, including all inherited members.
| check(DLIList< CubitFacetEdge * > &edge_list, DLIList< CubitFacet * > &facet_list) | FacetDataUtil | [static] |
| collapse_short_edges(DLIList< CubitFacet * > &facet_list, CubitBoolean non_manifold_only) | FacetDataUtil | [static] |
| copy_facets(DLIList< CubitFacet * > &old_facet_list, DLIList< CubitFacet * > &new_facet_list, DLIList< CubitPoint * > &new_point_list, DLIList< CubitFacetEdge * > &new_edge_list) | FacetDataUtil | [static] |
| delete_facet(CubitFacet *facet_ptr) | FacetDataUtil | [static] |
| delete_facets(DLIList< DLIList< CubitFacet * > * > &shell_list) | FacetDataUtil | [static] |
| delete_facets(DLIList< CubitFacet * > &facet_list) | FacetDataUtil | [static] |
| destruct_facet_no_delete(CubitFacet *facet_ptr) | FacetDataUtil | [static] |
| draw_edge(CubitFacetEdge *edge) | FacetDataUtil | [static] |
| edge_compare(CubitFacetEdge *&ea, CubitFacetEdge *&eb) | FacetDataUtil | [static] |
| edges_by_count(DLIList< CubitFacet * > &facets, unsigned int count, DLIList< CubitFacetEdge * > &edges) | FacetDataUtil | [static] |
| find_facet(DLIList< CubitFacet * > temp_split_facets, CubitPoint *pnt0, CubitPoint *pnt1, DLIList< CubitFacet * > &select_facets) | FacetDataUtil | [static] |
| get_adj_facets_on_shell(CubitFacet *start_facet_ptr, DLIList< CubitFacet * > *shell_ptr, CubitBoolean &is_water_tight, int mydebug) | FacetDataUtil | [private, static] |
| get_bbox_intersections(CubitVector &point1, CubitVector &point2, const CubitBox &bbox, CubitVector &intersection_1, CubitVector &intersection_2) | FacetDataUtil | [static] |
| get_bbox_of_points(DLIList< CubitPoint * > &point_list, CubitBox &bbox) | FacetDataUtil | [static] |
| get_boundary_edges(DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list) | FacetDataUtil | [static] |
| get_boundary_points(DLIList< CubitFacet * > &facet_list, DLIList< CubitPoint * > &point_list) | FacetDataUtil | [static] |
| get_edges(DLIList< CubitFacet * > &facet_list, DLIList< CubitFacetEdge * > &edge_list) | FacetDataUtil | [static] |
| get_facet_points(DLIList< CubitFacet * > &cubit_facets, DLIList< CubitPoint * > &facet_points) | FacetDataUtil | [static] |
| get_points(DLIList< CubitFacet * > &facet_list, DLIList< CubitPoint * > &point_list) | FacetDataUtil | [static] |
| intersect_facet(CubitVector &start, CubitVector &end, CubitFacet *facet_ptr, CubitVector &qq, CubitVector &ac, CubitBoolean bound=CUBIT_TRUE) | FacetDataUtil | [static] |
| is_point_in_polyhedron(DLIList< CubitFacet * > &tfacet_list, CubitVector &point_coords, CubitPointContainment &is_point_in) | FacetDataUtil | [static] |
| mark_facets(DLIList< FacetEntity * > &facet_list, int mark_value) | FacetDataUtil | [static] |
| merge_coincident_vertices(DLIList< DLIList< CubitFacet * > * > &shell_list, double tol, int &mpmerge, int &nemerge, DLIList< CubitPoint * > &unmerged_points) | FacetDataUtil | [static] |
| merge_coincident_vertices(DLIList< CubitPoint * > &points) | FacetDataUtil | [static] |
| merge_colinear_vertices(DLIList< DLIList< CubitFacet * > * > &shell_list, double tol, DLIList< CubitPoint * > &merge_points, int &mpmerge, int &nemerge, int &nnomerge) | FacetDataUtil | [private, static] |
| merge_points(CubitPoint *pt0, CubitPoint *pt1, int &nemerge, RTree< CubitFacetEdge * > *r_tree=NULL) | FacetDataUtil | [static] |
| ordered_point_edge_bdry(DLIList< CubitFacet * > &facets, DLIList< FacetEntity * > &point_edge_chain) | FacetDataUtil | [static] |
| partial_chain(DLIList< FacetEntity * > &point_edge_chain, FacetEntity *point1, FacetEntity *point2, DLIList< FacetEntity * > &chain_between) | FacetDataUtil | [static] |
| pt_in_tri_2d(double xpt, double ypt, double x0, double y0, double x1, double y1, double x2, double y2, CubitPointContainment &is_point_in) | FacetDataUtil | [static] |
| quality(CubitVector &c1, CubitVector &c2, CubitVector &c3, CubitVector &surf_normal) | FacetDataUtil | [static] |
| random_positive_ray(CubitVector &ray) | FacetDataUtil | [static] |
| ray_intersects_boundingbox(CubitVector &point, CubitVector &ray, const CubitBox &bbox) | FacetDataUtil | [static] |
| split_into_shells(DLIList< CubitFacet * > &tfacet_list, DLIList< CubitQuadFacet * > &qfacet_list, DLIList< DLIList< CubitFacet * > * > &shell_list, CubitBoolean &is_water_tight) | FacetDataUtil | [static] |
| squared_distance_to_segment(CubitVector &p, CubitVector &p0, CubitVector &p1, double &distance2) | FacetDataUtil | [static] |
| stitch_facets(DLIList< DLIList< CubitFacet * > * > &shell_list, double tol, CubitBoolean &is_water_tight, CubitBoolean write_results=CUBIT_TRUE) | FacetDataUtil | [static] |
| write_facets(const char *file_name, DLIList< CubitFacet * > &facet_list) | FacetDataUtil | [static] |
