MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* Filename : UnkonwnInterface.h 00002 * Creator : Clinton Stimpson 00003 * 00004 * Date : 10 Jan 2002 00005 * 00006 * Owner : Clinton Stimpson 00007 * 00008 * Description: Contains declarations for MBuuid which keeps 00009 * track of different interfaces. 00010 * Also contains the declaration for the base class 00011 * UknownInterface from which all interfaces are 00012 * derived from 00013 */ 00014 00015 #ifndef MOAB_UNKNOWN_INTERFACE_HPP 00016 #define MOAB_UNKNOWN_INTERFACE_HPP 00017 00018 #include <memory.h> 00019 00020 namespace moab 00021 { 00022 00023 //! struct that handles universally unique id's for the Mesh Database 00024 00025 // note: this MBuuid is compliant with the windows GUID. 00026 // It is possible to do a memcpy() to copy the data from a MBuuid to a GUID 00027 // if we want to support dll registration 00028 struct MBuuid 00029 { 00030 //! default constructor that initializes to zero 00031 MBuuid() 00032 { 00033 memset( this, 0, sizeof( MBuuid ) ); 00034 } 00035 //! constructor that takes initialization arguments 00036 MBuuid( unsigned l, 00037 unsigned short w1, 00038 unsigned short w2, 00039 unsigned char b1, 00040 unsigned char b2, 00041 unsigned char b3, 00042 unsigned char b4, 00043 unsigned char b5, 00044 unsigned char b6, 00045 unsigned char b7, 00046 unsigned char b8 ) 00047 { 00048 data1 = l; 00049 data2 = w1; 00050 data3 = w2; 00051 data4[0] = b1; 00052 data4[1] = b2; 00053 data4[2] = b3; 00054 data4[3] = b4; 00055 data4[4] = b5; 00056 data4[5] = b6; 00057 data4[6] = b7; 00058 data4[7] = b8; 00059 } 00060 //! copy constructor 00061 MBuuid( const MBuuid& mdbuuid ) 00062 { 00063 memcpy( this, &mdbuuid, sizeof( MBuuid ) ); 00064 } 00065 //! sets this uuid equal to another one 00066 MBuuid& operator=( const MBuuid& orig ) 00067 { 00068 memcpy( this, &orig, sizeof( MBuuid ) ); 00069 return *this; 00070 } 00071 //! returns whether two uuid's are equal 00072 bool operator==( const MBuuid& orig ) const 00073 { 00074 return !memcmp( this, &orig, sizeof( MBuuid ) ); 00075 } 00076 //! returns whether two uuid's are not equal 00077 bool operator!=( const MBuuid& orig ) const 00078 { 00079 return !( *this == orig ); 00080 } 00081 00082 //! uuid data storage 00083 unsigned data1; 00084 unsigned short data2; 00085 unsigned short data3; 00086 unsigned char data4[8]; 00087 }; 00088 00089 //! uuid for an unknown interface 00090 //! this can be used to either return a default interface 00091 //! or a NULL interface 00092 static const MBuuid IDD_MBUnknown = 00093 MBuuid( 0xf4f6605e, 0x2a7e, 0x4760, 0xbb, 0x06, 0xb9, 0xed, 0x27, 0xe9, 0x4a, 0xec ); 00094 00095 //! base class for all interface classes 00096 class UnknownInterface 00097 { 00098 public: 00099 virtual int QueryInterface( const MBuuid&, UnknownInterface** ) = 0; 00100 virtual ~UnknownInterface() {} 00101 }; 00102 00103 } // namespace moab 00104 00105 #endif // MOAB_UNKNOWN_INTERFACE_HPP
