, including all inherited members.
| add_vsequence(EntitySequence *vert_seq, EntitySequence *elem_seq, const HomCoord &p1, const HomCoord &q1, const HomCoord &p2, const HomCoord &q2, const HomCoord &p3, const HomCoord &q3, bool bb_input=false, const HomCoord *bb_min=NULL, const HomCoord *bb_max=NULL) | moab::SequenceManager | |
| allocate_mesh_set(EntityHandle at_this_handle, unsigned flags) | moab::SequenceManager | |
| check_valid_entities(Error *error_handler, const Range &entities) const | moab::SequenceManager | |
| check_valid_entities(Error *error_handler, const EntityHandle entities[], size_t num_entities, bool root_set_okay=false) const | moab::SequenceManager | |
| clear() | moab::SequenceManager | |
| create_element(EntityType type, const EntityHandle *conn_array, unsigned num_vertices, EntityHandle &handle_out) | moab::SequenceManager | |
| create_entity_sequence(EntityType type, EntityID num_entities, int nodes_per_entity, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out, int sequence_size) | moab::SequenceManager | |
| create_mesh_set(unsigned flags, EntityHandle &handle_out) | moab::SequenceManager | |
| create_meshset_sequence(EntityID num_sets, EntityID start_id_hint, const unsigned *flags, EntityHandle &first_handle_out, EntitySequence *&sequence_out) | moab::SequenceManager | |
| create_meshset_sequence(EntityID num_sets, EntityID start_id_hint, unsigned flags, EntityHandle &first_handle_out, EntitySequence *&sequence_out) | moab::SequenceManager | |
| create_scd_sequence(int imin, int jmin, int kmin, int imax, int jmax, int kmax, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out, int *is_periodic=NULL) | moab::SequenceManager | |
| create_scd_sequence(const HomCoord &coord_min, const HomCoord &coord_max, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out, int *is_periodic=NULL) | moab::SequenceManager | |
| create_sweep_sequence(int imin, int jmin, int kmin, int imax, int jmax, int kmax, int *Cq, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out) | moab::SequenceManager | |
| create_sweep_sequence(const HomCoord &coord_min, const HomCoord &coord_max, int *Cq, EntityType type, EntityID start_id_hint, EntityHandle &first_handle_out, EntitySequence *&sequence_out) | moab::SequenceManager | |
| create_vertex(const double coords[3], EntityHandle &handle_out) | moab::SequenceManager | |
| DEFAULT_ELEMENT_SEQUENCE_SIZE | moab::SequenceManager | [static] |
| DEFAULT_MESHSET_SEQUENCE_SIZE | moab::SequenceManager | [static] |
| default_poly_sequence_size(int entity_connectivity_length) | moab::SequenceManager | [static] |
| DEFAULT_POLY_SEQUENCE_SIZE | moab::SequenceManager | [static] |
| DEFAULT_VERTEX_SEQUENCE_SIZE | moab::SequenceManager | [static] |
| delete_entities(Error *error_handler, const Range &entities) | moab::SequenceManager | |
| delete_entity(Error *error_handler, EntityHandle entity) | moab::SequenceManager | |
| entity_map(EntityType type) | moab::SequenceManager | [inline] |
| entity_map(EntityType type) const | moab::SequenceManager | [inline] |
| find(EntityHandle handle, EntitySequence *&sequence_out) | moab::SequenceManager | [inline] |
| find(EntityHandle handle, const EntitySequence *&sequence_out) const | moab::SequenceManager | [inline] |
| get_entities(EntityType type, Range &entities_out) const | moab::SequenceManager | [inline] |
| get_entities(Range &entities_out) const | moab::SequenceManager | |
| get_entities(EntityType type, std::vector< EntityHandle > &entities_out) const | moab::SequenceManager | [inline] |
| get_entities(std::vector< EntityHandle > &entities_out) const | moab::SequenceManager | |
| get_last_accessed_sequence(EntityType type) const | moab::SequenceManager | [inline] |
| get_memory_use(unsigned long long &total_entity_storage, unsigned long long &total_storage) const | moab::SequenceManager | |
| get_memory_use(EntityType type, unsigned long long &total_entity_storage, unsigned long long &total_storage) const | moab::SequenceManager | |
| get_memory_use(const Range &entities, unsigned long long &total_entity_storage, unsigned long long &total_amortized_storage) const | moab::SequenceManager | |
| get_number_entities(EntityType type) const | moab::SequenceManager | [inline] |
| get_number_entities() const | moab::SequenceManager | |
| get_sequence_multiplier() const | moab::SequenceManager | [inline] |
| new_sequence_size(EntityHandle start_handle, EntityID requested_size, int sequence_size) const | moab::SequenceManager | |
| release_tag_array(Error *error_handler, int id, bool release_id) | moab::SequenceManager | |
| replace_subsequence(EntitySequence *new_seq) | moab::SequenceManager | |
| reserve_tag_array(Error *error_handler, int tag_size, int &array_id_out) | moab::SequenceManager | |
| sequence_multiplier | moab::SequenceManager | [private] |
| sequence_start_handle(EntityType type, EntityID entity_count, int values_per_entity, EntityID start_id_hint, SequenceData *&data_out, EntityID &data_size) | moab::SequenceManager | [private] |
| SequenceManager(double default_seq_multiplier=1.0) | moab::SequenceManager | [inline] |
| set_sequence_multiplier(double factor) | moab::SequenceManager | [inline] |
| tagSizes | moab::SequenceManager | [private] |
| trim_sequence_block(EntityHandle start_handle, EntityHandle &end_handle_in_out, unsigned maximum_sequence_size) | moab::SequenceManager | [private] |
| typeData | moab::SequenceManager | [private] |
| ~SequenceManager() | moab::SequenceManager | |
