, including all inherited members.
| add_to_error_count() | CubitMessage | [protected] |
| add_to_warning_count() | CubitMessage | [protected] |
| count_stream_users(const std::ofstream *stream) | CubitMessage | [protected] |
| CubitMessage() | CubitMessage | [protected] |
| currentDebugFlag | CubitMessage | [protected] |
| debug_flag(const int index) | CubitMessage | [inline] |
| debug_flag(const int index, const int flag) | CubitMessage | [inline] |
| debugFlag | CubitMessage | [protected] |
| delete_instance() | CubitMessage | [static] |
| diagnosticFlag | CubitMessage | [protected, static] |
| error_count() | CubitMessage | |
| errorCount | CubitMessage | [protected, static] |
| errorFlag | CubitMessage | [protected, static] |
| expectedEndErrorCount | CubitMessage | [protected, static] |
| expectedLessErrorCountAccepted | CubitMessage | [protected, static] |
| expectedStartErrorCount | CubitMessage | [protected, static] |
| find_file_use(const CubitString &filename) | CubitMessage | [protected] |
| free_instance() | CubitMessage | [static] |
| get_diagnostic_flag() | CubitMessage | [inline, static] |
| get_error_flag() | CubitMessage | [inline, static] |
| get_error_handler() | CubitMessage | [static] |
| get_info_flag() | CubitMessage | [inline, static] |
| get_logging_file_setting() | CubitMessage | [static] |
| get_message_handler() | CubitMessage | [static] |
| get_warning_flag() | CubitMessage | [inline, static] |
| infoFlag | CubitMessage | [protected, static] |
| initialize_settings() | CubitMessage | [static] |
| instance_ | CubitMessage | [protected, static] |
| internal_error(const int message_type, std::ofstream *output_stream, const CubitString &str) | CubitMessage | [virtual] |
| is_debug_flag_gui_set() | CubitMessage | [inline, virtual] |
| is_debug_flag_set(int flag) | CubitMessage | |
| logging_errors_filename() const | CubitMessage | |
| logging_filename() const | CubitMessage | |
| loggingErrorFile | CubitMessage | [protected, static] |
| loggingErrorStream | CubitMessage | [protected, static] |
| loggingFile | CubitMessage | [protected, static] |
| loggingStream | CubitMessage | [protected, static] |
| mErrorHandler | CubitMessage | [protected, static] |
| mHandler | CubitMessage | [protected, static] |
| number_of_debug_flags() | CubitMessage | |
| output_debug_information(int from=1, int to=-1, int step=1) | CubitMessage | |
| output_debug_information(CubitString &match) | CubitMessage | |
| output_logging_information() | CubitMessage | |
| print_debug(const CubitString &str) | CubitMessage | |
| print_debug_gui(const char *,...) | CubitMessage | [inline, virtual] |
| print_diagnostic(const CubitString &str) | CubitMessage | |
| print_error(const CubitString &str) | CubitMessage | |
| print_info(const CubitString &str) | CubitMessage | |
| print_warning(const CubitString &str) | CubitMessage | |
| remove_debug_stream(const int index) | CubitMessage | [protected] |
| reset_error_count(int value=0) | CubitMessage | |
| reset_warning_count(int value=0) | CubitMessage | |
| set_debug_file_setting(const int index, const CubitString &filename) | CubitMessage | |
| set_debug_flag_gui(bool) | CubitMessage | [inline, virtual] |
| set_debug_stream(const int index, std::ofstream *output_stream) | CubitMessage | [protected] |
| set_diagnostic_flag(bool flag) | CubitMessage | [inline, static] |
| set_error_flag(bool flag) | CubitMessage | [inline, static] |
| set_error_handler(CubitMessageErrorHandler *handler) | CubitMessage | [static] |
| set_error_logging_file_setting(const char *file, CubitBoolean resume_flag=CUBIT_FALSE) | CubitMessage | [static] |
| set_info_flag(bool flag) | CubitMessage | [inline, static] |
| set_logging_file_setting(const CubitString &filename, CubitBoolean resume_flag=CUBIT_FALSE) | CubitMessage | |
| set_logging_file_setting(const char *file) | CubitMessage | [static] |
| set_message_handler(CubitMessageHandler *handler) | CubitMessage | [static] |
| set_warning_flag(bool flag) | CubitMessage | [inline, static] |
| start_expected_error_count(int error_count, bool less_than_accepted) | CubitMessage | |
| staticDebugFlag | CubitMessage | [protected, static] |
| stop_expected_error_count(const CubitString &message) | CubitMessage | |
| warning_count() | CubitMessage | |
| warningCount | CubitMessage | [protected, static] |
| warningFlag | CubitMessage | [protected, static] |
| ~CubitMessage() | CubitMessage | [virtual] |
