, including all inherited members.
| category_tag | moab::ReadCGM | [private] |
| create_curve_facets(std::map< RefEntity *, EntityHandle > &curve_map, std::map< RefEntity *, EntityHandle > &vertex_map, int norm_tol, double faceting_tol, bool verbose_warn=false, bool fatal_on_curves=false) | moab::ReadCGM | [private] |
| create_entity_sets(std::map< RefEntity *, EntityHandle >(&entmap)[5]) | moab::ReadCGM | [private] |
| create_group_entsets(std::map< RefEntity *, EntityHandle > &group_map) | moab::ReadCGM | [private] |
| create_surface_facets(std::map< RefEntity *, EntityHandle > &surface_map, std::map< RefEntity *, EntityHandle > &vertex_map, int norm_tol, double facet_tol, double length_tol) | moab::ReadCGM | [private] |
| create_topology(std::map< RefEntity *, EntityHandle >(&entitymap)[5]) | moab::ReadCGM | [private] |
| create_vertices(std::map< RefEntity *, EntityHandle > &vertex_map) | moab::ReadCGM | [private] |
| dump_fail_counts() | moab::ReadCGM | [private] |
| faceting_tol_tag | moab::ReadCGM | [private] |
| factory(Interface *) | moab::ReadCGM | [static] |
| failed_curve_count | moab::ReadCGM | [private] |
| failed_curves | moab::ReadCGM | [private] |
| failed_surface_count | moab::ReadCGM | [private] |
| failed_surfaces | moab::ReadCGM | [private] |
| geom_tag | moab::ReadCGM | [private] |
| geometry_resabs_tag | moab::ReadCGM | [private] |
| get_failed_curve_count() | moab::ReadCGM | |
| get_failed_surface_count() | moab::ReadCGM | |
| get_geom_file_type(const char *filename) | moab::ReadCGM | [private] |
| get_geom_fptr_type(FILE *file) | moab::ReadCGM | [private] |
| id_tag | moab::ReadCGM | [private] |
| is_cubit_file(FILE *file) | moab::ReadCGM | [private] |
| is_facet_file(FILE *file) | moab::ReadCGM | [private] |
| is_iges_file(FILE *file) | moab::ReadCGM | [private] |
| is_occ_brep_file(FILE *file) | moab::ReadCGM | [private] |
| is_step_file(FILE *file) | moab::ReadCGM | [private] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadCGM | [virtual] |
| mdbImpl | moab::ReadCGM | [private] |
| myGeomTool | moab::ReadCGM | [private] |
| name_tag | moab::ReadCGM | [private] |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::ReadCGM | [virtual] |
| ReadCGM(Interface *impl=NULL) | moab::ReadCGM | |
| readUtilIface | moab::ReadCGM | [private] |
| set_cgm_attributes(bool const act_attributes, bool const verbose) | moab::ReadCGM | [private] |
| set_options(const FileOptions &opts, int &norm_tol, double &faceting_tol, double &len_tol, bool &act_att, bool &verbose_warnings, bool &fatal_on_curves) | moab::ReadCGM | [private] |
| store_curve_senses(std::map< RefEntity *, EntityHandle > &curve_map, std::map< RefEntity *, EntityHandle > &surface_map) | moab::ReadCGM | [private] |
| store_group_content(std::map< RefEntity *, EntityHandle >(&entitymap)[5]) | moab::ReadCGM | [private] |
| store_groups(std::map< RefEntity *, EntityHandle >(&entitymap)[5]) | moab::ReadCGM | [private] |
| store_surface_senses(std::map< RefEntity *, EntityHandle > &surface_map, std::map< RefEntity *, EntityHandle > &volume_map) | moab::ReadCGM | [private] |
| tokenize(const std::string &str, std::vector< std::string > &tokens, const char *delimiters) | moab::ReadCGM | |
| ~ReadCGM() | moab::ReadCGM | [virtual] |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
