, including all inherited members.
| add_box(ScdBox *box) | moab::ScdInterface | [protected] |
| assign_global_ids(ScdBox *box) | moab::ScdInterface | [private] |
| box_dims_tag(bool create_if_missing=true) | moab::ScdInterface | |
| box_periodic_tag(bool create_if_missing=true) | moab::ScdInterface | |
| box_set_tag(bool create_if_missing=true) | moab::ScdInterface | |
| boxDimsTag | moab::ScdInterface | [private] |
| boxPeriodicTag | moab::ScdInterface | [private] |
| boxSetTag | moab::ScdInterface | [private] |
| compute_partition(int np, int nr, const ScdParData &par_data, int *ldims, int *lperiodic=NULL, int *pdims=NULL) | moab::ScdInterface | [inline, static] |
| compute_partition_alljkbal(int np, int nr, const int gijk[6], const int *const gperiodic, int *lijk, int *lperiodic, int *pijk) | moab::ScdInterface | [inline, private, static] |
| compute_partition_alljorkori(int np, int nr, const int gijk[6], const int *const gperiodic, int *lijk, int *lperiodic, int *pijk) | moab::ScdInterface | [inline, private, static] |
| compute_partition_sqij(int np, int nr, const int gijk[6], const int *const gperiodic, int *lijk, int *lperiodic, int *pijk) | moab::ScdInterface | [inline, private, static] |
| compute_partition_sqijk(int np, int nr, const int gijk[6], const int *const gperiodic, int *lijk, int *lperiodic, int *pijk) | moab::ScdInterface | [inline, private, static] |
| compute_partition_sqjk(int np, int nr, const int gijk[6], const int *const gperiodic, int *lijk, int *lperiodic, int *pijk) | moab::ScdInterface | [inline, private, static] |
| construct_box(HomCoord low, HomCoord high, const double *const coords, unsigned int num_coords, ScdBox *&new_box, int *const lperiodic=NULL, ScdParData *const par_data=NULL, bool assign_global_ids=false, int resolve_shared_ents=-1) | moab::ScdInterface | |
| create_box_set(const HomCoord &low, const HomCoord &high, EntityHandle &scd_set, int *is_periodic=NULL) | moab::ScdInterface | [private] |
| create_scd_sequence(const HomCoord &low, const HomCoord &high, EntityType type, int starting_id, ScdBox *&new_box, int *is_periodic=NULL) | moab::ScdInterface | |
| find_boxes(std::vector< ScdBox * > &boxes) | moab::ScdInterface | |
| find_boxes(Range &boxes) | moab::ScdInterface | |
| get_boxes(std::vector< ScdBox * > &boxes) | moab::ScdInterface | |
| get_indices(const int *const ldims, const int *const rdims, const int *const across_bdy, int *face_dims, std::vector< int > &shared_indices) | moab::ScdInterface | [inline, private, static] |
| get_neighbor(int np, int nr, const ScdParData &spd, const int *const dijk, int &pto, int *rdims, int *facedims, int *across_bdy) | moab::ScdInterface | [inline, static] |
| get_neighbor_alljkbal(int np, int pfrom, const int *const gdims, const int *const gperiodic, const int *const dijk, int &pto, int *rdims, int *facedims, int *across_bdy) | moab::ScdInterface | [private, static] |
| get_neighbor_alljorkori(int np, int pfrom, const int *const gdims, const int *const gperiodic, const int *const dijk, int &pto, int *rdims, int *facedims, int *across_bdy) | moab::ScdInterface | [private, static] |
| get_neighbor_sqij(int np, int pfrom, const int *const gdims, const int *const gperiodic, const int *const dijk, int &pto, int *rdims, int *facedims, int *across_bdy) | moab::ScdInterface | [private, static] |
| get_neighbor_sqijk(int np, int pfrom, const int *const gdims, const int *const gperiodic, const int *const dijk, int &pto, int *rdims, int *facedims, int *across_bdy) | moab::ScdInterface | [private, static] |
| get_neighbor_sqjk(int np, int pfrom, const int *const gdims, const int *const gperiodic, const int *const dijk, int &pto, int *rdims, int *facedims, int *across_bdy) | moab::ScdInterface | [private, static] |
| get_scd_box(EntityHandle eh) | moab::ScdInterface | |
| get_shared_vertices(ParallelComm *pcomm, ScdBox *box, std::vector< int > &procs, std::vector< int > &offsets, std::vector< int > &shared_indices) | moab::ScdInterface | [private, static] |
| global_box_dims_tag(bool create_if_missing=true) | moab::ScdInterface | |
| globalBoxDimsTag | moab::ScdInterface | [private] |
| gtol(const int *gijk, int i, int j, int k) | moab::ScdInterface | [inline, private, static] |
| impl() const | moab::ScdInterface | |
| mbImpl | moab::ScdInterface | [private] |
| part_method_tag(bool create_if_missing=true) | moab::ScdInterface | |
| partMethodTag | moab::ScdInterface | [private] |
| remove_box(ScdBox *box) | moab::ScdInterface | [protected] |
| ScdBox class | moab::ScdInterface | [friend] |
| scdBoxes | moab::ScdInterface | [private] |
| ScdInterface(Interface *impl, bool find_boxes=false) | moab::ScdInterface | |
| searchedBoxes | moab::ScdInterface | [private] |
| tag_shared_vertices(ParallelComm *pcomm, EntityHandle seth) | moab::ScdInterface | [inline] |
| tag_shared_vertices(ParallelComm *pcomm, ScdBox *box) | moab::ScdInterface | |
| ~ScdInterface() | moab::ScdInterface | |
