, including all inherited members.
| about_spatially_equal(RefEdge *ref_edge_ptr_2, double tolerance_factor=1.0, CubitSense *sensePtr=NULL, CubitBoolean notify_refEntity=CUBIT_FALSE) | RefEdge | |
| actuate_cubit_attrib(int attrib_type) | CubitAttribUser | |
| actuate_cubit_attrib(DLIList< RefEntity * >, int) | CubitAttribUser | [static] |
| add_compare_data(RefEntity *partner) | RefEntity | |
| add_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
| add_grouping_entity(GroupingEntity *) | BasicTopologyEntity | |
| add_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
| add_sense_entity(SenseEntity *) | BasicTopologyEntity | |
| add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
| angle_between(RefEdge *other_edge_ptr, RefFace *face_ptr) | RefEdge | |
| append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| assign_default_name(CubitBoolean user_setting=CUBIT_FALSE) | RefEntity | |
| auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE) | CubitAttribUser | |
| auto_read_cubit_attrib() | CubitAttribUser | |
| auto_update_cubit_attrib() | CubitAttribUser | |
| auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE) | CubitAttribUser | [static] |
| autoMergeStatus | RefEntity | [protected] |
| BasicTopologyEntity() | BasicTopologyEntity | [inline] |
| bodies(DLIList< Body * > &body_list) | TopologyEntity | |
| body() | TopologyEntity | |
| bounding_box() | BasicTopologyEntity | [virtual] |
| bridge_manager() const | TopologyEntity | [inline] |
| bridge_manager() | TopologyEntity | [inline] |
| can_modify() | RefEntity | [virtual] |
| center_point() | RefEdge | [virtual] |
| chains(DLIList< Chain * > &chain_list) | TopologyEntity | |
| change_to_parent_ref_entities(DLIList< RefEntity * > &ancestors) | RefEntity | [static] |
| children_mergeable() | RefEntity | [virtual] |
| ChildType typedef | RefEdge | |
| class_name() const | RefEdge | [inline, virtual] |
| clear_all_simple_attrib(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
| clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
| clear_simple_attribs() | CubitAttribUser | |
| clear_simple_attribs_set_to_actuate() | CubitAttribUser | |
| closest_point(CubitVector const &location, CubitVector &closest_location, CubitVector *tangent_ptr=NULL, CubitVector *curvature_ptr=NULL) | RefEdge | |
| closest_point_trimmed(CubitVector const &location, CubitVector &closest_location) | RefEdge | |
| closest_vertex(const CubitVector &point3) | RefEdge | |
| co_edge() | TopologyEntity | |
| co_edges(DLIList< CoEdge * > &co_edge_list) | TopologyEntity | |
| co_faces(DLIList< CoFace * > &co_face_list) | TopologyEntity | |
| co_vertices(DLIList< CoVertex * > &co_vertex_list) | TopologyEntity | |
| co_volumes(DLIList< CoVolume * > &co_volume_list) | TopologyEntity | |
| color(int value) | RefEntity | [virtual] |
| color() const | RefEntity | [virtual] |
| common_ref_face(RefEdge *otherRefEdgePtr) | RefEdge | |
| common_ref_faces(RefEdge *otherRefEdgePtr, DLIList< RefFace * > &common_face_list) | RefEdge | |
| common_ref_vertex(RefEdge *otherRefEdgePtr) | RefEdge | |
| common_ref_vertex(RefEdge *next_ref_edge, RefFace *ref_face_ptr) | RefEdge | |
| common_vertices(RefEdge *otherRefEdgePtr, DLIList< RefVertex * > &common_verts) | RefEdge | |
| comparison_found(RefEntity *partner) | RefEntity | |
| CubitAttribUser(CubitAttrib *=NULL) | CubitAttribUser | |
| CubitEntity() | CubitEntity | [inline] |
| CubitEventDispatcher class | CubitObservable | [friend] |
| CubitObservable() | CubitObservable | |
| CubitObservable(const CubitObservable &) | CubitObservable | [protected] |
| CubitObserver class | CubitObservable | [friend] |
| curve_center() | RefEdge | |
| dag_type() const | RefEdge | [inline, virtual] |
| RefEntity::dag_type(const std::type_info &) | RefEntity | [static] |
| RefEntity::dag_type(const char *cli_type_name) | RefEntity | [static] |
| deactivated(CubitBoolean flag) | TopologyEntity | |
| deactivated() const | TopologyEntity | |
| deactivatedStatus_ | TopologyEntity | [protected] |
| delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| delete_TD(ToolData *td) | ToolDataUser | [virtual] |
| dimension() const | RefEdge | [virtual] |
| disconnect_all_children(DLIList< TopologyEntity * > *children=0) | BasicTopologyEntity | [protected, virtual] |
| disconnect_all_parents(DLIList< TopologyEntity * > *parents=0) | BasicTopologyEntity | [protected, virtual] |
| disconnect_from_DAG() | TopologyEntity | |
| encountered_ | TopologyEntity | [protected] |
| end_coordinates() | RefEdge | |
| end_param() | RefEdge | |
| end_vertex() | RefEdge | |
| entity_name() const | RefEntity | [virtual] |
| entity_name(CubitString name) | RefEntity | |
| entity_names(DLIList< CubitString > &names) const | RefEntity | |
| entity_type_info() const | RefEdge | [inline, virtual] |
| entityId | CubitEntity | [protected] |
| evaluate_exterior_angle(double *exterior_angle) | RefEdge | |
| find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const | CubitAttribUser | |
| find_sense_entity(GroupingEntity *gpe) const | BasicTopologyEntity | |
| find_sense_entity(BasicTopologyEntity *bte) const | BasicTopologyEntity | |
| fraction_from_arc_length(RefVertex *root_vertex, double length) | RefEdge | |
| gather_bdy_entities(DLIList< RefEntity * > &entity_list, DLIList< RefEntity * > &bdy_list) | RefEntity | [static] |
| generate_default_name(CubitString &name) | RefEntity | |
| geometry_type() const | BasicTopologyEntity | |
| get_all_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | |
| get_all_child_ref_entities(DLIList< RefEntity * > &input_list, DLIList< RefEntity * > &output_list) | RefEntity | [static] |
| get_all_parent_ref_entities(DLIList< RefEntity * > &entity_list, const int get_bodies=CUBIT_FALSE) | RefEntity | |
| get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_arc_length() | RefEdge | |
| get_arc_length(const CubitVector &point1, const CubitVector &point2) | RefEdge | |
| get_arc_length(const CubitVector &point1, int whichEnd) | RefEdge | |
| get_by_name(const CubitString &name) | RefEntity | [static] |
| get_center_radius(CubitVector ¢er, double &radius) | RefEdge | [virtual] |
| get_chain_ptr() | RefEdge | |
| get_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | [virtual] |
| get_child_ref_entity_type() const | RefEntity | |
| get_child_ref_entity_type(DagType parent_type) | RefEntity | [static] |
| get_children(DLIList< TopologyEntity * > *list=0) const | BasicTopologyEntity | [virtual] |
| get_chord_length() | RefEdge | |
| get_class_name() | RefEdge | [inline, static] |
| get_co_edges(DLIList< CoEdge * > &co_edges_found_list, RefFace *input_ref_face_ptr=NULL) | RefEdge | |
| get_compare_partner() | RefEntity | |
| get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE) | CubitAttribUser | |
| get_cubit_attrib_list(DLIList< CubitAttrib * > &) | CubitAttribUser | |
| get_curve_ptr() | RefEdge | |
| get_curve_ptr() const | RefEdge | |
| get_entity_type_info(const char *entity_type) | RefEntity | [static] |
| get_first_grouping_entity_ptr() const | BasicTopologyEntity | [inline] |
| get_first_sense_entity_ptr() const | BasicTopologyEntity | [inline] |
| get_geometry_entity_ptr() const | BasicTopologyEntity | |
| get_geometry_query_engine() const | TopologyEntity | |
| get_graphics(GMem &polyline, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) | RefEdge | |
| get_grouping_entity_list(DLIList< GroupingEntity * > &groupingEntityList) const | BasicTopologyEntity | |
| get_interior_extrema(DLIList< CubitVector * > &interior_points, CubitSense &return_sense) const | RefEdge | |
| get_lower_param_bound() | RefEdge | [private] |
| get_mark() | RefEdge | [inline] |
| get_observer_list(DLIList< CubitObserver * > &observers) | CubitObservable | |
| get_other_curve(RefVertex *common_vertex, RefFace *ref_face_ptr) | RefEdge | |
| get_param_range(double &start_param, double &end_param) | RefEdge | |
| get_parent_ref_entities(DLIList< RefEntity * > &entity_list) | RefEdge | [virtual] |
| get_parent_ref_entity_type() const | RefEntity | |
| get_parent_ref_entity_type(DagType child_type) | RefEntity | [static] |
| get_parents(DLIList< TopologyEntity * > *list=0) const | BasicTopologyEntity | [virtual] |
| get_point_direction(CubitVector &origin, CubitVector &direction) | RefEdge | [virtual] |
| get_ref_class_name(const std::type_info &ref_type) | RefEntity | [static] |
| get_related_entity_list(const std::type_info &related_entity_type, DLIList< RefEntity * > &entity_list) | RefEntity | |
| get_sense_entities(DLIList< SenseEntity * > &result, GroupingEntity *in_this) | BasicTopologyEntity | |
| get_sense_entities(DLIList< SenseEntity * > &result, BasicTopologyEntity *in_this) | BasicTopologyEntity | |
| get_sense_entity_list(DLIList< SenseEntity * > &senseEntityList) const | BasicTopologyEntity | |
| get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
| get_two_co_edges(RefEdge *next_ref_edge, RefFace *ref_face_ptr, CoEdge *&co_edge_this, CoEdge *&co_edge_next) | RefEdge | |
| get_upper_param_bound() | RefEdge | [private] |
| headAttrib | CubitAttribUser | [protected] |
| id() const | CubitEntity | [virtual] |
| initialize() | RefEdge | [private] |
| is_child(RefEntity *entity) | RefEntity | [virtual] |
| is_directly_related(TopologyEntity *entity) | TopologyEntity | |
| is_mergeable(AutoMergeStatus val) | RefEntity | [virtual] |
| is_mergeable() | RefEntity | |
| is_merged() | RefEntity | |
| is_nonmanifold(GroupingEntity *in_this_parent) | BasicTopologyEntity | |
| is_parent(RefEntity *entity) | RefEntity | [virtual] |
| is_periodic() | RefEdge | |
| is_periodic(double &period) | RefEdge | |
| is_tolerant() | RefEdge | |
| is_transparent(int flag) | CubitEntity | [virtual] |
| is_transparent() const | CubitEntity | [virtual] |
| is_visible(int flag) | CubitEntity | [virtual] |
| is_visible() const | CubitEntity | [virtual] |
| join(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
| join(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
| length_from_u(double parameter1, double parameter2) | RefEdge | |
| listFlag | RefEntity | [protected] |
| local_tolerance(double value) | RefEntity | [inline] |
| local_tolerance(void) | RefEntity | [inline] |
| loops(DLIList< Loop * > &loop_list) | TopologyEntity | |
| marked(int value) | RefEntity | [inline, virtual] |
| marked() | RefEntity | [inline, virtual] |
| markedFlag | RefEdge | [private] |
| mColor | RefEntity | [protected] |
| measure() | RefEdge | [virtual] |
| measure_label() | RefEdge | [virtual] |
| meet(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
| meet(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
| merge_entity_names(RefEntity *dead_entity) | RefEntity | |
| merge_owner(RefEntity *deletable_entity) | CubitAttribUser | |
| merge_status() const | RefEntity | |
| mid_point(const CubitVector &point1, const CubitVector &point2, CubitVector &midPoint) | RefEdge | |
| mid_point(CubitVector &mid_point) | RefEdge | |
| ModelQueryEngine class | TopologyEntity | [friend] |
| move_to_curve(CubitVector &vector) | RefEdge | [virtual] |
| mSuppressEdgeLengthWarning | RefEdge | [private, static] |
| notify_observers(const CubitEvent *event) | CubitObservable | |
| notify_sub_all_observers(const GeometryEvent::Type &event) | RefEntity | |
| num_cubit_attrib() | CubitAttribUser | |
| num_loops() | TopologyEntity | |
| num_names() const | RefEntity | |
| num_of_common_ref_face(RefEdge *other_edge) | RefEdge | |
| num_parent_ref_entities() | RefEntity | |
| num_ref_edges() | TopologyEntity | |
| num_ref_faces() | TopologyEntity | |
| num_ref_vertices() | TopologyEntity | |
| num_ref_volumes() | TopologyEntity | |
| observerList | CubitObservable | [protected] |
| operator=(const RefEdge &) | RefEdge | [private] |
| CubitObservable::operator=(const CubitObservable &) | CubitObservable | [protected] |
| other_face(RefFace *not_face, RefVolume *ref_volume=NULL) | RefEdge | |
| other_vertex(RefVertex *refVertexPtr) | RefEdge | |
| ParentType typedef | RefEdge | |
| point_containment(const CubitVector &point) | RefEdge | |
| point_from_arc_length(double root_param, double arc_length, CubitVector &new_point) | RefEdge | |
| point_from_arc_length(const CubitVector &root_point, double arc_length, CubitVector &new_point) | RefEdge | |
| position_from_fraction(double fraction_along_curve, CubitVector &ouput_position) | RefEdge | |
| position_from_u(double u_value, CubitVector &output_position) | RefEdge | |
| query_append_children(DLIList< TopologyEntity * > &list) | BasicTopologyEntity | [protected, virtual] |
| query_append_parents(DLIList< TopologyEntity * > &list) | BasicTopologyEntity | [protected, virtual] |
| read_cubit_attrib(int attrib_type) | CubitAttribUser | |
| ref_edge() | TopologyEntity | |
| ref_edges(DLIList< RefEdge * > &ref_edge_list) | TopologyEntity | |
| ref_face() | TopologyEntity | |
| ref_faces(DLIList< RefFace * > &ref_face_list) | TopologyEntity | |
| ref_vertex() | TopologyEntity | |
| ref_vertices(DLIList< RefVertex * > &ref_vertex_list) | TopologyEntity | |
| ref_volume() | TopologyEntity | |
| ref_volumes(DLIList< RefVolume * > &ref_volume_list) | TopologyEntity | |
| RefEdge(Curve *curvePtr) | RefEdge | [protected] |
| RefEdge(const RefEdge &) | RefEdge | [private] |
| refEdgeClone | RefEdge | [private] |
| RefEntity() | RefEntity | |
| RefEntityFactory class | RefEdge | [friend] |
| relative_sense(RefEdge *ref_edge_ptr_2, double tolerance_factor, CubitSense *sense, CubitBoolean &spatially_equal, CubitBoolean force_merge=CUBIT_FALSE) | RefEdge | |
| remove_all_simple_attribute(TopologyBridge *bridge) | CubitAttribUser | |
| remove_attrib_geometry_entity(CubitAttrib *) | CubitAttribUser | |
| remove_child_link(TopologyEntity *entity_ptr) | BasicTopologyEntity | [protected, virtual] |
| remove_compare_data() | RefEntity | |
| remove_cubit_attrib(int attrib_type) | CubitAttribUser | |
| remove_cubit_attrib(CubitAttrib *) | CubitAttribUser | |
| remove_entity_name(CubitString const &name) | RefEntity | |
| remove_entity_names() | RefEntity | |
| remove_from_DAG(CubitBoolean recursive_flag=CUBIT_FALSE) | TopologyEntity | |
| remove_from_observers() | CubitObservable | [protected] |
| remove_grouping_entity(GroupingEntity *) | BasicTopologyEntity | |
| remove_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
| remove_sense_entity(SenseEntity *) | BasicTopologyEntity | |
| remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| remove_TD(ToolData *td) | ToolDataUser | [virtual] |
| reverse_tangent() | RefEdge | |
| reverse_topology() | RefEdge | [virtual] |
| sense(RefFace *face) | RefEdge | |
| set_geometry_entity_ptr(GeometryEntity *geometryEntityPtr) | BasicTopologyEntity | |
| set_grouping_entity_list(DLIList< GroupingEntity * > &new_list, DLIList< GroupingEntity * > &removed_list) | BasicTopologyEntity | |
| set_id(int i) | RefEntity | [virtual] |
| set_id(int i, CubitBoolean emit_event) | RefEntity | |
| set_mark(int set_value) | RefEdge | [inline] |
| set_topology_bridge(TopologyBridge *TB_ptr) | TopologyEntity | [protected] |
| set_updated_flag(CubitBoolean flag) | CubitAttribUser | |
| set_written_flag(CubitBoolean flag) | CubitAttribUser | |
| shells(DLIList< Shell * > &shell_list) | TopologyEntity | |
| split_owner(DLIList< CubitSimpleAttrib > &csa_list) | CubitAttribUser | |
| start_coordinates() | RefEdge | |
| start_param() | RefEdge | |
| start_vertex() | RefEdge | |
| suppress_edge_length_warning(bool flag) | RefEdge | [static] |
| switch_entity_names(RefEntity *other_entity) | RefEntity | |
| tangent(const CubitVector &point, CubitVector &tangent_vec) | RefEdge | |
| tangent(const CubitVector &point, CubitVector &tangent_vec, RefFace *ref_face_ptr) | RefEdge | |
| tangent(const CubitVector &point, CubitVector &tangent_vec, RefEdge *next_ref_edge, RefFace *ref_face_ptr) | RefEdge | |
| ToolDataUser() | ToolDataUser | [inline] |
| TopologyEntity() | TopologyEntity | |
| transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor) | CubitAttribUser | |
| u_from_arc_length(double root_param, double arc_length) | RefEdge | |
| u_from_position(const CubitVector &input_position) | RefEdge | |
| unmerged_bounding_box() | BasicTopologyEntity | [virtual] |
| update_auto_merge_state() | RefEntity | |
| update_cubit_attrib(int) | CubitAttribUser | |
| valence(RefEntity *parent=NULL) | RefEntity | |
| validate() | RefEdge | [virtual] |
| write_cubit_attrib_by_type(int attrib_type) | CubitAttribUser | |
| write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list) | CubitAttribUser | |
| write_cubit_attribs() | CubitAttribUser | |
| write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
| ~BasicTopologyEntity() | BasicTopologyEntity | [virtual] |
| ~CubitAttribUser() | CubitAttribUser | [virtual] |
| ~CubitEntity() | CubitEntity | [virtual] |
| ~CubitObservable() | CubitObservable | [virtual] |
| ~RefEdge() | RefEdge | [virtual] |
| ~RefEntity() | RefEntity | [virtual] |
| ~ToolDataUser() | ToolDataUser | [virtual] |
| ~TopologyEntity() | TopologyEntity | [virtual] |
