, including all inherited members.
| add(PartitionCoEdge *coedge) | PartitionCurve | |
| append_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionCurve | [virtual] |
| bodysm() | TopologyBridge | |
| bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
| bounding_box() const | SegmentedCurve | [virtual] |
| bridge_manager() const | TopologyBridge | |
| bridge_manager(BridgeManager *manager) | TopologyBridge | |
| bridge_sense() | TopologyBridge | [inline] |
| center_point() | Curve | [inline, virtual] |
| ChildType typedef | Curve | |
| closest_point(CubitVector const &location, CubitVector &closest_location, CubitVector *tangent_ptr=NULL, CubitVector *curvature_ptr=NULL, double *param=NULL) | SegmentedCurve | [virtual] |
| closest_point_on_segment(const CubitVector &segment_base, const CubitVector &segment_direction, const CubitVector &from_position) | SegmentedCurve | [protected, static] |
| closest_point_trimmed(CubitVector const &from_pt, CubitVector &result_pt) | SegmentedCurve | [virtual] |
| closest_segment(CubitVector const &location, double *fraction_on_segment=NULL, CubitVector *closest_pt=NULL) | SegmentedCurve | [protected] |
| coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
| combine(PartitionCurve *dead_curve) | SegmentedCurve | [virtual] |
| construct(const CubitSimpleAttrib &attrib, PartitionEntity *parent) | SegmentedCurve | [static] |
| Curve() | Curve | |
| curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
| do_facet_cleanup() | PartitionCurve | |
| draw_facets(int color) | PartitionCurve | |
| end_param() | SegmentedCurve | [inline, virtual] |
| end_point() const | PartitionCurve | [inline] |
| end_point(PartitionPoint *point) | PartitionCurve | |
| fix_facet_data(PartitionCurve *new_curve) | PartitionCurve | |
| G1_discontinuous(double param, CubitVector *minus_tangent=NULL, CubitVector *plus_tangent=NULL) | SegmentedCurve | [virtual] |
| geometry_type() | Curve | [inline, virtual] |
| GeometryEntity() | GeometryEntity | [inline] |
| get_arc_length() | Curve | [inline, virtual] |
| get_arc_length(const CubitVector &point1, const CubitVector &point2) | Curve | [inline, virtual] |
| get_arc_length(const CubitVector &point1, const int which_end) | Curve | [inline, virtual] |
| get_center_radius(CubitVector ¢er, double &radius) | SegmentedCurve | [virtual] |
| get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
| get_children_virt(DLIList< TopologyBridge * > &) | PartitionCurve | [virtual] |
| get_ellipse_params(CubitVector ¢er, CubitVector &normal, CubitVector &major_axis, double &radius_ratio) const | SegmentedCurve | [virtual] |
| get_facet_data(DLIList< CubitFacetEdgeData * > &result_list) const | PartitionCurve | |
| get_geometry_query_engine() const | PartitionCurve | [virtual] |
| get_graphics(GMem &result, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) | SegmentedCurve | [virtual] |
| get_interior_extrema(DLIList< CubitVector * > &points, CubitSense &return_sense) | SegmentedCurve | [virtual] |
| get_param_range(double &lower_bound, double &upper_bound) | SegmentedCurve | [virtual] |
| get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
| get_parents_virt(DLIList< TopologyBridge * > &) | PartitionCurve | [virtual] |
| get_point_direction(CubitVector &origin, CubitVector &direction) | SegmentedCurve | [virtual] |
| get_save_topology(DLIList< int > &points) | PartitionCurve | [protected] |
| get_saved_id() const | GeometryEntity | [inline] |
| get_saved_names(std::vector< CubitString > &names) | GeometryEntity | |
| get_segments(DLIList< CubitVector * > &points) | SegmentedCurve | [virtual] |
| get_simple_attribute(DLIList< CubitSimpleAttrib > &) | PartitionCurve | [virtual] |
| get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &) | PartitionCurve | [virtual] |
| get_spline_params(bool &rational, int °ree, DLIList< CubitVector > &cntrl_pts, DLIList< double > &cntrl_pt_weights, DLIList< double > &knots, bool &spline_is_reversed) const | SegmentedCurve | [virtual] |
| has_facet_data() const | PartitionCurve | [inline] |
| is_in_surface(const PartitionSurface *surf, bool manifold_only=false) const | PartitionCurve | |
| is_linear() | SegmentedCurve | |
| is_nonmanifold(const PartitionSurface *in_this_surf) const | PartitionCurve | |
| is_periodic(double &period) | SegmentedCurve | [virtual] |
| is_periodic() const | SegmentedCurve | |
| is_position_on(const CubitVector &position) | SegmentedCurve | [virtual] |
| is_tolerant() | Curve | [inline, virtual] |
| layer() const | PartitionCurve | [inline, virtual] |
| length_from_u(double param1, double param2) | SegmentedCurve | [virtual] |
| loopsm() | TopologyBridge | |
| loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
| lump() | TopologyBridge | |
| lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
| mark | PartitionEntity | |
| MAX_TB_LAYER enum value | TopologyBridge | |
| measure() | SegmentedCurve | [virtual] |
| mid_point(const CubitVector &point1, const CubitVector &point2, CubitVector &mid_point) | Curve | [inline, virtual] |
| mid_point(CubitVector &mid_point) | Curve | [inline, virtual] |
| move_to_geometry(CubitVector &position) | PartitionCurve | [virtual] |
| move_to_geometry(CubitPoint *facetPoint) | PartitionCurve | |
| next_coedge(const PartitionCoEdge *prev=0) const | PartitionCurve | [inline] |
| next_curve(const PartitionPoint *about_this) const | PartitionCurve | [inline] |
| normalize_periodic_parameter(double &u) | SegmentedCurve | [protected] |
| notify_split(FacetEntity *old_entity, FacetEntity *new_entity) | PartitionCurve | [virtual] |
| num_coedges() const | PartitionCurve | |
| other_point(const PartitionPoint *pt) const | PartitionCurve | [inline] |
| owner() const | TopologyBridge | [inline] |
| owner(TBOwner *new_owner) | TopologyBridge | [inline] |
| PartitionCurve() | PartitionCurve | [protected] |
| partitioned_entity() const | PartitionEntity | [inline] |
| PartitionEntity() | PartitionEntity | [protected] |
| point_containment(const CubitVector &vect) | SegmentedCurve | [virtual] |
| point_count() const | SegmentedCurve | [virtual] |
| point_from_arc_length(double root_param, const double arc_length, CubitVector &new_point) | Curve | [virtual] |
| point_from_arc_length(const CubitVector &root_point, double const arc_length, CubitVector &new_point) | Curve | [virtual] |
| point_list | SegmentedCurve | [private] |
| points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
| position(int index) const | SegmentedCurve | [protected] |
| position_from_fraction(const double fraction_along_curve, CubitVector &output_position) | Curve | [inline, virtual] |
| position_from_u(double u_value, CubitVector &position) | SegmentedCurve | [virtual] |
| print_debug_info(const char *prefix, bool pss=true) const | SegmentedCurve | [virtual] |
| print_partitioned_entity(const char *prefix=0) const | PartitionEntity | |
| relative_sense(Curve *other_curve) | Curve | [virtual] |
| relax_to_geometry(CubitPoint *facet_point, const CubitVector *input_position=0) | PartitionEntity | |
| remove(PartitionCoEdge *coedge) | PartitionCurve | |
| remove_all_coedges() | PartitionCurve | |
| remove_all_simple_attribute_virt() | PartitionCurve | [virtual] |
| remove_dead_facet(CubitFacetEdgeData *edge) | PartitionCurve | |
| remove_facet_data() | PartitionCurve | |
| remove_simple_attribute_virt(const CubitSimpleAttrib &) | PartitionCurve | [virtual] |
| replace_facet(CubitFacetEdgeData *dead_facet, DLIList< CubitFacetEdgeData * > &new_facets) | PartitionCurve | |
| reverse_bridge_sense() | TopologyBridge | [inline] |
| reverse_point_order() | PartitionCurve | [protected] |
| reverse_sense() | SegmentedCurve | [virtual] |
| save(CubitSimpleAttrib &attrib) | SegmentedCurve | [virtual] |
| segment_from_u(double &u) | SegmentedCurve | [protected] |
| segment_length(int segment_no) const | SegmentedCurve | [protected] |
| SegmentedCurve(PartitionSurface *owning_surf, DLIList< CubitVector * > &segments) | SegmentedCurve | |
| SegmentedCurve(PartitionLump *owning_vol, DLIList< CubitVector * > &segments) | SegmentedCurve | |
| SegmentedCurve(PartitionEntity *owning_vol, const CubitSimpleAttrib &attrib, DLIList< int > &pass_back_vertex_conn) | SegmentedCurve | [private] |
| SegmentedCurve(SegmentedCurve *split_from, int num_points) | SegmentedCurve | [private] |
| set_facet_data(const DLIList< CubitFacetEdgeData * > &new_list) | PartitionCurve | |
| set_saved_id(int value) | GeometryEntity | [inline] |
| set_saved_names(const std::vector< CubitString > &names) | GeometryEntity | |
| shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
| split(double param) | SegmentedCurve | [virtual] |
| start_param() | SegmentedCurve | [inline, virtual] |
| start_point() const | PartitionCurve | [inline] |
| start_point(PartitionPoint *point) | PartitionCurve | |
| sub_entity_set() const | PartitionEntity | [inline] |
| surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
| topology_entity() const | TopologyBridge | |
| TopologyBridge() | TopologyBridge | [inline] |
| transform(const CubitTransformMatrix &) | SegmentedCurve | [virtual] |
| u_from_arc_length(double param, double length) | SegmentedCurve | [virtual] |
| u_from_position(const CubitVector &position) | SegmentedCurve | [virtual] |
| validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
| ~Curve() | Curve | [virtual] |
| ~GeometryEntity() | GeometryEntity | [virtual] |
| ~PartitionCurve() | PartitionCurve | [virtual] |
| ~PartitionEntity() | PartitionEntity | [virtual] |
| ~SegmentedCurve() | SegmentedCurve | [virtual] |
| ~TopologyBridge() | TopologyBridge | [virtual] |
