MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 // Copyright (c) 2010, Lawrence Livermore National Security, LLC. Produced at 00002 // the Lawrence Livermore National Laboratory. LLNL-CODE-443211. All Rights 00003 // reserved. See file COPYRIGHT for details. 00004 // 00005 // This file is part of the MFEM library. For more information and source code 00006 // availability see http://mfem.org. 00007 // 00008 // MFEM is free software; you can redistribute it and/or modify it under the 00009 // terms of the GNU Lesser General Public License (as published by the Free 00010 // Software Foundation) version 2.1 dated February 1999. 00011 00012 /// This HYPRE library interface has been taken originally from MFEM and modified 00013 /// to suit the needs for the MOAB library. 00014 /// Modified by: Vijay Mahadevan 00015 00016 #ifndef MOAB_HYPREPARMATRIX 00017 #define MOAB_HYPREPARMATRIX 00018 00019 #include "moab/MOABConfig.h" 00020 #include "moab/Core.hpp" 00021 00022 #ifdef MOAB_HAVE_EIGEN3 00023 #include <Eigen/Core> 00024 #include <Eigen/Sparse> 00025 #else 00026 #error Configure with Eigen3 enabled 00027 #endif 00028 00029 #ifdef MOAB_HAVE_MPI 00030 #include "moab/ParallelComm.hpp" 00031 00032 // hypre header files 00033 // #include "HYPRE.h" 00034 // #include "HYPRE_parcsr_ls.h" 00035 // #include "HYPRE_MatvecFunctions.h" 00036 00037 #include "seq_mv.h" 00038 #include "HypreParVector.hpp" 00039 #include "_hypre_parcsr_mv.h" 00040 #include "_hypre_parcsr_ls.h" 00041 #include "interpreter.h" 00042 #include "HYPRE_MatvecFunctions.h" 00043 00044 #include "temp_multivector.h" 00045 00046 #ifdef HYPRE_COMPLEX 00047 #error "MOAB does not work with HYPRE's complex numbers support" 00048 #endif 00049 00050 #include "hypre_parcsr.hpp" 00051 00052 namespace moab 00053 { 00054 00055 namespace internal 00056 { 00057 00058 // Convert a HYPRE_Int to int 00059 inline int to_int( HYPRE_Int i ) 00060 { 00061 #ifdef HYPRE_BIGINT 00062 MFEM_ASSERT( HYPRE_Int( int( i ) ) == i, "overflow converting HYPRE_Int to int" ); 00063 #endif 00064 return int( i ); 00065 } 00066 00067 } // namespace internal 00068 00069 /// Wrapper for hypre's ParCSR matrix class 00070 class HypreParMatrix 00071 { 00072 private: 00073 /// The actual object 00074 HYPRE_IJMatrix A; 00075 hypre_ParCSRMatrix* A_parcsr; 00076 00077 mv_InterfaceInterpreter* interpreter; 00078 00079 // Does the object own the pointer A? 00080 char ParCSROwner; 00081 00082 // Store the dimensions of the matrix 00083 int height, gnrows; 00084 int width, gncols; 00085 00086 moab::ParallelComm* pcomm; 00087 char initialized; 00088 00089 // Initialize with defaults. Does not initialize inherited members. 00090 void Init(); 00091 00092 // Delete all owned data. Does not perform re-initialization with defaults. 00093 void Destroy(); 00094 00095 friend class HypreSolver; 00096 00097 public: 00098 typedef Eigen::VectorXd Vector; 00099 typedef Eigen::SparseMatrix< double, Eigen::RowMajor > MOABSparseMatrix; 00100 // typedef template Eigen::ArrayXX<T> Array2D<T>; 00101 00102 public: 00103 /// An empty matrix to be used as a reference to an existing matrix 00104 HypreParMatrix( moab::ParallelComm* p_comm ); 00105 00106 /// Converts hypre's format to HypreParMatrix 00107 HypreParMatrix( HYPRE_IJMatrix a ) 00108 { 00109 Init(); 00110 A = a; 00111 height = GetNumRows(); 00112 width = GetNumCols(); 00113 } 00114 00115 /** Creates block-diagonal square parallel matrix. Diagonal is given by diag 00116 which must be in CSR format (finalized). The new HypreParMatrix does not 00117 take ownership of any of the input arrays. */ 00118 HypreParMatrix( moab::ParallelComm* p_comm, HYPRE_Int glob_size, HYPRE_Int* row_starts, HYPRE_Int nnz_pr_diag = 0 ); 00119 00120 /** Creates block-diagonal rectangular parallel matrix. Diagonal is given by 00121 diag which must be in CSR format (finalized). The new HypreParMatrix does 00122 not take ownership of any of the input arrays. */ 00123 HypreParMatrix( moab::ParallelComm* p_comm, 00124 HYPRE_Int global_num_rows, 00125 HYPRE_Int global_num_cols, 00126 HYPRE_Int* row_starts, 00127 HYPRE_Int* col_starts, 00128 HYPRE_Int nnz_pr_diag = 0, 00129 HYPRE_Int onz_pr_diag = 0, 00130 HYPRE_Int nnz_pr_offdiag = 0 ); 00131 00132 /** Creates a general parallel matrix from a local CSR matrix on each 00133 processor described by the I, J and data arrays. The local matrix should 00134 be of size (local) nrows by (global) glob_ncols. The new parallel matrix 00135 contains copies of all input arrays (so they can be deleted). */ 00136 // HypreParMatrix(MPI_Comm comm, int nrows, HYPRE_Int glob_nrows, 00137 // HYPRE_Int glob_ncols, int *I, HYPRE_Int *J, 00138 // double *data, HYPRE_Int *rows, HYPRE_Int *cols); 00139 00140 /// Make this HypreParMatrix a reference to 'master' 00141 void MakeRef( const HypreParMatrix& master ); 00142 00143 /// MPI communicator 00144 moab::ParallelComm* GetParallelCommunicator() const 00145 { 00146 return pcomm; 00147 } 00148 00149 /// Typecasting to hypre's HYPRE_IJMatrix* 00150 operator HYPRE_IJMatrix() 00151 { 00152 return A; 00153 } 00154 /// Typecasting to hypre's HYPRE_ParCSRMatrix, a.k.a. void * 00155 operator HYPRE_ParCSRMatrix() 00156 { 00157 return (HYPRE_ParCSRMatrix)A_parcsr; 00158 } 00159 00160 /// Changes the ownership of the matrix 00161 HYPRE_IJMatrix StealData(); 00162 /// Changes the ownership of the matrix to A 00163 void StealData( HypreParMatrix& A ); 00164 00165 /** If the HypreParMatrix does not own the row-starts array, make a copy of 00166 it that the HypreParMatrix will own. If the col-starts array is the same 00167 as the row-starts array, col-starts is also replaced. */ 00168 // void CopyRowStarts(); 00169 /** If the HypreParMatrix does not own the col-starts array, make a copy of 00170 it that the HypreParMatrix will own. If the row-starts array is the same 00171 as the col-starts array, row-starts is also replaced. */ 00172 // void CopyColStarts(); 00173 00174 /// Returns the global number of nonzeros 00175 inline HYPRE_Int NNZ() 00176 { 00177 return A_parcsr->num_nonzeros; 00178 } 00179 /// Returns the row partitioning 00180 inline HYPRE_Int* RowPart() 00181 { 00182 return A->row_partitioning; 00183 } 00184 /// Returns the column partitioning 00185 inline HYPRE_Int* ColPart() 00186 { 00187 return A->col_partitioning; 00188 } 00189 /// Returns the global number of rows 00190 inline HYPRE_Int M() 00191 { 00192 return A->global_num_rows; 00193 } 00194 /// Returns the global number of columns 00195 inline HYPRE_Int N() 00196 { 00197 return A->global_num_cols; 00198 } 00199 /// Returns the global number of rows 00200 inline HYPRE_Int FirstRow() 00201 { 00202 return A->global_first_row; 00203 } 00204 /// Returns the global number of columns 00205 inline HYPRE_Int FirstCol() 00206 { 00207 return A->global_first_col; 00208 } 00209 00210 /// Get the local diagonal of the matrix. 00211 void GetDiag( Vector& diag ) const; 00212 /// Get the local diagonal block. NOTE: 'diag' will not own any data. 00213 void GetDiag( MOABSparseMatrix& diag ) const; 00214 /// Get the local off-diagonal block. NOTE: 'offd' will not own any data. 00215 void GetOffd( MOABSparseMatrix& offd, HYPRE_Int*& cmap ) const; 00216 00217 /** Split the matrix into M x N equally sized blocks of parallel matrices. 00218 The size of 'blocks' must already be set to M x N. */ 00219 // void GetBlocks(Eigen::Array<HypreParMatrix*,Eigen::Dynamic,Eigen::Dynamic> &blocks, 00220 // bool interleaved_rows = false, 00221 // bool interleaved_cols = false) const; 00222 00223 /// Returns the transpose of *this 00224 // HypreParMatrix * Transpose(); 00225 00226 /** Destroy and resize block-diagonal square parallel matrix. Diagonal is given by diag 00227 which must be in CSR format (finalized). The new HypreParMatrix does not 00228 take ownership of any of the input arrays. */ 00229 void resize( HYPRE_Int glob_size, HYPRE_Int* row_starts, HYPRE_Int nnz_pr_diag = 0, HYPRE_Int nnz_pr_offdiag = 0 ); 00230 00231 /** Destroy and resize block-diagonal rectangular parallel matrix. Diagonal is given by 00232 diag which must be in CSR format (finalized). The new HypreParMatrix does 00233 not take ownership of any of the input arrays. */ 00234 void resize( HYPRE_Int global_num_rows, 00235 HYPRE_Int global_num_cols, 00236 HYPRE_Int* row_starts, 00237 HYPRE_Int* col_starts, 00238 HYPRE_Int* nnz_pr_diag = NULL, 00239 HYPRE_Int* onz_pr_diag = NULL, 00240 HYPRE_Int nnz_pr_offdiag = 0 ); 00241 00242 /// Returns the number of rows in the diagonal block of the ParCSRMatrix 00243 int GetNumRows() const 00244 { 00245 return internal::to_int( hypre_CSRMatrixNumRows( hypre_ParCSRMatrixDiag( A_parcsr ) ) ); 00246 } 00247 00248 /// Returns the number of columns in the diagonal block of the ParCSRMatrix 00249 int GetNumCols() const 00250 { 00251 return internal::to_int( hypre_CSRMatrixNumCols( hypre_ParCSRMatrixDiag( A_parcsr ) ) ); 00252 } 00253 00254 /// Computes y = alpha * A * x + beta * y 00255 HYPRE_Int Mult( HypreParVector& x, HypreParVector& y, double alpha = 1.0, double beta = 0.0 ); 00256 /// Computes y = alpha * A * x + beta * y 00257 HYPRE_Int Mult( HYPRE_ParVector x, HYPRE_ParVector y, double alpha = 1.0, double beta = 0.0 ); 00258 /// Computes y = alpha * A^t * x + beta * y 00259 HYPRE_Int MultTranspose( HypreParVector& x, HypreParVector& y, double alpha = 1.0, double beta = 0.0 ); 00260 00261 void Mult( double a, const HypreParVector& x, double b, HypreParVector& y ) const; 00262 void MultTranspose( double a, const HypreParVector& x, double b, HypreParVector& y ) const; 00263 00264 // virtual void Mult(const Vector &x, Vector &y) const 00265 // { Mult(1.0, x, 0.0, y); } 00266 // virtual void MultTranspose(const Vector &x, Vector &y) const 00267 // { MultTranspose(1.0, x, 0.0, y); } 00268 00269 /** The "Boolean" analog of y = alpha * A * x + beta * y, where elements in 00270 the sparsity pattern of the matrix are treated as "true". */ 00271 // void BooleanMult(int alpha, int *x, int beta, int *y) 00272 // { 00273 // internal::hypre_ParCSRMatrixBooleanMatvec(A_parcsr, alpha, x, beta, y); 00274 // } 00275 00276 /** Multiply A on the left by a block-diagonal parallel matrix D. Return 00277 a new parallel matrix, D*A. If D has a different number of rows than A, 00278 D's row starts array needs to be given (as returned by the methods 00279 GetDofOffsets/GetTrueDofOffsets of ParFiniteElementSpace). The new matrix 00280 D*A uses copies of the row-, column-starts arrays, so "this" matrix and 00281 "row_starts" can be deleted. 00282 NOTE: this operation is local and does not require communication. */ 00283 // HypreParMatrix* LeftDiagMult(const MOABSparseMatrix &D, 00284 // HYPRE_Int* row_starts = NULL) const; 00285 00286 /// Scale the local row i by s(i). 00287 void ScaleRows( const Vector& s ); 00288 /// Scale the local row i by 1./s(i) 00289 void InvScaleRows( const Vector& s ); 00290 /// Scale all entries by s: A_scaled = s*A. 00291 void operator*=( double s ); 00292 00293 /// Remove values smaller in absolute value than some threshold 00294 void Threshold( double threshold = 0.0 ); 00295 00296 /// If a row contains only zeros, set its diagonal to 1. 00297 void EliminateZeroRows() 00298 { 00299 hypre_ParCSRMatrixFixZeroRows( A_parcsr ); 00300 } 00301 00302 /** Eliminate rows and columns from the matrix, and rows from the vector B. 00303 Modify B with the BC values in X. */ 00304 void EliminateRowsCols( const std::vector< HYPRE_Int >& rows_cols, const HypreParVector& X, HypreParVector& B ); 00305 00306 /** Eliminate rows and columns from the matrix and store the eliminated 00307 elements in a new matrix Ae (returned), so that the modified matrix and 00308 Ae sum to the original matrix. */ 00309 HypreParMatrix* EliminateRowsCols( const std::vector< HYPRE_Int >& rows_cols ); 00310 00311 HYPRE_Int GetValues( const HYPRE_Int nrows, 00312 HYPRE_Int* ncols, 00313 HYPRE_Int* rows, 00314 HYPRE_Int* cols, 00315 HYPRE_Complex* values ); 00316 HYPRE_Int SetValues( const HYPRE_Int nrows, 00317 HYPRE_Int* ncols, 00318 const HYPRE_Int* rows, 00319 const HYPRE_Int* cols, 00320 const HYPRE_Complex* values ); 00321 HYPRE_Int AddToValues( const HYPRE_Int nrows, 00322 HYPRE_Int* ncols, 00323 const HYPRE_Int* rows, 00324 const HYPRE_Int* cols, 00325 const HYPRE_Complex* values ); 00326 00327 HYPRE_Int FinalizeAssembly(); 00328 00329 HYPRE_Int verbosity( const HYPRE_Int level ); 00330 00331 /// Prints the locally owned rows in parallel 00332 void Print( const char* fname, HYPRE_Int offi = 0, HYPRE_Int offj = 0 ); 00333 /// Reads the matrix from a file 00334 void Read( const char* fname ); 00335 00336 /// Calls hypre's destroy function 00337 virtual ~HypreParMatrix() 00338 { 00339 Destroy(); 00340 } 00341 00342 /// Returns the matrix A * B 00343 friend HypreParMatrix* ParMult( HypreParMatrix* A, HypreParMatrix* B ); 00344 00345 /// Returns the matrix P^t * A * P 00346 friend HypreParMatrix* RAP( HypreParMatrix* A, HypreParMatrix* P ); 00347 /// Returns the matrix Rt^t * A * P 00348 friend HypreParMatrix* RAP( HypreParMatrix* Rt, HypreParMatrix* A, HypreParMatrix* P ); 00349 00350 /** Eliminate essential BC specified by 'ess_dof_list' from the solution X to 00351 the r.h.s. B. Here A is a matrix with eliminated BC, while Ae is such that 00352 (A+Ae) is the original (Neumann) matrix before elimination. */ 00353 friend void EliminateBC( HypreParMatrix& A, 00354 HypreParMatrix& Ae, 00355 const std::vector< int >& ess_dof_list, 00356 const HypreParVector& X, 00357 HypreParVector& B ); 00358 00359 friend class HypreSolver; 00360 }; 00361 00362 } // namespace moab 00363 00364 #endif // MOAB_HAVE_MPI 00365 00366 #endif
