, including all inherited members.
| blocksLoading | moab::ReadNCDF | [private] |
| CPU_WORD_SIZE | moab::ReadNCDF | [private] |
| create_sideset_element(const std::vector< EntityHandle > &, EntityType, EntityHandle &, int &) | moab::ReadNCDF | [private] |
| create_ss_elements(int *element_ids, int *side_list, int num_sides, int num_dist_factors, std::vector< EntityHandle > &entities_to_add, std::vector< EntityHandle > &reverse_entities, std::vector< double > &dist_factor_vector, int ss_seq_id) | moab::ReadNCDF | [private] |
| dimension_exists(const char *attrib_name) | moab::ReadNCDF | [private] |
| exodus_file() | moab::ReadNCDF | [private] |
| exodusFile | moab::ReadNCDF | [private] |
| faceBlocksLoading | moab::ReadNCDF | [private] |
| factory(Interface *) | moab::ReadNCDF | [static] |
| find_side_element_type(const int element_id, ExoIIElementType &type, ReadBlockData &block_data, int &df_index, int side_id) | moab::ReadNCDF | [private] |
| get_number_nodes(EntityHandle handle) | moab::ReadNCDF | [private] |
| get_type(char *exo_element_type, EntityType &elem_type) | moab::ReadNCDF | [private] |
| get_type(EntityType &elem_type, std::string &exo_element_type) | moab::ReadNCDF | [private] |
| initRange | moab::ReadNCDF | [private] |
| IO_WORD_SIZE | moab::ReadNCDF | [private] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadNCDF | [virtual] |
| max_line_length | moab::ReadNCDF | [private] |
| max_str_length | moab::ReadNCDF | [private] |
| mCurrentMeshHandle | moab::ReadNCDF | [private] |
| mdbImpl | moab::ReadNCDF | [private] |
| mDirichletSetTag | moab::ReadNCDF | [private] |
| mDistFactorTag | moab::ReadNCDF | [private] |
| mGlobalIdTag | moab::ReadNCDF | [private] |
| mHasMidNodesTag | moab::ReadNCDF | [private] |
| mMaterialSetTag | moab::ReadNCDF | [private] |
| mNeumannSetTag | moab::ReadNCDF | [private] |
| mQaRecordTag | moab::ReadNCDF | [private] |
| ncFile | moab::ReadNCDF | [private] |
| nodesInLoadedBlocks | moab::ReadNCDF | [private] |
| number_dimensions() | moab::ReadNCDF | [inline, private] |
| numberDimensions_loading | moab::ReadNCDF | [private] |
| numberElementBlocks_loading | moab::ReadNCDF | [private] |
| numberElements_loading | moab::ReadNCDF | [private] |
| numberFaceBlocks_loading | moab::ReadNCDF | [private] |
| numberNodes_loading | moab::ReadNCDF | [private] |
| numberNodeSets_loading | moab::ReadNCDF | [private] |
| numberSideSets_loading | moab::ReadNCDF | [private] |
| polyfaces | moab::ReadNCDF | [private] |
| read_block_headers(const int *blocks_to_load, const int num_blocks) | moab::ReadNCDF | [private] |
| read_elements(const Tag *file_id_tag) | moab::ReadNCDF | [private] |
| read_exodus_header() | moab::ReadNCDF | [private] |
| read_face_blocks_headers() | moab::ReadNCDF | [private] |
| read_global_ids() | moab::ReadNCDF | [private] |
| read_nodes(const Tag *file_id_tag) | moab::ReadNCDF | [private] |
| read_nodesets() | moab::ReadNCDF | [private] |
| read_polyhedra_faces() | moab::ReadNCDF | [private] |
| read_qa_information(std::vector< std::string > &qa_record_list) | moab::ReadNCDF | [private] |
| read_qa_records(EntityHandle file_set) | moab::ReadNCDF | [private] |
| read_qa_string(char *string, int record_number, int record_position) | moab::ReadNCDF | [private] |
| read_sidesets() | moab::ReadNCDF | [private] |
| read_tag_values(const char *file_name, const char *tag_name, const FileOptions &opts, std::vector< int > &tag_values_out, const SubsetList *subset_list=0) | moab::ReadNCDF | [virtual] |
| readMeshIface | moab::ReadNCDF | [private] |
| ReadNCDF(Interface *impl=NULL) | moab::ReadNCDF | |
| reset() | moab::ReadNCDF | [private] |
| tokenize(const std::string &str, std::vector< std::string > &tokens, const char *delimiters) | moab::ReadNCDF | |
| update(const char *exodus_file_name, const FileOptions &opts, const int num_blocks, const int *blocks_to_load, const EntityHandle file_set) | moab::ReadNCDF | |
| vertexOffset | moab::ReadNCDF | [private] |
| ~ReaderIface() | moab::ReaderIface | [inline, virtual] |
| ~ReadNCDF() | moab::ReadNCDF | [virtual] |
