, including all inherited members.
| add(CompositeCoEdge *coedge) | CompositeCurve | |
| append_simple_attribute_virt(const CubitSimpleAttrib &csa) | CompositeCurve | [virtual] |
| bodysm() | TopologyBridge | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() const | CompositeCurve | [virtual] |
| bridge_destroyed(TopologyBridge *bridge) | TBOwner | [inline, virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| center_point() | Curve | [inline, virtual] |
| ChildType typedef | Curve | |
| closest_curve(CubitVector const &location, CubitVector *point=NULL) | CompositeCurve | [protected] |
| closest_point(CubitVector const &location, CubitVector &closest_location, CubitVector *tangent_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL) | CompositeCurve | [virtual] |
| closest_point_trimmed(CubitVector const &from_pt, CubitVector &result_pt) | CompositeCurve | [virtual] |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| combine(CompositeCurve *curve_ptr, bool prepend) | CompositeCurve | |
| common_point(CompositeCurve *curve) | CompositeCurve | |
| compGeom | CompositeCurve | [private] |
| composite_param(int index, double param) const | CompositeCurve | |
| CompositeCurve(Curve *curve) | CompositeCurve | |
| CompositeCurve(CompositeGeom *geometry) | CompositeCurve | |
| CompositeCurve(CompositePoint *point) | CompositeCurve | |
| CompositeCurve() | CompositeCurve | [protected] |
| CompositeCurve(const CompositeCurve &) | CompositeCurve | [private] |
| contains_bridge(TopologyBridge *bridge) const | CompositeCurve | [virtual] |
| Curve() | Curve | |
| curve_param(double u_composite, double &u_curve, int &index) const | CompositeCurve | |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| end_param() | CompositeCurve | [virtual] |
| end_point() const | CompositeCurve | [inline] |
| end_point(CompositePoint *pt) | CompositeCurve | |
| endNext | CompositeCurve | [private] |
| endPoint | CompositeCurve | [private] |
| first_coedge() const | CompositeCurve | [inline] |
| firstCoEdge | CompositeCurve | [private] |
| fixup_periodic_param(double &u) const | CompositeCurve | [protected] |
| G1_discontinuous(double param, CubitVector *minus_tangent=NULL, CubitVector *plus_tangent=NULL) | CompositeCurve | [virtual] |
| geometry_type() | CompositeCurve | [virtual] |
| GeometryEntity() | GeometryEntity | [inline] |
| get_arc_length() | Curve | [inline, virtual] |
| get_arc_length(const CubitVector &point1, const CubitVector &point2) | Curve | [inline, virtual] |
| get_arc_length(const CubitVector &point1, const int which_end) | Curve | [inline, virtual] |
| get_center_radius(CubitVector &c, double &r) | CompositeCurve | [virtual] |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &children) | CompositeCurve | [virtual] |
| get_curve(int index) const | CompositeCurve | [inline] |
| get_ellipse_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio) const | CompositeCurve | [virtual] |
| get_geometry_query_engine() const | CompositeCurve | [virtual] |
| get_hidden_points(DLIList< TBPoint * > &points) | CompositeCurve | |
| get_interior_extrema(DLIList< CubitVector * > &interior_points, CubitSense &return_sense) | CompositeCurve | [virtual] |
| get_param_range(double &lower, double &upper) | CompositeCurve | [virtual] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &parents) | CompositeCurve | [virtual] |
| get_point_direction(CubitVector &origin, CubitVector &direction) | CompositeCurve | [virtual] |
| get_saved_id() const | GeometryEntity | [inline] |
| get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
| get_sense(int index) const | CompositeCurve | [inline] |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &csa_list) | CompositeCurve | [virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &attrib_list) | CompositeCurve | [virtual] |
| get_spline_params(bool &rational, int °ree, DLIList< CubitVector > &cntrl_pts, DLIList< double > &cntrl_pt_weights, DLIList< double > &knots, bool &spline_is_reversed) const | CompositeCurve | [virtual] |
| get_stitched(DLIList< CompositeCurve * > &list) | CompositeCurve | |
| HadBridgeRemoved | CompositeCurve | |
| has_parent_composite_surface() const | CompositeCurve | |
| hidden_entities() | CompositeCurve | [inline] |
| hiddenSet | CompositeCurve | [private] |
| index_of(Curve *curve_ptr) const | CompositeCurve | [inline] |
| is_periodic(double &period) | CompositeCurve | [virtual] |
| is_position_on(const CubitVector &test_position) | CompositeCurve | [virtual] |
| is_stitched() | CompositeCurve | |
| is_tolerant() | Curve | [inline, virtual] |
| layer() const | CompositeCurve | [inline, virtual] |
| length_from_u(double parameter1, double parameter2) | CompositeCurve | [virtual] |
| lengthUntilI(int index) const | CompositeCurve | [protected] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| MAX_TB_LAYER enum value | TopologyBridge | |
| measure() | CompositeCurve | [virtual] |
| mid_point(const CubitVector &point1, const CubitVector &point2, CubitVector &mid_point) | Curve | [inline, virtual] |
| mid_point(CubitVector &mid_point) | Curve | [inline, virtual] |
| next(const CompositePoint *around_this) | CompositeCurve | |
| next_coedge(CompositeCoEdge *after_this) const | CompositeCurve | [inline] |
| notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
| notify_reversed(TopologyBridge *bridge) | CompositeCurve | [virtual] |
| notify_split(TopologyBridge *new_bridge, TopologyBridge *split_from) | CompositeCurve | [virtual] |
| notify_topology_modified(TopologyBridge *) | TBOwner | [inline, virtual] |
| num_curves() const | CompositeCurve | [inline] |
| operator=(const CompositeCurve &) | CompositeCurve | [private] |
| other_point(CompositePoint *pt) | CompositeCurve | |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| point_containment(const CubitVector &point) | CompositeCurve | [virtual] |
| point_from_arc_length(double root_param, const double arc_length, CubitVector &new_point) | Curve | [virtual] |
| point_from_arc_length(const CubitVector &root_point, double const arc_length, CubitVector &new_point) | Curve | [virtual] |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| position_from_fraction(const double fraction_along_curve, CubitVector &output_position) | Curve | [inline, virtual] |
| position_from_u(double u_value, CubitVector &pos) | CompositeCurve | [virtual] |
| primary_stitched_curve() | CompositeCurve | |
| print_debug_info(const char *prefix=0, bool brief=false) const | CompositeCurve | |
| read_attributes() | CompositeCurve | |
| relative_sense(Curve *other_curve) | Curve | [virtual] |
| remove(CompositeCoEdge *coedge) | CompositeCurve | |
| remove_all_simple_attribute_virt() | CompositeCurve | [virtual] |
| remove_bridge(TopologyBridge *bridge) | CompositeCurve | [virtual] |
| remove_curve(int index) | CompositeCurve | |
| remove_simple_attribute_virt(const CubitSimpleAttrib &csa) | CompositeCurve | [virtual] |
| reverse() | CompositeCurve | |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| set_point(bool set_start_point, CompositePoint *point) | CompositeCurve | [protected] |
| set_saved_id(int value) | GeometryEntity | [inline] |
| set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| split(Curve *curve_ptr) | CompositeCurve | |
| start_param() | CompositeCurve | [virtual] |
| start_point() const | CompositeCurve | [inline] |
| start_point(CompositePoint *pt) | CompositeCurve | |
| startNext | CompositeCurve | [private] |
| startPoint | CompositeCurve | [private] |
| stitch(CompositeCurve *merge_with) | CompositeCurve | |
| stitchNext | CompositeCurve | [private] |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| swap_bridge(TopologyBridge *old, TopologyBridge *neww, bool reversed) | CompositeCurve | [virtual] |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| u_from_arc_length(double root_param, double arc_length) | CompositeCurve | [virtual] |
| u_from_position(const CubitVector &input_position) | CompositeCurve | [virtual] |
| unstitch_all() | CompositeCurve | |
| update() | CompositeCurve | [inline] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| write_attributes() | CompositeCurve | |
| ~CompositeCurve() | CompositeCurve | [virtual] |
| ~Curve() | Curve | [virtual] |
| ~GeometryEntity() | GeometryEntity | [virtual] |
| ~TBOwner() | TBOwner | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
