, including all inherited members.
| add_intersection(EntityHandle set, EntityHandle tri, double dist, OrientedBoxTreeTool::IntersectSearchWindow &search_win) | moab::GQT_IntRegCtxt | [private] |
| add_mode1_intersection(EntityHandle set, EntityHandle facet, double dist, OrientedBoxTreeTool::IntersectSearchWindow &search_win) | moab::GQT_IntRegCtxt | [private] |
| append_intersection(EntityHandle set, EntityHandle facet, double dist) | moab::GQT_IntRegCtxt | [private] |
| desiredOrient | moab::GQT_IntRegCtxt | [private] |
| edge_node_piercing_intersect(const EntityHandle tri, const CartVect &ray_direction, const GeomUtil::intersection_type int_type, const std::vector< EntityHandle > &close_tris, const std::vector< int > &close_senses, const Interface *MBI, std::vector< EntityHandle > *neighborhood_tris=0) | moab::GQT_IntRegCtxt | [private] |
| facets | moab::OrientedBoxTreeTool::IntRegCtxt | [protected] |
| geomVol | moab::GQT_IntRegCtxt | [private] |
| get_facets() | moab::OrientedBoxTreeTool::IntRegCtxt | [inline] |
| get_intersections() | moab::OrientedBoxTreeTool::IntRegCtxt | [inline] |
| get_sets() | moab::OrientedBoxTreeTool::IntRegCtxt | [inline] |
| getDesiredOrient() | moab::GQT_IntRegCtxt | [inline, virtual] |
| GQT_IntRegCtxt(OrientedBoxTreeTool *obbtool, const double ray_point[3], const double ray_dir[3], double tolerance, int min_tolerance_intersections, const EntityHandle *root_set, const EntityHandle *geom_volume, const Tag *sense_tag, const int *desired_orient, const std::vector< EntityHandle > *prev_facets) | moab::GQT_IntRegCtxt | [inline] |
| in_neighborhoods(const EntityHandle tri) | moab::GQT_IntRegCtxt | [private] |
| in_prevFacets(const EntityHandle tri) | moab::GQT_IntRegCtxt | [private] |
| intersections | moab::OrientedBoxTreeTool::IntRegCtxt | [protected] |
| minTolInt | moab::GQT_IntRegCtxt | [private] |
| neighborhood | moab::GQT_IntRegCtxt | [private] |
| neighborhoods | moab::GQT_IntRegCtxt | [private] |
| prevFacets | moab::GQT_IntRegCtxt | [private] |
| ray_direction | moab::GQT_IntRegCtxt | [private] |
| ray_origin | moab::GQT_IntRegCtxt | [private] |
| register_intersection(EntityHandle set, EntityHandle triangle, double distance, OrientedBoxTreeTool::IntersectSearchWindow &, GeomUtil::intersection_type int_type) | moab::GQT_IntRegCtxt | [virtual] |
| rootSet | moab::GQT_IntRegCtxt | [private] |
| senseTag | moab::GQT_IntRegCtxt | [private] |
| set_intersection(int len_idx, EntityHandle set, EntityHandle facet, double dist) | moab::GQT_IntRegCtxt | [private] |
| sets | moab::OrientedBoxTreeTool::IntRegCtxt | [protected] |
| tol | moab::GQT_IntRegCtxt | [private] |
| tool | moab::GQT_IntRegCtxt | [private] |
| update_orient(EntityHandle set, int *surfTriOrient) | moab::GQT_IntRegCtxt | [virtual] |
