, including all inherited members.
| add(PartitionLoop *loop) | PartitionSurface | |
| add(PartitionCoSurf *cosurf) | PartitionSurface | |
| append_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionSurface | [virtual] |
| are_positions_on(DLIList< CubitVector * > &test_position_list, DLIList< CubitBoolean * > &is_on_list) | Surface | [virtual] |
| bodysm() | TopologyBridge | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() const | PartitionSurface | [virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| ChildType typedef | Surface | |
| closest_facet(const CubitVector &input_position, CubitVector &result_position) | PartitionSurface | |
| closest_point(CubitVector const &pos, CubitVector *close=0, CubitVector *norm=0, CubitVector *curv1=0, CubitVector *curv2=0) | PartitionSurface | [virtual] |
| closest_point_along_vector(CubitVector &from_point, CubitVector &along_vector, CubitVector &point_on_surface) | PartitionSurface | [virtual] |
| closest_point_trimmed(CubitVector from, CubitVector &closest) | PartitionSurface | [virtual] |
| closest_point_uv_guess(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL, CubitVector *unit_normal=NULL) | PartitionSurface | [virtual] |
| closest_points(DLIList< CubitVector * > &location_list, DLIList< CubitVector * > *closest_location_list=NULL, DLIList< CubitVector * > *unit_normal_list=NULL, DLIList< CubitVector * > *curvature1_list=NULL, DLIList< CubitVector * > *curvature2_list=NULL) | Surface | [virtual] |
| closest_points_trimmed(std::vector< CubitVector > &from_points_list, std::vector< CubitVector > &points_on_surface_list) | Surface | [virtual] |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| combine(PartitionSurface *dead_surface) | PartitionSurface | [virtual] |
| construct(const CubitSimpleAttrib &attrib, PartitionLump *vol) | PartitionSurface | [static] |
| copy() | PartitionSurface | [protected, virtual] |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| draw_facets(int color) const | PartitionSurface | |
| evaluate(double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2) | PartitionSurface | [virtual] |
| Surface::evaluate(double u, double v, CubitVector &pos, CubitVector deriv1[2], CubitVector deriv2[3]) | Surface | [virtual] |
| facetList | PartitionSurface | [protected] |
| find_first(const PartitionShell *shell) const | PartitionSurface | |
| find_first(const PartitionLump *lump) const | PartitionSurface | |
| find_first(const PartitionShell *shell, CubitSense sense) const | PartitionSurface | |
| find_next(const PartitionCoSurf *cosurf) const | PartitionSurface | |
| firstCoSurf | PartitionSurface | [private] |
| firstLoop | PartitionSurface | [private] |
| geometry_sense | PartitionSurface | [protected] |
| geometry_type() | PartitionSurface | [virtual] |
| GeometryEntity() | GeometryEntity | [inline] |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &) | PartitionSurface | [virtual] |
| get_cone_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio, double &sine_angle, double &cos_angle) const | PartitionSurface | [virtual] |
| get_facet_data(DLIList< CubitFacetData * > &result_list) const | PartitionSurface | |
| get_geometry_query_engine() const | PartitionSurface | [virtual] |
| get_geometry_sense() | PartitionSurface | [virtual] |
| get_nurb_params(bool &rational, int °ree_u, int °ree_v, int &num_cntrl_pts_u, int &num_cntrl_pts_v, DLIList< CubitVector > &cntrl_pts, DLIList< double > &weights, DLIList< double > &u_knots, DLIList< double > &v_knots) const | PartitionSurface | [virtual] |
| get_param_range_U(double &lo, double &hi) | PartitionSurface | [virtual] |
| get_param_range_V(double &lo, double &hi) | PartitionSurface | [virtual] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &) | PartitionSurface | [virtual] |
| get_point_normal(CubitVector &point, CubitVector &normal) | PartitionSurface | [virtual] |
| get_points(DLIList< PartitionPoint * > &list) const | PartitionSurface | |
| get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance) | PartitionSurface | [virtual] |
| get_save_topology(DLIList< int > &curves) | PartitionSurface | [protected] |
| get_saved_id() const | GeometryEntity | [inline] |
| get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
| get_shell_sense(ShellSM *shell_ptr) const | PartitionSurface | [virtual] |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &) | PartitionSurface | [virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &) | PartitionSurface | [virtual] |
| get_sphere_params(CubitVector ¢er, double &radius) const | PartitionSurface | [virtual] |
| get_torus_params(CubitVector ¢er, CubitVector &normal, double &major_radius, double &minor_radius) const | PartitionSurface | [virtual] |
| get_uv_sense() | Surface | [inline, virtual] |
| has_facets() const | PartitionSurface | [inline] |
| init_facet_data() | PartitionSurface | |
| insert_facets(DLIList< PartitionEntity * > points, DLIList< CubitFacetEdgeData * > &boundary_edges, DLIList< CubitFacetData * > &surf_facets) | PartitionSurface | [protected] |
| interior_facet_points(DLIList< CubitPoint * > &result_list) const | PartitionSurface | [protected] |
| is_closed_in_U() | PartitionSurface | [virtual] |
| is_closed_in_V() | PartitionSurface | [virtual] |
| is_cylindrical() | Surface | [inline, virtual] |
| is_parametric() | PartitionSurface | [virtual] |
| is_periodic() | PartitionSurface | [virtual] |
| is_periodic_in_U(double &period) | PartitionSurface | [virtual] |
| is_periodic_in_V(double &period) | PartitionSurface | [virtual] |
| is_position_on(CubitVector &test_position) | PartitionSurface | [virtual] |
| is_singular_in_U(double u_param) | PartitionSurface | [virtual] |
| is_singular_in_V(double v_param) | PartitionSurface | [virtual] |
| layer() const | PartitionSurface | [inline, virtual] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| mark | PartitionEntity | |
| MAX_TB_LAYER enum value | TopologyBridge | |
| measure() | PartitionSurface | [virtual] |
| move_to_geometry(CubitVector &position) | PartitionSurface | [virtual] |
| next_co_surface(const PartitionCoSurf *prev=0) const | PartitionSurface | [inline] |
| next_loop(const PartitionLoop *prev=0) const | PartitionSurface | [inline] |
| notify_destroyed(CubitFacetData *facet) | PartitionSurface | |
| notify_moving_point(CubitPoint *point, const CubitVector &new_pos) | PartitionSurface | |
| notify_split(FacetEntity *old_tri, FacetEntity *new_tri) | PartitionSurface | [virtual] |
| num_loops() const | PartitionSurface | |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| param_dir(CubitVector &, CubitVector &, double &, double &) | Surface | [inline, virtual] |
| partitioned_entity() const | PartitionEntity | [inline] |
| PartitionEntity() | PartitionEntity | [protected] |
| PartitionSurface(PartitionLump *owner) | PartitionSurface | |
| PartitionSurface() | PartitionSurface | [protected] |
| PartitionSurface(PartitionSurface *split_from) | PartitionSurface | [private] |
| PartitionSurface(const PartitionSurface &) | PartitionSurface | [private] |
| point_containment(const CubitVector &point) | PartitionSurface | [virtual] |
| point_containment(double u, double v) | PartitionSurface | [virtual] |
| point_containment(const CubitVector &point, PartitionCurve *&boundary_curve) | PartitionSurface | |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| position_from_u_v(double u, double v) | PartitionSurface | [virtual] |
| principal_curvatures(CubitVector const &loc, double &curv1, double &curv2, CubitVector *closest_location=0) | PartitionSurface | [virtual] |
| print_debug_info(const char *prefix=0, bool print_sub_entity_set=true) const | PartitionSurface | [virtual] |
| print_partitioned_entity(const char *prefix=0) const | PartitionEntity | |
| relax_to_geometry(CubitPoint *facet_point, const CubitVector *input_position=0) | PartitionEntity | |
| remove(PartitionLoop *loop) | PartitionSurface | |
| remove(PartitionCoSurf *cosurf) | PartitionSurface | |
| remove_all_simple_attribute_virt() | PartitionSurface | [virtual] |
| remove_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionSurface | [virtual] |
| replace_facets(DLIList< CubitFacetData * > &dead_facets, DLIList< CubitFacetData * > &new_facets) | PartitionSurface | |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| reverse_loops() | PartitionSurface | [protected] |
| reverse_sense() | PartitionSurface | [virtual] |
| save(CubitSimpleAttrib &attrib) | PartitionSurface | [virtual] |
| set_facet_data(const DLIList< CubitFacetData * > &new_list) | PartitionSurface | |
| set_saved_id(int value) | GeometryEntity | [inline] |
| set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| split(DLIList< CubitFacetData * > &facets_to_move) | PartitionSurface | |
| sub_entity_set() const | PartitionEntity | [inline] |
| Surface() | Surface | |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| transform(const CubitTransformMatrix &xform) | PartitionSurface | [virtual] |
| u_v_from_position(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL) | PartitionSurface | [virtual] |
| update_facet_tool() | PartitionSurface | [protected] |
| uv_derivitives(double u, double v, CubitVector &du, CubitVector &dv) | PartitionSurface | [virtual] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| ~GeometryEntity() | GeometryEntity | [virtual] |
| ~PartitionEntity() | PartitionEntity | [virtual] |
| ~PartitionSurface() | PartitionSurface | [virtual] |
| ~Surface() | Surface | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
