MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * This imoab_map2 test will simulate coupling between 2 components 00003 * 2 meshes will be loaded from 2 files (src, tgt), and one map file 00004 * after the map is read, in parallel, on coupler pes, with distributed rows, the 00005 * coupler meshes for source and target will be generated, in a migration step, 00006 * in which we will migrate from target pes according to row ids, to coupler target mesh, 00007 * and from source to coverage mesh mesh on coupler. During this migration, par comm graphs 00008 * will be established between source and coupler and target and coupler, which will assist 00009 * in field transfer from source to target, through coupler 00010 * 00011 */ 00012 00013 #include "moab/Core.hpp" 00014 #ifndef MOAB_HAVE_MPI 00015 #error mbtempest tool requires MPI configuration 00016 #endif 00017 00018 // MPI includes 00019 #include "moab_mpi.h" 00020 #include "moab/ParallelComm.hpp" 00021 #include "MBParallelConventions.h" 00022 00023 #include "moab/iMOAB.h" 00024 #include "TestUtil.hpp" 00025 #include "moab/CpuTimer.hpp" 00026 #include "moab/ProgOptions.hpp" 00027 #include <iostream> 00028 #include <sstream> 00029 00030 #include "imoab_coupler_utils.hpp" 00031 00032 #ifndef MOAB_HAVE_TEMPESTREMAP 00033 #error The climate coupler test example requires MOAB configuration with TempestRemap 00034 #endif 00035 00036 int main( int argc, char* argv[] ) 00037 { 00038 int ierr; 00039 int rankInGlobalComm, numProcesses; 00040 MPI_Group jgroup; 00041 std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); 00042 00043 // Timer data 00044 moab::CpuTimer timer; 00045 double timer_ops; 00046 std::string opName; 00047 00048 MPI_Init( &argc, &argv ); 00049 MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm ); 00050 MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); 00051 00052 MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup 00053 00054 std::string atmFilename = TestDir + "unittest/srcWithSolnTag.h5m"; 00055 // on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ; 00056 // intx atm/ocn is not in e3sm yet, give a number 00057 // 6 * 100+ 18 = 618 : atmocnid 00058 // 9 LND, 10 CPLLND 00059 // 6 * 100 + 10 = 610 atmlndid: 00060 // cmpatm is for atm on atm pes 00061 // cmpocn is for ocean, on ocean pe 00062 // cplatm is for atm on coupler pes 00063 // cplocn is for ocean on coupelr pes 00064 // atmocnid is for intx atm / ocn on coupler pes 00065 // 00066 int rankInAtmComm = -1; 00067 int cmpatm = 5, 00068 cplatm = 6; // component ids are unique over all pes, and established in advance; 00069 00070 std::string ocnFilename = TestDir + "unittest/outTri15_8.h5m"; 00071 std::string mapFilename = TestDir + "unittest/mapNE20_FV15.nc"; // this is a netcdf file! 00072 00073 std::string baseline = TestDir + "unittest/baseline2.txt"; 00074 int rankInOcnComm = -1; 00075 int cmpocn = 17, cplocn = 18, 00076 atmocnid = 618; // component ids are unique over all pes, and established in advance; 00077 00078 int rankInCouComm = -1; 00079 00080 int nghlay = 0; // number of ghost layers for loading the file 00081 std::vector< int > groupTasks; 00082 int startG1 = 0, startG2 = 0, endG1 = numProcesses - 1, endG2 = numProcesses - 1; 00083 00084 int startG4 = startG1, endG4 = endG1; // these are for coupler layout 00085 int context_id = -1; // used now for freeing buffers 00086 00087 // default: load atm / source on 2 proc, ocean / target on 2, 00088 // load map on 2 also, in parallel, distributed by rows (which is very bad actually for ocean mesh, because 00089 // probably all source cells will be involved in coverage mesh on both tasks 00090 00091 ProgOptions opts; 00092 opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename ); 00093 opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename ); 00094 opts.addOpt< std::string >( "map_file,w", "map file from source to target", &mapFilename ); 00095 00096 opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 ); 00097 opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 ); 00098 00099 opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 ); 00100 opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 ); 00101 00102 opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 ); 00103 opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 ); 00104 00105 int types[2] = { 3, 3 }; // type of source and target; 1 = SE, 2,= PC, 3 = FV 00106 int disc_orders[2] = { 1, 1 }; // 1 is for FV and PC; 4 could be for SE 00107 opts.addOpt< int >( "typeSource,x", "source type", &types[0] ); 00108 opts.addOpt< int >( "typeTarget,y", "target type", &types[1] ); 00109 opts.addOpt< int >( "orderSource,u", "source order", &disc_orders[0] ); 00110 opts.addOpt< int >( "orderTarget,v", "target oorder", &disc_orders[1] ); 00111 bool analytic_field = false; 00112 opts.addOpt< void >( "analytic,q", "analytic field", &analytic_field ); 00113 00114 bool no_regression_test = false; 00115 opts.addOpt< void >( "no_regression,r", "do not do regression test against baseline 1", &no_regression_test ); 00116 opts.parseCommandLine( argc, argv ); 00117 00118 char fileWriteOptions[] = "PARALLEL=WRITE_PART"; 00119 00120 if( !rankInGlobalComm ) 00121 { 00122 std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 00123 << "\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 00124 << "\n map file:" << mapFilename << "\n on tasks : " << startG4 << ":" << endG4 << "\n"; 00125 if( !no_regression_test ) 00126 { 00127 std::cout << " check projection against baseline: " << baseline << "\n"; 00128 } 00129 } 00130 00131 // load files on 3 different communicators, groups 00132 // first groups has task 0, second group tasks 0 and 1 00133 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00134 // first groups has task 0, second group tasks 0 and 1 00135 // coupler will be on joint tasks, will be on a third group (0 and 1, again) 00136 MPI_Group atmPEGroup; 00137 MPI_Comm atmComm; 00138 ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm ); 00139 CHECKIERR( ierr, "Cannot create atm MPI group and communicator " ) 00140 00141 MPI_Group ocnPEGroup; 00142 MPI_Comm ocnComm; 00143 ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm ); 00144 CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " ) 00145 00146 // we will always have a coupler 00147 MPI_Group couPEGroup; 00148 MPI_Comm couComm; 00149 ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm ); 00150 CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " ) 00151 00152 // atm_coupler 00153 MPI_Group joinAtmCouGroup; 00154 MPI_Comm atmCouComm; 00155 ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm ); 00156 CHECKIERR( ierr, "Cannot create joint atm cou communicator" ) 00157 00158 // ocn_coupler 00159 MPI_Group joinOcnCouGroup; 00160 MPI_Comm ocnCouComm; 00161 ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm ); 00162 CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) 00163 00164 ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should 00165 CHECKIERR( ierr, "Cannot initialize iMOAB" ) 00166 00167 int cmpAtmAppID = -1; 00168 iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm 00169 int cplAtmAppID = -1; // -1 means it is not initialized 00170 iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs 00171 00172 int cmpOcnAppID = -1; 00173 iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn 00174 int cplOcnAppID = -1, cplAtmOcnAppID = -1; // -1 means it is not initialized 00175 iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs 00176 iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm -ocn on coupler PEs 00177 00178 if( couComm != MPI_COMM_NULL ) 00179 { 00180 MPI_Comm_rank( couComm, &rankInCouComm ); 00181 // Register all the applications on the coupler PEs 00182 ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm, 00183 cplAtmPID ); // atm on coupler pes 00184 CHECKIERR( ierr, "Cannot register ATM over coupler PEs" ) 00185 00186 ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn, 00187 cplOcnPID ); // ocn on coupler pes 00188 CHECKIERR( ierr, "Cannot register OCN over coupler PEs" ) 00189 } 00190 00191 if( atmComm != MPI_COMM_NULL ) 00192 { 00193 MPI_Comm_rank( atmComm, &rankInAtmComm ); 00194 ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID ); 00195 CHECKIERR( ierr, "Cannot register ATM App" ) 00196 ierr = iMOAB_LoadMesh( cmpAtmPID, atmFilename.c_str(), readopts.c_str(), &nghlay ); 00197 CHECKIERR( ierr, "Cannot load atm mesh" ) 00198 } 00199 00200 MPI_Barrier( MPI_COMM_WORLD ); 00201 if( ocnComm != MPI_COMM_NULL ) 00202 { 00203 MPI_Comm_rank( ocnComm, &rankInOcnComm ); 00204 ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID ); 00205 CHECKIERR( ierr, "Cannot register OCN App" ) 00206 ierr = iMOAB_LoadMesh( cmpOcnPID, ocnFilename.c_str(), readopts.c_str(), &nghlay ); 00207 CHECKIERR( ierr, "Cannot load ocn mesh" ) 00208 } 00209 00210 MPI_Barrier( MPI_COMM_WORLD ); 00211 00212 if( couComm != MPI_COMM_NULL ) 00213 { 00214 // now load map between OCNx and ATMx on coupler PEs 00215 ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID ); 00216 CHECKIERR( ierr, "Cannot register ocn_atm map instance over coupler pes " ) 00217 } 00218 00219 const std::string intx_from_file_identifier = "map-from-file"; 00220 00221 if( couComm != MPI_COMM_NULL ) 00222 { 00223 int dummyCpl = -1; 00224 int dummy_rowcol = -1; 00225 int dummyType = 0; 00226 ierr = iMOAB_LoadMappingWeightsFromFile( cplAtmOcnPID, &dummyCpl, &dummy_rowcol, &dummyType, 00227 intx_from_file_identifier.c_str(), mapFilename.c_str() ); 00228 CHECKIERR( ierr, "failed to load map file from disk" ); 00229 } 00230 00231 if( atmCouComm != MPI_COMM_NULL ) 00232 { 00233 int type = types[0]; // FV 00234 int direction = 1; // from source to coupler; will create a mesh on cplAtmPID 00235 // because it is like "coverage", context will be cplocn 00236 ierr = iMOAB_MigrateMapMesh( cmpAtmPID, cplAtmOcnPID, cplAtmPID, &atmCouComm, &atmPEGroup, &couPEGroup, &type, 00237 &cmpatm, &cplocn, &direction ); 00238 CHECKIERR( ierr, "failed to migrate mesh for atm on coupler" ); 00239 #ifdef VERBOSE 00240 if( *cplAtmPID >= 0 ) 00241 { 00242 char prefix[] = "atmcov"; 00243 ierr = iMOAB_WriteLocalMesh( cplAtmPID, prefix ); 00244 CHECKIERR( ierr, "failed to write local mesh" ); 00245 } 00246 #endif 00247 } 00248 MPI_Barrier( MPI_COMM_WORLD ); 00249 00250 if( ocnCouComm != MPI_COMM_NULL ) 00251 { 00252 int type = types[1]; // cells with GLOBAL_ID in ocean / target set 00253 int direction = 2; // from coupler to target; will create a mesh on cplOcnPID 00254 // it will be like initial migrate cmpocn <-> cplocn 00255 ierr = iMOAB_MigrateMapMesh( cmpOcnPID, cplAtmOcnPID, cplOcnPID, &ocnCouComm, &ocnPEGroup, &couPEGroup, &type, 00256 &cmpocn, &cplocn, &direction ); 00257 CHECKIERR( ierr, "failed to migrate mesh for ocn on coupler" ); 00258 00259 #ifdef VERBOSE 00260 if( *cplOcnPID >= 0 ) 00261 { 00262 char prefix[] = "ocntgt"; 00263 ierr = iMOAB_WriteLocalMesh( cplOcnPID, prefix ); 00264 CHECKIERR( ierr, "failed to write local ocean mesh" ); 00265 char outputFileRec[] = "CoupOcn.h5m"; 00266 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileRec, fileWriteOptions ); 00267 CHECKIERR( ierr, "failed to write ocean global mesh file" ); 00268 } 00269 #endif 00270 } 00271 MPI_Barrier( MPI_COMM_WORLD ); 00272 00273 int tagIndex[2]; 00274 int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE }; 00275 int atmCompNDoFs = disc_orders[0] * disc_orders[0], ocnCompNDoFs = disc_orders[1] * disc_orders[1] /*FV*/; 00276 00277 const char* bottomTempField = "AnalyticalSolnSrcExact"; 00278 const char* bottomTempProjectedField = "Target_proj"; 00279 00280 if( couComm != MPI_COMM_NULL ) 00281 { 00282 ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomTempField, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00283 CHECKIERR( ierr, "failed to define the field tag AnalyticalSolnSrcExact" ); 00284 00285 ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomTempProjectedField, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); 00286 CHECKIERR( ierr, "failed to define the field tag Target_proj" ); 00287 } 00288 00289 if( analytic_field && ( atmComm != MPI_COMM_NULL ) ) // we are on source /atm pes 00290 { 00291 // cmpOcnPID, "T_proj;u_proj;v_proj;" 00292 ierr = iMOAB_DefineTagStorage( cmpAtmPID, bottomTempField, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); 00293 CHECKIERR( ierr, "failed to define the field tag AnalyticalSolnSrcExact" ); 00294 00295 int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; 00296 /* 00297 * Each process in the communicator will have access to a local mesh instance, which will contain the 00298 * original cells in the local partition and ghost entities. Number of vertices, primary cells, visible 00299 * blocks, number of sidesets and nodesets boundary conditions will be returned in numProcesses 3 arrays, 00300 * for local, ghost and total numbers. 00301 */ 00302 ierr = iMOAB_GetMeshInfo( cmpAtmPID, nverts, nelem, nblocks, nsbc, ndbc ); 00303 CHECKIERR( ierr, "failed to get num primary elems" ); 00304 int numAllElem = nelem[2]; 00305 int eetype = 1; 00306 00307 if( types[0] == 2 ) // point cloud 00308 { 00309 numAllElem = nverts[2]; 00310 eetype = 0; 00311 } 00312 std::vector< double > vals; 00313 int storLeng = atmCompNDoFs * numAllElem; 00314 vals.resize( storLeng ); 00315 for( int k = 0; k < storLeng; k++ ) 00316 vals[k] = k; 00317 00318 ierr = iMOAB_SetDoubleTagStorage( cmpAtmPID, bottomTempField, &storLeng, &eetype, &vals[0] ); 00319 CHECKIERR( ierr, "cannot make analytical tag" ) 00320 } 00321 00322 // need to make sure that the coverage mesh (created during intx method) received the tag that 00323 // need to be projected to target so far, the coverage mesh has only the ids and global dofs; 00324 // need to change the migrate method to accommodate any GLL tag 00325 // now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh 00326 // (cplAtmPID), using the new coverage graph communicator 00327 00328 // make the tag 0, to check we are actually sending needed data 00329 { 00330 if( cplAtmAppID >= 0 ) 00331 { 00332 int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; 00333 /* 00334 * Each process in the communicator will have access to a local mesh instance, which 00335 * will contain the original cells in the local partition and ghost entities. Number of 00336 * vertices, primary cells, visible blocks, number of sidesets and nodesets boundary 00337 * conditions will be returned in numProcesses 3 arrays, for local, ghost and total 00338 * numbers. 00339 */ 00340 ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc ); 00341 CHECKIERR( ierr, "failed to get num primary elems" ); 00342 int numAllElem = nelem[2]; 00343 int eetype = 1; 00344 if( types[0] == 2 ) // Point cloud 00345 { 00346 eetype = 0; // vertices 00347 numAllElem = nverts[2]; 00348 } 00349 std::vector< double > vals; 00350 int storLeng = atmCompNDoFs * numAllElem; 00351 00352 vals.resize( storLeng ); 00353 for( int k = 0; k < storLeng; k++ ) 00354 vals[k] = 0.; 00355 00356 ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomTempField, &storLeng, &eetype, &vals[0] ); 00357 CHECKIERR( ierr, "cannot make tag nul" ) 00358 00359 // set the tag to 0 00360 } 00361 } 00362 00363 const char* concat_fieldname = "AnalyticalSolnSrcExact"; 00364 const char* concat_fieldnameT = "Target_proj"; 00365 00366 { 00367 00368 PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" ) 00369 if( atmComm != MPI_COMM_NULL ) 00370 { 00371 // as always, use nonblocking sends 00372 // this is for projection to ocean: 00373 ierr = iMOAB_SendElementTag( cmpAtmPID, "AnalyticalSolnSrcExact", &atmCouComm, &cplocn ); 00374 CHECKIERR( ierr, "cannot send tag values" ) 00375 } 00376 if( couComm != MPI_COMM_NULL ) 00377 { 00378 // receive on atm on coupler pes, that was redistributed according to coverage 00379 ierr = iMOAB_ReceiveElementTag( cplAtmPID, "AnalyticalSolnSrcExact", &atmCouComm, &cmpatm ); 00380 CHECKIERR( ierr, "cannot receive tag values" ) 00381 } 00382 00383 // we can now free the sender buffers 00384 if( atmComm != MPI_COMM_NULL ) 00385 { 00386 ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cplocn ); // context is for ocean 00387 CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) 00388 } 00389 POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) 00390 #ifdef VERBOSE 00391 if( *cplAtmPID >= 0 ) 00392 { 00393 char prefix[] = "atmcov_withdata"; 00394 ierr = iMOAB_WriteLocalMesh( cplAtmPID, prefix ); 00395 CHECKIERR( ierr, "failed to write local atm cov mesh with data" ); 00396 } 00397 #endif 00398 00399 if( couComm != MPI_COMM_NULL ) 00400 { 00401 /* We have the remapping weights now. Let us apply the weights onto the tag we defined 00402 on the source mesh and get the projection on the target mesh */ 00403 PUSH_TIMER( "Apply Scalar projection weights" ) 00404 ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, intx_from_file_identifier.c_str(), 00405 concat_fieldname, concat_fieldnameT ); 00406 CHECKIERR( ierr, "failed to compute projection weight application" ); 00407 POP_TIMER( couComm, rankInCouComm ) 00408 00409 { 00410 char outputFileTgt[] = "fOcnOnCpl6.h5m"; 00411 ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions ); 00412 CHECKIERR( ierr, "could not write fOcnOnCpl6.h5m to disk" ) 00413 } 00414 } 00415 00416 // send the projected tag back to ocean pes, with send/receive tag 00417 if( ocnComm != MPI_COMM_NULL ) 00418 { 00419 int tagIndexIn2; 00420 ierr = iMOAB_DefineTagStorage( cmpOcnPID, bottomTempProjectedField, &tagTypes[1], &ocnCompNDoFs, 00421 &tagIndexIn2 ); 00422 CHECKIERR( ierr, "failed to define the field tag for receiving back the tag " 00423 "Target_proj on ocn pes" ); 00424 } 00425 // send the tag to ocean pes, from ocean mesh on coupler pes 00426 // from couComm, using common joint comm ocn_coupler 00427 // as always, use nonblocking sends 00428 // original graph (context is -1_ 00429 if( couComm != MPI_COMM_NULL ) 00430 { 00431 // need to use ocean comp id for context 00432 context_id = cmpocn; // id for ocean on comp 00433 ierr = iMOAB_SendElementTag( cplOcnPID, "Target_proj", &ocnCouComm, &context_id ); 00434 CHECKIERR( ierr, "cannot send tag values back to ocean pes" ) 00435 } 00436 00437 // receive on component 2, ocean 00438 if( ocnComm != MPI_COMM_NULL ) 00439 { 00440 context_id = cplocn; // id for ocean on coupler 00441 ierr = iMOAB_ReceiveElementTag( cmpOcnPID, "Target_proj", &ocnCouComm, &context_id ); 00442 CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" ) 00443 } 00444 00445 if( couComm != MPI_COMM_NULL ) 00446 { 00447 context_id = cmpocn; 00448 ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id ); 00449 } 00450 MPI_Barrier( MPI_COMM_WORLD ); 00451 00452 if( ocnComm != MPI_COMM_NULL ) 00453 { 00454 #ifdef VERBOSE 00455 char outputFileOcn[] = "OcnWithProj.h5m"; 00456 ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions ); 00457 CHECKIERR( ierr, "could not write OcnWithProj.h5m to disk" ) 00458 #endif 00459 // test results only for n == 1, for bottomTempProjectedField 00460 if( !no_regression_test ) 00461 { 00462 // the same as remap test 00463 // get temp field on ocean, from conservative, the global ids, and dump to the baseline file 00464 // first get GlobalIds from ocn, and fields: 00465 int nverts[3], nelem[3]; 00466 ierr = iMOAB_GetMeshInfo( cmpOcnPID, nverts, nelem, 0, 0, 0 ); 00467 CHECKIERR( ierr, "failed to get ocn mesh info" ); 00468 std::vector< int > gidElems; 00469 gidElems.resize( nelem[2] ); 00470 std::vector< double > tempElems; 00471 tempElems.resize( nelem[2] ); 00472 // get global id storage 00473 const std::string GidStr = "GLOBAL_ID"; // hard coded too 00474 int tag_type = DENSE_INTEGER, ncomp = 1, tagInd = 0; 00475 ierr = iMOAB_DefineTagStorage( cmpOcnPID, GidStr.c_str(), &tag_type, &ncomp, &tagInd ); 00476 CHECKIERR( ierr, "failed to define global id tag" ); 00477 00478 int ent_type = 1; 00479 ierr = iMOAB_GetIntTagStorage( cmpOcnPID, GidStr.c_str(), &nelem[2], &ent_type, &gidElems[0] ); 00480 CHECKIERR( ierr, "failed to get global ids" ); 00481 ierr = iMOAB_GetDoubleTagStorage( cmpOcnPID, bottomTempProjectedField, &nelem[2], &ent_type, 00482 &tempElems[0] ); 00483 CHECKIERR( ierr, "failed to get temperature field" ); 00484 int err_code = 1; 00485 check_baseline_file( baseline, gidElems, tempElems, 1.e-9, err_code ); 00486 if( 0 == err_code ) 00487 std::cout << " passed baseline test atm2ocn on ocean task " << rankInOcnComm << "\n"; 00488 } 00489 } 00490 00491 } // end loop iterations n 00492 00493 if( couComm != MPI_COMM_NULL ) 00494 { 00495 ierr = iMOAB_DeregisterApplication( cplAtmOcnPID ); 00496 CHECKIERR( ierr, "cannot deregister app intx AO" ) 00497 } 00498 if( ocnComm != MPI_COMM_NULL ) 00499 { 00500 ierr = iMOAB_DeregisterApplication( cmpOcnPID ); 00501 CHECKIERR( ierr, "cannot deregister app OCN1" ) 00502 } 00503 00504 if( atmComm != MPI_COMM_NULL ) 00505 { 00506 ierr = iMOAB_DeregisterApplication( cmpAtmPID ); 00507 CHECKIERR( ierr, "cannot deregister app ATM1" ) 00508 } 00509 00510 if( couComm != MPI_COMM_NULL ) 00511 { 00512 ierr = iMOAB_DeregisterApplication( cplOcnPID ); 00513 CHECKIERR( ierr, "cannot deregister app OCNX" ) 00514 } 00515 00516 if( couComm != MPI_COMM_NULL ) 00517 { 00518 ierr = iMOAB_DeregisterApplication( cplAtmPID ); 00519 CHECKIERR( ierr, "cannot deregister app ATMX" ) 00520 } 00521 00522 //#endif 00523 ierr = iMOAB_Finalize(); 00524 CHECKIERR( ierr, "did not finalize iMOAB" ) 00525 00526 // free atm coupler group and comm 00527 if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm ); 00528 MPI_Group_free( &joinAtmCouGroup ); 00529 if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm ); 00530 00531 if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm ); 00532 // free ocn - coupler group and comm 00533 if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm ); 00534 MPI_Group_free( &joinOcnCouGroup ); 00535 00536 if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm ); 00537 00538 MPI_Group_free( &atmPEGroup ); 00539 00540 MPI_Group_free( &ocnPEGroup ); 00541 00542 MPI_Group_free( &couPEGroup ); 00543 MPI_Group_free( &jgroup ); 00544 00545 MPI_Finalize(); 00546 00547 return 0; 00548 }
