, including all inherited members.
| add(PartitionShell *shell) | PartitionLump | |
| append_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionLump | [virtual] |
| bodysm() | TopologyBridge | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() const | PartitionLump | [virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| ChildType typedef | Lump | |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| find_parent_body() const | PartitionLump | |
| first_shell() const | PartitionLump | [inline] |
| geometry_type() | Lump | [inline, virtual] |
| GeometryEntity() | GeometryEntity | [inline] |
| get_all_children(DLIList< PartitionEntity * > &result) | PartitionLump | |
| get_body() const | PartitionLump | |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &) | PartitionLump | [virtual] |
| get_geometry_query_engine() const | PartitionLump | [virtual] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &) | PartitionLump | [virtual] |
| get_saved_id() const | GeometryEntity | [inline] |
| get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &) | PartitionLump | [virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &) | PartitionLump | [virtual] |
| layer() const | PartitionLump | [inline, virtual] |
| listHead | PartitionLump | [private] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| Lump() | Lump | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| mark | PartitionEntity | |
| mass_properties(CubitVector &volume_centrioid, double &volume) | PartitionLump | [virtual] |
| Lump::mass_properties(CubitVector[3], CubitVector &, CubitVector &, double &) | Lump | [inline, virtual] |
| MAX_TB_LAYER enum value | TopologyBridge | |
| measure() | PartitionLump | [virtual] |
| move_to_geometry(CubitVector &position) | PartitionEntity | [virtual] |
| next_shell(PartitionShell *after_this=0) const | PartitionLump | [inline] |
| notify_split(FacetEntity *, FacetEntity *) | PartitionLump | [virtual] |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| PartitionBody class | PartitionLump | [friend] |
| partitioned_entity() const | PartitionEntity | [inline] |
| PartitionEntity() | PartitionEntity | [protected] |
| PartitionLump(Lump *real_lump) | PartitionLump | |
| PartitionLump(PartitionLump *split_from) | PartitionLump | |
| point_containment(const CubitVector &pos, double tolerance=-1) | PartitionLump | |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| print_debug_info(const char *prefix=0, bool print_subentity_set=true) const | PartitionEntity | [virtual] |
| print_partitioned_entity(const char *prefix=0) const | PartitionEntity | |
| real_lump() const | PartitionLump | |
| relax_to_geometry(CubitPoint *facet_point, const CubitVector *input_position=0) | PartitionEntity | |
| remove(PartitionShell *shell) | PartitionLump | |
| remove_all_shells() | PartitionLump | |
| remove_all_simple_attribute_virt() | PartitionLump | [virtual] |
| remove_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionLump | [virtual] |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| reverse_sense() | PartitionLump | [virtual] |
| save(CubitSimpleAttrib &) | PartitionLump | [virtual] |
| set_saved_id(int value) | GeometryEntity | [inline] |
| set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| sub_entity_set() const | PartitionEntity | [inline] |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| transform(const CubitTransformMatrix &) | PartitionLump | [virtual] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| ~GeometryEntity() | GeometryEntity | [virtual] |
| ~Lump() | Lump | [virtual] |
| ~PartitionEntity() | PartitionEntity | [virtual] |
| ~PartitionLump() | PartitionLump | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
