, including all inherited members.
| auto_collapse(double length, double angle, CubitBoolean preview, CubitBoolean if_comp_vertex, double max_angle) | CollapseAngleTool | |
| collapse_angle(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position) | CollapseAngleTool | [private] |
| collapse_one_angle(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position, CubitBoolean preview, CubitBoolean if_comp_vertex, double angle) | CollapseAngleTool | |
| CollapseAngleTool() | CollapseAngleTool | [private] |
| draw_preview(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefEdge *the_other_edge, double length1, double length2, CubitBoolean get_position, CubitVector &position) | CollapseAngleTool | [private] |
| exchange_edges(RefEdge *&edge, RefEdge *&the_other_edge) | CollapseAngleTool | [private] |
| if_partition_surf(RefVertex *vex_ptr, RefEdge *edge_to_remove, RefFace *common_face) | CollapseAngleTool | [private] |
| instance() | CollapseAngleTool | [static] |
| instance_ | CollapseAngleTool | [private, static] |
| partition_curve(RefEdge *&edge, RefVertex *root_vertex, CubitVector &position, RefVertex *&new_vertex) | CollapseAngleTool | [private] |
| partition_curve(RefEdge *&edge, RefVertex *root_vertex, double arc_length, RefVertex *&new_vertex) | CollapseAngleTool | [private] |
| partition_surface(RefFace *common_face, RefEdge *&edge, RefVertex *root, RefVertex *vertex1, RefVertex *veretx2, RefFace *&result_face) | CollapseAngleTool | [private] |
| partly_drawn_curve | CollapseAngleTool | [private] |
| position_from_length(RefEdge *edge, RefVertex *root_vertex, double arc_length, CubitVector &v_new) | CollapseAngleTool | [private] |
| the_surface_angle(RefEdge *edge, RefVertex *root_vertex, double length) | CollapseAngleTool | [private] |
| ~CollapseAngleTool() | CollapseAngleTool | [private] |
