, including all inherited members.
| about_spatially_equal(RefVolume *ref_vol_ptr_2, double tolerance_factor) | RefVolume | |
| actuate_cubit_attrib(int attrib_type) | CubitAttribUser | |
| actuate_cubit_attrib(DLIList< RefEntity * >, int) | CubitAttribUser | [static] |
| add_compare_data(RefEntity *partner) | RefEntity | |
| add_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
| add_grouping_entity(GroupingEntity *) | BasicTopologyEntity | |
| add_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
| add_sense_entity(SenseEntity *) | BasicTopologyEntity | |
| add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
| append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| assign_default_name(CubitBoolean user_setting=CUBIT_FALSE) | RefEntity | |
| auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE) | CubitAttribUser | |
| auto_read_cubit_attrib() | CubitAttribUser | |
| auto_update_cubit_attrib() | CubitAttribUser | |
| auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE) | CubitAttribUser | [static] |
| autoMergeStatus | RefEntity | [protected] |
| BasicTopologyEntity() | BasicTopologyEntity | [inline] |
| bodies(DLIList< Body * > &body_list) | TopologyEntity | |
| body() | TopologyEntity | |
| bounding_box() | BasicTopologyEntity | [virtual] |
| bridge_manager() const | TopologyEntity | [inline] |
| bridge_manager() | TopologyEntity | [inline] |
| can_modify() | RefEntity | [virtual] |
| center_point() | RefVolume | [virtual] |
| chains(DLIList< Chain * > &chain_list) | TopologyEntity | |
| change_to_parent_ref_entities(DLIList< RefEntity * > &ancestors) | RefEntity | [static] |
| children_mergeable() | RefEntity | [virtual] |
| ChildType typedef | RefVolume | |
| class_name() const | RefVolume | [inline, virtual] |
| clear_all_simple_attrib(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
| clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
| clear_simple_attribs() | CubitAttribUser | |
| clear_simple_attribs_set_to_actuate() | CubitAttribUser | |
| co_edge() | TopologyEntity | |
| co_edges(DLIList< CoEdge * > &co_edge_list) | TopologyEntity | |
| co_faces(DLIList< CoFace * > &co_face_list) | TopologyEntity | |
| co_vertices(DLIList< CoVertex * > &co_vertex_list) | TopologyEntity | |
| co_volumes(DLIList< CoVolume * > &co_volume_list) | TopologyEntity | |
| color(int value) | RefEntity | [virtual] |
| color() const | RefEntity | [virtual] |
| comparison_found(RefEntity *partner) | RefEntity | |
| CubitAttribUser(CubitAttrib *=NULL) | CubitAttribUser | |
| CubitEntity() | CubitEntity | [inline] |
| CubitEventDispatcher class | CubitObservable | [friend] |
| CubitObservable() | CubitObservable | |
| CubitObservable(const CubitObservable &) | CubitObservable | [protected] |
| CubitObserver class | CubitObservable | [friend] |
| dag_type() const | RefVolume | [inline, virtual] |
| RefEntity::dag_type(const std::type_info &) | RefEntity | [static] |
| RefEntity::dag_type(const char *cli_type_name) | RefEntity | [static] |
| deactivated(CubitBoolean flag) | TopologyEntity | |
| deactivated() const | TopologyEntity | |
| deactivatedStatus_ | TopologyEntity | [protected] |
| delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| delete_TD(ToolData *td) | ToolDataUser | [virtual] |
| dimension() const | RefVolume | [virtual] |
| disconnect_all_children(DLIList< TopologyEntity * > *children=0) | BasicTopologyEntity | [protected, virtual] |
| disconnect_all_parents(DLIList< TopologyEntity * > *parents=0) | BasicTopologyEntity | [protected, virtual] |
| disconnect_from_DAG() | TopologyEntity | |
| encountered_ | TopologyEntity | [protected] |
| entity_name() const | RefEntity | [virtual] |
| entity_name(CubitString name) | RefEntity | |
| entity_names(DLIList< CubitString > &names) const | RefEntity | |
| entity_type_info() const | RefVolume | [inline, virtual] |
| entityId | CubitEntity | [protected] |
| find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const | CubitAttribUser | |
| find_sense_entity(GroupingEntity *gpe) const | BasicTopologyEntity | |
| find_sense_entity(BasicTopologyEntity *bte) const | BasicTopologyEntity | |
| gather_bdy_entities(DLIList< RefEntity * > &entity_list, DLIList< RefEntity * > &bdy_list) | RefEntity | [static] |
| generate_default_name(CubitString &name) | RefEntity | |
| genus() | RefVolume | |
| geometry_type() const | BasicTopologyEntity | |
| get_all_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | |
| get_all_child_ref_entities(DLIList< RefEntity * > &input_list, DLIList< RefEntity * > &output_list) | RefEntity | [static] |
| get_all_parent_ref_entities(DLIList< RefEntity * > &entity_list, const int get_bodies=CUBIT_FALSE) | RefEntity | |
| get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
| get_body_ptr() | RefVolume | |
| get_by_name(const CubitString &name) | RefEntity | [static] |
| get_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | [virtual] |
| get_child_ref_entity_type() const | RefEntity | |
| get_child_ref_entity_type(DagType parent_type) | RefEntity | [static] |
| get_children(DLIList< TopologyEntity * > *list=0) const | BasicTopologyEntity | [virtual] |
| get_class_name() | RefVolume | [inline, static] |
| get_compare_partner() | RefEntity | |
| get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE) | CubitAttribUser | |
| get_cubit_attrib_list(DLIList< CubitAttrib * > &) | CubitAttribUser | |
| get_entity_type_info(const char *entity_type) | RefEntity | [static] |
| get_first_grouping_entity_ptr() const | BasicTopologyEntity | [inline] |
| get_first_sense_entity_ptr() const | BasicTopologyEntity | [inline] |
| get_geometry_entity_ptr() const | BasicTopologyEntity | |
| get_geometry_query_engine() const | TopologyEntity | |
| get_grouping_entity_list(DLIList< GroupingEntity * > &groupingEntityList) const | BasicTopologyEntity | |
| get_lump_ptr() | RefVolume | |
| get_lump_ptr() const | RefVolume | |
| get_observer_list(DLIList< CubitObserver * > &observers) | CubitObservable | |
| get_parent_ref_entities(DLIList< RefEntity * > &entity_list) | RefVolume | [virtual] |
| get_parent_ref_entity_type() const | RefEntity | |
| get_parent_ref_entity_type(DagType child_type) | RefEntity | [static] |
| get_parents(DLIList< TopologyEntity * > *list=0) const | BasicTopologyEntity | [virtual] |
| get_ref_class_name(const std::type_info &ref_type) | RefEntity | [static] |
| get_related_entity_list(const std::type_info &related_entity_type, DLIList< RefEntity * > &entity_list) | RefEntity | |
| get_sense_entities(DLIList< SenseEntity * > &result, GroupingEntity *in_this) | BasicTopologyEntity | |
| get_sense_entities(DLIList< SenseEntity * > &result, BasicTopologyEntity *in_this) | BasicTopologyEntity | |
| get_sense_entity_list(DLIList< SenseEntity * > &senseEntityList) const | BasicTopologyEntity | |
| get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
| headAttrib | CubitAttribUser | [protected] |
| id() const | CubitEntity | [virtual] |
| initialize() | RefVolume | [private] |
| is_child(RefEntity *entity) | RefEntity | [virtual] |
| is_directly_related(TopologyEntity *entity) | TopologyEntity | |
| is_mergeable(AutoMergeStatus val) | RefEntity | [virtual] |
| is_mergeable() | RefEntity | |
| is_merged() | RefEntity | |
| is_nonmanifold(GroupingEntity *in_this_parent) | BasicTopologyEntity | |
| is_parent(RefEntity *entity) | RefEntity | [virtual] |
| is_sheet() | RefVolume | |
| is_transparent(int flag) | CubitEntity | [virtual] |
| is_transparent() const | CubitEntity | [virtual] |
| is_visible(int flag) | CubitEntity | [virtual] |
| is_visible() const | CubitEntity | [virtual] |
| join(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
| join(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
| listFlag | RefEntity | [protected] |
| local_tolerance(double value) | RefEntity | [inline] |
| local_tolerance(void) | RefEntity | [inline] |
| loops(DLIList< Loop * > &loop_list) | TopologyEntity | |
| marked(int value) | RefEntity | [inline, virtual] |
| marked() | RefEntity | [inline, virtual] |
| markedFlag | RefEntity | [protected] |
| mass_properties(CubitVector ¢roid, double &volume) | RefVolume | |
| mass_properties(CubitVector principal_axes[3], CubitVector &principal_moments, CubitVector ¢roid, double &volume) | RefVolume | |
| mColor | RefEntity | [protected] |
| measure() | BasicTopologyEntity | [virtual] |
| measure_label() | RefVolume | [virtual] |
| meet(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
| meet(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
| merge_entity_names(RefEntity *dead_entity) | RefEntity | |
| merge_owner(RefEntity *deletable_entity) | CubitAttribUser | |
| merge_status() const | RefEntity | |
| ModelQueryEngine class | TopologyEntity | [friend] |
| notify_observers(const CubitEvent *event) | CubitObservable | |
| notify_sub_all_observers(const GeometryEvent::Type &event) | RefEntity | |
| num_boundary_components() | RefVolume | |
| num_cubit_attrib() | CubitAttribUser | |
| num_loops() | TopologyEntity | |
| num_names() const | RefEntity | |
| num_parent_ref_entities() | RefEntity | |
| num_ref_edges() | TopologyEntity | |
| num_ref_faces() | TopologyEntity | |
| num_ref_vertices() | TopologyEntity | |
| num_ref_volumes() | TopologyEntity | |
| observerList | CubitObservable | [protected] |
| operator=(const RefVolume &) | RefVolume | [private] |
| CubitObservable::operator=(const CubitObservable &) | CubitObservable | [protected] |
| ParentType typedef | RefVolume | |
| query_append_children(DLIList< TopologyEntity * > &list) | BasicTopologyEntity | [protected, virtual] |
| query_append_parents(DLIList< TopologyEntity * > &list) | BasicTopologyEntity | [protected, virtual] |
| read_cubit_attrib(int attrib_type) | CubitAttribUser | |
| ref_edge() | TopologyEntity | |
| ref_edges(DLIList< RefEdge * > &ref_edge_list) | TopologyEntity | |
| ref_face() | TopologyEntity | |
| ref_faces(DLIList< RefFace * > &ref_face_list) | TopologyEntity | |
| ref_vertex() | TopologyEntity | |
| ref_vertices(DLIList< RefVertex * > &ref_vertex_list) | TopologyEntity | |
| ref_volume() | TopologyEntity | |
| ref_volumes(DLIList< RefVolume * > &ref_volume_list) | TopologyEntity | |
| RefEntity() | RefEntity | |
| RefEntityFactory class | RefVolume | [friend] |
| RefVolume(Lump *lumpPtr) | RefVolume | [protected] |
| RefVolume(const RefVolume &) | RefVolume | [private] |
| remove_all_simple_attribute(TopologyBridge *bridge) | CubitAttribUser | |
| remove_attrib_geometry_entity(CubitAttrib *) | CubitAttribUser | |
| remove_child_link(TopologyEntity *entity_ptr) | BasicTopologyEntity | [protected, virtual] |
| remove_compare_data() | RefEntity | |
| remove_cubit_attrib(int attrib_type) | CubitAttribUser | |
| remove_cubit_attrib(CubitAttrib *) | CubitAttribUser | |
| remove_entity_name(CubitString const &name) | RefEntity | |
| remove_entity_names() | RefEntity | |
| remove_from_DAG(CubitBoolean recursive_flag=CUBIT_FALSE) | TopologyEntity | |
| remove_from_observers() | CubitObservable | [protected] |
| remove_grouping_entity(GroupingEntity *) | BasicTopologyEntity | |
| remove_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
| remove_sense_entity(SenseEntity *) | BasicTopologyEntity | |
| remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
| remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
| remove_TD(ToolData *td) | ToolDataUser | [virtual] |
| reverse_topology() | TopologyEntity | [inline, virtual] |
| set_geometry_entity_ptr(GeometryEntity *geometryEntityPtr) | BasicTopologyEntity | |
| set_grouping_entity_list(DLIList< GroupingEntity * > &new_list, DLIList< GroupingEntity * > &removed_list) | BasicTopologyEntity | |
| set_id(int i) | RefEntity | [virtual] |
| set_id(int i, CubitBoolean emit_event) | RefEntity | |
| set_topology_bridge(TopologyBridge *TB_ptr) | TopologyEntity | [protected] |
| set_updated_flag(CubitBoolean flag) | CubitAttribUser | |
| set_written_flag(CubitBoolean flag) | CubitAttribUser | |
| shells(DLIList< Shell * > &shell_list) | TopologyEntity | |
| split_owner(DLIList< CubitSimpleAttrib > &csa_list) | CubitAttribUser | |
| switch_entity_names(RefEntity *other_entity) | RefEntity | |
| ToolDataUser() | ToolDataUser | [inline] |
| TopologyEntity() | TopologyEntity | |
| transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor) | CubitAttribUser | |
| unmerged_bounding_box() | BasicTopologyEntity | [virtual] |
| update_auto_merge_state() | RefEntity | |
| update_cubit_attrib(int) | CubitAttribUser | |
| valence(RefEntity *parent=NULL) | RefEntity | |
| validate() | RefVolume | [virtual] |
| write_cubit_attrib_by_type(int attrib_type) | CubitAttribUser | |
| write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list) | CubitAttribUser | |
| write_cubit_attribs() | CubitAttribUser | |
| write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
| ~BasicTopologyEntity() | BasicTopologyEntity | [virtual] |
| ~CubitAttribUser() | CubitAttribUser | [virtual] |
| ~CubitEntity() | CubitEntity | [virtual] |
| ~CubitObservable() | CubitObservable | [virtual] |
| ~RefEntity() | RefEntity | [virtual] |
| ~RefVolume() | RefVolume | [virtual] |
| ~ToolDataUser() | ToolDataUser | [virtual] |
| ~TopologyEntity() | TopologyEntity | [virtual] |
