, including all inherited members.
| create_partition_sets(std::string &ptag_name, EntityHandle file_set) | moab::ReadParallel | [protected] |
| delete_nonlocal_entities(std::string &ptag_name, std::vector< int > &ptag_vals, bool distribute, EntityHandle file_set) | moab::ReadParallel | |
| delete_nonlocal_entities(EntityHandle file_set) | moab::ReadParallel | |
| factory(Interface *) | moab::ReadParallel | [static] |
| load_file(const char *file_name, const EntityHandle *file_set, const FileOptions &opts, const ReaderIface::SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadParallel | [inline] |
| load_file(const char **file_names, const int num_files, const EntityHandle *file_set, const FileOptions &opts, const ReaderIface::SubsetList *subset_list=0, const Tag *file_id_tag=0) | moab::ReadParallel | |
| load_file(const char **file_names, const int num_files, const EntityHandle *file_set, int parallel_mode, std::string &partition_tag_name, std::vector< int > &partition_tag_vals, bool distrib, bool partition_by_rank, std::vector< int > &pa_vec, const FileOptions &opts, const ReaderIface::SubsetList *subset_list, const Tag *file_id_tag, const int reader_rank, const bool cputime, const int resolve_dim, const int shared_dim, const int ghost_dim, const int bridge_dim, const int num_layers, const int addl_ents) | moab::ReadParallel | |
| mbImpl | moab::ReadParallel | [private] |
| mError | moab::ReadParallel | [private] |
| myDebug | moab::ReadParallel | [private] |
| myPcomm | moab::ReadParallel | [private] |
| PA_AUGMENT_SETS_WITH_GHOSTS enum value | moab::ReadParallel | |
| PA_BROADCAST enum value | moab::ReadParallel | |
| PA_CHECK_GIDS_SERIAL enum value | moab::ReadParallel | |
| PA_CORRECT_THIN_GHOSTS enum value | moab::ReadParallel | |
| PA_CREATE_TRIVIAL_PARTITION enum value | moab::ReadParallel | |
| PA_DELETE_NONLOCAL enum value | moab::ReadParallel | |
| PA_EXCHANGE_GHOSTS enum value | moab::ReadParallel | |
| PA_GET_FILESET_ENTS enum value | moab::ReadParallel | |
| PA_PRINT_PARALLEL enum value | moab::ReadParallel | |
| PA_READ enum value | moab::ReadParallel | |
| PA_READ_PART enum value | moab::ReadParallel | |
| PA_RESOLVE_SHARED_ENTS enum value | moab::ReadParallel | |
| PA_RESOLVE_SHARED_SETS enum value | moab::ReadParallel | |
| ParallelActions enum name | moab::ReadParallel | |
| ParallelActionsNames | moab::ReadParallel | [static] |
| ParallelOpts enum name | moab::ReadParallel | |
| parallelOptsNames | moab::ReadParallel | [static] |
| POPT_BCAST enum value | moab::ReadParallel | |
| POPT_BCAST_DELETE enum value | moab::ReadParallel | |
| POPT_DEFAULT enum value | moab::ReadParallel | |
| POPT_NONE enum value | moab::ReadParallel | |
| POPT_READ_DELETE enum value | moab::ReadParallel | |
| POPT_READ_PART enum value | moab::ReadParallel | |
| ReadParallel(Interface *impl=NULL, ParallelComm *pc=NULL) | moab::ReadParallel | |
| ~ReadParallel() | moab::ReadParallel | [inline, virtual] |
