, including all inherited members.
| ccmio_to_moab_type(int ccm_type, EntityType &moab_type, bool &has_mid_nodes) | moab::ReadCCMIO | [private] |
| construct_cells(TupleList &face_map, SenseList &sense_map, TupleList &vert_map, std::map< int, int > &cell_topo_types, std::vector< EntityHandle > &new_cells) | moab::ReadCCMIO | [private] |
| create_cell_from_faces(std::vector< EntityHandle > &facehs, std::vector< int > &senses, EntityType this_type, bool has_mid_nodes, EntityHandle &cell) | moab::ReadCCMIO | [private] |
| factory(Interface *) | moab::ReadCCMIO | [static] |
| get_dbl_option(const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node) | moab::ReadCCMIO | [private] |
| get_int_option(const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node) | moab::ReadCCMIO | [private] |
| get_processors(CCMIOID stateID, CCMIOID &processorID, CCMIOID &verticesID, CCMIOID &topologyID, CCMIOID &solutionID, std::vector< CCMIOSize_t > &procs, bool &has_solution) | moab::ReadCCMIO | [private] |
| get_state(CCMIOID rootID, CCMIOID &problemID, CCMIOID &stateID) | moab::ReadCCMIO | [private] |
| get_str_option(const char *opt_str, EntityHandle seth, Tag &tag, CCMIOID node, const char *tag_name=NULL) | moab::ReadCCMIO | [private] |
| hasSolution | moab::ReadCCMIO | [private] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadCCMIO | [virtual] |
| load_matset_data(CCMIOID problemID) | moab::ReadCCMIO | [private] |
| load_metadata(CCMIOID rootID, CCMIOID problemID, CCMIOID stateID, CCMIOID processorID, const EntityHandle *file_set) | moab::ReadCCMIO | [private] |
| load_neuset_data(CCMIOID problemID) | moab::ReadCCMIO | [private] |
| make_faces(int *farray, TupleList &vert_map, std::vector< EntityHandle > &new_faces, int num_faces) | moab::ReadCCMIO | [private] |
| mbImpl | moab::ReadCCMIO | [private] |
| mBoundaryTypeTag | moab::ReadCCMIO | [private] |
| mColorIdxTag | moab::ReadCCMIO | [private] |
| mCreatingProgramTag | moab::ReadCCMIO | [private] |
| mDirichletSetTag | moab::ReadCCMIO | [private] |
| mFreeSurfaceMaterialTag | moab::ReadCCMIO | [private] |
| mGlobalIdTag | moab::ReadCCMIO | [private] |
| mGroupIdTag | moab::ReadCCMIO | [private] |
| mHasMidNodesTag | moab::ReadCCMIO | [private] |
| mLightMaterialTag | moab::ReadCCMIO | [private] |
| mMaterialIdTag | moab::ReadCCMIO | [private] |
| mMaterialSetTag | moab::ReadCCMIO | [private] |
| mMaterialTypeTag | moab::ReadCCMIO | [private] |
| mNameTag | moab::ReadCCMIO | [private] |
| mNeumannSetTag | moab::ReadCCMIO | [private] |
| mPorosityIdTag | moab::ReadCCMIO | [private] |
| mProcessorIdTag | moab::ReadCCMIO | [private] |
| mProstarRegionNumberTag | moab::ReadCCMIO | [private] |
| mRadiationTag | moab::ReadCCMIO | [private] |
| mSpinIdTag | moab::ReadCCMIO | [private] |
| mThicknessTag | moab::ReadCCMIO | [private] |
| newMatsets | moab::ReadCCMIO | [private] |
| newNeusets | moab::ReadCCMIO | [private] |
| read_all_faces(CCMIOID topologyID, TupleList &vert_map, TupleList &face_map, SenseList &sense_map, Range *new_faces) | moab::ReadCCMIO | [private] |
| read_cells(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, TupleList &vert_map, Range *new_cells) | moab::ReadCCMIO | [private] |
| read_faces(CCMIOID faceID, CCMIOEntity bdy_or_int, TupleList &vert_map, TupleList &face_map, SenseList &sense_map, Range *new_faces) | moab::ReadCCMIO | [private] |
| read_gids_and_types(CCMIOID problemID, CCMIOID topologyID, std::vector< EntityHandle > &cells) | moab::ReadCCMIO | [private] |
| read_processor(CCMIOID rootID, CCMIOID problemID, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, CCMIOSize_t proc, Range *new_ents) | moab::ReadCCMIO | [private] |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::ReadCCMIO | [private, virtual] |
| read_topology_types(CCMIOID &topologyID, std::map< int, int > &cell_topo_types) | moab::ReadCCMIO | [private] |
| read_vertices(CCMIOSize_t proc, CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID, Range *verts, TupleList &vert_map) | moab::ReadCCMIO | [private] |
| ReadCCMIO(Interface *impl) | moab::ReadCCMIO | |
| readMeshIface | moab::ReadCCMIO | [private] |
| SenseList typedef | moab::ReadCCMIO | |
| TupleList typedef | moab::ReadCCMIO | |
| ~ReadCCMIO() | moab::ReadCCMIO | [virtual] |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
