, including all inherited members.
| clear_undo_groups() | CubitUndo | [static] |
| create_dummy_undo_object() | CubitUndo | [static] |
| CubitUndo() | CubitUndo | |
| end_undo_group() | CubitUndo | [static] |
| execute_undo() | CubitUndo | [static] |
| get_undo_enabled() | CubitUndo | [static] |
| inside_undo_group() | CubitUndo | [static] |
| mInstance | CubitUndo | [private, static] |
| note_result_bodies(DLIList< Body * > &bodies_to_delete) | CubitUndo | [static] |
| note_result_body(Body *body_to_delete) | CubitUndo | [static] |
| note_result_boundary_conditions(RefEntity *owner_entity) | CubitUndo | [static] |
| note_result_entities(DLIList< RefEntity * > &entities_to_delete) | CubitUndo | [static] |
| note_result_entities(DLIList< MRefVolume * > &vols_to_delete) | CubitUndo | [static] |
| note_result_entity(RefEntity *entity_to_delete) | CubitUndo | [static] |
| number_undo_groups() | CubitUndo | [static] |
| p_clear_undo_groups()=0 | CubitUndo | [protected, pure virtual] |
| p_create_dummy_undo_object()=0 | CubitUndo | [protected, pure virtual] |
| p_end_undo_group()=0 | CubitUndo | [protected, pure virtual] |
| p_execute_undo()=0 | CubitUndo | [protected, pure virtual] |
| p_get_undo_enabled()=0 | CubitUndo | [protected, pure virtual] |
| p_inside_undo_group()=0 | CubitUndo | [protected, pure virtual] |
| p_note_result_bodies(DLIList< Body * > &bodies_to_delete)=0 | CubitUndo | [protected, pure virtual] |
| p_note_result_body(Body *body_to_delete)=0 | CubitUndo | [protected, pure virtual] |
| p_note_result_boundary_conditions(RefEntity *owner_entity)=0 | CubitUndo | [protected, pure virtual] |
| p_note_result_entities(DLIList< RefEntity * > &entities_to_delete)=0 | CubitUndo | [protected, pure virtual] |
| p_note_result_entities(DLIList< MRefVolume * > &vols_to_delete)=0 | CubitUndo | [protected, pure virtual] |
| p_note_result_entity(RefEntity *entity_to_delete)=0 | CubitUndo | [protected, pure virtual] |
| p_number_undo_groups()=0 | CubitUndo | [protected, pure virtual] |
| p_remove_last_undo()=0 | CubitUndo | [protected, pure virtual] |
| p_remove_last_undo_group()=0 | CubitUndo | [protected, pure virtual] |
| p_retain_mesh_on_result_bodies(DLIList< Body * > &bodies)=0 | CubitUndo | [protected, pure virtual] |
| p_retain_mesh_on_result_curves(DLIList< RefEdge * > &curves)=0 | CubitUndo | [protected, pure virtual] |
| p_retain_mesh_on_result_vertices(DLIList< RefVertex * > &vertices)=0 | CubitUndo | [protected, pure virtual] |
| p_save_all_mesh_data(MRefEntity *entity)=0 | CubitUndo | [protected, pure virtual] |
| p_save_merge_data(DLIList< RefEntity * > &ents, bool merging=true)=0 | CubitUndo | [protected, pure virtual] |
| p_save_mesh_scheme_data(MRefEntity *entity)=0 | CubitUndo | [protected, pure virtual] |
| p_save_mesh_size_data(MRefEntity *entity)=0 | CubitUndo | [protected, pure virtual] |
| p_save_mesh_state_before_smoothing(DLIList< MRefEntity * > &ents_to_smooth)=0 | CubitUndo | [protected, pure virtual] |
| p_save_mesh_state_before_smoothing(DLIList< MeshEntity * > &ents_to_smooth)=0 | CubitUndo | [protected, pure virtual] |
| p_save_smooth_scheme_data(MRefEntity *entity)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state()=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(DLIList< Body * > &bodies_to_save, DLIList< RefEntity * > *free_ref_ents=NULL)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(DLIList< RefVolume * > &volumes_to_save)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(DLIList< RefFace * > &faces_to_save)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(RefFace *face_to_save)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(RefVolume *volume_to_save)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(DLIList< MRefVolume * > &volumes_to_save)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(DLIList< RefEdge * > &edges_to_save)=0 | CubitUndo | [protected, pure virtual] |
| p_save_state_with_cubit_file(DLIList< RefVertex * > &vertices_to_save, bool save_only_if_free=false)=0 | CubitUndo | [protected, pure virtual] |
| p_set_undo_by_command(CubitString command)=0 | CubitUndo | [protected, pure virtual] |
| p_set_undo_by_restoring_state()=0 | CubitUndo | [protected, pure virtual] |
| p_set_undo_enabled(bool value)=0 | CubitUndo | [protected, pure virtual] |
| p_start_undo_group()=0 | CubitUndo | [protected, pure virtual] |
| remove_last_undo() | CubitUndo | [static] |
| remove_last_undo_group() | CubitUndo | [static] |
| retain_mesh_on_result_bodies(DLIList< Body * > &bodies) | CubitUndo | [static] |
| retain_mesh_on_result_curves(DLIList< RefEdge * > &curves) | CubitUndo | [static] |
| retain_mesh_on_result_vertices(DLIList< RefVertex * > &vertices) | CubitUndo | [static] |
| save_all_mesh_data(MRefEntity *entity) | CubitUndo | [static] |
| save_merge_data(DLIList< RefEntity * > &ents, bool merging=true) | CubitUndo | [static] |
| save_mesh_scheme_data(MRefEntity *entity) | CubitUndo | [static] |
| save_mesh_size_data(MRefEntity *entity) | CubitUndo | [static] |
| save_mesh_state_before_smoothing(MRefEntity *entity) | CubitUndo | [static] |
| save_mesh_state_before_smoothing(DLIList< MRefEntity * > &ents) | CubitUndo | [static] |
| save_mesh_state_before_smoothing(DLIList< MeshEntity * > &ents) | CubitUndo | [static] |
| save_smooth_scheme_data(MRefEntity *entity) | CubitUndo | [static] |
| save_state() | CubitUndo | [static] |
| save_state_with_cubit_file(DLIList< Body * > &bodies_to_save, DLIList< RefEntity * > *free_ents_to_save=NULL) | CubitUndo | [static] |
| save_state_with_cubit_file(DLIList< RefVolume * > &volumes_to_save) | CubitUndo | [static] |
| save_state_with_cubit_file(DLIList< RefFace * > &faces_to_save) | CubitUndo | [static] |
| save_state_with_cubit_file(RefFace *face_to_save) | CubitUndo | [static] |
| save_state_with_cubit_file(RefVolume *volume_to_save) | CubitUndo | [static] |
| save_state_with_cubit_file(DLIList< MRefVolume * > &volumes_to_save) | CubitUndo | [static] |
| save_state_with_cubit_file(DLIList< RefEdge * > &edges_to_save) | CubitUndo | [static] |
| save_state_with_cubit_file(DLIList< RefVertex * > &vertices_to_save, bool save_if_free=false) | CubitUndo | [static] |
| set_undo_by_command(CubitString command) | CubitUndo | [static] |
| set_undo_by_restoring_state() | CubitUndo | [static] |
| set_undo_enabled(bool value) | CubitUndo | [static] |
| start_undo_group() | CubitUndo | [static] |
| ~CubitUndo() | CubitUndo | [virtual] |
