cgma
| append(const_reference new_item) | DLIList< X > | [inline] |
| append_unique(const_reference new_item) | DLIList< X > | [inline] |
| as_vector() const | DLIList< X > | [inline] |
| back() | DLIList< X > | [inline] |
| back(int n) | DLIList< X > | [inline] |
| begin() | DLIList< X > | [inline] |
| begin() const | DLIList< X > | [inline] |
| casting_merge_unique(const DLIList< Y > &merge_list, bool merge_list_unique=false) | DLIList< X > | [inline] |
| change_to(X val) | DLIList< X > | [inline] |
| clean_out() | DLIList< X > | [inline] |
| const_iterator typedef | DLIList< X > | |
| const_pointer typedef | DLIList< X > | |
| const_reference typedef | DLIList< X > | |
| copy_from(X *other_array, const int other_size) | DLIList< X > | [inline] |
| copy_to(X *other_array) | DLIList< X > | [inline] |
| distance_to_nearby(const X val) | DLIList< X > | [inline] |
| DLIList(int size=0) | DLIList< X > | [inline, explicit] |
| DLIList(const DLIList< X > &from) | DLIList< X > | [inline] |
| DLIList(const std::vector< X > &from) | DLIList< X > | [inline, explicit] |
| DLIListIterator< X > class | DLIList< X > | [friend] |
| empty() const | DLIList< X > | [inline] |
| end() | DLIList< X > | [inline] |
| end() const | DLIList< X > | [inline] |
| extract() | DLIList< X > | [inline] |
| get() const | DLIList< X > | [inline] |
| get() | DLIList< X > | [inline] |
| get_and_back() | DLIList< X > | [inline] |
| get_and_step() | DLIList< X > | [inline] |
| get_index() | DLIList< X > | [inline] |
| index | DLIList< X > | [private] |
| insert(X val) | DLIList< X > | [inline] |
| insert_first(X val) | DLIList< X > | [inline] |
| intersect(const DLIList< X > &merge_list) | DLIList< X > | [inline] |
| intersect_unordered(const DLIList< X > &merge_list) | DLIList< X > | [inline] |
| is_at_beginning() const | DLIList< X > | [inline] |
| is_at_end() const | DLIList< X > | [inline] |
| is_in_list(const_reference item) const | DLIList< X > | [inline] |
| last() | DLIList< X > | [inline] |
| last_item(void) | DLIList< X > | [inline] |
| last_item(void) const | DLIList< X > | [inline] |
| lengthen_list(int by_how_much=DLI_COUNT_INCREMENT, double by_what_factor=DLI_COUNT_FACTOR) | DLIList< X > | [inline, private] |
| listArray | DLIList< X > | [private] |
| memory_use() | DLIList< X > | [inline] |
| merge_unique(const DLIList< X > &merge_list, bool merge_list_unique=false) | DLIList< X > | [inline] |
| move_between(X val1, X val2) | DLIList< X > | [inline] |
| move_to(const_reference item) | DLIList< X > | [inline] |
| move_to_nearby(const X val) | DLIList< X > | [inline] |
| next() const | DLIList< X > | [inline] |
| next(int n) const | DLIList< X > | [inline] |
| omit(const_reference val) | DLIList< X > | [inline] |
| operator!=(const DLIList< X > &from) | DLIList< X > | [inline] |
| operator+=(const DLIList< X > &from) | DLIList< X > | [inline] |
| operator+=(const std::vector< X > &from) | DLIList< X > | [inline] |
| operator-=(const DLIList< X > &from) | DLIList< X > | [inline] |
| operator=(const DLIList< X > &from) | DLIList< X > | [inline] |
| operator=(const std::vector< X > &from) | DLIList< X > | [inline] |
| operator=(const DLIListIterator< X > &from_iterator) | DLIList< X > | [inline] |
| operator==(const DLIList< X > &from) | DLIList< X > | [inline] |
| operator[](int index) const | DLIList< X > | [inline] |
| operator[](int index) | DLIList< X > | [inline] |
| pop() | DLIList< X > | [inline] |
| prev() const | DLIList< X > | [inline] |
| prev(int n) const | DLIList< X > | [inline] |
| push(X val) | DLIList< X > | [inline] |
| remove() | DLIList< X > | [inline] |
| remove(const_reference val) | DLIList< X > | [inline] |
| remove_all_with_value(const_reference val) | DLIList< X > | [inline] |
| reserve(int min_size) | DLIList< X > | [inline] |
| reset() | DLIList< X > | [inline] |
| reverse() | DLIList< X > | [inline] |
| shrink(int k) | DLIList< X > | [inline] |
| size() const | DLIList< X > | [inline] |
| sort() | DLIList< X > | [inline] |
| sort(SortFunction f) | DLIList< X > | |
| SortFunction typedef | DLIList< X > | |
| step(int n) | DLIList< X > | [inline] |
| step_and_get() | DLIList< X > | [inline] |
| swap(std::vector< X > &other) | DLIList< X > | [inline] |
| uniquify_ordered() | DLIList< X > | [inline] |
| uniquify_unordered() | DLIList< X > | [inline] |
| uniquify_unordered_checked() | DLIList< X > | [inline] |
| value_type typedef | DLIList< X > | |
| where_is_item(const_reference val) const | DLIList< X > | [inline] |
| ~DLIList() | DLIList< X > | [inline] |
