, including all inherited members.
| append_entities(EntityID count) | moab::EntitySequence | [protected] |
| create_data_subset(EntityHandle start_handle, EntityHandle end_handle, int num_sequence_arrays, unsigned const *bytes_per_element) const | moab::EntitySequence | [protected] |
| create_data_subset(EntityHandle start_handle, EntityHandle end_handle) const =0 | moab::EntitySequence | [pure virtual] |
| data() const | moab::EntitySequence | [inline] |
| data(SequenceData *ptr) | moab::EntitySequence | [inline] |
| ElementSequence(EntityHandle start, EntityID count, unsigned int nodes_per_elem, SequenceData *dat) | moab::ElementSequence | [inline] |
| ElementSequence(ElementSequence &split_from, EntityHandle here) | moab::ElementSequence | [inline, protected] |
| end_handle() const | moab::EntitySequence | [inline] |
| EntitySequence(EntityHandle h) | moab::EntitySequence | [inline, protected] |
| EntitySequence(EntitySequence &split_from, EntityHandle here) | moab::EntitySequence | [inline, protected] |
| EntitySequence(EntityHandle start, EntityID count, SequenceData *dat) | moab::EntitySequence | [inline] |
| get_connectivity(EntityHandle handle, std::vector< EntityHandle > &connect, bool topological=false) const =0 | moab::ElementSequence | [pure virtual] |
| get_connectivity(EntityHandle handle, EntityHandle const *&connect, int &connect_length, bool topological=false, std::vector< EntityHandle > *storage=0) const =0 | moab::ElementSequence | [pure virtual] |
| get_connectivity_array() const | moab::ElementSequence | [inline] |
| get_connectivity_array()=0 | moab::ElementSequence | [pure virtual] |
| get_const_memory_use(unsigned long &bytes_per_entity, unsigned long &size_of_sequence) const =0 | moab::EntitySequence | [pure virtual] |
| get_per_entity_memory_use(EntityHandle first, EntityHandle last) const | moab::EntitySequence | [virtual] |
| has_mid_edge_nodes() const | moab::ElementSequence | [inline] |
| has_mid_face_nodes() const | moab::ElementSequence | [inline] |
| has_mid_volume_nodes() const | moab::ElementSequence | [inline] |
| merge(EntitySequence &other) | moab::EntitySequence | [virtual] |
| nodes_per_element() const | moab::ElementSequence | [inline] |
| nodesPerElement | moab::ElementSequence | [private] |
| pop_back(EntityID count) | moab::EntitySequence | [virtual] |
| pop_front(EntityID count) | moab::EntitySequence | [virtual] |
| prepend_entities(EntityID count) | moab::EntitySequence | [protected] |
| set_connectivity(EntityHandle handle, EntityHandle const *connect, int connect_length)=0 | moab::ElementSequence | [pure virtual] |
| size() const | moab::EntitySequence | [inline] |
| split(EntityHandle here)=0 | moab::EntitySequence | [pure virtual] |
| start_handle() const | moab::EntitySequence | [inline] |
| type() const | moab::EntitySequence | [inline] |
| using_entire_data() const | moab::EntitySequence | |
| values_per_entity() const | moab::EntitySequence | [virtual] |
| ~ElementSequence() | moab::ElementSequence | [inline, virtual] |
| ~EntitySequence() | moab::EntitySequence | [inline, virtual] |
