, tag_handle,
                                             MB_TAG_VARLEN | MB_TAG_CREAT | MB_TAG_BYTES | tag_type, def_val_ptr );
        else
            result = mbImpl->tag_get_handle( tag_name.c_str(), tag_size, (DataType)tag_data_type, tag_handle,
        if( MB_SUCCESS != result ) return result;
        // Get handles and convert to local handles
        int num_ents;
        std::vector< EntityHandle > dum_ents( num_ents );
        UNPACK_EH( buff_ptr, &dum_ents[0], num_ents );
        // In this case handles are indices into new entity range; need to convert
        // to local handles
        result = get_local_handles( &dum_ents[0], num_ents, entities );MB_CHK_SET_ERR( result, "Unable to convert to local handles" );
        // If it's a handle type, also convert tag vals in-place in buffer
        if( MB_TYPE_HANDLE == tag_type )
            dum_ehvals.resize( num_ents );
            UNPACK_EH( buff_ptr, &dum_ehvals[0], num_ents );
            result = get_local_handles( &dum_ehvals[0], num_ents, entities );MB_CHK_SET_ERR( result, "Failed to get local handles for tag vals" );
        DataType data_type;
        mbImpl->tag_get_data_type( tag_handle, data_type );
        int type_size = TagInfo::size_from_data_type( data_type );
        if( !dum_ents.empty() )
                // Be careful of alignment here. If the integers are aligned
                // in the buffer, we can use them directly. Otherwise we must
                // copy them.
                std::vector< int > var_lengths( num_ents );
                UNPACK_INTS( buff_ptr, &var_lengths[0], num_ents );
                UPC( sizeof( int ) * num_ents, " void" );
                // Get pointers into buffer for each tag value
                var_len_vals.resize( num_ents );
                for( std::vector< EntityHandle >::size_type j = 0; j < (std::vector< EntityHandle >::size_type)num_ents;
                     j++ )
                    var_len_vals[j] = buff_ptr;
                    buff_ptr += var_lengths[j] * type_size;
                    UPC( var_lengths[j], " void" );
                result =
                    mbImpl->tag_set_by_ptr( tag_handle, &dum_ents[0], num_ents, &var_len_vals[0], &var_lengths[0] );MB_CHK_SET_ERR( result, "Failed to set tag data when unpacking variable-length tag" );
            else
                // Get existing values of dst tag
                dum_vals.resize( tag_size * num_ents );
                if( mpi_op )
                    int tag_length;
                    result = mbImpl->tag_get_length( tag_handle, tag_length );MB_CHK_SET_ERR( result, "Failed to get tag length" );
                    result = mbImpl->tag_get_data( tag_handle, &dum_ents[0], num_ents, &dum_vals[0] );MB_CHK_SET_ERR( result, "Failed to get existing value of dst tag on entities" );
                    result = reduce_void( tag_data_type, *mpi_op, tag_length * num_ents, &dum_vals[0], buff_ptr );MB_CHK_SET_ERR( result, "Failed to perform mpi op on dst tags" );
                result = mbImpl->tag_set_data( tag_handle, &dum_ents[0], num_ents, buff_ptr );MB_CHK_SET_ERR( result, "Failed to set range-based tag data when unpacking tag" );
                buff_ptr += num_ents * tag_size;
                UPC( num_ents * tag_size, " void" );
    myDebug->tprintf( 4, "Done unpacking tags.\n" );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::update_iface_sets ( Range sent_ents,
std::vector< EntityHandle > &  remote_handles,
int  from_proc
) [private]
for any remote_handles set to zero, remove corresponding sent_ents from iface_sets corresponding to from_proc
ErrorCode moab::ParallelComm::update_remote_data ( EntityHandle  entity,
std::vector< int > &  procs,
std::vector< EntityHandle > &  handles
Definition at line 1019 of file ParallelComm.cpp.
References moab::error(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, PSTATUS_INTERFACE, PSTATUS_NOT_OWNED, and rank().
Referenced by resolve_shared_ents(), unpack_entities(), unpack_remote_handles(), unpack_sets(), and update_remote_data().
    ErrorCode error;
    unsigned char pstatus = PSTATUS_INTERFACE;
    int procmin = *std::min_element( procs.begin(), procs.end() );
    if( (int)rank() > procmin )
    else
        procmin = rank();
    // DBG
    // std::cout<<"entity = "<<entity<<std::endl;
    // for (int j=0; j<procs.size(); j++)
    // std::cout<<"procs["<<j<<"] = "<<procs[j]<<", handles["<<j<<"] = "<<handles[j]<<std::endl;
    // DBG
    if( (int)procs.size() > 1 )
        procs.push_back( rank() );
        handles.push_back( entity );
        int idx = std::find( procs.begin(), procs.end(), procmin ) - procs.begin();
        std::iter_swap( procs.begin(), procs.begin() + idx );
        std::iter_swap( handles.begin(), handles.begin() + idx );
        // DBG
        // DBG
    // if ((entity == 10388) && (rank()==1))
    //    std::cout<<"Here"<<std::endl;
    error = update_remote_data( entity, &procs[0], &handles[0], procs.size(), pstatus );MB_CHK_ERR( error );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::update_remote_data ( Range local_range,
Range remote_range,
int  other_proc,
const unsigned char  add_pstat
) [private]
Definition at line 2629 of file ParallelComm.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_CHK_ERR, MB_SUCCESS, and update_remote_data().
    Range::iterator rit, rit2;
    ErrorCode result = MB_SUCCESS;
    // For each pair of local/remote handles:
    for( rit = local_range.begin(), rit2 = remote_range.begin(); rit != local_range.end(); ++rit, ++rit2 )
        result = update_remote_data( *rit, &other_proc, &( *rit2 ), 1, add_pstat );MB_CHK_ERR( result );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::update_remote_data ( const EntityHandle  new_h,
const int *  ps,
const EntityHandle hs,
const int  num_ps,
) [private]
Definition at line 2646 of file ParallelComm.cpp.
References moab::CN::EntityTypeName(), ErrorCode, get_sharing_data(), moab::ID_FROM_HANDLE(), MAX_SHARING_PROCS, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, rank(), set_sharing_data(), sharedEnts, and moab::TYPE_FROM_HANDLE().
    // Get initial sharing data; tag_ps and tag_hs get terminated with -1 and 0
    // in this function, so no need to initialize; sharing data does not include
    // this proc if shared with only one other
    // Following variables declared here to avoid compiler errors
    int new_numps;
    unsigned char new_pstat;
    std::vector< int > new_ps( MAX_SHARING_PROCS, -1 );
    std::vector< EntityHandle > new_hs( MAX_SHARING_PROCS, 0 );
    new_numps        = 0;
    ErrorCode result = get_sharing_data( new_h, &new_ps[0], &new_hs[0], new_pstat, new_numps );MB_CHK_SET_ERR( result, "Failed to get sharing data in update_remote_data" );
    int num_exist = new_numps;
    // Add new pstat info to the flag
    new_pstat |= add_pstat;
    #define plist(str, lst, siz)                                          \
        std::cout << str << "(";                                          \
        for (int i = 0; i < (int)siz; i++) std::cout << lst[i] << " ";    \
        std::cout << ") ";                                                \
        std::cout << "update_remote_data: rank = " << rank() << ", new_h = " << new_h << std::endl;
        std::string ostr;
        plist("ps", ps, num_ps);
        plist("hs", hs, num_ps);
        print_pstatus(add_pstat, ostr);
        std::cout << ", add_pstat = " << ostr.c_str() << std::endl;
        plist("tag_ps", new_ps, new_numps);
        plist("tag_hs", new_hs, new_numps);
        assert(new_numps <= size());
        print_pstatus(new_pstat, ostr);
        std::cout << ", tag_pstat=" << ostr.c_str() << std::endl;
#ifndef NDEBUG
        unsigned int dp = 0;
        for( ; (int)dp < num_ps && -1 != ps[dp]; dp++ )
        assert( dp == dumprocs.size() );
#endif
    // If only one sharer and I'm the owner, insert myself in the list;
    // otherwise, my data is checked at the end
    if( 1 == new_numps && !( new_pstat & PSTATUS_NOT_OWNED ) )
        new_hs[1] = new_hs[0];
        new_ps[1] = new_ps[0];
        new_hs[0] = new_h;
        new_ps[0] = rank();
        new_numps = 2;
    // Now put passed-in data onto lists
    int idx;
    for( int i = 0; i < num_ps; i++ )
        idx = std::find( &new_ps[0], &new_ps[0] + new_numps, ps[i] ) - &new_ps[0];
        if( idx < new_numps )
            if( !new_hs[idx] && hs[i] )
                // h on list is 0 and passed-in h is non-zero, replace it
                new_hs[idx] = hs[i];
            else
                assert( !hs[i] || new_hs[idx] == hs[i] );
        else
            if( new_numps + 1 == MAX_SHARING_PROCS )
                MB_SET_ERR( MB_FAILURE, "Exceeded MAX_SHARING_PROCS for "
                                            << CN::EntityTypeName( TYPE_FROM_HANDLE( new_h ) ) << ' '
                                            << ID_FROM_HANDLE( new_h ) << " in process " << rank() );
            new_ps[new_numps] = ps[i];
            new_hs[new_numps] = hs[i];
            new_numps++;
    // Add myself, if it isn't there already
    idx = std::find( &new_ps[0], &new_ps[0] + new_numps, rank() ) - &new_ps[0];
    if( idx == new_numps )
        new_ps[new_numps] = rank();
        new_hs[new_numps] = new_h;
        new_numps++;
    else if( !new_hs[idx] && new_numps > 2 )
        new_hs[idx] = new_h;
    // Proc list is complete; update for shared, multishared
    if( new_numps > 1 )
        if( new_numps > 2 ) new_pstat |= PSTATUS_MULTISHARED;
        new_pstat |= PSTATUS_SHARED;
        plist("new_ps", new_ps, new_numps);
        plist("new_hs", new_hs, new_numps);
        std::cout << ", new_pstat=" << ostr.c_str() << std::endl;
        std::cout << std::endl;
    result = set_sharing_data( new_h, new_pstat, num_exist, new_numps, &new_ps[0], &new_hs[0] );MB_CHK_SET_ERR( result, "Failed to set sharing data in update_remote_data" );
    if( new_pstat & PSTATUS_SHARED ) sharedEnts.insert( new_h );
    return MB_SUCCESS;
ErrorCode moab::ParallelComm::update_remote_data_old ( const EntityHandle  new_h,
const int *  ps,
const int  num_ps,
) [private]
Definition at line 2777 of file ParallelComm.cpp.
References moab::CN::EntityTypeName(), ErrorCode, get_sharing_data(), moab::ID_FROM_HANDLE(), MAX_SHARING_PROCS, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SUCCESS, mbImpl, proc_config(), moab::ProcConfig::proc_rank(), procConfig, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT_OWNED, PSTATUS_SHARED, pstatus_tag(), sharedEnts, sharedh_tag(), sharedhs_tag(), sharedp_tag(), sharedps_tag(), moab::Interface::tag_set_data(), and moab::TYPE_FROM_HANDLE().
    EntityHandle tag_hs[MAX_SHARING_PROCS];
    int tag_ps[MAX_SHARING_PROCS];
    unsigned char pstat;
    unsigned int num_exist;
    ErrorCode result = get_sharing_data( new_h, tag_ps, tag_hs, pstat, num_exist );MB_CHK_ERR( result );
#ifndef NDEBUG
#endif
    // Add any new sharing data
    bool changed = false;
    int idx;
    if( !num_exist )
        // Just take what caller passed
        memcpy( tag_ps, ps, num_ps * sizeof( int ) );
        memcpy( tag_hs, hs, num_ps * sizeof( EntityHandle ) );
        num_exist = num_ps;
        // If it's only one, hopefully I'm not there yet...
        assert( "I shouldn't be the only proc there." && ( 1 != num_exist || ps[0] != (int)procConfig.proc_rank() ) );
        changed = true;
    else
            idx = std::find( tag_ps, tag_ps + num_exist, ps[i] ) - tag_ps;
            if( idx == (int)num_exist )
                if( num_exist == MAX_SHARING_PROCS )
                    std::cerr << "Exceeded MAX_SHARING_PROCS for " << CN::EntityTypeName( TYPE_FROM_HANDLE( new_h ) )
                              << ' ' << ID_FROM_HANDLE( new_h ) << " in process " << proc_config().proc_rank()
                              << std::endl;
                    std::cerr.flush();
                // If there's only 1 sharing proc, and it's not me, then
                // we'll end up with 3; add me to the front
                if( !i && num_ps == 1 && num_exist == 1 && ps[0] != (int)procConfig.proc_rank() )
                    int j = 1;
                    // If I own this entity, put me at front, otherwise after first
                    if( !( pstat & PSTATUS_NOT_OWNED ) )
                        tag_ps[1] = tag_ps[0];
                        tag_hs[1] = tag_hs[0];
                        j         = 0;
                    tag_ps[j] = procConfig.proc_rank();
                    tag_hs[j] = new_h;
                    num_exist++;
                tag_ps[num_exist] = ps[i];
                tag_hs[num_exist] = hs[i];
                num_exist++;
                changed = true;
            else if( 0 == tag_hs[idx] )
                tag_hs[idx] = hs[i];
                changed     = true;
            else if( 0 != hs[i] )
                assert( hs[i] == tag_hs[idx] );
    // Adjust for interface layer if necessary
    if( add_pstat & PSTATUS_INTERFACE )
        idx = std::min_element( tag_ps, tag_ps + num_exist ) - tag_ps;
        if( idx )
            int tag_proc       = tag_ps[idx];
            tag_ps[idx]        = tag_ps[0];
            tag_ps[0]          = tag_proc;
            EntityHandle tag_h = tag_hs[idx];
            tag_hs[idx]        = tag_hs[0];
            tag_hs[0]          = tag_h;
            changed            = true;
            if( tag_ps[0] != (int)procConfig.proc_rank() ) pstat |= PSTATUS_NOT_OWNED;
    if( !changed ) return MB_SUCCESS;
    assert( "interface entities should have > 1 proc" && ( !( add_pstat & PSTATUS_INTERFACE ) || num_exist > 1 ) );
    assert( "ghost entities should have > 1 proc" && ( !( add_pstat & PSTATUS_GHOST ) || num_exist > 1 ) );
    // If it's multi-shared and we created the entity in this unpack,
    // local handle probably isn't in handle list yet
    if( num_exist > 2 )
        idx = std::find( tag_ps, tag_ps + num_exist, procConfig.proc_rank() ) - tag_ps;
        assert( idx < (int)num_exist );
        if( !tag_hs[idx] ) tag_hs[idx] = new_h;
    int tag_p;
    EntityHandle tag_h;
    // Update pstat
    pstat |= add_pstat;
    if( num_exist > 2 )
        pstat |= ( PSTATUS_MULTISHARED | PSTATUS_SHARED );
    else if( num_exist > 0 )
    //    compare_remote_data(new_h, num_ps, hs, ps, add_pstat,
    //                        num_exist, tag_hs, tag_ps, pstat);
    // Reset single shared proc/handle if was shared and moving to multi-shared
    if( num_exist > 2 && !( pstat & PSTATUS_MULTISHARED ) && ( pstat & PSTATUS_SHARED ) )
        // Must remove sharedp/h first, which really means set to default value
        tag_p  = -1;
        result = mbImpl->tag_set_data( sharedp_tag(), &new_h, 1, &tag_p );MB_CHK_SET_ERR( result, "Failed to set sharedp tag data" );
        tag_h  = 0;
        result = mbImpl->tag_set_data( sharedh_tag(), &new_h, 1, &tag_h );MB_CHK_SET_ERR( result, "Failed to set sharedh tag data" );
    // Set sharing tags
    if( num_exist > 2 )
        std::fill( tag_ps + num_exist, tag_ps + MAX_SHARING_PROCS, -1 );
        std::fill( tag_hs + num_exist, tag_hs + MAX_SHARING_PROCS, 0 );
        result = mbImpl->tag_set_data( sharedps_tag(), &new_h, 1, tag_ps );MB_CHK_SET_ERR( result, "Failed to set sharedps tag data" );
        result = mbImpl->tag_set_data( sharedhs_tag(), &new_h, 1, tag_hs );MB_CHK_SET_ERR( result, "Failed to set sharedhs tag data" );
#ifndef NDEBUG
            for( ; dp < num_exist && -1 != tag_ps[dp]; dp++ )
                dumprocs.insert( tag_ps[dp] );
#endif
    else if( num_exist == 2 || num_exist == 1 )
        if( tag_ps[0] == (int)procConfig.proc_rank() )
            assert( 2 == num_exist && tag_ps[1] != (int)procConfig.proc_rank() );
            tag_ps[0] = tag_ps[1];
            tag_hs[0] = tag_hs[1];
        assert( tag_ps[0] != -1 && tag_hs[0] != 0 );
        result = mbImpl->tag_set_data( sharedp_tag(), &new_h, 1, tag_ps );MB_CHK_SET_ERR( result, "Failed to set sharedp tag data" );
        result = mbImpl->tag_set_data( sharedh_tag(), &new_h, 1, tag_hs );MB_CHK_SET_ERR( result, "Failed to set sharedh tag data" );
    // Now set new pstatus
    result = mbImpl->tag_set_data( pstatus_tag(), &new_h, 1, &pstat );MB_CHK_SET_ERR( result, "Failed to set pstatus tag data" );
    if( pstat & PSTATUS_SHARED ) sharedEnts.insert( new_h );
    return MB_SUCCESS;
Friends And Related Function Documentation
friend class ParallelMergeMesh [friend]
Definition at line 57 of file ParallelComm.hpp.
Member Data Documentation
Definition at line 1475 of file ParallelComm.hpp.
Referenced by recv_entities(), and send_entities().
Error handler.
Definition at line 1438 of file ParallelComm.hpp.
Referenced by initialize(), and packed_tag_size().
Cache of global part count.
Definition at line 1467 of file ParallelComm.hpp.
Referenced by collective_sync_partition(), create_part(), destroy_part(), and get_global_part_count().
Definition at line 1465 of file ParallelComm.hpp.
std::ofstream moab::ParallelComm::myFile [private]
Definition at line 1471 of file ParallelComm.hpp.
entity set containing all parts
Definition at line 1469 of file ParallelComm.hpp.
Referenced by get_partitioning(), and set_partitioning().
the partition, interface sets for this comm'n instance
Definition at line 1459 of file ParallelComm.hpp.
Referenced by get_part_entities(), partition_sets(), resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
Referenced by partition_tag().
Definition at line 1473 of file ParallelComm.hpp.
Referenced by get_id(), initialize(), and ParallelComm().
unsigned char moab::ParallelComm::PROC_OWNER [static]
Definition at line 88 of file ParallelComm.hpp.
unsigned char moab::ParallelComm::PROC_SHARED [static]
Referenced by pstatus_tag().
std::vector< MPI_Request > moab::ParallelComm::recvRemotehReqs [private]
Definition at line 1453 of file ParallelComm.hpp.
Referenced by exchange_owned_meshs(), post_irecv(), recv_entities(), and send_entities().
std::vector< MPI_Request > moab::ParallelComm::recvReqs [private]
receive request objects
Referenced by exchange_owned_meshs(), post_irecv(), recv_entities(), recv_messages(), send_entities(), and set_recv_request().
Sequence manager, to get more efficient access to entities.
Definition at line 1435 of file ParallelComm.hpp.
Referenced by get_tag_send_list(), initialize(), pack_entities(), and packed_tag_size().
Referenced by sharedhs_tag().
Referenced by sharedh_tag().
Referenced by sharedps_tag().
tags used to save sharing procs and handles
Referenced by sharedp_tag().
List of all members.
