MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /*========================================================================= 00002 00003 Module: $RCSfile: V_EdgeMetric.cpp,v $ 00004 00005 Copyright (c) 2006 Sandia Corporation. 00006 All rights reserved. 00007 See Copyright.txt or http://www.kitware.com/Copyright.htm for details. 00008 00009 This software is distributed WITHOUT ANY WARRANTY; without even 00010 the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR 00011 PURPOSE. See the above copyright notice for more information. 00012 00013 =========================================================================*/ 00014 00015 /* 00016 * 00017 * V_EdgeMetric.cpp contains quality calcultions for edges 00018 * 00019 * This file is part of VERDICT 00020 * 00021 */ 00022 00023 #define VERDICT_EXPORTS 00024 00025 #include "moab/verdict.h" 00026 #include <cmath> 00027 00028 /*! 00029 length of and edge 00030 length is calculated by taking the distance between the end nodes 00031 */ 00032 C_FUNC_DEF double v_edge_length( int /*num_nodes*/, double coordinates[][3] ) 00033 { 00034 00035 double x = coordinates[1][0] - coordinates[0][0]; 00036 double y = coordinates[1][1] - coordinates[0][1]; 00037 double z = coordinates[1][2] - coordinates[0][2]; 00038 return (double)( sqrt( x * x + y * y + z * z ) ); 00039 } 00040 00041 /*! 00042 00043 higher order function for calculating multiple metrics at once. 00044 00045 for an edge, there is only one metric, edge length. 00046 */ 00047 00048 C_FUNC_DEF void edge_quality( int num_nodes, 00049 double coordinates[][3], 00050 unsigned int metrics_request_flag, 00051 struct EdgeMetricVals* metric_vals ) 00052 { 00053 if( metrics_request_flag & V_EDGE_LENGTH ) metric_vals->length = v_edge_length( num_nodes, coordinates ); 00054 }
