MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /**\file SpatialLocatorTimes.hpp 00002 * \class moab::SpatialLocatorTimes 00003 * \brief Statistics for spatial location 00004 * 00005 * Class to accumulate statistics on performance of spatial location. This structure stores 00006 * only local (single proc) statistics, but provides functions for accumulating max/min/avg 00007 * time properties for performance reporting. 00008 * 00009 * Similar to TreeStats, this class is very lightweight, with most variables publicly accessible. 00010 * 00011 */ 00012 00013 #ifndef SPATIALLOCATORTIMES_HPP 00014 #define SPATIALLOCATORTIMES_HPP 00015 00016 #include "moab/Interface.hpp" 00017 00018 #include <iostream> 00019 00020 #ifdef MOAB_HAVE_MPI 00021 #include "moab_mpi.h" 00022 #endif 00023 00024 namespace moab 00025 { 00026 class SpatialLocatorTimes 00027 { 00028 public: 00029 /* constructor 00030 */ 00031 SpatialLocatorTimes() 00032 { 00033 reset(); 00034 } 00035 00036 /* \brief Reset all stats defined here 00037 */ 00038 void reset(); 00039 00040 /* \brief Output header for stats names 00041 */ 00042 void output_header( bool print_endl = false ) const; 00043 00044 /* \brief Output stats all on one line 00045 */ 00046 void output( bool print_head = false, bool print_endl = false ) const; 00047 00048 #ifdef MOAB_HAVE_MPI 00049 /* \brief Accumulate times over all processors into provided array 00050 * Max and min is accumulated over all processors, onto root, for each stat. If avg_stats is 00051 non-NULL, 00052 * all stats are gathered to root so average can be taken too. 00053 * 00054 * This function must be called collectively on the communicator 00055 * \param comm MPI communictor over which this accumulation is done 00056 * \param max_times Array of size NUM_STATS into which max times are inserted 00057 * \param min_times Array of size NUM_STATS into which min times are inserted 00058 * \param avg_times Array of size NUM_STATS into which avg times are inserted; if NULL, no avg 00059 times are computed. 00060 00061 */ 00062 ErrorCode accumulate_times( MPI_Comm comm, double* max_times, double* min_times, double* avg_times = NULL ); 00063 #endif 00064 00065 /* \brief Enumeration to identify fields in performance data 00066 */ 00067 enum 00068 { 00069 INTMED_INIT = 0, // time to compute intermediate partition, incl global bounding box 00070 INTMED_SEND, // time to send search points from target to intermediate parts 00071 INTMED_SEARCH, // time to find candidate src boxes for search points on intermidiate procs 00072 SRC_SEND, // time to send search points to src procs 00073 SRC_SEARCH, // time to search local box/elements on src procs 00074 TARG_RETURN, // time to return point location data to target procs 00075 TARG_STORE, // time to store point location into local SpatialLocator object 00076 NUM_STATS // number of stats, useful for array sizing and terminating loops over stats 00077 }; 00078 00079 double slTimes[NUM_STATS]; 00080 }; 00081 00082 inline void SpatialLocatorTimes::reset() 00083 { 00084 for( int i = 0; i < NUM_STATS; i++ ) 00085 slTimes[i] = 0.0; 00086 } 00087 00088 #ifdef MOAB_HAVE_MPI 00089 inline ErrorCode SpatialLocatorTimes::accumulate_times( MPI_Comm comm, 00090 double* min_times, 00091 double* max_times, 00092 double* avg_times ) 00093 { 00094 ErrorCode rval = MB_SUCCESS; 00095 int success = MPI_Reduce( slTimes, min_times, NUM_STATS, MPI_DOUBLE, MPI_MIN, 0, comm ); 00096 if( !success ) rval = MB_FAILURE; 00097 00098 success = MPI_Reduce( slTimes, max_times, NUM_STATS, MPI_DOUBLE, MPI_MAX, 0, comm ); 00099 if( !success ) rval = MB_FAILURE; 00100 00101 if( avg_times ) 00102 { 00103 int sz, rank; 00104 MPI_Comm_size( comm, &sz ); 00105 MPI_Comm_rank( comm, &rank ); 00106 std::vector< double > all_times; 00107 if( !rank ) all_times.resize( NUM_STATS * sz + NUM_STATS ); 00108 success = MPI_Gather( slTimes, NUM_STATS, MPI_DOUBLE, ( rank ? NULL : &all_times[0] ), NUM_STATS, MPI_DOUBLE, 0, 00109 comm ); 00110 if( !success ) rval = MB_FAILURE; 00111 if( !rank ) 00112 { 00113 std::fill( avg_times, avg_times + NUM_STATS, 0.0 ); 00114 for( int p = 0; p < sz; p++ ) 00115 { 00116 for( int s = 0; s < NUM_STATS; s++ ) 00117 avg_times[s] += all_times[p * NUM_STATS + s]; 00118 } 00119 00120 for( int s = 0; s <= NUM_STATS; s++ ) 00121 avg_times[s] /= (double)sz; 00122 } 00123 } 00124 00125 return rval; 00126 } 00127 #endif 00128 00129 /* \brief Output stats all on one line 00130 */ 00131 inline void SpatialLocatorTimes::output_header( bool print_endl ) const 00132 { 00133 std::cout << "Intmed_init Intmed_send Intmed_search src_send src_search targ_return targ_store"; 00134 if( print_endl ) std::cout << std::endl; 00135 } 00136 00137 /* \brief Output stats all on one line 00138 */ 00139 inline void SpatialLocatorTimes::output( bool print_head, bool print_endl ) const 00140 { 00141 if( print_head ) output_header( true ); 00142 for( int i = 0; i < NUM_STATS; i++ ) 00143 std::cout << slTimes[i] << " "; 00144 00145 if( print_endl ) std::cout << std::endl; 00146 } 00147 00148 } // namespace moab 00149 00150 #endif
