MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 // Copyright (c) 2010, Lawrence Livermore National Security, LLC. Produced at 00002 // the Lawrence Livermore National Laboratory. LLNL-CODE-443211. All Rights 00003 // reserved. See file COPYRIGHT for details. 00004 // 00005 // This file is part of the MFEM library. For more information and source code 00006 // availability see http://mfem.org. 00007 // 00008 // MFEM is free software; you can redistribute it and/or modify it under the 00009 // terms of the GNU Lesser General Public License (as published by the Free 00010 // Software Foundation) version 2.1 dated February 1999. 00011 00012 #include "HypreSolver.hpp" 00013 #include "HypreParMatrix.hpp" 00014 00015 #ifdef MOAB_HAVE_MPI 00016 00017 #include "hypre_parcsr.hpp" 00018 00019 #include <fstream> 00020 #include <iostream> 00021 #include <cmath> 00022 #include <cstdlib> 00023 #include <cassert> 00024 00025 using namespace std; 00026 00027 namespace moab 00028 { 00029 #define moab_hypre_assert( a, b ) \ 00030 { \ 00031 } 00032 #define moab_hypre_assert_t( a, b ) \ 00033 { \ 00034 if( !a ) \ 00035 { \ 00036 std::cout << "HYPRE Error: " << b << std::endl; \ 00037 exit( -1 ); \ 00038 } 00039 00040 HypreSolver::HypreSolver( bool iterative ) : AbstractSolver( iterative ) 00041 { 00042 A = NULL; 00043 setup_called = 0; 00044 B = X = NULL; 00045 } 00046 00047 HypreSolver::HypreSolver( HypreParMatrix* _A, bool iterative ) : AbstractSolver( iterative ) 00048 { 00049 A = _A; 00050 setup_called = 0; 00051 B = X = NULL; 00052 } 00053 00054 HYPRE_Int HypreSolver::Solve( const HypreParVector& b, HypreParVector& x ) const 00055 { 00056 HYPRE_Int err; 00057 00058 if( A == NULL ) 00059 { 00060 MB_SET_ERR_RET_VAL( "HypreSolver::Solve (...) : HypreParMatrix A is missing", 1 ); 00061 } 00062 00063 if( !setup_called ) 00064 { 00065 err = SetupFcn()( *this, *A, b.x_par, x.x_par ); 00066 setup_called = 1; 00067 } 00068 00069 if( !iterative_mode ) 00070 { 00071 x = 0.0; 00072 } 00073 00074 err = SolveFcn()( *this, *A, b.x_par, x.x_par ); 00075 return err; 00076 } 00077 00078 HypreSolver::~HypreSolver() 00079 { 00080 if( B ) 00081 { 00082 delete B; 00083 } 00084 00085 if( X ) 00086 { 00087 delete X; 00088 } 00089 } 00090 00091 HyprePCG::HyprePCG( HypreParMatrix& _A ) : HypreSolver( &_A, true ) 00092 { 00093 iterative_mode = true; 00094 HYPRE_ParCSRPCGCreate( A->GetParallelCommunicator()->comm(), &pcg_solver ); 00095 } 00096 00097 void HyprePCG::SetTol( double tol ) 00098 { 00099 HYPRE_PCGSetTol( pcg_solver, tol ); 00100 } 00101 00102 void HyprePCG::SetMaxIter( int max_iter ) 00103 { 00104 HYPRE_PCGSetMaxIter( pcg_solver, max_iter ); 00105 } 00106 00107 void HyprePCG::SetLogging( int logging ) 00108 { 00109 HYPRE_PCGSetLogging( pcg_solver, logging ); 00110 } 00111 00112 void HyprePCG::Verbosity( int print_lvl ) 00113 { 00114 HYPRE_ParCSRPCGSetPrintLevel( pcg_solver, print_lvl ); 00115 } 00116 00117 void HyprePCG::SetPreconditioner( HypreSolver& precond ) 00118 { 00119 HYPRE_ParCSRPCGSetPrecond( pcg_solver, precond.SolveFcn(), precond.SetupFcn(), precond ); 00120 } 00121 00122 void HyprePCG::SetResidualConvergenceOptions( int res_frequency, double rtol ) 00123 { 00124 HYPRE_PCGSetTwoNorm( pcg_solver, 1 ); 00125 00126 if( res_frequency > 0 ) 00127 { 00128 HYPRE_PCGSetRecomputeResidualP( pcg_solver, res_frequency ); 00129 } 00130 00131 if( rtol > 0.0 ) 00132 { 00133 HYPRE_PCGSetResidualTol( pcg_solver, rtol ); 00134 } 00135 } 00136 00137 HYPRE_Int HyprePCG::Solve( const HypreParVector& b, HypreParVector& x ) const 00138 { 00139 HYPRE_Int err; 00140 int myid; 00141 HYPRE_Int time_index = 0; 00142 HYPRE_Int num_iterations; 00143 double final_res_norm; 00144 moab::ParallelComm* pcomm; 00145 HYPRE_Int print_level; 00146 HYPRE_PCGGetPrintLevel( pcg_solver, &print_level ); 00147 pcomm = A->GetParallelCommunicator(); 00148 00149 if( !setup_called ) 00150 { 00151 if( print_level > 0 ) 00152 { 00153 #ifdef HYPRE_TIMING 00154 time_index = hypre_InitializeTiming( "PCG Setup" ); 00155 hypre_BeginTiming( time_index ); 00156 #endif 00157 } 00158 00159 err = HYPRE_ParCSRPCGSetup( pcg_solver, *A, (HYPRE_ParVector)b, (HYPRE_ParVector)x ); 00160 setup_called = 1; 00161 00162 if( err != 0 ) 00163 { 00164 cout << "PCG Setup failed with error = " << err << endl; 00165 return err; 00166 } 00167 00168 if( print_level > 0 ) 00169 { 00170 #ifdef HYPRE_TIMING 00171 hypre_EndTiming( time_index ); 00172 hypre_PrintTiming( "Setup phase times", pcomm->comm() ); 00173 hypre_FinalizeTiming( time_index ); 00174 hypre_ClearTiming(); 00175 #endif 00176 } 00177 } 00178 00179 if( print_level > 0 ) 00180 { 00181 #ifdef HYPRE_TIMING 00182 time_index = hypre_InitializeTiming( "PCG Solve" ); 00183 hypre_BeginTiming( time_index ); 00184 #endif 00185 } 00186 00187 if( !iterative_mode ) 00188 { 00189 x = 0.0; 00190 } 00191 00192 err = HYPRE_ParCSRPCGSolve( pcg_solver, *A, (HYPRE_ParVector)b, (HYPRE_ParVector)x ); 00193 00194 if( print_level > 0 ) 00195 { 00196 #ifdef HYPRE_TIMING 00197 hypre_EndTiming( time_index ); 00198 hypre_PrintTiming( "Solve phase times", pcomm->comm() ); 00199 hypre_FinalizeTiming( time_index ); 00200 hypre_ClearTiming(); 00201 #endif 00202 HYPRE_ParCSRPCGGetNumIterations( pcg_solver, &num_iterations ); 00203 HYPRE_ParCSRPCGGetFinalRelativeResidualNorm( pcg_solver, &final_res_norm ); 00204 MPI_Comm_rank( pcomm->comm(), &myid ); 00205 00206 if( myid == 0 ) 00207 { 00208 cout << "PCG Iterations = " << num_iterations << endl 00209 << "Final PCG Relative Residual Norm = " << final_res_norm << endl; 00210 } 00211 } 00212 00213 return err; 00214 } 00215 00216 HyprePCG::~HyprePCG() 00217 { 00218 HYPRE_ParCSRPCGDestroy( pcg_solver ); 00219 } 00220 00221 HypreGMRES::HypreGMRES( HypreParMatrix& _A ) : HypreSolver( &_A, true ) 00222 { 00223 MPI_Comm comm; 00224 int k_dim = 50; 00225 int max_iter = 100; 00226 double tol = 1e-6; 00227 iterative_mode = true; 00228 HYPRE_ParCSRMatrixGetComm( *A, &comm ); 00229 HYPRE_ParCSRGMRESCreate( comm, &gmres_solver ); 00230 HYPRE_ParCSRGMRESSetKDim( gmres_solver, k_dim ); 00231 HYPRE_ParCSRGMRESSetMaxIter( gmres_solver, max_iter ); 00232 HYPRE_ParCSRGMRESSetTol( gmres_solver, tol ); 00233 } 00234 00235 void HypreGMRES::SetTol( double atol, double rtol ) 00236 { 00237 HYPRE_GMRESSetAbsoluteTol( gmres_solver, atol ); 00238 HYPRE_GMRESSetTol( gmres_solver, rtol ); 00239 } 00240 00241 void HypreGMRES::SetMaxIter( int max_iter ) 00242 { 00243 HYPRE_GMRESSetMaxIter( gmres_solver, max_iter ); 00244 } 00245 00246 void HypreGMRES::SetKDim( int k_dim ) 00247 { 00248 HYPRE_GMRESSetKDim( gmres_solver, k_dim ); 00249 } 00250 00251 void HypreGMRES::SetLogging( int logging ) 00252 { 00253 HYPRE_GMRESSetLogging( gmres_solver, logging ); 00254 } 00255 00256 void HypreGMRES::Verbosity( int print_lvl ) 00257 { 00258 HYPRE_GMRESSetPrintLevel( gmres_solver, print_lvl ); 00259 } 00260 00261 void HypreGMRES::SetPreconditioner( HypreSolver& precond ) 00262 { 00263 HYPRE_ParCSRGMRESSetPrecond( gmres_solver, precond.SolveFcn(), precond.SetupFcn(), precond ); 00264 } 00265 00266 HYPRE_Int HypreGMRES::Solve( const HypreParVector& b, HypreParVector& x ) const 00267 { 00268 HYPRE_Int err; 00269 int myid; 00270 HYPRE_Int time_index = 0; 00271 HYPRE_Int num_iterations; 00272 double final_res_norm; 00273 MPI_Comm comm; 00274 HYPRE_Int print_level; 00275 HYPRE_GMRESGetPrintLevel( gmres_solver, &print_level ); 00276 HYPRE_ParCSRMatrixGetComm( *A, &comm ); 00277 00278 if( !setup_called ) 00279 { 00280 if( print_level > 0 ) 00281 { 00282 #ifdef HYPRE_TIMING 00283 time_index = hypre_InitializeTiming( "GMRES Setup" ); 00284 hypre_BeginTiming( time_index ); 00285 #endif 00286 } 00287 00288 err = HYPRE_ParCSRGMRESSetup( gmres_solver, *A, b, x ); 00289 setup_called = 1; 00290 00291 if( err != 0 ) 00292 { 00293 cout << "PCG Setup failed with error = " << err << endl; 00294 return err; 00295 } 00296 00297 if( print_level > 0 ) 00298 { 00299 #ifdef HYPRE_TIMING 00300 hypre_EndTiming( time_index ); 00301 hypre_PrintTiming( "Setup phase times", comm ); 00302 hypre_FinalizeTiming( time_index ); 00303 hypre_ClearTiming(); 00304 #endif 00305 } 00306 } 00307 00308 if( print_level > 0 ) 00309 { 00310 #ifdef HYPRE_TIMING 00311 time_index = hypre_InitializeTiming( "GMRES Solve" ); 00312 hypre_BeginTiming( time_index ); 00313 #endif 00314 } 00315 00316 if( !iterative_mode ) 00317 { 00318 x = 0.0; 00319 } 00320 00321 err = HYPRE_ParCSRGMRESSolve( gmres_solver, *A, b, x ); 00322 00323 if( print_level > 0 ) 00324 { 00325 #ifdef HYPRE_TIMING 00326 hypre_EndTiming( time_index ); 00327 hypre_PrintTiming( "Solve phase times", comm ); 00328 hypre_FinalizeTiming( time_index ); 00329 hypre_ClearTiming(); 00330 #endif 00331 HYPRE_ParCSRGMRESGetNumIterations( gmres_solver, &num_iterations ); 00332 HYPRE_ParCSRGMRESGetFinalRelativeResidualNorm( gmres_solver, &final_res_norm ); 00333 MPI_Comm_rank( comm, &myid ); 00334 00335 if( myid == 0 ) 00336 { 00337 cout << "GMRES Iterations = " << num_iterations << endl 00338 << "Final GMRES Relative Residual Norm = " << final_res_norm << endl; 00339 } 00340 } 00341 00342 return err; 00343 } 00344 00345 HypreGMRES::~HypreGMRES() 00346 { 00347 HYPRE_ParCSRGMRESDestroy( gmres_solver ); 00348 } 00349 00350 HypreParaSails::HypreParaSails( HypreParMatrix& A ) : HypreSolver( &A ) 00351 { 00352 MPI_Comm comm; 00353 int sai_max_levels = 1; 00354 double sai_threshold = 0.1; 00355 double sai_filter = 0.1; 00356 int sai_sym = 0; 00357 double sai_loadbal = 0.0; 00358 int sai_reuse = 0; 00359 int sai_logging = 1; 00360 HYPRE_ParCSRMatrixGetComm( A, &comm ); 00361 HYPRE_ParaSailsCreate( comm, &sai_precond ); 00362 HYPRE_ParaSailsSetParams( sai_precond, sai_threshold, sai_max_levels ); 00363 HYPRE_ParaSailsSetFilter( sai_precond, sai_filter ); 00364 HYPRE_ParaSailsSetSym( sai_precond, sai_sym ); 00365 HYPRE_ParaSailsSetLoadbal( sai_precond, sai_loadbal ); 00366 HYPRE_ParaSailsSetReuse( sai_precond, sai_reuse ); 00367 HYPRE_ParaSailsSetLogging( sai_precond, sai_logging ); 00368 } 00369 00370 void HypreParaSails::SetSymmetry( int sym ) 00371 { 00372 HYPRE_ParaSailsSetSym( sai_precond, sym ); 00373 } 00374 00375 HypreParaSails::~HypreParaSails() 00376 { 00377 HYPRE_ParaSailsDestroy( sai_precond ); 00378 } 00379 00380 HypreBoomerAMG::HypreBoomerAMG() 00381 { 00382 HYPRE_BoomerAMGCreate( &amg_precond ); 00383 SetDefaultOptions(); 00384 } 00385 00386 HypreBoomerAMG::HypreBoomerAMG( HypreParMatrix& A ) : HypreSolver( &A ) 00387 { 00388 HYPRE_BoomerAMGCreate( &amg_precond ); 00389 SetDefaultOptions(); 00390 } 00391 00392 void HypreBoomerAMG::SetDefaultOptions() 00393 { 00394 // AMG coarsening options: 00395 int coarsen_type = 10; // 10 = HMIS, 8 = PMIS, 6 = Falgout, 0 = CLJP 00396 int agg_levels = 2; // number of aggressive coarsening levels 00397 double theta = 0.25; // strength threshold: 0.25, 0.5, 0.8 00398 // AMG interpolation options: 00399 int interp_type = 6; // 6 = extended+i, 0 = classical 00400 int Pmax = 4; // max number of elements per row in P 00401 // AMG relaxation options: 00402 int relax_type = 10; // 8 = l1-GS, 6 = symm. GS, 3 = GS, 18 = l1-Jacobi 00403 int relax_sweeps = 1; // relaxation sweeps on each level 00404 // Additional options: 00405 int print_level = 1; // print AMG iterations? 1 = no, 2 = yes 00406 int max_levels = 25; // max number of levels in AMG hierarchy 00407 HYPRE_BoomerAMGSetCoarsenType( amg_precond, coarsen_type ); 00408 HYPRE_BoomerAMGSetAggNumLevels( amg_precond, agg_levels ); 00409 HYPRE_BoomerAMGSetRelaxType( amg_precond, relax_type ); 00410 HYPRE_BoomerAMGSetNumSweeps( amg_precond, relax_sweeps ); 00411 HYPRE_BoomerAMGSetStrongThreshold( amg_precond, theta ); 00412 HYPRE_BoomerAMGSetInterpType( amg_precond, interp_type ); 00413 HYPRE_BoomerAMGSetPMaxElmts( amg_precond, Pmax ); 00414 HYPRE_BoomerAMGSetPrintLevel( amg_precond, print_level ); 00415 HYPRE_BoomerAMGSetMaxLevels( amg_precond, max_levels ); 00416 // Use as a preconditioner (one V-cycle, zero tolerance) 00417 HYPRE_BoomerAMGSetMaxIter( amg_precond, 1 ); 00418 HYPRE_BoomerAMGSetTol( amg_precond, 0.0 ); 00419 } 00420 00421 void HypreBoomerAMG::ResetAMGPrecond() 00422 { 00423 HYPRE_Int coarsen_type; 00424 HYPRE_Int agg_levels; 00425 HYPRE_Int relax_type; 00426 HYPRE_Int relax_sweeps; 00427 HYPRE_Real theta; 00428 HYPRE_Int interp_type; 00429 HYPRE_Int Pmax; 00430 HYPRE_Int print_level; 00431 HYPRE_Int dim; 00432 hypre_ParAMGData* amg_data = (hypre_ParAMGData*)amg_precond; 00433 // read options from amg_precond 00434 HYPRE_BoomerAMGGetCoarsenType( amg_precond, &coarsen_type ); 00435 agg_levels = hypre_ParAMGDataAggNumLevels( amg_data ); 00436 relax_type = hypre_ParAMGDataUserRelaxType( amg_data ); 00437 relax_sweeps = hypre_ParAMGDataUserNumSweeps( amg_data ); 00438 HYPRE_BoomerAMGGetStrongThreshold( amg_precond, &theta ); 00439 hypre_BoomerAMGGetInterpType( amg_precond, &interp_type ); 00440 HYPRE_BoomerAMGGetPMaxElmts( amg_precond, &Pmax ); 00441 HYPRE_BoomerAMGGetPrintLevel( amg_precond, &print_level ); 00442 HYPRE_BoomerAMGGetNumFunctions( amg_precond, &dim ); 00443 HYPRE_BoomerAMGDestroy( amg_precond ); 00444 HYPRE_BoomerAMGCreate( &amg_precond ); 00445 HYPRE_BoomerAMGSetCoarsenType( amg_precond, coarsen_type ); 00446 HYPRE_BoomerAMGSetAggNumLevels( amg_precond, agg_levels ); 00447 HYPRE_BoomerAMGSetRelaxType( amg_precond, relax_type ); 00448 HYPRE_BoomerAMGSetNumSweeps( amg_precond, relax_sweeps ); 00449 HYPRE_BoomerAMGSetMaxLevels( amg_precond, 25 ); 00450 HYPRE_BoomerAMGSetTol( amg_precond, 0.0 ); 00451 HYPRE_BoomerAMGSetMaxIter( amg_precond, 1 ); // one V-cycle 00452 HYPRE_BoomerAMGSetStrongThreshold( amg_precond, theta ); 00453 HYPRE_BoomerAMGSetInterpType( amg_precond, interp_type ); 00454 HYPRE_BoomerAMGSetPMaxElmts( amg_precond, Pmax ); 00455 HYPRE_BoomerAMGSetPrintLevel( amg_precond, print_level ); 00456 HYPRE_BoomerAMGSetNumFunctions( amg_precond, dim ); 00457 } 00458 00459 void HypreBoomerAMG::SetOperator( const HypreParMatrix& op ) 00460 { 00461 if( A ) 00462 { 00463 ResetAMGPrecond(); 00464 } 00465 00466 // update base classes: Operator, Solver, HypreSolver 00467 A = const_cast< HypreParMatrix* >( &op ); 00468 setup_called = 0; 00469 delete X; 00470 delete B; 00471 B = X = NULL; 00472 } 00473 00474 void HypreBoomerAMG::SetSystemsOptions( int dim ) 00475 { 00476 HYPRE_BoomerAMGSetNumFunctions( amg_precond, dim ); 00477 // More robust options with respect to convergence 00478 HYPRE_BoomerAMGSetAggNumLevels( amg_precond, 0 ); 00479 HYPRE_BoomerAMGSetStrongThreshold( amg_precond, dim * 0.25 ); 00480 } 00481 00482 HypreBoomerAMG::~HypreBoomerAMG() 00483 { 00484 HYPRE_BoomerAMGDestroy( amg_precond ); 00485 } 00486 00487 } // namespace moab 00488 00489 #endif
