, including all inherited members.
| AdaptiveKDTree(Interface *iface) | moab::AdaptiveKDTree | |
| AdaptiveKDTree(Interface *iface, const Range &entities, EntityHandle *tree_root_set=NULL, FileOptions *opts=NULL) | moab::AdaptiveKDTree | |
| AdaptiveKDTreeIter class | moab::AdaptiveKDTree | [friend] |
| Axis enum name | moab::AdaptiveKDTree | |
| axisTag | moab::AdaptiveKDTree | [private] |
| best_subdivision_plane(int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, double eps) | moab::AdaptiveKDTree | [private] |
| best_subdivision_snap_plane(int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, std::vector< double > &tmp_data, double eps) | moab::AdaptiveKDTree | [private] |
| best_vertex_median_plane(int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, std::vector< double > &coords, double eps) | moab::AdaptiveKDTree | [private] |
| best_vertex_sample_plane(int num_planes, const AdaptiveKDTreeIter &iter, Range &best_left, Range &best_right, Range &best_both, AdaptiveKDTree::Plane &best_plane, std::vector< double > &coords, std::vector< EntityHandle > &indices, double eps) | moab::AdaptiveKDTree | [private] |
| boundBox | moab::Tree | [protected] |
| boxTag | moab::Tree | [protected] |
| boxTagName | moab::Tree | [protected] |
| build_tree(const Range &entities, EntityHandle *tree_root_set=NULL, FileOptions *options=NULL) | moab::AdaptiveKDTree | [virtual] |
| CandidatePlaneSet enum name | moab::AdaptiveKDTree | |
| cleanUp | moab::Tree | [protected] |
| closest_triangle(EntityHandle tree_root, const double from_coords[3], double closest_point_out[3], EntityHandle &triangle_out) | moab::AdaptiveKDTree | |
| compute_depth(EntityHandle root, unsigned int &min_depth, unsigned int &max_depth) | moab::AdaptiveKDTree | |
| create_root(const double box_min[3], const double box_max[3], EntityHandle &root_handle) | moab::Tree | |
| delete_tree_sets() | moab::Tree | |
| distance_search(const double *point, const double distance, std::vector< EntityHandle > &leaves_out, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, std::vector< double > *dists_out=NULL, std::vector< CartVect > *params_out=NULL, EntityHandle *start_node=NULL) | moab::AdaptiveKDTree | [virtual] |
| find_all_trees(Range &results) | moab::Tree | |
| find_close_triangle(EntityHandle root, const double from_point[3], double pt[3], EntityHandle &triangle) | moab::AdaptiveKDTree | [private] |
| get_bounding_box(BoundBox &box, EntityHandle *tree_node=NULL) const | moab::Tree | [inline, virtual] |
| get_box_tag(bool create_if_missing=true) | moab::Tree | [inline, protected] |
| get_eval() | moab::Tree | [inline] |
| get_info(EntityHandle root, double min[3], double max[3], unsigned int &dep) | moab::AdaptiveKDTree | [virtual] |
| get_last_iterator(EntityHandle tree_root, AdaptiveKDTreeIter &result) | moab::AdaptiveKDTree | |
| get_max_depth() | moab::Tree | [inline] |
| get_max_per_leaf() | moab::Tree | [inline] |
| get_split_plane(EntityHandle node, Plane &plane) | moab::AdaptiveKDTree | |
| get_sub_tree_iterator(EntityHandle tree_root, const double box_min[3], const double box_max[3], AdaptiveKDTreeIter &result) | moab::AdaptiveKDTree | |
| get_tree_iterator(EntityHandle tree_root, AdaptiveKDTreeIter &result) | moab::AdaptiveKDTree | |
| init() | moab::AdaptiveKDTree | [private] |
| intersect_children_with_elems(const Range &elems, AdaptiveKDTree::Plane plane, double eps, CartVect box_min, CartVect box_max, Range &left_tris, Range &right_tris, Range &both_tris, double &metric_value) | moab::AdaptiveKDTree | [private] |
| make_tag(Interface *iface, std::string name, TagType storage, DataType type, int count, void *default_val, Tag &tag_handle, std::vector< Tag > &created_tags) | moab::AdaptiveKDTree | [private] |
| maxDepth | moab::Tree | [protected] |
| maxPerLeaf | moab::Tree | [protected] |
| mbImpl | moab::Tree | [protected] |
| merge_leaf(AdaptiveKDTreeIter &iter) | moab::AdaptiveKDTree | |
| meshsetFlags | moab::Tree | [protected] |
| minWidth | moab::Tree | [protected] |
| moab() | moab::Tree | [inline] |
| moab() const | moab::Tree | [inline] |
| myEval | moab::Tree | [protected] |
| myRoot | moab::Tree | [protected] |
| parse_common_options(FileOptions &options) | moab::Tree | [protected] |
| parse_options(FileOptions &options) | moab::AdaptiveKDTree | [virtual] |
| planeSet | moab::AdaptiveKDTree | [private] |
| planeTag | moab::AdaptiveKDTree | [private] |
| point_search(const double *point, EntityHandle &leaf_out, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, bool *multiple_leaves=NULL, EntityHandle *start_node=NULL, CartVect *params=NULL) | moab::AdaptiveKDTree | [virtual] |
| point_search(const double *point, AdaptiveKDTreeIter &leaf_it, const double iter_tol=1.0e-10, const double inside_tol=1.0e-6, bool *multiple_leaves=NULL, EntityHandle *start_node=NULL) | moab::AdaptiveKDTree | |
| print() | moab::AdaptiveKDTree | [virtual] |
| radius | moab::AdaptiveKDTree | [private] |
| ray_intersect_triangles(EntityHandle tree_root, const double tolerance, const double ray_unit_dir[3], const double ray_base_pt[3], std::vector< EntityHandle > &triangles_out, std::vector< double > &distance_out, int result_count_limit=0, double distance_limit=-1.0) | moab::AdaptiveKDTree | |
| reset_tree() | moab::AdaptiveKDTree | [inline, virtual] |
| set_eval(ElemEvaluator *eval) | moab::Tree | [inline] |
| set_split_plane(EntityHandle node, const Plane &plane) | moab::AdaptiveKDTree | |
| sphere_intersect_triangles(EntityHandle tree_root, const double center[3], double radius, std::vector< EntityHandle > &triangles) | moab::AdaptiveKDTree | |
| spherical | moab::AdaptiveKDTree | [private] |
| split_leaf(AdaptiveKDTreeIter &leaf, Plane plane) | moab::AdaptiveKDTree | |
| split_leaf(AdaptiveKDTreeIter &leaf, Plane plane, EntityHandle &left_child, EntityHandle &right_child) | moab::AdaptiveKDTree | |
| split_leaf(AdaptiveKDTreeIter &leaf, Plane plane, const Range &left_entities, const Range &right_entities) | moab::AdaptiveKDTree | |
| split_leaf(AdaptiveKDTreeIter &leaf, Plane plane, const std::vector< EntityHandle > &left_entities, const std::vector< EntityHandle > &right_entities) | moab::AdaptiveKDTree | |
| splitsPerDir | moab::AdaptiveKDTree | [private] |
| SUBDIVISION enum value | moab::AdaptiveKDTree | |
| SUBDIVISION_SNAP enum value | moab::AdaptiveKDTree | |
| Tree(Interface *iface) | moab::Tree | [inline] |
| tree_stats() | moab::Tree | [inline] |
| tree_stats() const | moab::Tree | [inline] |
| treeDepth | moab::Tree | [protected] |
| treeName | moab::AdaptiveKDTree | [private, static] |
| treeStats | moab::Tree | [protected] |
| VERTEX_MEDIAN enum value | moab::AdaptiveKDTree | |
| VERTEX_SAMPLE enum value | moab::AdaptiveKDTree | |
| X enum value | moab::AdaptiveKDTree | |
| Y enum value | moab::AdaptiveKDTree | |
| Z enum value | moab::AdaptiveKDTree | |
| ~AdaptiveKDTree() | moab::AdaptiveKDTree | |
| ~Tree() | moab::Tree | [inline, virtual] |
